TCP/IP connection lost. Network failure?
Добавлено: Вт дек 12, 2017 11:26 am
Не подключается к серверу W2012R2.
WTware 5.6.22/RPi supervisor.
[ KERNEL] [ 0.000000] Linux version 4.9.65 (aka@c12) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #3 SMP Fri Dec 1 21:14:42 +04 2017
[ KERNEL] [ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
[ KERNEL] [ 0.000000] On node 0 totalpages: 242688
[ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80c22b40, node_mem_map ba3a1000
[ KERNEL] [ 0.000000] Normal zone: 2133 pages used for memmap
[ KERNEL] [ 0.000000] Normal zone: 242688 pages, LIFO batch:31
[ KERNEL] [ 0.000000] percpu: Embedded 11 pages/cpu @ba367000 s15948 r8192 d20916 u45056
[ KERNEL] [ 0.000000] pcpu-alloc: s15948 r8192 d20916 u45056 alloc=11*4096
[ KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 240555
[ KERNEL] [ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 quiet wtboot=mmc
[ KERNEL] [ 0.000000] Memory: 941160K/970752K available (5120K kernel code, 143K rwdata, 920K rodata, 5120K init, 365K bss, 21400K reserved, 8192K cma-reserved)
[ KERNEL] [ 0.000000] lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
[ KERNEL] [ 0.000000] .init : 0x80700000 - 0x80c00000 (5120 kB)
[ KERNEL] [ 0.000000] .data : 0x80c00000 - 0x80c23df8 ( 144 kB)
[ KERNEL] [ 0.000000] .bss : 0x80c25000 - 0x80c805a0 ( 366 kB)
[ KERNEL] [ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ KERNEL] [ 0.000017] Switching to timer-based delay loop, resolution 52ns
[ KERNEL] [ 0.000208] Console: colour dummy device 80x30
[ KERNEL] [ 0.000222] console [tty0] enabled
[ KERNEL] [ 0.000238] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ KERNEL] [ 0.000251] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.000381] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.000389] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.001234] Disabling memory control group subsystem
[ KERNEL] [ 0.001288] CPU: Testing write buffer coherency: ok
[ KERNEL] [ 0.001620] CPU0: update cpu_capacity 1024
[ KERNEL] [ 0.001629] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ KERNEL] [ 0.001652] Setting up static identity map for 0x100000 - 0x100034
[ KERNEL] [ 0.003172] CPU1: update cpu_capacity 1024
[ KERNEL] [ 0.003179] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ KERNEL] [ 0.003729] CPU2: update cpu_capacity 1024
[ KERNEL] [ 0.003735] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ KERNEL] [ 0.004280] CPU3: update cpu_capacity 1024
[ KERNEL] [ 0.004286] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ KERNEL] [ 0.004364] Brought up 4 CPUs
[ KERNEL] [ 0.004373] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ KERNEL] [ 0.004377] CPU: All CPU(s) started in HYP mode.
[ KERNEL] [ 0.004380] CPU: Virtualization extensions available.
