Не работает ПС\2 мышь!!!
Добавлено: Пт ноя 16, 2007 12:41 pm
Пробовал 2 мыши 100% рабочие ....
WTCENTER: Close connection.
+--- FILE "/tmp/all.log" -----------------------
| WTware PRO Shell v.4.3.37
| KERNEL: Linux version 2.4.34 (root@colinux) (gcc version 3.4.6) #17 Mon Jul 23 09:56:42 MDT 2007
| KERNEL: BIOS-provided physical RAM map:
| KERNEL: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
| KERNEL: BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
| KERNEL: BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
| KERNEL: BIOS-e820: 0000000000100000 - 000000000ffc0000 (usable)
| KERNEL: BIOS-e820: 000000000ffc0000 - 000000000fff8000 (ACPI data)
| KERNEL: BIOS-e820: 000000000fff8000 - 0000000010000000 (ACPI NVS)
| KERNEL: BIOS-e820: 00000000ffb80000 - 00000000ffc00000 (reserved)
| KERNEL: BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
| KERNEL: 255MB LOWMEM available.
| KERNEL: On node 0 totalpages: 65472
| KERNEL: zone(0): 4096 pages.
| KERNEL: zone(1): 61376 pages.
| KERNEL: zone(2): 0 pages.
| KERNEL: ACPI disabled because your bios is from 2000 and too old
| KERNEL: You can enable it with acpi=force
| KERNEL: Kernel command line: root=/dev/ram/0 ramdisk_blocksize=4096 ramdisk_size=8192 quiet initrd=wtshell/wtshell BOOT_IMAGE=wtshell/bzImage
| KERNEL: Initializing CPU#0
| KERNEL: Detected 996.994 MHz processor.
| KERNEL: Console: colour VGA+ 80x25
| KERNEL: Calibrating delay loop... 1985.74 BogoMIPS
| KERNEL: Memory: 255224k/261888k available (1027k kernel code, 6276k reserved, 494k data, 88k init, 0k highmem)
| KERNEL: Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
| KERNEL: Inode cache hash table entries: 16384 (order: 5, 131072 bytes)
| KERNEL: Mount cache hash table entries: 512 (order: 0, 4096 bytes)
| KERNEL: Buffer cache hash table entries: 16384 (order: 4, 65536 bytes)
| KERNEL: Page-cache hash table entries: 65536 (order: 6, 262144 bytes)
| KERNEL: CPU: L1 I cache: 16K, L1 D cache: 16K
| KERNEL: CPU: L2 cache: 128K
| KERNEL: CPU: After generic, caps: 0383f9ff 00000000 00000000 00000000
| KERNEL: CPU: Common caps: 0383f9ff 00000000 00000000 00000000
| KERNEL: CPU: Intel Celeron (Coppermine) stepping 0a
| KERNEL: Enabling fast FPU save and restore... done.
| KERNEL: Enabling unmasked SIMD FPU exception support... done.
| KERNEL: Checking 'hlt' instruction... OK.
| KERNEL: POSIX conformance testing by UNIFIX
| KERNEL: mtrr: v1.40 (20010327) Richard Gooch (rgooch@atnf.csiro.au)
| KERNEL: mtrr: detected mtrr type: Intel
| KERNEL: ACPI: Subsystem revision 20040326
| KERNEL: ACPI: Interpreter disabled.
| KERNEL: PCI: PCI BIOS revision 2.10 entry at 0xfda95, last bus=2
| KERNEL: PCI: Using configuration type 1
| KERNEL: PCI: Probing PCI hardware
| KERNEL: PCI: Probing PCI hardware (bus 00)
| KERNEL: Transparent bridge - Intel Corporation 82801 PCI Bridge
| KERNEL: PCI: Using IRQ router PIIX/ICH [8086/2440] at 00:1f.0
| KERNEL: isapnp: Scanning for PnP cards...
| KERNEL: isapnp: No Plug & Play device found
| KERNEL: Linux NET4.0 for Linux 2.4
| KERNEL: Based upon Swansea University Computer Society NET3.039
| KERNEL: Initializing RT netlink socket
| KERNEL: Starting kswapd
| KERNEL: devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
| KERNEL: devfs: boot_options: 0x1
| KERNEL: RAMDISK driver initialized: 16 RAM disks of 8192K size 4096 blocksize
| KERNEL: Initializing Cryptographic API
| KERNEL: NET4: Linux TCP/IP 1.0 for NET4.0
| KERNEL: IP Protocols: ICMP, UDP, TCP
| KERNEL: IP: routing cache hash table of 2048 buckets, 16Kbytes
| KERNEL: TCP: Hash tables configured (established 16384 bind 32768)
| KERNEL: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
| KERNEL: RAMDISK: cramfs filesystem found at block 0
| KERNEL: RAMDISK: Loading 1608 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|done.
| KERNEL: Freeing initrd memory: 1608k freed
| KERNEL: VFS: Mounted root (cramfs filesystem) readonly.
| KERNEL: Mounted devfs on /dev
| KERNEL: Freeing unused kernel memory: 88k freed
| +--- FILE "/proc/pci" -----------------------
| | PCI devices found:
| | Bus 0, device 0, function 0, WTCODE 0600 8086 1130
| | Host bridge: Intel Corporation 82815 815 Chipset Host Bridge and Memory Controller Hub (rev 2).
| | Prefetchable 32 bit memory at 0xf8000000 [0xfbffffff].
| | Bus 0, device 1, function 0, WTCODE 0604 8086 1131
| | PCI bridge: Intel Corporation 82815 815 Chipset AGP Bridge (rev 2).
| | Master Capable. Latency=32. Min Gnt=8.
| | Bus 0, device 30, function 0, WTCODE 0604 8086 244e
| | PCI bridge: Intel Corporation 82801 PCI Bridge (rev 2).
| | Master Capable. No bursts. Min Gnt=2.
| | Bus 0, device 31, function 0, WTCODE 0601 8086 2440
| | ISA bridge: Intel Corporation 82801BA ISA Bridge (LPC) (rev 2).
| | Bus 0, device 31, function 1, WTCODE 0101 8086 244b
| | IDE interface: Intel Corporation 82801BA IDE U100 (rev 2).
| | I/O at 0xffa0 [0xffaf].
| | Bus 0, device 31, function 2, WTCODE 0c03 8086 2442
| | USB Controller: Intel Corporation 82801BA/BAM USB (Hub #1) (rev 2).
| | IRQ 11.
| | I/O at 0xef40 [0xef5f].
| | Bus 0, device 31, function 3, WTCODE 0c05 8086 2443
| | SMBus: Intel Corporation 82801BA/BAM SMBus (rev 2).
| | IRQ 10.
| | I/O at 0xefa0 [0xefaf].
| | Bus 0, device 31, function 4, WTCODE 0c03 8086 2444
| | USB Controller: Intel Corporation 82801BA/BAM USB (Hub #2) (rev 2).
| | IRQ 9.
| | I/O at 0xef80 [0xef9f].
| | Bus 2, device 0, function 0, WTCODE 0300 10de 002d
| | VGA compatible controller: nVidia Corporation NV5M64 [RIVA TNT2 Model 64/Model 64 Pro] (rev 21).
| | IRQ 11.
| | Master Capable. Latency=32. Min Gnt=5.Max Lat=1.
| | Non-prefetchable 32 bit memory at 0xfd000000 [0xfdffffff].
| | Prefetchable 32 bit memory at 0xf2000000 [0xf3ffffff].
| | Bus 1, device 11, function 0, WTCODE 0200 8086 1229
| | Ethernet controller: Intel Corporation 82557/8/9 [Ethernet Pro 100] (rev
| | IRQ 9.
| | Master Capable. Latency=32. Min Gnt=8.Max Lat=56.
| | Non-prefetchable 32 bit memory at 0xfc9ff000 [0xfc9fffff].
| | I/O at 0xdf00 [0xdf3f].
| | Non-prefetchable 32 bit memory at 0xfc800000 [0xfc8fffff].
