USB flash не пробрасывается
VladmirK
Сообщение VladmirK » Пн июл 25, 2016 6:24 pm
доброго времени суток, после сбоев с электричеством на двух тонких клиентах перестали работать флешки.
на виндовых компьютерах они работают нормально, проверка диска ничего не показывает.
Win2012 устройство видит, но определяет его как белый листик без буквы . в лог пишет следующее:
17-09-14-012| [hpsc] Success: USB2p1 mounted VFAT r/w.
17-09-14-012| [KERNEL] [ 149.313123] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
17-09-14-012| [rdpclient 633] Announce new disk named USB1 at /mnt/usb-rdp/6, r/w.
17-09-14-012| [KERNEL] [ 531.127628] usb 1-8: USB disconnect, device number 5
17-09-14-012| [hpsc] /dev/sdb1 unmounted from /mnt/usb-rdp/6.
17-09-14-012| [hpsc] USBIP: remove 1-8.
17-09-14-013| Connection from wtc.exe at 172.16.48.251.
17-09-20-303| [KERNEL] [ 550.874693] usb 1-3: new high-speed USB device number 6 using ehci-pci
17-09-20-506| [KERNEL] [ 550.990469] usb 1-3: New USB device found, idVendor=8564, idProduct=1000
17-09-20-506| [KERNEL] [ 550.990475] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
17-09-20-506| [KERNEL] [ 550.990479] usb 1-3: Product: Mass Storage Device
17-09-20-506| [KERNEL] [ 550.990481] usb 1-3: Manufacturer: JetFlash
17-09-20-506| [KERNEL] [ 550.990484] usb 1-3: SerialNumber: 58PE31TD1MBQ3B05
17-09-20-506| [KERNEL] [ 550.992047] usb-storage 1-3:1.0: USB Mass Storage device detected
17-09-20-506| [hpsc] +--- Executing "/sbin/usbip unbind -b 1-3"
17-09-20-522| [hpsc] +- Errorlevel: 1, output:
17-09-20-522| | usbip: error: usbip-host is not in use by any devices
17-09-20-522| [hpsc] +------------------------
17-09-20-522| [KERNEL] [ 550.995263] scsi6 : usb-storage 1-3:1.0
17-09-21-723| [KERNEL] [ 552.295748] scsi 6:0:0:0: Direct-Access JetFlash Transcend 32GB 1100 PQ: 0 ANSI: 4
17-09-21-738| [KERNEL] [ 552.299001] sd 6:0:0:0: [sdb] 63406080 512-byte logical blocks: (32.4 GB/30.2 GiB)
17-09-21-738| [KERNEL] [ 552.299751] sd 6:0:0:0: [sdb] Write Protect is off
17-09-21-738| [KERNEL] [ 552.299758] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00
17-09-21-754| [KERNEL] [ 552.300503] sd 6:0:0:0: [sdb] No Caching mode page found
17-09-21-754| [KERNEL] [ 552.300509] sd 6:0:0:0: [sdb] Assuming drive cache: write through
17-09-21-754| [KERNEL] [ 552.304601] sd 6:0:0:0: [sdb] No Caching mode page found
17-09-21-754| [KERNEL] [ 552.304608] sd 6:0:0:0: [sdb] Assuming drive cache: write through
17-09-21-754| [KERNEL] [ 552.305491] sdb: sdb1
17-09-21-754| [hpsc] Filesystem signature not found at /dev/sdb.
17-09-21-754| [hpsc] 00000000:33c08ed0bc007cfb5007501ffcbe1b7cbf1b065057b9e501f3a4cbbdbe07b104 3.....|.P.P..|..PW...........
17-09-21-754| [hpsc] 00000020:386e007c09751383c510e2f4cd188bf583c610497419382c74f6a0b507b4078b 8n.|.u.........It8,t.......
17-09-21-754| [hpsc] 00000040:f0ac3c0074fcbb0700b40ecd10ebf2884e10e84600732afe4610807e040b740b ..<.t..........N.F.s*.F.~..t.
17-09-21-754| [hpsc] 00000060:807e040c7405a0b60775d2804602068346080683560a00e821007305a0b607eb .~..t....u..F...F...V...!.s.....
17-09-21-754| [KERNEL] [ 552.311854] sd 6:0:0:0: [sdb] No Caching mode page found
17-09-21-754| [KERNEL] [ 552.311861] sd 6:0:0:0: [sdb] Assuming drive cache: write through
17-09-21-770| [KERNEL] [ 552.311867] sd 6:0:0:0: [sdb] Attached SCSI removable disk
17-09-21-770| [hpsc] Success: USB2p1 mounted VFAT r/w.
17-09-21-770| [KERNEL] [ 552.315629] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
17-09-21-770| [rdpclient 633] Announce new disk named USB1 at /mnt/usb-rdp/6, r/w.
Re: USB flash не пробрасывается
Сообщение aka » Пн июл 25, 2016 7:27 pm
Параметр shared_usb удали. Для проброса флешек достаточно одной строки disk=usb, никакие другие строки для проброса флешек ен нужны.
Если не поможет, покажи лог целиком. Перезагрузи терминал, залогинься, подключи флешку, открой в проводнике адрес \\tsclient Если там флешки не будет, сохрани и выложи лог целиком.
