Wtware+windows 8
Добавлено: Вт янв 31, 2017 3:04 pm
sashkaru
Здравствуйте,WTware v.5.4.62, на виртуальной машине поднята windows 8, при загрузке через RDP нормально показывает монитор, на максимальном разрешении, но не запускается по какой-то причине Гранд Смета(ключ прокинут другими средствами), попробовали загрузку по vnc, грандсмета открывается и все норм, но проблема с разрешением экрана, нужное 1920х1080, а показывает только 1024х768. Как исправить?
лог
[ vncclient 922] [ 38.397990] VNC Client, WTware v.5.4.62, pipe 2, pid 922.
[ vncclient 922] [ 38.398151] Use /lib/ui32.so.
[ vncclient 922] [ 38.398205] Make VNC session with 192.168.200.243:5900.
[ vncclient 922] [ 38.398222] TCP: connecting to 192.168.200.243:5900.
[ vncclient 922] [ 38.400951] TCP: connection with 192.168.200.243:5900 established.
[ vncclient 922] [ 38.403373] Server VNC version 3.8.
[ vncclient 922] [ 38.405701] 2 security types.
[ vncclient 922] [ 38.405726] Security code 17 (0x11).
[ vncclient 922] [ 38.405743] Security code 2 (0x02).
[ vncclient 922] [ 38.405759] Use security type 0x00000002.
[ vncclient 922] [ 40.053755] VNC screen 1920x1080, bpp 32 depth 32, low endian true color.
[ vncclient 922] [ 40.053784] Red 00ff, 16. Green 00ff, 8. Blue 00ff, 0.
[ vncclient 922] [ 40.053796] Server name "srv-v0904-2 ( 192.168.200.243 ) - service mode".
[ vncclient 922] [ 40.053807] VNC server require to large resolution 1920x1080.
[ pfac] [ 40.053903] Process pid 922 terminated, status 00000009.
[ gm] [ 40.063936] Final message: VNC server require to large resolution 1920x1080.
[ gm] [ 40.979927] Run '/sbin/resolver 0x819efa0 dns [192.168.200.243]', log '', env '', pid ''.
[ pfac] [ 40.979969] Run /sbin/resolver 0x819efa0 dns [192.168.200.243].
[ pfac] [ 40.980043] Ok, PID 926.
[ pfac] [ 40.980653] Process pid 926 terminated, status 00000000.
[ gm] [ 40.981486] 192.168.200.243 => 192.168.200.243.
[ pfac] [ 40.981513] Run /sbin/vncclient 3.
[ gm] [ 40.981519] Free ram before fork terminal client /sbin/vncclient (session 3): 2967560 Kb.
[ gm] [ 40.981530] Run '/sbin/vncclient 3', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 40.981540] Ok, PID 927.
[ vncclient 927] [ 40.981963] VNC Client, WTware v.5.4.62, pipe 3, pid 927.
[ vncclient 927] [ 40.982127] Use /lib/ui32.so.
[ vncclient 927] [ 40.982179] Make VNC session with 192.168.200.243:5900.
[ vncclient 927] [ 40.982196] TCP: connecting to 192.168.200.243:5900.
[ vncclient 927] [ 40.997162] TCP: connection with 192.168.200.243:5900 established.
[ vncclient 927] [ 41.004152] Server VNC version 3.8.
[ vncclient 927] [ 41.013193] 2 security types.
[ vncclient 927] [ 41.013228] Security code 17 (0x11).
[ vncclient 927] [ 41.013239] Security code 2 (0x02).
[ vncclient 927] [ 41.013248] Use security type 0x00000002.
[ vncclient 927] [ 41.920899] VNC screen 1920x1080, bpp 32 depth 32, low endian true color.
[ vncclient 927] [ 41.920927] Red 00ff, 16. Green 00ff, 8. Blue 00ff, 0.
[ vncclient 927] [ 41.920939] Server name "srv-v0904-2 ( 192.168.200.243 ) - service mode".
[ vncclient 927] [ 41.920950] VNC server require to large resolution 1920x1080.
[ pfac] [ 41.921044] Process pid 927 terminated, status 00000009.
[ gm] [ 41.931080] Final message: VNC server require to large resolution 1920x1080.
[ gm] [ 43.499938] Run '/sbin/resolver 0x819efa0 dns [192.168.200.243]', log '', env '', pid ''.
[ pfac] [ 43.499988] Run /sbin/resolver 0x819efa0 dns [192.168.200.243].
[ pfac] [ 43.500049] Ok, PID 930.
[ pfac] [ 43.500652] Process pid 930 terminated, status 00000000.
[ gm] [ 43.501452] 192.168.200.243 => 192.168.200.243.
[ gm] [ 43.501477] Free ram before fork terminal client /sbin/vncclient (session 4): 2967304 Kb.
[ gm] [ 43.501491] Run '/sbin/vncclient 4', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 43.501554] Run /sbin/vncclient 4.
[ pfac] [ 43.501577] Ok, PID 931.
[ vncclient 931] [ 43.501991] VNC Client, WTware v.5.4.62, pipe 4, pid 931.
[ vncclient 931] [ 43.502068] Use /lib/ui32.so.
[ vncclient 931] [ 43.502088] Make VNC session with 192.168.200.243:5900.
[ vncclient 931] [ 43.502100] TCP: connecting to 192.168.200.243:5900.
[ vncclient 931] [ 43.513068] TCP: connection with 192.168.200.243:5900 established.
[ vncclient 931] [ 43.521000] Server VNC version 3.8.
[ vncclient 931] [ 43.531146] 2 security types.
[ vncclient 931] [ 43.531181] Security code 17 (0x11).
[ vncclient 931] [ 43.531192] Security code 2 (0x02).
[ vncclient 931] [ 43.531200] Use security type 0x00000002.
[ vncclient 931] [ 44.537953] SecurityResult 1.
[ vncclient 931] [ 44.537983] vncclient-main.cpp ( 103): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ vncclient 931] [ 44.537996] vncclient-main.cpp ( 169): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ vncclient 931] [ 44.538007] vncclient-main.cpp ( 500): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ vncclient 931] [ 44.538017] VNC Connection sequence failed. Incorrect password?
[ pfac] [ 44.538106] Process pid 931 terminated, status 00000009.
[ gm] [ 44.548131] Final message: VNC Connection sequence failed. Incorrect password?
Re: Wtware+windows 8
Добавлено: Вт янв 31, 2017 3:06 pm
sashkaru
и при соединении пароль на vnc не с первого раза берет, только со второго.
([ gm] [ 44.548131] Final message: VNC Connection sequence failed. Incorrect password)
Добавлено: Вт янв 31, 2017 4:51 pm
Варианты:
1. Лицензию втвари прописать.
2. Разрешение на сервере поменьше поставить.
VNC клиент в точности копирует экран сервера. Если на сервере 1920х1080, то клиенту надо сделать такое же. Но из-за баннера "ТОЛЬКО ДЛЯ ТЕСТИРОВАНИЯ" 1920 точек по ширине не влазит.
Пришлите МАК терминала на aka@pxe.ru, сделаю лицензию для экспериментов.
Про пароль со второго раза - пришлитепочтой полный лог.
