сорян не мог тогда получить. Вот он.
17-13-09-344| [wtc.exe] Соединение закрыто.
17-13-22-374| WTware 5.6.24/RPi supervisor.
17-13-22-374| [ KERNEL] [ 0.000000] Booting Linux on physical CPU 0xf00
17-13-22-374| [ KERNEL] [ 0.000000] Linux version 4.9.75 (aka@c16) (gcc version 7.2.0 (Debian 7.2.0-11) ) #4 SMP Wed Jan 10 10:39:31 EST 2018
17-13-22-374| [ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
17-13-22-374| [ KERNEL] [ 0.000000] CPU: div instructions available: patching division code
17-13-22-374| [ KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
17-13-22-374| [ KERNEL] [ 0.000000] OF: fdt:Machine model: Raspberry Pi 2 Model B Rev 1.1
17-13-22-374| [ KERNEL] [ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
17-13-22-374| [ KERNEL] [ 0.000000] Memory policy: Data cache writealloc
17-13-22-374| [ KERNEL] [ 0.000000] On node 0 totalpages: 242688
17-13-22-374| [ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80c22b80, node_mem_map ba3a1000
17-13-22-374| [ KERNEL] [ 0.000000] Normal zone: 2133 pages used for memmap
17-13-22-374| [ KERNEL] [ 0.000000] Normal zone: 0 pages reserved
17-13-22-374| [ KERNEL] [ 0.000000] Normal zone: 242688 pages, LIFO batch:31
17-13-22-374| [ KERNEL] [ 0.000000] percpu: Embedded 11 pages/cpu @ba367000 s15948 r8192 d20916 u45056
17-13-22-374| [ KERNEL] [ 0.000000] pcpu-alloc: s15948 r8192 d20916 u45056 alloc=11*4096
17-13-22-374| [ KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
17-13-22-374| [ KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 240555
17-13-22-374| [ KERNEL] [ 0.000000] Kernel command line: bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 quiet wtboot=mmc usbhid.mousepoll=1
17-13-22-374| [ KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
17-13-22-374| [ KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
17-13-22-374| [ KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
17-13-22-374| [ KERNEL] [ 0.000000] Memory: 941160K/970752K available (5120K kernel code, 143K rwdata, 920K rodata, 5120K init, 365K bss, 21400K reserved, 8192K cma-reserved)
17-13-22-374| [ KERNEL] [ 0.000000] Virtual kernel memory layout:
17-13-22-374| [ KERNEL] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
17-13-22-374| [ KERNEL] [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
17-13-22-374| [ KERNEL] [ 0.000000] vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
17-13-22-374| [ KERNEL] [ 0.000000] lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
17-13-22-374| [ KERNEL] [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
17-13-22-374| [ KERNEL] [ 0.000000] .text : 0x80008000 - 0x80600000 (6112 kB)
17-13-22-374| [ KERNEL] [ 0.000000] .init : 0x80700000 - 0x80c00000 (5120 kB)
17-13-22-374| [ KERNEL] [ 0.000000] .data : 0x80c00000 - 0x80c23e38 ( 144 kB)
17-13-22-374| [ KERNEL] [ 0.000000] .bss : 0x80c25000 - 0x80c805e0 ( 366 kB)
17-13-22-374| [ KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
17-13-22-374| [ KERNEL] [ 0.000000] Hierarchical RCU implementation.
17-13-22-374| [ KERNEL] [ 0.000000] Build-time adjustment of leaf fanout to 32.
