Не загружается Chrom
Spider84
Сообщение Spider84 »
Настроил в режиме Хром Киоска.
Система загружается до надписи Пожалуйста подождите... и всё. В логах следующее:
Mar 29 10:39:39 192.168.10.12  [            gm] [   62.337352] [TFTP] Download and unpack file 5.8.90/pi2/localboot/packages/chprf from 192.168.10.100.
Mar 29 10:39:43 192.168.10.12  [            gm] [   66.475647] [TFTP] Download and unpack file 5.8.90/pi2/localboot/packages/pi2-chrome from 192.168.10.100.
Mar 29 10:40:53 192.168.10.12  [            gm] [  136.006862] Run '/usr/lib/chromium-browser/chromium-browser-v7 --window-size=1280,1024 --window-position=0,0 --disable-ipv6 --wm-window-animations-disabled --no-default-browser-check --password-store=basic --disable-infobars --show-component-extension-options --ignore-gpu-blacklist --disable-pings --media-router=0 --enable-remote-extensions --enable-low-res-tiling --disable-smooth-scrolling --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=99.99.999.999 --noerrdialogs --kiosk https://***/ --alsa-output-device=plughw:0', log '/tmp/Xapp00.out', env 'DISPLAY=:0.0 LANG=ru_RU.utf8 LANGUAGE=ru_RU GOOGLE_API_KEY=AIzaSyCkfPOPZXDKNn8hhgu3JrA62wIgC93d44k GOOGLE_DEFAULT_CLIENT_ID=811574891467.apps.googleusercontent.com GOOGLE_DEFAULT_CLIENT_SECRET=kdloedMFGdGla2P1zacGjAQh CHROME_VERSION_EXTRA=WTware', pid '/tmp/Xapp00.pidpipe'.
Mar 29 10:40:53 192.168.10.12  [          pfac] [  136.011757] Run /usr/lib/chromium-browser/chromium-browser-v7 --window-size=1280,1024 --window-position=0,0 --disable-ipv6 --wm-window-animations-disabled --no-default-browser-check --password-store=basic --disable-infobars --show-component-extension-options --ignore-gpu-blacklist --disable-pings --media-router=0 --enable-remote-extensions --enable-low-res-tiling --disable-smooth-scrolling --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=99.99.999.999 --noerrdialogs --kiosk https://***/ --alsa-output-device=plughw:0.
Mar 29 10:40:53 192.168.10.12  [          pfac] [  136.012108] Ok, PID 761.
Mar 29 10:40:54 192.168.10.12  [            gm] [  137.008280] Success, pid 761.
Mar 29 10:40:54 192.168.10.12  [            gm] [  137.008601] Everyone can control terminal by VNC.
Mar 29 10:40:54 192.168.10.12  [            gm] [  137.008725] [VNC] Listener at port 5900.
Mar 29 10:40:54 192.168.10.12  [            gm] [  137.008828] Nobody can control terminal by WTRC.
Mar 29 10:40:56 192.168.10.12  [SYSLOG] <37>Feb 17 06:02:15 dbus-daemon[694]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.1" (uid=1007 pid=761 comm="/usr/lib/chromium-browser/chromium-browser-v7 --wi") interface="org.freedesktop.DBus.ObjectManager" member="GetManagedObjects" error name="(unset)" requested_reply="0" destination="org.bluez" (bus)
Mar 29 10:40:56 192.168.10.12  [           X00] [  139.405274] libEGL warning: DRI2: failed to authenticate
Mar 29 10:40:57 192.168.10.12  [            gm] [  139.748733] [UUI] Bind window 0x00400001 (pid 761, ppid 1) to the screen 1.
Mar 29 10:40:57 192.168.10.12  [           X00] [  139.889357] [804:811:0217/060216.768732:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for www.gstatic.com failed err=-8181
Mar 29 10:40:57 192.168.10.12  [           X00] [  139.891797] [804:810:0217/060216.771443:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:40:57 192.168.10.12  [           X00] [  139.892379] [804:810:0217/060216.772102:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.103880] [804:811:0217/060216.983509:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for accounts.google.com failed err=-8181
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.120170] [804:810:0217/060216.984830:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.143456] [804:809:0217/060217.023057:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for redirector.gvt1.com failed err=-8181
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.145808] [804:810:0217/060217.025449:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:40:57 192.168.10.12  [SYSLOG] <30>Feb 17 06:02:17 dbus-daemon[694]: [system] Activating service name='org.freedesktop.UPower' requested by ':1.2' (uid=1007 pid=761 comm="/usr/lib/chromium-browser/chromium-browser-v7 --wi") (using servicehelper)
Mar 29 10:40:57 192.168.10.12  [SYSLOG] <30>Feb 17 06:02:17 dbus-daemon[694]: [system] Activated service 'org.freedesktop.UPower' failed: Failed to execute program org.freedesktop.UPower: No such file or directory
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.228530] [761:849:0217/060217.108151:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.Spawn.ExecFailed: Failed to execute program org.freedesktop.UPower: No such file or directory
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.255349] [761:849:0217/060217.135066:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.Spawn.ExecFailed: Failed to execute program org.freedesktop.UPower:No such file or directory
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.282812] [761:849:0217/060217.162480:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.UPower.EnumerateDevices: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.Spawn.ExecFailed: Failed to execute program org.freedesktop.UPower:No such file or directory
Mar 29 10:40:58 192.168.10.12  [           X00] [  141.260800] [800:800:0217/060218.139753:ERROR:sandbox_linux.cc(369)] InitializeSandbox() called with multiple threads in process gpu-process.
Mar 29 10:40:58 192.168.10.12  [           X00] [  141.338536] [804:810:0217/060218.218144:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:01 192.168.10.12  [           X00] [  144.191462] [804:810:0217/060221.071068:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:06 192.168.10.12  [           X00] [  149.379304] [804:809:0217/060226.258945:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for ssl.gstatic.com failed err=-8181
Mar 29 10:41:06 192.168.10.12  [           X00] [  149.380733] [804:810:0217/060226.260454:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:06 192.168.10.12  [           X00] [  149.381046] [804:810:0217/060226.260827:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:09 192.168.10.12  [           X00] [  152.107851] [804:809:0217/060228.987481:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for clients2.google.com failed err=-8181
Mar 29 10:41:09 192.168.10.12  [           X00] [  152.109268] [804:810:0217/060228.988983:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:10 192.168.10.12  [           X00] [  153.086471] [804:809:0217/060229.966070:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for accounts.google.com failed err=-8181
Mar 29 10:41:10 192.168.10.12  [           X00] [  153.087379] [804:810:0217/060229.967112:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:11 192.168.10.12  [           X00] [  154.326846] [804:809:0217/060231.206432:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for clients2.google.com failed err=-8181
Mar 29 10:41:11 192.168.10.12  [           X00] [  154.328150] [804:810:0217/060231.207858:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:15 192.168.10.12  [           X00] [  158.196558] [804:810:0217/060235.076175:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:23 192.168.10.12  [           X00] [  165.907478] [804:810:0217/060242.787158:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:37 192.168.10.12  [           X00] [  180.128186] [804:810:0217/060257.007872:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:38 192.168.10.12  [           X00] [  181.331757] [804:810:0217/060258.211430:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:57 192.168.10.12  [           X00] [  200.039517] [804:809:0217/060316.919158:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for www.gstatic.com failed err=-8181
Mar 29 10:41:57 192.168.10.12  [           X00] [  200.041246] [804:810:0217/060316.920971:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:42:02 192.168.10.12  [           X00] [  205.334978] [804:811:0217/060322.214658:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for safebrowsing.googleapis.com failed err=-8181
Mar 29 10:42:02 192.168.10.12  [           X00] [  205.335983] [804:810:0217/060322.215732:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:42:08 192.168.10.12  [           X00] [  210.717113] [804:810:0217/060327.595294:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:42:43 192.168.10.12  [           X00] [  246.353073] [804:810:0217/060403.232768:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:43:09 192.168.10.12  [           X00] [  271.512617] [804:810:0217/060428.392304:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Re: Не загружается Chrom
Покажи лог целиком.
Spider84
Mar 29 10:38:46 192.168.10.12  WTware 5.8.90/RPi supervisor.
