Иногда происходит самопроизвольное отключение от сервера.
вот кусок лога
17-56-26-767| [gm] modprobe fuse.
17-56-26-767| [gm] modprobe exfat.
17-56-26-767| [KERNEL] [ 32.762219] fuse init (API version 7.23)
17-56-26-767| [gm] /graphic/ppllg.png: 32x38.
17-56-26-767| [KERNEL] [ 32.764040] exFAT: Version 1.2.9
17-56-26-767| [gm] /graphic/pplsm.png: 27x30.
17-56-26-767| [gm] /graphic/offsm.png: 28x31.
17-56-26-767| [gm] Everyone can control terminal by VNC.
17-56-26-767| [gm] VNC listener at port 5900.
17-56-26-767| [gm] Add keyboard event6: Video Bus.
17-56-26-767| [rdpaudin] snd_ctl_open return -2, 'No such file or directory'.
17-56-26-767| [rdpsnd] snd_ctl_open return -2, 'No such file or directory'.
17-56-26-767| [pfac] Process pid 739 terminated, status 00000000.
17-56-26-767| [rdpaudin] Caught signal SIGSEGV.
17-56-26-767| [pfac] Process pid 738 terminated, status 00000000.
17-56-26-767| [rdpsnd] Caught signal SIGSEGV.
17-56-26-767| [pfac] Got command line /sbin/resolver 0x8233278 dns [192.168.16.28].
17-56-26-767| [pfac] Ok, PID 860.
17-56-26-767| [gm] 192.168.16.28 => 192.168.16.28.
17-56-26-767| [gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 861780 Kb.
17-56-26-767| [pfac] Got command line /sbin/rdpclient 1.
17-56-26-767| [pfac] Ok, PID 861.
17-56-26-767| [pfac] Process pid 860 terminated, status 00000000.
17-56-26-767| [rdpclient 861] RDP Terminal Client, WTware v.5.3.2, pipe 1, pid 861.
17-56-26-767| [rdpclient 861] Add smartcard redirection.
17-56-26-767| [rdpdr-scard] New client connection, id 1.
17-56-26-767| [rdpclient 861] Redirect sound.
17-56-26-767| [rdpclient 861] rdpclient-rdpsnd.cpp ( 576): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 861] rdpclient-vchans.cpp ( 52): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 861] Make RDP session with 192.168.16.28, port 3389.
17-56-26-767| [rdpclient 861] Username: "chernomordin.ka".
17-56-26-767| [rdpclient 861] No password.
17-56-26-767| [rdpclient 861] No PIN.
17-56-26-767| [rdpclient 861] Domain: "tech".
17-56-26-767| [rdpclient 861] No shell.
17-56-26-767| [rdpclient 861] No directory.
17-56-26-767| [rdpclient 861] Window: 1792x1080@16.
17-56-26-767| [rdpclient 861] PFlags 0x000000AE.
17-56-26-767| [rdpclient 861] Keyboard 00000409:00000000.
17-56-26-767| [rdpclient 861] My hostname "wtwBCAEC57116B0".
17-56-26-767| [rdpclient 861] TCP: connecting to 192.168.16.28:3389.
17-56-26-767| [rdpclient 861] TCP: connection with 192.168.16.28:3389 established.
17-56-26-767| [rdpclient 861] Turn keepalive on.
17-56-26-767| [rdpclient 861] fstream.cpp ( 1020): Set TCP_USER_TIMEOUT 25000 miliseconds.
17-56-26-767| [rdpclient 861] Free ram after buffers allocation: 858600 KB.
17-56-26-767| [rdpclient 861] Process RDP server certificate.
17-56-26-767| [rdpclient 861] RDP5 encryption (X.509).
17-56-26-767| [rdpclient 861] Timezone "(UTC+03:00) Moscow, St. Petersburg, Volgograd".
17-56-26-767| [rdpdr-scard] Reset client 1.
17-56-26-767| [rdpclient 861] SessionId 0x00000008: TECH\chernomordin.ka.
17-56-26-767| [rdpclient 861] ERRINFO_RPC_INITIATED_DISCONNECT_BYUSER
17-56-26-767| [rdpclient 861] Receive Disconnect Provider Ultimatum.
17-56-26-767| [gm] TSClient gracefully end.