17-13-22-374| [ KERNEL] [ 0.000000] NR_IRQS:16 nr_irqs:16 16
17-13-22-374| [ KERNEL] [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
17-13-22-374| [ KERNEL] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
17-13-22-374| [ KERNEL] [ 0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
17-13-22-374| [ KERNEL] [ 0.000022] Switching to timer-based delay loop, resolution 52ns
17-13-22-374| [ KERNEL] [ 0.000255] Console: colour dummy device 80x30
17-13-22-374| [ KERNEL] [ 0.000272] console [tty0] enabled
17-13-22-374| [ KERNEL] [ 0.000292] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
17-13-22-374| [ KERNEL] [ 0.000310] pid_max: default: 32768 minimum: 301
17-13-22-374| [ KERNEL] [ 0.000484] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
17-13-22-374| [ KERNEL] [ 0.000495] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
17-13-22-374| [ KERNEL] [ 0.001600] Disabling memory control group subsystem
17-13-22-374| [ KERNEL] [ 0.001688] CPU: Testing write buffer coherency: ok
17-13-22-374| [ KERNEL] [ 0.002190] CPU0: update cpu_capacity 1024
17-13-22-374| [ KERNEL] [ 0.002203] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
17-13-22-374| [ KERNEL] [ 0.002239] Setting up static identity map for 0x100000 - 0x100034
17-13-22-374| [ KERNEL] [ 0.004597] CPU1: update cpu_capacity 1024
17-13-22-374| [ KERNEL] [ 0.004608] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
17-13-22-374| [ KERNEL] [ 0.005468] CPU2: update cpu_capacity 1024
17-13-22-374| [ KERNEL] [ 0.005476] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
17-13-22-374| [ KERNEL] [ 0.006330] CPU3: update cpu_capacity 1024
17-13-22-374| [ KERNEL] [ 0.006339] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
17-13-22-374| [ KERNEL] [ 0.006452] Brought up 4 CPUs
17-13-22-374| [ KERNEL] [ 0.006465] SMP: Total of 4 processors activated (153.60 BogoMIPS).
17-13-22-374| [ KERNEL] [ 0.006471] CPU: All CPU(s) started in HYP mode.
17-13-22-374| [ KERNEL] [ 0.006474] CPU: Virtualization extensions available.
17-13-22-374| [ KERNEL] [ 0.007223] devtmpfs: initialized
17-13-22-374| [ KERNEL] [ 0.019007] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
17-13-22-374| [ KERNEL] [ 0.019588] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
17-13-22-374| [ KERNEL] [ 0.019610] futex hash table entries: 1024 (order: 4, 65536 bytes)
17-13-22-374| [ KERNEL] [ 0.020373] pinctrl core: initialized pinctrl subsystem
17-13-22-374| [ KERNEL] [ 0.021237] NET: Registered protocol family 16
17-13-22-374| [ KERNEL] [ 0.023428] DMA: preallocated 1024 KiB pool for atomic coherent allocations
17-13-22-374| [ KERNEL] [ 0.036080] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
17-13-22-374| [ KERNEL] [ 0.121876] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
17-13-22-374| [ KERNEL] [ 0.125141] usbcore: registered new interface driver usbfs
17-13-22-374| [ KERNEL] [ 0.125343] usbcore: registered new interface driver hub
17-13-22-374| [ KERNEL] [ 0.125484] usbcore: registered new device driver usb
17-13-22-374| [ KERNEL] [ 0.130355] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-01-08 14:28
17-13-22-374| [ KERNEL] [ 0.133663] clocksource: Switched to clocksource arch_sys_counter
17-13-22-374| [ KERNEL] [ 0.155476] NET: Registered protocol family 2
17-13-22-374| [ KERNEL] [ 0.156266] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
17-13-22-374| [ KERNEL] [ 0.156395] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
17-13-22-374| [ KERNEL] [ 0.156583] TCP: Hash tables configured (established 8192 bind 8192)
17-13-22-374| [ KERNEL] [ 0.156692] UDP hash table entries: 512 (order: 2, 16384 bytes)
17-13-22-374| [ KERNEL] [ 0.156748] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
17-13-22-374| [ KERNEL] [ 0.157012] NET: Registered protocol family 1
17-13-22-374| [ KERNEL] [ 3.017402] workingset: timestamp_bits=14 max_order=18 bucket_order=4
17-13-22-374| [ KERNEL] [ 3.105452] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
17-13-22-374| [ KERNEL] [ 3.105472] io scheduler noop registered
