маппинг com портов
Свойства, ошибки, замечания и проблемы сборок WTware для Rockchip. Про WTware на обычных x86 компьютерах смотрите раздел ниже.
Правила форума
маппинг com портов
Сообщение Гость » Пт дек 11, 2015 4:21 pm
Возникла проблема, при маппинге com порта на rk3188.
На x86 это же устройство ([initrd] USB: 0403:1234 Future Technology Devices International, Ltd IronLogic RFID Adapter [Z-2 USB].) маппится отлично.
Лог с x86:
[KERNEL] [ 0.000000] Linux version 4.1.13 (root@c12) (gcc version 5.2.1 20151010 (Ubuntu 5.2.1-22ubuntu2) ) #1 Wed Dec 2 22:10:29 SAMT 2015
[KERNEL] [ 0.015275] CPU: Intel(R) Celeron(R) CPU 2.53GHz (fam: 0f, model: 04, stepping: 09)
[KERNEL] [ 0.180128] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[KERNEL] [ 0.180134] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.180138] usb usb1: Product: EHCI Host Controller
[KERNEL] [ 0.180142] usb usb1: Manufacturer: Linux 4.1.13 ehci_hcd
[KERNEL] [ 0.180145] usb usb1: SerialNumber: 0000:00:1d.7
[KERNEL] [ 0.180434] hub 1-0:1.0: USB hub found
[KERNEL] [ 0.180450] hub 1-0:1.0: 8 ports detected
[KERNEL] [ 0.180812] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[KERNEL] [ 0.180826] ohci-pci: OHCI PCI platform driver
[KERNEL] [ 0.180882] uhci_hcd: USB Universal Host Controller Interface driver
[KERNEL] [ 0.181061] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[KERNEL] [ 0.181076] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[KERNEL] [ 0.181112] uhci_hcd 0000:00:1d.0: irq 20, io base 0x0000a000
[KERNEL] [ 0.181203] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.181208] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.181212] usb usb2: Product: UHCI Host Controller
[KERNEL] [ 0.181216] usb usb2: Manufacturer: Linux 4.1.13 uhci_hcd
[KERNEL] [ 0.181220] usb usb2: SerialNumber: 0000:00:1d.0
[KERNEL] [ 0.181500] hub 2-0:1.0: USB hub found
[KERNEL] [ 0.181517] hub 2-0:1.0: 2 ports detected
[KERNEL] [ 0.181837] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[KERNEL] [ 0.181853] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[KERNEL] [ 0.181924] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000a400
[KERNEL] [ 0.182017] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.182022] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.182026] usb usb3: Product: UHCI Host Controller
[KERNEL] [ 0.182029] usb usb3: Manufacturer: Linux 4.1.13 uhci_hcd
[KERNEL] [ 0.182033] usb usb3: SerialNumber: 0000:00:1d.1
[KERNEL] [ 0.182309] hub 3-0:1.0: USB hub found
[KERNEL] [ 0.182326] hub 3-0:1.0: 2 ports detected
[KERNEL] [ 0.182645] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[KERNEL] [ 0.182660] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[KERNEL] [ 0.182700] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000a800
[KERNEL] [ 0.182792] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.182797] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.182801] usb usb4: Product: UHCI Host Controller
[KERNEL] [ 0.182805] usb usb4: Manufacturer: Linux 4.1.13 uhci_hcd
[KERNEL] [ 0.182808] usb usb4: SerialNumber: 0000:00:1d.2
[KERNEL] [ 0.183090] hub 4-0:1.0: USB hub found
[KERNEL] [ 0.183108] hub 4-0:1.0: 2 ports detected
[KERNEL] [ 0.183433] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[KERNEL] [ 0.183449] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[KERNEL] [ 0.183489] uhci_hcd 0000:00:1d.3: irq 19, io base 0x0000b000
[KERNEL] [ 0.183800] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.183806] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.183810] usb usb5: Product: UHCI Host Controller
[KERNEL] [ 0.183814] usb usb5: Manufacturer: Linux 4.1.13 uhci_hcd
[KERNEL] [ 0.183817] usb usb5: SerialNumber: 0000:00:1d.3
[KERNEL] [ 0.184145] hub 5-0:1.0: USB hub found
[KERNEL] [ 0.184162] hub 5-0:1.0: 2 ports detected
[KERNEL] [ 0.184503] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[KERNEL] [ 0.184508] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[KERNEL] [ 0.185168] serio: i8042 KBD port at 0x60,0x64 irq 1
[KERNEL] [ 0.185300] hv_vmbus: registering driver hyperv_keyboard
[KERNEL] [ 0.185421] mousedev: PS/2 mouse device common for all mice
[KERNEL] [ 0.186188] input: PC Speaker as /devices/platform/pcspkr/input/input3
[KERNEL] [ 0.186401] hidraw: raw HID events driver (C) Jiri Kosina
[KERNEL] [ 0.186731] hv_vmbus: registering driver hid_hyperv
[KERNEL] [ 0.187226] usbcore: registered new interface driver usbhid
[KERNEL] [ 0.187232] usbhid: USB HID core driver
[KERNEL] [ 0.187346] NET: Registered protocol family 17
[KERNEL] [ 0.187693] Using IPI Shortcut mode
[KERNEL] [ 0.207888] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[KERNEL] [ 0.208096] RAMDISK: xz image found at block 0
[KERNEL] [ 0.676292] usb 2-1: new full-speed USB device number 2 using uhci_hcd
[KERNEL] [ 0.808115] usb 1-8: new high-speed USB device number 4 using ehci-pci
[KERNEL] [ 0.878467] usb 2-1: New USB device found, idVendor=0403, idProduct=1234
[KERNEL] [ 0.878474] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[KERNEL] [ 0.878479] usb 2-1: Product: USB IronLogic RFID Adapter
[KERNEL] [ 0.878483] usb 2-1: Manufacturer: ILogic
[KERNEL] [ 0.878487] usb 2-1: SerialNumber: IL01R3L3
[KERNEL] [ 0.880246] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[KERNEL] [ 0.944992] usb 1-8: New USB device found, idVendor=0951, idProduct=1642
[KERNEL] [ 0.944999] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[KERNEL] [ 0.945004] usb 1-8: Product: DT 101 G2
[KERNEL] [ 0.945008] usb 1-8: Manufacturer: Kingston
[KERNEL] [ 0.945012] usb 1-8: SerialNumber: 001CC05FE930BCA189160019
[KERNEL] [ 1.025139] VFS: Mounted root (romfs filesystem) readonly on device 1:0.
[KERNEL] [ 1.025179] devtmpfs: mounted
[KERNEL] [ 1.025438] Freeing unused kernel memory: 324K (c1478000 - c14c9000)
[KERNEL] [ 1.025502] Write protecting the kernel text: 3428k
[KERNEL] [ 1.025519] Write protecting the kernel read-only data: 940k
[KERNEL] [ 1.085186] usb 3-1: New USB device found, idVendor=0458, idProduct=003a
[KERNEL] [ 1.085195] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[KERNEL] [ 1.085200] usb 3-1: Manufacturer: Genius
[KERNEL] [ 1.102638] input: Genius as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.0/0003:0458:003A.0001/input/input4
[KERNEL] [ 1.102979] hid-generic 0003:0458:003A.0001: input,hidraw0: USB HID v1.10 Mouse [Genius] on usb-0000:00:1d.1-1/input0
[KERNEL] [ 1.156032] tsc: Refined TSC clocksource calibration: 2533.251 MHz
[KERNEL] [ 1.156044] clocksource tsc: mask: 0xffffffffffffffff max_cycles: 0x2483ec817d1, max_idle_ns: 440795216948 ns
[pfac] Ok, PID 530.
[initrd] WTware shell v.5.4.8
[initrd] USB boot.
[initrd] PCI: C 06 8086:2770 Bridge Intel Corporation 82945G/GZ/P/PL Memory Controller Hub.
[initrd] PCI: C 03 8086:2772 Display controller Intel Corporation 82945G/GZ Integrated Graphics Controller.
[initrd] PCI: C 04:03 8086:27d8 Multimedia controller Audio device Intel Corporation NM10/ICH7 Family High Definition Audio Controller.
[initrd] PCI: C 06:04 8086:27d0 Bridge PCI bridge Intel Corporation NM10/ICH7 Family PCI Express Port 1.
[initrd] PCI: C 0c:03 8086:27c8 Serial bus controller USB controller Intel Corporation NM10/ICH7 Family USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:27c9 Serial bus controller USB controller Intel Corporation NM10/ICH7 Family USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:27ca Serial bus controller USB controller Intel Corporation NM10/ICH7 Family USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:27cb Serial bus controller USB controller Intel Corporation NM10/ICH7 Family USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:27cc Serial bus controller USB controller Intel Corporation NM10/ICH7 Family USB2 EHCI Controller.
[initrd] PCI: C 06:04 8086:244e Bridge PCI bridge Intel Corporation 82801 PCI Bridge.
[initrd] PCI: C 06:01 8086:27b8 Bridge ISA bridge Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge.
[initrd] PCI: C 01:01 8086:27df Mass storage controller IDE interface Intel Corporation 82801G (ICH7 Family) IDE Controller.
[initrd] PCI: C 01:01 8086:27c0 Mass storage controller IDE interface Intel Corporation NM10/ICH7 Family SATA Controller [IDE mode].
[initrd] PCI: C 0c:05 8086:27da Serial bus controller SMBus Intel Corporation NM10/ICH7 Family SMBus Controller.
[initrd] PCI: C 02 11ab:4320 Network controller Marvell Technology Group Ltd. 88E8001 Gigabit Ethernet Controller.
[initrd] USB: 0951:1642 Kingston Technology DT101 G2.
[initrd] USB: 0458:003a KYE Systems Corp. (Mouse Systems) NetScroll+ Mini Traveler / Genius NetScroll 120.
[initrd] Load ISO 9660 and UDF CDROM filesystem drivers.
[initrd] modprobe udf.
[initrd] modprobe isofs.
[initrd] Load UTF8 charset.
[initrd] modprobe nls_cp437.
[initrd] modprobe nls_utf8.
[initrd] Load VFAT filesystem driver.
[initrd] modprobe fat.
[initrd] modprobe vfat.
[initrd] Load usb storage driver.
[initrd] modprobe scsi_mod.
[initrd] modprobe usb-storage.
[KERNEL] [ 1.567257] SCSI subsystem initialized
[initrd] modprobe sd_mod.
