В версии 6.2.2 проблема с драйверами nvidia
Taniriel
Сообщение Taniriel »
Здравствуйте.
В версии 6.2.2 проблема с драйверами nvidia nouveau(f) полностью отсутствует изображение на мониторах после загрузки тонкого клиента.
На версии 6.0.50 работает нормально.
Ниже последняя часть лога
[ initrd] [ 8.164808] [TFTP] Download and unpack file 6.2.2\packages\f-drm from 192.168.1.200.
[ initrd] [ 8.602256] [TFTP] Download and unpack file 6.2.2\packages\fwt6 from 192.168.1.200.
[ KERNEL] [ 9.241007] random: crng init done
[ initrd] [ 9.960828] [TFTP] Download and unpack file 6.2.2\packages\f-nouveau from 192.168.1.200.
[ initrd] [ 10.387917] [TFTP] Download and unpack file 6.2.2\packages\graphic from 192.168.1.200.
[ gm] [ 10.452354] WTware 6.2.2 session manager.
[ KERNEL] [ 10.457055] input: Remote Control Keyboard as /devices/virtual/input/input8
[ gm] [ 10.465719] [EVDEV] Keys found. Add event7: Remote Control Keyboard.
[ gm] [ 10.465808] [EVDEV] Keys found. Add event6: Logitech USB Keyboard System Control.
[ gm] [ 10.465847] [EVDEV] EV_ABS flag found. Add event5: Logitech USB Keyboard Consumer Control.
[ gm] [ 10.465886] [EVDEV] Keys found. Add event4: Logitech USB Keyboard.
[ gm] [ 10.465920] [EVDEV] EV_REL flag found. Add event3: Logitech M215.
[ gm] [ 10.465955] [EVDEV] Ignore event2: PC Speaker.
[ gm] [ 10.465990] [EVDEV] Keys found. Add event1: Power Button.
[ gm] [ 10.466027] [EVDEV] Keys found. Add event0: Power Button.
[ gm] [ 10.466063] Display mode: 1024x768, 16 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 2.
[ gm] [ 10.466108] M2 mode: 1024x768, landscape, 0 Hz, modeline "", DDC enabled, connector 1.
[ gm] [ 10.839792] modprobe drm.
[ gm] [ 10.846834] Run modprobe nouveau .
[ gm] [ 10.846911] modprobe nouveau.
[ KERNEL] [ 10.880719] nouveau 0000:04:00.0: vgaarb: deactivate vga console
[ KERNEL] [ 10.880851] Console: switching to colour dummy device 80x25
[ KERNEL] [ 10.881342] nouveau 0000:04:00.0: NVIDIA GT218 (0a8280b1)
[ KERNEL] [ 11.104402] nouveau 0000:04:00.0: bios: version 70.18.a6.00.0e
[ KERNEL] [ 11.114110] nouveau 0000:04:00.0: fb: 1024 MiB DDR3
[ KERNEL] [ 12.449052] nouveau 0000:04:00.0: DRM: VRAM: 1024 MiB
[ KERNEL] [ 12.449062] nouveau 0000:04:00.0: DRM: GART: 1048576 MiB
[ KERNEL] [ 12.449069] nouveau 0000:04:00.0: DRM: TMDS table version 2.0
[ KERNEL] [ 12.449073] nouveau 0000:04:00.0: DRM: DCB version 4.0
[ KERNEL] [ 12.449077] nouveau 0000:04:00.0: DRM: DCB outp 00: 01000302 00020030
[ KERNEL] [ 12.449083] nouveau 0000:04:00.0: DRM: DCB outp 01: 02000300 00000000
[ KERNEL] [ 12.449088] nouveau 0000:04:00.0: DRM: DCB outp 02: 02022362 00020010
[ KERNEL] [ 12.449092] nouveau 0000:04:00.0: DRM: DCB outp 03: 01011310 00000000
[ KERNEL] [ 12.449097] nouveau 0000:04:00.0: DRM: DCB conn 00: 00001030
[ KERNEL] [ 12.449101] nouveau 0000:04:00.0: DRM: DCB conn 01: 00000100
[ KERNEL] [ 12.449104] nouveau 0000:04:00.0: DRM: DCB conn 02: 00002261
[ KERNEL] [ 12.451975] nouveau 0000:04:00.0: DRM: MM: using COPY for buffer copies
[ gm] [ 12.556420] Kernel drm/kms module loaded.