[ KERNEL] [ 0.004917] devtmpfs: initialized
[ KERNEL] [ 0.014591] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ KERNEL] [ 0.014970] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ KERNEL] [ 0.014986] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ KERNEL] [ 0.015469] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.015998] NET: Registered protocol family 16
[ KERNEL] [ 0.017832] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ KERNEL] [ 0.027969] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ KERNEL] [ 0.111147] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[ KERNEL] [ 0.113462] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.113585] usbcore: registered new interface driver hub
[ KERNEL] [ 0.113668] usbcore: registered new device driver usb
[ KERNEL] [ 0.120125] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-11-17 15:19
[ KERNEL] [ 0.122389] clocksource: Switched to clocksource arch_sys_counter
[ KERNEL] [ 0.137435] NET: Registered protocol family 2
[ KERNEL] [ 0.138009] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ KERNEL] [ 0.138117] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ KERNEL] [ 0.138301] TCP: Hash tables configured (established 8192 bind 8192)
[ KERNEL] [ 0.138387] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.138428] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.138600] NET: Registered protocol family 1
[ KERNEL] [ 2.242713] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ KERNEL] [ 2.279207] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ KERNEL] [ 2.279217] io scheduler noop registered
[ KERNEL] [ 2.279222] io scheduler deadline registered (default)
[ KERNEL] [ 2.287993] BCM2708FB: allocated DMA memory fad10000
[ KERNEL] [ 2.288032] BCM2708FB: allocated DMA channel 0 @ bb80f000
[ KERNEL] [ 2.308415] Console: switching to colour frame buffer device 160x64
[ KERNEL] [ 2.321807] bcm2835-rng 3f104000.rng: hwrng registered
[ KERNEL] [ 2.322010] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ KERNEL] [ 2.323022] vc-sm: Videocore shared memory driver
[ KERNEL] [ 2.328205] zram: Added device: zram0
[ KERNEL] [ 2.328239] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ KERNEL] [ 2.556308] Core Release: 2.80a
[ KERNEL] [ 2.556316] Setting default values for core params
[ KERNEL] [ 2.556341] Finished setting default values for core params
[ KERNEL] [ 2.756694] Using Buffer DMA mode
[ KERNEL] [ 2.756700] Periodic Transfer Interrupt Enhancement - disabled
[ KERNEL] [ 2.756703] Multiprocessor Interrupt Enhancement - disabled
[ KERNEL] [ 2.756710] OTG VER PARAM: 0, OTG VER FLAG: 0
[ KERNEL] [ 2.756740] Dedicated Tx FIFOs mode
[ KERNEL] [ 2.757241] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[ KERNEL] [ 2.757264] FIQ FSM acceleration enabled for :
[ KERNEL] [ 2.757264] Non-periodic Split Transactions
[ KERNEL] [ 2.757264] Periodic Split Transactions
[ KERNEL] [ 2.757264] High-Speed Isochronous Endpoints
[ KERNEL] [ 2.757264] Interrupt/Control Split Transaction hack enabled
[ KERNEL] [ 2.757282] dwc_otg: Microframe scheduler enabled
[ KERNEL] [ 2.757337] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397d28
[ KERNEL] [ 2.757346] WARN::hcd_init_fiq:460: FIQ ASM at 0x8039808c length 36
[ KERNEL] [ 2.757355] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[ KERNEL] [ 2.757410] dwc_otg 3f980000.usb: DWC OTG Controller
[ KERNEL] [ 2.757443] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ KERNEL] [ 2.757473] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ KERNEL] [ 2.757518] Init: Port Power? op_state=1
[ KERNEL] [ 2.757521] Init: Power Port (0)
[ KERNEL] [ 2.757695] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ KERNEL] [ 2.757705] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 2.757712] usb usb1: Product: DWC OTG Controller
[ KERNEL] [ 2.757719] usb usb1: Manufacturer: Linux 4.9.65 dwc_otg_hcd
[ KERNEL] [ 2.757726] usb usb1: SerialNumber: 3f980000.usb
[ KERNEL] [ 2.758437] hub 1-0:1.0: USB hub found
[ KERNEL] [ 2.758472] hub 1-0:1.0: 1 port detected
[ KERNEL] [ 2.759157] dwc_otg: FIQ enabled
[ KERNEL] [ 2.759161] dwc_otg: NAK holdoff enabled
[ KERNEL] [ 2.759165] dwc_otg: FIQ split-transaction FSM enabled
[ KERNEL] [ 2.759178] Module dwc_common_port init
[ KERNEL] [ 2.759561] usbcore: registered new interface driver usbtouchscreen