[KERNEL] [ 1.576833] usb-storage 1-8:1.0: USB Mass Storage device detected
[KERNEL] [ 1.576947] scsi host0: usb-storage 1-8:1.0
[KERNEL] [ 1.577111] usbcore: registered new interface driver usb-storage
[KERNEL] [ 2.156067] Switched to clocksource tsc
[KERNEL] [ 2.577032] scsi 0:0:0:0: Direct-Access Kingston DT 101 G2 PMAP PQ: 0 ANSI: 4
[KERNEL] [ 2.578289] sd 0:0:0:0: [sda] 15187968 512-byte logical blocks: (7.77 GB/7.24 GiB)
[KERNEL] [ 2.579545] sd 0:0:0:0: [sda] Write Protect is off
[KERNEL] [ 2.579555] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[KERNEL] [ 2.580802] sd 0:0:0:0: [sda] No Caching mode page found
[KERNEL] [ 2.580812] sd 0:0:0:0: [sda] Assuming drive cache: write through
[KERNEL] [ 2.586523] sda: sda1 sda2
[KERNEL] [ 2.590658] sd 0:0:0:0: [sda] Attached SCSI removable disk
[KERNEL] [ 2.635257] FAT-fs (sda): invalid media value (0xb9)
[KERNEL] [ 2.635263] FAT-fs (sda): Can't find a valid FAT filesystem
[initrd] Success: first USB disk mounted to /bootmedia.
[initrd] WTpassword empty.
| [BOM]
| clientIP=192.168.0.2
[initrd] Load ethernet drivers.
[initrd] modprobe skge.
[initrd] NIC module skge.ko loaded.
[KERNEL] [ 2.665854] skge: 1.14 addr 0xdfffc000 irq 20 chip Yukon-Lite rev 9
[KERNEL] [ 2.666207] skge 0000:01:04.0 eth0: addr 00:1a:92:32:d6:fc
[KERNEL] [ 2.680075] skge 0000:01:04.0 eth0: enabling interface
[KERNEL] [ 4.385352] skge 0000:01:04.0 eth0: Link is up at 100 Mbps, full duplex, flow control none
[initrd] eth0: 11ab:4320. Apply WOL configuration.
Send broadcast WTCU discover.
[initrd] Common local disk config:
| [BOM]
| server=192.168.0.1
| serial=com3(usb 0403:1234)
| clienthostname=2
| connection
| [BOM]
| server=192.168.0.1
| clienthostname=2
| connection
[initrd] Hostname: "2".
RSH: listener is active.
[gm] WTware session manager v.5.4.8.
[gm] Load agpgart driver.
[gm] modprobe agpgart.
[gm] modprobe intel-agp.
[KERNEL] [ 4.825796] Linux agpgart interface v0.103
[KERNEL] [ 4.830160] agpgart-intel 0000:00:00.0: Intel 945G Chipset
[KERNEL] [ 4.830195] agpgart-intel 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[KERNEL] [ 4.830346] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[KERNEL] [ 4.830542] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[gm] EV_REL flag found. Add mouse event4: Genius.
[gm] Add keyboard event3: AT Translated Set 2 keyboard.
[gm] Ignore event2: PC Speaker.
[gm] Add keyboard event1: Power Button.
[gm] Add keyboard event0: Power Button.
[gm] Display mode: 1366x768, 16 bit, 60 Hz, modeline "", DDC enabled, connector 0.
[gm] modprobe drm.
[gm] Run modprobe i915 modeset=1.
[KERNEL] [ 5.241937] [drm] Initialized drm 1.1.0 20060810
[gm] modprobe i915 modeset=1.
[KERNEL] [ 5.264704] [drm] Memory usable by graphics device = 256M
[KERNEL] [ 5.264715] [drm] Replacing VGA console driver
[KERNEL] [ 5.264845] Console: switching to colour dummy device 80x25
[KERNEL] [ 5.265592] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[KERNEL] [ 5.265599] [drm] Driver supports precise vblank timestamp query.
[KERNEL] [ 5.294996] [drm] initialized overlay support
[KERNEL] [ 5.295041] [drm] Initialized i915 1.6.0 20150327 for 0000:00:02.0 on minor 0
[gm] Kernel drm/kms module loaded.
[KERNEL] [ 5.367855] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[KERNEL] [ 5.367862] i915 0000:00:02.0: registered panic notifier
[gm] count_fbs 0.
[gm] count_crtcs 2.
[gm] count_connectors 1.
[gm] count_encoders 1.
[gm] min_width 0, max_width 4096, min_height 0, max_height 4096.
[gm] ======================
[gm] fb_id 0.
[gm] width 1366.
[gm] height 768.
[gm] pitch 2752.
[gm] bpp 16.
[gm] depth 16.
[gm] handle 0x00000001.
[gm] LINELENBYTES 2752, VBUF 0x0xb72c1000.
[gm] WMEMCOPY: 19530K copied in 0.016123 sec.
[gm] libc: 19530K copied in 0.015925 sec.
[gm] movs: 19530K copied in 0.015883 sec.
[gm] MMX: 19530K copied in 0.015779 sec.
[gm] SSE2: 19530K copied in 0.015897 sec.
[gm] Choose MMX memcpy.
[gm] Run serial daemon for ttyUSB0.
[pfac] Got command line /sbin/rdpdr[serial] 8.
[pfac] Ok, PID 643.
[gm] Load usb <-> serial bridges drivers.
[gm] modprobe usbserial.
[rdpdr-serial 8] RDP Serial Port Redirector, WTware v.5.4.8, device ttyUSB0.
[gm] modprobe pl2303.
[KERNEL] [ 5.653339] usbcore: registered new interface driver usbserial
[KERNEL] [ 5.653390] usbcore: registered new interface driver usbserial_generic
[KERNEL] [ 5.653432] usbserial: USB Serial support registered for generic
[gm] modprobe ftdi_sio.
[KERNEL] [ 5.661287] usbcore: registered new interface driver pl2303
[KERNEL] [ 5.661353] usbserial: USB Serial support registered for pl2303
[KERNEL] [ 5.667143] usbcore: registered new interface driver ftdi_sio
[KERNEL] [ 5.667199] usbserial: USB Serial support registered for FTDI USB Serial Device
[KERNEL] [ 5.667307] ftdi_sio 2-1:1.0: FTDI USB Serial Device converter detected
[KERNEL] [ 5.667387] usb 2-1: Detected FT232RL
[KERNEL] [ 5.669689] usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB0
[gm] modprobe cp210x.
[gm] modprobe ch341.
[KERNEL] [ 5.675118] usbcore: registered new interface driver cp210x
[KERNEL] [ 5.675173] usbserial: USB Serial support registered for cp210x
[gm] modprobe mxu11x0.
[KERNEL] [ 5.680792] usbcore: registered new interface driver ch341
[KERNEL] [ 5.680849] usbserial: USB Serial support registered for ch341-uart
[gm] modprobe metro-usb.
[KERNEL] [ 5.686580] usbcore: registered new interface driver mxu11x0
[KERNEL] [ 5.686641] usbserial: USB Serial support registered for MOXA UPort 1110
[KERNEL] [ 5.686684] usbserial: USB Serial support registered for MOXA UPort 1130
[KERNEL] [ 5.686724] usbserial: USB Serial support registered for MOXA UPort 1150
[KERNEL] [ 5.686765] usbserial: USB Serial support registered for MOXA UPort 1150I
[KERNEL] [ 5.686809] usbserial: USB Serial support registered for MOXA UPort 1130I
[KERNEL] [ 5.686819] mxu11x0: 1.3.11:MOXA UPort 11x0 USB to Serial Hub Driver
[gm] modprobe symbolserial.
[KERNEL] [ 5.696250] usbcore: registered new interface driver metro_usb
[KERNEL] [ 5.696317] usbserial: USB Serial support registered for Metrologic USB to Serial
[gm] modprobe opticon.
[KERNEL] [ 5.701340] usbcore: registered new interface driver symbolserial
[KERNEL] [ 5.701398] usbserial: USB Serial support registered for symbol
[KERNEL] [ 5.706931] usbcore: registered new interface driver opticon
[KERNEL] [ 5.706987] usbserial: USB Serial support registered for opticon
[pfac] Got command line /sbin/resolver 0x9231ca8 dns [192.168.0.1].
[pfac] Ok, PID 697.
[gm] Nobody can control terminal by VNC.
[gm] 192.168.0.1 => 192.168.0.1.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 880260 Kb.
[pfac] Ok, PID 698.
[pfac] Process pid 697 terminated, status 00000000.
[rdpclient 698] RDP Terminal Client, WTware v.5.4.8, pipe 1, pid 698.
[gm] COM3 => ttyUSB0.
[rdpclient 698] Add serial redirection, COM3 in the session = hardware ttyUSB0.
[rdpdr-serial 8] New client connection, id 1.
[rdpclient 698] Make RDP session with 192.168.0.1, port 3389.
[rdpclient 698] No PIN.
[rdpclient 698] No domain.
[rdpclient 698] No shell.
[rdpclient 698] No directory.
[rdpclient 698] Window: 1302x768@16.
[rdpclient 698] PFlags 0x0000002F.
[rdpclient 698] Keyboard 00000409:00000000.
[rdpclient 698] My hostname "2".
[rdpclient 698] TCP: connecting to 192.168.0.1:3389.
[rdpclient 698] TCP: connection with 192.168.0.1:3389 established.
[rdpclient 698] Turn keepalive on.
[rdpclient 698] Free ram after buffers allocation: 880012 KB.
[rdpclient 698] Process RDP server certificate.
[rdpclient 698] RDP5 encryption (X.509).
[KERNEL] [ 5.730368] random: rdpclient urandom read with 63 bits of entropy available
[rdpclient 698] INFOTYPE_LOGON_PLAINNOTIFY
[KERNEL] [ 74.045396] random: nonblocking pool is initialized
На rk3188 пишет:
[gm] ERROR: usb-serial device 0403:1234 not found.
[gm] Do NOT redirect COM4.
Лог с rk3188:
[init] WTware init v.5.4.8/RK3066 (c) 2003-2015 WTware http://www.wtware.com
[init] Run /sbin/loader.
[init] Ok, PID 72.
[loader] WTware/RK3066 loader v.5.4.8.
[loader] [0] partition 'misc'.
[loader] [1] partition 'kernel'.
[loader] [2] partition 'boot'.
[loader] [3] partition 'recovery'.
[loader] [4] partition 'backup'.
[loader] [5] partition 'cache'.
[loader] [6] partition 'userdata'.
[loader] [7] partition 'metadata'.
[loader] [8] partition 'kpanic'.
[loader] [9] partition 'system'. Store data here.
[loader] [10] partition 'user'.
[loader] Loader version 2.16.
[loader] Video mode looks like 1920x1080.
[loader] Keyboard not found.
[init] Run /sbin/kotenok.
[init] Ok, PID 105.
WTware v.5.4.8/RK3066 supervisor.
WTC listener is active.
HTTPd listener is active.