17-13-22-374| [ KERNEL] [ 3.105478] io scheduler deadline registered (default)
17-13-22-374| [ KERNEL] [ 3.117164] BCM2708FB: allocated DMA memory fad00000
17-13-22-374| [ KERNEL] [ 3.117231] BCM2708FB: allocated DMA channel 0 @ bb80f000
17-13-22-374| [ KERNEL] [ 3.174991] Console: switching to colour frame buffer device 240x67
17-13-22-374| [ KERNEL] [ 3.212574] bcm2835-rng 3f104000.rng: hwrng registered
17-13-22-374| [ KERNEL] [ 3.212880] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
17-13-22-374| [ KERNEL] [ 3.215227] vc-sm: Videocore shared memory driver
17-13-22-374| [ KERNEL] [ 3.227990] zram: Added device: zram0
17-13-22-374| [ KERNEL] [ 3.228069] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
17-13-22-374| [ KERNEL] [ 3.456391] Core Release: 2.80a
17-13-22-374| [ KERNEL] [ 3.456411] Setting default values for core params
17-13-22-374| [ KERNEL] [ 3.456446] Finished setting default values for core params
17-13-22-374| [ KERNEL] [ 3.656857] Using Buffer DMA mode
17-13-22-374| [ KERNEL] [ 3.656869] Periodic Transfer Interrupt Enhancement - disabled
17-13-22-374| [ KERNEL] [ 3.656873] Multiprocessor Interrupt Enhancement - disabled
17-13-22-374| [ KERNEL] [ 3.656884] OTG VER PARAM: 0, OTG VER FLAG: 0
17-13-22-374| [ KERNEL] [ 3.656982] Dedicated Tx FIFOs mode
17-13-22-374| [ KERNEL] [ 3.657719] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad14000 dma = 0xfad14000 len=9024
17-13-22-374| [ KERNEL] [ 3.657754] FIQ FSM acceleration enabled for :
17-13-22-374| [ KERNEL] [ 3.657754] Non-periodic Split Transactions
17-13-22-374| [ KERNEL] [ 3.657754] Periodic Split Transactions
17-13-22-374| [ KERNEL] [ 3.657754] High-Speed Isochronous Endpoints
17-13-22-374| [ KERNEL] [ 3.657754] Interrupt/Control Split Transaction hack enabled
17-13-22-374| [ KERNEL] [ 3.657763] dwc_otg: Microframe scheduler enabled
17-13-22-374| [ KERNEL] [ 3.657861] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397770
17-13-22-374| [ KERNEL] [ 3.657873] WARN::hcd_init_fiq:460: FIQ ASM at 0x80397ad4 length 36
17-13-22-374| [ KERNEL] [ 3.657885] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
17-13-22-374| [ KERNEL] [ 3.657960] dwc_otg 3f980000.usb: DWC OTG Controller
17-13-22-374| [ KERNEL] [ 3.658022] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
17-13-22-374| [ KERNEL] [ 3.658068] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
17-13-22-374| [ KERNEL] [ 3.658117] Init: Port Power? op_state=1
17-13-22-374| [ KERNEL] [ 3.658123] Init: Power Port (0)
17-13-22-374| [ KERNEL] [ 3.658414] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
17-13-22-374| [ KERNEL] [ 3.658427] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
17-13-22-374| [ KERNEL] [ 3.658436] usb usb1: Product: DWC OTG Controller
17-13-22-374| [ KERNEL] [ 3.658445] usb usb1: Manufacturer: Linux 4.9.75 dwc_otg_hcd
17-13-22-374| [ KERNEL] [ 3.658453] usb usb1: SerialNumber: 3f980000.usb
17-13-22-374| [ KERNEL] [ 3.659782] hub 1-0:1.0: USB hub found
17-13-22-374| [ KERNEL] [ 3.659876] hub 1-0:1.0: 1 port detected
17-13-22-374| [ KERNEL] [ 3.660911] dwc_otg: FIQ enabled
17-13-22-374| [ KERNEL] [ 3.660918] dwc_otg: NAK holdoff enabled
17-13-22-374| [ KERNEL] [ 3.660924] dwc_otg: FIQ split-transaction FSM enabled
17-13-22-374| [ KERNEL] [ 3.661071] Module dwc_common_port init
17-13-22-374| [ KERNEL] [ 3.661904] usbcore: registered new interface driver usbtouchscreen
17-13-22-374| [ KERNEL] [ 3.664143] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
17-13-22-374| [ KERNEL] [ 3.665051] bcm2835-cpufreq: min=600000 max=800000
17-13-22-374| [ KERNEL] [ 3.666594] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
17-13-22-374| [ KERNEL] [ 3.668807] ledtrig-cpu: registered to indicate activity on CPUs
17-13-22-374| [ KERNEL] [ 3.669419] hidraw: raw HID events driver (C) Jiri Kosina
17-13-22-374| [ KERNEL] [ 3.672679] usbcore: registered new interface driver usbhid
17-13-22-374| [ KERNEL] [ 3.672692] usbhid: USB HID core driver
17-13-22-374| [ KERNEL] [ 3.678190] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
