smartcard
RoR
smartcard
Сообщение RoR » Чт окт 29, 2015 1:41 pm
загрузка с SD
Не Удается подключится к удаленному серверу при добавлении параметра smartcard=etoken,rutoken
Как решить проблему, ключ нужен для работы
config
timezone=N. Central Asia Standard Time
turnoffmenu=on
connection Ivanova Ekaterina
server=10.1.1.154
connection main-fs
server=10.1.1.200
connection RoR
server=flint.laximo.local
log
[rdpclient 566] RDP Terminal Client, WTware v.5.3.10/Pi2, pipe 1, pid 566.
[rdpclient 566] Add smartcard redirection.
[rdpclient 566] rdpclient-vchan-rdpdr.cpp ( 1364): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 566] Make RDP session with 10.1.1.154, port 3389.
[rdpclient 566] No username.
[rdpclient 566] No password.
[rdpclient 566] No PIN.
[rdpclient 566] No domain.
[rdpclient 566] No shell.
[rdpclient 566] No directory.
[rdpclient 566] Window: 1920x1080@16.
[rdpclient 566] PFlags 0x0000002F.
[rdpclient 566] Keyboard 00000409:00000000.
[rdpclient 566] My hostname "wtwB827EB7BBAB8".
[rdpclient 566] TCP: connecting to 10.1.1.154:3389.
[rdpclient 566] TCP: connection with 10.1.1.154:3389 established.
[rdpclient 566] Turn keepalive on.
[rdpclient 566] Free ram after buffers allocation: 924240 KB.
[rdpclient 566] Process RDP server certificate.
[rdpclient 566] RDP4 encryption.
[rdpclient 566] Timezone "(UTC+06:00) Almaty, Novosibirsk".
[rdpclient 566] rdpclient-connect.cpp ( 2641): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 566] I'm tired.
[rdpclient 566] Caught signal SIGTERM.
Re: smartcard
Сообщение aka » Чт окт 29, 2015 3:18 pm
Покажи лог целиком, с самого начала и до подключения к виндовсу.
RoR
Re: smartcard
Сообщение RoR » Пт окт 30, 2015 2:37 pm
WTware v.5.3.10
WTware v.5.3.10/Pi2 supervisor.
WTC listener is active.
HTTPd listener is active.
[KERNEL] [ 0.000000] Booting Linux on physical CPU 0xf00
[KERNEL] [ 0.000000] Linux version 4.1.10+ (aka@c12) (gcc version 4.9.2 (Ubuntu/Linaro 4.9.2-10ubuntu10) ) #14 SMP PREEMPT Fri Oct 16 20:06:20 SAMT 2015
[KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[KERNEL] [ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[KERNEL] [ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[KERNEL] [ 0.000000] Memory policy: Data cache writealloc
[KERNEL] [ 0.000000] On node 0 totalpages: 241664
[KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 8082e2c0, node_mem_map ba092000
[KERNEL] [ 0.000000] Normal zone: 1888 pages used for memmap
[KERNEL] [ 0.000000] Normal zone: 0 pages reserved
[KERNEL] [ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] enter (93c0->f3003010)
[KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[KERNEL] [ 0.000000] PERCPU: Embedded 10 pages/cpu @ba05c000 s10688 r8192 d22080 u40960
[KERNEL] [ 0.000000] pcpu-alloc: s10688 r8192 d22080 u40960 alloc=10*4096
[KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239776
[KERNEL] [ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa01041 bcm2709.serial=0x8b7bbab8 smsc95xx.macaddr=B8:27:EB:7B:BA:B8 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 console=ttyAMA0,115200 console=tty1 quiet wtboot=mmc
[KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[KERNEL] [ 0.000000] Memory: 941128K/966656K available (3331K kernel code, 259K rwdata, 1072K rodata, 3684K init, 346K bss, 17336K reserved, 8192K cma-reserved)
[KERNEL] [ 0.000000] Virtual kernel memory layout:
[KERNEL] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[KERNEL] [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[KERNEL] [ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[KERNEL] [ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
[KERNEL] [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[KERNEL] [ 0.000000] .text : 0x80008000 - 0x80454fc4 (4404 kB)
[KERNEL] [ 0.000000] .init : 0x80455000 - 0x807ee000 (3684 kB)
[KERNEL] [ 0.000000] .data : 0x807ee000 - 0x8082eef8 ( 260 kB)
[KERNEL] [ 0.000000] .bss : 0x80831000 - 0x80887bac ( 347 kB)
[KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[KERNEL] [ 0.000000] Preemptible hierarchical RCU implementation.