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] Booting Linux on physical CPU 0x0
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] Linux version 4.19.102-v7 (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-2)) #19 SMP Mon Feb 17 09:17:30 UTC 2020
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] CPU: div instructions available: patching division code
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] Memory policy: Data cache writealloc
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] On node 0 totalpages: 242688
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000]   Normal zone: 1896 pages used for memmap
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000]   Normal zone: 0 pages reserved
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000]   Normal zone: 242688 pages, LIFO batch:63
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] random: get_random_bytes called from 0x807009cc with crng_init=0
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] percpu: Embedded 15 pages/cpu s29132 r8192 d24116 u61440
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] pcpu-alloc: s29132 r8192 d24116 u61440 alloc=15*4096
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240792
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:73:E9:F4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 quiet splash
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] Memory: 942060K/970752K available (5120K kernel code, 134K rwdata, 600K rodata, 5120K init, 349K bss, 20500K reserved, 8192K cma-reserved)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] Virtual kernel memory layout:
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000]     lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (6112 kB)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (5120 kB)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 135 kB)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 350 kB)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] rcu: Hierarchical RCU implementation.
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000017] Switching to timer-based delay loop, resolution 52ns
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000194] Console: colour dummy device 80x30
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000209] console [tty0] enabled
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000246] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000258] pid_max: default: 32768 minimum: 301
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000409] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.000422] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.001032] CPU: Testing write buffer coherency: ok
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.001404] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.001862] Setting up static identity map for 0x100000 - 0x10003c
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.001972] rcu: Hierarchical SRCU implementation.
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.002525] smp: Bringing up secondary CPUs ...
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.003145] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.003829] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.004463] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.004553] smp: Brought up 1 node, 4 CPUs
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.004562] SMP: Total of 4 processors activated (153.60 BogoMIPS).
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.004566] CPU: All CPU(s) started in HYP mode.
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.004569] CPU: Virtualization extensions available.
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.005202] devtmpfs: initialized
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.016284] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.016617] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.016634] futex hash table entries: 1024 (order: 4, 65536 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.017064] pinctrl core: initialized pinctrl subsystem
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.018077] NET: Registered protocol family 16
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.020345] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.027895] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.050038] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-12-11 15:14, variant start
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.060042] raspberrypi-firmware soc:firmware: Firmware hash is 44e6357b14365c3029d973dc32956fc5730dc334
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.108370] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.110879] usbcore: registered new interface driver usbfs
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.110983] usbcore: registered new interface driver hub
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.111074] usbcore: registered new device driver usb
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.112806] clocksource: Switched to clocksource arch_sys_counter
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.125720] NET: Registered protocol family 2
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.126275] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.126306] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.126414] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.126598] TCP: Hash tables configured (established 8192 bind 8192)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.126722] UDP hash table entries: 512 (order: 2, 16384 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.126767] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    0.126938] NET: Registered protocol family 1
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.338913] Initialise system trusted keyrings
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.339087] workingset: timestamp_bits=30 max_order=18 bucket_order=0
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.398506] Key type asymmetric registered
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.398515] Asymmetric key parser 'x509' registered
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.398597] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.398604] io scheduler noop registered
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.398760] io scheduler cfq registered (default)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.403281] bcm2708_fb soc:fb: FB found 1 display(s)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.442733] Console: switching to colour frame buffer device 160x64
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.465112] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1280x1024
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.466999] bcm2835-rng 3f104000.rng: hwrng registered
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.467390] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.468101] vc-sm: Videocore shared memory driver
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.468521] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.469725] zram: Added device: zram0
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.470831] libphy: Fixed MDIO Bus: probed
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.470918] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.498440] dwc_otg 3f980000.usb: base=(ptrval)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.698682] Core Release: 2.80a
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.698691] Setting default values for core params
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.698721] Finished setting default values for core params
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899011] Using Buffer DMA mode
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899017] Periodic Transfer Interrupt Enhancement - disabled
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899022] Multiprocessor Interrupt Enhancement - disabled
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899030] OTG VER PARAM: 0, OTG VER FLAG: 0
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899061] Dedicated Tx FIFOs mode
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899623] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = bad04000 dma = 0xfad04000 len=9024
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899649] FIQ FSM acceleration enabled for :
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899649] Non-periodic Split Transactions
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899649] Periodic Split Transactions
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899649] High-Speed Isochronous Endpoints
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899649] Interrupt/Control Split Transaction hack enabled
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899656] dwc_otg: Microframe scheduler enabled
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899703] WARN::hcd_init_fiq:457: FIQ on core 1
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899711] WARN::hcd_init_fiq:458: FIQ ASM at 803b2300 length 36
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899721] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899742] dwc_otg 3f980000.usb: DWC OTG Controller
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899774] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899807] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899852] Init: Port Power? op_state=1
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.899856] Init: Power Port (0)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.900040] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.900050] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.900057] usb usb1: Product: DWC OTG Controller
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.900065] usb usb1: Manufacturer: Linux 4.19.102-v7 dwc_otg_hcd
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.900072] usb usb1: SerialNumber: 3f980000.usb
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.900681] hub 1-0:1.0: USB hub found
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.900719] hub 1-0:1.0: 1 port detected
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.901418] dwc_otg: FIQ enabled
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.901424] dwc_otg: NAK holdoff enabled
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.901429] dwc_otg: FIQ split-transaction FSM enabled
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.901440] Module dwc_common_port init
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.901811] usbcore: registered new interface driver usbtouchscreen
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.902892] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.903213] bcm2835-cpufreq: min=600000 max=1200000
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.903994] sdhci: Secure Digital Host Controller Interface driver
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.904001] sdhci: Copyright(c) Pierre Ossman
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.904539] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.905189] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.905361] sdhci-pltfm: SDHCI platform and OF driver helper
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.905483] hidraw: raw HID events driver (C) Jiri Kosina
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.906451] usbcore: registered new interface driver usbhid
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.906457] usbhid: USB HID core driver
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.907824] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.909955] [vc_sm_connected_init]: start
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.931809] [vc_sm_connected_init]: end - returning 0
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.933182] NET: Registered protocol family 17
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.933553] Registering SWP/SWPB emulation handler
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.934282] Loading compiled-in X.509 certificates
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.938911] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.938926] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.964226] sdhost: log_buf @ (ptrval) (fad07000)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.998390] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    2.999921] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.001452] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.004201] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.012834] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.012972] of_cfs_init
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.013125] of_cfs_init: OK
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.039026] Freeing unused kernel memory: 5120K
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.089481] Run /init as init process
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.123191] Indeed it is in host mode hprt0 = 00021501
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.185144] random: fast init done
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.252686] mmc1: new high speed SDIO card at address 0001
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.332851] usb 1-1: new high-speed USB device number 2 using dwc_otg
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.333028] Indeed it is in host mode hprt0 = 00001101
Mar 29 10:38:46 192.168.10.12  [       hotplug] [    3.391159] Block device 254:0. No action.
Mar 29 10:38:46 192.168.10.12  [          pfac] [    3.423672] Run /sbin/initrd.
Mar 29 10:38:46 192.168.10.12  [          pfac] [    3.423807] Ok, PID 645.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    3.428348] WTware 5.8.90/RPi shell.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    3.428711] Load font 'ter-c32b.psf', console 80x32.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    3.459602] MMC is not present.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    3.459742] No device '/dev/fb1'.
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.573068] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.573081] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.573739] hub 1-1:1.0: USB hub found
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.573850] hub 1-1:1.0: 5 ports detected
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    3.892842] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.023061] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.023073] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.122841] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.257799] usb 1-1.2: New USB device found, idVendor=27dd, idProduct=0101, bcdDevice= 1.00
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.257810] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.257818] usb 1-1.2: Product: Mindeo Barcode Scanner
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.257826] usb 1-1.2: Manufacturer: Minde Electronics
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.263298] input: Minde Electronics Mindeo Barcode Scanner as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:27DD:0101.0001/input/input0
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.334005] hid-generic 0003:27DD:0101.0001: input,hidraw0: USB HID v1.00 Keyboard [Minde Electronics Mindeo Barcode Scanner] on usb-3f980000.usb-1.2/input0
Mar 29 10:38:46 192.168.10.12  [        initrd] [    4.490582] Load Ethernet drivers.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    4.490727] modprobe lan78xx.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    4.499973] modprobe smsc95xx.
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.501783] usbcore: registered new interface driver lan78xx
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.513071] smsc95xx v1.0.6
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.615776] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:73:e9:f4
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.616010] usbcore: registered new interface driver smsc95xx
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    4.724732] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Mar 29 10:38:46 192.168.10.12  [        KERNEL] [    6.344294] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
Mar 29 10:38:46 192.168.10.12  [        initrd] [    7.630191] dhcp: 340 bytes from 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    7.630327] 00000000:000001400000000000110000C0A80A64C0A80A0C004300440140000002010600  ...@.....#021.....d.....C.D.@......
Mar 29 10:38:46 192.168.10.12  [        initrd] [    7.630407] 00000020:67458B6B0000000000000000C0A80A0CC0A80A6400000000B827EB73E9F40000  gE.k...............d.....'.s....