[KERNEL] [ 0.000000] Initializing cgroup subsys cpu
[KERNEL] [ 0.000000] Linux version 3.0.36+ (yangfeihu@xintu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #14 SMP PREEMPT Wed Jun 3 18:42:05 CST 2015
[KERNEL] [ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
[KERNEL] [ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[KERNEL] [ 0.000000] Machine: RK30board
[KERNEL] [ 0.000000] ddr size = 1024 M, set ion_reserve_size size to 125829120
[KERNEL] [ 0.000000] memory reserve: Memory(base:0x98800000 size:120M) reserved for
[KERNEL] [ 0.000000] memory reserve: Memory(base:0x97000000 size:24M) reserved for
[KERNEL] [ 0.000000] memory reserve: Memory(base:0x96800000 size:8M) reserved for
[KERNEL] [ 0.000000] memory reserve: Total reserved 152M
[KERNEL] [ 0.000000] Memory policy: ECC disabled, Data cache writeback
[KERNEL] [ 0.000000] bootconsole [earlycon0] enabled
[KERNEL] [ 0.000000] CPU SRAM: copied sram code from c0e47000 to fef00100 - fef02030
[KERNEL] [ 0.000000] CPU SRAM: copied sram data from c0e48f30 to fef02030 - fef02960
[KERNEL] [ 0.000000] sram_log: @ 0q @ P 1 / ! aB@ 2 `" 2q : 4q
[KERNEL] [ 0.000000] CLKDATA_MSG: pll_flag = 0x03
[KERNEL] [ 0.000000] cpll auto set rate error
[KERNEL] [ 0.000000] hzb test rmii clk get form clkin
[KERNEL] [ 0.000000] L310 cache controller enabled
[KERNEL] [ 0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c8, AUX_CTRL 0x76050001, Cache size: 524288 B
[KERNEL] [ 0.000000] DDR DEBUG: version 1.00 20131106
[KERNEL] [ 0.000000] DDR DEBUG: DDR3 Device
[KERNEL] [ 0.000000] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[KERNEL] [ 0.000000] DDR DEBUG: init success!!! freq=300MHz
[KERNEL] [ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=0 extra clock, DGPS=360
[KERNEL] [ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=1 extra clock, DGPS=90
[KERNEL] [ 0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[KERNEL] [ 0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb
[KERNEL] [ 0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[KERNEL] [ 0.000000] On node 0 totalpages: 223232
[KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat c0e44c40, node_mem_map c2790000
[KERNEL] [ 0.000000] Normal zone: 976 pages used for memmap
[KERNEL] [ 0.000000] Normal zone: 0 pages reserved
[KERNEL] [ 0.000000] Normal zone: 123952 pages, LIFO batch:31
[KERNEL] [ 0.000000] HighMem zone: 1072 pages used for memmap
[KERNEL] [ 0.000000] HighMem zone: 97232 pages, LIFO batch:31
[KERNEL] [ 0.000000] PERCPU: Embedded 7 pages/cpu @c2f99000 s7040 r8192 d13440 u32768
[KERNEL] [ 0.000000] pcpu-alloc: s7040 r8192 d13440 u32768 alloc=8*4096
[KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 221184
[KERNEL] [ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00790000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00006000@0x00004000(kernel),0x00006000@0x0000a000(boot),0x00010000@0x00010000(recovery),0x00020000@0x00020000(backup),0x00040000@0x00040000(cache),0x00400000@0x00080000(userdata),0x00002000@0x00480000(metadata),0x00002000@0x00482000(kpanic),0x00300000@0x00484000(system),-@0x00784000(user) bootver=2014-07-22#2.16 firmware_ver=4.4.2
[KERNEL] [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[KERNEL] [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[KERNEL] [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[KERNEL] [ 0.000000] allocated 4194304 bytes of page_cgroup
[KERNEL] [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[KERNEL] [ 0.000000] Memory: 872MB = 872MB total
[KERNEL] [ 0.000000] Memory: 850848k/850848k available, 197728k reserved, 393216K highmem
[KERNEL] [ 0.000000] Virtual kernel memory layout:
[KERNEL] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[KERNEL] [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[KERNEL] [ 0.000000] DMA : 0xff600000 - 0xffe00000 ( 8 MB)
[KERNEL] [ 0.000000] vmalloc : 0xdf000000 - 0xfe800000 ( 504 MB)
[KERNEL] [ 0.000000] lowmem : 0xc0000000 - 0xde800000 ( 488 MB)
[KERNEL] [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[KERNEL] [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[KERNEL] [ 0.000000] .init : 0xc0408000 - 0xc062f000 (2204 kB)
[KERNEL] [ 0.000000] .text : 0xc062f000 - 0xc0dbf548 (7746 kB)
[KERNEL] [ 0.000000] .data : 0xc0dc0000 - 0xc0e46aa8 ( 539 kB)
[KERNEL] [ 0.000000] .bss : 0xc0e4a024 - 0xc18facc8 (10948 kB)
[KERNEL] [ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[KERNEL] [ 0.000000] Preemptible hierarchical RCU implementation.
[KERNEL] [ 0.000000] NR_IRQS:352
[KERNEL] [ 0.000000] rk30_gpio_init: 128 gpio irqs in 4 banks
[KERNEL] [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[KERNEL] [ 0.000000] rk_timer: version 1.3
[KERNEL] [ 0.003748] Calibrating delay loop (skipped) preset value.. 1583.48 BogoMIPS (lpj=7917420)
[KERNEL] [ 0.012892] pid_max: default: 32768 minimum: 301
[KERNEL] [ 0.018159] Security Framework initialized
[KERNEL] [ 0.022731] SELinux: Initializing.
[KERNEL] [ 0.026655] SELinux: Starting in permissive mode
[KERNEL] [ 0.026721] Mount-cache hash table entries: 512
[KERNEL] [ 0.032303] Initializing cgroup subsys debug
[KERNEL] [ 0.037066] Initializing cgroup subsys cpuacct
[KERNEL] [ 0.042040] Initializing cgroup subsys memory
[KERNEL] [ 0.046920] Initializing cgroup subsys freezer
[KERNEL] [ 0.051894] CPU: Testing write buffer coherency: ok
[KERNEL] [ 0.138079] CPU1: Booted secondary processor
[KERNEL] [ 0.178069] CPU2: Booted secondary processor
[KERNEL] [ 0.218069] CPU3: Booted secondary processor
[KERNEL] [ 0.218110] Brought up 4 CPUs
[KERNEL] [ 0.235713] SMP: Total of 4 processors activated (6333.93 BogoMIPS).
[KERNEL] [ 0.243113] devtmpfs: initialized
[KERNEL] [ 0.252047] delayline: aclk_cpu 297000000 div 2 clk 99000000 start point 67
[KERNEL] [ 0.252820] NET: Registered protocol family 16
[KERNEL] [ 0.257896] last_log: 0xde100000 map to 0xdf004000 and copy to 0xc0e4e1a0 (version 2.1)
[KERNEL] [ 0.282073] DVFS MSG: AVS Value(index=0): 144 145 145 144 144 146 145 143 145 144
[KERNEL] [ 0.301087] lcdc0 is used as external display device contoller!
[KERNEL] [ 0.307717] lcdc1 is used as primary display device controller!
[KERNEL] [ 0.414511] rk29sdk_wifi_bt_gpio_control_init: init finished
[KERNEL] [ 0.422171] console [ttyFIQ0] enabled, bootconsole disabled
[KERNEL] [ 0.431339] Registered FIQ tty driver de035cc0
[KERNEL] [ 0.431966] Loaded driver for PL330 DMAC-1 rk29-pl330
[KERNEL] [ 0.432011] DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[KERNEL] [ 0.432196] Loaded driver for PL330 DMAC-2 rk29-pl330
[KERNEL] [ 0.432238] DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14
[KERNEL] [ 0.464021] bio: create slab at 0
[KERNEL] [ 0.468439] SCSI subsystem initialized
[KERNEL] [ 0.468650] usbcore: registered new interface driver usbfs
[KERNEL] [ 0.468766] usbcore: registered new interface driver hub
[KERNEL] [ 0.483016] usbcore: registered new device driver usb
[KERNEL] [ 0.483280] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter
[KERNEL] [ 0.483533] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
[KERNEL] [ 0.483718] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
[KERNEL] [ 0.483851] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter
[KERNEL] [ 0.484145] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter
[KERNEL] [ 0.514609] rk30-adc rk30-adc: rk30 adc: driver initialized
[KERNEL] [ 0.514712] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[KERNEL] [ 0.514931] rk29-wdt rk29-wdt.0: starting watchdog timer
[KERNEL] [ 0.515195] Advanced Linux Sound Architecture Driver Version 1.0.24.
[KERNEL] [ 0.515653] Bluetooth: Core ver 2.16
[KERNEL] [ 0.515727] NET: Registered protocol family 31
[KERNEL] [ 0.515764] Bluetooth: HCI device and connection manager initialized
[KERNEL] [ 0.515817] Bluetooth: HCI socket layer initialized
[KERNEL] [ 0.515856] Bluetooth: L2CAP socket layer initialized
[KERNEL] [ 0.515921] Bluetooth: SCO socket layer initialized
[KERNEL] [ 0.517021] rk fb probe ok!
[KERNEL] [ 0.521801] act8846_set_init,line=17
[KERNEL] [ 0.521833] act8846_set_init:g_pmic_type=3
[KERNEL] [ 0.523531] act8846_set_init act_dcdc1 =1200000mV end
[KERNEL] [ 0.525322] act8846_set_init vdd_core =1000000mV end
[KERNEL] [ 0.527107] act8846_set_init vdd_cpu =1000000mV end
[KERNEL] [ 0.528905] act8846_set_init act_dcdc4 =3300000mV end
[KERNEL] [ 0.530094] act8846_set_init act_ldo1 =1000000mV end
[KERNEL] [ 0.531777] act8846_set_init act_ldo2 =1200000mV end
[KERNEL] [ 0.533460] act8846_set_init act_ldo3 =1800000mV end
[KERNEL] [ 0.535143] act8846_set_init act_ldo4 =3300000mV end
[KERNEL] [ 0.536827] act8846_set_init act_ldo5 =3300000mV end
[KERNEL] [ 0.538524] act8846_set_init act_ldo6 =1800000mV end
[KERNEL] [ 0.539607] act8846_set_init act_ldo7 =1800000mV end
[KERNEL] [ 0.541290] act8846_set_init act_ldo8 =2800000mV end
[KERNEL] [ 0.541338] act8846_set_init,line=78 END
[KERNEL] [ 0.541407] i2c-core: driver [act8846] using legacy suspend method
[KERNEL] [ 0.541455] i2c-core: driver [act8846] using legacy resume method
[KERNEL] [ 0.541530] rk1000_control_probe
[KERNEL] [ 0.566434] rk1000_control_probe ok
[KERNEL] [ 0.566516] Switching to clocksource rk_timer
[KERNEL] [ 0.567504] Switched to NOHz mode on CPU #0
[KERNEL] [ 0.568107] Switched to NOHz mode on CPU #3
[KERNEL] [ 0.568126] Switched to NOHz mode on CPU #2
[KERNEL] [ 0.568138] Switched to NOHz mode on CPU #1
[KERNEL] [ 0.575370] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xdf0ac000
[KERNEL] [ 0.575461] fb0:win0
[KERNEL] [ 0.575466] fb1:win1
[KERNEL] [ 0.575471] fb2:win2
[KERNEL] [ 0.575565] rk3188 lcdc1 clk enable...
