WTware 6.0.20/UEFI supervisor.
[        KERNEL] [    0.000000] Linux version 5.4.72 (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-6)) #10 SMP Wed Oct 28 19:03:47 UTC 2020
[        KERNEL] [    0.000000] Command line:
[        KERNEL] [    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[        KERNEL] [    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[        KERNEL] [    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[        KERNEL] [    0.000000] x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
[        KERNEL] [    0.000000] x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
[        KERNEL] [    0.000000] x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
[        KERNEL] [    0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[        KERNEL] [    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[        KERNEL] [    0.000000] x86/fpu: xstate_offset[5]:  832, xstate_sizes[5]:   64
[        KERNEL] [    0.000000] x86/fpu: xstate_offset[6]:  896, xstate_sizes[6]:  512
[        KERNEL] [    0.000000] x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
[        KERNEL] [    0.000000] x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]:    8
[        KERNEL] [    0.000000] x86/fpu: Enabled xstate features 0x2e7, context size is 2440 bytes, using 'compacted' format.
[        KERNEL] [    0.000000] BIOS-provided physical RAM map:
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000069f1cfff] usable
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x0000000069f1d000-0x000000006d01cfff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000006d01d000-0x000000006d0e8fff] ACPI data
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000006d0e9000-0x000000006d18afff] ACPI NVS
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000006d18b000-0x0000000071efefff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x0000000071eff000-0x0000000071efffff] usable
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x0000000071f00000-0x0000000079ffffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000007aa00000-0x000000007abfffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000007b000000-0x00000000803fffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000027fbfffff] usable
[        KERNEL] [    0.000000] NX (Execute Disable) protection: active
[        KERNEL] [    0.000000] efi: EFI v2.70 by American Megatrends
[        KERNEL] [    0.000000] efi:  ACPI=0x6d0e8000  ACPI 2.0=0x6d0e8014  SMBIOS=0x71ca4000  SMBIOS 3.0=0x71ca3000  ESRT=0x6895cb98
[        KERNEL] [    0.000000] SMBIOS 3.3.0 present.
[        KERNEL] [    0.000000] DMI: HP HP Laptop 15s-fq2xxx/87FE, BIOS F.07 12/01/2020
[        KERNEL] [    0.000000] tsc: Detected 2000.000 MHz processor
[        KERNEL] [    0.000283] tsc: Detected 1996.800 MHz TSC
[        KERNEL] [    0.000283] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[        KERNEL] [    0.000284] e820: remove [mem 0x000a0000-0x000fffff] usable
[        KERNEL] [    0.000289] last_pfn = 0x27fc00 max_arch_pfn = 0x400000000
[        KERNEL] [    0.000290] MTRR default type: write-back
[        KERNEL] [    0.000291] MTRR fixed ranges enabled:
[        KERNEL] [    0.000291]   00000-9FFFF write-back
[        KERNEL] [    0.000292]   A0000-BFFFF uncachable
[        KERNEL] [    0.000292]   C0000-FFFFF write-protect
[        KERNEL] [    0.000292] MTRR variable ranges enabled:
[        KERNEL] [    0.000293]   0 base 0080000000 mask 7F80000000 uncachable
[        KERNEL] [    0.000294]   1 base 007C000000 mask 7FFC000000 uncachable
[        KERNEL] [    0.000294]   2 base 2000000000 mask 6000000000 uncachable
[        KERNEL] [    0.000294]   3 base 1000000000 mask 7000000000 uncachable
[        KERNEL] [    0.000295]   4 base 0800000000 mask 7800000000 uncachable
[        KERNEL] [    0.000295]   5 base 0400000000 mask 7C00000000 uncachable
[        KERNEL] [    0.000295]   6 base 4000000000 mask 4000000000 uncachable
[        KERNEL] [    0.000296]   7 disabled
[        KERNEL] [    0.000296]   8 disabled
[        KERNEL] [    0.000296]   9 disabled
[        KERNEL] [    0.000704] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[        KERNEL] [    0.000848] last_pfn = 0x71f00 max_arch_pfn = 0x400000000
[        KERNEL] [    0.007755] esrt: Reserving ESRT space from 0x000000006895cb98 to 0x000000006895cbd0.
[        KERNEL] [    0.007759] e820: update [mem 0x6895c000-0x6895cfff] usable ==> reserved
[        KERNEL] [    0.007771] Using GB pages for direct mapping
[        KERNEL] [    0.008008] Secure boot disabled
[        KERNEL] [    0.008020] ACPI: Early table checksum verification disabled
[        KERNEL] [    0.008022] ACPI: RSDP 0x000000006D0E8014 000024 (v02 HPQOEM)
[        KERNEL] [    0.008023] ACPI: XSDT 0x000000006D0E7728 0000F4 (v01 HPQOEM SLIC-MPC 01072009 AMI  01000013)
[        KERNEL] [    0.008027] ACPI: FACP 0x000000006D0E2000 000114 (v06 HPQOEM SLIC-MPC 01072009 HP   00010013)
[        KERNEL] [    0.008030] ACPI: DSDT 0x000000006D08F000 052F83 (v02 HPQOEM 87FE     01072009 ACPI 20191018)
[        KERNEL] [    0.008032] ACPI: FACS 0x000000006D187000 000040
[        KERNEL] [    0.008033] ACPI: MCFG 0x000000006D0E6000 00003C (v01 HPQOEM 87FE     01072009 HP   00000097)
[        KERNEL] [    0.008035] ACPI: SSDT 0x000000006D0E3000 0025CF (v02 HPQOEM 87FE     00003000 ACPI 20191018)
[        KERNEL] [    0.008036] ACPI: FIDT 0x000000006D08E000 00009C (v01 HPQOEM 87FE     01072009 HP   00010013)
[        KERNEL] [    0.008038] ACPI: SSDT 0x000000006D08A000 0032D3 (v02 HPQOEM 87FE     00001000 ACPI 20191018)
[        KERNEL] [    0.008040] ACPI: SSDT 0x000000006D087000 002B59 (v02 SaSsdt SaSsdt   00003000 INTL 20191018)
