Вот лог одного из терминальных клиентов за весь день работы, но он не похож на полный. Ошибки в работе были но здесь насколько я могу понять ничего не видно.
18-16-46-947| Close connection with wtc.exe.
18-16-46-947| Send WTCU discover to 192.168.0.119.
18-16-46-950| Connection from wtc.exe at 192.168.0.119.
07-24-13-520| [pfac] Got command line /sbin/resolver 09d8c5b0 dns [192.168.0.119].
07-24-13-598| [pfac] Ok, PID 632.
07-24-13-598| [pfac] Process pid 632 terminated, status 00000000.
07-24-13-598| [gm] 192.168.0.119 => 192.168.0.119.
07-24-13-598| [gm] Free ram before fork terminal client /sbin/rdpclient (session 6): 174064 Kb.
07-24-13-598| [pfac] Got command line /sbin/rdpclient 6.
07-24-13-598| [pfac] Ok, PID 633.
07-24-13-598| [rdpclient 633] RDP Terminal Client, WTware v.5.2.10, pipe 6, pid 633.
07-24-13-614| [rdpclient 633] Add serial redirection, COM3 in the session = hardware COM1.
07-24-13-614| [rdpdr-serial 0] New client connection, id 6.
07-24-13-614| [rdpclient 633] Make RDP session with 192.168.0.119:3389.
07-24-13-614| [rdpclient 633] Username: "kasir3".
07-24-13-614| [rdpclient 633] Password: present.
07-24-13-614| [rdpclient 633] No domain.
07-24-13-614| [rdpclient 633] No shell.
07-24-13-614| [rdpclient 633] No directory.
07-24-13-629| [rdpclient 633] Window: 1024x768@16.
07-24-13-629| [rdpclient 633] PFlags 0x000000AF.
07-24-13-629| [rdpclient 633] Keyboard 00000419:00000000.
07-24-13-629| [rdpclient 633] My hostname "MLN.KASSA3".
07-24-13-629| [rdpclient 633] TCP: connecting to 192.168.0.119:3389.
07-24-13-629| [rdpclient 633] TCP: connection with 192.168.0.119:3389 established.
07-24-13-629| [rdpclient 633] Turn keepalive on.
07-24-13-629| [rdpclient 633] Free ram after buffers allocation: 170472 KB.
07-24-13-645| [rdpclient 633] Process RDP server certificate.
07-24-13-645| [rdpclient 633] RDP4 encryption.
07-24-13-645| [rdpclient 633] Timezone "(UTC+02:00) Helsinki, Kyiv, Riga, Sofia, Tallinn, Vilnius".
07-24-14-129| [rdpclient 633] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000002.
07-24-14-301| [rdpclient 633] SessionId 0x00000002: SERVER1\kasir3.
14-15-00-392| [rdpclient 633] ERRINFO_LOGOFF_BY_USER
14-15-00-503| [rdpclient 633] Receive Disconnect Provider Ultimatum.
14-15-00-553| [gm] TSClient gracefully end.
14-15-00-557| [pfac] Process pid 633 terminated, status 00000000.
14-15-00-558| [rdpdr-serial 0] Close client connection 0 (id 6).
14-15-00-567| [rdpclient 633] Caught signal SIGTERM.
14-15-02-624| [pfac] Got command line /sbin/resolver 09d8c5b0 dns [192.168.0.119].
14-15-02-682| [pfac] Ok, PID 634.
14-15-02-689| [pfac] Process pid 634 terminated, status 00000000.
14-15-02-689| [gm] 192.168.0.119 => 192.168.0.119.
14-15-02-699| [gm] Free ram before fork terminal client /sbin/rdpclient (session 7): 174008 Kb.
14-15-02-699| [pfac] Got command line /sbin/rdpclient 7.
14-15-02-714| [pfac] Ok, PID 635.
14-15-02-714| [rdpclient 635] RDP Terminal Client, WTware v.5.2.10, pipe 7, pid 635.
14-15-02-718| [rdpclient 635] Add serial redirection, COM3 in the session = hardware COM1.
14-15-02-718| [rdpdr-serial 0] New client connection, id 7.
14-15-02-724| [rdpclient 635] Make RDP session with 192.168.0.119:3389.
14-15-02-725| [rdpclient 635] Username: "kasir3".
14-15-02-740| [rdpclient 635] Password: present.
14-15-02-747| [rdpclient 635] No domain.
14-15-02-758| [rdpclient 635] No shell.
14-15-02-758| [rdpclient 635] No directory.