[KERNEL] [ 0.600682] rk3188 lcdc1 clk disable...
[KERNEL] [ 0.660404] fb0:phy:97000000>>vir:e0000000>>len:0x1800000
[KERNEL] [ 0.660693] rk_fb_register>>>>>fb0
[KERNEL] [ 0.661028] rk_fb_register>>>>>fb1
[KERNEL] [ 0.693521] rk3188 lcdc1 probe ok!
[KERNEL] [ 0.693617] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xdf0c0000
[KERNEL] [ 0.693693] fb0:win0
[KERNEL] [ 0.693698] fb1:win1
[KERNEL] [ 0.693703] fb2:win2
[KERNEL] [ 0.693802] rk3188 lcdc0 clk enable...
[KERNEL] [ 0.718900] rk3188 lcdc0 clk disable...
[KERNEL] [ 0.718940] fb2:phy:97000000>>vir:e0000000>>len:0x1800000
[KERNEL] [ 0.719201] rk_fb_register>>>>>fb2
[KERNEL] [ 0.719543] rk_fb_register>>>>>fb3
[KERNEL] [ 0.719574] rk3188 lcdc0 probe ok!
[KERNEL] [ 0.752873] cfg80211: Calling CRDA to update world regulatory domain
[KERNEL] [ 0.780562] IT66121 probe success.
[KERNEL] [ 0.783891] emmc emmc: internal_storage is NOT emmc
[KERNEL] [ 0.784103] NET: Registered protocol family 2
[KERNEL] [ 0.784245] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
[KERNEL] [ 0.784602] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[KERNEL] [ 0.785622] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[KERNEL] [ 0.786775] TCP: Hash tables configured (established 65536 bind 65536)
[KERNEL] [ 0.786825] TCP reno registered
[KERNEL] [ 0.786857] UDP hash table entries: 256 (order: 1, 8192 bytes)
[KERNEL] [ 0.786916] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[KERNEL] [ 0.787235] NET: Registered protocol family 1
[KERNEL] [ 0.787438] Unpacking initramfs...
[KERNEL] [ 1.017573] Freeing initrd memory: 7744K
[KERNEL] [ 1.017689] PMU: registered new PMU device of type 0
[KERNEL] [ 1.017829] efuse_version_val: efuse version = 51
[KERNEL] [ 1.017870] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 33000
[KERNEL] [ 1.017926] adjust table freq=1608000 KHz, index=1350000 mV to index=1250000 mV
[KERNEL] [ 1.017984] efuse_version_val: efuse version = 51
[KERNEL] [ 1.018022] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 33000
[KERNEL] [ 1.018632] ******** Show Sink Info ********
[KERNEL] [ 1.018667] Support video mode:
[KERNEL] [ 1.018695] 1920x1080p@60Hz.
[KERNEL] [ 1.018719] 1920x1080p@50Hz.
[KERNEL] [ 1.018743] 1280x720p@60Hz.
[KERNEL] [ 1.018767] 1280x720p@50Hz.
[KERNEL] [ 1.018790] 720x576p@50Hz.
[KERNEL] [ 1.018813] 720x480p@60Hz.
[KERNEL] [ 1.018835] Support audio type: LPCM
[KERNEL] [ 1.018863] Support audio sample rate:
[KERNEL] [ 1.018893] 32000
[KERNEL] [ 1.018909] 44100
[KERNEL] [ 1.018926] 48000
[KERNEL] [ 1.018943] 88200
[KERNEL] [ 1.018960] 96000
[KERNEL] [ 1.018978] 176400
[KERNEL] [ 1.018995] 192000
[KERNEL] [ 1.019012] Support audio word lenght:
[KERNEL] [ 1.019042] 16bit
[KERNEL] [ 1.019059] 20bit
[KERNEL] [ 1.019075] 24bit
[KERNEL] [ 1.019093] ******** Show Sink Info ********
[KERNEL] [ 1.019152] rk3188 lcdc1 clk enable...
[KERNEL] [ 1.019196] lcdc1: dclk:148500000>>fps:60
[KERNEL] [ 1.019235] rk30-lcdc rk30-lcdc.1: rk3188_load_screen for lcdc1 ok!
[KERNEL] [ 1.019287] lcdc1 wakeup from standby!
[KERNEL] [ 1.019320] lcdc1 win0 open,atv layer:1
[KERNEL] [ 1.019361] lcdc1 win1 closed,atv layer:1
[KERNEL] [ 1.019712] cpufreq: delete arm freq(1608000)
[KERNEL] [ 1.148430] rk3188 cpufreq version 2.2, suspend freq 816 MHz
[KERNEL] [ 1.148937] vpu: power on
[KERNEL] [ 1.149005] VPU_SERVICE: checking hw id 4831
[KERNEL] [ 1.161345] vpu: power off...done
[KERNEL] [ 1.161406] VPU_SERVICE: init success
[KERNEL] [ 1.161695] audit: initializing netlink socket (disabled)
[KERNEL] [ 1.161769] type=2000 audit(1.090:1): initialized
[KERNEL] [ 1.164345] highmem bounce pool size: 64 pages
[KERNEL] [ 1.164529] ashmem: initialized
[KERNEL] [ 1.191454] fuse init (API version 7.16)
[KERNEL] [ 1.191730] SELinux: Registering netfilter hooks
[KERNEL] [ 1.196404] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[KERNEL] [ 1.196469] io scheduler noop registered
[KERNEL] [ 1.196510] io scheduler deadline registered
[KERNEL] [ 1.196628] io scheduler cfq registered (default)
[KERNEL] [ 1.216881] rga: Driver loaded succesfully
[KERNEL] [ 1.217014] rk3188 lcdc0 clk enable...
[KERNEL] [ 1.217058] lcdc0: dclk:148500000>>fps:60
[KERNEL] [ 1.217096] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
[KERNEL] [ 1.217585] rk1000_tv ver 2.0 probe ok
[KERNEL] [ 1.217806] rk_serial.c v1.6 2013-12-23
[KERNEL] [ 1.218095] rk_serial rk_serial.0: dma_rx_buffer 0xffdfc000
[KERNEL] [ 1.218141] rk_serial rk_serial.0: dma_rx_phy 0x7d4e6000
[KERNEL] [ 1.218193] rk_serial rk_serial.0: serial_rk_init_dma_rx sucess
[KERNEL] [ 1.218246] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0
[KERNEL] [ 1.218437] rk_serial rk_serial.0: membase 0xdf0c8000
[KERNEL] [ 1.218524] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
[KERNEL] [ 1.218709] rk_serial rk_serial.3: membase 0xdf0d0000
[KERNEL] [ 1.219000] Rockchip ion module(version: 1.0) is successfully loaded
[KERNEL] [ 1.221692] loop: module loaded
[KERNEL] [ 1.221756] Android kernel panic handler initialized (bind=kpanic)
[KERNEL] [ 1.221834] mt6622_probe.
[KERNEL] [ 1.221861] [BT-PLAT] mt_bt_power_init
[KERNEL] [ 2.436644] BTHWCTL: alloc bthwctl: 251:0
[KERNEL] [ 2.436795] BTHWCTL: Bluetooth hardware control driver initialized
[KERNEL] [ 2.437361] random_ether_addr***********:4A:F9:88:8E:7C:5
[KERNEL] [ 2.437611] rk29 vmac rk29 vmac.0: ARC VMAC at 0x10204000 irq 51 4a:f9:88:8e:7c:05
[KERNEL] [ 2.437683] PPP generic driver version 2.4.2
[KERNEL] [ 2.437811] PPP Deflate Compression module registered
[KERNEL] [ 2.437845] PPP BSD Compression module registered
[KERNEL] [ 2.447051] PPP MPPE Compression module registered
[KERNEL] [ 2.447090] NET: Registered protocol family 24
[KERNEL] [ 2.447174] usbcore: registered new interface driver asix
[KERNEL] [ 2.447232] usbcore: registered new interface driver cdc_ether
[KERNEL] [ 2.447289] usbcore: registered new interface driver dm9620
[KERNEL] [ 2.447342] usbcore: registered new interface driver SR9700_android
[KERNEL] [ 2.447408] usbcore: registered new interface driver CoreChips
[KERNEL] [ 2.447463] usbcore: registered new interface driver net1080
[KERNEL] [ 2.447517] usbcore: registered new interface driver cdc_subset
[KERNEL] [ 2.447580] usbcore: registered new interface driver zaurus
[KERNEL] [ 2.447625] cdc_ncm: 04-Aug-2011
[KERNEL] [ 2.447665] usbcore: registered new interface driver cdc_ncm
[KERNEL] [ 2.447701] Rockchip WiFi SYS interface (V1.00) ...
[KERNEL] [ 2.447758] Initializing USB Mass Storage driver...
[KERNEL] [ 2.447813] usbcore: registered new interface driver usb-storage
[KERNEL] [ 2.447852] USB Mass Storage support registered.