17-13-22-374| [ KERNEL] [ 3.708051] [vc_sm_connected_init]: start
17-13-22-374| [ KERNEL] [ 3.718292] [vc_sm_connected_init]: end - returning 0
17-13-22-374| [ KERNEL] [ 3.718722] NET: Registered protocol family 17
17-13-22-374| [ KERNEL] [ 3.718974] Registering SWP/SWPB emulation handler
17-13-22-374| [ KERNEL] [ 3.720131] registered taskstats version 1
17-13-22-374| [ KERNEL] [ 3.729020] sdhost: log_buf @ bad13000 (fad13000)
17-13-22-374| [ KERNEL] [ 3.803701] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
17-13-22-374| [ KERNEL] [ 3.803843] of_cfs_init
17-13-22-374| [ KERNEL] [ 3.803970] of_cfs_init: OK
17-13-22-374| [ KERNEL] [ 3.819227] Freeing unused kernel memory: 5120K
17-13-22-374| [ KERNEL] [ 3.883941] Indeed it is in host mode hprt0 = 00021501
17-13-22-374| [ KERNEL] [ 3.950983] mmc0: host does not support reading read-only switch, assuming write-enable
17-13-22-374| [ KERNEL] [ 3.953067] mmc0: new high speed SDHC card at address 1234
17-13-22-374| [ KERNEL] [ 3.954113] mmcblk0: mmc0:1234 SA08G 7.21 GiB
17-13-22-374| [ KERNEL] [ 3.956763] mmcblk0: p1
17-13-22-374| [ hotplug] [ 3.959301] Block device 179:1. No action.
17-13-22-374| [ hotplug] [ 3.962146] Block device 179:0. No action.
17-13-22-374| [ KERNEL] [ 3.975259] random: fast init done
17-13-22-374| [ KERNEL] [ 4.083783] usb 1-1: new high-speed USB device number 2 using dwc_otg
17-13-22-374| [ KERNEL] [ 4.083937] Indeed it is in host mode hprt0 = 00001101
17-13-22-374| [ hotplug] [ 4.140630] Block device 254:0. No action.
17-13-22-374| [ pfac] [ 4.164772] Run /sbin/initrd.
17-13-22-374| [ pfac] [ 4.164907] Ok, PID 594.
17-13-22-374| [ initrd] [ 4.168650] WTware shell 5.6.24/RPi
17-13-22-374| [ initrd] [ 4.203535] HDD/MMC/SD boot.
17-13-22-374| [ KERNEL] [ 4.313971] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
17-13-22-374| [ KERNEL] [ 4.313986] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
17-13-22-374| [ KERNEL] [ 4.314949] hub 1-1:1.0: USB hub found
17-13-22-374| [ KERNEL] [ 4.315113] hub 1-1:1.0: 5 ports detected
17-13-22-374| [ KERNEL] [ 4.633700] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
17-13-22-374| [ KERNEL] [ 4.764037] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
17-13-22-374| [ KERNEL] [ 4.764052] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
17-13-22-374| [ KERNEL] [ 4.863704] usb 1-1.5: new full-speed USB device number 4 using dwc_otg
17-13-22-374| [ KERNEL] [ 5.008206] usb 1-1.5: New USB device found, idVendor=045e, idProduct=0745
17-13-22-374| [ KERNEL] [ 5.008222] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
17-13-22-374| [ KERNEL] [ 5.008232] usb 1-1.5: Product: Microsoft® 2.4GHz Transceiver v8.0
17-13-22-374| [ KERNEL] [ 5.008242] usb 1-1.5: Manufacturer: Microsoft
17-13-22-374| [ KERNEL] [ 5.018235] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:045E:0745.0001/input/input0
17-13-22-374| [ KERNEL] [ 5.085345] hid-generic 0003:045E:0745.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft® 2.4GHz Transceiver v8.0] on usb-3f980000.usb-1.5/input0
17-13-22-374| [ KERNEL] [ 5.103108] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:045E:0745.0002/input/input1
17-13-22-374| [ KERNEL] [ 5.164499] hid-generic 0003:045E:0745.0002: input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft® 2.4GHz Transceiver v8.0] on usb-3f980000.usb-1.5/input1
17-13-22-374| [ KERNEL] [ 5.204628] input: Microsoft Microsoft® 2.4GHz Transceiver v8.0 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.2/0003:045E:0745.0003/input/input2
17-13-22-374| [ initrd] [ 5.255670] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
17-13-22-374| /--- FILE "/bootmedia/config.txt" -----------------------
17-13-22-374| | # For more options and information see
17-13-22-374| | # http://www.raspberrypi.org/documentation/configuration/config-txt.md
17-13-22-374| | # Some settings may impact device functionality. See link above for details
17-13-22-374| | # Uncomment if you get no picture on HDMI for a default "safe" mode.