[        KERNEL] [    0.008041] ACPI: SSDT 0x000000006D083000 003350 (v02 HPQOEM 87FE     00003000 ACPI 20191018)
[        KERNEL] [    0.008043] ACPI: HPET 0x000000006D082000 000038 (v01 HPQOEM 87FE     01072009 HP   01000013)
[        KERNEL] [    0.008044] ACPI: APIC 0x000000006D081000 00012C (v04 HPQOEM 87FE     01072009 HP   01000013)
[        KERNEL] [    0.008046] ACPI: NHLT 0x000000006D07F000 0018CE (v00 HPQOEM 87FE     01072009 HP   01000013)
[        KERNEL] [    0.008047] ACPI: LPIT 0x000000006D07E000 0000CC (v01 HPQOEM 87FE     01072009 HP   01000013)
[        KERNEL] [    0.008049] ACPI: SSDT 0x000000006D07A000 002720 (v02 HPQOEM 87FE     00001000 ACPI 20191018)
[        KERNEL] [    0.008050] ACPI: SSDT 0x000000006D079000 00012A (v02 HPQOEM 87FE     00000000 ACPI 20191018)
[        KERNEL] [    0.008052] ACPI: DBGP 0x000000006D078000 000034 (v01 HPQOEM 87FE     01072009 HP   01000013)
[        KERNEL] [    0.008054] ACPI: DBG2 0x000000006D077000 000054 (v00 HPQOEM 87FE     01072009 HP   01000013)
[        KERNEL] [    0.008055] ACPI: SSDT 0x000000006D076000 000BA3 (v02 HPQOEM 87FE     00001000 ACPI 20191018)
[        KERNEL] [    0.008057] ACPI: DMAR 0x000000006D075000 000088 (v02 HPQOEM 87FE     00000002 HP   01000013)
[        KERNEL] [    0.008058] ACPI: SSDT 0x000000006D074000 000694 (v02 HPQOEM 87FE     00000000 ACPI 20191018)
[        KERNEL] [    0.008060] ACPI: SSDT 0x000000006D073000 000144 (v02 HPQOEM 87FE     00001000 ACPI 20191018)
[        KERNEL] [    0.008061] ACPI: SSDT 0x000000006D072000 000060 (v01 HPQOEM 87FE     00000001 ACPI 20191018)
[        KERNEL] [    0.008063] ACPI: UEFI 0x000000006D147000 00063A (v01 HPQOEM 87FE     00000000 HP   00000000)
[        KERNEL] [    0.008064] ACPI: UEFI 0x000000006D146000 00005C (v01 HPQOEM 87FE     00000000 HP   00000000)
[        KERNEL] [    0.008066] ACPI: PTDT 0x000000006D071000 000CFE (v00 HPQOEM 87FE     00000005 HP   0100000D)
[        KERNEL] [    0.008067] ACPI: WSMT 0x000000006D07D000 000028 (v01 HPQOEM 87FE     01072009 HP   00010013)
[        KERNEL] [    0.008069] ACPI: FPDT 0x000000006D070000 000044 (v01 HPQOEM 87FE     01072009 HP   01000013)
[        KERNEL] [    0.008070] ACPI: BGRT 0x000000006D06F000 000038 (v01 HPQOEM 87FE     01072009 HP   00010013)
[        KERNEL] [    0.008075] ACPI: Local APIC address 0xfee00000
[        KERNEL] [    0.008086] Zone ranges:
[        KERNEL] [    0.008086]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[        KERNEL] [    0.008087]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[        KERNEL] [    0.008087]   Normal   [mem 0x0000000100000000-0x000000027fbfffff]
[        KERNEL] [    0.008088] Movable zone start for each node
[        KERNEL] [    0.008088] Early memory node ranges
[        KERNEL] [    0.008089]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[        KERNEL] [    0.008089]   node   0: [mem 0x0000000000100000-0x0000000069f1cfff]
[        KERNEL] [    0.008090]   node   0: [mem 0x0000000071eff000-0x0000000071efffff]
[        KERNEL] [    0.008090]   node   0: [mem 0x0000000100000000-0x000000027fbfffff]
[        KERNEL] [    0.008508] Zeroed struct page in unavailable ranges: 58692 pages
[        KERNEL] [    0.008510] Initmem setup node 0 [mem 0x0000000000001000-0x000000027fbfffff]
[        KERNEL] [    0.008511] On node 0 totalpages: 2005692
[        KERNEL] [    0.008512]   DMA zone: 64 pages used for memmap
[        KERNEL] [    0.008512]   DMA zone: 24 pages reserved
[        KERNEL] [    0.008513]   DMA zone: 3998 pages, LIFO batch:0
[        KERNEL] [    0.008552]   DMA32 zone: 6717 pages used for memmap
[        KERNEL] [    0.008553]   DMA32 zone: 429854 pages, LIFO batch:63
[        KERNEL] [    0.013082]   Normal zone: 24560 pages used for memmap
[        KERNEL] [    0.013083]   Normal zone: 1571840 pages, LIFO batch:63
[        KERNEL] [    0.023849] Reserving Intel graphics memory at [mem 0x7c800000-0x803fffff]
[        KERNEL] [    0.024121] ACPI: PM-Timer IO Port: 0x1808
[        KERNEL] [    0.024122] ACPI: Local APIC address 0xfee00000
[        KERNEL] [    0.024126] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[        KERNEL] [    0.024126] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[        KERNEL] [    0.024127] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[        KERNEL] [    0.024127] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[        KERNEL] [    0.024127] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[        KERNEL] [    0.024127] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[        KERNEL] [    0.024128] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[        KERNEL] [    0.024128] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[        KERNEL] [    0.024128] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[        KERNEL] [    0.024129] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[        KERNEL] [    0.024129] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[        KERNEL] [    0.024129] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[        KERNEL] [    0.024129] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[        KERNEL] [    0.024130] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[        KERNEL] [    0.024130] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[        KERNEL] [    0.024130] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[        KERNEL] [    0.024166] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[        KERNEL] [    0.024168] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[        KERNEL] [    0.024169] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[        KERNEL] [    0.024169] ACPI: IRQ0 used by override.
[        KERNEL] [    0.024170] ACPI: IRQ9 used by override.
