AR9271
rquid
AR9271
Сообщение rquid » Сб ноя 18, 2017 6:51 pm
Не хочет поднимать на таком адаптере, выбирает внутренний почему-то.
WTware 5.6.20/RPi supervisor.
[        KERNEL] [    0.000000] Booting Linux on physical CPU 0x0
[        KERNEL] [    0.000000] Linux version 4.9.61 (aka@c12) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #3 SMP Fri Nov 17 03:46:20 +04 2017
[        KERNEL] [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[        KERNEL] [    0.000000] CPU: div instructions available: patching division code
[        KERNEL] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[        KERNEL] [    0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
[        KERNEL] [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
[        KERNEL] [    0.000000] Memory policy: Data cache writealloc
[        KERNEL] [    0.000000] On node 0 totalpages: 242688
[        KERNEL] [    0.000000] free_area_init_node: node 0, pgdat 80b22b40, node_mem_map ba3a1000
[        KERNEL] [    0.000000]   Normal zone: 2133 pages used for memmap
[        KERNEL] [    0.000000]   Normal zone: 0 pages reserved
[        KERNEL] [    0.000000]   Normal zone: 242688 pages, LIFO batch:31
[        KERNEL] [    0.000000] percpu: Embedded 11 pages/cpu @ba367000 s15948 r8192 d20916 u45056
[        KERNEL] [    0.000000] pcpu-alloc: s15948 r8192 d20916 u45056 alloc=11*4096
[        KERNEL] [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[        KERNEL] [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 240555
[        KERNEL] [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  quiet wtboot=mmc usbhid.mousepoll=0
[        KERNEL] [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[        KERNEL] [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[        KERNEL] [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[        KERNEL] [    0.000000] Memory: 942184K/970752K available (5120K kernel code, 143K rwdata, 920K rodata, 4096K init, 365K bss, 20376K reserved, 8192K cma-reserved)
[        KERNEL] [    0.000000] Virtual kernel memory layout:
[        KERNEL] [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[        KERNEL] [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[        KERNEL] [    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
[        KERNEL] [    0.000000]     lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
[        KERNEL] [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
[        KERNEL] [    0.000000]       .text : 0x80008000 - 0x80600000   (6112 kB)
[        KERNEL] [    0.000000]       .init : 0x80700000 - 0x80b00000   (4096 kB)
[        KERNEL] [    0.000000]       .data : 0x80b00000 - 0x80b23df8   ( 144 kB)
[        KERNEL] [    0.000000]        .bss : 0x80b25000 - 0x80b805a0   ( 366 kB)
[        KERNEL] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[        KERNEL] [    0.000000] Hierarchical RCU implementation.
[        KERNEL] [    0.000000] 	Build-time adjustment of leaf fanout to 32.
[        KERNEL] [    0.000000] NR_IRQS:16 nr_irqs:16 16
[        KERNEL] [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[        KERNEL] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[        KERNEL] [    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[        KERNEL] [    0.000016] Switching to timer-based delay loop, resolution 52ns
[        KERNEL] [    0.000207] Console: colour dummy device 80x30
[        KERNEL] [    0.000221] console [tty0] enabled
[        KERNEL] [    0.000238] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[        KERNEL] [    0.000250] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.000382] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.000389] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.001229] Disabling memory control group subsystem
[        KERNEL] [    0.001280] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.001617] CPU0: update cpu_capacity 1024
[        KERNEL] [    0.001624] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[        KERNEL] [    0.001648] Setting up static identity map for 0x100000 - 0x100034
[        KERNEL] [    0.003172] CPU1: update cpu_capacity 1024
[        KERNEL] [    0.003178] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[        KERNEL] [    0.003741] CPU2: update cpu_capacity 1024
[        KERNEL] [    0.003748] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[        KERNEL] [    0.004302] CPU3: update cpu_capacity 1024
[        KERNEL] [    0.004308] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[        KERNEL] [    0.004385] Brought up 4 CPUs
[        KERNEL] [    0.004395] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[        KERNEL] [    0.004399] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.004402] CPU: Virtualization extensions available.