[ KERNEL] [ 2.760926] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ KERNEL] [ 2.761383] bcm2835-cpufreq: min=600000 max=1200000
[ KERNEL] [ 2.762548] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[ KERNEL] [ 2.764968] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ KERNEL] [ 2.767883] ledtrig-cpu: registered to indicate activity on CPUs
[ KERNEL] [ 2.768157] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 2.769705] usbcore: registered new interface driver usbhid
[ KERNEL] [ 2.769712] usbhid: USB HID core driver
[ KERNEL] [ 2.771880] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[ KERNEL] [ 2.781851] [vc_sm_connected_init]: start
[ KERNEL] [ 2.790798] [vc_sm_connected_init]: end - returning 0
[ KERNEL] [ 2.791292] NET: Registered protocol family 17
[ KERNEL] [ 2.791474] Registering SWP/SWPB emulation handler
[ KERNEL] [ 2.792944] registered taskstats version 1
[ KERNEL] [ 2.799871] sdhost: log_buf @ bad07000 (fad07000)
[ KERNEL] [ 2.872429] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ KERNEL] [ 2.874729] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ KERNEL] [ 2.874736] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ KERNEL] [ 2.953608] mmc0: host does not support reading read-only switch, assuming write-enable
[ KERNEL] [ 2.953685] of_cfs_init
[ KERNEL] [ 2.953766] of_cfs_init: OK
[ KERNEL] [ 2.972492] mmc0: Problem switching card into high-speed mode!
[ KERNEL] [ 2.972636] Indeed it is in host mode hprt0 = 00021501
[ KERNEL] [ 2.980068] Freeing unused kernel memory: 5120K
[ KERNEL] [ 3.049419] mmc0: new SDHC card at address 0001
[ KERNEL] [ 3.051345] mmcblk0: mmc0:0001 ASTC 14.7 GiB
[ KERNEL] [ 3.060900] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ KERNEL] [ 3.061500] mmcblk0: p1
[ KERNEL] [ 3.063068] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 3.064716] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 3.066198] random: fast init done
[ KERNEL] [ 3.067653] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ KERNEL] [ 3.158662] mmc1: new high speed SDIO card at address 0001
[ KERNEL] [ 3.182443] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ KERNEL] [ 3.182590] Indeed it is in host mode hprt0 = 00001101
[ hotplug] [ 3.229641] Block device 254:0. No action.
[ hotplug] [ 3.362509] Block device 179:1. No action.
[ hotplug] [ 3.362665] Block device 179:0. No action.
[ pfac] [ 3.370192] Run /sbin/initrd.
[ pfac] [ 3.374615] Ok, PID 608.
[ initrd] [ 3.374708] WTware shell 5.6.22/RPi
[ initrd] [ 3.394725] HDD/MMC/SD boot.
[ KERNEL] [ 3.442658] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ KERNEL] [ 3.442670] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 3.443442] hub 1-1:1.0: USB hub found
[ KERNEL] [ 3.443569] hub 1-1:1.0: 5 ports detected
[ KERNEL] [ 3.762420] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ KERNEL] [ 3.892660] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ KERNEL] [ 3.892671] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 3.992414] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[ KERNEL] [ 4.140375] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c31c
[ KERNEL] [ 4.140386] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 4.140393] usb 1-1.2: Product: USB Keyboard
[ KERNEL] [ 4.140400] usb 1-1.2: Manufacturer: Logitech
[ KERNEL] [ 4.160587] input: Logitech USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C31C.0001/input/input0
[ KERNEL] [ 4.223820] hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3f980000.usb-1.2/input0
[ KERNEL] [ 4.252128] input: Logitech USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C31C.0002/input/input1
[ KERNEL] [ 4.312866] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3f980000.usb-1.2/input1
[ initrd] [ 4.406849] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
| # http://www.raspberrypi.org/documentation/configuration/config-txt.md
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=1
| #hdmi_mode=1
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| #hdmi_group=2
| # 800x600: hdmi_mode=9
| # 1024x768: hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768: hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900: hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768: hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| framebuffer_depth=32
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
[ initrd] [ 4.414273] WTpassword empty.