17-56-26-767| [rdpclient 861] Caught signal SIGTERM.
17-56-26-767| [rdpdr-scard] Close client connection 0 (id 1).
17-56-26-767| [pfac] Process pid 861 terminated, status 00000000.
17-56-26-767| [pfac] Ok, PID 862.
17-56-26-767| [gm] Free ram before fork terminal client /sbin/rdpclient (session 2): 861812 Kb.
17-56-26-767| [pfac] Got command line /sbin/rdpclient 2.
17-56-26-767| [pfac] Ok, PID 863.
17-56-26-767| [pfac] Process pid 862 terminated, status 00000000.
17-56-26-767| [rdpclient 863] RDP Terminal Client, WTware v.5.3.2, pipe 2, pid 863.
17-56-26-767| [rdpclient 863] Add smartcard redirection.
17-56-26-767| [rdpdr-scard] New client connection, id 2.
17-56-26-767| [rdpclient 863] Redirect sound.
17-56-26-767| [rdpclient 863] rdpclient-rdpsnd.cpp ( 576): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 863] rdpclient-vchans.cpp ( 52): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 863] Make RDP session with 192.168.16.28, port 3389.
17-56-26-767| [rdpclient 863] Username: "Администратор".
17-56-26-767| [rdpclient 863] No password.
17-56-26-767| [rdpclient 863] No PIN.
17-56-26-767| [rdpclient 863] Domain: "tech".
17-56-26-767| [rdpclient 863] No shell.
17-56-26-767| [rdpclient 863] No directory.
17-56-26-767| [rdpclient 863] Window: 1792x1080@16.
17-56-26-767| [rdpclient 863] PFlags 0x000000AE.
17-56-26-767| [rdpclient 863] Keyboard 00000409:00000000.
17-56-26-767| [rdpclient 863] My hostname "wtwBCAEC57116B0".
17-56-26-767| [rdpclient 863] TCP: connecting to 192.168.16.28:3389.
17-56-26-767| [rdpclient 863] TCP: connection with 192.168.16.28:3389 established.
17-56-26-767| [rdpclient 863] Turn keepalive on.
17-56-26-767| [rdpclient 863] fstream.cpp ( 1020): Set TCP_USER_TIMEOUT 25000 miliseconds.
17-56-26-767| [rdpclient 863] Free ram after buffers allocation: 858648 KB.
17-56-26-767| [rdpclient 863] Process RDP server certificate.
17-56-26-767| [rdpclient 863] RDP5 encryption (X.509).
17-56-26-767| [rdpclient 863] Timezone "(UTC+03:00) Moscow, St. Petersburg, Volgograd".
17-56-26-767| [rdpdr-scard] Reset client 2.
17-56-26-767| [rdpdr-scard] Contexts left: 3, cards left: 0.
17-56-26-767| [rdpclient 863] SessionId 0x00000006: TECH\Администратор.
17-56-26-767| [rdpdr-scard] Contexts left: 2, cards left: 0.
17-56-26-767| [rdpclient 863] Sound redirection: 44100 frames per second.
17-56-26-767| [rdpclient 863] rdpclient-rdpsnd.cpp ( 424): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 863] Caught signal SIGSEGV.
17-56-26-767| [rdpdr-scard] Close client connection 0 (id 2).
17-56-26-767| [gm] ./fstream.h ( 240): -- ERROR -- Not enough data in stream in TSClientSession.cpp line 203.
17-56-26-767| [gm] ./fstream.h ( 242): -- ERROR -- Not enough data in stream in ./fstream.h line 260.
17-56-26-767| [pfac] Process pid 863 terminated, status 00000000.
17-56-26-767| [pfac] Ok, PID 864.
17-56-26-767| [gm] Free ram before fork terminal client /sbin/rdpclient (session 3): 861812 Kb.
17-56-26-767| [pfac] Got command line /sbin/rdpclient 3.
17-56-26-767| [pfac] Ok, PID 865.
17-56-26-767| [pfac] Process pid 864 terminated, status 00000000.
17-56-26-767| [rdpclient 865] RDP Terminal Client, WTware v.5.3.2, pipe 3, pid 865.
17-56-26-767| [rdpclient 865] Add smartcard redirection.
17-56-26-767| [rdpdr-scard] New client connection, id 3.
17-56-26-767| [rdpclient 865] Redirect sound.
