WTware 5.6.23
WTware 5.6.23/RPi supervisor.
[        KERNEL] [    0.000000] Booting Linux on physical CPU 0x0
[        KERNEL] [    0.000000] Linux version 4.9.75 (aka@c16) (gcc version 7.2.0 (Debian 7.2.0-11) ) #3 SMP Wed Jan 10 06:29:40 EST 2018
[        KERNEL] [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[        KERNEL] [    0.000000] CPU: div instructions available: patching division code
[        KERNEL] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[        KERNEL] [    0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
[        KERNEL] [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
[        KERNEL] [    0.000000] Memory policy: Data cache writealloc
[        KERNEL] [    0.000000] On node 0 totalpages: 242688
[        KERNEL] [    0.000000] free_area_init_node: node 0, pgdat 80c22b80, node_mem_map ba3a1000
[        KERNEL] [    0.000000]   Normal zone: 2133 pages used for memmap
[        KERNEL] [    0.000000]   Normal zone: 0 pages reserved
[        KERNEL] [    0.000000]   Normal zone: 242688 pages, LIFO batch:31
[        KERNEL] [    0.000000] percpu: Embedded 11 pages/cpu @ba367000 s15948 r8192 d20916 u45056
[        KERNEL] [    0.000000] pcpu-alloc: s15948 r8192 d20916 u45056 alloc=11*4096
[        KERNEL] [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[        KERNEL] [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 240555
[        KERNEL] [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  quiet wtboot=mmc
[        KERNEL] [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[        KERNEL] [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[        KERNEL] [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[        KERNEL] [    0.000000] Memory: 941160K/970752K available (5120K kernel code, 143K rwdata, 920K rodata, 5120K init, 365K bss, 21400K reserved, 8192K cma-reserved)
[        KERNEL] [    0.000000] Virtual kernel memory layout:
[        KERNEL] [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[        KERNEL] [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[        KERNEL] [    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
[        KERNEL] [    0.000000]     lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
[        KERNEL] [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
[        KERNEL] [    0.000000]       .text : 0x80008000 - 0x80600000   (6112 kB)
[        KERNEL] [    0.000000]       .init : 0x80700000 - 0x80c00000   (5120 kB)
[        KERNEL] [    0.000000]       .data : 0x80c00000 - 0x80c23e38   ( 144 kB)
[        KERNEL] [    0.000000]        .bss : 0x80c25000 - 0x80c805e0   ( 366 kB)
[        KERNEL] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[        KERNEL] [    0.000000] Hierarchical RCU implementation.
[        KERNEL] [    0.000000] 	Build-time adjustment of leaf fanout to 32.
[        KERNEL] [    0.000000] NR_IRQS:16 nr_irqs:16 16
[        KERNEL] [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[        KERNEL] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[        KERNEL] [    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[        KERNEL] [    0.000016] Switching to timer-based delay loop, resolution 52ns
[        KERNEL] [    0.000218] Console: colour dummy device 80x30
[        KERNEL] [    0.000231] console [tty0] enabled
[        KERNEL] [    0.000246] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[        KERNEL] [    0.000259] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.000390] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.000398] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.001233] Disabling memory control group subsystem
[        KERNEL] [    0.001284] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.001615] CPU0: update cpu_capacity 1024
[        KERNEL] [    0.001622] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[        KERNEL] [    0.001648] Setting up static identity map for 0x100000 - 0x100034
[        KERNEL] [    0.003191] CPU1: update cpu_capacity 1024
[        KERNEL] [    0.003198] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[        KERNEL] [    0.003770] CPU2: update cpu_capacity 1024
[        KERNEL] [    0.003776] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[        KERNEL] [    0.004344] CPU3: update cpu_capacity 1024
[        KERNEL] [    0.004350] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[        KERNEL] [    0.004428] Brought up 4 CPUs
[        KERNEL] [    0.004436] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[        KERNEL] [    0.004440] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.004443] CPU: Virtualization extensions available.