[ KERNEL] [ 4.412438] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[ KERNEL] [ 4.547379] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c05a
[ KERNEL] [ 4.547392] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 4.547400] usb 1-1.3: Product: USB Optical Mouse
[ KERNEL] [ 4.547407] usb 1-1.3: Manufacturer: Logitech
[ KERNEL] [ 4.552058] input: Logitech USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C05A.0003/input/input2
[ KERNEL] [ 4.553555] hid-generic 0003:046D:C05A.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-3f980000.usb-1.3/input0
| clientIP = *
| config = local
[ initrd] [ 6.416038] Load ethernet drivers.
[ initrd] [ 6.419785] modprobe smsc95xx.
[ KERNEL] [ 6.429431] smsc95xx v1.0.5
[ KERNEL] [ 6.525712] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:11:42:68
[ KERNEL] [ 6.525969] usbcore: registered new interface driver smsc95xx
[ KERNEL] [ 6.614580] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ initrd] [ 8.215736] WTpassword empty.
[ KERNEL] [ 8.217517] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ initrd] [ 9.420177] dhcp: 367 bytes from 195.38.58.24.
[ initrd] [ 9.420358] 00000000:0000015B0000000000110000C3263A18FFFFFFFF00430044015B000002010600 ...[........&:.....C.D.[......
[ initrd] [ 9.420487] 00000020:67458B6B0000000000000000C3263966C3263A2200000000B827EB1142680000 gE.k.........&9f.&:".....'.Bh..
[ initrd] [ 9.420614] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 9.420739] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 9.420864] 00000080:0000000000000000626F6F745C7838365C7764736E62702E636F6D0000000000 ........boot\x86\wdsnbp.com.....
[ initrd] [ 9.420988] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 9.421111] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 9.421234] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.680186] dhcp: 367 bytes from 195.38.58.24.
[ initrd] [ 11.680372] 00000000:0000015B0000000000110000C3263A18FFFFFFFF00430044015B000002010600 ...[........&:.....C.D.[......
[ initrd] [ 11.680502] 00000020:67458B6B0000000000000000C3263966C3263A2200000000B827EB1142680000 gE.k.........&9f.&:".....'.Bh..
[ initrd] [ 11.680628] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.680752] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.680895] 00000080:0000000000000000626F6F745C7838365C7764736E62702E636F6D0000000000 ........boot\x86\wdsnbp.com.....
[ initrd] [ 11.681018] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.681140] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.681262] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.720106] dhcp: server address 195.38.58.24.
[ initrd] [ 11.720219] dhcp: 195.38.57.102/255.255.252.0.
[ initrd] [ 11.720326] dhcp: default gateway 195.38.58.206.
[ initrd] [ 11.720558] dhcp: DNS 195.38.58.22.
[ initrd] [ 11.720629] dhcp: DNS 195.38.58.24.
[ initrd] [ 11.720696] dhcp: domain radioc.ru.
[ initrd] [ 11.720760] dhcp: TFTP from 066 195.38.58.34.
[ initrd] [ 11.720825] dhcp: TFTP 195.38.58.34.
[ initrd] [ 11.720889] dhcp: boot file (067) boot\x86\wdsnbp.com.
[ initrd] [ 11.720954] TFTP binary "boot\x86\", configs prefix "boot\", using "\" slash.
WTC listener is active.
Send broadcast WTCU discover.
[ pfac] [ 11.724041] Run /sbin/httpd.
[ initrd] [ 11.724115] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[ pfac] [ 11.724232] Ok, PID 650.
[ httpd] [ 11.728607] HTTP Server, WTware 5.6.22/RPi
[ initrd] [ 11.836654] USB: 046d:c05a Logitech, Inc. M90/M100 Optical Mouse.
[ initrd] [ 11.836787] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[ initrd] [ 11.836860] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[ initrd] [ 11.836931] USB: 046d:c31c Logitech, Inc. Keyboard K120.