[        KERNEL] [    0.024171] Using ACPI (MADT) for SMP configuration information
[        KERNEL] [    0.024172] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[        KERNEL] [    0.024178] e820: update [mem 0x674d4000-0x674e7fff] usable ==> reserved
[        KERNEL] [    0.024184] TSC deadline timer available
[        KERNEL] [    0.024185] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[        KERNEL] [    0.024194] [mem 0x80400000-0xbfffffff] available for PCI devices
[        KERNEL] [    0.024195] Booting paravirtualized kernel on bare hardware
[        KERNEL] [    0.024197] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[        KERNEL] [    0.067484] setup_percpu: NR_CPUS:4 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[        KERNEL] [    0.067579] percpu: Embedded 42 pages/cpu s132376 r8192 d31464 u524288
[        KERNEL] [    0.067583] pcpu-alloc: s132376 r8192 d31464 u524288 alloc=1*2097152
[        KERNEL] [    0.067584] pcpu-alloc: [0] 0 1 2 3
[        KERNEL] [    0.067597] Built 1 zonelists, mobility grouping on.  Total pages: 1974327
[        KERNEL] [    0.067598] Kernel command line: quiet
[        KERNEL] [    0.067900] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[        KERNEL] [    0.068049] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[        KERNEL] [    0.068082] mem auto-init: stack:off, heap alloc:off, heap free:off
[        KERNEL] [    0.082397] Memory: 7715488K/8022768K available (8194K kernel code, 391K rwdata, 1764K rodata, 3112K init, 444K bss, 307280K reserved, 0K cma-reserved)
[        KERNEL] [    0.082426] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[        KERNEL] [    0.082452] rcu: Hierarchical RCU implementation.
[        KERNEL] [    0.082453] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[        KERNEL] [    0.082479] NR_IRQS: 4352, nr_irqs: 1024, preallocated irqs: 16
[        KERNEL] [    0.082917] random: crng done (trusting CPU's manufacturer)
[        KERNEL] [    0.082930] Console: colour dummy device 80x25
[        KERNEL] [    0.082932] printk: console [tty0] enabled
[        KERNEL] [    0.082935] ACPI: Core revision 20190816
[        KERNEL] [    0.083236] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 99544814920 ns
[        KERNEL] [    0.083356] APIC: Switch to symmetric I/O mode setup
[        KERNEL] [    0.083357] DMAR: Host address width 39
[        KERNEL] [    0.083358] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[        KERNEL] [    0.083362] DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 69e2ff0505e
[        KERNEL] [    0.083363] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[        KERNEL] [    0.083367] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[        KERNEL] [    0.083368] DMAR: RMRR base: 0x0000007c000000 end: 0x000000803fffff
[        KERNEL] [    0.083370] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[        KERNEL] [    0.083370] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[        KERNEL] [    0.083371] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[        KERNEL] [    0.084928] DMAR-IR: Enabled IRQ remapping in x2apic mode
[        KERNEL] [    0.084929] x2apic enabled
[        KERNEL] [    0.084958] Switched APIC routing to cluster x2apic.
[        KERNEL] [    0.089619] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[        KERNEL] [    0.107295] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3990bec8342, max_idle_ns: 881590769617 ns
[        KERNEL] [    0.107299] Calibrating delay loop (skipped), value calculated using timer frequency.. 3993.60 BogoMIPS (lpj=7987200)
[        KERNEL] [    0.107300] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.109413] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[        KERNEL] [    0.109444] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[        KERNEL] [    0.109559] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[        KERNEL] [    0.109583] mce: CPU0: Thermal monitoring enabled (TM1)
[        KERNEL] [    0.109655] process: using mwait in idle threads
[        KERNEL] [    0.109656] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[        KERNEL] [    0.109657] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[        KERNEL] [    0.109659] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[        KERNEL] [    0.109660] Spectre V2 : Mitigation: Enhanced IBRS
[        KERNEL] [    0.109660] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[        KERNEL] [    0.109661] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[        KERNEL] [    0.109662] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[        KERNEL] [    0.109782] Freeing SMP alternatives memory: 20K
[        KERNEL] [    0.110359] smpboot: CPU0: Intel(R) Pentium(R) Gold 7505 @ 2.00GHz (family: 0x6, model: 0x8c, stepping: 0x1)
[        KERNEL] [    0.110397] Performance Events: PEBS fmt4+-baseline, Icelake events, 32-deep LBR, full-width counters, Intel PMU driver.
[        KERNEL] [    0.110402] ... version:                5
[        KERNEL] [    0.110402] ... bit width:              48
[        KERNEL] [    0.110402] ... generic registers:      8
[        KERNEL] [    0.110403] ... value mask:             0000ffffffffffff
[        KERNEL] [    0.110403] ... max period:             00007fffffffffff
[        KERNEL] [    0.110403] ... fixed-purpose events:   4
[        KERNEL] [    0.110403] ... event mask:             0000000f000000ff
[        KERNEL] [    0.110425] rcu: Hierarchical SRCU implementation.
[        KERNEL] [    0.110459] smp: Bringing up secondary CPUs ...