17-13-22-374| | #hdmi_safe=1
17-13-22-374| | # Uncomment this if your display has a black border of unused pixels visible
17-13-22-374| | # and your display can output without overscan.
17-13-22-374| | disable_overscan=1
17-13-22-374| | # Uncomment if hdmi display is not detected and composite is being output.
17-13-22-374| | #hdmi_force_hotplug=1
17-13-22-374| | # Uncomment to force a specific HDMI mode (this will force VGA).
17-13-22-374| | #hdmi_group=1
17-13-22-374| | #hdmi_mode=1
17-13-22-374| | # Force the monitor to HDMI mode so that sound will be sent over HDMI cable.
17-13-22-374| | #hdmi_drive=2
17-13-22-374| | # Uncomment to increase signal to HDMI, if you have interference, blanking, or
17-13-22-374| | # no display.
17-13-22-374| | #config_hdmi_boost=4
17-13-22-374| | # Uncomment to overclock the arm. 700 MHz is the default.
17-13-22-374| | arm_freq=800
17-13-22-374| | disable_splash=1
17-13-22-374| | #hdmi_group=2
17-13-22-374| | # 800x600: hdmi_mode=9
17-13-22-374| | # 1024x768: hdmi_mode=16
17-13-22-374| | # 1280x1024: hdmi_mode=35
17-13-22-374| | # 1360x768: hdmi_mode=39
17-13-22-374| | # 1400x1050: hdmi_mode=42
17-13-22-374| | # 1440x900: hdmi_mode=47
17-13-22-374| | # 1600x1200: hdmi_mode=51
17-13-22-374| | # 1680x1050: hdmi_mode=58
17-13-22-374| | # 1366x768: hdmi_mode=81
17-13-22-374| | # 1920x1080: hdmi_mode=82
17-13-22-374| | # 1920x1200: hdmi_mode=69
17-13-22-374| | framebuffer_depth=32
17-13-22-374| | # Uncomment for 16-bit color. It is up to two
17-13-22-374| | # times faster than default 32-bit.
17-13-22-374| | #framebuffer_depth=16
17-13-22-374| | # Enable onboard audio (HDMI or jack).
17-13-22-374| | dtparam=audio=on
17-13-22-374| | # Removes the warning overlay.
17-13-22-374| | #avoid_warnings=1
17-13-22-374| | # Additionally allows turbo when low-voltage is present.
17-13-22-374| | #avoid_warnings=2
17-13-22-374| | graphic=a
17-13-22-374| \----------------------------------------------------
17-13-22-374| [ KERNEL] [ 5.275003] hid-generic 0003:045E:0745.0003: input,hiddev0,hidraw2: USB HID v1.11 Device [Microsoft Microsoft® 2.4GHz Transceiver v8.0] on usb-3f980000.usb-1.5/input2
17-13-22-374| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
17-13-22-374| | clientIP = *
17-13-22-374| | config = local
17-13-22-374| [ initrd] [ 7.289382] Load ethernet drivers.
17-13-22-374| [ initrd] [ 7.294505] modprobe smsc95xx.