[ initrd] [ 11.837227] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[ initrd] [ 11.837959] Common local disk config:
| [BOM]
| server=144.76.35.17
| [BOM]
| server=144.76.35.17
| connection
[ initrd] [ 11.838708] Hostname: "wtwB827EB114268".
RSH: listener is active.
[ httpd] [ 12.074941] Reread settings.
[ httpd] [ 12.075105] Everyone can control terminal by HTTP.
[ gm] [ 12.079309] WTware session manager 5.6.22/RPi.
[ gm] [ 12.080309] EV_REL flag found. Add mouse event2: Logitech USB Optical Mouse.
[ gm] [ 12.080396] Add keyboard event1: Logitech USB Keyboard.
[ gm] [ 12.080470] Add keyboard event0: Logitech USB Keyboard.
[ gm] [ 12.080581] Display mode: 1280x1024, 16 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 12.092556] Framebuffer device found.
[ gm] [ 12.092635] LINELENBYTES 2560
[ gm] [ 12.092708] VLEN 2621440
[ gm] [ 12.105467] Use /lib/ui16.so.
[ gm] [ 12.182771] Run '/sbin/resolver 0xa04ac8 dns [144.76.35.17]', log '', env '', pid ''.
[ gm] [ 12.182906] Nobody can control terminal by VNC.
[ pfac] [ 12.183120] Run /sbin/resolver 0xa04ac8 dns [144.76.35.17].
[ pfac] [ 12.183662] Ok, PID 651.
[ gm] [ 12.187271] 144.76.35.17 => 144.76.35.17.
[ pfac] [ 12.187648] Process pid 651 terminated, status 00000000.
[ gm] [ 12.196661] Free ram before fork terminal client /sbin/rdpclient (session 1): 932072 Kb.
[ gm] [ 12.196807] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 12.196965] Run /sbin/rdpclient 1.
[ pfac] [ 12.197375] Ok, PID 652.
[ rdpclient 652] [ 12.204528] RDP Terminal Client, WTware 5.6.22/RPi, pipe 1, pid 652.
[ rdpclient 652] [ 12.205047] Use /lib/ui16.so.
[ rdpclient 652] [ 12.206383] Make RDP session with 144.76.35.17, port 3389.
[ rdpclient 652] [ 12.206557] No username.
[ rdpclient 652] [ 12.206637] No password.
[ rdpclient 652] [ 12.206718] No PIN.
[ rdpclient 652] [ 12.206850] No domain.
[ rdpclient 652] [ 12.206962] No shell.
[ rdpclient 652] [ 12.207042] No directory.
[ rdpclient 652] [ 12.207120] Window: 1280x1024@16.
[ rdpclient 652] [ 12.207197] PFlags 0x0000002F.
[ rdpclient 652] [ 12.207273] Keyboard 00000409:00000000.
[ rdpclient 652] [ 12.207349] My hostname "wtwB827EB114268".
[ rdpclient 652] [ 12.207426] TCP: connecting to 144.76.35.17:3389.
[ rdpclient 652] [ 12.277088] TCP: connection with 144.76.35.17:3389 established.
[ rdpclient 652] [ 12.277215] Turn keepalive on.
[ rdpclient 652] [ 12.277988] Free ram after buffers allocation: 931320 KB.
[ rdpclient 652] [ 12.348415] Server supports GFX Pipeline.
[ rdpclient 652] [ 12.418521] Process RDP server certificate.
[ rdpclient 652] [ 12.418611] RDP5 encryption (X.509).
[ rdpclient 652] [ 13.280797] Unsupported EncryptionMethod 0x00000010.
[ rdpclient 652] [ 13.280918] Enable font smoothing and Desktop Composition.
[ rdpclient 652] [ 13.352112] ./streamInOps.h ( 313): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 652] [ 13.352199] ./streamInStealer.h ( 29): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 652] [ 13.352279] [ERROR] totalLength 61565 large then packet 26 channelId 1003.
[ rdpclient 652] [ 13.352357] 00000000:0300003602F08068000103EB302808000000100001029364BFCF7FF06ABB1F88 ...6...h....0(........d...j..