Mar 29 10:38:46 192.168.10.12  [        initrd] [    7.630500] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
Mar 29 10:38:46 192.168.10.12  [        initrd] [    7.630575] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
Mar 29 10:38:46 192.168.10.12  [        initrd] [    7.630649] 00000080:00000000000000007774776172652F352E382E39302F7774776172652E707865  ........wtware/5.8.90/wtware.pxe
Mar 29 10:38:46 192.168.10.12  [        initrd] [    7.630722] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
Mar 29 10:38:46 192.168.10.12  [        initrd] [    7.630796] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
Mar 29 10:38:46 192.168.10.12  [        initrd] [    7.630869] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
Mar 29 10:38:46 192.168.10.12  [        initrd] [    7.630942] 00000100:0000000000000000638253633501023604C0A80A64330400000E100104FFFFFF  ........c.Sc5..6....d3....#020.....
Mar 29 10:38:46 192.168.10.12  [        initrd] [    7.631015] 00000120:000304C0A80A640604C0A80A640C09726173702D7061636B0F136F6666696365  ......d.....d..rasp-pack.#023office
Mar 29 10:38:46 192.168.10.12  [        initrd] [    7.631088] 00000140:****************************************                          .**********....d.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.820221] dhcp: 340 bytes from 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.820324] 00000000:000001400000000000110000C0A80A64C0A80A0C004300440140000002010600  ...@.....#021.....d.....C.D.@......
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.820401] 00000020:67458B6B0000000000000000C0A80A0CC0A80A6400000000B827EB73E9F40000  gE.k...............d.....'.s....
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.820474] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.820547] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.820620] 00000080:00000000000000007774776172652F352E382E39302F7774776172652E707865  ........wtware/5.8.90/wtware.pxe
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.820693] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.820765] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.820838] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.820911] 00000100:0000000000000000638253633501053604C0A80A64330400000E100104FFFFFF  ........c.Sc5..6....d3....#020.....
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.820983] 00000120:000304C0A80A640604C0A80A640C09726173702D7061636B0F136F6666696365  ......d.....d..rasp-pack.#023office
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.821056] 00000140:2E******************2E72752A04C0A80A64FF                          .*********.ru*....d.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.860092] [DHCP] DHCP server address 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.860171] [DHCP] IP 192.168.10.12 mask 255.255.255.0.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.860245] [DHCP] Default gateway 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.860316] [DHCP] DNS 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.860400] [DHCP] NTP 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.860485] [DHCP] Hostname rasp-pack.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.860563] [DHCP] Domain office.*********.ru.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.860634] [DHCP] TFTP from siaddr 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.860707] [DHCP] TFTP 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.860783] [DHCP] Use default TFTP prefix for Raspberry network boot.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.860869] [DHCP] TFTP binary "5.8.90/", configs prefix "", using "/" slash.
Mar 29 10:38:46 192.168.10.12  WTC listener is active.
Mar 29 10:38:46 192.168.10.12  WTC broadcast listener is active.
Mar 29 10:38:46 192.168.10.12  Send broadcast WTCU discover.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.975608] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.975767] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.975846] USB: 27dd:0101 .
Mar 29 10:38:46 192.168.10.12  [        initrd] [    8.999816] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
Mar 29 10:38:46 192.168.10.12  [          pfac] [    9.000318] Run /sbin/httpd.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.000411] [TFTP] Download config file Everyone/source.wtc from 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [          pfac] [    9.000528] Ok, PID 688.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.009605] [TFTP] 192.168.10.100 is not WTware5 TFTP server.
Mar 29 10:38:46 192.168.10.12  [         httpd] [    9.012712] Internal HTTP Server, WTware 5.8.90/RPi
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.015812] [TFTP] Error code 1: File not found.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.015953] [TFTP] Download config file Everyone/list.wtc from 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.019470] [TFTP] Error code 1: File not found.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.019592] [TFTP] Download config file Terminals/B8.27.EB.73.E9.F4/config.wtc from 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.024113] [TFTP] Download config file Terminals/B8.27.EB.73.E9.F4/wtware.lic from 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.027116] [TFTP] Error code 1: File not found.
Mar 29 10:38:46 192.168.10.12  /--- FILE "/tmp/config.wtc" -----------------------
Mar 29 10:38:46 192.168.10.12  | server=192.168.10.33
Mar 29 10:38:46 192.168.10.12  | animation_speed=off
Mar 29 10:38:46 192.168.10.12  | application=chrome
Mar 29 10:38:46 192.168.10.12  | chrome_language=ru
Mar 29 10:38:46 192.168.10.12  | chrome_mode=kiosk-nopointer
Mar 29 10:38:46 192.168.10.12  | chrome_url=https://***********.ru/pack/
Mar 29 10:38:46 192.168.10.12  | clienthostname=rasp-*IP2
Mar 29 10:38:46 192.168.10.12  | display=
Mar 29 10:38:46 192.168.10.12  | graphic=abcdefg
Mar 29 10:38:46 192.168.10.12  | infobox=never
Mar 29 10:38:46 192.168.10.12  | keyboard=ru
Mar 29 10:38:46 192.168.10.12  | language=ru,default
Mar 29 10:38:46 192.168.10.12  | onerror=quiet
Mar 29 10:38:46 192.168.10.12  | screenswitch=none
Mar 29 10:38:46 192.168.10.12  | sound=on, amixer:cset numid=3 2, stereo
Mar 29 10:38:46 192.168.10.12  | syslog=192.168.10.100
Mar 29 10:38:46 192.168.10.12  | timezone=Omsk Standard Time,  local:Asia/Omsk
Mar 29 10:38:46 192.168.10.12  | user=Фасовка:\x31\x31\x31\x31; --only-listed--
Mar 29 10:38:46 192.168.10.12  | vnc=on
Mar 29 10:38:46 192.168.10.12  | vnc_password=******
Mar 29 10:38:46 192.168.10.12  | connection
Mar 29 10:38:46 192.168.10.12  \----------------------------------------------------
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.027866] [TFTP] Download config file Everyone/all.wtc from 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.031067] [TFTP] Error code 1: File not found.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.031153] [TFTP] Download config file Everyone/wtware.lic from 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.034628] [TFTP] Error code 1: File not found.
Spider84
Mar 29 10:38:46 192.168.10.12  /--- FILE "/etc/config.compiled" -----------------------
Mar 29 10:38:46 192.168.10.12  | [BOM]
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.038380] Hostname: "rasp--10-12".
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.270458] [TFTP] Download and unpack file 5.8.90/pi2/localboot/packages/tz from 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.476974] Run '/bin/sh /tmp/ntpdate', log '/tmp/ntp.out', env '', pid ''.
Mar 29 10:38:46 192.168.10.12  [          pfac] [    9.477139] Run /bin/sh /tmp/ntpdate.
Mar 29 10:38:46 192.168.10.12  Everyone can control terminal by RSH.
Mar 29 10:38:46 192.168.10.12  RSH: listener is active.
Mar 29 10:38:46 192.168.10.12  [          pfac] [    9.487254] Ok, PID 689.
Mar 29 10:38:46 192.168.10.12  [         httpd] [    9.487478] Reread settings.
Mar 29 10:38:46 192.168.10.12  [        initrd] [    9.487606] [TFTP] Download and unpack file 5.8.90/pi2/localboot/packages/pi2-u from 192.168.10.100.
Mar 29 10:38:46 192.168.10.12  [         httpd] [    9.487686] Everyone can control terminal by HTTP.
Mar 29 10:38:46 192.168.10.12  [           NTP] [    9.492085] ntpd: sending query to 192.168.10.100
Mar 29 10:38:47 192.168.10.12  [        KERNEL] [   10.151588] random: crng init done
Mar 29 10:38:50 192.168.10.12  [        initrd] [   13.231691] [TFTP] Download and unpack file 5.8.90/pi2/localboot/packages/pi2-dbus from 192.168.10.100.
Mar 29 10:38:51 192.168.10.12  [        initrd] [   14.137017] +--- Executing "/usr/bin/dbus-uuidgen --ensure"
Mar 29 10:38:51 192.168.10.12  [        initrd] [   14.146385] +- Errorlevel: 0, output:
Mar 29 10:38:51 192.168.10.12  File is empty.
Mar 29 10:38:51 192.168.10.12  [        initrd] [   14.146764] +------------------------
Mar 29 10:38:51 192.168.10.12  [        initrd] [   14.146855] +--- Executing "/usr/bin/dbus-daemon --system "
Mar 29 10:38:51 192.168.10.12  [        initrd] [   14.194673] +- Errorlevel: 0, output:
Mar 29 10:38:51 192.168.10.12  [        initrd] [   14.195109] +------------------------
Mar 29 10:38:51 192.168.10.12  [        initrd] [   14.195222] Run '/usr/bin/dbus-daemon --session --address=unix:path=/run/user/1007/bus', log '', env '', pid ''.