[        KERNEL] [    0.110488] x86: Booting SMP configuration:
[        KERNEL] [    0.110489] .... node  #0, CPUs:      #1 #2 #3
[        KERNEL] [    0.111050] smp: Brought up 1 node, 4 CPUs
[        KERNEL] [    0.111050] smpboot: Max logical packages: 1
[        KERNEL] [    0.111050] smpboot: Total of 4 processors activated (15974.40 BogoMIPS)
[        KERNEL] [    0.111050] devtmpfs: initialized
[        KERNEL] [    0.111050] PM: Registering ACPI NVS region [mem 0x6d0e9000-0x6d18afff] (663552 bytes)
[        KERNEL] [    0.111050] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[        KERNEL] [    0.111050] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[        KERNEL] [    0.111050] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.111050] NET: Registered protocol family 16
[        KERNEL] [    0.111050] cpuidle: using governor ladder
[        KERNEL] [    0.111050] cpuidle: using governor menu
[        KERNEL] [    0.111050] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[        KERNEL] [    0.111050] ACPI: bus type PCI registered
[        KERNEL] [    0.111050] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xc0000000-0xcfffffff] (base 0xc0000000)
[        KERNEL] [    0.111050] PCI: MMCONFIG at [mem 0xc0000000-0xcfffffff] reserved in E820
[        KERNEL] [    0.111050] PCI: Using configuration type 1 for base access
[        KERNEL] [    0.111050] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[        KERNEL] [    0.111511] ACPI: Added _OSI(Module Device)
[        KERNEL] [    0.111511] ACPI: Added _OSI(Processor Device)
[        KERNEL] [    0.111511] ACPI: Added _OSI(3.0 _SCP Extensions)
[        KERNEL] [    0.111511] ACPI: Added _OSI(Processor Aggregator Device)
[        KERNEL] [    0.111511] ACPI: Added _OSI(Linux-Dell-Video)
[        KERNEL] [    0.111511] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[        KERNEL] [    0.111511] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[        KERNEL] [    0.149661] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149665] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149666] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149667] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149668] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149669] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149764] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149765] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149766] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149766] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149768] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149768] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149770] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149771] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149771] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149772] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149773] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149774] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149780] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149782] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149782] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149783] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149784] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149784] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149786] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149787] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149787] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149788] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149789] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149789] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149791] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149792] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149792] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149793] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149794] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149795] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149796] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149797] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149798] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149798] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149799] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149800] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149801] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149802] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149803] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149803] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS05._PLD], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149804] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149805] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149806] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149807] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149808] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.149808] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS06._PLD], AE_ALREADY_EXISTS (20190816/dswload2-327)
[        KERNEL] [    0.149809] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
[        KERNEL] [    0.149810] ACPI: Skipping parse of AML opcode: OpcodeName unavailable (0x0014)
[        KERNEL] [    0.150118] ACPI: 11 ACPI AML tables successfully acquired and loaded
[        KERNEL] [    0.156808] ACPI: Dynamic OEM Table Load:
[        KERNEL] [    0.156815] ACPI: SSDT 0xFFFF9291B6270600 0001B8 (v02 PmRef  Cpu0Psd  00003000 INTL 20191018)
[        KERNEL] [    0.157626] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[        KERNEL] [    0.158099] ACPI: Dynamic OEM Table Load:
[        KERNEL] [    0.158103] ACPI: SSDT 0xFFFF9291B621A400 000394 (v02 PmRef  Cpu0Cst  00003001 INTL 20191018)
[        KERNEL] [    0.159002] ACPI: Dynamic OEM Table Load:
[        KERNEL] [    0.159006] ACPI: SSDT 0xFFFF9291B5D7B000 00053F (v02 PmRef  Cpu0Ist  00003000 INTL 20191018)
[        KERNEL] [    0.159943] ACPI: Dynamic OEM Table Load:
[        KERNEL] [    0.159946] ACPI: SSDT 0xFFFF9291B6270800 000128 (v02 PmRef  Cpu0Hwp  00003000 INTL 20191018)
[        KERNEL] [    0.160944] ACPI: Dynamic OEM Table Load:
[        KERNEL] [    0.160948] ACPI: SSDT 0xFFFF9291B625C000 0008E7 (v02 PmRef  ApIst    00003000 INTL 20191018)
[        KERNEL] [    0.161933] ACPI: Dynamic OEM Table Load:
[        KERNEL] [    0.161937] ACPI: SSDT 0xFFFF9291B5D7C800 00048A (v02 PmRef  ApHwp    00003000 INTL 20191018)
[        KERNEL] [    0.162870] ACPI: Dynamic OEM Table Load:
[        KERNEL] [    0.162875] ACPI: SSDT 0xFFFF9291B5D7D000 0004D2 (v02 PmRef  ApPsd    00003000 INTL 20191018)
[        KERNEL] [    0.163802] ACPI: Dynamic OEM Table Load:
[        KERNEL] [    0.163806] ACPI: SSDT 0xFFFF9291B5D7D800 00048A (v02 PmRef  ApCst    00003000 INTL 20191018)
[        KERNEL] [    0.165395] ACPI: EC: EC started
[        KERNEL] [    0.165395] ACPI: EC: interrupt blocked
[        KERNEL] [    0.175795] ACPI: \_SB_.PC00.LPCB.EC0_: Used as first EC
[        KERNEL] [    0.175796] ACPI: \_SB_.PC00.LPCB.EC0_: GPE=0x6e, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[        KERNEL] [    0.175797] ACPI: \_SB_.PC00.LPCB.EC0_: Boot DSDT EC used to handle transactions
[        KERNEL] [    0.175797] ACPI: Interpreter enabled
[        KERNEL] [    0.175824] ACPI: (supports S0 S5)
[        KERNEL] [    0.175824] ACPI: Using IOAPIC for interrupt routing
