Лог клиента
WTware v.5.4.20
WTware v.5.4.20/Pi2 supervisor.
WTC listener is active.
HTTPd listener is active.
[ KERNEL] [ 0.000000] Booting Linux on physical CPU 0xf00
[ KERNEL] [ 0.000000] Linux version 4.1.19 (aka@c12) (gcc version 5.2.1 20151010 (Ubuntu 5.2.1-22ubuntu1) ) #4 SMP PREEMPT Sun Mar 13 03:20:30 SAMT 2016
[ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ KERNEL] [ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 8080aa80, node_mem_map ba092000
[ KERNEL] [ 0.000000] Normal zone: 1888 pages used for memmap
[ KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] enter (93c0->f3003010)
[ KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ KERNEL] [ 0.000000] PERCPU: Embedded 10 pages/cpu @ba05c000 s10688 r8192 d22080 u40960
[ KERNEL] [ 0.000000] pcpu-alloc: s10688 r8192 d22080 u40960 alloc=10*4096
[ KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239776
[ KERNEL] [ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa01041 bcm2709.serial=0x77135906 smsc95xx.macaddr=B8:27:EB:13:59:06 bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 console=ttyAMA0,115200 console=tty1 wtboot=mmc
[ KERNEL] [ 0.000000] Memory: 941268K/966656K available (3439K kernel code, 261K rwdata, 1104K rodata, 3400K init, 347K bss, 17196K reserved, 8192K cma-reserved)
[ KERNEL] [ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[ KERNEL] [ 0.000000] .text : 0x80008000 - 0x80477fc4 (4544 kB)
[ KERNEL] [ 0.000000] .init : 0x80478000 - 0x807ca000 (3400 kB)
[ KERNEL] [ 0.000000] .data : 0x807ca000 - 0x8080b6c0 ( 262 kB)
[ KERNEL] [ 0.000000] .bss : 0x8080e000 - 0x80864c28 ( 348 kB)
[ KERNEL] [ 0.000000] Preemptible hierarchical RCU implementation.
[ KERNEL] [ 0.000000] NR_IRQS:608
[ KERNEL] [ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ KERNEL] [ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ KERNEL] [ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ KERNEL] [ 0.000030] Switching to timer-based delay loop, resolution 52ns
[ KERNEL] [ 0.000225] Console: colour dummy device 80x30
[ KERNEL] [ 0.001227] console [tty1] enabled
[ KERNEL] [ 0.001275] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ KERNEL] [ 0.001349] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.001516] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.001564] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.002622] CPU: Testing write buffer coherency: ok
[ KERNEL] [ 0.003190] CPU0: update cpu_capacity 1024
[ KERNEL] [ 0.003238] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ KERNEL] [ 0.003278] [bcm2709_smp_prepare_cpus] enter
[ KERNEL] [ 0.003392] Setting up static identity map for 0x8240 - 0x8274
[ KERNEL] [ 0.060262] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ KERNEL] [ 0.060625] [bcm2709_secondary_init] enter cpu:1
[ KERNEL] [ 0.060675] CPU1: update cpu_capacity 1024
[ KERNEL] [ 0.060682] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ KERNEL] [ 0.080223] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ KERNEL] [ 0.080507] [bcm2709_secondary_init] enter cpu:2
[ KERNEL] [ 0.080536] CPU2: update cpu_capacity 1024
[ KERNEL] [ 0.080544] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ KERNEL] [ 0.100266] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ KERNEL] [ 0.100522] [bcm2709_secondary_init] enter cpu:3
[ KERNEL] [ 0.100549] CPU3: update cpu_capacity 1024
[ KERNEL] [ 0.100556] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ KERNEL] [ 0.100628] Brought up 4 CPUs
[ KERNEL] [ 0.100751] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ KERNEL] [ 0.100789] CPU: All CPU(s) started in HYP mode.
[ KERNEL] [ 0.100821] CPU: Virtualization extensions available.