| cmdline: root=/dev/ram/0 ramdisk_blocksize=4096 ramdisk_size=8192 quiet initrd=wtshell/wtshell BOOT_IMAGE=wtshell/bzImage
| PCIID, network: 8086:1229.
| PCIID, VGA: 10de:002d.
| RAM: 256920Kb total, 247056Kb free.
| Force USB hub driver.
| Loading usb bus driver.
| +--- FILE "/proc/bus/usb/devices" -----------------------
| | T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
| | B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
| | D: Ver= 1.00 Cls=09(hub ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
| | P: Vendor=0000 ProdID=0000 Rev= 0.00
| | S: Product=USB UHCI Root Hub
| | S: SerialNumber=ef80
| | C:* #Ifs= 1 Cfg#= 1 Atr=40 MxPwr= 0mA
| | I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
| | E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=255ms
| | T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
| | S: SerialNumber=ef40
| Ethernet boot.
| Loading ethernet drivers.
| Network card found: Intel EtherExpressPro/100 (i8255x chip).
| dhcp server: "192.168.100.1"
| interface: "eth0"
| My ip: "192.168.100.2"
| My subnet: "255.255.255.0"
| TFTP server: "192.168.100.1".
| Boot file: "pro\4.3.37\pxelinux.0".
| TFTP prefix: "pro\4.3.37/".
| WTwizard: "192.168.100.1".
| router: "192.168.100.1"
| Trying to download file "pro\4.3.37/configs/wizard.wtc" from TFTP server "192.168.100.1".
| Wizard config file:
| +--- FILE "/tmp/cfg" -----------------------
| | # В файле используется DOS-кодировка. Для корректного отображения в Notepad #
| | # выберите в меню 'Формат > Шрифт' шрифт 'Terminal'. #
| | # WTware PRO #
| | # Windows Terminal #
| | # (c) WTware <aka@wtware.ru>, 2002-2005 #
| | # http://www.wtware.ru/ #
| | # ” ©« Ї а ¬Ґва®ў ¬ бвҐа бва®©ЄЁ вҐа¬Ё « #
| | # 08.08.2005 #
| | # Њ бвҐа бва®©ЄЁ вҐа¬Ё « - Ёбва㬥в, Є®в®ал© Ї®¬®Ј Ґв Ї®¤®Ўа вм #
| | # ®ЇвЁ¬ «млҐ бва®©ЄЁ ўЁ¤Ґ®Є авл, в Є¦Ґ Їа®ўҐаЁвм Є®а४в®бвм а Ў®вл #
| | # ¬лиЁ Ё Є« ўЁ вгал вҐа¬Ё « . #
| | # Њ бвҐа бва®©ЄЁ § ЇгбЄ Ґвбп ўв®¬ вЁзҐбЄЁ ўбпЄЁ© а §, Є®Ј¤ вҐа¬Ё « #
| | # Ґ ®Ў аг¦Ёў Ґв бў®© Є®дЁЈга жЁ®л© д ©«. #
| | # ‚л ¬®¦ҐвҐ Ќ€—…ѓЋ Ґ гЄ §лў вм ў н⮬ д ©«Ґ. Ѓ®«ҐҐ в®Ј®, ¬л ४®¬Ґ¤гҐ¬ #
| | # ЁзҐЈ® Ґ гЄ §лў вм §¤Ґбм ¤® вҐе Ї®а, Ї®Є ўл Ґ ®бў®ЁвҐбм б #
| | # ЁбЇ®«м§®ў ЁҐ¬ ¬ бвҐа бва®©ЄЁ. …б«Ё ¬ бвҐа Ґ ®Ў аг¦Ёв ў н⮬ д ©«Ґ #
| | # гЄ § ле § 票© ЇҐаҐ¬Ґле, ® Їа®бв® Ї®Їа®бЁв ў б ўлЎа вм г¦л© #
| | # ў аЁ в Ё§ ¬Ґо. #
| | # …¤Ёб⢥®Ґ ЁбЄ«о票Ґ - Ї а ¬Ґва usbkeyboard. …Ј® Ќ…ЋЃ•Ћ„€ЊЋ гЄ § вм, #
| | # Ґб«Ё ўл е®вЁвҐ ЁбЇ®«м§®ў вм USB-Є« ўЁ вгаг. #
| | # ‡ Јаг¦ вм «Ё ¤а ©ўҐа ¤«п USB-Є« ўЁ вгал. ЋЎп§ вҐ«м® а бЄ®¬¬ҐвЁаг©вҐ
| | # бва®Єг, Ґб«Ё ўл е®вЁвҐ ЁбЇ®«м§®ў вм USB-Є« ўЁ вгаг, ® вҐа¬Ё «Ґ
| | # ¬ҐмиҐ 64ЊЎ Ї ¬пвЁ.
| | # usbkeyboard = on
| | # …б«Ё ўл ЁбЇ®«м§гҐвҐ ¬лиЁ б Є®«ҐбЁЄ®¬, а бЄ®¬¬ҐвЁаг©вҐ бва®Єг б® § 票Ґ¬
| | # on. …б«Ё ўл ЁбЇ®«м§гҐвҐ ¬лиЁ ЎҐ§ Є®«ҐбЁЄ , а бЄ®¬¬ҐвЁаг©вҐ бва®Єг б®
| | # § 票Ґ¬ off.
| | # mouse_wheel = on
| | # mouse_wheel = off
| | # …б«Ё ўбҐ ЁбЇ®«м§гҐ¬лҐ ў ¬Ё ¬лиЁ Ї®¤Є«озҐл ®¤Ё Ё в®в ¦Ґ Ї®ав,
| | # а бЄ®¬¬ҐвЁаг©вҐ ᮮ⢥вбвўгойго бва®Єг.
| | # mouse = ps/2
| | # mouse = usb
| | # mouse = com1
| | # mouse = com2
| | # …б«Ё ўл ЁбЇ®«м§гҐвҐ в®«мЄ® ®¤® а §аҐиҐЁҐ нЄа , а бЄ®¬¬ҐвЁаг©вҐ
| | # ᮮ⢥вбвўгойго бва®Єг.
| | # resolution = 640x480
| | # resolution = 800x600
| | resolution = 1024x768
| | # resolution = 1280x1024
| | # resolution = 1600x1200
| | # resolution = 960x720
| | # resolution = 1152x864
| | # …б«Ё ўл ўбҐЈ¤ ЁбЇ®«м§гҐвҐ в®«мЄ® ®¤г Ј«гЎЁг 梥в , а ббЄ®¬ҐвЁаг©вҐ
| | # ᮮ⢥вбвўгойго бва®Єг. Ћ¤ Є® ¬л Ґ б®ўҐв㥬 ў ¬ гЄ §лў вм нв®в Ї а ¬Ґва
| | # §¤Ґбм. ‹гзиҐ Ї®Їа®Ў®ў вм ўлЎа вм Ё§ ¬Ґо ¬ бвҐа а §лҐ ў аЁ вл Ё
| | # Ї®¤®Ўа вм ®ЇвЁ¬ «мл©.
| | # [!] Windows 2000 Server Ї®¤¤Ґа¦Ёў Ґв в®«мЄ® 8-ЎЁвл© жўҐв. Џ®н⮬г, Ґб«Ё
| | # ўл Ї« ЁагҐвҐ а Ў®в вм б Windows 2000 Server, Ґв б¬лб« Їа®ўҐапвм
| | # Ёго Ј«гЎЁг 梥в .