[        KERNEL] [    0.004936] devtmpfs: initialized
[        KERNEL] [    0.014606] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[        KERNEL] [    0.014987] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[        KERNEL] [    0.015002] futex hash table entries: 1024 (order: 4, 65536 bytes)
[        KERNEL] [    0.015486] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.016010] NET: Registered protocol family 16
[        KERNEL] [    0.017878] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.028060] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[        KERNEL] [    0.111160] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[        KERNEL] [    0.113496] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.113624] usbcore: registered new interface driver hub
[        KERNEL] [    0.113708] usbcore: registered new device driver usb
[        KERNEL] [    0.120128] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-11-03 17:00
[        KERNEL] [    0.122428] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.137389] NET: Registered protocol family 2
[        KERNEL] [    0.137962] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.138069] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.138253] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.138337] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138378] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138559] NET: Registered protocol family 1
[        KERNEL] [    2.237366] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[        KERNEL] [    2.273447] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    2.273461] io scheduler noop registered
[        KERNEL] [    2.273466] io scheduler deadline registered (default)
[        KERNEL] [    2.282238] BCM2708FB: allocated DMA memory fad10000
[        KERNEL] [    2.282287] BCM2708FB: allocated DMA channel 0 @ bb80f000
[        KERNEL] [    2.313348] Console: switching to colour frame buffer device 240x67
[        KERNEL] [    2.334121] bcm2835-rng 3f104000.rng: hwrng registered
[        KERNEL] [    2.334378] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    2.335231] vc-sm: Videocore shared memory driver
[        KERNEL] [    2.338258] zram: Added device: zram0
[        KERNEL] [    2.338299] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    2.566434] Core Release: 2.80a
[        KERNEL] [    2.566443] Setting default values for core params
[        KERNEL] [    2.566467] Finished setting default values for core params
[        KERNEL] [    2.766806] Using Buffer DMA mode
[        KERNEL] [    2.766813] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    2.766817] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    2.766822] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    2.766853] Dedicated Tx FIFOs mode
[        KERNEL] [    2.767317] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[        KERNEL] [    2.767340] FIQ FSM acceleration enabled for :
[        KERNEL] [    2.767340] Non-periodic Split Transactions
[        KERNEL] [    2.767340] Periodic Split Transactions
[        KERNEL] [    2.767340] High-Speed Isochronous Endpoints
[        KERNEL] [    2.767340] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    2.767346] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    2.767386] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397c10
[        KERNEL] [    2.767394] WARN::hcd_init_fiq:460: FIQ ASM at 0x80397f74 length 36
[        KERNEL] [    2.767403] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[        KERNEL] [    2.767454] dwc_otg 3f980000.usb: DWC OTG Controller
[        KERNEL] [    2.767485] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[        KERNEL] [    2.767514] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[        KERNEL] [    2.767559] Init: Port Power? op_state=1
[        KERNEL] [    2.767562] Init: Power Port (0)
[        KERNEL] [    2.767738] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[        KERNEL] [    2.767747] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.767755] usb usb1: Product: DWC OTG Controller
[        KERNEL] [    2.767763] usb usb1: Manufacturer: Linux 4.9.61 dwc_otg_hcd
[        KERNEL] [    2.767769] usb usb1: SerialNumber: 3f980000.usb
[        KERNEL] [    2.768495] hub 1-0:1.0: USB hub found
[        KERNEL] [    2.768533] hub 1-0:1.0: 1 port detected
[        KERNEL] [    2.769188] dwc_otg: FIQ enabled
[        KERNEL] [    2.769192] dwc_otg: NAK holdoff enabled
[        KERNEL] [    2.769195] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    2.769208] Module dwc_common_port init
[        KERNEL] [    2.770786] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    2.771977] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[        KERNEL] [    2.772374] bcm2835-cpufreq: min=600000 max=1200000
[        KERNEL] [    2.773587] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[        KERNEL] [    2.775901] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[        KERNEL] [    2.778777] ledtrig-cpu: registered to indicate activity on CPUs
[        KERNEL] [    2.778929] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    2.779688] usbcore: registered new interface driver usbhid