[ KERNEL] [ 0.101453] devtmpfs: initialized
[ KERNEL] [ 0.124189] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ KERNEL] [ 0.124837] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ KERNEL] [ 0.125374] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.125964] NET: Registered protocol family 16
[ KERNEL] [ 0.131428] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ KERNEL] [ 0.132438] bcm2709.uart_clock = 3000000
[ KERNEL] [ 0.139887] Serial: AMBA PL011 UART driver
[ KERNEL] [ 0.140166] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ KERNEL] [ 0.573289] console [ttyAMA0] enabled
[ KERNEL] [ 0.577537] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ KERNEL] [ 0.662278] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[ KERNEL] [ 0.671090] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[ KERNEL] [ 0.679948] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ KERNEL] [ 0.686907] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ KERNEL] [ 0.692851] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.698583] usbcore: registered new interface driver hub
[ KERNEL] [ 0.704103] usbcore: registered new device driver usb
[ KERNEL] [ 0.710213] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-09 18:11
[ KERNEL] [ 0.746080] Switched to clocksource arch_sys_counter
[ KERNEL] [ 0.767596] NET: Registered protocol family 2
[ KERNEL] [ 0.772994] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ KERNEL] [ 0.780265] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ KERNEL] [ 0.786935] TCP: Hash tables configured (established 8192 bind 8192)
[ KERNEL] [ 0.793417] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.799434] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.806124] NET: Registered protocol family 1
[ KERNEL] [ 2.964780] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ KERNEL] [ 2.971374] audit: initializing netlink subsys (disabled)
[ KERNEL] [ 2.976959] audit: type=2000 audit(2.779:1): initialized
[ KERNEL] [ 3.015054] alg: No test for stdrng (krng)
[ KERNEL] [ 3.030592] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ KERNEL] [ 3.041054] io scheduler noop registered
[ KERNEL] [ 3.045092] io scheduler cfq registered (default)
[ KERNEL] [ 3.055987] BCM2708FB: allocated DMA memory fac00000
[ KERNEL] [ 3.061078] BCM2708FB: allocated DMA channel 0 @ f3007000
[ KERNEL] [ 3.101864] Console: switching to colour frame buffer device 240x67
[ KERNEL] [ 3.131123] bcm2708_rng_init=bb906000
[ KERNEL] [ 4.020635] bcm2835-rng 3f104000.rng: hwrng registered
[ KERNEL] [ 4.026121] vc-cma: Videocore CMA driver
[ KERNEL] [ 4.030143] vc-cma: vc_cma_base = 0x00000000
[ KERNEL] [ 4.034957] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ KERNEL] [ 4.040492] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ KERNEL] [ 4.046378] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ KERNEL] [ 4.056723] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ KERNEL] [ 4.065813] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ KERNEL] [ 4.272398] Core Release: 2.80a
[ KERNEL] [ 4.275645] Setting default values for core params
[ KERNEL] [ 4.280586] Finished setting default values for core params
[ KERNEL] [ 4.486756] Using Buffer DMA mode
[ KERNEL] [ 4.490157] Periodic Transfer Interrupt Enhancement - disabled
[ KERNEL] [ 4.496194] Multiprocessor Interrupt Enhancement - disabled
[ KERNEL] [ 4.501874] OTG VER PARAM: 0, OTG VER FLAG: 0
[ KERNEL] [ 4.506368] Dedicated Tx FIFOs mode
[ KERNEL] [ 4.510512] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ KERNEL] [ 4.520617] FIQ FSM acceleration enabled for :
[ KERNEL] [ 4.520617] Non-periodic Split Transactions
[ KERNEL] [ 4.520617] Periodic Split Transactions
[ KERNEL] [ 4.520617] High-Speed Isochronous Endpoints
[ KERNEL] [ 4.537727] dwc_otg: Microframe scheduler enabled
[ KERNEL] [ 4.537828] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80216e84
[ KERNEL] [ 4.543869] WARN::hcd_init_fiq:413: FIQ ASM at 0x802171e8 length 36
[ KERNEL] [ 4.550251] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb90a000
[ KERNEL] [ 4.556408] dwc_otg 3f980000.usb: DWC OTG Controller
[ KERNEL] [ 4.561514] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ KERNEL] [ 4.569017] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ KERNEL] [ 4.574728] Init: Port Power? op_state=1
[ KERNEL] [ 4.578750] Init: Power Port (0)
[ KERNEL] [ 4.582289] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ KERNEL] [ 4.589306] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 4.596688] usb usb1: Product: DWC OTG Controller
[ KERNEL] [ 4.601481] usb usb1: Manufacturer: Linux 4.1.19 dwc_otg_hcd
[ KERNEL] [ 4.607264] usb usb1: SerialNumber: 3f980000.usb
[ KERNEL] [ 4.612836] hub 1-0:1.0: USB hub found
[ KERNEL] [ 4.616788] hub 1-0:1.0: 1 port detected
[ KERNEL] [ 4.627119] dwc_otg: FIQ enabled
[ KERNEL] [ 4.627132] dwc_otg: NAK holdoff enabled
[ KERNEL] [ 4.627142] dwc_otg: FIQ split-transaction FSM enabled
[ KERNEL] [ 4.627188] Module dwc_common_port init
[ KERNEL] [ 4.628461] bcm2835-cpufreq: min=600000 max=900000
[ KERNEL] [ 4.642594] sdhost: log_buf @ bac13000 (fac13000)
[ KERNEL] [ 4.726120] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ KERNEL] [ 4.736160] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 4.747373] usbcore: registered new interface driver usbhid
[ KERNEL] [ 4.757377] usbhid: USB HID core driver
[ KERNEL] [ 4.765649] NET: Registered protocol family 17
[ KERNEL] [ 4.774437] Registering SWP/SWPB emulation handler
[ KERNEL] [ 4.783704] registered taskstats version 1
[ KERNEL] [ 4.792291] vc-sm: Videocore shared memory driver
[ KERNEL] [ 4.800849] [vc_sm_connected_init]: start
[ KERNEL] [ 4.809507] [vc_sm_connected_init]: end - returning 0
[ KERNEL] [ 4.824029] mmc0: host does not support reading read-only switch, assuming write-enable
[ KERNEL] [ 4.825167] Freeing unused kernel memory: 3400K (80478000 - 807ca000)
[ KERNEL] [ 4.846527] Indeed it is in host mode hprt0 = 00021501
[ KERNEL] [ 4.859581] mmc0: new high speed SDHC card at address aaaa
[ KERNEL] [ 4.862382] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ KERNEL] [ 4.863844] mmcblk0: p1
[ KERNEL] [ 5.026124] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ KERNEL] [ 5.026271] Indeed it is in host mode hprt0 = 00001101
[ hotplug] [ 4.972363] Block device 179:1. No action.