| | # bpp = 8
| | # bpp = 15
| | # bpp = 16
| | # bpp = 24
| | # bpp = 32
| | # ‹оЎ п Їа®Ја ¬¬ ᮤҐа¦Ёв ®иЁЎЄЁ. …б«Ё ўл бзЁв ҐвҐ, зв® ¬ бвҐа бва®©ЄЁ
| | # ўҐ¤Ґв бҐЎп Ґ в Є, Є Є ¤®«¦Ґ, Ё«Ё Ґб«Ё ўл и«Ё пўго ®иЁЎЄг - ўл ¬®¦ҐвҐ
| | # бд®а¬Ёа®ў вм ®взҐв ¤«п б«г¦Ўл Ї®¤¤Ґа¦ЄЁ WTware. C ў 襩 Ї®¬®ймо ¬л ¬®¦Ґ¬
| | # ᤥ« вм WTware «гзиҐ. „«п в®Ј®, зв®Ўл бд®а¬Ёа®ў вм ®взҐв:
| | # 1. Ќ «оЎ®© Windows-¬ иЁҐ § ЇгбвЁвҐ Їа®Ја ¬¬г wtcenter.exe, Є®в®а п
| | # Ґбвм ў аеЁўҐ, «ЁЎ® "Џа®б¬®ва б®®ЎйҐЁ©" Ё§ ¬Ґо "ЏгбЄ" > "Џа®Ја ¬¬л" > "WTware",
| | # Ґб«Ё ўл гбв ў«Ёў «Ё WTware ЇаЁ Ї®¬®йЁ Windows-Ёбв ««пв®а .
| | # 2. ђ ббЄ®¬¬ҐвЁаг©вҐ б«Ґ¤гойго бва®Єг Ё гЄ ¦ЁвҐ ў Ґ© IP- ¤аҐб ¬ иЁл,
| | # Є®в®а®© § ЇгйҐ Їа®Ја ¬¬ wtcenter.exe:
| | syslog = 192.168.100.1
| | # 3. ‡ Јаг¦ ©вҐ вҐа¬Ё « Ё Ї®Їлв ©вҐбм ў®бЇа®Ё§ўҐбвЁ ®иЁЎЄг. ’Ґа¬Ё « Ўг¤Ґв
| | # ўҐбвЁ Їа®в®Є®« а Ў®вл, Їа®Ја ¬¬ wtcenter.exe Ўг¤Ґв ЇаЁЁ¬ вм б®®ЎйҐЁп
| | # Ё § ⥬ Ї®§ў®«Ёв б®еа Ёвм Ёе ў д ©«.
| | # 4. Ћв®и«ЁвҐ Ї®«гзЁўиЁ©бп д ©« Ё б«®ўҐб®Ґ ®ЇЁб ЁҐ ®иЁЎЄЁ ў б«г¦Ўг
| | # Ї®¤¤Ґа¦ЄЁ WTware, email: support@wtware.ru
| Read wizard config file.
| Found parameter "resolution" with value = "1024x768".
| Found parameter "syslog" with value = "192.168.100.1".
Conection to WTwizard Service at 192.168.100.1 established.
Trying to download file "pro\4.3.37/packages/wtpx.pkg" from TFTP server "192.168.100.1".
Trying to download file "pro\4.3.37/graphic/pleasewait.gif" from TFTP server "192.168.100.1".
Error code 1: File not found..
Trying to download file "pro\4.3.37/graphic/popup.gif" from TFTP server "192.168.100.1".
WTware PRO 4.3.37 supervisor.
Waiting for init.
KERNEL: usb.c: registered new driver usbdevfs
KERNEL: usb.c: registered new driver hub
KERNEL: usb-uhci.c: $Revision: 1.275 $ time 09:57:49 Jul 23 2007
KERNEL: usb-uhci.c: High bandwidth mode enabled
KERNEL: PCI: Found IRQ 11 for device 00:1f.2
KERNEL: PCI: Setting latency timer of device 00:1f.2 to 64
KERNEL: usb-uhci.c: USB UHCI at I/O 0xef40, IRQ 11
KERNEL: usb-uhci.c: Detected 2 ports
KERNEL: usb.c: new USB bus registered, assigned bus number 1
KERNEL: hub.c: USB hub found
KERNEL: hub.c: 2 ports detected
KERNEL: PCI: Found IRQ 9 for device 00:1f.4
KERNEL: PCI: Sharing IRQ 9 with 01:0b.0
KERNEL: PCI: Setting latency timer of device 00:1f.4 to 64
KERNEL: usb-uhci.c: USB UHCI at I/O 0xef80, IRQ 9
KERNEL: usb.c: new USB bus registered, assigned bus number 2
KERNEL: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
KERNEL: e100: Intel(R) PRO/100 Network Driver, 3.5.14
KERNEL: e100: Copyright(c) 1999-2006 Intel Corporation
KERNEL: PCI: Found IRQ 9 for device 01:0b.0
KERNEL: PCI: Sharing IRQ 9 with 00:1f.4
KERNEL: e100: eth0: e100_probe: addr 0xfc9ff000, irq 9, MAC addr 00:02:B3:90:37:61
KERNEL: e100: eth0: e100_watchdog: link up, 100Mbps, full-duplex
Inilog started, process init - second shell, v.4.3.37.
New mode: 1024x768, 15 bit, 80 Hz.
+--- FILE "/etc/XF86Config" -----------------------
| Section "Files"
| FontPath "/X/fonts"
| EndSection
| Section "ServerFlags"
| Option "DontVTSwitch"
| Option "DontZoom"
| Option "DontZap"
| Option "XkbDisable"
| Option "NoPM"
| EndSection
| Section "InputDevice"
| Identifier "Keyboard"
| Driver "keyboard"
| Option "CoreKeyboard"
| Option "Xleds" "1 2 3"
| EndSection
| Identifier "Mouse"
| Driver "mouse"
| Option "CorePointer"
| Option "Device" "/dev/misc/psaux"
| Option "Protocol" "IMPS/2"
| Option "ZAxisMapping" "4 5"
| EndSection
| Section "Device"
| Identifier "Video"
| Driver "nv"
| Option "HWCursor" "off"
| Option "SWCursor" "on"
| Option "DRI" "off"
| EndSection
| Section "Monitor"
| Identifier "Monitor"
| HorizSync 20-200
| VertRefresh 50-200
| ModeLine "1024x768" 88.50 1024 1088 1200 1376 768 769 772 804 -HSync +Vsync
| EndSection
| Section "Screen"
| Identifier "Screen"
| Device "Video"
| Monitor "Monitor"
| DefaultDepth 15
| SubSection "Display"
| Depth 15
| Modes "1024x768"
| EndSubSection
| EndSection
| Section "ServerLayout"
| Identifier "Layout"
| Screen "Screen"
| InputDevice "Keyboard"
| InputDevice "Mouse"
| EndSection
+--- FILE "/tmp/log.x" -----------------------
| X Window System Version 7.2.0
| Release Date: 21 December 2005
| X Protocol Version 11, Revision 0, Release 7.2
| Build Operating System: Linux
| Current Operating System: Linux 2.4.34 #17 Mon Jul 23 09:56:42 MDT 2007 i686
| Build Date: 03 July 2007 02:21:1183472475PM
| Before reporting problems, check http://www.wtware.com/
| to make sure that you have the latest version.
| Module Loader present
| Markers: (--) probed, (**) from config file, (==) default setting,
| (++) from command line, (!!) notice, (II) informational,
| (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
| (==) Log file: "/X11R7/var/log/Xorg.0.log", Time: Thu Jan 1 00:01:16 1970
| (==) Using config file: "/etc/XF86Config"
| (EE) Failed to load module "dbe" (module does not exist, 0)
| (EE) Failed to load module "glx" (module does not exist, 0)
| (EE) Failed to load module "freetype" (module does not exist, 0)
| (EE) Failed to load module "type1" (module does not exist, 0)
| (EE) Failed to load module "dri" (module does not exist, 0)
| (II) Module "i2c" already built-in
| (II) Module "ddc" already built-in
+--- FILE "/X11R7/var/log/Xorg.0.log" -----------------------
| (==) ServerLayout "Layout"
| (**) |-->Screen "Screen" (0)
| (**) | |-->Monitor "Monitor"
| (**) | |-->Device "Video"
| (**) |-->Input Device "Keyboard"
| (**) |-->Input Device "Mouse"
| (**) Option "DontVTSwitch"
| (**) Option "DontZap"
| (**) Option "DontZoom"
| (**) Option "XkbDisable"
| (**) Option "NoPM"
| (**) Xkb disabled
| (WW) The directory "/X/fonts" does not exist.
