ION + wtware
ION + wtware
В один прекрасный момент перестали работать часть терминалов на моноблоках Acer Veriton 262.
Видеокарты - nVidia ION
в настройках стоит:
video = nouveau(F)
Работает только разрешение 1024*768, все что выше - черный экран.
Родное 1366*768 не работает.
в настройках стоит:
video = nouveau(F)
Re: ION + wtware
Экспериментальным путем выяснили, что при установке разрешения по ширине больше 1330 пикс (при родном 1366) вылетает с ошибкой:
[ gm] [ 13.214201] Connector Id 61.
[ gm] [ 13.215166] Encoder Id 62.
[ gm] [ 13.215245] CRTC Id 50.
[ gm] [ 13.215316] Force 60Hz refresh.
[ gm] [ 13.215684] Make new mode 1340x766@60Hz.
[ gm] [ 13.215764] Mode 1340x766@60Hz NOT found in table. Generate timings.
[ gm] [ 13.215836] Mode 1340x766: clock 83740 H 1344 1408 1552 1760 0 V 766 767 770 793 0 VR 60 flags 0x000a type 0x0028.
[ gm] [ 13.215982] fb_ptr 0xb740d000
[ gm] [ 13.216239] stride 5376.
[ gm] [ 13.216493] size 4120576.
[ gm] [ 13.216723] handle 0x00000001.
[ gm] [ 13.238367] ======================
[ gm] [ 13.238454] fb_id 0.
[ gm] [ 13.238525] width 1340.
[ gm] [ 13.238581] height 766.
[ gm] [ 13.238632] pitch 5376.
[ gm] [ 13.238682] bpp 32.
[ gm] [ 13.238733] depth 24.
[ gm] [ 13.238783] handle 0x00000001.
[ gm] [ 13.238833] ======================
[ gm] [ 13.238884] DRM ioctl failed with -1, errno 28.
[ gm] [ 13.238934] graphdriver_f_drm.cpp ( 877): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 13.238985] graphdriver_f_drm.cpp ( 938): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 13.239036] graphdriver_f.cpp ( 605): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 13.239087] graphconsole.cpp ( 669): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 13.239137] graphconsole.cpp ( 713): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ pfac] [ 13.804525] Process pid 291 terminated, status 00000000.
[ pfac] [ 13.804617] [ERROR] UDSD_send failed: sendto() return -1 instead of 5, errno 111.
[ pfac] [ 13.804671] hotplug.h ( 64): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ KERNEL] [ 23.395623] nouveau 0000:03:00.0: [drm] Cannot find any crtc or sizes
Re: ION + wtware
В БИОСе не ковырялись, конфиг втвари не меняли, версию втвари не меняли, ни на что не нажимали, оно само?
А в логе 1366x768 и с ошибкой не вылетает. Что это за лог и где логи с ошибкой?
Логи с ошибкой в студию.
1. В конфиге:
display=1366x768
bpp=16
display=1366x768
4. Опять же в BIOS, скорее всего в разделе Boot, поискать отключение Legacy/Compatibility/CSM.
Вместо них включение UEFI или EFI.
Если получится, шрифт втвари немного поменяется и везде после версии втвари будет написано /UEFI.
Re: ION + wtware
возможно, в биосе.. сейчас проверил - там нет никаких настроек ни Legacy/Compatibility/CSM, ни про видео...
для надежности сбросил настройки биоса к заводским, не помогло.
ошибок нет, но черный экран.
Возможно, поможет.
Если ставить разрешение еще меньше, например, 800*600, то изображение дублируется, показывая копии экрана вверху и внизу
Re: ION + wtware
аналогично - черный экран.bpp=16
display=1366x768
Re: ION + wtware
bpp=16 оно ругается, наверное не понимает.
С 32 битами цвета оно считает, что всё работает. Ругани в логе нет. Не знаю, куда копать. Если когда-то работало, а сейчас так, то наверное ядерщики сломали драйвер и чинить его уже некому.
Обновить BIOS наверное уже не получится?
Надо вспоминать, какая версия втвари на этом моноблоке работала, и оставаться на ней. Наш склад старых версий здесь: http://wtware.ru/files/