[KERNEL] [ 2.447945] usbcore: registered new interface driver usbserial
[KERNEL] [ 2.448003] USB Serial support registered for generic
[KERNEL] [ 2.448058] usbcore: registered new interface driver usbserial_generic
[KERNEL] [ 2.448098] usbserial: USB Serial Driver core
[KERNEL] [ 2.448144] USB Serial support registered for GSM modem (1-port)
[KERNEL] [ 2.448202] usbcore: registered new interface driver option
[KERNEL] [ 2.448236] option: v0.7.2:USB Driver for GSM modems
[KERNEL] [ 2.448285] USB Serial support registered for usi-modem
[KERNEL] [ 2.448345] usbcore: registered new interface driver usi-modem
[KERNEL] [ 2.660128] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
[KERNEL] [ 2.660184] usb20_otg usb20_otg: DWC OTG Controller
[KERNEL] [ 2.660289] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
[KERNEL] [ 2.660360] usb20_otg usb20_otg: irq 48, io mem 0x00000000
[KERNEL] [ 2.660417] DWC_OTG: Init: Port Power? op_state=1
[KERNEL] [ 2.660447] DWC_OTG: Init: Power Port (0)
[KERNEL] [ 2.660512] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[KERNEL] [ 2.660555] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 2.660598] usb usb1: Product: DWC OTG Controller
[KERNEL] [ 2.660631] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd
[KERNEL] [ 2.660666] usb usb1: SerialNumber: usb20_otg
[KERNEL] [ 2.660976] hub 1-0:1.0: USB hub found
[KERNEL] [ 2.661012] hub 1-0:1.0: 1 port detected
[KERNEL] [ 2.663600] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xdf180000
[KERNEL] [ 2.874131] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
[KERNEL] [ 2.874170] usb20_host usb20_host: DWC OTG Controller
[KERNEL] [ 2.874233] usb20_host usb20_host: new USB bus registered, assigned bus number 2
[KERNEL] [ 2.874296] usb20_host usb20_host: irq 49, io mem 0x00000000
[KERNEL] [ 2.874366] DWC_OTG: Init: Port Power? op_state=1
[KERNEL] [ 2.874396] DWC_OTG: Init: Power Port (0)
[KERNEL] [ 2.874449] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[KERNEL] [ 2.874492] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 2.874538] usb usb2: Product: DWC OTG Controller
[KERNEL] [ 2.874569] usb usb2: Manufacturer: Linux 3.0.36+ host20_hcd
[KERNEL] [ 2.874604] usb usb2: SerialNumber: usb20_host
[KERNEL] [ 2.874881] hub 2-0:1.0: USB hub found
[KERNEL] [ 2.874912] hub 2-0:1.0: 1 port detected
[KERNEL] [ 2.875261] DWC_OTG: Mode Mismatch Interrupt: currently in Host mode
[KERNEL] [ 2.948517] android_usb gadget: Mass Storage Function, version: 2009/09/11
[KERNEL] [ 2.948570] android_usb gadget: Number of LUNs=2
[KERNEL] [ 2.948612] lun0: LUN: removable file: (no medium)
[KERNEL] [ 2.948651] lun1: LUN: removable file: (no medium)
[KERNEL] [ 2.948938] android_usb gadget: android_usb ready
[KERNEL] [ 2.949164] input: rk29-keypad as /devices/platform/rk29-keypad/input/input0
[KERNEL] [ 2.949436] usbcore: registered new interface driver xpad
[KERNEL] [ 2.949657] ===================================================
[KERNEL] [ 2.949699] Rockchip IR remote controller driver. Version 1.0.0
[KERNEL] [ 2.949740] ===================================================
[KERNEL] [ 2.949782] ++++++++remotectl_init
[KERNEL] [ 2.949824] ++++++++remotectl_probe
[KERNEL] [ 2.949872] remotectl probe j=0x0
[KERNEL] [ 2.949901] remotectl probe j=0x1
[KERNEL] [ 2.949927] remotectl probe j=0x2
[KERNEL] [ 2.949951] remotectl probe j=0x3
[KERNEL] [ 2.949976] remotectl probe j=0x4
[KERNEL] [ 2.950001] remotectl probe j=0x5
[KERNEL] [ 2.950028] remotectl probe j=0x6
[KERNEL] [ 2.950175] input: rkxx-remotectl as /devices/platform/rkxx-remotectl/input/input1
[KERNEL] [ 2.952431] rtc_hym8563 1-0051: clock/calendar information is no longer guaranteed
[KERNEL] [ 2.955875] using rtc device, rtc_hym8563, for alarms
[KERNEL] [ 2.955927] rtc_hym8563 1-0051: rtc core: registered rtc_hym8563 as rtc0
[KERNEL] [ 2.955997] i2c /dev entries driver
[KERNEL] [ 2.956433] lirc_dev: IR Remote Control driver registered, major 249
[KERNEL] [ 2.956477] IR NEC protocol handler initialized
[KERNEL] [ 2.956506] IR RC5(x) protocol handler initialized
[KERNEL] [ 2.956537] IR RC6 protocol handler initialized
[KERNEL] [ 2.956566] IR JVC protocol handler initialized
[KERNEL] [ 2.956625] IR Sony protocol handler initialized
[KERNEL] [ 2.956655] IR RC5 (streamzap) protocol handler initialized
[KERNEL] [ 2.956691] IR LIRC bridge handler initialized
[KERNEL] [ 2.956718] Linux video capture interface: v2.00
[KERNEL] [ 2.956906] usbcore: registered new interface driver uvcvideo
[KERNEL] [ 2.956944] USB Video Class driver (v1.1.0)
[KERNEL] [ 2.957000] def_ref_volt: 1800mV, curr_ref_volt: 1800mV
[KERNEL] [ 2.957296] device-mapper: uevent: version 1.0.3
[KERNEL] [ 2.957520] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[KERNEL] [ 2.957714] Bluetooth: HCI UART driver ver 2.2
[KERNEL] [ 2.957746] Bluetooth: HCI H4 protocol initialized
[KERNEL] [ 2.957776] Bluetooth: HCILL protocol initialized
[KERNEL] [ 2.957805] Bluetooth: Generic Bluetooth USB driver ver 0.6
[KERNEL] [ 2.957878] usbcore: registered new interface driver btusb
[KERNEL] [ 2.957948] cpuidle: using governor ladder
[KERNEL] [ 2.957976] cpuidle: using governor menu
[KERNEL] [ 3.003438]
[KERNEL] [ 3.003442] drivers/mmc/core/core.c...2019.. ===== mmc_rescan Begin....[mmc0]
[KERNEL] [ 3.003495]
[KERNEL] [ 3.003498] =================
[KERNEL] [ 3.003502] sdmmc_rescan..2026.. ====find no SDMMC host. [mmc0]
[KERNEL] [ 3.003583] .Line4018..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20. [sd_mmc]
[KERNEL] [ 3.003781]
[KERNEL] [ 3.003784] drivers/mmc/core/core.c...2019.. ===== mmc_rescan Begin....[mmc1]
[KERNEL] [ 3.003846] .Line4018..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20. [sdio]
[KERNEL] [ 3.003993] Registered led device: it66121
[KERNEL] [ 3.004038] Registered led device: cvbs
[KERNEL] [ 3.005184] usbcore: registered new interface driver usbhid
[KERNEL] [ 3.005223] usbhid: USB HID core driver
[KERNEL] [ 3.005543] logger: created 256K log 'log_main'
[KERNEL] [ 3.005638] logger: created 256K log 'log_events'
[KERNEL] [ 3.005720] logger: created 256K log 'log_radio'
[KERNEL] [ 3.005798] logger: created 256K log 'log_system'
[KERNEL] [ 3.006104] zram: Created 1 device(s) ...
[KERNEL] [ 3.006539] i2c-core: driver [RK1000_CODEC] using legacy suspend method
[KERNEL] [ 3.006609] i2c-core: driver [RK1000_CODEC] using legacy resume method
[KERNEL] [ 3.026876] rk29_sdmmc_change_clk_div..1684.. newDiv=42, newCLK=294Khz [sdio]
[KERNEL] [ 3.046664] usb 1-1: new full speed USB device number 2 using usb20_otg
[KERNEL] [ 3.161294] register rk1000 codec earlysuspend ok
[KERNEL] [ 3.161332] RK1000_CODEC 4-0060: Failed to add route Left DAC->Left Mixer
[KERNEL] [ 3.167907] asoc: rk1000_codec <-> rk29_i2s.1 mapping ok
[KERNEL] [ 3.168227] ALSA device list:
[KERNEL] [ 3.168250] #0: RK29_RK1000
[KERNEL] [ 3.168356] GACT probability NOT on
[KERNEL] [ 3.168385] Mirror/redirect action on
[KERNEL] [ 3.168410] u32 classifier
[KERNEL] [ 3.168427] Actions configured
[KERNEL] [ 3.168450] Netfilter messages via NETLINK v0.30.
[KERNEL] [ 3.168519] nf_conntrack version 0.5.0 (13415 buckets, 53660 max)
[KERNEL] [ 3.168816] ctnetlink v0.93: registering with nfnetlink.
[KERNEL] [ 3.168880] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[KERNEL] [ 3.168922] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[KERNEL] [ 3.169230] xt_time: kernel timezone is -0000
[KERNEL] [ 3.169373] ip_tables: (C) 2000-2006 Netfilter Core Team
[KERNEL] [ 3.169527] arp_tables: (C) 2002 David S. Miller
[KERNEL] [ 3.169595] TCP cubic registered
[KERNEL] [ 3.169616] Initializing XFRM netlink socket
[KERNEL] [ 3.169967] NET: Registered protocol family 10
[KERNEL] [ 3.170594] Mobile IPv6
[KERNEL] [ 3.170633] ip6_tables: (C) 2000-2006 Netfilter Core Team
[KERNEL] [ 3.170757] IPv6 over IPv4 tunneling driver
[KERNEL] [ 3.171311] NET: Registered protocol family 17
[KERNEL] [ 3.171360] NET: Registered protocol family 15
[KERNEL] [ 3.270844] usb 1-1: New USB device found, idVendor=0403, idProduct=1234
[KERNEL] [ 3.270890] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[KERNEL] [ 3.270934] usb 1-1: Product: USB IronLogic RFID Adapter
[KERNEL] [ 3.270968] usb 1-1: Manufacturer: ILogic
[KERNEL] [ 3.270996] usb 1-1: SerialNumber: IL01R3L3
[KERNEL] [ 3.412582] Bluetooth: RFCOMM TTY layer initialized
[KERNEL] [ 3.412648] Bluetooth: RFCOMM socket layer initialized
[KERNEL] [ 3.412684] Bluetooth: RFCOMM ver 1.11
[KERNEL] [ 3.412711] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[KERNEL] [ 3.412745] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[KERNEL] [ 3.412896] NET: Registered protocol family 35
[KERNEL] [ 3.413085] [BT_RFKILL]: Enter rfkill_rk_init
[KERNEL] [ 3.413192] [BT_RFKILL]: Request irq for bt wakeup host
[KERNEL] [ 3.413236] [BT_RFKILL]: ** disable irq
[KERNEL] [ 3.436594] [BT_RFKILL]: bt shut off power
[KERNEL] [ 3.456614] usb 2-1: new high speed USB device number 2 using usb20_host
[KERNEL] [ 3.466588] [BT_RFKILL]: bt_default device registered.
[KERNEL] [ 3.466668] pmic set pm_suspend_volt:
[KERNEL] [ 3.482089] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[KERNEL] [ 3.482179] Registering SWP/SWPB emulation handler
[KERNEL] [ 3.482649] ddrfreq: verion 3.2 20131126
[KERNEL] [ 3.482678] ddrfreq: fix cpu pause bug
[KERNEL] [ 3.482703] ddrfreq: normal 456MHz video 0MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 300MHz
[KERNEL] [ 3.483491] ddrfreq: change freq to 445 MHz when normal
[KERNEL] [ 3.483834] Error: Driver 'generic-bluetooth' is already registered, aborting...