| Entry deleted from font path.
| (WW) FontPath is completely invalid. Using compiled-in default.
| (==) FontPath set to:
| /X11R7/lib/X11/fonts/misc/,
| /X11R7/lib/X11/fonts/TTF/,
| /X11R7/lib/X11/fonts/OTF,
| /X11R7/lib/X11/fonts/Type1/,
| /X11R7/lib/X11/fonts/100dpi/,
| /X11R7/lib/X11/fonts/75dpi/
| (==) RgbPath set to "/X11R7/share/X11/rgb"
| (==) ModulePath set to "/X11R7/lib/xorg/modules"
| (II) Loader magic: 0x81e5fc0
| (II) Module ABI versions:
| X.Org ANSI C Emulation: 0.3
| X.Org Video Driver: 2.0
| X.Org XInput driver : 1.1
| X.Org Server Extension : 0.3
| X.Org Font Renderer : 0.5
| (II) Loader running on linux
| (II) LoadModule: "pcidata"
| (II) Loading /X11R7/lib/xorg/modules//libpcidata.so
| (II) Module pcidata: vendor="X.Org Foundation"
| compiled for 7.2.0, module version = 1.0.0
| ABI class: X.Org Video Driver, version 2.0
| (--) using VT number 2
| (WW) xf86OpenConsole: setsid failed: Operation not permitted
| (WW) xf86OpenConsole: Could not save ownership of VT
| (WW) xf86OpenConsole: chown /dev/tty0 failed: No such file or directory
| (II) PCI: PCI scan (all values are in hex)
| (II) PCI: 00:00:0: chip 8086,1130 card 8086,4541 rev 02 class 06,00,00 hdr 00
| (II) PCI: 00:01:0: chip 8086,1131 card 0000,0000 rev 02 class 06,04,00 hdr 01
| (II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev 02 class 06,04,00 hdr 01
| (II) PCI: 00:1f:0: chip 8086,2440 card 0000,0000 rev 02 class 06,01,00 hdr 80
| (II) PCI: 00:1f:1: chip 8086,244b card 8086,4541 rev 02 class 01,01,80 hdr 00
| (II) PCI: 00:1f:2: chip 8086,2442 card 8086,4541 rev 02 class 0c,03,00 hdr 00
| (II) PCI: 00:1f:3: chip 8086,2443 card 8086,4541 rev 02 class 0c,05,00 hdr 00
| (II) PCI: 00:1f:4: chip 8086,2444 card 8086,4541 rev 02 class 0c,03,00 hdr 00
| (II) PCI: 01:0b:0: chip 8086,1229 card 8086,000c rev 08 class 02,00,00 hdr 00
| (II) PCI: 02:00:0: chip 10de,002d card 0000,0000 rev 15 class 03,00,00 hdr 00
| (II) PCI: End of PCI scan
| (II) Intel Bridge workaround enabled
| (II) Host-to-PCI bridge:
| (II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
| (II) Bus 0 I/O range:
| [0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
| (II) Bus 0 non-prefetchable memory range:
| [0] -1 0 0x00000000 - 0xffffffff (0x0) MX
| (II) Bus 0 prefetchable memory range:
| (II) PCI-to-PCI bridge:
| (II) Bus 2: bridge is at (0:1:0), (0,2,2), BCTRL: 0x0008 (VGA_EN is set)
| (II) Bus 2 non-prefetchable memory range:
| [0] -1 0 0xfca00000 - 0xfeafffff (0x2100000) MX
| (II) Bus 2 prefetchable memory range:
| [0] -1 0 0xf0300000 - 0xf43fffff (0x4100000) MX
| (II) Subtractive PCI-to-PCI bridge:
| (II) Bus 1: bridge is at (0:30:0), (0,1,1), BCTRL: 0x0002 (VGA_EN is cleared)
| (II) Bus 1 I/O range:
| [0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX
| (II) Bus 1 non-prefetchable memory range:
| [0] -1 0 0xfc500000 - 0xfc9fffff (0x500000) MX
| (II) Bus 1 prefetchable memory range:
| [0] -1 0 0xf0200000 - 0xf02fffff (0x100000) MX
| (II) PCI-to-ISA bridge:
| (II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
| (--) PCI:*(2:0:0) unknown vendor (0x10de) unknown chipset (0x002d) rev 21, Mem @ 0xfd000000/24, 0xf2000000/25, BIOS @ 0xfeaf0000/16
| (II) Addressable bus resource ranges are
| [1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
| (II) OS-reported resource ranges:
| [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
| [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
| [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
| [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
| [4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
| [5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
| (II) PCI Memory resource overlap reduced 0xf8000000 from 0xfbffffff to 0xf7ffffff
| (II) Active PCI resource ranges:
| [0] -1 0 0xfc800000 - 0xfc8fffff (0x100000) MX[B]
| [1] -1 0 0xfc9ff000 - 0xfc9fffff (0x1000) MX[B]
| [2] -1 0 0xf8000000 - 0xf7ffffff (0x0) MX[B]O
| [3] -1 0 0xfeaf0000 - 0xfeafffff (0x10000) MX[B](B)
| [4] -1 0 0xf2000000 - 0xf3ffffff (0x2000000) MX[B](B)
| [5] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MX[B](B)
| [6] -1 0 0x0000df00 - 0x0000df3f (0x40) IX[B]
| [7] -1 0 0x0000ef80 - 0x0000ef9f (0x20) IX[B]
| [8] -1 0 0x0000efa0 - 0x0000efaf (0x10) IX[B]
| [9] -1 0 0x0000ef40 - 0x0000ef5f (0x20) IX[B]
| [10] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
| (II) Active PCI resource ranges after removing overlaps:
| (II) OS-reported resource ranges after removing overlaps with PCI:
| (II) All system resource ranges:
| [4] -1 0 0xfc800000 - 0xfc8fffff (0x100000) MX[B]
| [5] -1 0 0xfc9ff000 - 0xfc9fffff (0x1000) MX[B]
| [6] -1 0 0xf8000000 - 0xf7ffffff (0x0) MX[B]O
| [7] -1 0 0xfeaf0000 - 0xfeafffff (0x10000) MX[B](B)
| [8] -1 0 0xf2000000 - 0xf3ffffff (0x2000000) MX[B](B)
| [9] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MX[B](B)
| [10] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
| [11] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
| [12] -1 0 0x0000df00 - 0x0000df3f (0x40) IX[B]
| [13] -1 0 0x0000ef80 - 0x0000ef9f (0x20) IX[B]
| [14] -1 0 0x0000efa0 - 0x0000efaf (0x10) IX[B]
| [15] -1 0 0x0000ef40 - 0x0000ef5f (0x20) IX[B]
| [16] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
| (II) LoadModule: "extmod"
| (II) Loading /X11R7/lib/xorg/modules/extensions//libextmod.so
| (II) Module extmod: vendor="X.Org Foundation"
| Module class: X.Org Server Extension
| ABI class: X.Org Server Extension, version 0.3
| (II) Loading extension SHAPE
| (II) Loading extension MIT-SUNDRY-NONSTANDARD
| (II) Loading extension BIG-REQUESTS
| (II) Loading extension SYNC
| (II) Loading extension XC-MISC
| (II) Loading extension XFree86-DGA
| (II) Loading extension XVideo
| (II) Loading extension XVideo-MotionCompensation
| (II) LoadModule: "dbe"
| (WW) Warning, couldn't open module dbe
| (II) UnloadModule: "dbe"
| (II) LoadModule: "glx"
| (WW) Warning, couldn't open module glx
| (II) UnloadModule: "glx"
| (II) LoadModule: "freetype"
| (WW) Warning, couldn't open module freetype
| (II) UnloadModule: "freetype"
| (II) LoadModule: "type1"
| (WW) Warning, couldn't open module type1
| (II) UnloadModule: "type1"
| (II) LoadModule: "record"
| (II) Loading /X11R7/lib/xorg/modules/extensions//librecord.so
| (II) Module record: vendor="X.Org Foundation"
| compiled for 7.2.0, module version = 1.13.0
| (II) Loading extension RECORD
| (II) LoadModule: "dri"
| (WW) Warning, couldn't open module dri