17-13-22-374| [ KERNEL] [ 7.309594] smsc95xx v1.0.5
17-13-22-374| [ KERNEL] [ 7.403477] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:ad:ee:60
17-13-22-374| [ KERNEL] [ 7.404682] usbcore: registered new interface driver smsc95xx
17-13-22-374| [ KERNEL] [ 7.506242] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
17-13-22-374| [ KERNEL] [ 8.926436] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xD1E1
17-13-22-374| [ KERNEL] [ 9.204376] random: crng init done
17-13-22-374| [ initrd] [ 9.547593] dhcp: 328 bytes from 192.168.88.1.
17-13-22-374| [ initrd] [ 9.547721] 00000000:000001340000000000110000C0A85801C0A858E4004300440134000002010600 ...4.........X...X..C.D.4......
17-13-22-374| [ initrd] [ 9.547827] 00000020:67458B6B0000000000000000C0A858E4C0A8580100000000B827EBADEE600000 gE.k..........X...X......'...`..
17-13-22-374| [ initrd] [ 9.547929] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-13-22-374| [ initrd] [ 9.548024] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-13-22-374| [ initrd] [ 9.548118] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-13-22-374| [ initrd] [ 9.548215] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-13-22-374| [ initrd] [ 9.548311] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-13-22-374| [ initrd] [ 9.548408] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-13-22-374| [ initrd] [ 12.860255] dhcp: 328 bytes from 192.168.88.1.
17-13-22-374| [ initrd] [ 12.860453] 00000000:000001340000000000110000C0A85801C0A858E4004300440134000002010600 ...4.........X...X..C.D.4......
17-13-22-374| [ initrd] [ 12.860561] 00000020:67458B6B0000000000000000C0A858E4C0A8580100000000B827EBADEE600000 gE.k..........X...X......'...`..
17-13-22-374| [ initrd] [ 12.860656] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-13-22-374| [ initrd] [ 12.860757] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-13-22-374| [ initrd] [ 12.860858] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-13-22-374| [ initrd] [ 12.860960] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-13-22-374| [ initrd] [ 12.861058] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-13-22-374| [ initrd] [ 12.861155] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
17-13-22-374| [ initrd] [ 12.910155] [DHCP] DHCP server address 192.168.88.1.
17-13-22-374| [ initrd] [ 12.910281] [DHCP] IP 192.168.88.228 mask 255.255.255.0.
17-13-22-374| [ initrd] [ 12.910383] [DHCP] Default gateway 192.168.88.1.
17-13-22-374| [ initrd] [ 12.910480] [DHCP] DNS 192.168.88.1.
17-13-22-374| [ initrd] [ 12.910614] [DHCP] DNS 192.168.8.1.
17-13-22-374| [ initrd] [ 12.910719] [DHCP] TFTP from siaddr 192.168.88.1.
17-13-22-374| [ initrd] [ 12.910822] [DHCP] TFTP 192.168.88.1.
17-13-22-374| [ initrd] [ 12.910921] [DHCP] No boot file from DHCP.
17-13-22-374| [ initrd] [ 12.911021] [DHCP] TFTP binary "", configs prefix "", using "/" slash.
17-13-22-374| WTC listener is active.
17-13-22-374| WTC broadcast listener is active.
17-13-22-374| Send broadcast WTCU discover.
17-13-22-374| [ initrd] [ 12.913624] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
17-13-22-374| [ pfac] [ 12.913894] Run /sbin/httpd.
17-13-22-374| [ pfac] [ 12.914089] Ok, PID 635.
17-13-22-374| [ httpd] [ 12.922847] HTTP Server, WTware 5.6.24/RPi
17-13-22-374| [ initrd] [ 13.047671] USB: 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth.
17-13-22-374| [ initrd] [ 13.047880] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
17-13-22-374| [ initrd] [ 13.047999] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
17-13-22-374| [ initrd] [ 13.048437] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
17-13-22-374| [ initrd] [ 13.049350] Common local disk config:
17-13-22-374| /--- FILE "/tmp/config.wtc" -----------------------
17-13-22-374| | [BOM]
17-13-22-374| | server = 192.168.88.252
17-13-22-374| /--- FILE "/etc/config.compiled" -----------------------
17-13-22-374| | server=192.168.88.252
17-13-22-374| | connection
17-13-22-374| [ initrd] [ 13.050794] Hostname: "wtwB827EBADEE60".