[KERNEL] [ 0.000000] NR_IRQS:608
[KERNEL] [ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[KERNEL] [ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[KERNEL] [ 0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[KERNEL] [ 0.000032] Switching to timer-based delay loop, resolution 52ns
[KERNEL] [ 0.000235] Console: colour dummy device 80x30
[KERNEL] [ 0.000430] console [tty1] enabled
[KERNEL] [ 0.000463] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[KERNEL] [ 0.000483] pid_max: default: 32768 minimum: 301
[KERNEL] [ 0.000630] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[KERNEL] [ 0.000647] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[KERNEL] [ 0.001673] CPU: Testing write buffer coherency: ok
[KERNEL] [ 0.002208] CPU0: update cpu_capacity 1024
[KERNEL] [ 0.002230] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[KERNEL] [ 0.002245] [bcm2709_smp_prepare_cpus] enter
[KERNEL] [ 0.002336] Setting up static identity map for 0x8240 - 0x8274
[KERNEL] [ 0.060275] [bcm2709_boot_secondary] cpu:1 started (0) 17
[KERNEL] [ 0.060635] [bcm2709_secondary_init] enter cpu:1
[KERNEL] [ 0.060680] CPU1: update cpu_capacity 1024
[KERNEL] [ 0.060687] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[KERNEL] [ 0.080232] [bcm2709_boot_secondary] cpu:2 started (0) 18
[KERNEL] [ 0.080511] [bcm2709_secondary_init] enter cpu:2
[KERNEL] [ 0.080540] CPU2: update cpu_capacity 1024
[KERNEL] [ 0.080547] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[KERNEL] [ 0.100275] [bcm2709_boot_secondary] cpu:3 started (0) 16
[KERNEL] [ 0.100529] [bcm2709_secondary_init] enter cpu:3
[KERNEL] [ 0.100556] CPU3: update cpu_capacity 1024
[KERNEL] [ 0.100563] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[KERNEL] [ 0.100635] Brought up 4 CPUs
[KERNEL] [ 0.100664] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[KERNEL] [ 0.100674] CPU: All CPU(s) started in HYP mode.
[KERNEL] [ 0.100682] CPU: Virtualization extensions available.