| (II) UnloadModule: "dri"
| (II) LoadModule: "nv"
| (II) Loading /X11R7/lib/xorg/modules/drivers//nv_drv.so
| (II) Module nv: vendor="X.Org Foundation"
| compiled for 7.2.0, module version = 2.1.1
| Module class: X.Org Video Driver
| (II) LoadModule: "kbd"
| (II) Loading /X11R7/lib/xorg/modules/input//kbd_drv.so
| (II) Module kbd: vendor="X.Org Foundation"
| compiled for 7.2.0, module version = 1.2.1
| Module class: X.Org XInput Driver
| ABI class: X.Org XInput driver, version 1.1
| (II) LoadModule: "mouse"
| (II) Loading /X11R7/lib/xorg/modules/input//mouse_drv.so
| (II) Module mouse: vendor="X.Org Foundation"
| (II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
| Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
| Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
| GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
| GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
| Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
| GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
| GeForce4 420 Go 32M, GeForce4 460 Go, Quadro4 550 XGL,
| GeForce4 440 Go 64M, Quadro NVS, Quadro4 500 GoGL,
| GeForce4 410 Go 16M, GeForce4 MX 440 with AGP8X,
| GeForce4 MX 440SE with AGP8X, GeForce4 MX 420 with AGP8X,
| GeForce4 MX 4000, GeForce4 448 Go, GeForce4 488 Go, Quadro4 580 XGL,
| Quadro4 NVS 280 SD, Quadro4 380 XGL, Quadro NVS 50 PCI,
| GeForce4 448 Go, GeForce4 MX Integrated GPU, GeForce3,
| GeForce3 Ti 200, GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600,
| GeForce4 Ti 4400, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
| Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
| GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
| Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
| GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
| GeForce FX 5600 Ultra, GeForce FX 5600, GeForce FX 5600XT,
| GeForce FX Go5600, GeForce FX Go5650, Quadro FX Go700,
| GeForce FX 5200, GeForce FX 5200 Ultra, GeForce FX 5200,
| GeForce FX 5200LE, GeForce FX Go5200, GeForce FX Go5250,
| GeForce FX 5500, GeForce FX 5100, GeForce FX Go5200 32M/64M,
| Quadro NVS 55/280 PCI, Quadro FX 500/600 PCI,
| GeForce FX Go53xx Series, GeForce FX Go5100, GeForce FX 5900 Ultra,
| GeForce FX 5900, GeForce FX 5900XT, GeForce FX 5950 Ultra,
| GeForce FX 5900ZT, Quadro FX 3000, Quadro FX 700,
| GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE,
| GeForce FX 5700VE, GeForce FX Go5700, GeForce FX Go5700,
| Quadro FX Go1000, Quadro FX 1100, GeForce 6800 Ultra, GeForce 6800,
| GeForce 6800 LE, GeForce 6800 XE, GeForce 6800 XT, GeForce 6800 GT,
| GeForce 6800 GT, GeForce 6800 GS, GeForce 6800 XT, Quadro FX 4000,
| GeForce 6800 GS, GeForce 6800, GeForce 6800 LE, GeForce 6800 XT,
| GeForce Go 6800, GeForce Go 6800 Ultra, Quadro FX Go1400,
| Quadro FX 3450/4000 SDI, Quadro FX 1400, GeForce 6600 GT,
| GeForce 6600, GeForce 6600 LE, GeForce 6600 VE, GeForce Go 6600,
| GeForce 6610 XL, GeForce Go 6600 TE/6200 TE, GeForce 6700 XL,
| GeForce Go 6600, GeForce Go 6600 GT, Quadro FX 550, Quadro FX 550,
| Quadro FX 540, GeForce 6200, GeForce 6500,
| GeForce 6200 TurboCache(TM), GeForce 6200SE TurboCache(TM),
| GeForce 6200 LE, GeForce Go 6200, Quadro NVS 285, GeForce Go 6400,
| GeForce Go 6200, GeForce Go 6400, GeForce 6250, GeForce 6800,
| GeForce 6800 LE, GeForce 6800 GT, GeForce 6800 XT, GeForce 6200,
| GeForce 6200 A-LE, GeForce 7800 GTX, GeForce 7800 GTX,
| GeForce 7800 GT, GeForce 7800 GS, GeForce 7800 SLI, GeForce Go 7800,
| GeForce Go 7800 GTX, Quadro FX 4500, GeForce 7300 LE,
| GeForce 7300 SE, GeForce Go 7200, GeForce Go 7300, GeForce Go 7400,
| GeForce Go 7400 GS, Quadro NVS 110M, Quadro NVS 120M, Quadro FX 350M,
| GeForce 7500 LE, Quadro FX 350, GeForce 7300 GS, GeForce 7600 GT,
| GeForce 7600 GS, GeForce 7300 GT, GeForce 7600 LE, GeForce 7300 GT,
| GeForce Go 7700, GeForce Go 7600, GeForce Go 7600 GT,
| Quadro NVS 300M, GeForce Go 7900 SE, Quadro FX 550M, Quadro FX 560,
| GeForce 7900 GTX, GeForce 7900 GT, GeForce 7900 GS,
| GeForce Go 7900 GS, GeForce Go 7900 GTX, Quadro FX 2500M,
| Quadro FX 1500M, Quadro FX 5500, Quadro FX 3500, Quadro FX 1500,
| Quadro FX 4500 X2, GeForce 6150, GeForce 6150 LE, GeForce 6100,
| GeForce Go 6150, GeForce Go 6100, GeForce 8800 GTX, GeForce 8800 GTS,
| GeForce 8800 Ultra, Quadro FX 5600, Quadro FX 4600, GeForce 8600 GTS,
| GeForce 8600 GT, GeForce 8500 GT, GeForce 8400 GS, GeForce 8300 GS,
| GeForce 8400M G
| (II) Primary Device is: PCI 02:00:0
| (--) Assigning device section with no busID to primary device
| (--) Chipset RIVA TNT2 Model 64 found
| (II) resource ranges after xf86ClaimFixedResources() call:
| (II) resource ranges after probing:
| [10] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
| [11] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
| [12] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
| [13] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
| [14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
| [15] -1 0 0x0000df00 - 0x0000df3f (0x40) IX[B]
| [16] -1 0 0x0000ef80 - 0x0000ef9f (0x20) IX[B]
| [17] -1 0 0x0000efa0 - 0x0000efaf (0x10) IX[B]
| [18] -1 0 0x0000ef40 - 0x0000ef5f (0x20) IX[B]
| [19] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
| [20] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
| [21] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
| (II) Setting vga for screen 0.
| (II) Loading sub module "int10"
| (II) LoadModule: "int10"
| (II) Loading /X11R7/lib/xorg/modules//libint10.so
| (II) Module int10: vendor="X.Org Foundation"
| (II) NV(0): Initializing int10
| (II) NV(0): Primary V_BIOS segment is: 0xc000
| (--) NV(0): Chipset: "RIVA TNT2 Model 64"
| (**) NV(0): Depth 15, (--) framebuffer bpp 16
| (==) NV(0): RGB weight 555
| (==) NV(0): Default visual is TrueColor
| (II) Loading sub module "vgahw"
| (II) LoadModule: "vgahw"
| (II) Loading /X11R7/lib/xorg/modules//libvgahw.so
| (II) Module vgahw: vendor="X.Org Foundation"
| compiled for 7.2.0, module version = 0.1.0
| (**) NV(0): Option "SWcursor" "on"
| (**) NV(0): Option "HWcursor" "off"
| (**) NV(0): Using SW cursor
| (--) NV(0): Linear framebuffer at 0xF2000000
| (--) NV(0): MMIO registers at 0xFD000000
| (II) Loading sub module "i2c"
| (II) LoadModule: "i2c"(II) Module "i2c" already built-in
| (II) Loading sub module "ddc"
| (II) LoadModule: "ddc"(II) Module "ddc" already built-in
| (II) NV(0): I2C bus "DDC" initialized.