[        KERNEL] [    0.004983] devtmpfs: initialized
[        KERNEL] [    0.014579] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[        KERNEL] [    0.014959] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[        KERNEL] [    0.014975] futex hash table entries: 1024 (order: 4, 65536 bytes)
[        KERNEL] [    0.015449] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.015976] NET: Registered protocol family 16
[        KERNEL] [    0.017809] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.027926] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[        KERNEL] [    0.111161] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[        KERNEL] [    0.113490] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.113612] usbcore: registered new interface driver hub
[        KERNEL] [    0.113697] usbcore: registered new device driver usb
[        KERNEL] [    0.120135] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-01-08 14:28
[        KERNEL] [    0.122386] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.137623] NET: Registered protocol family 2
[        KERNEL] [    0.138198] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.138305] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.138489] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.138575] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138616] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138791] NET: Registered protocol family 1
[        KERNEL] [    2.442852] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[        KERNEL] [    2.500604] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    2.500616] io scheduler noop registered
[        KERNEL] [    2.500621] io scheduler deadline registered (default)
[        KERNEL] [    2.516038] BCM2708FB: allocated DMA memory fad10000
[        KERNEL] [    2.516089] BCM2708FB: allocated DMA channel 0 @ bb80f000
[        KERNEL] [    2.568819] Console: switching to colour frame buffer device 240x67
[        KERNEL] [    2.602030] bcm2835-rng 3f104000.rng: hwrng registered
[        KERNEL] [    2.602156] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    2.602810] vc-sm: Videocore shared memory driver
[        KERNEL] [    2.612486] zram: Added device: zram0
[        KERNEL] [    2.612524] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    2.840680] Core Release: 2.80a
[        KERNEL] [    2.840690] Setting default values for core params
[        KERNEL] [    2.840717] Finished setting default values for core params
[        KERNEL] [    3.041076] Using Buffer DMA mode
[        KERNEL] [    3.041082] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    3.041085] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    3.041091] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    3.041165] Dedicated Tx FIFOs mode
[        KERNEL] [    3.041722] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[        KERNEL] [    3.041747] FIQ FSM acceleration enabled for :
[        KERNEL] [    3.041747] Non-periodic Split Transactions
[        KERNEL] [    3.041747] Periodic Split Transactions
[        KERNEL] [    3.041747] High-Speed Isochronous Endpoints
[        KERNEL] [    3.041747] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    3.041753] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    3.041799] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397770
[        KERNEL] [    3.041807] WARN::hcd_init_fiq:460: FIQ ASM at 0x80397ad4 length 36
[        KERNEL] [    3.041818] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[        KERNEL] [    3.041872] dwc_otg 3f980000.usb: DWC OTG Controller
[        KERNEL] [    3.041904] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[        KERNEL] [    3.041934] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[        KERNEL] [    3.041981] Init: Port Power? op_state=1
[        KERNEL] [    3.041985] Init: Power Port (0)
[        KERNEL] [    3.042172] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[        KERNEL] [    3.042182] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    3.042190] usb usb1: Product: DWC OTG Controller
[        KERNEL] [    3.042197] usb usb1: Manufacturer: Linux 4.9.75 dwc_otg_hcd
[        KERNEL] [    3.042204] usb usb1: SerialNumber: 3f980000.usb
[        KERNEL] [    3.042983] hub 1-0:1.0: USB hub found
[        KERNEL] [    3.043019] hub 1-0:1.0: 1 port detected
[        KERNEL] [    3.043707] dwc_otg: FIQ enabled
[        KERNEL] [    3.043712] dwc_otg: NAK holdoff enabled
[        KERNEL] [    3.043716] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    3.043728] Module dwc_common_port init
[        KERNEL] [    3.044115] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    3.045194] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[        KERNEL] [    3.045592] bcm2835-cpufreq: min=600000 max=1200000
[        KERNEL] [    3.046780] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[        KERNEL] [    3.049315] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[        KERNEL] [    3.052910] ledtrig-cpu: registered to indicate activity on CPUs
[        KERNEL] [    3.053210] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    3.054895] usbcore: registered new interface driver usbhid
[        KERNEL] [    3.054903] usbhid: USB HID core driver
[        KERNEL] [    3.058468] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[        KERNEL] [    3.082270] [vc_sm_connected_init]: start
[        KERNEL] [    3.092618] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    3.093015] NET: Registered protocol family 17
[        KERNEL] [    3.093248] Registering SWP/SWPB emulation handler
[        KERNEL] [    3.094139] registered taskstats version 1
[        KERNEL] [    3.102585] sdhost: log_buf @ bad07000 (fad07000)
[        KERNEL] [    3.192421] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[        KERNEL] [    3.194765] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[        KERNEL] [    3.194774] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[        KERNEL] [    3.272543] of_cfs_init
[        KERNEL] [    3.272633] of_cfs_init: OK
[        KERNEL] [    3.288286] mmc0: host does not support reading read-only switch, assuming write-enable
[        KERNEL] [    3.288568] Indeed it is in host mode hprt0 = 00021501
[        KERNEL] [    3.295333] Freeing unused kernel memory: 5120K
[        KERNEL] [    3.363329] mmc0: Problem switching card into high-speed mode!
