Сильно тормозит один из терминалов.
AndreyEver
Сообщение AndreyEver »
Wtware 6.2.20
Работать как локально, так и по wtrc невозможно. Лога забит вот такими ошибками. Есть идеи как поправить?
P.S. мышь подключена надежно. Пробовали переподключать в другой USB порт
[            gm] [181325.575077]                           evdev-device.cpp (  857): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[        KERNEL] [181325.558940] usb 1-1.3: USB disconnect, device number 60
[            gm] [181325.575138] [EVDEV] Close input device 'PixArt USB Optical Mouse', errno 19.
[        KERNEL] [181325.804184] usb 1-1.3: new low-speed USB device number 61 using ehci-pci
[        KERNEL] [181325.916437] usb 1-1.3: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[        KERNEL] [181325.916445] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [181325.916448] usb 1-1.3: Product: USB Optical Mouse
[        KERNEL] [181325.916451] usb 1-1.3: Manufacturer: PixArt
[        KERNEL] [181325.919204] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:093A:2510.003A/input/input64
[        KERNEL] [181325.919343] hid-generic 0003:093A:2510.003A: input,hidraw1: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1a.0-1.3/input0
[ rdpclient 491] [181397.857875] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [181467.310601] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [182265.350051] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [182321.521101] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [182901.246844] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [183836.709493] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [183839.400680] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [183867.833789] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [183897.230052] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [183912.680321] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [183916.359877] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [183929.953696] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [183931.781159] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184259.079029] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184263.740507] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184264.660374] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [184293.535915] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184326.605713] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184416.137076] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [184419.238468] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184429.195788] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184479.949825] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184480.160941] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184534.536068] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [184716.245307] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184716.435637] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184774.276107] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184775.479631] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [184777.245846] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184957.233352] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [184957.316225] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [184994.666119] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [185002.343206] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [185002.353426] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [185791.811416] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [185892.549152] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [188486.532784] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [188581.241809] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [188581.515672] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [208242.936465] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [208243.065062] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[        KERNEL] [336914.110912] usb 1-1.3: USB disconnect, device number 61
[            gm] [336914.144201]                           evdev-device.cpp (  857): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[            gm] [336914.144245] [EVDEV] Close input device 'PixArt USB Optical Mouse', errno 19.
[        KERNEL] [336914.353156] usb 1-1.3: new low-speed USB device number 62 using ehci-pci
[        KERNEL] [336914.469405] usb 1-1.3: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[        KERNEL] [336914.469413] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [336914.469417] usb 1-1.3: Product: USB Optical Mouse
[        KERNEL] [336914.469419] usb 1-1.3: Manufacturer: PixArt
[        KERNEL] [336914.472175] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:093A:2510.003B/input/input65
[        KERNEL] [336914.472322] hid-generic 0003:093A:2510.003B: input,hidraw1: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1a.0-1.3/input0
[ rdpclient 491] [336923.377674] [ClearCodec debug] The cursor has gone over the edge.
[ rdpclient 491] [338519.932584] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 491] [338524.637353] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 491] [340683.135395] [ClearCodec debug] The cursor has gone over the edge.
Re: Сильно тормозит один из терминалов.
Не вижу ничего плохого для обрывка лога за четверо суток работы. В первые сутки проблема есть? Покажи лог целиком.
AndreyEver
Станцию ребутнули. Пришлю как только опять начнет чудить. Но в логе постоянные
после которых стабильно идет
и сново переподлючаем мышь.
AndreyEver писал(а): Ср апр 24, 2024 11:57 am [ rdpclient 491] [208243.065062]...
Между этими событиями 35 часов!
AndreyEver
Сильно помогло уменьшение TCP MSS в кпд.
Кто такой кпд?