[KERNEL] [ 0.101302] devtmpfs: initialized
[KERNEL] [ 0.122494] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[KERNEL] [ 0.123084] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[KERNEL] [ 0.123571] pinctrl core: initialized pinctrl subsystem
[KERNEL] [ 0.124134] NET: Registered protocol family 16
[KERNEL] [ 0.129566] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[KERNEL] [ 0.130652] bcm2709.uart_clock = 3000000
[KERNEL] [ 0.137754] Serial: AMBA PL011 UART driver
[KERNEL] [ 0.137950] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[KERNEL] [ 0.138319] console [ttyAMA0] enabled
[KERNEL] [ 0.138981] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[KERNEL] [ 0.211824] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[KERNEL] [ 0.211871] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[KERNEL] [ 0.213035] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[KERNEL] [ 0.213057] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[KERNEL] [ 0.213747] usbcore: registered new interface driver usbfs
[KERNEL] [ 0.213925] usbcore: registered new interface driver hub
[KERNEL] [ 0.214116] usbcore: registered new device driver usb
[KERNEL] [ 0.214703] raspberrypi-firmware soc:firmware: Attached to firmware from 2015-10-11 16:16
[KERNEL] [ 0.242928] Switched to clocksource arch_sys_counter
[KERNEL] [ 0.260340] NET: Registered protocol family 2
[KERNEL] [ 0.261286] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[KERNEL] [ 0.261424] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[KERNEL] [ 0.261618] TCP: Hash tables configured (established 8192 bind 8192)
[KERNEL] [ 0.261739] UDP hash table entries: 512 (order: 2, 16384 bytes)
[KERNEL] [ 0.261803] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[KERNEL] [ 0.262093] NET: Registered protocol family 1
[KERNEL] [ 2.635156] futex hash table entries: 1024 (order: 4, 65536 bytes)
[KERNEL] [ 2.635387] audit: initializing netlink subsys (disabled)
[KERNEL] [ 2.635523] audit: type=2000 audit(2.629:1): initialized
[KERNEL] [ 2.689626] alg: No test for stdrng (krng)
[KERNEL] [ 2.690737] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[KERNEL] [ 2.690768] io scheduler noop registered
[KERNEL] [ 2.690828] io scheduler cfq registered (default)
[KERNEL] [ 2.693743] BCM2708FB: allocated DMA memory fac00000
[KERNEL] [ 2.693823] BCM2708FB: allocated DMA channel 0 @ f3007000
[KERNEL] [ 2.728954] Console: switching to colour frame buffer device 240x67
[KERNEL] [ 2.751348] bcm2708_rng_init=bb906000
[KERNEL] [ 3.595446] vc-cma: Videocore CMA driver
[KERNEL] [ 3.595473] vc-cma: vc_cma_base = 0x00000000
[KERNEL] [ 3.595484] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[KERNEL] [ 3.595495] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[KERNEL] [ 3.595867] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[KERNEL] [ 3.598016] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[KERNEL] [ 3.603424] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[KERNEL] [ 3.803848] Core Release: 2.80a
[KERNEL] [ 3.803875] Setting default values for core params
[KERNEL] [ 3.803921] Finished setting default values for core params
[KERNEL] [ 4.004380] Using Buffer DMA mode
[KERNEL] [ 4.004409] Periodic Transfer Interrupt Enhancement - disabled
[KERNEL] [ 4.004419] Multiprocessor Interrupt Enhancement - disabled
[KERNEL] [ 4.004430] OTG VER PARAM: 0, OTG VER FLAG: 0
[KERNEL] [ 4.004447] Dedicated Tx FIFOs mode
[KERNEL] [ 4.004974] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[KERNEL] [ 4.005015] FIQ FSM acceleration enabled for :
[KERNEL] [ 4.005015] Non-periodic Split Transactions
[KERNEL] [ 4.005015] Periodic Split Transactions
[KERNEL] [ 4.005015] High-Speed Isochronous Endpoints
[KERNEL] [ 4.005040] dwc_otg: Microframe scheduler enabled
[KERNEL] [ 4.005102] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x802150a8
[KERNEL] [ 4.005119] WARN::hcd_init_fiq:413: FIQ ASM at 0x80215410 length 36
