Загрузка по сети и VLAN
Ярослав
Сообщение Ярослав »
Столкнулся со странной проблемой, есть необходимость разделить сеть на VLAN, сделан тестовый сегмент, трафик ходит и устройства видят сервер, но в нем не идет загрузка по сети.
Лог загрузки:
11-23-00-345| [192.168.104.11] RRQ 32 bytes:
11-23-00-345| [192.168.104.11] 00000000: 35 2e 38 2e 34 36 5c 77 74 77 61 72 65 2e 70 78
11-23-00-361| [192.168.104.11] 00000010: 65 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00
11-23-00-361| [192.168.104.11] "5.8.46\wtware.pxe": tsize is requested, blksize default.
11-23-00-376| [192.168.104.11] "5.8.46\wtware.pxe": "C:\Program Files (x86)\WTware\TFTPDROOT\5.8.46\wtware.pxe".
11-23-00-392| [192.168.104.11] RRQ 37 bytes:
11-23-00-407| [192.168.104.11] 00000000: 35 2e 38 2e 34 36 5c 77 74 77 61 72 65 2e 70 78
11-23-00-423| [192.168.104.11] 00000010: 65 00 6f 63 74 65 74 00 62 6c 6b 73 69 7a 65 00
11-23-00-423| [192.168.104.11] 00000020: 31 34 35 36 00
11-23-00-438| [192.168.104.11] Request block size 1456, forced to 1360.
11-23-00-438| [192.168.104.11] "5.8.46\wtware.pxe": tsize is not requested, blksize 1360 bytes.
11-23-00-454| [192.168.104.11] "5.8.46\wtware.pxe": "C:\Program Files (x86)\WTware\TFTPDROOT\5.8.46\wtware.pxe".
11-23-02-348| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-02-348| [192.168.104.11] Resend block 0.
11-23-02-363| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-02-379| [192.168.104.11] Resend block 0.
11-23-04-355| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-04-355| [192.168.104.11] Resend block 0.
11-23-04-371| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-04-386| [192.168.104.11] Resend block 0.
11-23-06-369| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-06-369| [192.168.104.11] Resend block 0.
11-23-06-385| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-06-400| [192.168.104.11] Resend block 0.
11-23-08-375| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-08-383| [192.168.104.11] Resend block 0.
11-23-08-383| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-08-399| [192.168.104.11] Resend block 0.
11-23-10-376| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-10-376| [192.168.104.11] Resend block 0.
11-23-10-392| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-10-392| [192.168.104.11] Resend block 0.
11-23-12-387| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-12-387| [192.168.104.11] Resend block 0.
11-23-12-403| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-12-419| [192.168.104.11] Resend block 0.
11-23-14-390| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-14-390| [192.168.104.11] Resend block 0.
11-23-14-406| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-14-422| [192.168.104.11] Resend block 0.
11-23-16-393| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-16-393| [192.168.104.11] Resend block 0.
11-23-16-409| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-16-409| [192.168.104.11] Resend block 0.
11-23-18-397| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-18-397| [192.168.104.11] Resend block 0.
11-23-18-412| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-18-412| [192.168.104.11] Resend block 0.
11-23-20-404| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-20-404| [192.168.104.11] Client not responding. Connection closed.
11-23-20-420| [192.168.104.11] Timeout occured while transfer "5.8.46\wtware.pxe".
11-23-20-420| [192.168.104.11] Client not responding. Connection closed.
11-23-36-345| [192.168.104.11] Received ASK, sending ERROR "Illegal TFTP operation".
11-23-36-345| [192.168.104.11] Sending ERR 4, message "Illegal TFTP operation.".
Тот же сервер, другая подсеть загрузка идет корректно (просто поднят интерфейс на порту, без VLAN)
15-33-19-775| [192.168.0.250] RRQ 32 bytes:
15-33-19-791| [192.168.0.250] 00000000: 35 2e 38 2e 34 36 2f 77 74 77 61 72 65 2e 70 78
15-33-19-791| [192.168.0.250] 00000010: 65 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00
15-33-19-791| [192.168.0.250] "5.8.46\wtware.pxe": tsize is requested, blksize default.
15-33-19-806| [192.168.0.250] "5.8.46\wtware.pxe": "C:\Program Files (x86)\WTware\TFTPDROOT\5.8.46\wtware.pxe".
15-33-19-806| [192.168.0.250] Received opcode ERR.