[        KERNEL] [    0.175855] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[        KERNEL] [    0.176145] ACPI: Enabled 7 GPEs in block 00 to 7F
[        KERNEL] [    0.187305] ACPI: Power Resource [V0PR] (on)
[        KERNEL] [    0.187305] ACPI: Power Resource [V1PR] (on)
[        KERNEL] [    0.187305] ACPI: Power Resource [V2PR] (on)
[        KERNEL] [    0.188649] ACPI: Power Resource [WRST] (on)
[        KERNEL] [    0.189306] ACPI: Power Resource [V0PR] (on)
[        KERNEL] [    0.189338] ACPI: Power Resource [V1PR] (on)
[        KERNEL] [    0.189369] ACPI: Power Resource [V2PR] (on)
[        KERNEL] [    0.189399] ACPI: Power Resource [V3PR] (on)
[        KERNEL] [    0.192496] ACPI: Power Resource [PIN] (off)
[        KERNEL] [    0.192703] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-fe])
[        KERNEL] [    0.192706] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[        KERNEL] [    0.193960] acpi PNP0A08:00: _OSC: OS now controls [PME PCIeCapability LTR]
[        KERNEL] [    0.193960] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[        KERNEL] [    0.194111] PCI host bridge to bus 0000:00
[        KERNEL] [    0.194113] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[        KERNEL] [    0.194113] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[        KERNEL] [    0.194114] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[        KERNEL] [    0.194114] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[        KERNEL] [    0.194115] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[        KERNEL] [    0.194115] pci_bus 0000:00: root bus resource [mem 0x80400000-0xbfffffff window]
[        KERNEL] [    0.194116] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[        KERNEL] [    0.194117] pci_bus 0000:00: root bus resource [bus 00-fe]
[        KERNEL] [    0.194128] pci 0000:00:00.0: [8086:9a04] type 00 class 0x060000
[        KERNEL] [    0.195304] pci 0000:00:02.0: [8086:9a78] type 00 class 0x030000
[        KERNEL] [    0.195304] pci 0000:00:02.0: reg 0x10: [mem 0x6002000000-0x6002ffffff 64bit]
[        KERNEL] [    0.195304] pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
[        KERNEL] [    0.195304] pci 0000:00:02.0: reg 0x20: [io  0x4000-0x403f]
[        KERNEL] [    0.195304] pci 0000:00:02.0: BAR 2: assigned to efifb
[        KERNEL] [    0.195304] pci 0000:00:04.0: [8086:9a03] type 00 class 0x118000
[        KERNEL] [    0.195304] pci 0000:00:04.0: reg 0x10: [mem 0x6003200000-0x600321ffff 64bit]
[        KERNEL] [    0.195304] pci 0000:00:08.0: [8086:9a11] type 00 class 0x088000
[        KERNEL] [    0.195304] pci 0000:00:08.0: reg 0x10: [mem 0x600323d000-0x600323dfff 64bit]
[        KERNEL] [    0.195310] pci 0000:00:0e.0: [8086:9a0b] type 00 class 0x010400
[        KERNEL] [    0.195310] pci 0000:00:0e.0: reg 0x10: [mem 0x6000000000-0x6001ffffff 64bit]
[        KERNEL] [    0.195310] pci 0000:00:0e.0: reg 0x18: [mem 0x82000000-0x83ffffff]
[        KERNEL] [    0.195310] pci 0000:00:0e.0: reg 0x20: [mem 0x6003100000-0x60031fffff 64bit]
[        KERNEL] [    0.195310] pci 0000:00:14.0: [8086:a0ed] type 00 class 0x0c0330
[        KERNEL] [    0.195310] pci 0000:00:14.0: reg 0x10: [mem 0x6003220000-0x600322ffff 64bit]
[        KERNEL] [    0.195310] pci 0000:00:14.0: PME# supported from D3hot D3cold
[        KERNEL] [    0.195486] pci 0000:00:14.2: [8086:a0ef] type 00 class 0x050000
[        KERNEL] [    0.195510] pci 0000:00:14.2: reg 0x10: [mem 0x6003234000-0x6003237fff 64bit]
[        KERNEL] [    0.195523] pci 0000:00:14.2: reg 0x18: [mem 0x600323c000-0x600323cfff 64bit]
[        KERNEL] [    0.195731] pci 0000:00:15.0: [8086:a0e8] type 00 class 0x0c8000
[        KERNEL] [    0.195766] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[        KERNEL] [    0.196068] pci 0000:00:15.1: [8086:a0e9] type 00 class 0x0c8000
[        KERNEL] [    0.196104] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[        KERNEL] [    0.196440] pci 0000:00:16.0: [8086:a0e0] type 00 class 0x078000
[        KERNEL] [    0.196471] pci 0000:00:16.0: reg 0x10: [mem 0x6003239000-0x6003239fff 64bit]
[        KERNEL] [    0.196557] pci 0000:00:16.0: PME# supported from D3hot
[        KERNEL] [    0.196736] pci 0000:00:1c.0: [8086:a0bf] type 01 class 0x060400
[        KERNEL] [    0.196844] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[        KERNEL] [    0.197023] pci 0000:00:1d.0: [8086:09ab] type 00 class 0x088000
[        KERNEL] [    0.197200] pci 0000:00:1f.0: [8086:a082] type 00 class 0x060100
[        KERNEL] [    0.197433] pci 0000:00:1f.3: [8086:a0c8] type 00 class 0x040100
[        KERNEL] [    0.197490] pci 0000:00:1f.3: reg 0x10: [mem 0x6003230000-0x6003233fff 64bit]
[        KERNEL] [    0.197543] pci 0000:00:1f.3: reg 0x20: [mem 0x6003000000-0x60030fffff 64bit]
[        KERNEL] [    0.197653] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[        KERNEL] [    0.197819] pci 0000:00:1f.4: [8086:a0a3] type 00 class 0x0c0500
[        KERNEL] [    0.197846] pci 0000:00:1f.4: reg 0x10: [mem 0x6003238000-0x60032380ff 64bit]
[        KERNEL] [    0.197876] pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
[        KERNEL] [    0.198019] pci 0000:00:1f.5: [8086:a0a4] type 00 class 0x0c8000
[        KERNEL] [    0.198040] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[        KERNEL] [    0.199302] pci 0000:01:00.0: [10ec:c821] type 00 class 0x028000
[        KERNEL] [    0.199302] pci 0000:01:00.0: reg 0x10: [io  0x3000-0x30ff]
[        KERNEL] [    0.199302] pci 0000:01:00.0: reg 0x18: [mem 0x84000000-0x8400ffff 64bit]
[        KERNEL] [    0.199302] pci 0000:01:00.0: supports D1 D2
[        KERNEL] [    0.199302] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[        KERNEL] [    0.199304] pci 0000:00:1c.0: PCI bridge to [bus 01]
[        KERNEL] [    0.199304] pci 0000:00:1c.0:   bridge window [io  0x3000-0x3fff]
[        KERNEL] [    0.199304] pci 0000:00:1c.0:   bridge window [mem 0x84000000-0x840fffff]
[        KERNEL] [    0.199304] pci_bus 0000:00: on NUMA node 0
[        KERNEL] [    0.199311] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0
[        KERNEL] [    0.199311] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *1
[        KERNEL] [    0.199327] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0
[        KERNEL] [    0.199381] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0
[        KERNEL] [    0.199436] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0
[        KERNEL] [    0.199491] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0
[        KERNEL] [    0.199546] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0
[        KERNEL] [    0.199600] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0
[        KERNEL] [    0.208774] ACPI: EC: interrupt unblocked
[        KERNEL] [    0.208785] ACPI: EC: event unblocked
[        KERNEL] [    0.208804] ACPI: \_SB_.PC00.LPCB.EC0_: GPE=0x6e, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[        KERNEL] [    0.208805] ACPI: \_SB_.PC00.LPCB.EC0_: Boot DSDT EC used to handle transactions and events
[        KERNEL] [    0.208843] iommu: Default domain type: Translated
[        KERNEL] [    0.208851] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[        KERNEL] [    0.208851] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[        KERNEL] [    0.208851] pci 0000:00:02.0: vgaarb: bridge control possible
[        KERNEL] [    0.208851] vgaarb: loaded
[        KERNEL] [    0.208851] ACPI: bus type USB registered