[KERNEL] [ 4.005137] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb908000
[KERNEL] [ 4.005180] dwc_otg 3f980000.usb: DWC OTG Controller
[KERNEL] [ 4.005227] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[KERNEL] [ 4.005272] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[KERNEL] [ 4.005327] Init: Port Power? op_state=1
[KERNEL] [ 4.005338] Init: Power Port (0)
[KERNEL] [ 4.005602] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[KERNEL] [ 4.005621] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 4.005637] usb usb1: Product: DWC OTG Controller
[KERNEL] [ 4.005653] usb usb1: Manufacturer: Linux 4.1.10+ dwc_otg_hcd
[KERNEL] [ 4.005667] usb usb1: SerialNumber: 3f980000.usb
[KERNEL] [ 4.006564] hub 1-0:1.0: USB hub found
[KERNEL] [ 4.006637] hub 1-0:1.0: 1 port detected
[KERNEL] [ 4.007280] dwc_otg: FIQ enabled
[KERNEL] [ 4.007298] dwc_otg: NAK holdoff enabled
[KERNEL] [ 4.007307] dwc_otg: FIQ split-transaction FSM enabled
[KERNEL] [ 4.007363] Module dwc_common_port init
[KERNEL] [ 4.011489] bcm2835-cpufreq: min=600000 max=900000
[KERNEL] [ 4.014444] hidraw: raw HID events driver (C) Jiri Kosina
[KERNEL] [ 4.015882] usbcore: registered new interface driver usbhid
[KERNEL] [ 4.015900] usbhid: USB HID core driver
[KERNEL] [ 4.016195] NET: Registered protocol family 17
[KERNEL] [ 4.016506] Registering SWP/SWPB emulation handler
[KERNEL] [ 4.022695] registered taskstats version 1
[KERNEL] [ 4.022787] vc-sm: Videocore shared memory driver
[KERNEL] [ 4.022802] [vc_sm_connected_init]: start
[KERNEL] [ 4.023638] [vc_sm_connected_init]: end - returning 0
[KERNEL] [ 4.029653] Freeing unused kernel memory: 3684K (80455000 - 807ee000)
[KERNEL] [ 4.203107] Indeed it is in host mode hprt0 = 00021501
[pfac] Ok, PID 492.
[initrd] WTware shell v.5.3.10/Pi2
[initrd] Local media boot.
[KERNEL] [ 4.382986] usb 1-1: new high-speed USB device number 2 using dwc_otg
[KERNEL] [ 4.383135] Indeed it is in host mode hprt0 = 00001101
[initrd] USB boot.
[KERNEL] [ 4.583177] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[KERNEL] [ 4.583199] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[KERNEL] [ 4.583866] hub 1-1:1.0: USB hub found
[KERNEL] [ 4.584003] hub 1-1:1.0: 5 ports detected
[KERNEL] [ 4.862974] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[KERNEL] [ 4.963264] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[KERNEL] [ 4.963289] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[KERNEL] [ 5.042986] usb 1-1.5: new full-speed USB device number 4 using dwc_otg
[KERNEL] [ 5.147850] usb 1-1.5: New USB device found, idVendor=046d, idProduct=c534
[KERNEL] [ 5.147874] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[KERNEL] [ 5.147890] usb 1-1.5: Product: USB Receiver
[KERNEL] [ 5.147905] usb 1-1.5: Manufacturer: Logitech
[KERNEL] [ 5.158402] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:046D:C534.0001/input/input0
[KERNEL] [ 5.213553] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3f980000.usb-1.5/input0
[KERNEL] [ 5.223493] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:046D:C534.0002/input/input1
[KERNEL] [ 5.283847] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3f980000.usb-1.5/input1
[initrd] Load UTF8 charset.
[initrd] modprobe nls_cp437.
[initrd] modprobe nls_utf8.
[initrd] Load VFAT filesystem driver.
[initrd] modprobe fat.
[initrd] modprobe vfat.
[initrd] Load MMC driver.
[initrd] modprobe mmc_block.
[initrd] modprobe bcm2835-mmc.
[KERNEL] [ 5.458428] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[KERNEL] [ 5.458462] mmc-bcm2835 3f300000.mmc: Forcing PIO mode
[KERNEL] [ 5.530377] mmc0: host does not support reading read-only switch, assuming write-enable
[KERNEL] [ 5.532506] mmc0: new high speed SDHC card at address 0001
[KERNEL] [ 5.533194] mmcblk0: mmc0:0001 SD32G 29.5 GiB
[KERNEL] [ 5.535356] mmcblk0: p1
[hotplug] Block device 179:0. No action.