[ KERNEL] [ 12.529374] nouveau 0000:04:00.0: DRM: allocated 1280x1024 fb: 0x70000, bo 0b0325d2
[ KERNEL] [ 12.529543] fbcon: nouveaudrmfb (fb0) is primary device
[ KERNEL] [ 12.529700] Console: switching to colour frame buffer device 160x64
[ KERNEL] [ 12.529718] nouveau 0000:04:00.0: [drm] fb0: nouveaudrmfb frame buffer device
[ KERNEL] [ 12.530217] [drm] Initialized nouveau 1.3.1 20120801 for 0000:04:00.0 on minor 0
[ gm] [ 12.598188] count_fbs 0.
[ gm] [ 12.598297] count_crtcs 2.
[ gm] [ 12.598375] count_connectors 3.
[ gm] [ 12.598450] count_encoders 4.
[ gm] [ 12.598522] min_width 0, max_width 8192, min_height 0, max_height 8192.
[ gm] [ 12.627806] ======================
[ gm] [ 12.627905] connector_id 61.
[ gm] [ 12.627979] encoder_id 0.
[ gm] [ 12.628050] connector_type DVII (2).
[ gm] [ 12.628122] connector_type_id 1.
[ gm] [ 12.628195] connection 1.
[ gm] [ 12.628266] mm_width 380, mm_height 300.
[ gm] [ 12.628336] subpixel 0.
[ gm] [ 12.628406] count_modes 17.
[ gm] [ 12.628476] count_props 14.
[ gm] [ 12.628546] count_encoders 2.
[ gm] [ 12.628615] encoders_ptr [62]
[ gm] [ 12.628685] encoders_ptr [63]
[ gm] [ 12.628755] ======================
[ gm] [ 12.630853] ======================
[ gm] [ 12.630946] connector_id 64.
[ gm] [ 12.631022] encoder_id 0.
[ gm] [ 12.631095] connector_type HDMIA (11).
[ gm] [ 12.631165] connector_type_id 1.
[ gm] [ 12.631235] connection 2.
[ gm] [ 12.631306] mm_width 0, mm_height 0.
[ gm] [ 12.631376] subpixel 0.
[ gm] [ 12.631446] count_modes 0.
[ gm] [ 12.631515] count_props 13.
[ gm] [ 12.631586] count_encoders 1.
[ gm] [ 12.631655] encoders_ptr [65]
[ gm] [ 12.631724] ======================
[ gm] [ 12.660004] ======================
[ gm] [ 12.660102] connector_id 66.
[ gm] [ 12.660176] encoder_id 0.
[ gm] [ 12.660248] connector_type VGA (1).
[ gm] [ 12.660322] connector_type_id 1.
[ gm] [ 12.660405] connection 1.
[ gm] [ 12.660479] mm_width 340, mm_height 270.
[ gm] [ 12.660549] subpixel 0.
[ gm] [ 12.660619] count_modes 17.
[ gm] [ 12.660688] count_props 8.
[ gm] [ 12.660758] count_encoders 1.
[ gm] [ 12.660828] encoders_ptr [67]
[ gm] [ 12.660897] ======================
[ gm] [ 12.660981] ======================
[ gm] [ 12.661056] crtc_id 50.
[ gm] [ 12.661128] fb buffer_id 0 (disconnected from fb).
[ gm] [ 12.661197] x 0, y 0.
[ gm] [ 12.661267] mode_valid 0.
[ gm] [ 12.661342] Mode : clock 0 H 0 0 0 0 0 V 0 0 0 0 0 VR 0 flags 0x0000 type 0x0000.
[ gm] [ 12.661416] gamma_size 256.
[ gm] [ 12.661486] 0 connectors.