[        KERNEL] [    2.779696] usbhid: USB HID core driver
[        KERNEL] [    2.781454] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[        KERNEL] [    2.787204] [vc_sm_connected_init]: start
[        KERNEL] [    2.794465] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    2.794722] NET: Registered protocol family 17
[        KERNEL] [    2.794869] Registering SWP/SWPB emulation handler
[        KERNEL] [    2.795397] registered taskstats version 1
[        KERNEL] [    2.799469] sdhost: log_buf @ bad07000 (fad07000)
[        KERNEL] [    2.872443] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[        KERNEL] [    2.874563] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[        KERNEL] [    2.874567] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[        KERNEL] [    2.972493] of_cfs_init
[        KERNEL] [    2.972551] of_cfs_init: OK
[        KERNEL] [    2.982580] Freeing unused kernel memory: 4096K
[        KERNEL] [    2.982647] Indeed it is in host mode hprt0 = 00021501
[        KERNEL] [    2.990000] mmc0: host does not support reading read-only switch, assuming write-enable
[        KERNEL] [    3.049432] mmc0: new high speed SDHC card at address aaaa
[        KERNEL] [    3.049905] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[        KERNEL] [    3.051497] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[        KERNEL] [    3.051689]  mmcblk0: p1
[        KERNEL] [    3.053114] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.054614] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.057302] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[        KERNEL] [    3.065482] random: fast init done
[        KERNEL] [    3.146310] mmc1: new high speed SDIO card at address 0001
[        KERNEL] [    3.182570] usb 1-1: new high-speed USB device number 2 using dwc_otg
[        KERNEL] [    3.182701] Indeed it is in host mode hprt0 = 00001101
[       hotplug] [    3.241810] Block device 254:0. No action.
[       hotplug] [    3.351203] Block device 179:1. No action.
[       hotplug] [    3.351309] Block device 179:0. No action.
[          pfac] [    3.364229] Run /sbin/initrd.
[          pfac] [    3.364499] Ok, PID 607.
[        initrd] [    3.368505] WTware shell 5.6.20/RPi
[        initrd] [    3.400231] HDD/MMC/SD boot.
[        KERNEL] [    3.432701] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    3.432713] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.433445] hub 1-1:1.0: USB hub found
[        KERNEL] [    3.434036] hub 1-1:1.0: 5 ports detected
[        KERNEL] [    3.752451] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    3.882674] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    3.882685] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.982469] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
[        KERNEL] [    4.117691] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52b
[        KERNEL] [    4.117702] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.117710] usb 1-1.4: Product: USB Receiver
[        KERNEL] [    4.117718] usb 1-1.4: Manufacturer: Logitech
[        KERNEL] [    4.132899] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.4/input2
[        KERNEL] [    4.280614] input: Logitech M325 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:400A.0004/input/input0
[        KERNEL] [    4.281108] logitech-hidpp-device 0003:046D:400A.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech M325] on usb-3f980000.usb-1.4:1
[        KERNEL] [    4.592466] usb 1-1.2: new low-speed USB device number 5 using dwc_otg
[        KERNEL] [    4.738064] usb 1-1.2: New USB device found, idVendor=1a2c, idProduct=2124
[        KERNEL] [    4.738076] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.738083] usb 1-1.2: Product: USB Keyboard
[        KERNEL] [    4.738090] usb 1-1.2: Manufacturer: SEM
[        KERNEL] [    4.749045] input: SEM USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:1A2C:2124.0005/input/input1
[        KERNEL] [    4.823890] hid-generic 0003:1A2C:2124.0005: input,hidraw2: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-3f980000.usb-1.2/input0
[        KERNEL] [    4.833819] input: SEM USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:1A2C:2124.0006/input/input2
[        KERNEL] [    4.902993] hid-generic 0003:1A2C:2124.0006: input,hidraw3: USB HID v1.10 Device [SEM USB Keyboard] on usb-3f980000.usb-1.2/input1
[        initrd] [    5.184935] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
| # http://www.raspberrypi.org/documentation/configuration/config-txt.md
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=1
| #hdmi_mode=1
| hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| #hdmi_group=2
| # 800x600:   hdmi_mode=9
| # 1024x768:  hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768:  hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900:  hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768:  hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| framebuffer_depth=32
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
[        initrd] [    5.190946] WTpassword present: 3e3c3d6728e97b3f0ba58906973a746d.