[hotplug] Block device 179:1. No action.
[initrd] WTpassword empty.
| [BOM]
| clientIP=*
| config=local
| netmedia=ethernet
[initrd] Load ethernet drivers.
[initrd] modprobe smsc95xx.
[KERNEL] [ 6.366638] smsc95xx v1.0.4
[KERNEL] [ 6.427251] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:7b:ba:b8
[KERNEL] [ 6.427646] usbcore: registered new interface driver smsc95xx
[KERNEL] [ 6.485324] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[KERNEL] [ 7.889122] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[initrd] dhcp: 333 bytes from 10.1.1.200.
[initrd] 00000000:0000013900000000001100000a0101c8ffffffff004300440139000002010600 ...9................C.D.9......
[initrd] 00000020:67458b6b00000000000000000a0101340a0101c800000000b827eb7bbab80000 gE.k...........4.........'.{....
[initrd] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[initrd] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[initrd] 00000020:67458b6b00000000000000000a0101340000000000000000b827eb7bbab80000 gE.k...........4.........'.{....
[initrd] dhcp: server address 10.1.1.200.
[initrd] dhcp: 10.1.1.52/255.255.255.0.
[initrd] dhcp: default gateway 10.1.1.254.
[initrd] dhcp: DNS 10.1.1.201.
[initrd] dhcp: DNS 10.1.1.200.
[initrd] dhcp: domain laximo.local.
[initrd] dhcp: TFTP from siaddr 10.1.1.200.
[initrd] dhcp: TFTP 10.1.1.200.
[initrd] No boot file from DHCP.
[initrd] TFTP binary "", configs prefix "", using "/" slash.
Send broadcast WTCU discover.
[initrd] Common local disk config:
| [BOM]
| turnoffmenu=on
| server=10.1.1.154
| connection main-fs
| server=10.1.1.200
| connection RoR
| [BOM]
| turnoffmenu=on
| server=10.1.1.154
| connection main-fs
| server=10.1.1.200
| connection RoR
[initrd] Hostname: "wtwB827EB7BBAB8".
RSH: listener is active.
[gm] WTware session manager v.5.3.10/Pi2.
[gm] Add keyboard event1: Logitech USB Receiver.
[gm] Add keyboard event0: Logitech USB Receiver.
[gm] Display mode: 1920x1080, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
[gm] Framebuffer device found.
[gm] LINELENBYTES 3840
[gm] VLEN 4147200
[gm] execve failed
[gm] globalConfig.cpp ( 1902): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[pfac] Got command line /sbin/rdpdr[scard].
[pfac] Ok, PID 557.
[SCARD] close kotopipe (n = 0, errno 0).
[pfac] Process pid 557 terminated, status 00007f00.
[gm] /graphic/winlg.png: 48x48.
[gm] /graphic/winsm.png: 38x38.
[gm] /graphic/offsm.png: 28x31.
[gm] Nobody can control terminal by VNC.
[KERNEL] [ 11.447588] random: nonblocking pool is initialized
[pfac] Got command line /sbin/resolver 0x691e98 dns [10.1.1.154].
[pfac] Ok, PID 565.
[gm] 10.1.1.154 => 10.1.1.154.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 927576 Kb.
[pfac] Process pid 565 terminated, status 00000000.
[pfac] Ok, PID 566.
[rdpclient 566] Got EHOSTUNREACH.
[rdpclient 566] fstream.cpp ( 499): -- ERROR -- Conection with 10.1.1.154:3389 failed, errno 113.
[rdpclient 566] rdpclient-tcp.cpp ( 260): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 566] Сервер 10.1.1.154, порт 3389: отказано в подключении.
Убедитесь, что на этом сервере работает служба терминалов
и попробуйте подключиться к ней стандартным клиентом
службы терминалов mstsc.exe.