[ rdpclient 652] [ 13.352436] 00000020:CD9463DCC689586F8EE80158FC32FF5BF049B97A6BF1 ..c...Xo...X.2.[.I.zk.
[ rdpclient 652] [ 13.352514] rdpclient-connect.cpp ( 2769): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 652] [ 13.352592] Close TCP connection while receiving data, errno 104.
[ gm] [ 13.352670] Final message: TCP/IP connection lost. Network failure?
[ rdpclient 652] [ 13.352713] TCP/IP connection lost. Network failure?
[ pfac] [ 13.353531] Process pid 652 terminated, status 00000009.
[ KERNEL] [ 15.914146] random: crng init done
[ gm] [ 24.065935] Run '/sbin/resolver 0xa04ac8 dns [144.76.35.17]', log '', env '', pid ''.
[ pfac] [ 24.066187] Run /sbin/resolver 0xa04ac8 dns [144.76.35.17].
[ pfac] [ 24.066274] Ok, PID 658.
[ gm] [ 24.069468] 144.76.35.17 => 144.76.35.17.
[ pfac] [ 24.069891] Process pid 658 terminated, status 00000000.
[ gm] [ 24.078791] Free ram before fork terminal client /sbin/rdpclient (session 2): 931436 Kb.
[ pfac] [ 24.079339] Run /sbin/rdpclient 2.
[ gm] [ 24.079406] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 24.079499] Ok, PID 659.
[ rdpclient 659] [ 24.086203] RDP Terminal Client, WTware 5.6.22/RPi, pipe 2, pid 659.
[ rdpclient 659] [ 24.086691] Use /lib/ui16.so.
[ rdpclient 659] [ 24.087907] Make RDP session with 144.76.35.17, port 3389.
[ rdpclient 659] [ 24.088086] No username.
[ rdpclient 659] [ 24.088166] No password.
[ rdpclient 659] [ 24.088245] No PIN.
[ rdpclient 659] [ 24.088321] No domain.
[ rdpclient 659] [ 24.088399] No shell.
[ rdpclient 659] [ 24.088475] No directory.
[ rdpclient 659] [ 24.088552] Window: 1280x1024@16.
[ rdpclient 659] [ 24.088630] PFlags 0x0000002F.
[ rdpclient 659] [ 24.088707] Keyboard 00000409:00000000.
[ rdpclient 659] [ 24.088782] My hostname "wtwB827EB114268".
[ rdpclient 659] [ 24.088859] TCP: connecting to 144.76.35.17:3389.
[ rdpclient 659] [ 24.157441] TCP: connection with 144.76.35.17:3389 established.
[ rdpclient 659] [ 24.157564] Turn keepalive on.
[ rdpclient 659] [ 24.158287] Free ram after buffers allocation: 931328 KB.
[ rdpclient 659] [ 24.228588] Server supports GFX Pipeline.
[ rdpclient 659] [ 24.298920] Process RDP server certificate.
[ rdpclient 659] [ 24.299006] RDP5 encryption (X.509).
[ rdpclient 659] [ 24.854343] Unsupported EncryptionMethod 0x00000010.
[ rdpclient 659] [ 24.854444] Enable font smoothing and Desktop Composition.
[ rdpclient 659] [ 24.924163] ./streamInOps.h ( 313): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 659] [ 24.924251] ./streamInStealer.h ( 29): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 659] [ 24.924331] [ERROR] totalLength 54236 large then packet 26 channelId 1003.
[ rdpclient 659] [ 24.924409] 00000000:0300003602F08068000103EB30280800000010000102CB0C2026DED340F58BAF ...6...h....0(......... &..@...
[ rdpclient 659] [ 24.924488] 00000020:2671B0F371FAD1011757B4D18B5A43CE78427AC573F0 &q..q...W...ZC.xBz.s.