[        KERNEL] [    0.208851] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.208851] usbcore: registered new interface driver hub
[        KERNEL] [    0.208851] usbcore: registered new device driver usb
[        KERNEL] [    0.208851] pps_core: LinuxPPS API ver. 1 registered
[        KERNEL] [    0.208851] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <
giometti@linux.it>
[        KERNEL] [    0.208851] PTP clock support registered
[        KERNEL] [    0.208851] Registered efivars operations
[        KERNEL] [    0.208851] PCI: Using ACPI for IRQ routing
[        KERNEL] [    0.229679] PCI: pci_cache_line_size set to 64 bytes
[        KERNEL] [    0.229766] pci 0000:00:1f.5: can't claim BAR 0 [mem 0xfe010000-0xfe010fff]: no compatible bridge window
[        KERNEL] [    0.229845] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[        KERNEL] [    0.229846] e820: reserve RAM buffer [mem 0x674d4000-0x67ffffff]
[        KERNEL] [    0.229846] e820: reserve RAM buffer [mem 0x6895c000-0x6bffffff]
[        KERNEL] [    0.229847] e820: reserve RAM buffer [mem 0x69f1d000-0x6bffffff]
[        KERNEL] [    0.229847] e820: reserve RAM buffer [mem 0x71f00000-0x73ffffff]
[        KERNEL] [    0.229847] e820: reserve RAM buffer [mem 0x27fc00000-0x27fffffff]
[        KERNEL] [    0.229924] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[        KERNEL] [    0.231302] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[        KERNEL] [    0.231325] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[        KERNEL] [    0.231325] hpet0: 8 comparators, 64-bit 19.200000 MHz counter
[        KERNEL] [    0.232327] clocksource: Switched to clocksource tsc-early
[        KERNEL] [    0.232353] pnp: PnP ACPI init
[        KERNEL] [    0.232464] system 00:00: [io  0x0680-0x069f] has been reserved
[        KERNEL] [    0.232465] system 00:00: [io  0x164e-0x164f] has been reserved
[        KERNEL] [    0.232468] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[        KERNEL] [    0.232494] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[        KERNEL] [    0.232549] system 00:02: [io  0x1854-0x1857] has been reserved
[        KERNEL] [    0.232551] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[        KERNEL] [    0.232566] pnp 00:03: Plug and Play ACPI device, IDs HPQ8001 PNP0303 (active)
[        KERNEL] [    0.232851] system 00:04: [mem 0xfedc0000-0xfedc7fff] has been reserved
[        KERNEL] [    0.232852] system 00:04: [mem 0xfeda0000-0xfeda0fff] has been reserved
[        KERNEL] [    0.232852] system 00:04: [mem 0xfeda1000-0xfeda1fff] has been reserved
[        KERNEL] [    0.232853] system 00:04: [mem 0xc0000000-0xcfffffff] has been reserved
[        KERNEL] [    0.232853] system 00:04: [mem 0xfed20000-0xfed7ffff] has been reserved
[        KERNEL] [    0.232854] system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
[        KERNEL] [    0.232855] system 00:04: [mem 0xfed45000-0xfed8ffff] could not be reserved
[        KERNEL] [    0.232855] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
[        KERNEL] [    0.232857] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[        KERNEL] [    0.233176] system 00:05: [io  0x1800-0x18fe] could not be reserved
[        KERNEL] [    0.233177] system 00:05: [mem 0xfe000000-0xfe01ffff] could not be reserved
[        KERNEL] [    0.233178] system 00:05: [mem 0xfe04c000-0xfe04ffff] has been reserved
[        KERNEL] [    0.233178] system 00:05: [mem 0xfe050000-0xfe0affff] has been reserved
[        KERNEL] [    0.233179] system 00:05: [mem 0xfe0d0000-0xfe0fffff] has been reserved
[        KERNEL] [    0.233179] system 00:05: [mem 0xfe200000-0xfe7fffff] has been reserved
[        KERNEL] [    0.233180] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[        KERNEL] [    0.233181] system 00:05: [mem 0xfd000000-0xfd68ffff] has been reserved
[        KERNEL] [    0.233181] system 00:05: [mem 0xfd6b0000-0xfd6cffff] has been reserved
[        KERNEL] [    0.233182] system 00:05: [mem 0xfd6f0000-0xfdffffff] has been reserved
[        KERNEL] [    0.233184] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[        KERNEL] [    0.233361] system 00:06: [io  0x2000-0x20fe] has been reserved
[        KERNEL] [    0.233363] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[        KERNEL] [    0.233486] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[        KERNEL] [    0.234126] pnp: PnP ACPI: found 8 devices
[        KERNEL] [    0.234143] thermal_sys: Registered thermal governor 'step_wise'
[        KERNEL] [    0.238122] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[        KERNEL] [    0.238122] pci 0000:00:15.0: BAR 0: assigned [mem 0x4010000000-0x4010000fff 64bit]
[        KERNEL] [    0.238122] pci 0000:00:15.1: BAR 0: assigned [mem 0x4010001000-0x4010001fff 64bit]
[        KERNEL] [    0.238122] pci 0000:00:1f.5: BAR 0: assigned [mem 0x80400000-0x80400fff]
[        KERNEL] [    0.238122] pci 0000:00:1c.0: PCI bridge to [bus 01]
[        KERNEL] [    0.238122] pci 0000:00:1c.0:   bridge window [io  0x3000-0x3fff]
[        KERNEL] [    0.238122] pci 0000:00:1c.0:   bridge window [mem 0x84000000-0x840fffff]
[        KERNEL] [    0.238122] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[        KERNEL] [    0.238122] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[        KERNEL] [    0.238122] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[        KERNEL] [    0.238122] pci_bus 0000:00: resource 7 [mem 0x000e8000-0x000ebfff window]
[        KERNEL] [    0.238122] pci_bus 0000:00: resource 8 [mem 0x000ec000-0x000effff window]
[        KERNEL] [    0.238122] pci_bus 0000:00: resource 9 [mem 0x80400000-0xbfffffff window]
[        KERNEL] [    0.238122] pci_bus 0000:00: resource 10 [mem 0x4000000000-0x7fffffffff window]
[        KERNEL] [    0.238122] pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
[        KERNEL] [    0.238122] pci_bus 0000:01: resource 1 [mem 0x84000000-0x840fffff]
[        KERNEL] [    0.238122] NET: Registered protocol family 2
[        KERNEL] [    0.238122] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[        KERNEL] [    0.238122] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[        KERNEL] [    0.238122] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[        KERNEL] [    0.238122] TCP: Hash tables configured (established 65536 bind 65536)
[        KERNEL] [    0.238122] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[        KERNEL] [    0.238122] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[        KERNEL] [    0.238122] NET: Registered protocol family 1
[        KERNEL] [    0.238122] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[        KERNEL] [    0.239469] PCI: CLS 64 bytes, default 64
[        KERNEL] [    0.397044] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[        KERNEL] [    0.397046] software IO TLB: mapped [mem 0x60e0c000-0x64e0c000] (64MB)
[        KERNEL] [    0.397057] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3990bec8342, max_idle_ns: 881590769617 ns
[        KERNEL] [    0.397070] clocksource: Switched to clocksource tsc
[        KERNEL] [    0.397199] simple-framebuffer simple-framebuffer.0: framebuffer at 0x4000000000, 0x7e9000 bytes, mapped to 0x000000002e47048c
[        KERNEL] [    0.397200] simple-framebuffer simple-framebuffer.0: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[        KERNEL] [    0.397271] Console: switching to colour frame buffer device 240x67
[        KERNEL] [    0.402539] simple-framebuffer simple-framebuffer.0: fb0: simplefb registered!