Mar 29 10:38:51 192.168.10.12  [          pfac] [   14.195733] Run /usr/bin/dbus-daemon --session --address=unix:path=/run/user/1007/bus.
Mar 29 10:38:51 192.168.10.12  [          pfac] [   14.195881] Ok, PID 696.
Mar 29 10:38:51 192.168.10.12  [            gm] [   14.223695] WTware 5.8.90/RPi session manager.
Mar 29 10:38:51 192.168.10.12  [            gm] [   14.226336] [TFTP] Download and unpack file 5.8.90/pi2/localboot/packages/pi2-lstdcpp from 192.168.10.100.
Mar 29 10:38:52 192.168.10.12  [            gm] [   14.559902] [TFTP] Download and unpack file 5.8.90/pi2/localboot/packages/pi2-xml2 from 192.168.10.100.
Mar 29 10:38:56 192.168.10.12  [           NTP] [   19.492770] Alarm clock
Mar 29 10:38:57 192.168.10.12  [           NTP] [   19.496344] hwclock: can't open '/dev/misc/rtc': No such file or directory
Mar 29 10:38:57 192.168.10.12  [          pfac] [   19.497611] Process pid 689 terminated, status 00000000.
Mar 29 10:39:06 192.168.10.12  [            gm] [   28.613883] /lib/arm-linux-gnueabihf/liblzma.so.5.2.4 already exist. Do not overwrite.
Mar 29 10:39:06 192.168.10.12  [            gm] [   28.691432] [TFTP] Download and unpack file 5.8.90/pi2/localboot/packages/pi2-uetc from 192.168.10.100.
Mar 29 10:39:34 192.168.10.12  [            gm] [   57.266251] [TFTP] Download and unpack file 5.8.90/pi2/localboot/packages/ufont from 192.168.10.100.
Mar 29 10:39:38 192.168.10.12  [            gm] [   60.548006] Add keyboard event0: Minde Electronics Mindeo Barcode Scanner.
Mar 29 10:39:38 192.168.10.12  [            gm] [   60.548374] Display mode: 1280x1024, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
Mar 29 10:39:38 192.168.10.12  /--- FILE "/etc/xorg.conf" -----------------------
Mar 29 10:39:38 192.168.10.12  | Section     "InputDevice"
Mar 29 10:39:38 192.168.10.12  |  Identifier "Keyboard0"
Mar 29 10:39:38 192.168.10.12  |  Driver     "evdev"
Mar 29 10:39:38 192.168.10.12  |  Option     "Device" "/dev/input/event0"
Mar 29 10:39:38 192.168.10.12  |  Option     "SendCoreEvents" "on"
Mar 29 10:39:38 192.168.10.12  |  Option     "XkbLayout" "ru,us"
Mar 29 10:39:38 192.168.10.12  |  Option     "XkbRules" "evdev"
Mar 29 10:39:38 192.168.10.12  |  Option     "XkbOptions" "grp:ctrl_shift_toggle"
Mar 29 10:39:38 192.168.10.12  | EndSection
Mar 29 10:39:38 192.168.10.12  | Section "ServerFlags"
Mar 29 10:39:38 192.168.10.12  |  Option  "DontVTSwitch"   "on"
Mar 29 10:39:38 192.168.10.12  |  Option  "DontZoom"       "on"
Mar 29 10:39:38 192.168.10.12  |  Option  "DontZap"        "on"
Mar 29 10:39:38 192.168.10.12  |  Option  "NoPM"           "on"
Mar 29 10:39:38 192.168.10.12  |  Option  "AutoAddDevices" "off"
Mar 29 10:39:38 192.168.10.12  | Section "Device"
Mar 29 10:39:38 192.168.10.12  |  Identifier "Video0"
Mar 29 10:39:38 192.168.10.12  |  Driver "fbturbo"
Mar 29 10:39:38 192.168.10.12  | Section "Monitor"
Mar 29 10:39:38 192.168.10.12  |  Identifier "Monitor0"
Mar 29 10:39:38 192.168.10.12  |  HorizSync 20-200
Mar 29 10:39:38 192.168.10.12  |  VertRefresh 50-60
Mar 29 10:39:38 192.168.10.12  |  Option "PreferredMode"  "1280x1024"
Mar 29 10:39:38 192.168.10.12  | Section "Screen"
Mar 29 10:39:38 192.168.10.12  |  Identifier "Screen0"
Mar 29 10:39:38 192.168.10.12  |  Device  "Video0"
Mar 29 10:39:38 192.168.10.12  |  Monitor  "Monitor0"
Mar 29 10:39:38 192.168.10.12  |  DefaultDepth 24
Mar 29 10:39:38 192.168.10.12  |  SubSection "Display"
Mar 29 10:39:38 192.168.10.12  |   Depth  24
Mar 29 10:39:38 192.168.10.12  |   Modes  "1280x1024"
Mar 29 10:39:38 192.168.10.12  |   Virtual 1280 1024
Mar 29 10:39:38 192.168.10.12  |  EndSubSection
Mar 29 10:39:38 192.168.10.12  | Section "ServerLayout"
Mar 29 10:39:38 192.168.10.12  |  Identifier  "Layout"
Mar 29 10:39:38 192.168.10.12  |  Screen      "Screen0"
Mar 29 10:39:38 192.168.10.12  |  InputDevice "Keyboard0"
Mar 29 10:39:38 192.168.10.12  \----------------------------------------------------
Mar 29 10:39:38 192.168.10.12  [            gm] [   60.682575] Run '/usr/lib/xorg/Xorg -nolisten inet6 -s 0 -quiet -logfile /tmp/Xorg.0.log -nocursor', log '/tmp/Xorg.out', env '', pid ''.
Mar 29 10:39:38 192.168.10.12  [          pfac] [   60.682802] Run /usr/lib/xorg/Xorg -nolisten inet6 -s 0 -quiet -logfile /tmp/Xorg.0.log -nocursor.
Mar 29 10:39:38 192.168.10.12  [          pfac] [   60.683136] Ok, PID 700.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.715790] [    60.715]
Mar 29 10:39:38 192.168.10.12  [             X] [   60.715903] X.Org X Server 1.20.4
Mar 29 10:39:38 192.168.10.12  [             X] [   60.715955] X Protocol Version 11, Revision 0
Mar 29 10:39:38 192.168.10.12  [             X] [   60.715997] [    60.715] Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
Mar 29 10:39:38 192.168.10.12  [             X] [   60.716078] [    60.715] Current Operating System: Linux wtware 4.19.102-v7 #19 SMP Mon Feb 17 09:17:30 UTC 2020 armv7l
Mar 29 10:39:38 192.168.10.12  [             X] [   60.716118] [    60.715] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:73:E9:F4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 quiet splash
Mar 29 10:39:38 192.168.10.12  [             X] [   60.716158] [    60.715] Build Date: 05 June 2019  12:49:54PM
Mar 29 10:39:38 192.168.10.12  [             X] [   60.716196] [    60.715] xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
Mar 29 10:39:38 192.168.10.12  [             X] [   60.716229] [    60.716] Current version of pixman: 0.36.0
Mar 29 10:39:38 192.168.10.12  [             X] [   60.716259] [    60.716] #011Before reporting problems, check http://wiki.x.org
Mar 29 10:39:38 192.168.10.12  [             X] [   60.716291] #011to make sure that you have the latest version.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.716371] [    60.716] Markers: (--) probed, (**) from config file, (==) default setting,
Mar 29 10:39:38 192.168.10.12  [             X] [   60.716418] #011(++) from command line, (!!) notice, (II) informational,
Mar 29 10:39:38 192.168.10.12  [             X] [   60.716452] #011(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.716482] [    60.716] (++) Log file: "/tmp/Xorg.0.log", Time: Mon Feb 17 06:00:57 2020
Mar 29 10:39:38 192.168.10.12  [             X] [   60.716638] [    60.716] (==) Using config file: "/etc/xorg.conf"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.717074] [    60.717] (==) ServerLayout "Layout"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.717156] [    60.717] (**) |-->Screen "Screen0" (0)
Mar 29 10:39:38 192.168.10.12  [             X] [   60.717195] [    60.717] (**) |   |-->Monitor "Monitor0"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.719396] [    60.719] (**) |   |-->Device "Video0"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.719463] [    60.719] (**) |-->Input Device "Keyboard0"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.719527] [    60.719] (**) Option "DontVTSwitch" "on"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.719562] [    60.719] (**) Option "DontZap" "on"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.719621] [    60.719] (**) Option "DontZoom" "on"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.719656] [    60.719] (**) Option "NoPM" "on"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.719714] [    60.719] (**) Option "AutoAddDevices" "off"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.719775] [    60.719] (**) Not automatically adding devices
Mar 29 10:39:38 192.168.10.12  [             X] [   60.719812] [    60.719] (==) Automatically enabling devices
Mar 29 10:39:38 192.168.10.12  [             X] [   60.719871] [    60.719] (==) Automatically adding GPU devices
Mar 29 10:39:38 192.168.10.12  [             X] [   60.719906] [    60.719] (==) Max clients allowed: 256, resource mask: 0x1fffff
Mar 29 10:39:38 192.168.10.12  [             X] [   60.719966] [    60.719] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720051] [    60.719] #011Entry deleted from font path.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720092] [    60.719] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720156] [    60.719] #011Entry deleted from font path.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720217] [    60.719] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720251] [    60.720] #011Entry deleted from font path.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720311] [    60.720] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720346] [    60.720] #011Entry deleted from font path.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720378] [    60.720] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720438] [    60.720] #011Entry deleted from font path.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720473] [    60.720] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720507] [    60.720] #011Entry deleted from font path.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720539] [    60.720] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720571] [    60.720] #011Entry deleted from font path.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720632] [    60.720] (==) FontPath set to:
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720666] #011built-ins
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720698] [    60.720] (==) ModulePath set to "/usr/lib/xorg/modules"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720728] [    60.720] (==) |-->Input Device "Keyboard0"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720757] [    60.720] (==) |-->Input Device "<default keyboard>"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720827] [    60.720] (==) The core pointer device wasn't specified explicitly in the layout.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720875] #011Using the first mouse device.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720926] [    60.720] (==) The core keyboard device wasn't specified explicitly in the layout.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.720962] #011Using the default keyboard configuration.