| (II) NV(0): Probing for EDID on I2C bus A...
| (II) NV(0): I2C device "DDC:ddc2" registered at address 0xA0.
| (--) NV(0): DDC detected a CRT:
| (II) NV(0): Manufacturer: VSC Model: 8b06 Serial#: 16843009
| (II) NV(0): Year: 2001 Week: 50
| (II) NV(0): EDID Version: 1.3
| (II) NV(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
| (II) NV(0): Signal levels configurable
| (II) NV(0): Sync: Separate CompositeSerration on. V.Sync Pulse req. if CompSync or SyncOnGreen
| (II) NV(0): Max H-Image Size [cm]: horiz.: 28 vert.: 21
| (II) NV(0): Gamma: 2.76
| (II) NV(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
| (II) NV(0): First detailed timing is preferred mode
| (II) NV(0): GTF timings supported
| (II) NV(0): redX: 0.642 redY: 0.330 greenX: 0.273 greenY: 0.605
| (II) NV(0): blueX: 0.142 blueY: 0.063 whiteX: 0.283 whiteY: 0.297
| (II) NV(0): Supported VESA Video Modes:
| (II) NV(0): 720x400@70Hz
| (II) NV(0): 720x400@88Hz
| (II) NV(0): 640x480@60Hz
| (II) NV(0): 640x480@67Hz
| (II) NV(0): 640x480@72Hz
| (II) NV(0): 640x480@75Hz
| (II) NV(0): 800x600@56Hz
| (II) NV(0): 800x600@60Hz
| (II) NV(0): 800x600@72Hz
| (II) NV(0): 800x600@75Hz
| (II) NV(0): 832x624@75Hz
| (II) NV(0): 1024x768@87Hz (interlaced)
| (II) NV(0): 1024x768@60Hz
| (II) NV(0): 1024x768@70Hz
| (II) NV(0): Manufacturer's mask: 0
| (II) NV(0): Supported Future Video Modes:
| (II) NV(0): #0: hsize: 800 vsize 600 refresh: 75 vid: 20293
| (II) NV(0): #1: hsize: 800 vsize 600 refresh: 85 vid: 22853
| (II) NV(0): #2: hsize: 640 vsize 480 refresh: 85 vid: 22833
| (II) NV(0): Supported additional Video Mode:
| (II) NV(0): clock: 49.5 MHz Image Size: 270 x 202 mm
| (II) NV(0): h_active: 800 h_sync: 816 h_sync_end 896 h_blank_end 1056 h_border: 0
| (II) NV(0): v_active: 600 v_sync: 601 v_sync_end 604 v_blanking: 625 v_border: 0
| (II) NV(0): Serial No: 11F015001907
| (II) NV(0): Ranges: V min: 50 V max: 120 Hz, H min: 30 H max: 56 kHz, PixClock max 80 MHz
| (II) NV(0): Monitor name: E50-4
| (II) NV(0): EDID (in hex):
| (II) NV(0): 00ffffffffffff005a63068b01010101
| (II) NV(0): 320b01031d1c15b0eb6058a454469b24
| (II) NV(0): 10484cfffc00454f4559315901010101
| (II) NV(0): 01010101010156132000315819201050
| (II) NV(0): 13000eca1000001e000000ff00313146
| (II) NV(0): 3031353030313930370a000000fd0032
| (II) NV(0): 781e3808000a202020202020000000fc
| (II) NV(0): 004535302d340a202020202020200074
| (II) NV(0): Using CRT on CRTC 0
| (II) NV(0): EDID vendor "VSC", prod id 35590
| (II) NV(0): Using hsync ranges from config file
| (II) NV(0): Using vrefresh ranges from config file
| (II) NV(0): Printing DDC gathered Modelines:
| (II) NV(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
| (II) NV(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
| (II) NV(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
| (II) NV(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
| (II) NV(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz)
| (II) NV(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
| (II) NV(0): Modeline "640x480"x0.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
| (II) NV(0): Modeline "720x400"x0.0 35.50 720 738 846 900 400 421 423 449 -hsync -vsync (39.4 kHz)
| (II) NV(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
| (II) NV(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
| (II) NV(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
| (II) NV(0): Modeline "1024x768"x0.0 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35.5 kHz)
| (II) NV(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
| (II) NV(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
| (II) NV(0): Modeline "800x600"x74.9 49.00 800 840 920 1040 600 603 607 629 -hsync +vsync (47.1 kHz)
| (II) NV(0): Modeline "800x600"x84.9 56.75 800 848 928 1056 600 603 607 633 -hsync +vsync (53.7 kHz)
| (II) NV(0): Modeline "640x480"x84.6 35.00 640 664 728 816 480 483 487 507 -hsync +vsync (42.9 kHz)
| (--) NV(0): VideoRAM: 32768 kBytes
| (==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
| (II) NV(0): Monitor: Using hsync range of 20.00-200.00 kHz
| (II) NV(0): Monitor: Using vrefresh range of 50.00-200.00 Hz
| (II) NV(0): Clock range: 12.00 to 350.00 MHz
| (II) NV(0): Not using mode "1024x768" (mode clock too high)
| (II) NV(0): Not using default mode "1152x864" (mode clock too high)
| (II) NV(0): Not using default mode "1280x960" (mode clock too high)
| (II) NV(0): Not using default mode "1280x1024" (mode clock too high)
| (II) NV(0): Not using default mode "1600x1200" (mode clock too high)
| (II) NV(0): Not using default mode "800x600" (mode clock too high)
| (II) NV(0): Not using default mode "1792x1344" (mode clock too high)
| (II) NV(0): Not using default mode "896x672" (mode clock too high)
| (II) NV(0): Not using default mode "1856x1392" (mode clock too high)
| (II) NV(0): Not using default mode "928x696" (mode clock too high)
| (II) NV(0): Not using default mode "1920x1440" (mode clock too high)
| (II) NV(0): Not using default mode "960x720" (mode clock too high)
| (II) NV(0): Not using default mode "1400x1050" (mode clock too high)
| (II) NV(0): Not using default mode "1600x1024" (mode clock too high)
| (II) NV(0): Not using default mode "2048x1536" (mode clock too high)
| (II) NV(0): Not using default mode "2048x1536" (bad mode clock/interlace/doublescan)
| (II) NV(0): Not using default mode "1152x768" (width too large for virtual size)
| (--) NV(0): Virtual size is 1024x768 (pitch 1024)
| (**) NV(0): *Driver mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
| (II) NV(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
| (**) NV(0): Driver mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
| (II) NV(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
| (**) NV(0): Driver mode "1024x768": 44.9 MHz, 35.5 kHz, 86.9 Hz (I)
| (II) NV(0): Modeline "1024x768"x86.9 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35.5 kHz)
| (**) NV(0): Driver mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
| (II) NV(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
| (**) NV(0): Default mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
| (**) NV(0): Driver mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
| (II) NV(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
| (**) NV(0): Driver mode "800x600": 56.8 MHz, 53.7 kHz, 84.9 Hz
| (**) NV(0): Driver mode "800x600": 49.0 MHz, 47.1 kHz, 74.9 Hz
| (**) NV(0): Driver mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
| (II) NV(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
| (**) NV(0): Driver mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
| (II) NV(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
| (**) NV(0): Driver mode "800x600": 36.0 MHz, 35.2 kHz, 56.3 Hz
| (II) NV(0): Modeline "800x600"x56.3 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
| (**) NV(0): Default mode "800x600": 56.3 MHz, 53.7 kHz, 85.1 Hz