[KERNEL] [ 3.484387] rtc_hym8563 1-0051: setting system clock to 2011-01-01 12:00:00 UTC (1293883200)
[KERNEL] [ 3.485035] rk_cam_cif(3329):rk3066b-camera version: v0.3.21 Zoom by ipp
[KERNEL] [ 3.486439] asoc: dit-hifi <-> rk-spdif mapping ok
[KERNEL] [ 3.486889] usbcore: registered new interface driver snd-usb-audio
[KERNEL] [ 3.487198] Freeing init memory: 2204K
[KERNEL] [ 3.488663] ret: 0
[KERNEL] [ 3.516640] ret: 0
[KERNEL] [ 3.557017] ret: 0
[KERNEL] [ 3.559276] gp_rknand_info = : 0xde388600
[KERNEL] [ 3.559366] rk30_chip_set:1
[KERNEL] [ 3.559433] FtlInit!
[KERNEL] [ 3.559462] No.1 FLASH ID:ad de 14 a7 42 4a
[KERNEL] [ 3.562279] FTL version: 5.0.12 20140214
[KERNEL] [ 3.586654] camera 33-0-ov5640_back_3: Probe ov5640_back_3 failed
[KERNEL] [ 3.586763] ret: 0
[KERNEL] [ 3.616601] ret: 0
[KERNEL] [ 3.656867] min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200
[KERNEL] [ 3.657318] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
[KERNEL] [ 3.657752] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1...
[KERNEL] [ 3.658182] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0...
[KERNEL] [ 3.658228] ov2659_front_4(rk_cam_sensor:163): write reg(0x103, val:0x1) failed, try to write again!
[KERNEL] [ 3.658672] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
[KERNEL] [ 3.659104] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1...
[KERNEL] [ 3.659536] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0...
[KERNEL] [ 3.659581] ov2659_front_4(rk_cam_sensor:163): write reg(0x103, val:0x1) failed, try to write again!
[KERNEL] [ 3.660024] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
[KERNEL] [ 3.660454] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1...
[KERNEL] [ 3.660885] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0...
[KERNEL] [ 3.660931] ov2659_front_4(rk_cam_sensor:163): write reg(0x103, val:0x1) failed, try to write again!
[KERNEL] [ 3.660986] ov2659_front_4(rk_cam_sensor:379): write array failed!
[KERNEL] [ 3.661020] ov2659_front_4(rk_cam_sensor:685): soft reset failed
[KERNEL] [ 3.661026]
[KERNEL] [ 3.667164] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101
[KERNEL] [ 3.667201] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[KERNEL] [ 3.667239] usb 2-1: Product: USB 2.0 Hub [MTT]
[KERNEL] [ 3.667562] hub 2-1:1.0: USB hub found
[KERNEL] [ 3.667659] hub 2-1:1.0: 4 ports detected
[KERNEL] [ 3.677102] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
[KERNEL] [ 3.677640] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1...
[KERNEL] [ 3.678178] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0...
[KERNEL] [ 3.678226] ov2659_front_4(rk_cam_sensor:329): read reg(0x300a val:0x0) failed, try to read again!
[KERNEL] [ 3.678281] ov2659_front_4(rk_cam_sensor:712): read chip id failed
[KERNEL] [ 3.678383] ret: 0
[KERNEL] [ 3.706618] camera 33-1-ov2659_front_4: Probe ov2659_front_4 failed
[KERNEL] [ 3.836131] gBootMedia = 1 gSdmmcFwPartOffset =0!
[KERNEL] [ 3.836158] rknand_buffer.c version: 4.40 20130830!
[KERNEL] [ 3.871644] 11 cmdlinepart partitions found on MTD device rk29xxnand
[KERNEL] [ 3.871680] Creating 11 MTD partitions on "rk29xxnand":
[KERNEL] [ 3.871717] 0x000000400000-0x000000800000 : "misc"
[KERNEL] [ 3.888259] 0x000000800000-0x000001400000 : "kernel"
[KERNEL] [ 3.893452] 0x000001400000-0x000002000000 : "boot"
[KERNEL] [ 3.898461] 0x000002000000-0x000004000000 : "recovery"
[KERNEL] [ 3.903820] 0x000004000000-0x000008000000 : "backup"
[KERNEL] [ 3.909041] 0x000008000000-0x000010000000 : "cache"
[KERNEL] [ 3.914144] 0x000010000000-0x000090000000 : "userdata"
[KERNEL] [ 3.919510] 0x000090000000-0x000090400000 : "metadata"
[KERNEL] [ 3.924879] 0x000090400000-0x000090800000 : "kpanic"
[KERNEL] [ 3.930867] apanic: Bound to mtd partition 'kpanic'
[KERNEL] [ 3.930897] apanic: No panic data available
[KERNEL] [ 3.930930] 0x000090800000-0x0000f0800000 : "system"
[KERNEL] [ 3.945100] 0x0000f0800000-0x0001d4000000 : "user"
[KERNEL] [ 3.960998] EXT4-fs (mtdblock9): mounted filesystem with ordered data mode. Opts:
[KERNEL] [ 3.968619]
[KERNEL] [ 3.968644]
[KERNEL] [ 7.552483] enter func vmac_open...
[KERNEL] [ 7.552548] !!!!!!!!!!11111111111111!!!!
[KERNEL] [ 7.552589] power on phy
[KERNEL] [ 7.698535] vmac_mii_bus: probed
[KERNEL] [ 7.699530] rk29 vmac rk29 vmac.0: PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1)
[KERNEL] [ 7.700666] ADDRCONF(NETDEV_UP): eth0: link is not ready
[KERNEL] [ 9.697047] PHY: 0:00 - Link is Down
[KERNEL] [ 10.699265] PHY: 0:00 - Link is Up - 100/Full
[KERNEL] [ 10.700294] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[KERNEL] [ 13.835473]
[KERNEL] [ 13.837054]
[KERNEL] [ 17.424515] enter func vmac_close...
[KERNEL] [ 17.428197] enter func vmac_open...
[KERNEL] [ 17.428237] !!!!!!!!!!11111111111111!!!!
[KERNEL] [ 17.428281] power on phy
[KERNEL] [ 17.576593] vmac_mii_bus: probed
[KERNEL] [ 17.577306] rk29 vmac rk29 vmac.0: PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1)
[KERNEL] [ 17.577843] ADDRCONF(NETDEV_UP): eth0: link is not ready
[KERNEL] [ 19.576991] PHY: 0:00 - Link is Down
[KERNEL] [ 20.579220] PHY: 0:00 - Link is Up - 100/Full
[KERNEL] [ 20.580208] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[init] Run /sbin/gm.
[init] Ok, PID 106.
[gm] WTware/RK3066 session manager v.5.4.8.
[gm] Common local disk config:
| [BOM]
| server=192.168.0.1
| serial=com4(usb 0403:1234)
| clienthostname=3
| connection
| [BOM]
| server=192.168.0.1
| clienthostname=3
| connection
[gm] Hostname: "3".
[gm] Add keyboard event1: rkxx-remotectl.
[gm] Add keyboard event0: rk29-keypad.
[init] Run /sbin/rdpdr[serial] 0.
[init] Ok, PID 107.
[init] Process pid 107 terminated, status 00007f00.
[init] Run /sbin/resolver 0xc7798 dns [192.168.0.1].
[init] Ok, PID 108.
[init] Process pid 108 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 812128 Kb.
[init] Run /sbin/rdpclient 1.
[init] Ok, PID 109.
[rdpclient 109] RDP Terminal Client, WTware v.5.4.8/RK3066, pipe 1, pid 109.
[gm] Failed to set keyboard leds.
[rdpclient 109] Make RDP session with 192.168.0.1, port 3389.
[rdpclient 109] Username: "sklad-suhoy".
[rdpclient 109] Password: present.
[rdpclient 109] No PIN.
[rdpclient 109] No domain.
[rdpclient 109] No shell.
[rdpclient 109] No directory.
[rdpclient 109] Window: 1856x1080@16.
[rdpclient 109] PFlags 0x0000002F.
[rdpclient 109] Keyboard 00000409:00000000.
[rdpclient 109] My hostname "3".
[rdpclient 109] TCP: connecting to 192.168.0.1:3389.
[init] Process pid 72 terminated, status 00000000.
[rdpclient 109] TCP: connection with 192.168.10.1:3389 established.
[rdpclient 109] Turn keepalive on.
[rdpclient 109] Free ram after buffers allocation: 811384 KB.
[rdpclient 109] Process RDP server certificate.
[rdpclient 109] RDP5 encryption (X.509).
[rdpclient 109] INFOTYPE_LOGON_PLAINNOTIFY
Re: маппинг com портов
Сообщение aka » Пт дек 11, 2015 5:20 pm
В самом верху страницы, над твоим сообщением, оранжевую рамочку видишь? Вот это оно. Ядро не наше. Муторно это - подсовывать в чужое ядро, исходников которого у меня нет, новый модуль (драйвер). На Raspberry должно работать, там ядро наше. На рокчипе не едет.
Перенаправление USB через RDP для 2012R2 сервера понемногу начинает дышать, оно может помочь. В этом году надеюсь выложить первую экспериментальну сборку.
bannedspam
Сообщение bannedspam » Пт дек 11, 2015 6:47 pm
Понял, спасибо.
16.12.15 буду пробовать это же на Raspberry PI2 model B, результат напишу.
bannedspam
Сообщение bannedspam » Пт дек 18, 2015 12:48 pm
На Raspberry Pi2 model B тоже не заработало, пишет то же самое:
[gm] Do NOT redirect COM3.
вот лог Raspberry Pi2 model B:
WTware v.5.4.8
WTware v.5.4.8/Pi2 supervisor.