Mar 29 10:39:38 192.168.10.12  [             X] [   60.721000] [    60.720] (II) Loader magic: 0x1fcf80
Mar 29 10:39:38 192.168.10.12  [             X] [   60.721041] [    60.720] (II) Module ABI versions:
Mar 29 10:39:38 192.168.10.12  [             X] [   60.721076] [    60.720] #011X.Org ANSI C Emulation: 0.4
Mar 29 10:39:38 192.168.10.12  [             X] [   60.721105] [    60.720] #011X.Org Video Driver: 24.0
Mar 29 10:39:38 192.168.10.12  [             X] [   60.721133] [    60.720] #011X.Org XInput driver : 24.1
Mar 29 10:39:38 192.168.10.12  [             X] [   60.721162] [    60.720] #011X.Org Server Extension : 10.0
Mar 29 10:39:38 192.168.10.12  [             X] [   60.724415] [    60.724] (--) using VT number 2
Mar 29 10:39:38 192.168.10.12  [             X] [   60.724540] [    60.724] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
Mar 29 10:39:38 192.168.10.12  [             X] [   60.725044] [    60.724] (II) no primary bus or device found
Mar 29 10:39:38 192.168.10.12  [             X] [   60.725510] [    60.725] (II) LoadModule: "glx"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.725730] [    60.725] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
Mar 29 10:39:38 192.168.10.12  [             X] [   60.731763] [    60.731] (II) Module glx: vendor="X.Org Foundation"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.731884] [    60.731] #011compiled for 1.20.4, module version = 1.0.0
Mar 29 10:39:38 192.168.10.12  [             X] [   60.731931] [    60.731] #011ABI class: X.Org Server Extension, version 10.0
Mar 29 10:39:38 192.168.10.12  [             X] [   60.732011] [    60.731] (II) LoadModule: "fbturbo"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.732250] [    60.732] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
Mar 29 10:39:38 192.168.10.12  [             X] [   60.732738] [    60.732] (II) Module fbturbo: vendor="X.Org Foundation"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.732814] [    60.732] #011compiled for 1.20.3, module version = 0.5.1
Mar 29 10:39:38 192.168.10.12  [             X] [   60.732852] [    60.732] #011Module class: X.Org Video Driver
Mar 29 10:39:38 192.168.10.12  [             X] [   60.732886] [    60.732] #011ABI class: X.Org Video Driver, version 24.0
Mar 29 10:39:38 192.168.10.12  [             X] [   60.732944] [    60.732] (II) LoadModule: "evdev"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.733206] [    60.733] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
Mar 29 10:39:38 192.168.10.12  [             X] [   60.734960] [    60.734] (II) Module evdev: vendor="X.Org Foundation"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.735025] [    60.734] #011compiled for 1.20.3, module version = 2.10.6
Mar 29 10:39:38 192.168.10.12  [             X] [   60.735098] [    60.734] #011Module class: X.Org XInput Driver
Mar 29 10:39:38 192.168.10.12  [             X] [   60.735134] [    60.734] #011ABI class: X.Org XInput driver, version 24.1
Mar 29 10:39:38 192.168.10.12  [             X] [   60.735168] [    60.735] (II) LoadModule: "kbd"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.735520] [    60.735] (WW) Warning, couldn't open module kbd
Mar 29 10:39:38 192.168.10.12  [             X] [   60.735558] [    60.735] (EE) Failed to load module "kbd" (module does not exist, 0)
Mar 29 10:39:38 192.168.10.12  [             X] [   60.735621] [    60.735] (II) FBTURBO: driver for framebuffer: fbturbo
Mar 29 10:39:38 192.168.10.12  [             X] [   60.760373] [    60.760] (WW) Falling back to old probe method for fbturbo
Mar 29 10:39:38 192.168.10.12  [             X] [   60.760550] [    60.760] (II) Loading sub module "fbdevhw"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.760591] [    60.760] (II) LoadModule: "fbdevhw"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.760719] [    60.760] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
Mar 29 10:39:38 192.168.10.12  [             X] [   60.761422] [    60.761] (II) Module fbdevhw: vendor="X.Org Foundation"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.761470] [    60.761] #011compiled for 1.20.4, module version = 0.0.2
Mar 29 10:39:38 192.168.10.12  [             X] [   60.761537] [    60.761] #011ABI class: X.Org Video Driver, version 24.0
Mar 29 10:39:38 192.168.10.12  [             X] [   60.761872] [    60.761] (II) FBTURBO(0): using default device
Mar 29 10:39:38 192.168.10.12  [             X] [   60.761941] [    60.761] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
Mar 29 10:39:38 192.168.10.12  [             X] [   60.762080] [    60.762] (**) FBTURBO(0): Depth 24, (--) framebuffer bpp 32
Mar 29 10:39:38 192.168.10.12  [             X] [   60.762145] [    60.762] (==) FBTURBO(0): RGB weight 888
Mar 29 10:39:38 192.168.10.12  [             X] [   60.762182] [    60.762] (==) FBTURBO(0): Default visual is TrueColor
Mar 29 10:39:38 192.168.10.12  [             X] [   60.762244] [    60.762] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
Mar 29 10:39:38 192.168.10.12  [             X] [   60.762280] [    60.762] (II) FBTURBO(0): hardware: BCM2708 FB (video memory: 5120kB)
Mar 29 10:39:38 192.168.10.12  [             X] [   60.762314] [    60.762] (DB) xf86MergeOutputClassOptions unsupported bus type 0
Mar 29 10:39:38 192.168.10.12  [             X] [   60.762862] [    60.762] (II) FBTURBO(0): processor: Unknown
Mar 29 10:39:38 192.168.10.12  [             X] [   60.762930] [    60.762] (II) FBTURBO(0): checking modes against framebuffer device...
Mar 29 10:39:38 192.168.10.12  [             X] [   60.762994] [    60.762] (II) FBTURBO(0): #011mode "1280x1024" ok
Mar 29 10:39:38 192.168.10.12  [             X] [   60.763058] [    60.762] (II) FBTURBO(0): checking modes against monitor...