15-33-19-822| [192.168.0.250] RRQ 37 bytes:
15-33-19-822| [192.168.0.250] 00000000: 35 2e 38 2e 34 36 2f 77 74 77 61 72 65 2e 70 78
15-33-19-837| [192.168.0.250] 00000010: 65 00 6f 63 74 65 74 00 62 6c 6b 73 69 7a 65 00
15-33-19-837| [192.168.0.250] 00000020: 31 34 35 36 00
15-33-19-837| [192.168.0.250] Request block size 1456, interface MTU 1500.
15-33-19-837| [192.168.0.250] "5.8.46\wtware.pxe": tsize is not requested, blksize 1456 bytes.
15-33-19-837| [192.168.0.250] "5.8.46\wtware.pxe": "C:\Program Files (x86)\WTware\TFTPDROOT\5.8.46\wtware.pxe".
15-33-19-884| [192.168.0.250] "5.8.46\wtware.pxe": completed.
15-33-19-915| [192.168.0.250] RRQ 71 bytes:
15-33-19-915| [192.168.0.250] 00000000: 35 2e 38 2e 34 36 2f 30 30 30 32 30 30 30 33 2d
15-33-19-932| [192.168.0.250] 00000010: 30 30 30 34 2d 30 30 30 35 2d 30 30 30 36 2d 30
15-33-19-932| [192.168.0.250] 00000020: 30 30 37 30 30 30 38 30 30 30 39 00 6f 63 74 65
15-33-19-932| [192.168.0.250] 00000030: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
15-33-19-946| [192.168.0.250] 00000040: 65 00 31 34 30 38 00
15-33-19-946| [192.168.0.250] Request block size 1408, interface MTU 1500.
15-33-19-946| [192.168.0.250] "5.8.46\00020003-0004-0005-0006-000700080009": tsize is requested, blksize 1408 bytes.
15-33-19-946| [192.168.0.250] "5.8.46\00020003-0004-0005-0006-000700080009": file not found: "C:\Program Files (x86)\WTware\TFTPDROOT\5.8.46\00020003-0004-0005-0006-000700080009".
15-33-19-962| [192.168.0.250] RRQ 55 bytes:
15-33-19-978| [192.168.0.250] 00000000: 35 2e 38 2e 34 36 2f 30 31 2d 62 63 2d 35 66 2d
15-33-19-978| [192.168.0.250] 00000010: 66 34 2d 65 61 2d 37 63 2d 30 36 00 6f 63 74 65
15-33-19-978| [192.168.0.250] 00000020: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
15-33-19-993| [192.168.0.250] 00000030: 65 00 31 34 30 38 00
15-33-19-993| [192.168.0.250] Request block size 1408, interface MTU 1500.
15-33-19-993| [192.168.0.250] "5.8.46\01-bc-5f-f4-ea-7c-06": tsize is requested, blksize 1408 bytes.
15-33-19-993| [192.168.0.250] "5.8.46\01-bc-5f-f4-ea-7c-06": file not found: "C:\Program Files (x86)\WTware\TFTPDROOT\5.8.46\01-bc-5f-f4-ea-7c-06".
15-33-20-009| [192.168.0.250] RRQ 43 bytes:
15-33-20-024| [192.168.0.250] 00000000: 35 2e 38 2e 34 36 2f 43 30 41 38 36 39 35 33 00
15-33-20-024| [192.168.0.250] 00000010: 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c
15-33-20-024| [192.168.0.250] 00000020: 6b 73 69 7a 65 00 31 34 30 38 00
15-33-20-040| [192.168.0.250] Request block size 1408, interface MTU 1500.
15-33-20-040| [192.168.0.250] "5.8.46\C0A86953": tsize is requested, blksize 1408 bytes.
15-33-20-040| [192.168.0.250] "5.8.46\C0A86953": file not found: "C:\Program Files (x86)\WTware\TFTPDROOT\5.8.46\C0A86953".
и далее идет корректная загрузка. Куда смотреть?
Re: Загрузка по сети и VLAN
Служба TFTP пакеты от терминала получает. Терминал пакеты от службы TFTP не получает. Файрвол на сервере рубит? Маршрутизаторов между терминалом и сервером нет?
Ярослав
Сообщение Ярослав »
Файрвол отключен для проверки, маршрутизатор есть. Трафик между подсетями ходит успешно.
Ярослав писал(а): Ср авг 14, 2019 5:52 pm маршрутизатор есть. Трафик между подсетями ходит успешно.
Как именно это проверено? Ненастроенный маршрутизатор это самая простая причинина, почему пакет в одну сторону идет, а в другую не идет.