| (II) NV(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz)
| (**) NV(0): Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
| (**) NV(0): Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
| (**) NV(0): Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
| (**) NV(0): Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.3 Hz
| (**) NV(0): Default mode "700x525": 77.9 MHz, 81.5 kHz, 74.8 Hz (D)
| (II) NV(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz)
| (**) NV(0): Default mode "700x525": 61.0 MHz, 64.9 kHz, 60.0 Hz (D)
| (II) NV(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz)
| (**) NV(0): Default mode "640x512": 78.8 MHz, 91.1 kHz, 85.0 Hz (D)
| (II) NV(0): Modeline "640x512"x85.0 78.75 640 672 752 864 512 512 514 536 doublescan +hsync +vsync (91.1 kHz)
| (**) NV(0): Default mode "640x512": 67.5 MHz, 80.0 kHz, 75.0 Hz (D)
| (II) NV(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz)
| (**) NV(0): Default mode "640x512": 54.0 MHz, 64.0 kHz, 60.0 Hz (D)
| (II) NV(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz)
| (**) NV(0): Driver mode "640x480": 35.0 MHz, 42.9 kHz, 84.6 Hz
| (**) NV(0): Driver mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
| (II) NV(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
| (**) NV(0): Driver mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
| (II) NV(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz)
| (**) NV(0): Driver mode "640x480": 30.2 MHz, 35.0 kHz, 66.7 Hz
| (II) NV(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
| (**) NV(0): Driver mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
| (II) NV(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
| (**) NV(0): Default mode "640x480": 74.3 MHz, 85.9 kHz, 85.1 Hz (D)
| (II) NV(0): Modeline "640x480"x85.1 74.25 640 672 752 864 480 480 482 505 doublescan +hsync +vsync (85.9 kHz)
| (**) NV(0): Default mode "640x480": 36.0 MHz, 43.3 kHz, 85.0 Hz
| (II) NV(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz)
| (**) NV(0): Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
| (**) NV(0): Default mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
| (II) NV(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
| (**) NV(0): Default mode "640x480": 54.0 MHz, 60.0 kHz, 60.0 Hz (D)
| (II) NV(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz)
| (**) NV(0): Default mode "640x480": 25.2 MHz, 31.5 kHz, 59.9 Hz
| (II) NV(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
| (**) NV(0): Driver mode "720x400": 35.5 MHz, 39.4 kHz, 87.8 Hz
| (II) NV(0): Modeline "720x400"x87.8 35.50 720 738 846 900 400 421 423 449 -hsync -vsync (39.4 kHz)
| (**) NV(0): Driver mode "720x400": 28.3 MHz, 31.5 kHz, 70.1 Hz
| (II) NV(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
| (**) NV(0): Default mode "720x400": 35.5 MHz, 37.9 kHz, 85.0 Hz
| (II) NV(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz)
| (**) NV(0): Default mode "640x400": 31.5 MHz, 37.9 kHz, 85.1 Hz
| (II) NV(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz)
| (**) NV(0): Default mode "576x432": 54.0 MHz, 67.5 kHz, 75.0 Hz (D)
| (II) NV(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz)
| (**) NV(0): Default mode "640x350": 31.5 MHz, 37.9 kHz, 85.1 Hz
| (II) NV(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz)
| (**) NV(0): Default mode "576x384": 32.5 MHz, 44.2 kHz, 54.8 Hz (D)
| (II) NV(0): Modeline "576x384"x54.8 32.50 576 589 657 736 384 385 388 403 doublescan +hsync +vsync (44.2 kHz)
| (**) NV(0): Default mode "512x384": 47.3 MHz, 68.7 kHz, 85.0 Hz (D)
| (II) NV(0): Modeline "512x384"x85.0 47.25 512 536 584 688 384 384 386 404 doublescan +hsync +vsync (68.7 kHz)
| (**) NV(0): Default mode "512x384": 39.4 MHz, 60.0 kHz, 75.0 Hz (D)
| (II) NV(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz)
| (**) NV(0): Default mode "512x384": 37.5 MHz, 56.5 kHz, 70.1 Hz (D)
| (II) NV(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz)
| (**) NV(0): Default mode "512x384": 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
| (II) NV(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz)
| (**) NV(0): Default mode "512x384": 22.4 MHz, 35.5 kHz, 86.6 Hz (D)
| (II) NV(0): Modeline "512x384"x86.6 22.45 512 516 604 632 384 384 388 409 interlace doublescan +hsync +vsync (35.5 kHz)
| (**) NV(0): Default mode "416x312": 28.6 MHz, 49.7 kHz, 74.7 Hz (D)
| (II) NV(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz)
| (**) NV(0): Default mode "400x300": 28.1 MHz, 53.7 kHz, 85.3 Hz (D)
| (II) NV(0): Modeline "400x300"x85.3 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync (53.7 kHz)
| (**) NV(0): Default mode "400x300": 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
| (II) NV(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz)
| (**) NV(0): Default mode "400x300": 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
| (II) NV(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz)
| (**) NV(0): Default mode "400x300": 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
| (II) NV(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz)
| (**) NV(0): Default mode "400x300": 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
| (II) NV(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz)
| (**) NV(0): Default mode "320x240": 18.0 MHz, 43.3 kHz, 85.2 Hz (D)
| (II) NV(0): Modeline "320x240"x85.2 18.00 320 348 376 416 240 240 242 254 doublescan -hsync -vsync (43.3 kHz)
| (**) NV(0): Default mode "320x240": 15.8 MHz, 37.5 kHz, 75.0 Hz (D)
| (II) NV(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz)
| (**) NV(0): Default mode "320x240": 15.8 MHz, 37.9 kHz, 72.8 Hz (D)
| (II) NV(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz)
| (**) NV(0): Default mode "320x240": 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
| (II) NV(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz)
| (**) NV(0): Default mode "360x200": 17.8 MHz, 37.9 kHz, 85.0 Hz (D)
| (II) NV(0): Modeline "360x200"x85.0 17.75 360 378 414 468 200 200 202 223 doublescan -hsync +vsync (37.9 kHz)
| (**) NV(0): Default mode "320x200": 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
| (II) NV(0): Modeline "320x200"x85.3 15.75 320 336 368 416 200 200 202 222 doublescan -hsync +vsync (37.9 kHz)
| (**) NV(0): Default mode "320x175": 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
| (II) NV(0): Modeline "320x175"x85.3 15.75 320 336 368 416 175 191 192 222 doublescan +hsync -vsync (37.9 kHz)
| (**) NV(0): Display dimensions: (280, 210) mm
| (**) NV(0): DPI set to (92, 92)
| (II) Loading sub module "fb"
| (II) LoadModule: "fb"
| (II) Loading /X11R7/lib/xorg/modules//libfb.so
| (II) Module fb: vendor="X.Org Foundation"
| ABI class: X.Org ANSI C Emulation, version 0.3
| (II) Loading sub module "xaa"
| (II) LoadModule: "xaa"
| (II) Loading /X11R7/lib/xorg/modules//libxaa.so
| (II) Module xaa: vendor="X.Org Foundation"
| compiled for 7.2.0, module version = 1.2.0
| (II) do I need RAC? No, I don't.