[ hotplug] [ 4.974570] Block device 179:0. No action.
[ pfac] [ 4.995761] Run /sbin/initrd.
[ pfac] [ 4.995900] Ok, PID 511.
[ initrd] [ 4.999624] WTware shell v.5.4.20/Pi2
[ initrd] [ 5.022866] Local media boot.
[ initrd] [ 5.023069] USB boot.
[ KERNEL] [ 5.226444] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ KERNEL] [ 5.226467] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 5.227143] hub 1-1:1.0: USB hub found
[ KERNEL] [ 5.227277] hub 1-1:1.0: 5 ports detected
[ KERNEL] [ 5.506131] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ KERNEL] [ 5.606424] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ KERNEL] [ 5.606446] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 5.686125] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[ KERNEL] [ 5.791248] usb 1-1.2: New USB device found, idVendor=10c4, idProduct=8105
[ KERNEL] [ 5.791269] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 5.791284] usb 1-1.2: Product: USB OPTICAL MOUSE
[ KERNEL] [ 5.791299] usb 1-1.2: Manufacturer: YSPRINGTECH
[ KERNEL] [ 5.798247] input: YSPRINGTECH USB OPTICAL MOUSE as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:10C4:8105.0001/input/input0
[ KERNEL] [ 5.798809] hid-generic 0003:10C4:8105.0001: input,hidraw0: USB HID v1.11 Mouse [YSPRINGTECH USB OPTICAL MOUSE] on usb-3f980000.usb-1.2/input0
[ KERNEL] [ 5.876157] usb 1-1.4: new low-speed USB device number 5 using dwc_otg
[ KERNEL] [ 6.002279] usb 1-1.4: New USB device found, idVendor=046e, idProduct=55a5
[ KERNEL] [ 6.002301] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 6.002316] usb 1-1.4: Product: USB Multimedia Keyboard
[ KERNEL] [ 6.002331] usb 1-1.4: Manufacturer: BTC
[ KERNEL] [ 6.018706] input: BTC USB Multimedia Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046E:55A5.0002/input/input1
[ KERNEL] [ 6.076711] hid-generic 0003:046E:55A5.0002: input,hidraw1: USB HID v1.10 Keyboard [BTC USB Multimedia Keyboard] on usb-3f980000.usb-1.4/input0
[ KERNEL] [ 6.104549] input: BTC USB Multimedia Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046E:55A5.0003/input/input2
[ KERNEL] [ 6.156959] hid-generic 0003:046E:55A5.0003: input,hiddev0,hidraw2: USB HID v1.10 Device [BTC USB Multimedia Keyboard] on usb-3f980000.usb-1.4/input1
[ KERNEL] [ 6.236136] usb 1-1.5: new high-speed USB device number 6 using dwc_otg
[ KERNEL] [ 6.341968] usb 1-1.5: New USB device found, idVendor=13fe, idProduct=4100
[ KERNEL] [ 6.341992] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 6.342007] usb 1-1.5: Product: USB DISK 2.0
[ KERNEL] [ 6.342024] usb 1-1.5: Manufacturer:
[ KERNEL] [ 6.342039] usb 1-1.5: SerialNumber: 0700383D8BDDE432
[ initrd] [ 6.195347] Load UTF8 charset.
[ initrd] [ 6.195567] modprobe nls_cp437.
[ initrd] [ 6.207037] modprobe nls_utf8.