[        KERNEL] [    5.202467] usb 1-1.3: new high-speed USB device number 6 using dwc_otg
[        KERNEL] [    5.353066] usb 1-1.3: New USB device found, idVendor=0cf3, idProduct=9271
[        KERNEL] [    5.353078] usb 1-1.3: New USB device strings: Mfr=16, Product=32, SerialNumber=48
[        KERNEL] [    5.353085] usb 1-1.3: Product: UB93
[        KERNEL] [    5.353092] usb 1-1.3: Manufacturer: ATHEROS
[        KERNEL] [    5.353099] usb 1-1.3: SerialNumber: 12345
| [BOM]
| clientIP=*
| config=local
| netmedia=wifi
| setupPassword=
| wifi_ssid=cowondrugs
| wifi_channel=8
| wifi_security=wpa_psk
Skip 'wifi_key='.
[        initrd] [    7.203429] Load WiFi wireless network card driver.
[        initrd] [    7.206671] Unpack /bootmedia/packages/pi2-dbus.
[        initrd] [    7.480838] +--- Executing "/usr/bin/dbus-daemon --system"
[        initrd] [    7.525147] +- Errorlevel: 0, output:
File is empty.
[        initrd] [    7.525838] +------------------------
[        initrd] [    7.525927] Unpack /bootmedia/packages/pi2-xnet.
[        initrd] [    8.183927] Load driver for Pi 3 onboard WiFi.
[        initrd] [    8.184032] modprobe brcmfmac.
[        KERNEL] [    8.283609] brcmfmac: Firmware version = wl0: Aug 29 2016 20:48:16 version 7.45.41.26 (r640327) FWID 01-4527cfab
[        KERNEL] [    8.284241] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.6.3 Inc Compiler: 1.29.4 Inc ClmImport: 1.31.4 Creation: 2016-08-29 20:46:38
[        KERNEL] [    8.298240] random: crng init done
[        KERNEL] [    8.395391] brcmfmac mmc1:0001:1 eth0: renamed from wlan0
/--- FILE "/etc/wpa.conf" -----------------------
| ctrl_interface=/var/run/wpa_supplicant
| network={
Skip 'psk='.
| 	ssid="cowondrugs"
[        KERNEL] [    8.442574] brcmfmac: power management disabled
[        initrd] [    8.443105] +--- Executing "/sbin/wpa_supplicant -B -c /etc/wpa.conf -i eth0 -f /tmp/wpa_supplicant.out"
[           WPA] [    8.451021] Successfully initialized wpa_supplicant
[        KERNEL] [    8.497580] brcmfmac: power management disabled
[           WPA] [    8.658388] Could not read interface p2p-dev-eth0 flags: No such device
[        initrd] [    8.667966] +- Errorlevel: 0, output:
File is empty.
[        initrd] [    8.668396] +------------------------
[        initrd] [    8.672144] State DISCONNECTED before handshake, do nothing.
[        initrd] [    8.978788] State SCANNING before handshake, do nothing.
[           WPA] [    9.158556] eth0: Trying to associate with 64:d1:54:66:a0:2c (SSID='cowondrugs' freq=2447 MHz)
[           WPA] [    9.213380] eth0: Associated with 64:d1:54:66:a0:2c
[           WPA] [    9.222084] eth0: WPA: Key negotiation completed with 64:d1:54:66:a0:2c [PTK=CCMP GTK=CCMP]
[           WPA] [    9.222190] eth0: CTRL-EVENT-CONNECTED - Connection to 64:d1:54:66:a0:2c completed [id=0 id_str=]
[        initrd] [    9.286987] wpa_state=COMPLETED
[        initrd] [    9.287097] WTpassword present: 3e3c3d6728e97b3f0ba58906973a746d.
[        initrd] [   10.510172] dhcp: 328 bytes from 192.168.88.1.
[        initrd] [   10.510357] 00000000:000001340000000000110000C0A85801C0A8580F004300440134000002010600  ...4.........X...X..C.D.4......