Mar 29 10:39:38 192.168.10.12  [             X] [   60.763094] [    60.763] (II) FBTURBO(0): Virtual size is 1280x1024 (pitch 1280)
Mar 29 10:39:38 192.168.10.12  [             X] [   60.763156] [    60.763] (**) FBTURBO(0):  Default mode "1280x1024": 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
Mar 29 10:39:38 192.168.10.12  [             X] [   60.763192] [    60.763] (II) FBTURBO(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
Mar 29 10:39:38 192.168.10.12  [             X] [   60.763256] [    60.763] (==) FBTURBO(0): DPI set to (96, 96)
Mar 29 10:39:38 192.168.10.12  [             X] [   60.763293] [    60.763] (II) Loading sub module "fb"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.763325] [    60.763] (II) LoadModule: "fb"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.763483] [    60.763] (II) Loading /usr/lib/xorg/modules/libfb.so
Mar 29 10:39:38 192.168.10.12  [             X] [   60.764267] [    60.764] (II) Module fb: vendor="X.Org Foundation"
Mar 29 10:39:38 192.168.10.12  [             X] [   60.764318] [    60.764] #011compiled for 1.20.4, module version = 1.0.0
Mar 29 10:39:38 192.168.10.12  [             X] [   60.764400] [    60.764] #011ABI class: X.Org ANSI C Emulation, version 0.4
Mar 29 10:39:38 192.168.10.12  [             X] [   60.766506] [    60.766] (II) FBTURBO(0): using backing store heuristics
Mar 29 10:39:38 192.168.10.12  [         X out] [   60.774129] modprobe: module g2d_23 not found in modules.dep
Mar 29 10:39:38 192.168.10.12  [             X] [   60.774525] [    60.774] (II) FBTURBO(0): can't load 'g2d_23' kernel module
Mar 29 10:39:38 192.168.10.12  [             X] [   60.774650] [    60.774] (II) FBTURBO(0): failed to enable the use of sunxi display controller
Mar 29 10:39:38 192.168.10.12  [             X] [   60.774718] [    60.774] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
Mar 29 10:39:38 192.168.10.12  [             X] [   60.774781] [    60.774] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
Mar 29 10:39:38 192.168.10.12  [             X] [   60.774819] [    60.774] (II) FBTURBO(0): enabled fbdev copyarea acceleration
Mar 29 10:39:38 192.168.10.12  [             X] [   60.774875] [    60.774] (==) FBTURBO(0): Backing store enabled
Mar 29 10:39:38 192.168.10.12  [             X] [   60.776445] [    60.776] (==) FBTURBO(0): DPMS enabled
Mar 29 10:39:38 192.168.10.12  [             X] [   60.776514] [    60.776] (II) FBTURBO(0): failed to enable hardware cursor
Mar 29 10:39:38 192.168.10.12  [             X] [   60.776557] [    60.776] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
Mar 29 10:39:38 192.168.10.12  [             X] [   60.776610] [    60.776] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
Mar 29 10:39:38 192.168.10.12  [             X] [   60.776672] [    60.776] (II) Initializing extension Generic Event Extension
Mar 29 10:39:38 192.168.10.12  [             X] [   60.778512] [    60.778] (II) Initializing extension SHAPE
Mar 29 10:39:38 192.168.10.12  [             X] [   60.780473] [    60.780] (II) Initializing extension MIT-SHM
Mar 29 10:39:38 192.168.10.12  [             X] [   60.782302] [    60.782] (II) Initializing extension XInputExtension
Mar 29 10:39:38 192.168.10.12  [             X] [   60.784341] [    60.784] (II) Initializing extension XTEST
Mar 29 10:39:38 192.168.10.12  [             X] [   60.786171] [    60.786] (II) Initializing extension BIG-REQUESTS
Mar 29 10:39:38 192.168.10.12  [             X] [   60.787950] [    60.787] (II) Initializing extension SYNC
Mar 29 10:39:38 192.168.10.12  [             X] [   60.789808] [    60.789] (II) Initializing extension XKEYBOARD
Mar 29 10:39:38 192.168.10.12  [             X] [   60.791694] [    60.791] (II) Initializing extension XC-MISC
Mar 29 10:39:38 192.168.10.12  [             X] [   60.793477] [    60.793] (II) Initializing extension SECURITY
Mar 29 10:39:38 192.168.10.12  [             X] [   60.795314] [    60.795] (II) Initializing extension XFIXES
Mar 29 10:39:38 192.168.10.12  [             X] [   60.797213] [    60.797] (II) Initializing extension RENDER
Mar 29 10:39:38 192.168.10.12  [             X] [   60.799051] [    60.799] (II) Initializing extension RANDR
Mar 29 10:39:38 192.168.10.12  [             X] [   60.802755] [    60.802] (II) Initializing extension COMPOSITE
Mar 29 10:39:38 192.168.10.12  [             X] [   60.804568] [    60.804] (II) Initializing extension DAMAGE
Mar 29 10:39:38 192.168.10.12  [             X] [   60.806378] [    60.806] (II) Initializing extension MIT-SCREEN-SAVER
Mar 29 10:39:38 192.168.10.12  [             X] [   60.808169] [    60.808] (II) Initializing extension DOUBLE-BUFFER
Mar 29 10:39:38 192.168.10.12  [             X] [   60.809967] [    60.809] (II) Initializing extension RECORD
Mar 29 10:39:38 192.168.10.12  [             X] [   60.811805] [    60.811] (II) Initializing extension DPMS
Mar 29 10:39:38 192.168.10.12  [             X] [   60.813618] [    60.813] (II) Initializing extension Present
Mar 29 10:39:38 192.168.10.12  [             X] [   60.815417] [    60.815] (II) Initializing extension DRI3
Mar 29 10:39:38 192.168.10.12  [             X] [   60.815488] [    60.815] (II) Initializing extension X-Resource
Mar 29 10:39:38 192.168.10.12  [             X] [   60.817275] [    60.817] (II) Initializing extension XVideo
Mar 29 10:39:38 192.168.10.12  [             X] [   60.819092] [    60.819] (II) Initializing extension XVideo-MotionCompensation
Mar 29 10:39:38 192.168.10.12  [             X] [   60.819130] [    60.819] (II) Initializing extension SELinux
Mar 29 10:39:38 192.168.10.12  [             X] [   60.819192] [    60.819] (II) SELinux: Disabled on system
Mar 29 10:39:38 192.168.10.12  [             X] [   60.819227] [    60.819] (II) Initializing extension GLX
Mar 29 10:39:38 192.168.10.12  [             X] [   60.821280] [    60.821] (II) AIGLX: Screen 0 is not DRI2 capable
Mar 29 10:39:38 192.168.10.12  [             X] [   61.059500] [    61.059] (II) IGLX: Loaded and initialized swrast
Mar 29 10:39:38 192.168.10.12  [             X] [   61.059626] [    61.059] (II) GLX: Initialized DRISWRAST GL provider for screen 0
Mar 29 10:39:38 192.168.10.12  [             X] [   61.059665] [    61.059] (II) Initializing extension XFree86-VidModeExtension
Mar 29 10:39:38 192.168.10.12  [             X] [   61.061462] [    61.061] (II) Initializing extension XFree86-DGA
Mar 29 10:39:38 192.168.10.12  [             X] [   61.063315] [    61.063] (II) Initializing extension XFree86-DRI
Mar 29 10:39:38 192.168.10.12  [             X] [   61.063355] [    61.063] (II) Initializing extension DRI2
Mar 29 10:39:38 192.168.10.12  [             X] [   61.242431] [    61.242] (II) Using input driver 'evdev' for 'Keyboard0'
Mar 29 10:39:38 192.168.10.12  [             X] [   61.242610] [    61.242] (**) Option "SendCoreEvents" "on"
Mar 29 10:39:38 192.168.10.12  [             X] [   61.242652] [    61.242] (**) Option "CorePointer" "on"
Mar 29 10:39:38 192.168.10.12  [             X] [   61.242691] [    61.242] (**) Keyboard0: always reports core events
Mar 29 10:39:38 192.168.10.12  [             X] [   61.242753] [    61.242] (**) evdev: Keyboard0: Device: "/dev/input/event0"
Mar 29 10:39:38 192.168.10.12  [             X] [   61.243229] [    61.243] (--) evdev: Keyboard0: Vendor 0x27dd Product 0x101
Mar 29 10:39:38 192.168.10.12  [             X] [   61.243297] [    61.243] (--) evdev: Keyboard0: Found keys
Mar 29 10:39:38 192.168.10.12  [             X] [   61.243335] [    61.243] (II) evdev: Keyboard0: Configuring as keyboard
Mar 29 10:39:38 192.168.10.12  [             X] [   61.243399] [    61.243] (II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD, id 6)
Mar 29 10:39:38 192.168.10.12  [             X] [   61.243462] [    61.243] (**) Option "xkb_rules" "evdev"
Mar 29 10:39:38 192.168.10.12  [             X] [   61.243499] [    61.243] (**) Option "xkb_layout" "ru,us"
Mar 29 10:39:38 192.168.10.12  [             X] [   61.243559] [    61.243] (**) Option "xkb_options" "grp:ctrl_shift_toggle"
Mar 29 10:39:38 192.168.10.12  [             X] [   61.425900] [    61.425] (II) Using input driver 'evdev' for 'Keyboard0'
Mar 29 10:39:38 192.168.10.12  [             X] [   61.426073] [    61.425] (**) Option "SendCoreEvents" "on"
Mar 29 10:39:38 192.168.10.12  [             X] [   61.426114] [    61.425] (**) Option "CorePointer" "on"
Mar 29 10:39:38 192.168.10.12  [             X] [   61.426148] [    61.425] (**) Keyboard0: always reports core events
Mar 29 10:39:38 192.168.10.12  [             X] [   61.426182] [    61.425] (**) evdev: Keyboard0: Device: "/dev/input/event0"
Mar 29 10:39:38 192.168.10.12  [             X] [   61.426302] [    61.426] (WW) evdev: Keyboard0: device file is duplicate. Ignoring.