[        KERNEL] [    3.365742] mmc0: new SDHC card at address 0001
[        KERNEL] [    3.367188] mmcblk0: mmc0:0001 SD16G 15.0 GiB (quirks 0x80000000)
[        KERNEL] [    3.377017] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[        KERNEL] [    3.378569] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.380112] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.382159] random: fast init done
[        KERNEL] [    3.382951] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[        KERNEL] [    3.396774]  mmcblk0: p1
[        KERNEL] [    3.473816] mmc1: new high speed SDIO card at address 0001
[        KERNEL] [    3.502426] usb 1-1: new high-speed USB device number 2 using dwc_otg
[        KERNEL] [    3.502565] Indeed it is in host mode hprt0 = 00001101
[       hotplug] [    3.518892] Block device 254:0. No action.
[       hotplug] [    3.699590] Block device 179:1. No action.
[       hotplug] [    3.699733] Block device 179:0. No action.
[          pfac] [    3.706301] Run /sbin/initrd.
[          pfac] [    3.706572] Ok, PID 607.
[        initrd] [    3.709944] WTware shell 5.6.23/RPi
[        KERNEL] [    3.749238] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    3.749248] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.750074] hub 1-1:1.0: USB hub found
[        KERNEL] [    3.750200] hub 1-1:1.0: 5 ports detected
[        initrd] [    3.750588] HDD/MMC/SD boot.
[        KERNEL] [    4.062414] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    4.192633] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    4.192644] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    4.302423] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[        KERNEL] [    4.437311] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c534
[        KERNEL] [    4.437322] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.437329] usb 1-1.2: Product: USB Receiver
[        KERNEL] [    4.437337] usb 1-1.2: Manufacturer: Logitech
[        KERNEL] [    4.443433] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C534.0001/input/input0
[        KERNEL] [    4.513904] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3f980000.usb-1.2/input0
[        KERNEL] [    4.521926] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C534.0002/input/input1
[        KERNEL] [    4.583215] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3f980000.usb-1.2/input1
[        KERNEL] [    4.682415] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[        initrd] [    4.777167] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
| # http://www.raspberrypi.org/documentation/configuration/config-txt.md
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=1
| #hdmi_mode=1
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| #hdmi_group=2
| # 800x600:   hdmi_mode=9
| # 1024x768:  hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768:  hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900:  hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768:  hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| framebuffer_depth=32
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
[        initrd] [    4.785323] WTpassword present: 5e092f36670c9c401f5707d2482b98f3.
[        KERNEL] [    4.812940] usb 1-1.3: New USB device found, idVendor=0482, idProduct=065d
[        KERNEL] [    4.812954] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[        KERNEL] [    4.812961] usb 1-1.3: Product: Kyocera ECOSYS P2035d
[        KERNEL] [    4.812968] usb 1-1.3: Manufacturer: Kyocera
[        KERNEL] [    4.812975] usb 1-1.3: SerialNumber: LVG4105665
[        KERNEL] [    4.912429] usb 1-1.4: new high-speed USB device number 6 using dwc_otg
[        KERNEL] [    5.137125] usb 1-1.4: New USB device found, idVendor=8564, idProduct=1000
[        KERNEL] [    5.137136] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[        KERNEL] [    5.137144] usb 1-1.4: Product: Mass Storage Device
[        KERNEL] [    5.137151] usb 1-1.4: Manufacturer: JetFlash
[        KERNEL] [    5.137159] usb 1-1.4: SerialNumber: QXCUN61V
| clientIP = 192.168.2.74
| netmask = 255.255.255.0
| routerIP = 192.168.2.1
| config = local
| setupPassword = 5e092f36670c9c401f5707d2482b98f3
[        initrd] [    6.804234] Load ethernet drivers.
[        initrd] [    6.808823] modprobe smsc95xx.
[        KERNEL] [    6.818794] smsc95xx v1.0.5
[        KERNEL] [    6.915715] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:6a:8d:4b
[        KERNEL] [    6.916010] usbcore: registered new interface driver smsc95xx
[        KERNEL] [    7.014216] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[        KERNEL] [    8.473725] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[        initrd] [    8.514988] WTpassword present: 5e092f36670c9c401f5707d2482b98f3.
WTC listener is active.
Send broadcast WTCU discover.