[KERNEL] [ 0.000000] Booting Linux on physical CPU 0xf00
[KERNEL] [ 0.000000] Linux version 4.1.11+ (aka@c12) (gcc version 5.2.1 20151010 (Ubuntu 5.2.1-22ubuntu1) ) #30 SMP PREEMPT Mon Dec 7 12:56:59 SAMT 2015
[KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[KERNEL] [ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[KERNEL] [ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[KERNEL] [ 0.000000] Memory policy: Data cache writealloc
[KERNEL] [ 0.000000] On node 0 totalpages: 241664
[KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80822240, node_mem_map ba092000
[KERNEL] [ 0.000000] Normal zone: 1888 pages used for memmap
[KERNEL] [ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] enter (93c0->f3003010)
[KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[KERNEL] [ 0.000000] PERCPU: Embedded 10 pages/cpu @ba05c000 s10688 r8192 d22080 u40960
[KERNEL] [ 0.000000] pcpu-alloc: s10688 r8192 d22080 u40960 alloc=10*4096
[KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239776
[KERNEL] [ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa21041 bcm2709.serial=0xc1ea1d60 smsc95xx.macaddr=B8:27:EB:EA:1D:60 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 console=ttyAMA0,115200 console=tty1 quiet wtboot=mmc
[KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[KERNEL] [ 0.000000] Memory: 941176K/966656K available (3339K kernel code, 259K rwdata, 1068K rodata, 3632K init, 346K bss, 17288K reserved, 8192K cma-reserved)
[KERNEL] [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[KERNEL] [ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[KERNEL] [ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
[KERNEL] [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[KERNEL] [ 0.000000] .text : 0x80008000 - 0x80455fc4 (4408 kB)
[KERNEL] [ 0.000000] .init : 0x80456000 - 0x807e2000 (3632 kB)
[KERNEL] [ 0.000000] .data : 0x807e2000 - 0x80822e78 ( 260 kB)
[KERNEL] [ 0.000000] .bss : 0x80825000 - 0x8087bba8 ( 347 kB)
[KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[KERNEL] [ 0.000000] NR_IRQS:608
[KERNEL] [ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[KERNEL] [ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[KERNEL] [ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[KERNEL] [ 0.000029] Switching to timer-based delay loop, resolution 52ns
[KERNEL] [ 0.000227] Console: colour dummy device 80x30
[KERNEL] [ 0.000430] console [tty1] enabled
[KERNEL] [ 0.000457] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[KERNEL] [ 0.000478] pid_max: default: 32768 minimum: 301
[KERNEL] [ 0.000614] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[KERNEL] [ 0.000632] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[KERNEL] [ 0.001635] CPU: Testing write buffer coherency: ok
[KERNEL] [ 0.002182] CPU0: update cpu_capacity 1024
[KERNEL] [ 0.002202] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[KERNEL] [ 0.002215] [bcm2709_smp_prepare_cpus] enter
[KERNEL] [ 0.002309] Setting up static identity map for 0x8240 - 0x8274
[KERNEL] [ 0.060287] [bcm2709_boot_secondary] cpu:1 started (0) 18
[KERNEL] [ 0.060652] [bcm2709_secondary_init] enter cpu:1
[KERNEL] [ 0.060701] CPU1: update cpu_capacity 1024
[KERNEL] [ 0.060709] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[KERNEL] [ 0.080234] [bcm2709_boot_secondary] cpu:2 started (0) 16
[KERNEL] [ 0.080515] [bcm2709_secondary_init] enter cpu:2
[KERNEL] [ 0.080543] CPU2: update cpu_capacity 1024
[KERNEL] [ 0.080551] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[KERNEL] [ 0.100274] [bcm2709_boot_secondary] cpu:3 started (0) 16
[KERNEL] [ 0.100529] [bcm2709_secondary_init] enter cpu:3
[KERNEL] [ 0.100556] CPU3: update cpu_capacity 1024
[KERNEL] [ 0.100564] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[KERNEL] [ 0.100637] Brought up 4 CPUs
[KERNEL] [ 0.100664] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[KERNEL] [ 0.100674] CPU: All CPU(s) started in HYP mode.
[KERNEL] [ 0.100683] CPU: Virtualization extensions available.
[KERNEL] [ 0.101308] devtmpfs: initialized
[KERNEL] [ 0.123286] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[KERNEL] [ 0.123873] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[KERNEL] [ 0.124379] pinctrl core: initialized pinctrl subsystem
[KERNEL] [ 0.124945] NET: Registered protocol family 16
[KERNEL] [ 0.130433] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[KERNEL] [ 0.131470] bcm2709.uart_clock = 3000000
[KERNEL] [ 0.138578] Serial: AMBA PL011 UART driver
[KERNEL] [ 0.138768] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[KERNEL] [ 0.139117] console [ttyAMA0] enabled
[KERNEL] [ 0.139781] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[KERNEL] [ 0.211776] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[KERNEL] [ 0.211824] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[KERNEL] [ 0.213012] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[KERNEL] [ 0.213033] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[KERNEL] [ 0.213696] usbcore: registered new interface driver usbfs
[KERNEL] [ 0.213874] usbcore: registered new interface driver hub
[KERNEL] [ 0.214078] usbcore: registered new device driver usb
[KERNEL] [ 0.214666] raspberrypi-firmware soc:firmware: Attached to firmware from 2015-10-23 16:24
[KERNEL] [ 0.242893] Switched to clocksource arch_sys_counter
[KERNEL] [ 0.260333] NET: Registered protocol family 2
[KERNEL] [ 0.261256] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[KERNEL] [ 0.261396] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[KERNEL] [ 0.261588] TCP: Hash tables configured (established 8192 bind 8192)
[KERNEL] [ 0.261707] UDP hash table entries: 512 (order: 2, 16384 bytes)
[KERNEL] [ 0.261772] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[KERNEL] [ 0.262070] NET: Registered protocol family 1
[KERNEL] [ 2.589439] futex hash table entries: 1024 (order: 4, 65536 bytes)
[KERNEL] [ 2.589636] audit: initializing netlink subsys (disabled)
[KERNEL] [ 2.589739] audit: type=2000 audit(2.579:1): initialized
[KERNEL] [ 2.646754] alg: No test for stdrng (krng)
[KERNEL] [ 2.647740] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[KERNEL] [ 2.647766] io scheduler noop registered
[KERNEL] [ 2.647818] io scheduler cfq registered (default)
[KERNEL] [ 2.650476] BCM2708FB: allocated DMA memory fac00000
[KERNEL] [ 2.650538] BCM2708FB: allocated DMA channel 0 @ f3007000
[KERNEL] [ 2.686158] Console: switching to colour frame buffer device 240x67
[KERNEL] [ 2.708738] bcm2708_rng_init=bb906000
[KERNEL] [ 3.598977] vc-cma: Videocore CMA driver
[KERNEL] [ 3.599003] vc-cma: vc_cma_base = 0x00000000
[KERNEL] [ 3.599017] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[KERNEL] [ 3.599028] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[KERNEL] [ 3.599380] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[KERNEL] [ 3.601233] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[KERNEL] [ 3.607431] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[KERNEL] [ 3.807795] Core Release: 2.80a
[KERNEL] [ 3.807826] Setting default values for core params
[KERNEL] [ 3.807867] Finished setting default values for core params
[KERNEL] [ 4.008340] Using Buffer DMA mode
[KERNEL] [ 4.008364] Periodic Transfer Interrupt Enhancement - disabled
[KERNEL] [ 4.008374] Multiprocessor Interrupt Enhancement - disabled
[KERNEL] [ 4.008385] OTG VER PARAM: 0, OTG VER FLAG: 0
[KERNEL] [ 4.008402] Dedicated Tx FIFOs mode
[KERNEL] [ 4.008924] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[KERNEL] [ 4.008964] FIQ FSM acceleration enabled for :
[KERNEL] [ 4.008964] Non-periodic Split Transactions
[KERNEL] [ 4.008964] Periodic Split Transactions
[KERNEL] [ 4.008964] High-Speed Isochronous Endpoints
[KERNEL] [ 4.008989] dwc_otg: Microframe scheduler enabled
[KERNEL] [ 4.009055] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80216818
[KERNEL] [ 4.009073] WARN::hcd_init_fiq:413: FIQ ASM at 0x80216b7c length 36
[KERNEL] [ 4.009091] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb908000
[KERNEL] [ 4.009136] dwc_otg 3f980000.usb: DWC OTG Controller
[KERNEL] [ 4.009188] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[KERNEL] [ 4.009234] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[KERNEL] [ 4.009286] Init: Port Power? op_state=1
[KERNEL] [ 4.009296] Init: Power Port (0)
[KERNEL] [ 4.009538] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[KERNEL] [ 4.009558] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 4.009573] usb usb1: Product: DWC OTG Controller
[KERNEL] [ 4.009588] usb usb1: Manufacturer: Linux 4.1.11+ dwc_otg_hcd
[KERNEL] [ 4.009602] usb usb1: SerialNumber: 3f980000.usb
[KERNEL] [ 4.010707] hub 1-0:1.0: USB hub found
[KERNEL] [ 4.010799] hub 1-0:1.0: 1 port detected
[KERNEL] [ 4.011573] dwc_otg: FIQ enabled
[KERNEL] [ 4.011592] dwc_otg: NAK holdoff enabled
[KERNEL] [ 4.011602] dwc_otg: FIQ split-transaction FSM enabled
[KERNEL] [ 4.011654] Module dwc_common_port init
[KERNEL] [ 4.012815] bcm2835-cpufreq: min=600000 max=900000
[KERNEL] [ 4.015715] hidraw: raw HID events driver (C) Jiri Kosina
[KERNEL] [ 4.017528] usbcore: registered new interface driver usbhid
[KERNEL] [ 4.017545] usbhid: USB HID core driver
[KERNEL] [ 4.017792] NET: Registered protocol family 17
[KERNEL] [ 4.018086] Registering SWP/SWPB emulation handler
[KERNEL] [ 4.019176] registered taskstats version 1
[KERNEL] [ 4.019271] vc-sm: Videocore shared memory driver
[KERNEL] [ 4.019287] [vc_sm_connected_init]: start
[KERNEL] [ 4.027018] [vc_sm_connected_init]: end - returning 0
[KERNEL] [ 4.032549] Freeing unused kernel memory: 3632K (80456000 - 807e2000)
[KERNEL] [ 4.203027] Indeed it is in host mode hprt0 = 00021501
[pfac] Ok, PID 492.
[initrd] WTware shell v.5.4.8/Pi2
[initrd] Local media boot.
[KERNEL] [ 4.382952] usb 1-1: new high-speed USB device number 2 using dwc_otg
[KERNEL] [ 4.383101] Indeed it is in host mode hprt0 = 00001101
[initrd] USB boot.
