17-10-15-0518| WTware TFTP server v.5.1.47 (c) 2003-2013 WTware
http://www.wtware.com
17-10-15-0519| sysiplist: Reading Bind Ips from Registry...
17-10-15-0519| sysiplist: BindIP: 192.168.5.2
17-10-15-0520| sysiplist: BindIP: 10.10.10.26
17-10-15-0520| sysiplist: Searching for available interfaces...
17-10-15-0520| sysiplist: Found IP *.*.*.247/255.255.252.0
17-10-15-0521| sysiplist: Found IP 192.168.5.77/255.255.255.0
17-10-15-0521| sysiplist: Found IP 192.168.7.1/255.255.255.0
17-10-15-0521| sysiplist: iplist data:
17-10-15-0522| sysiplist: IP *.*.*.247/255.255.252.0
17-10-15-0716| sysiplist: IP 192.168.5.77/255.255.255.0
17-10-15-0718| sysiplist: IP 192.168.7.1/255.255.255.0
17-10-15-0750| sysiplist: iplist data after filtering:
17-10-15-0752| Determined DNS server 192.168.7.1
17-10-15-0752| Determined DNS server 192.168.5.77
17-10-15-0752| Determined DNS server 127.0.0.1
17-10-15-0753| select () failed, return -1, errno 10022.
17-10-15-0753| Listener thread failed.
17-12-02-0448| Connection closed.
17-12-02-0757| sysiplist: Reading Bind Ips from Registry...
17-12-02-0763| sysiplist: BindIP: 192.168.5.2
17-12-02-0764| sysiplist: BindIP: 10.10.10.26
17-12-02-0769| sysiplist: Searching for available interfaces...
17-12-02-0770| sysiplist: Found IP *.*.*.247/255.255.252.0
17-12-02-0775| sysiplist: Found IP 192.168.5.77/255.255.255.0
17-12-02-0775| sysiplist: Found IP 10.10.10.26/255.255.255.252
17-12-02-0780| sysiplist: Found IP 192.168.7.1/255.255.255.0
17-12-02-0781| sysiplist: iplist data:
17-12-02-0786| sysiplist: IP *.*.*.247/255.255.252.0
17-12-02-0787| sysiplist: IP 192.168.5.77/255.255.255.0
17-12-02-0792| sysiplist: IP 10.10.10.26/255.255.255.252
17-12-02-0792| sysiplist: IP 192.168.7.1/255.255.255.0
17-12-02-0797| sysiplist: iplist data after filtering:
17-12-02-0798| sysiplist: IP 10.10.10.26/255.255.255.252
17-12-02-0803| Determined DNS server 192.168.7.1
17-12-02-0804| Determined MTU 1500 for interface 10.10.10.26/255.255.255.252 on adapter TAP-Windows Adapter V9
17-12-02-0810| Determined DNS server 192.168.5.77
17-12-02-0810| Determined DNS server 127.0.0.1
17-12-02-0815| sysiplist: Bind at 10.10.10.26:69.
17-12-21-0673| [192.168.0.83] Got RRQ, 38 bytes.
17-12-21-0680| [192.168.0.83] 00000000: 57 54 77 61 72 65 20 76 2e 35 2e 31 2e 32 30 20
17-12-21-0681| [192.168.0.83] 00000010: 61 74 20 38 43 3a 38 39 3a 41 35 3a 38 32 3a 37
17-12-21-0687| [192.168.0.83] 00000020: 39 3a 34 31 2e 00
17-12-21-0687| [192.168.0.83] WTware v.5.1.20 found at host [], mac 8C:89:A5:82:79:41.