[pfac] Process pid 566 terminated, status 00000000.
[gm] Final message: Сервер 10.1.1.154, порт 3389: отказано в подключении.
[gm] /graphic/exlm.png: 44x42.
[pfac] Ok, PID 567.
[pfac] Process pid 567 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 2): 927412 Kb.
[pfac] Got command line /sbin/rdpclient 2.
[pfac] Ok, PID 568.
[rdpclient 568] RDP Terminal Client, WTware v.5.3.10/Pi2, pipe 2, pid 568.
[rdpclient 568] Add smartcard redirection.
[rdpclient 568] rdpclient-vchan-rdpdr.cpp ( 1364): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 568] Make RDP session with 10.1.1.154, port 3389.
[rdpclient 568] No username.
[rdpclient 568] No password.
[rdpclient 568] No PIN.
[rdpclient 568] No domain.
[rdpclient 568] No shell.
[rdpclient 568] No directory.
[rdpclient 568] Window: 1920x1080@16.
[rdpclient 568] PFlags 0x0000002F.
[rdpclient 568] Keyboard 00000409:00000000.
[rdpclient 568] My hostname "wtwB827EB7BBAB8".
[rdpclient 568] TCP: connecting to 10.1.1.154:3389.
[rdpclient 568] TCP: connection with 10.1.1.154:3389 established.
[rdpclient 568] Turn keepalive on.
[rdpclient 568] Free ram after buffers allocation: 924024 KB.
[rdpclient 568] Process RDP server certificate.
[rdpclient 568] RDP4 encryption.
[rdpclient 568] Timezone "(UTC+06:00) Almaty, Novosibirsk".
[rdpclient 568] rdpclient-connect.cpp ( 2641): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 568] I'm tired.
[rdpclient 568] Caught signal SIGTERM.
[RDP] close kotopipe (n = 0, errno 2).
[pfac] Process pid 568 terminated, status 00000000.
[gm] Final message: I'm tired.
Home WTware diskless client.
Re: smartcard
Сообщение aka » Вс ноя 01, 2015 2:04 am
Так потому что Pi2. Перенаправление смарт-карт на Pi2 ещё не перенесли. На Pi2 ещё много всего не перенесли. Сделаем попозже.
Re: smartcard
Сообщение Гость » Пн ноя 02, 2015 9:41 am
Большое спасибо за оперативность!
RoR
Re: smartcard
Сообщение RoR » Пн ноя 02, 2015 9:47 am
А какие функции реализованы на малине???
Re: smartcard
Сообщение aka » Пн ноя 02, 2015 5:55 pm
Звук, принтеры через printer= и rdp_printer=, диски через disk=, ком-порты usb-com мостами через serial= уже должны работать.
ВАся
Re: smartcard
Сообщение ВАся » Пт дек 11, 2015 8:17 pm
А когда будет поддержка смарт карт???????????????????
Re: smartcard
Сообщение Гость » Ср мар 23, 2016 11:08 am
А когда будет реализована поддержка смарт-кард?
Re: smartcard
Сообщение aka » Вс мар 27, 2016 8:29 pm
Будет. Попозже немного.
Аватара пользователя
Re: smartcard
Сообщение Barvinok » Вт апр 12, 2016 2:55 pm
Стесняюсь спросить, а "немного" - это сколько? :roll:
Re: smartcard
Сообщение aka » Вт апр 12, 2016 3:43 pm
Эээ.. Мм... Ну немного. До лета должно заработать.
Re: smartcard
Сообщение aka » Пн май 02, 2016 1:48 am
Сделано в 5.4.28.
Евгений
Re: smartcard
Сообщение Евгений » Вт ноя 15, 2016 10:52 pm
Уже поздняя осень.
Ждем с нетерпением smartcard.
Спасибо.
Re: smartcard
Сообщение aka » Ср ноя 16, 2016 1:11 pm
Так сделано уже.