[KERNEL] [ 4.583144] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[KERNEL] [ 4.583163] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[KERNEL] [ 4.583811] hub 1-1:1.0: USB hub found
[KERNEL] [ 4.583933] hub 1-1:1.0: 5 ports detected
[KERNEL] [ 4.862933] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[KERNEL] [ 4.963247] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[KERNEL] [ 4.963271] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[KERNEL] [ 5.042949] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[KERNEL] [ 5.173195] usb 1-1.2: New USB device found, idVendor=0403, idProduct=1234
[KERNEL] [ 5.173217] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[KERNEL] [ 5.173233] usb 1-1.2: Product: USB IronLogic RFID Adapter
[KERNEL] [ 5.173248] usb 1-1.2: Manufacturer: ILogic
[KERNEL] [ 5.173264] usb 1-1.2: SerialNumber: IL01R3L3
[KERNEL] [ 5.262934] usb 1-1.4: new low-speed USB device number 5 using dwc_otg
[KERNEL] [ 5.381345] usb 1-1.4: New USB device found, idVendor=1c4f, idProduct=0026
[KERNEL] [ 5.381367] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[KERNEL] [ 5.381383] usb 1-1.4: Product: USB Keyboard
[KERNEL] [ 5.381398] usb 1-1.4: Manufacturer: SIGMACHIP
[KERNEL] [ 5.393180] input: SIGMACHIP USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:1C4F:0026.0001/input/input0
[KERNEL] [ 5.453533] hid-generic 0003:1C4F:0026.0001: input,hidraw0: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-3f980000.usb-1.4/input0
[KERNEL] [ 5.464945] input: SIGMACHIP USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:1C4F:0026.0002/input/input1
[KERNEL] [ 5.523492] hid-generic 0003:1C4F:0026.0002: input,hidraw1: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-3f980000.usb-1.4/input1
[KERNEL] [ 5.602957] usb 1-1.5: new low-speed USB device number 6 using dwc_otg
[KERNEL] [ 5.731091] usb 1-1.5: New USB device found, idVendor=0458, idProduct=003a
[KERNEL] [ 5.731148] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[KERNEL] [ 5.731171] usb 1-1.5: Manufacturer: Genius
[KERNEL] [ 5.742657] input: Genius as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:0458:003A.0003/input/input2
[KERNEL] [ 5.743240] hid-generic 0003:0458:003A.0003: input,hidraw2: USB HID v1.10 Mouse [Genius] on usb-3f980000.usb-1.5/input0
[initrd] Load MMC driver.
[initrd] modprobe mmc_block.
[initrd] modprobe bcm2835-mmc.
[KERNEL] [ 5.786942] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[KERNEL] [ 5.786972] mmc-bcm2835 3f300000.mmc: Forcing PIO mode
[KERNEL] [ 5.860346] mmc0: host does not support reading read-only switch, assuming write-enable
[KERNEL] [ 5.862491] mmc0: new high speed SDHC card at address 1234
[KERNEL] [ 5.863457] mmcblk0: mmc0:1234 SA04G 3.70 GiB
[KERNEL] [ 5.864948] mmcblk0: p1
[hotplug] Block device 179:1. No action.
[hotplug] Block device 179:0. No action.
| clientIP = 192.168.0.4
| netmask = 255.255.255.0
| routerIP = 192.168.0.1
| nameserverIP = 192.168.0.1
| config = local
[initrd] modprobe smsc95xx.
[KERNEL] [ 6.686572] smsc95xx v1.0.4
[KERNEL] [ 6.747301] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:ea:1d:60
[KERNEL] [ 6.747702] usbcore: registered new interface driver smsc95xx
[KERNEL] [ 6.805500] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[KERNEL] [ 8.248570] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
| [BOM]
| server=192.168.0.1
| connection
| [BOM]
| server=192.168.0.1
| connection
[initrd] Hostname: "wtwB827EBEA1D60".
[gm] WTware session manager v.5.4.8/Pi2.
[gm] EV_REL flag found. Add mouse event2: Genius.
[gm] Add keyboard event1: SIGMACHIP USB Keyboard.
[gm] Add keyboard event0: SIGMACHIP USB Keyboard.
[gm] Display mode: 1920x1080, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
[gm] Framebuffer device found.
[gm] LINELENBYTES 3840
[gm] VLEN 4147200
[pfac] Got command line /sbin/rdpdr[serial] 0.
[pfac] Ok, PID 561.
[rdpdr-serial 0] RDP Serial Port Redirector, WTware v.5.4.8/Pi2, device ttyUSB0.
[KERNEL] [ 8.458701] usbcore: registered new interface driver usbserial
[KERNEL] [ 8.458807] usbcore: registered new interface driver usbserial_generic
[KERNEL] [ 8.458898] usbserial: USB Serial support registered for generic
[KERNEL] [ 8.470151] usbcore: registered new interface driver pl2303
[KERNEL] [ 8.470342] usbserial: USB Serial support registered for pl2303
[KERNEL] [ 8.483577] usbcore: registered new interface driver ftdi_sio
[KERNEL] [ 8.483783] usbserial: USB Serial support registered for FTDI USB Serial Device
[KERNEL] [ 8.494249] usbcore: registered new interface driver cp210x
[KERNEL] [ 8.494366] usbserial: USB Serial support registered for cp210x
[KERNEL] [ 8.504131] usbcore: registered new interface driver ch341
[KERNEL] [ 8.504346] usbserial: USB Serial support registered for ch341-uart
[KERNEL] [ 8.513996] usbcore: registered new interface driver metro_usb
[KERNEL] [ 8.514116] usbserial: USB Serial support registered for Metrologic USB to Serial
[KERNEL] [ 8.523952] usbcore: registered new interface driver symbolserial
[KERNEL] [ 8.524162] usbserial: USB Serial support registered for symbol
[KERNEL] [ 8.533735] usbcore: registered new interface driver opticon
[KERNEL] [ 8.533868] usbserial: USB Serial support registered for opticon
[pfac] Got command line /sbin/resolver 0x860970 dns [192.168.0.1].
[pfac] Ok, PID 604.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 927232 Kb.
[pfac] Process pid 604 terminated, status 00000000.
[pfac] Ok, PID 606.
[rdpclient 606] RDP Terminal Client, WTware v.5.4.8/Pi2, pipe 1, pid 606.
[rdpclient 606] Make RDP session with 192.168.0.1, port 3389.
[rdpclient 606] No username.
[rdpclient 606] No password.
[rdpclient 606] No PIN.
[rdpclient 606] No domain.
[rdpclient 606] No shell.
[rdpclient 606] No directory.
[rdpclient 606] Window: 1920x1080@16.
[rdpclient 606] PFlags 0x0000002F.
[rdpclient 606] Keyboard 00000409:00000000.
[rdpclient 606] My hostname "4".
[rdpclient 606] TCP: connecting to 192.168.0.1:3389.
[rdpclient 606] TCP: connection with 192.168.0.1:3389 established.
[rdpclient 606] Turn keepalive on.
[rdpclient 606] Free ram after buffers allocation: 926784 KB.
[rdpclient 606] Process RDP server certificate.
[rdpclient 606] RDP5 encryption (X.509).
[KERNEL] [ 8.617293] random: rdpclient urandom read with 119 bits of entropy available
[KERNEL] [ 9.229514] random: nonblocking pool is initialized
Сообщение aka » Пн дек 21, 2015 4:46 pm
Загадочно.
Напиши так:
serial=com3(usb)
Что будет?
Сообщение aka » Вт дек 22, 2015 4:55 pm
И вот это попробуй:
http://pxe.ru/files/testing/201512220322.zip
Странно. Вроде всё правильно, железку на USB видит, драйвер взлетает.
Сообщение Гость » Вт дек 22, 2015 4:59 pm
Не мапится, в конце говорит:
[rdpclient 605] RDP Terminal Client, WTware v.5.4.8/Pi2, pipe 1, pid 605.
[rdpclient 605] Add serial redirection, COM3 in the session = hardware ttyUSB0.
[rdpdr-serial 0] New client connection, id 1.
[rdpclient 605] Make RDP session with 192.168.0.1, port 3389.
[rdpclient 605] Username: "user".
[rdpclient 605] No password.
[rdpclient 605] No PIN.
[rdpclient 605] Domain: "domain".
[rdpclient 605] No shell.
[rdpclient 605] No directory.
[rdpclient 605] Window: 1360x768@16.
[rdpclient 605] PFlags 0x0000002F.
[rdpclient 605] Keyboard 00000409:00000000.
[rdpclient 605] My hostname "4".
[rdpclient 605] TCP: connecting to 192.168.0.1:3389.
[rdpclient 605] TCP: connection with 192.168.0.1:3389 established.
[rdpclient 605] Turn keepalive on.
[rdpclient 605] Free ram after buffers allocation: 928640 KB.
[rdpclient 605] Process RDP server certificate.
[rdpclient 605] RDP5 encryption (X.509).
[KERNEL] [ 8.253482] random: rdpclient urandom read with 114 bits of entropy available
[KERNEL] [ 9.393221] random: nonblocking pool is initialized
[rdpclient 605] SessionId 0x00000005: DOMAIN\user.
[rdpdr-serial 0] rdpdr[serial]-worker.cpp ( 626): -- ERROR -- Failed to open /dev/ttyUSB0, errno 2.
bannedspam
Сообщение bannedspam » Вт дек 22, 2015 5:21 pm
на http://pxe.ru/files/testing/201512220322.zip та же ошибка:
[rdpclient 609] [ 60.673968] RDP Terminal Client, WTware v.5.4.9/Pi2, pipe 1, pid 609.
[ gm] [ 60.674524] COM3 => ttyUSB0.
[rdpclient 609] [ 60.676191] Add serial redirection, COM3 in the session = hardware ttyUSB0.
[rdpdr-serial 0] [ 60.676715] New client connection, id 1.
[rdpclient 609] [ 60.676993] Make RDP session with 192.168.0.1, port 3389.
[rdpclient 609] [ 60.677119] No username.
[rdpclient 609] [ 60.677232] No password.
[rdpclient 609] [ 60.677341] No PIN.
[rdpclient 609] [ 60.677451] No domain.
[rdpclient 609] [ 60.677562] No shell.
[rdpclient 609] [ 60.677671] No directory.
[rdpclient 609] [ 60.677781] Window: 1920x1080@16.
[rdpclient 609] [ 60.677936] PFlags 0x0000002F.
[rdpclient 609] [ 60.678051] Keyboard 00000409:00000000.
[rdpclient 609] [ 60.678158] My hostname "4".
[rdpclient 609] [ 60.678271] TCP: connecting to 192.168.0.1:3389.
[rdpclient 609] [ 60.679196] TCP: connection with 192.168.0.1:3389 established.
[rdpclient 609] [ 60.679350] Turn keepalive on.
[rdpclient 609] [ 60.680457] Free ram after buffers allocation: 926304 KB.
[rdpclient 609] [ 60.682019] Process RDP server certificate.
[rdpclient 609] [ 60.682179] RDP5 encryption (X.509).
[rdpclient 609] [ 67. 38603] SessionId 0x00000005: DOMAIN\user.
[rdpdr-serial 0] [ 76.369087] rdpdr[serial]-worker.cpp ( 626): -- ERROR -- Failed to open /dev/ttyUSB0, errno 2.
Сообщение aka » Вт дек 22, 2015 11:15 pm
bannedspam
Сообщение bannedspam » Чт дек 24, 2015 1:15 pm
http://pxe.ru/files/testing/201512230014.zip - отлично работает! ...и мапится, и данные передаются, и ошибок нет, все ок, спасибо!
