Добрый день! Сформировали сертификат от 01.01.2016, попробовали. Не цепляется.
Вот лог терминала:
16-57-46-407| [ initrd] [ 8.608842] Run OpenVPN with user config configs/openvpn.cfg.
16-57-46-407| [ initrd] [ 8.612235] Unpack /bootmedia/packages/pi2-dbus.
16-57-46-407| [ KERNEL] [ 8.682474] random: nonblocking pool is initialized
16-57-46-407| [ initrd] [ 8.683427] +--- Executing "/usr/bin/dbus-daemon --system"
16-57-46-407| [ initrd] [ 8.710464] +- Errorlevel: 0, output:
16-57-46-407| File is empty.
16-57-46-407| [ initrd] [ 8.710778] +------------------------
16-57-46-407| [ initrd] [ 8.710911] Unpack /bootmedia/packages/pi2-xnet.
16-57-46-407| [ initrd] [ 9.040831] +--- Executing "/sbin/modprobe tun"
16-57-46-407| [ KERNEL] [ 9.053683] tun: Universal TUN/TAP device driver, 1.6
16-57-46-407| [ KERNEL] [ 9.053703] tun: (C) 1999-2004 Max Krasnyansky <
maxk@qualcomm.com>
16-57-46-407| [ initrd] [ 9.048170] +- Errorlevel: 0, output:
16-57-46-407| [ initrd] [ 9.048457] +------------------------
16-57-46-407| [ initrd] [ 9.048531] +--- Executing "/usr/sbin/openvpn /etc/client.conf"
16-57-46-407| [SYSLOG] <27>Feb 14 00:00:06 openvpn[590]: Options error: Unrecognized option or missing parameter(s) in /etc/client.conf:10: openvpn=192.168.*.* (2.3.10)
16-57-46-407| [SYSLOG] <28>Feb 14 00:00:06 openvpn[590]: Use --help for more information.
16-57-46-407| [ initrd] [ 9.073516] +- Errorlevel: 1, output:
16-57-46-407| [ initrd] [ 9.073750] +------------------------
16-57-46-407| [ initrd] [ 9.073823] ERROR: INTERNAL ERROR
16-57-46-407| WTware v.5.4.78/RPi
16-57-46-407| File: initrdConfig.cpp
16-57-46-407| Line: 372
16-57-46-407| Please, report this information to WTware tech support.
Вот его конфиг:
client
dev tun
proto udp
port 1194
nobind
ns-cert-type server
cipher AES-256-CBC
comp-lzo
daemon
openvpn=192.168.5.106
<ca>
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
</ca>
<cert>
</cert>
<key>
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
</key>
key-direction 1
<tls-auth>
-----BEGIN OpenVPN Static key V1-----
-----END OpenVPN Static key V1-----
</tls-auth>
Обратила на себя внимание запись "openvpn[590]: Options error: Unrecognized option or missing parameter(s) in /etc/client.conf:10: openvpn=192.168.*.* (2.3.10)". Отмечу, что там указан просто локальный ip сервера OpenVPN, без "(2.3.10)". Что здесь неверно?