Mar 29 10:39:38 192.168.10.12  [             X] [   61.480133] [    61.480] (EE) PreInit returned 8 for "Keyboard0"
Mar 29 10:39:38 192.168.10.12  [             X] [   61.480208] [    61.480] (II) UnloadModule: "evdev"
Mar 29 10:39:38 192.168.10.12  [             X] [   61.480347] [    61.480] (II) LoadModule: "kbd"
Mar 29 10:39:38 192.168.10.12  [             X] [   61.480821] [    61.480] (WW) Warning, couldn't open module kbd
Mar 29 10:39:38 192.168.10.12  [             X] [   61.480889] [    61.480] (EE) Failed to load module "kbd" (module does not exist, 0)
Mar 29 10:39:38 192.168.10.12  [             X] [   61.480926] [    61.480] (EE) No input driver matching `kbd'
Mar 29 10:39:38 192.168.10.12  [             X] [   61.480960] [    61.480] (II) Falling back to input driver `libinput'
Mar 29 10:39:38 192.168.10.12  [             X] [   61.481023] [    61.480] (II) LoadModule: "libinput"
Mar 29 10:39:38 192.168.10.12  [             X] [   61.481455] [    61.481] (WW) Warning, couldn't open module libinput
Mar 29 10:39:38 192.168.10.12  [             X] [   61.481494] [    61.481] (EE) Failed to load module "libinput" (module does not exist, 0)
Mar 29 10:39:39 192.168.10.12  [            gm] [   61.625719] Disable DPMS.
Mar 29 10:39:39 192.168.10.12  [            gm] [   61.626362] Allocate 81920 bytes of shared memory for X imgbuf.
Mar 29 10:39:39 192.168.10.12  [            gm] [   61.630420] Use /lib/ui32.so.
Mar 29 10:39:39 192.168.10.12  [            gm] [   61.631207] Allocate 4980736 bytes of shared memory for X imgbuf.
Mar 29 10:39:39 192.168.10.12  [            gm] [   61.665554] [TFTP] Download and unpack file 5.8.90/pi2/localboot/packages/pi2-alsa from 192.168.10.100.
Mar 29 10:39:39 192.168.10.12  [            gm] [   62.254015] modprobe snd-bcm2835.
Mar 29 10:39:39 192.168.10.12  [        KERNEL] [   62.272993] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Mar 29 10:39:39 192.168.10.12  [            gm] [   62.277468] modprobe snd-usb-audio.
Mar 29 10:39:39 192.168.10.12  [        KERNEL] [   62.278739] bcm2835_audio soc:audio: card created with 8 channels
Mar 29 10:39:39 192.168.10.12  [        KERNEL] [   62.301973] usbcore: registered new interface driver snd-usb-audio
Mar 29 10:39:39 192.168.10.12  /--- FILE "/proc/asound/devices" -----------------------
Mar 29 10:39:39 192.168.10.12  |   0: [ 0]   : control
Mar 29 10:39:39 192.168.10.12  |  16: [ 0- 0]: digital audio playback
Mar 29 10:39:39 192.168.10.12  |  17: [ 0- 1]: digital audio playback
Mar 29 10:39:39 192.168.10.12  |  18: [ 0- 2]: digital audio playback
Mar 29 10:39:39 192.168.10.12  |  33:        : timer
Mar 29 10:39:39 192.168.10.12  \----------------------------------------------------
Mar 29 10:39:39 192.168.10.12  [            gm] [   62.301398] /dev/snd//controlC0 character device.
Mar 29 10:39:39 192.168.10.12  [            gm] [   62.301522] /dev/snd//pcmC0D2p character device.
Mar 29 10:39:39 192.168.10.12  [            gm] [   62.301615] /dev/snd//pcmC0D1p character device.
Mar 29 10:39:39 192.168.10.12  [            gm] [   62.301703] /dev/snd//pcmC0D0p character device.
Mar 29 10:39:39 192.168.10.12  [            gm] [   62.301792] /dev/snd//timer character device.
Mar 29 10:39:39 192.168.10.12  [            gm] [   62.301876] +--- Executing "/usr/bin/amixer cset numid=3 2"
Mar 29 10:39:39 192.168.10.12  [            gm] [   62.316892] +- Errorlevel: 0, output:
Mar 29 10:39:39 192.168.10.12  | numid=3,iface=MIXER,name='PCM Playback Route'
Mar 29 10:39:39 192.168.10.12  |   ; type=INTEGER,access=rw------,values=1,min=0,max=3,step=0
Mar 29 10:39:39 192.168.10.12  |   : values=2
Mar 29 10:39:39 192.168.10.12  [            gm] [   62.317409] +------------------------
Mar 29 10:39:39 192.168.10.12  [            gm] [   62.317499] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
Mar 29 10:39:39 192.168.10.12  [          pfac] [   62.317585] Run /sbin/rdpsnd sndvol 100 100 50.
Mar 29 10:39:39 192.168.10.12  [          pfac] [   62.317942] Ok, PID 745.
Mar 29 10:39:39 192.168.10.12  [        KERNEL] [   62.324125] zram0: detected capacity change from 0 to 1073741824
Mar 29 10:39:39 192.168.10.12  [        sndvol] [   62.333505] Card 'ALSA'/'bcm2835 ALSA'.
Mar 29 10:39:39 192.168.10.12  [        sndvol] [   62.333798] Mixer name: 'Broadcom Mixer'.
Mar 29 10:39:39 192.168.10.12  [        sndvol] [   62.333971] Components: ''.
Mar 29 10:39:39 192.168.10.12  [        sndvol] [   62.334153] Controls: 5.
Mar 29 10:39:39 192.168.10.12  [        sndvol] [   62.334319] ALSA: control 'PCM Playback Volume'.
Mar 29 10:39:39 192.168.10.12  [        KERNEL] [   62.337094] Adding 1048572k swap on /dev/zram0.  Priority:-2 extents:1 across:1048572k SS
Mar 29 10:39:39 192.168.10.12  [        sndvol] [   62.334631] ALSA: control 'PCM Playback Switch'.
Mar 29 10:39:39 192.168.10.12  [        sndvol] [   62.334798] ALSA: control 'PCM Playback Route'.
Mar 29 10:39:39 192.168.10.12  [        sndvol] [   62.334960] ALSA: control 'IEC958 Playback Default'.
Mar 29 10:39:39 192.168.10.12  [        sndvol] [   62.335101] ALSA: control 'IEC958 Playback Con Mask'.
Mar 29 10:39:39 192.168.10.12  [          pfac] [   62.337118] Process pid 745 terminated, status 00000000.
Mar 29 10:39:39 192.168.10.12  [            gm] [   62.337352] [TFTP] Download and unpack file 5.8.90/pi2/localboot/packages/chprf from 192.168.10.100.
Mar 29 10:39:43 192.168.10.12  [            gm] [   66.475647] [TFTP] Download and unpack file 5.8.90/pi2/localboot/packages/pi2-chrome from 192.168.10.100.
Mar 29 10:40:53 192.168.10.12  [            gm] [  136.006862] Run '/usr/lib/chromium-browser/chromium-browser-v7 --window-size=1280,1024 --window-position=0,0 --disable-ipv6 --wm-window-animations-disabled --no-default-browser-check --password-store=basic --disable-infobars --show-component-extension-options --ignore-gpu-blacklist --disable-pings --media-router=0 --enable-remote-extensions --enable-low-res-tiling --disable-smooth-scrolling --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=99.99.999.999 --noerrdialogs --kiosk https://***********.ru/pack/ --alsa-output-device=plughw:0', log '/tmp/Xapp00.out', env 'DISPLAY=:0.0 LANG=ru_RU.utf8 LANGUAGE=ru_RU GOOGLE_API_KEY=AIzaSyCkfPOPZXDKNn8hhgu3JrA62wIgC93d44k GOOGLE_DEFAULT_CLIENT_ID=811574891467.apps.googleusercontent.com GOOGLE_DEFAULT_CLIENT_SECRET=kdloedMFGdGla2P1zacGjAQh CHROME_VERSION_EXTRA=WTware', pid '/tmp/Xapp00.pidpipe'.