[        initrd] [   10.510489] 00000020:67458B6B0000000000000000C0A8580FC0A8580100000000B827EB9B04120000  gE.k..........X...X......'.....
[        initrd] [   10.510618] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.510744] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.510871] 00000080:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.510999] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.511127] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   10.511251] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   12.750154] dhcp: 328 bytes from 192.168.88.1.
[        initrd] [   12.750323] 00000000:000001340000000000110000C0A85801C0A8580F004300440134000002010600  ...4.........X...X..C.D.4......
[        initrd] [   12.750453] 00000020:67458B6B0000000000000000C0A8580FC0A8580100000000B827EB9B04120000  gE.k..........X...X......'.....
[        initrd] [   12.750580] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   12.750707] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   12.750836] 00000080:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   12.750962] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   12.751088] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   12.751213] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   12.790096] dhcp: server address 192.168.88.1.
[        initrd] [   12.790211] dhcp: 192.168.88.15/255.255.255.0.
[        initrd] [   12.790320] dhcp: default gateway 192.168.88.1.
[        initrd] [   12.790428] dhcp: DNS 192.168.88.1.
[        initrd] [   12.790534] dhcp: DNS 213.135.97.131.
[        initrd] [   12.790637] dhcp: DNS 213.135.96.250.
[        initrd] [   12.790747] dhcp: TFTP from siaddr 192.168.88.1.
[        initrd] [   12.790851] dhcp: TFTP 192.168.88.1.
[        initrd] [   12.790955] No boot file from DHCP.
[        initrd] [   12.791060] TFTP binary "", configs prefix "", using "/" slash.
WTC listener is active.
Send broadcast WTCU discover.
[        initrd] [   12.798927] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   12.799017] Run /sbin/httpd.
[          pfac] [   12.799295] Ok, PID 679.
[         httpd] [   12.804283] HTTP Server, WTware 5.6.20/RPi
[        initrd] [   12.923666] USB: 0cf3:9271 Atheros Communications, Inc. AR9271 802.11n.
[        initrd] [   12.923795] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[        initrd] [   12.923871] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[        initrd] [   12.923943] USB: 046d:c52b Logitech, Inc. Unifying Receiver.
[        initrd] [   12.924016] USB: 1a2c:2124 China Resource Semico Co., Ltd.
[        initrd] [   12.924109] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[        initrd] [   12.924674] Common local disk config:
| [BOM]
| server=192.168.88.18
| user=User:Asdf1234
| graphic=df
| [BOM]
| user=User:Asdf1234
| graphic=df
| connection
[        initrd] [   12.925530] Hostname: "wtwB827EB9B0412".
RSH: listener is active.
[         httpd] [   13.194475] Reread settings.
[         httpd] [   13.194628] Everyone can control terminal by HTTP.
[            gm] [   13.199437] WTware session manager 5.6.20/RPi.
[            gm] [   13.200429] Add keyboard event2: SEM USB Keyboard.
[            gm] [   13.200519] Add keyboard event1: SEM USB Keyboard.
[            gm] [   13.200598] EV_REL flag found. Add mouse event0: Logitech M325.
[            gm] [   13.200713] Display mode: 1920x1080, 16 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   13.218997] Framebuffer device found.
[            gm] [   13.219077] LINELENBYTES 3840
[            gm] [   13.219151] VLEN 4147200
[            gm] [   13.238266] Use /lib/ui16.so.
[            gm] [   13.343155] Run '/sbin/resolver 0x2a9b58 dns [192.168.88.18]', log '', env '', pid ''.
[          pfac] [   13.343337] Run /sbin/resolver 0x2a9b58 dns [192.168.88.18].
[            gm] [   13.343398] Nobody can control terminal by VNC.
[          pfac] [   13.343603] Ok, PID 681.
[          pfac] [   13.348232] Process pid 681 terminated, status 00000000.
[            gm] [   13.349252] 192.168.88.18 => 192.168.88.18.
[            gm] [   13.363836] Free ram before fork terminal client /sbin/rdpclient (session 1): 923220 Kb.
[          pfac] [   13.363930] Run /sbin/rdpclient 1.
[            gm] [   13.363975] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   13.364550] Ok, PID 682.