[        KERNEL] [    0.402717] Initialise system trusted keyrings
[        KERNEL] [    0.402740] workingset: timestamp_bits=62 max_order=21 bucket_order=0
[        KERNEL] [    0.406970] Key type asymmetric registered
[        KERNEL] [    0.406972] Asymmetric key parser 'x509' registered
[        KERNEL] [    0.406983] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[        KERNEL] [    0.407342] pcieport 0000:00:1c.0: PME: Signaling with IRQ 122
[        KERNEL] [    0.407435] intel_idle: does not run on family 6 model 140
[        KERNEL] [    0.407515] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[        KERNEL] [    0.407532] ACPI: Lid Switch [LID0]
[        KERNEL] [    0.407557] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[        KERNEL] [    0.407570] ACPI: Power Button [PWRB]
[        KERNEL] [    0.407593] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[        KERNEL] [    0.407618] ACPI: Power Button [PWRF]
[        KERNEL] [    0.407837] Monitor-Mwait will be used to enter C-1 state
[        KERNEL] [    0.407841] Monitor-Mwait will be used to enter C-2 state
[        KERNEL] [    0.407845] Monitor-Mwait will be used to enter C-3 state
[        KERNEL] [    0.410776] thermal LNXTHERM:00: registered as thermal_zone0
[        KERNEL] [    0.410777] ACPI: Thermal Zone [TZ01] (50 C)
[        KERNEL] [    0.411026] Linux agpgart interface v0.103
[        KERNEL] [    0.411027] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <
jroedel@suse.de>
[        KERNEL] [    0.411027] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[        KERNEL] [    0.411311] zram: Added device: zram0
[        KERNEL] [    0.431443] intel-lpss 0000:00:15.0: enabling device (0004 -> 0006)
[        KERNEL] [    0.431642] intel-lpss 0000:00:15.0: Failed to create debugfs entries
[        KERNEL] [    0.455450] intel-lpss 0000:00:15.1: enabling device (0004 -> 0006)
[        KERNEL] [    0.455685] intel-lpss 0000:00:15.1: Failed to create debugfs entries
[        KERNEL] [    0.460887] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[        KERNEL] [    0.460888] ehci-pci: EHCI PCI platform driver
[        KERNEL] [    0.460913] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[        KERNEL] [    0.460914] ohci-pci: OHCI PCI platform driver
[        KERNEL] [    0.460931] uhci_hcd: USB Universal Host Controller Interface driver
[        KERNEL] [    0.461200] xhci_hcd 0000:00:14.0: xHCI Host Controller
[        KERNEL] [    0.461206] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[        KERNEL] [    0.462306] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000000009810
[        KERNEL] [    0.462311] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[        KERNEL] [    0.462389] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[        KERNEL] [    0.462390] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    0.462391] usb usb1: Product: xHCI Host Controller
[        KERNEL] [    0.462392] usb usb1: Manufacturer: Linux 5.4.72 xhci-hcd
[        KERNEL] [    0.462393] usb usb1: SerialNumber: 0000:00:14.0
[        KERNEL] [    0.462490] hub 1-0:1.0: USB hub found
[        KERNEL] [    0.462510] hub 1-0:1.0: 12 ports detected
[        KERNEL] [    0.463328] xhci_hcd 0000:00:14.0: xHCI Host Controller
[        KERNEL] [    0.463330] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[        KERNEL] [    0.463332] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[        KERNEL] [    0.463361] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[        KERNEL] [    0.463362] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    0.463363] usb usb2: Product: xHCI Host Controller
[        KERNEL] [    0.463364] usb usb2: Manufacturer: Linux 5.4.72 xhci-hcd
[        KERNEL] [    0.463364] usb usb2: SerialNumber: 0000:00:14.0
[        KERNEL] [    0.463435] hub 2-0:1.0: USB hub found
[        KERNEL] [    0.463448] hub 2-0:1.0: 4 ports detected
[        KERNEL] [    0.463723] usb: port power management may be unreliable
[        KERNEL] [    0.463868] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[        KERNEL] [    0.463868] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[        KERNEL] [    0.465276] serio: i8042 KBD port at 0x60,0x64 irq 1
[        KERNEL] [    0.465303] hv_vmbus: registering driver hyperv_keyboard
[        KERNEL] [    0.465330] mousedev: PS/2 mouse device common for all mice
[        KERNEL] [    0.465769] usbcore: registered new interface driver synaptics_usb
[        KERNEL] [    0.465808] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    0.465841] input: PC Speaker as /devices/platform/pcspkr/input/input4
[        KERNEL] [    0.465897] rtc_cmos 00:01: RTC can wake from S4
[        KERNEL] [    0.466509] rtc_cmos 00:01: registered as rtc0
[        KERNEL] [    0.466527] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
[        KERNEL] [    0.466764] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[        KERNEL] [    0.466817] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[        KERNEL] [    0.467401] intel_pstate: Intel P-state driver initializing
[        KERNEL] [    0.467502] intel_pstate: HWP enabled
[        KERNEL] [    0.467545] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    0.467616] hv_vmbus: registering driver hid_hyperv