Mar 29 10:40:53 192.168.10.12  [          pfac] [  136.011757] Run /usr/lib/chromium-browser/chromium-browser-v7 --window-size=1280,1024 --window-position=0,0 --disable-ipv6 --wm-window-animations-disabled --no-default-browser-check --password-store=basic --disable-infobars --show-component-extension-options --ignore-gpu-blacklist --disable-pings --media-router=0 --enable-remote-extensions --enable-low-res-tiling --disable-smooth-scrolling --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=99.99.999.999 --noerrdialogs --kiosk https://***********.ru/pack/ --alsa-output-device=plughw:0.
Mar 29 10:40:53 192.168.10.12  [          pfac] [  136.012108] Ok, PID 761.
Mar 29 10:40:54 192.168.10.12  [            gm] [  137.008280] Success, pid 761.
Mar 29 10:40:54 192.168.10.12  [            gm] [  137.008601] Everyone can control terminal by VNC.
Mar 29 10:40:54 192.168.10.12  [            gm] [  137.008725] [VNC] Listener at port 5900.
Mar 29 10:40:54 192.168.10.12  [            gm] [  137.008828] Nobody can control terminal by WTRC.
Mar 29 10:40:56 192.168.10.12  [SYSLOG] <37>Feb 17 06:02:15 dbus-daemon[694]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.1" (uid=1007 pid=761 comm="/usr/lib/chromium-browser/chromium-browser-v7 --wi") interface="org.freedesktop.DBus.ObjectManager" member="GetManagedObjects" error name="(unset)" requested_reply="0" destination="org.bluez" (bus)
Mar 29 10:40:56 192.168.10.12  [           X00] [  139.405274] libEGL warning: DRI2: failed to authenticate
Mar 29 10:40:57 192.168.10.12  [            gm] [  139.748733] [UUI] Bind window 0x00400001 (pid 761, ppid 1) to the screen 1.
Mar 29 10:40:57 192.168.10.12  [           X00] [  139.889357] [804:811:0217/060216.768732:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for www.gstatic.com failed err=-8181
Mar 29 10:40:57 192.168.10.12  [           X00] [  139.891797] [804:810:0217/060216.771443:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:40:57 192.168.10.12  [           X00] [  139.892379] [804:810:0217/060216.772102:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.103880] [804:811:0217/060216.983509:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for accounts.google.com failed err=-8181
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.120170] [804:810:0217/060216.984830:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.143456] [804:809:0217/060217.023057:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for redirector.gvt1.com failed err=-8181
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.145808] [804:810:0217/060217.025449:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:40:57 192.168.10.12  [SYSLOG] <30>Feb 17 06:02:17 dbus-daemon[694]: [system] Activating service name='org.freedesktop.UPower' requested by ':1.2' (uid=1007 pid=761 comm="/usr/lib/chromium-browser/chromium-browser-v7 --wi") (using servicehelper)
Mar 29 10:40:57 192.168.10.12  [SYSLOG] <30>Feb 17 06:02:17 dbus-daemon[694]: [system] Activated service 'org.freedesktop.UPower' failed: Failed to execute program org.freedesktop.UPower: No such file or directory
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.228530] [761:849:0217/060217.108151:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.Spawn.ExecFailed: Failed to execute program org.freedesktop.UPower: No such file or directory
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.255349] [761:849:0217/060217.135066:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.Spawn.ExecFailed: Failed to execute program org.freedesktop.UPower: No such file or directory
Mar 29 10:40:57 192.168.10.12  [           X00] [  140.282812] [761:849:0217/060217.162480:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.UPower.EnumerateDevices: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.Spawn.ExecFailed: Failed to execute program org.freedesktop.UPower: No such file or directory
Mar 29 10:40:58 192.168.10.12  [           X00] [  141.260800] [800:800:0217/060218.139753:ERROR:sandbox_linux.cc(369)] InitializeSandbox() called with multiple threads in process gpu-process.
Mar 29 10:40:58 192.168.10.12  [           X00] [  141.338536] [804:810:0217/060218.218144:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:01 192.168.10.12  [           X00] [  144.191462] [804:810:0217/060221.071068:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:06 192.168.10.12  [           X00] [  149.379304] [804:809:0217/060226.258945:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for ssl.gstatic.com failed err=-8181
Mar 29 10:41:06 192.168.10.12  [           X00] [  149.380733] [804:810:0217/060226.260454:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:06 192.168.10.12  [           X00] [  149.381046] [804:810:0217/060226.260827:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:09 192.168.10.12  [           X00] [  152.107851] [804:809:0217/060228.987481:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for clients2.google.com failed err=-8181
Mar 29 10:41:09 192.168.10.12  [           X00] [  152.109268] [804:810:0217/060228.988983:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:10 192.168.10.12  [           X00] [  153.086471] [804:809:0217/060229.966070:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for accounts.google.com failed err=-8181
Mar 29 10:41:10 192.168.10.12  [           X00] [  153.087379] [804:810:0217/060229.967112:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:11 192.168.10.12  [           X00] [  154.326846] [804:809:0217/060231.206432:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for clients2.google.com failed err=-8181
Mar 29 10:41:11 192.168.10.12  [           X00] [  154.328150] [804:810:0217/060231.207858:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:15 192.168.10.12  [           X00] [  158.196558] [804:810:0217/060235.076175:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:23 192.168.10.12  [           X00] [  165.907478] [804:810:0217/060242.787158:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:37 192.168.10.12  [           X00] [  180.128186] [804:810:0217/060257.007872:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:38 192.168.10.12  [           X00] [  181.331757] [804:810:0217/060258.211430:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:41:57 192.168.10.12  [           X00] [  200.039517] [804:809:0217/060316.919158:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for www.gstatic.com failed err=-8181
Mar 29 10:41:57 192.168.10.12  [           X00] [  200.041246] [804:810:0217/060316.920971:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:42:02 192.168.10.12  [           X00] [  205.334978] [804:811:0217/060322.214658:ERROR:cert_verify_proc_nss.cc(1011)] CERT_PKIXVerifyCert for safebrowsing.googleapis.com failed err=-8181
Mar 29 10:42:02 192.168.10.12  [           X00] [  205.335983] [804:810:0217/060322.215732:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:42:08 192.168.10.12  [           X00] [  210.717113] [804:810:0217/060327.595294:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:42:33 192.168.10.12  [            gm] [  235.876188] [VNC] Connection from 192.168.60.100.
Mar 29 10:42:33 192.168.10.12  [            gm] [  235.893719] [VNC] Client VNC version 8 (RFB 003.008).
Mar 29 10:42:37 192.168.10.12  [            gm] [  240.292556] [VNC] Password ok.
Mar 29 10:42:37 192.168.10.12  [            gm] [  240.318481] [VNC] 12 encodings: 15 1 5 22 21 16 6 2 0 -314 -239 -223.
Mar 29 10:42:37 192.168.10.12  [            gm] [  240.318578] [VNC] bits-per-pixel 32, depth 24, big-endian false, true-colour true.
Mar 29 10:42:37 192.168.10.12  [            gm] [  240.318664] [VNC] red-max 0x00ff, green-max 0x00ff, blue-max 0x00ff.
Mar 29 10:42:37 192.168.10.12  [            gm] [  240.318744] [VNC] red-shift 16, green-shift 8, blue-shift 0.
Mar 29 10:42:37 192.168.10.12  [            gm] [  240.318825] [VNC] 32-bit server, 32-bit client.
Mar 29 10:42:43 192.168.10.12  [           X00] [  246.353073] [804:810:0217/060403.232768:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:43:09 192.168.10.12  [           X00] [  271.512617] [804:810:0217/060428.392304:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -201
Mar 29 10:44:06 192.168.10.12  Reboot..
Re: Не загружается Chrom
Проверил этот конфиг на 3b+ с загрузкой по сети. У меня работает.
Через две минуты после включения на экране терминала написано "пожалуйста ждите"?
PS: VNC в втвари не видит Хром. Видит только RDP сеансы.
Spider84
Сообщение Spider84 »
Ыыы. А это как так? :) там же Xы и DISPLAY. Или вы их в разные дисплеи направляете?
Там vnc самодельный втваревый, не иксовый. Потому что если нет хрома, то и иксов нет. А когда иксы есть, то прикрутить обычный vnc руки никак не дойдут...