[          pfac] [    8.516884] Run /sbin/httpd.
[        initrd] [    8.516940] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [    8.517038] Ok, PID 649.
[         httpd] [    8.523190] HTTP Server, WTware 5.6.23/RPi
[        initrd] [    8.637202] USB: 0482:065d Kyocera Corp..
[        initrd] [    8.637351] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[        initrd] [    8.637427] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[        initrd] [    8.637498] USB: 8564:1000 Transcend Information, Inc. JetFlash.
[        initrd] [    8.637567] USB: 046d:c534 Logitech, Inc. Unifying Receiver.
[        initrd] [    8.637858] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[        initrd] [    8.638679] Common local disk config:
| [BOM]
| server=vnc:192.168.2.10:5896
| printer=usb
| shared_disk = usb
| [BOM]
| printer=usb
| shared_disk=usb
| connection
[        initrd] [    8.639657] Hostname: "wtwB827EB6A8D4B".
RSH: listener is active.
[         httpd] [    8.644623] Reread settings.
[         httpd] [    8.644924] Everyone can control terminal by HTTP.
[        initrd] [    8.649485] Unpack /bootmedia/packages/print.
[        initrd] [    8.654934] /sbin/printer already exist. Do not overwrite.
[        initrd] [    8.660598] /sbin/prnsrvui already exist. Do not overwrite.
[        initrd] [    8.921067] Run '/sbin/printer 0 1 0 0 0 0000:0000', log '', env '', pid ''.
[          pfac] [    8.921202] Run /sbin/printer 0 1 0 0 0 0000:0000.
[          pfac] [    8.921773] Ok, PID 651.
[        initrd] [    8.921834] Load usb printer driver.
[        initrd] [    8.921910] modprobe usblp.
[       printer] [    8.924017] Printserver, WTware 5.6.23/RPi.
[       printer] [    8.926847] Printserver 0, device /dev/usb/lp0, listen at port 9100.
[       printer] [    8.927031] Printer device not found. Waiting...
[        KERNEL] [    8.934203] usblp 1-1.3:1.0: usblp0: USB Bidirectional printer dev 5 if 0 alt 0 proto 2 vid 0x0482 pid 0x065D
[        KERNEL] [    8.934389] usbcore: registered new interface driver usblp
[            gm] [    8.941268] WTware session manager 5.6.23/RPi.
[            gm] [    8.942402] Add keyboard event1: Logitech USB Receiver.
[            gm] [    8.942486] Add keyboard event0: Logitech USB Receiver.
[            gm] [    8.942646] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [    8.972504] Framebuffer device found.
[            gm] [    8.972588] LINELENBYTES 7680
[            gm] [    8.972656] VLEN 8294400
[            gm] [    9.003516] Use /lib/ui32.so.
[            gm] [    9.052810] Unpack /bootmedia/packages/pi2-samba.
[            gm] [    9.646698] Load usb storage driver.
[            gm] [    9.646823] modprobe scsi_mod.
[        KERNEL] [    9.661186] SCSI subsystem initialized
[            gm] [    9.660825] modprobe usb-storage.
[        KERNEL] [    9.676324] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[        KERNEL] [    9.676716] scsi host0: usb-storage 1-1.4:1.0
[        KERNEL] [    9.677477] usbcore: registered new interface driver usb-storage
[            gm] [    9.678405] modprobe sd_mod.
[            gm] [    9.688586] Load EXFAT filesystem driver.
[            gm] [    9.688737] modprobe fuse.
[            gm] [    9.702108] modprobe exfat.
[        KERNEL] [    9.702740] fuse init (API version 7.26)
/--- FILE "/usr/local/samba/lib/smb.conf" -----------------------
| [global]
|  security = SHARE
|  guest account = root
|  socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
|  dns proxy = No
|  encrypt passwords = no
|  wins support = no
|  server string = WTware Terminal
|  log level = 0
|  max log size = 1
|  load printers = No
|  disable spoolss = Yes
|  show add printer wizard = No
|  unix charset = UTF8
|  display charset = UTF8
|  default case = upper
|  preserve case = yes
|  short preserve case = yes
|  os level = 1
|  lm announce = no
|  preferred master = no
|  local master = no
|  domain master = no
|  browse list = no
|  enhanced browsing = no
|  deadtime = 1
|  workgroup = WTWARE
|  netbios name = wtwB827EB6A8D4B
| [USB]
|  path = /mnt/usb-smb
|  read only = no
|  guest ok = Yes
|  guest only = Yes
| [printer]
|  browseable = No
[        KERNEL] [    9.714633] exFAT: Version 1.2.9
[            gm] [    9.714288] +--- Executing "/usr/local/samba/sbin/smbd -D"
[            gm] [    9.805589] +- Errorlevel: 0, output:
File is empty.