[        KERNEL] [    0.467741] usbcore: registered new interface driver usbhid
[        KERNEL] [    0.467742] usbhid: USB HID core driver
[        KERNEL] [    0.629593] input: ELAN0712:00 04F3:30FD Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-ELAN0712:00/0018:04F3:30FD.0001/input/input5
[        KERNEL] [    0.629661] input: ELAN0712:00 04F3:30FD Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-ELAN0712:00/0018:04F3:30FD.0001/input/input7
[        KERNEL] [    0.629711] hid-multitouch 0018:04F3:30FD.0001: input,hidraw0: I2C HID v1.00 Mouse [ELAN0712:00 04F3:30FD] on i2c-ELAN0712:00
[        KERNEL] [    0.631393] NET: Registered protocol family 17
[        KERNEL] [    0.631632] IPI shorthand broadcast: enabled
[        KERNEL] [    0.631635] sched_clock: Marking stable (630821113, 477409)->(637661221, -6362699)
[        KERNEL] [    0.631665] Loading compiled-in X.509 certificates
[        KERNEL] [    0.632452] rtc_cmos 00:01: setting system clock to 2021-02-03T11:48:04 UTC (1612352884)
[        KERNEL] [    0.632979] Freeing unused kernel image memory: 3112K
[        KERNEL] [    0.667444] Write protecting the kernel read-only data: 12288k
[        KERNEL] [    0.667991] Freeing unused kernel image memory: 2020K
[        KERNEL] [    0.668057] Freeing unused kernel image memory: 284K
[        KERNEL] [    0.668058] Run /init as init process
[        KERNEL] [    0.795414] usb 1-1: new low-speed USB device number 2 using xhci_hcd
[        KERNEL] [    0.948265] usb 1-1: New USB device found, idVendor=1c4f, idProduct=0034, bcdDevice= 1.10
[        KERNEL] [    0.948267] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    0.948269] usb 1-1: Product: Usb Mouse
[        KERNEL] [    0.948270] usb 1-1: Manufacturer: SIGMACHIP
[        KERNEL] [    0.950901] input: SIGMACHIP Usb Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:1C4F:0034.0002/input/input8
[        KERNEL] [    0.951000] hid-generic 0003:1C4F:0034.0002: input,hidraw1: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-0000:00:14.0-1/input0
[          pfac] [    0.997319] Run /sbin/initrd.
[          pfac] [    0.997346] Ok, PID 1112.
[        initrd] [    0.997847] WTware 6.0.20/UEFI shell.
[        initrd] [    0.997918] Load font 'ter-c32b.psf', console 120x33.
[        initrd] [    1.005834] [UEFI] Boot0005.
[        initrd] [    1.006061] 00000000:0700000001000000900055005300420020004400720069007600650020002800  ..........U.S.B. .D.r.i.v.e. .(.
[        initrd] [    1.006069] 00000020:5500450046004900290020002D0020004B0069006E006700730074006F006E00  U.E.F.I.). .-. .K.i.n.g.s.t.o.n.
[        initrd] [    1.006075] 00000040:4400610074006100540072006100760065006C0065007200200032002E003000  D.a.t.a.T.r.a.v.e.l.e.r. .2...0.
[        initrd] [    1.006081] 00000060:50004D0041005000000002010C00D041030A0000000001010600001403050600  P.M.A.P........A...............
[        initrd] [    1.006087] 00000080:010004012A0001000000000800000000000000A0E80000000000000000000000  ....*...........................
[        initrd] [    1.006093] 000000a0:0000000000000000000001017FFF040001044600EF47642DC93BA041AC194D51  .................F..Gd-.;.A.MQ
[        initrd] [    1.006099] 000000c0:D01B4CE635003000450035003400390043003600390035004100440045004500  .L.5.0.E.5.4.9.C.6.9.5.A.D.E.E.
[        initrd] [    1.006105] 000000e0:380031004600390032003000420030003500320000007FFF04000000424F      8.1.F.9.2.0.B.0.5.2........BO
[        initrd] [    1.006111] [UEFI] USB Drive (UEFI) - KingstonDataTraveler 2.0PMAP.
[        initrd] [    1.006117] [UEFI] Skip type 0x02, subtype 0x01, length 12.
[        initrd] [    1.006123] [UEFI] Skip type 0x01, subtype 0x01, length 6.
[        initrd] [    1.006129] [UEFI] Looks like USB boot.
[        initrd] [    1.006136] USB boot.
[        KERNEL] [    1.075407] usb 1-2: new high-speed USB device number 3 using xhci_hcd
[        KERNEL] [    1.226970] usb 1-2: New USB device found, idVendor=0930, idProduct=6545, bcdDevice= 1.00
[        KERNEL] [    1.226973] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[        KERNEL] [    1.226975] usb 1-2: Product: DataTraveler 2.0
[        KERNEL] [    1.226976] usb 1-2: Manufacturer: Kingston
[        KERNEL] [    1.226977] usb 1-2: SerialNumber: 50E549C695ADEE81F920B052
[        KERNEL] [    1.355384] usb 1-3: new high-speed USB device number 4 using xhci_hcd
[        KERNEL] [    1.513492] usb 1-3: New USB device found, idVendor=0408, idProduct=5365, bcdDevice= 0.02
[        KERNEL] [    1.513494] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    1.513495] usb 1-3: Product: HP TrueVision HD Camera
[        KERNEL] [    1.513496] usb 1-3: Manufacturer: SunplusIT Inc
[        KERNEL] [    1.639620] usb 1-10: new full-speed USB device number 5 using xhci_hcd
[        KERNEL] [    1.788465] usb 1-10: New USB device found, idVendor=0bda, idProduct=b00e, bcdDevice= 1.10
[        KERNEL] [    1.788467] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[        KERNEL] [    1.788468] usb 1-10: Product: Bluetooth Radio
[        KERNEL] [    1.788469] usb 1-10: Manufacturer: Realtek
[        KERNEL] [    1.788470] usb 1-10: SerialNumber: 00e04c000001
[        KERNEL] [    4.390922] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input18