[ gm] [ 12.661555] ======================
[ gm] [ 12.661690] ======================
[ gm] [ 12.661777] crtc_id 60.
[ gm] [ 12.661849] fb buffer_id 0 (disconnected from fb).
[ gm] [ 12.661921] x 0, y 0.
[ gm] [ 12.661991] mode_valid 0.
[ gm] [ 12.662064] Mode : clock 0 H 0 0 0 0 0 V 0 0 0 0 0 VR 0 flags 0x0000 type 0x0000.
[ gm] [ 12.662134] gamma_size 256.
[ gm] [ 12.662205] 0 connectors.
[ gm] [ 12.662273] ======================
[ gm] [ 12.662356] ======================
[ gm] [ 12.662431] encoder_id 62.
[ gm] [ 12.662501] encoder_type TMDS (2).
[ gm] [ 12.662573] crtc_id 0.
[ gm] [ 12.662643] possible_crtcs 3.
[ gm] [ 12.662713] possible_clones 1.
[ gm] [ 12.662782] ======================
[ gm] [ 12.662861] ======================
[ gm] [ 12.662934] encoder_id 63.
[ gm] [ 12.663004] encoder_type DAC (1).
[ gm] [ 12.663073] crtc_id 0.
[ gm] [ 12.663144] possible_crtcs 3.
[ gm] [ 12.663214] possible_clones 2.
[ gm] [ 12.663283] ======================
[ gm] [ 12.663362] ======================
[ gm] [ 12.663436] encoder_id 65.
[ gm] [ 12.663551] encoder_type TMDS (2).
[ gm] [ 12.663600] crtc_id 0.
[ gm] [ 12.663635] possible_crtcs 3.
[ gm] [ 12.663669] possible_clones 4.
[ gm] [ 12.663704] ======================
[ gm] [ 12.663737] ======================
[ gm] [ 12.663772] encoder_id 67.
[ gm] [ 12.663807] encoder_type DAC (1).
[ gm] [ 12.663842] crtc_id 0.
[ gm] [ 12.663876] possible_crtcs 3.
[ gm] [ 12.663910] possible_clones 8.
[ gm] [ 12.663947] ======================
/--- FILE "/proc/mtrr" -----------------------
| reg00: base=0x000000000 ( 0MB), size= 512MB, count=1: write-back
[ gm] [ 12.665955] Connector Id 61.
[ gm] [ 12.693500] Encoder Id 62.
[ gm] [ 12.693618] M2 Connector Id 66.
[ gm] [ 12.722023] M2 Encoder Id 67.
[ gm] [ 12.722130] CRTC Id 50.
[ gm] [ 12.722217] M2 CRTC Id 60.
[ gm] [ 12.722293] Force 60Hz refresh.
[ gm] [ 12.722372] Mode 1280x1024: clock 108000 H 1280 1328 1440 1688 0 V 1024 1025 1028 1066 0 VR 60 flags 0x0005 type 0x0048.
[ gm] [ 12.722447] Mode 1280x1024: clock 135000 H 1280 1296 1440 1688 0 V 1024 1025 1028 1066 0 VR 75 flags 0x0005 type 0x0040.
[ gm] [ 12.722523] Mode 1280x960: clock 108000 H 1280 1376 1488 1800 0 V 960 961 964 1000 0 VR 60 flags 0x0005 type 0x0040.
[ gm] [ 12.722598] Mode 1152x864: clock 108000 H 1152 1216 1344 1600 0 V 864 865 868 900 0 VR 75 flags 0x0005 type 0x0040.
[ gm] [ 12.722673] Mode 1024x768: clock 78750 H 1024 1040 1136 1312 0 V 768 769 772 800 0 VR 75 flags 0x0005 type 0x0040.
[ gm] [ 12.722748] Mode 1024x768: clock 75000 H 1024 1048 1184 1328 0 V 768 771 777 806 0 VR 70 flags 0x000a type 0x0040.
[ gm] [ 12.722835] Mode 1024x768: clock 65000 H 1024 1048 1184 1344 0 V 768 771 777 806 0 VR 60 flags 0x000a type 0x0040.