[            gm] [    9.805964] +------------------------
[            gm] [    9.866662] Run '/sbin/resolver 0x7b7b60 dns [192.168.2.10]', log '', env '', pid ''.
[          pfac] [    9.866819] Run /sbin/resolver 0x7b7b60 dns [192.168.2.10].
[            gm] [    9.866880] Nobody can control terminal by VNC.
[          pfac] [    9.867565] Ok, PID 692.
[          pfac] [    9.871901] Process pid 692 terminated, status 00000000.
[            gm] [    9.878418] 192.168.2.10 => 192.168.2.10.
[            gm] [    9.890666] Free ram before fork terminal client /sbin/vncclient (session 1): 919388 Kb.
[          pfac] [    9.890846] Run /sbin/vncclient 1.
[            gm] [    9.890894] Run '/sbin/vncclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [    9.891453] Ok, PID 693.
[ vncclient 693] [    9.895364] VNC Client, WTware 5.6.23/RPi, pipe 1, pid 693.
[ vncclient 693] [    9.895765] Use /lib/ui32.so.
[ vncclient 693] [    9.896218] Make VNC session with 192.168.2.10:5896.
[ vncclient 693] [    9.896324] TCP: connecting to 192.168.2.10:5896.
[ vncclient 693] [    9.898720] TCP: connection with 192.168.2.10:5896 established.
[ vncclient 693] [    9.899693] Server VNC version 3.8.
[ vncclient 693] [    9.902691] 1 security types.
[ vncclient 693] [    9.902949] Security code 2 (0x02).
[ vncclient 693] [    9.903034] Use security type 0x00000002.
[        KERNEL] [   10.838038] scsi 0:0:0:0: Direct-Access     JetFlash Transcend 64GB   8.07 PQ: 0 ANSI: 4
[        KERNEL] [   10.840657] sd 0:0:0:0: [sda] 122118144 512-byte logical blocks: (62.5 GB/58.2 GiB)
[        KERNEL] [   10.841482] sd 0:0:0:0: [sda] Write Protect is off
[        KERNEL] [   10.841500] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[        KERNEL] [   10.842465] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[        KERNEL] [   12.434241]  sda: sda4
[        KERNEL] [   12.437654] sd 0:0:0:0: [sda] Attached SCSI removable disk
[       hotplug] [   12.438079] R/w FAT mount ("/dev/sda", "/mnt/usb-smb/USB1raw",..) failed, errno 22.
[        KERNEL] [   12.440090] FAT-fs (sda): invalid media value (0x01)
[        KERNEL] [   12.440102] FAT-fs (sda): Can't find a valid FAT filesystem
[SYSLOG] <14>Jan 10 00:00:09 modprobe: -q -- fs-ntfs
[       hotplug] [   12.441243] R/o NTFS mount ("/dev/sda", "/mnt/usb-smb/USB1raw",..) failed, errno 19.
[       hotplug] [   12.442839] R/o FAT mount ("/dev/sda", "/mnt/usb-smb/USB1raw",..) failed, errno 22.
[        KERNEL] [   12.444866] FAT-fs (sda): invalid media value (0x01)
[        KERNEL] [   12.444875] FAT-fs (sda): Can't find a valid FAT filesystem
[       hotplug] [   12.538322] R/w FAT mount ("/dev/sda4", "/mnt/usb-smb/USB1p4",..) failed, errno 22.
[        KERNEL] [   12.540508] FAT-fs (sda4): bogus number of reserved sectors
[        KERNEL] [   12.540516] FAT-fs (sda4): Can't find a valid FAT filesystem
[       hotplug] [   12.541302] R/o NTFS mount ("/dev/sda4", "/mnt/usb-smb/USB1p4",..) failed, errno 19.
[       hotplug] [   12.542772] R/o FAT mount ("/dev/sda4", "/mnt/usb-smb/USB1p4",..) failed, errno 22.
[        KERNEL] [   12.544975] FAT-fs (sda4): bogus number of reserved sectors
[        KERNEL] [   12.544987] FAT-fs (sda4): Can't find a valid FAT filesystem
[        KERNEL] [   14.775947] random: crng init done
Home    WTware diskless client.