17-13-22-374| Everyone can control terminal by RSH.
17-13-22-374| RSH: listener is active.
17-13-22-374| [ httpd] [ 13.330389] Reread settings.
17-13-22-374| [ httpd] [ 13.330602] Everyone can control terminal by HTTP.
17-13-22-374| [ gm] [ 13.335406] WTware session manager 5.6.24/RPi.
17-13-22-374| [ gm] [ 13.336903] Add keyboard event2: Microsoft Microsoft® 2.4GHz Transceiver v8.0.
17-13-22-374| [ gm] [ 13.337060] Add keyboard event1: Microsoft Microsoft® 2.4GHz Transceiver v8.0.
17-13-22-374| [ gm] [ 13.337176] Add keyboard event0: Microsoft Microsoft® 2.4GHz Transceiver v8.0.
17-13-22-374| [ gm] [ 13.337368] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
17-13-22-374| [ gm] [ 13.370334] Framebuffer device found.
17-13-22-374| [ gm] [ 13.370496] LINELENBYTES 7680
17-13-22-374| [ gm] [ 13.370608] VLEN 8294400
17-13-22-374| [ gm] [ 13.405240] Use /lib/ui32.so.
17-13-22-374| [ gm] [ 13.517276] Run '/sbin/resolver 0x5a7aa8 dns [192.168.88.252]', log '', env '', pid ''.
17-13-22-374| [ pfac] [ 13.517537] Run /sbin/resolver 0x5a7aa8 dns [192.168.88.252].
17-13-22-374| [ gm] [ 13.517832] Nobody can control terminal by VNC.
17-13-22-374| [ pfac] [ 13.518164] Ok, PID 637.
17-13-22-374| [ pfac] [ 13.528256] Process pid 637 terminated, status 00000000.
17-13-22-374| [ gm] [ 13.534622] 192.168.88.252 => 192.168.88.252.
17-13-22-374| [ gm] [ 13.547232] Free ram before fork terminal client /sbin/rdpclient (session 1): 925264 Kb.
17-13-22-374| [ pfac] [ 13.547426] Run /sbin/rdpclient 1.
17-13-22-374| [ gm] [ 13.547517] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
17-13-22-374| [ pfac] [ 13.547854] Ok, PID 638.
17-13-22-374| [ rdpclient 638] [ 13.559534] RDP Terminal Client, WTware 5.6.24/RPi, pipe 1, pid 638.
17-13-22-374| [ rdpclient 638] [ 13.561095] Use /lib/ui32.so.
17-13-22-374| [ rdpclient 638] [ 13.563484] Make RDP session with 192.168.88.252, port 3389.
17-13-22-374| [ rdpclient 638] [ 13.563731] No username.
17-13-22-374| [ rdpclient 638] [ 13.564469] No password.
17-13-22-374| [ rdpclient 638] [ 13.565530] No PIN.
17-13-22-374| [ rdpclient 638] [ 13.566120] No domain.
17-13-22-374| [ rdpclient 638] [ 13.566460] No shell.
17-13-22-374| [ rdpclient 638] [ 13.566997] No directory.
17-13-22-374| [ rdpclient 638] [ 13.567336] Window: 1920x1080@24.
17-13-22-374| [ rdpclient 638] [ 13.567578] PFlags 0x0000002F.
17-13-22-374| [ rdpclient 638] [ 13.568178] Keyboard 00000409:00000000.
17-13-22-374| [ rdpclient 638] [ 13.568467] My hostname "wtwB827EBADEE60".
17-13-22-374| [ rdpclient 638] [ 13.568862] TCP: connecting to 192.168.88.252:3389.
17-13-22-374| [ rdpclient 638] [ 13.569183] TCP: connection with 192.168.88.252:3389 established.
17-13-22-374| [ rdpclient 638] [ 13.569425] Turn keepalive on.
17-13-22-374| [ rdpclient 638] [ 13.569742] Free ram after buffers allocation: 925016 KB.
17-13-22-377| Connection from wtc.exe at 192.168.88.252.