[ gm] [ 12.722909] ^^^ Use this mode ^^^.
[ gm] [ 12.722987] Mode 832x624: clock 57284 H 832 864 928 1152 0 V 624 625 628 667 0 VR 75 flags 0x000a type 0x0040.
[ gm] [ 12.723062] Mode 800x600: clock 49500 H 800 816 896 1056 0 V 600 601 604 625 0 VR 75 flags 0x0005 type 0x0040.
[ gm] [ 12.723138] Mode 800x600: clock 50000 H 800 856 976 1040 0 V 600 637 643 666 0 VR 72 flags 0x0005 type 0x0040.
[ gm] [ 12.723214] Mode 800x600: clock 40000 H 800 840 968 1056 0 V 600 601 605 628 0 VR 60 flags 0x0005 type 0x0040.
[ gm] [ 12.723290] Mode 800x600: clock 36000 H 800 824 896 1024 0 V 600 601 603 625 0 VR 56 flags 0x0005 type 0x0040.
[ gm] [ 12.723364] Mode 640x480: clock 31500 H 640 656 720 840 0 V 480 481 484 500 0 VR 75 flags 0x000a type 0x0040.
[ gm] [ 12.723440] Mode 640x480: clock 31500 H 640 664 704 832 0 V 480 489 492 520 0 VR 73 flags 0x000a type 0x0040.
[ gm] [ 12.723515] Mode 640x480: clock 30240 H 640 704 768 864 0 V 480 483 486 525 0 VR 67 flags 0x000a type 0x0040.
[ gm] [ 12.723592] Mode 640x480: clock 25175 H 640 656 752 800 0 V 480 490 492 525 0 VR 60 flags 0x000a type 0x0040.
[ gm] [ 12.723667] Mode 720x400: clock 28320 H 720 738 846 900 0 V 400 412 414 449 0 VR 70 flags 0x0006 type 0x0040.
[ gm] [ 12.723740] Once more, choose this mode:
[ gm] [ 12.723818] Mode 1024x768: clock 65000 H 1024 1048 1184 1344 0 V 768 771 777 806 0 VR 60 flags 0x000a type 0x0040.
[ gm] [ 12.724067] fb_ptr 0xb7710000
[ gm] [ 12.724163] stride 2048.
[ gm] [ 12.724238] size 1572864.
[ gm] [ 12.724312] handle 0x00000001.
[ gm] [ 12.725555] ======================
[ gm] [ 12.725683] fb_id 0.
[ gm] [ 12.725764] width 1024.
[ gm] [ 12.725836] height 768.
[ gm] [ 12.725907] pitch 2048.
[ gm] [ 12.725978] bpp 16.
[ gm] [ 12.726051] depth 16.
[ gm] [ 12.726124] handle 0x00000001.
[ gm] [ 12.726195] ======================
[ gm] [ 12.726308] DRM ioctl failed with -1, errno 22.
[ gm] [ 12.726400] graphdriver_f_drm.cpp ( 877): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 12.726480] graphdriver_f_drm.cpp ( 938): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 12.726564] graphdriver_f.cpp ( 605): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 12.726641] graphconsole.cpp ( 669): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 12.726719] graphconsole.cpp ( 713): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ pfac] [ 13.029933] Process pid 253 terminated, status 00000000.
[ pfac] [ 13.030002] [ERROR] UDSD_send failed: sendto() return -1 instead of 5, errno 111.
[ pfac] [ 13.030043] hotplug.h ( 64): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
Re: В версии 6.2.2 проблема с драйверами nvidia
Не вижу, что мы делаем неправильно. Походу ядерщики сломали драйвер. Варианты - попробовать video=nouveau(U) или video=modesetting(U), или оставаться на той версии, которая работала...
Taniriel
aka писал(а): Чт июн 01, 2023 4:40 pm Не вижу, что мы делаем неправильно. Походу ядерщики сломали драйвер. Варианты - попробовать video=nouveau(U) или video=modesetting(U), или оставаться на той версии, которая работала...
Пробовал. Те-же симптомы.
Пока остаюсь на старой версии.