| (II) resource ranges after preInit:
| [0] 0 0 0xf2000000 - 0xf3ffffff (0x2000000) MX[B]
| [1] 0 0 0xfd000000 - 0xfdffffff (0x1000000) MX[B]
| [2] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
| [3] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
| [4] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
| [5] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
| [6] -1 0 0xfc800000 - 0xfc8fffff (0x100000) MX[B]
| [7] -1 0 0xfc9ff000 - 0xfc9fffff (0x1000) MX[B]
| [8] -1 0 0xf8000000 - 0xf7ffffff (0x0) MX[B]O
| [9] -1 0 0xfeaf0000 - 0xfeafffff (0x10000) MX[B](B)
| [10] -1 0 0xf2000000 - 0xf3ffffff (0x2000000) MX[B](B)
| [11] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MX[B](B)
| [12] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
| [13] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
| [14] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
| [15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
| [16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
| [17] -1 0 0x0000df00 - 0x0000df3f (0x40) IX[B]
| [18] -1 0 0x0000ef80 - 0x0000ef9f (0x20) IX[B]
| [19] -1 0 0x0000efa0 - 0x0000efaf (0x10) IX[B]
| [20] -1 0 0x0000ef40 - 0x0000ef5f (0x20) IX[B]
| [21] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
| [22] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
| [23] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
| (==) NV(0): Write-combining range (0xf2000000,0x2000000)
| (II) NV(0): Using XFree86 Acceleration Architecture (XAA)
| Screen to screen bit blits
| Solid filled rectangles
| 8x8 mono pattern filled rectangles
| Indirect CPU to Screen color expansion
| Solid Lines
| Scanline Image Writes
| Offscreen Pixmaps
| Setting up tile and stipple cache:
| 32 128x128 slots
| 32 256x256 slots
| 16 512x512 slots
| (++) NV(0): Backing store disabled
| (==) NV(0): Silken mouse enabled
| (WW) NV(0): Option "DRI" is not used
| (==) RandR enabled
| (II) Initializing built-in extension MIT-SHM
| (II) Initializing built-in extension XInputExtension
| (II) Initializing built-in extension XTEST
| (II) Initializing built-in extension XKEYBOARD
| (II) Initializing built-in extension XFIXES
| (II) Initializing built-in extension RENDER
| (II) Initializing built-in extension RANDR
| (II) Initializing built-in extension DAMAGE
| (**) Option "CoreKeyboard"
| (**) Keyboard: always reports core events
| (**) Option "Protocol" "standard"
| (**) Keyboard: Protocol: standard
| (**) Option "AutoRepeat" "500 30"
| (**) Option "XLeds" "1 2 3"
| (**) XKB: disabled
| (**) Option "CustomKeycodes" "off"
| (**) Keyboard: CustomKeycodes disabled
| (**) Option "Protocol" "IMPS/2"
| (**) Mouse: Device: "/dev/misc/psaux"
| (**) Mouse: Protocol: "IMPS/2"
| (**) Option "CorePointer"
| (**) Mouse: always reports core events
| (**) Option "Device" "/dev/misc/psaux"
| (==) Mouse: Emulate3Buttons, Emulate3Timeout: 50
| (**) Option "ZAxisMapping" "4 5"
| (**) Mouse: ZAxisMapping: buttons 4 and 5
| (**) Mouse: Buttons: 9
| (**) Mouse: Sensitivity: 1
| (II) evaluating device (Mouse)
| (II) XINPUT: Adding extended input device "Mouse" (type: MOUSE)
| (II) evaluating device (Keyboard)
| (II) XINPUT: Adding extended input device "Keyboard" (type: KEYBOARD)
| (II) Mouse: ps2EnableDataReporting: succeeded
shmqv 1, shmMajor 1, shmMinor 1, shmPixmaps 1.
Total free ram: 239316 KB.
Bitmap cache sizes: base number: 1729.
Free ram after buffers allocation: 207244 KB.
Video test result: 4.77.
и 2
INFO : Got RRQ, 36 bytes.
INFO : 00000000: 70 72 6f 5c 34 2e 33 2e 33 37 5c 70 78 65 6c 69
INFO : 00000010: 6e 75 78 2e 30 00 6f 63 74 65 74 00 74 73 69 7a
INFO : 00000020: 65 00 30 00
INFO : 192.168.100.2 requests file "pro\4.3.37\pxelinux.0". Tsize is requested, blksize default.
INFO : Sending OASK (tsize 13340) to 192.168.100.2.
WARNING: Received opcode 5 from 192.168.100.2.
WARNING: 00000000: 00 05 00 00 54 46 54 50 20 41 62 6f 72 74 65 64
WARNING: 00000010: 00
INFO : Got RRQ, 41 bytes.
INFO : 00000010: 6e 75 78 2e 30 00 6f 63 74 65 74 00 62 6c 6b 73
INFO : 00000020: 69 7a 65 00 31 34 35 36 00
INFO : 192.168.100.2 requests file "pro\4.3.37\pxelinux.0". Tsize is not requested, blksize 1456 bytes.
INFO : Sending OASK (blksize 1456) to 192.168.100.2.
INFO : Transfer of file "pro\4.3.37\pxelinux.0" to 192.168.100.2 completed.
INFO : Connection to 192.168.100.2 closed.
INFO : Got RRQ, 72 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 30 31 2d 30 30 2d 30 32
INFO : 00000020: 2d 62 33 2d 39 30 2d 33 37 2d 36 31 00 6f 63 74
INFO : 00000030: 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69
INFO : 00000040: 7a 65 00 31 34 34 30 00
INFO : 192.168.100.2 requests file "pro\4.3.37\pxelinux.cfg\01-00-02-b3-90-37-61". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.100.2 file "C:\Program Files\WTware\TFTPDROOT\pro\4.3.37\pxelinux.cfg\01-00-02-b3-90-37-61" not found.
INFO : Got RRQ, 60 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 38 36 34 30 32
INFO : 00000020: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62
INFO : 00000030: 6c 6b 73 69 7a 65 00 31 34 34 30 00
INFO : 192.168.100.2 requests file "pro\4.3.37\pxelinux.cfg\C0A86402". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.100.2 file "C:\Program Files\WTware\TFTPDROOT\pro\4.3.37\pxelinux.cfg\C0A86402" not found.
INFO : Got RRQ, 59 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 38 36 34 30 00
INFO : 00000020: 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c
INFO : 00000030: 6b 73 69 7a 65 00 31 34 34 30 00
INFO : 192.168.100.2 requests file "pro\4.3.37\pxelinux.cfg\C0A8640". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.100.2 file "C:\Program Files\WTware\TFTPDROOT\pro\4.3.37\pxelinux.cfg\C0A8640" not found.
INFO : Got RRQ, 58 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 38 36 34 00 6f
INFO : 00000020: 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b
INFO : 00000030: 73 69 7a 65 00 31 34 34 30 00
INFO : 192.168.100.2 requests file "pro\4.3.37\pxelinux.cfg\C0A864". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.100.2 file "C:\Program Files\WTware\TFTPDROOT\pro\4.3.37\pxelinux.cfg\C0A864" not found.
INFO : Got RRQ, 57 bytes.
INFO : 00000000
| | PCI devices found:
| | IRQ 11.
| | IRQ 10.
| | IRQ 9.
| | IRQ 11.
| | IRQ 9.
| Ethernet boot.
| interface: "eth0"
| Wizard config file:
| | # WTware PRO #
| | # 08.08.2005 #
| | # ў аЁ в Ё§ ¬Ґо. #
| | # usbkeyboard = on
| | # § 票Ґ¬ off.
| | # mouse_wheel = on
| | # mouse_wheel = off
| | # mouse = ps/2
| | # mouse = usb
| | # mouse = com1
| | # mouse = com2
| | # Ёго Ј«гЎЁг 梥в .
| | # bpp = 8
| | # bpp = 15
| | # bpp = 16
| | # bpp = 24
| | # bpp = 32
Waiting for init.
| Section "Files"
| FontPath "/X/fonts"
| EndSection
| Option "DontZoom"
| Option "DontZap"
| Option "XkbDisable"
| Option "NoPM"
| EndSection
| Driver "keyboard"
| EndSection
| Identifier "Mouse"
| Driver "mouse"
| EndSection
| Section "Device"
| Identifier "Video"
| Driver "nv"
| Option "DRI" "off"
| EndSection
| Section "Monitor"
| HorizSync 20-200
| VertRefresh 50-200
| EndSection
| Section "Screen"
| Identifier "Screen"
| Device "Video"
| Monitor "Monitor"
| DefaultDepth 15
| Depth 15
| Modes "1024x768"
| EndSubSection
| EndSection
| Identifier "Layout"
| Screen "Screen"
| InputDevice "Mouse"
| EndSection
| (**) Option "NoPM"
| (**) Xkb disabled
| GeForce 8400M G
| Solid Lines
| Offscreen Pixmaps
| 32 128x128 slots
| 32 256x256 slots
| 16 512x512 slots
| (==) RandR enabled
| (**) XKB: disabled
и 2
INFO : 00000000