[ initrd] [ 6.218684] Load VFAT filesystem driver.
[ initrd] [ 6.218937] modprobe fat.
[ initrd] [ 6.232743] modprobe vfat.
[ initrd] [ 6.251208] WTpassword empty.
| clientIP = *
| config = network
| tftpIP = 192.168.1.51
[ initrd] [ 9.173852] Load ethernet drivers.
[ initrd] [ 9.173990] modprobe smsc95xx.
[ KERNEL] [ 9.378312] smsc95xx v1.0.4
[ KERNEL] [ 9.439079] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:13:59:06
[ KERNEL] [ 9.439387] usbcore: registered new interface driver smsc95xx
[ KERNEL] [ 9.497842] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ KERNEL] [ 11.029119] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ initrd] [ 11.350186] dhcp: 302 bytes from 192.168.1.1.
[ initrd] [ 11.350369] 00000000:0000011a0000000000110000c0a80101ffffffff00430044011a000002010600 ...................C.D.......
[ initrd] [ 11.350520] 00000020:67458b6b0000000000000000c0a801340000000000000000b827eb1359060000 gE.k...........4.........'.Y...
[ initrd] [ 11.350645] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.350766] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ KERNEL] [ 11.835557] random: nonblocking pool is initialized
[ initrd] [ 12.830138] dhcp: 302 bytes from 192.168.1.1.
[ initrd] [ 12.830291] 00000000:0000011a0000000000110000c0a80101ffffffff00430044011a000002010600 ...................C.D.......
[ initrd] [ 12.830414] 00000020:67458b6b0000000000000000c0a801340000000000000000b827eb1359060000 gE.k...........4.........'.Y...
[ initrd] [ 12.830535] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 12.830675] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 12.860101] dhcp: server address 192.168.1.1.
[ initrd] [ 12.860217] dhcp: 192.168.1.52/255.255.255.0.
[ initrd] [ 12.860323] dhcp: default gateway 192.168.1.1.
[ initrd] [ 12.860439] dhcp: DNS 192.168.1.1.
[ initrd] [ 12.860546] TFTP IP 192.168.1.51 already specified.
[ initrd] [ 12.860651] No boot file from DHCP.
[ initrd] [ 12.860754] TFTP binary "", configs prefix "", using "/" slash.
Send broadcast WTCU discover.
[ initrd] [ 12.862036] TFTP: download file Everyone/list.wtc from 192.168.1.51.
[ initrd] [ 12.869046] WTware TFTP v.5.4.20.
| # Ïðèìåðû:
| # 02.03.04.05.06.07 file1
| # ListIncludes/file7.
[ initrd] [ 12.879961] TFTP: download file Terminals/B8.27.EB.13.59.06/config.wtc from 192.168.1.51.
| connection
[ initrd] [ 12.884725] TFTP: download file Everyone/all.wtc from 192.168.1.51.
| [BOM]
| server=192.168.1.51
| graphic=a
| keyswitch=alt-shift
| disk=usb
| rdp_printer=auto
| turnoffmenu=on
| redraw_delay=50
| user=lpp[test]:\x45\x63\x74\x68\x6c\x62\x74\x66\x65\x64\x6f\x72\x61\x31\x32
| smartcard=rutoken
[ initrd] [ 12.887964] TFTP: download file Everyone/wtware.lic from 192.168.1.51.
[ KERNEL] [ 13.087543] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
| [BOM]
| server=192.168.1.51
| graphic=a
| keyswitch=alt-shift
| disk=usb
| rdp_printer=auto
| turnoffmenu=on
| redraw_delay=50
| smartcard=rutoken
| connection
[ initrd] [ 12.901074] Hostname: "wtwB827EB135906".
RSH: listener is active.
[ gm] [ 13.085343] WTware session manager v.5.4.20/Pi2.
[ gm] [ 13.086324] Add keyboard event2: BTC USB Multimedia Keyboard.
[ gm] [ 13.086430] Add keyboard event1: BTC USB Multimedia Keyboard.
[ gm] [ 13.140122] EV_REL flag found. Add mouse event0: YSPRINGTECH USB OPTICAL MOUSE.
[ gm] [ 13.140359] Display mode: 1920x1080, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 13.154806] Framebuffer device found.
[ gm] [ 13.154915] LINELENBYTES 3840
[ gm] [ 13.154998] VLEN 4147200
[ gm] [ 13.194745] download.cpp ( 156): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 13.194994] Fatal error: INTERNAL ERROR
WTware v.5.4.20/Pi2
File: globalConfig.cpp
Line: 1894
Please, report this information
to WTware tech support.
[ gm] [ 13.199568] /graphic/exlm.png: 44x42.