[ rdpclient 682] [   13.371401] RDP Terminal Client, WTware 5.6.20/RPi, pipe 1, pid 682.
[ rdpclient 682] [   13.372667] Use /lib/ui16.so.
[ rdpclient 682] [   13.373909] Make RDP session with 192.168.88.18, port 3389.
[ rdpclient 682] [   13.374021]  Username: "User".
[ rdpclient 682] [   13.374109]  Password: present.
[ rdpclient 682] [   13.374188]  No PIN.
[ rdpclient 682] [   13.374395]  No domain.
[ rdpclient 682] [   13.374477]  No shell.
[ rdpclient 682] [   13.374562]  No directory.
[ rdpclient 682] [   13.374642]  Window: 1920x1080@16.
[ rdpclient 682] [   13.374720]  PFlags 0x000000A7.
[ rdpclient 682] [   13.374803]  Keyboard 00000409:00000000.
[ rdpclient 682] [   13.374887]  My hostname "wtwB827EB9B0412".
[ rdpclient 682] [   13.374966] TCP: connecting to 192.168.88.18:3389.
[ rdpclient 682] [   13.386360] TCP: connection with 192.168.88.18:3389 established.
[ rdpclient 682] [   13.386504] Turn keepalive on.
[ rdpclient 682] [   13.387223] Free ram after buffers allocation: 923056 KB.
[ rdpclient 682] [   13.395068] Reconnect with CredSSP enabled.
[ rdpclient 682] [   13.395168] TCP: reconnecting to 192.168.88.18:3389.
[ rdpclient 682] [   13.397721] TCP: connection with 192.168.88.18:3389 established.
[ rdpclient 682] [   13.397811] Turn keepalive on.
[ rdpclient 682] [   13.410118] Server supports GFX Pipeline.
[ rdpclient 682] [   13.410222] CredSSP.
[ rdpclient 682] [   13.410321] SSL/TLS.
[ rdpclient 682] [   13.577430] Enable font smoothing and Desktop Composition.
[ rdpclient 682] [   13.632086] RDP5 encryption (X.509).
[ rdpclient 682] [   13.824474] GFX codec.
[ rdpclient 682] [   13.964092] errorInfo 0x00000000.
[ rdpclient 682] [   14.149489] SessionId 0x00000002: WIN-A8IGPI2FTC1\user.
[ rdpclient 682] [   14.198475] Run 4 tile threads.
[           WPA] [   38.235322] eth0: WPA: Group rekeying completed with 64:d1:54:66:a0:2c [GTK=CCMP]
Home    WTware diskless client.
Re: AR9271
Сообщение aka » Вс ноя 19, 2017 12:24 pm
rquid
Re: AR9271
Сообщение rquid » Вс ноя 19, 2017 2:12 pm
[        initrd] [   47.417976] +------------------------
[        initrd] [   47.418082] Unpack /bootmedia/packages/pi2-xnet.
[        initrd] [   48.079371] modprobe ath9k_htc.
[        initrd] [   48.089647] USB WiFi module ath9k_htc.ko loaded.
[        KERNEL] [   48.091065] usb 1-1.4: ath9k_htc: Firmware ath9k_htc/htc_9271-1.4.0.fw requested
[        KERNEL] [   48.091147] usb 1-1.4: Direct firmware load for ath9k_htc/htc_9271-1.4.0.fw failed with error -2
[        KERNEL] [   48.091151] usb 1-1.4: Falling back to user helper
[        KERNEL] [   48.091359] usbcore: registered new interface driver ath9k_htc
[       hotplug] [   48.090822]     hotplug-main.cpp (  346): -- ERROR -- Firmware "/lib/firmware/ath9k_htc/htc_9271-1.4.0.fw" not found.
[        initrd] [   51.098858] ERROR: Unknown WiFi card. Please make photo of this screen and send it
to WTware tech support. We'll try to add driver for your hardware.
Re: AR9271
Сообщение aka » Вс ноя 19, 2017 3:41 pm
rquid
Re: AR9271
Сообщение rquid » Вс ноя 19, 2017 7:54 pm
Все, спасибо, работает.