17-56-26-767| [rdpclient 865] rdpclient-rdpsnd.cpp ( 576): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 865] rdpclient-vchans.cpp ( 52): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 865] Make RDP session with 192.168.16.28, port 3389.
17-56-26-767| [rdpclient 865] Username: "Администратор".
17-56-26-767| [rdpclient 865] No password.
17-56-26-767| [rdpclient 865] No PIN.
17-56-26-767| [rdpclient 865] Domain: "tech".
17-56-26-767| [rdpclient 865] No shell.
17-56-26-767| [rdpclient 865] No directory.
17-56-26-767| [rdpclient 865] Window: 1792x1080@16.
17-56-26-767| [rdpclient 865] PFlags 0x000000AE.
17-56-26-767| [rdpclient 865] Keyboard 00000409:00000000.
17-56-26-767| [rdpclient 865] My hostname "wtwBCAEC57116B0".
17-56-26-767| [rdpclient 865] TCP: connecting to 192.168.16.28:3389.
17-56-26-767| [rdpclient 865] TCP: connection with 192.168.16.28:3389 established.
17-56-26-767| [rdpclient 865] Turn keepalive on.
17-56-26-767| [rdpclient 865] fstream.cpp ( 1020): Set TCP_USER_TIMEOUT 25000 miliseconds.
17-56-26-767| [rdpclient 865] Free ram after buffers allocation: 858632 KB.
17-56-26-767| [rdpclient 865] Process RDP server certificate.
17-56-26-767| [rdpclient 865] RDP5 encryption (X.509).
17-56-26-767| [rdpclient 865] Timezone "(UTC+03:00) Moscow, St. Petersburg, Volgograd".
17-56-26-767| [rdpdr-scard] Reset client 3.
17-56-26-767| [rdpclient 865] SessionId 0x00000006: TECH\Администратор.
17-56-26-767| [rdpclient 865] Sound redirection: 44100 frames per second.
17-56-26-767| [rdpclient 865] rdpclient-rdpsnd.cpp ( 424): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 865] Caught signal SIGSEGV.
17-56-26-767| [rdpdr-scard] Close client connection 0 (id 3).
17-56-26-767| [rdpdr-scard] Contexts left: 1, cards left: 0.
17-56-26-767| [pfac] Process pid 865 terminated, status 00000000.
17-56-26-767| [pfac] Ok, PID 866.
17-56-26-767| [gm] Free ram before fork terminal client /sbin/rdpclient (session 4): 861812 Kb.
17-56-26-767| [pfac] Got command line /sbin/rdpclient 4.
17-56-26-767| [pfac] Ok, PID 867.
17-56-26-767| [pfac] Process pid 866 terminated, status 00000000.
17-56-26-767| [rdpclient 867] RDP Terminal Client, WTware v.5.3.2, pipe 4, pid 867.
17-56-26-767| [rdpclient 867] Add smartcard redirection.
17-56-26-767| [rdpdr-scard] New client connection, id 4.
17-56-26-767| [rdpclient 867] Redirect sound.
17-56-26-767| [rdpclient 867] rdpclient-rdpsnd.cpp ( 576): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 867] rdpclient-vchans.cpp ( 52): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 867] Make RDP session with 192.168.16.28, port 3389.
17-56-26-767| [rdpclient 867] Username: "Администратор".
17-56-26-767| [rdpclient 867] No password.
17-56-26-767| [rdpclient 867] No PIN.
17-56-26-767| [rdpclient 867] Domain: "tech".
17-56-26-767| [rdpclient 867] No shell.
17-56-26-767| [rdpclient 867] No directory.
17-56-26-767| [rdpclient 867] Window: 1792x1080@16.
17-56-26-767| [rdpclient 867] PFlags 0x000000AE.
17-56-26-767| [rdpclient 867] Keyboard 00000409:00000000.
17-56-26-767| [rdpclient 867] My hostname "wtwBCAEC57116B0".
17-56-26-767| [rdpclient 867] TCP: connecting to 192.168.16.28:3389.
17-56-26-767| [rdpclient 867] TCP: connection with 192.168.16.28:3389 established.
17-56-26-767| [rdpclient 867] Turn keepalive on.
17-56-26-767| [rdpclient 867] fstream.cpp ( 1020): Set TCP_USER_TIMEOUT 25000 miliseconds.