[ rdpclient 659] [ 24.924567] rdpclient-connect.cpp ( 2769): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 659] [ 24.924646] Close TCP connection while receiving data, errno 104.
[ gm] [ 24.924722] Final message: TCP/IP connection lost. Network failure?
[ rdpclient 659] [ 24.924768] TCP/IP connection lost. Network failure?
[ pfac] [ 24.925612] Process pid 659 terminated, status 00000009.
[ gm] [ 32.761853] Run '/sbin/resolver 0xa04ac8 dns [144.76.35.17]', log '', env '', pid ''.
[ pfac] [ 32.762105] Run /sbin/resolver 0xa04ac8 dns [144.76.35.17].
[ pfac] [ 32.762191] Ok, PID 663.
[ gm] [ 32.765470] 144.76.35.17 => 144.76.35.17.
[ pfac] [ 32.765885] Process pid 663 terminated, status 00000000.
[ gm] [ 32.774863] Free ram before fork terminal client /sbin/rdpclient (session 3): 931560 Kb.
[ pfac] [ 32.775403] Run /sbin/rdpclient 3.
[ gm] [ 32.775467] Run '/sbin/rdpclient 3', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 32.775554] Ok, PID 664.
[ rdpclient 664] [ 32.782301] RDP Terminal Client, WTware 5.6.22/RPi, pipe 3, pid 664.
[ rdpclient 664] [ 32.782836] Use /lib/ui16.so.
[ rdpclient 664] [ 32.784073] Make RDP session with 144.76.35.17, port 3389.
[ rdpclient 664] [ 32.784252] No username.
[ rdpclient 664] [ 32.784331] No password.
[ rdpclient 664] [ 32.784411] No PIN.
[ rdpclient 664] [ 32.784489] No domain.
[ rdpclient 664] [ 32.784564] No shell.
[ rdpclient 664] [ 32.784641] No directory.
[ rdpclient 664] [ 32.784718] Window: 1280x1024@16.
[ rdpclient 664] [ 32.784794] PFlags 0x0000002F.
[ rdpclient 664] [ 32.784871] Keyboard 00000409:00000000.
[ rdpclient 664] [ 32.784950] My hostname "wtwB827EB114268".
[ rdpclient 664] [ 32.785027] TCP: connecting to 144.76.35.17:3389.
[ rdpclient 664] [ 32.853498] TCP: connection with 144.76.35.17:3389 established.
[ rdpclient 664] [ 32.853617] Turn keepalive on.
[ rdpclient 664] [ 32.854397] Free ram after buffers allocation: 931312 KB.
[ rdpclient 664] [ 32.924524] Server supports GFX Pipeline.
[ rdpclient 664] [ 32.994746] Process RDP server certificate.
[ rdpclient 664] [ 32.994832] RDP5 encryption (X.509).
[ rdpclient 664] [ 33.551789] Unsupported EncryptionMethod 0x00000010.
[ rdpclient 664] [ 33.551898] Enable font smoothing and Desktop Composition.
[ rdpclient 664] [ 33.620957] ./streamInOps.h ( 313): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 664] [ 33.621044] ./streamInStealer.h ( 29): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 664] [ 33.621124] [ERROR] totalLength 30850 large then packet 26 channelId 1003.
[ rdpclient 664] [ 33.621202] 00000000:0300003602F08068000103EB3028080000001000010200201E018478B346EB4D ...6...h....0(........ ..x.F.M
[ rdpclient 664] [ 33.621286] 00000020:91E5D6861328A945C945C113071043B3B90E268EA056 ....(.E.E..C...&..V
[ rdpclient 664] [ 33.621364] rdpclient-connect.cpp ( 2769): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 33.621462] Final message: TCP/IP connection lost. Network failure?
[ rdpclient 664] [ 33.621506] Close TCP connection while receiving data, errno 104.
[ rdpclient 664] [ 33.621582] TCP/IP connection lost. Network failure?
[ pfac] [ 33.622440] Process pid 664 terminated, status 00000009.