14-15-02-770| [rdpclient 635] Window: 1024x768@16.
14-15-02-771| [rdpclient 635] PFlags 0x000000AF.
14-15-02-783| [rdpclient 635] Keyboard 00000419:00000000.
14-15-02-784| [rdpclient 635] My hostname "MLN.KASSA3".
14-15-02-799| [rdpclient 635] TCP: connecting to 192.168.0.119:3389.
14-15-02-800| [rdpclient 635] TCP: connection with 192.168.0.119:3389 established.
14-15-02-816| [rdpclient 635] Turn keepalive on.
14-15-02-816| [rdpclient 635] Free ram after buffers allocation: 170388 KB.
14-15-02-834| [rdpclient 635] Process RDP server certificate.
14-15-02-834| [rdpclient 635] RDP4 encryption.
14-15-02-839| [rdpclient 635] Timezone "(UTC+02:00) Helsinki, Kyiv, Riga, Sofia, Tallinn, Vilnius".
14-15-03-222| [rdpclient 635] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000002.
14-15-03-703| [rdpclient 635] SessionId 0x00000002: SERVER1\kasir3.
14-19-56-175| [rdpclient 635] ERRINFO_RPC_INITIATED_DISCONNECT_BYUSER
14-19-56-252| [rdpclient 635] Receive Disconnect Provider Ultimatum.
14-19-56-304| [gm] TSClient gracefully end.
14-19-56-307| [pfac] Process pid 635 terminated, status 00000000.
14-19-56-307| [rdpdr-serial 0] Close client connection 0 (id 7).
14-19-56-311| [rdpclient 635] Caught signal SIGTERM.
14-20-47-571| [pfac] Got command line /sbin/resolver 09d8c5b0 dns [192.168.0.119].
14-20-47-623| [pfac] Ok, PID 636.
14-20-47-627| [pfac] Process pid 636 terminated, status 00000000.
14-20-47-628| [gm] 192.168.0.119 => 192.168.0.119.
14-20-47-631| [gm] Free ram before fork terminal client /sbin/rdpclient (session
: 174008 Kb.
14-20-47-631| [pfac] Got command line /sbin/rdpclient 8.
14-20-47-635| [pfac] Ok, PID 637.
14-20-47-635| [rdpclient 637] RDP Terminal Client, WTware v.5.2.10, pipe 8, pid 637.
14-20-47-640| [rdpclient 637] Add serial redirection, COM3 in the session = hardware COM1.
14-20-47-640| [rdpdr-serial 0] New client connection, id 8.
14-20-47-645| [rdpclient 637] Make RDP session with 192.168.0.119:3389.
14-20-47-645| [rdpclient 637] Username: "kasir3".
14-20-47-648| [rdpclient 637] Password: present.
14-20-47-649| [rdpclient 637] No domain.
14-20-47-652| [rdpclient 637] No shell.
14-20-47-652| [rdpclient 637] No directory.
14-20-47-656| [rdpclient 637] Window: 1024x768@16.
14-20-47-657| [rdpclient 637] PFlags 0x000000AF.
14-20-47-664| [rdpclient 637] Keyboard 00000419:00000000.
14-20-47-664| [rdpclient 637] My hostname "MLN.KASSA3".
14-20-47-668| [rdpclient 637] TCP: connecting to 192.168.0.119:3389.
14-20-47-668| [rdpclient 637] TCP: connection with 192.168.0.119:3389 established.
14-20-47-672| [rdpclient 637] Turn keepalive on.
14-20-47-672| [rdpclient 637] Free ram after buffers allocation: 170388 KB.
14-20-47-677| [rdpclient 637] Process RDP server certificate.
14-20-47-677| [rdpclient 637] RDP4 encryption.
14-20-47-682| [rdpclient 637] Timezone "(UTC+02:00) Helsinki, Kyiv, Riga, Sofia, Tallinn, Vilnius".
14-20-48-095| [rdpclient 637] SessionId 0x00000002: SERVER1\kasir3.
22-00-54-627| [rdpclient 637] ERRINFO_RPC_INITIATED_DISCONNECT_BYUSER
22-00-54-721| [rdpclient 637] Receive Disconnect Provider Ultimatum.
22-00-54-768| [gm] TSClient gracefully end.
22-00-54-768| [pfac] Process pid 637 terminated, status 00000000.
22-00-54-768| [rdpdr-serial 0] Close client connection 0 (id
22-00-54-768| [rdpclient 637] Caught signal SIGTERM.