17-56-26-767| [rdpclient 867] Free ram after buffers allocation: 858532 KB.
17-56-26-767| [rdpclient 867] Process RDP server certificate.
17-56-26-767| [rdpclient 867] RDP5 encryption (X.509).
17-56-26-767| [rdpclient 867] Timezone "(UTC+03:00) Moscow, St. Petersburg, Volgograd".
17-56-26-767| [rdpdr-scard] Reset client 4.
17-56-26-767| [rdpdr-scard] Contexts left: 4, cards left: 0.
17-56-26-767| [rdpclient 867] SessionId 0x00000006: TECH\Администратор.
17-56-26-767| [rdpclient 867] Sound redirection: 44100 frames per second.
17-56-26-767| [rdpclient 867] rdpclient-rdpsnd.cpp ( 424): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 867] Caught signal SIGSEGV.
17-56-26-767| [rdpdr-scard] Close client connection 0 (id 4).
17-56-26-767| [pfac] Process pid 867 terminated, status 00000000.
17-56-26-767| [pfac] Ok, PID 868.
17-56-26-767| [gm] Free ram before fork terminal client /sbin/rdpclient (session 5): 861812 Kb.
17-56-26-767| [pfac] Got command line /sbin/rdpclient 5.
17-56-26-767| [pfac] Ok, PID 869.
17-56-26-767| [pfac] Process pid 868 terminated, status 00000000.
17-56-26-767| [rdpclient 869] RDP Terminal Client, WTware v.5.3.2, pipe 5, pid 869.
17-56-26-767| [rdpclient 869] Add smartcard redirection.
17-56-26-767| [rdpdr-scard] New client connection, id 5.
17-56-26-767| [rdpclient 869] Redirect sound.
17-56-26-767| [rdpclient 869] rdpclient-rdpsnd.cpp ( 576): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 869] rdpclient-vchans.cpp ( 52): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 869] Make RDP session with 192.168.16.28, port 3389.
17-56-26-767| [rdpclient 869] Username: "Администратор".
17-56-26-767| [rdpclient 869] No password.
17-56-26-767| [rdpclient 869] No PIN.
17-56-26-767| [rdpclient 869] Domain: "tech".
17-56-26-767| [rdpclient 869] No shell.
17-56-26-767| [rdpclient 869] No directory.
17-56-26-767| [rdpclient 869] Window: 1792x1080@16.
17-56-26-767| [rdpclient 869] PFlags 0x000000AE.
17-56-26-767| [rdpclient 869] Keyboard 00000409:00000000.
17-56-26-767| [rdpclient 869] My hostname "wtwBCAEC57116B0".
17-56-26-767| [rdpclient 869] TCP: connecting to 192.168.16.28:3389.
17-56-26-767| [rdpclient 869] TCP: connection with 192.168.16.28:3389 established.
17-56-26-767| [rdpclient 869] Turn keepalive on.
17-56-26-767| [rdpclient 869] fstream.cpp ( 1020): Set TCP_USER_TIMEOUT 25000 miliseconds.
17-56-26-767| [rdpclient 869] Free ram after buffers allocation: 858648 KB.
17-56-26-767| [rdpclient 869] Process RDP server certificate.
17-56-26-767| [rdpclient 869] RDP5 encryption (X.509).
17-56-26-767| [rdpclient 869] Timezone "(UTC+03:00) Moscow, St. Petersburg, Volgograd".
17-56-26-767| [rdpdr-scard] Reset client 5.
17-56-26-767| [rdpclient 869] SessionId 0x00000006: TECH\Администратор.
17-56-26-790| Connection from wtc.exe at 192.168.16.2.
Отключение от терминального сервера.
Re: Отключение от терминального сервера.
Это из-за звука, которого нет. Падает когда пытается воспроизвести звук. Убери из конфига sound=
Постоянные отключения от сервера терминалов. То ошибка "I'm tyred!", то "TCP\IP connection lost. Network failure?" Лог прилагаю.
- LOG.txt
- (19.17 КБ) 1259 скачиваний
1. Свежая версия называется 5.3.10. Надо её скачать, поставить и сделать так, чтобы она загружалась.
2. Лог - это такая большая штука из целой кучи строк. Его надо выкладывать целиком, не обрывать.
