Сброс TCP соединения со стороны терминала
Добавлено: Пт дек 16, 2022 12:22 pm
Добрый день, столкнулся с проблемой, терминал msi cubi n jsl-043bru с WtWare версии 6.0.94 сбрасывает соединение на этапе установки TCP- сессии: https://prnt.sc/h5dbPUkpOUoP
В данном примере 195.195.195.198- Сервер под управлением Windows 10, 195.195.195.199- Терминал.
Лог терминала:
В чем может быть причина такого поведения? Конфликта Ip адресов нет
Лог терминала:
[ gm] [ 4.417206] +--- Executing "/usr/local/samba/sbin/smbd -D"
[ gm] [ 4.445025] +- Errorlevel: 0, output:
| [No output]
[ gm] [ 4.445061] +------------------------
[ gm] [ 4.447665] Run '/sbin/resolver 0x5642076b0240 dns [195.195.195.198]', log '', env '', pid ''.
[ gm] [ 4.447681] Nobody can control terminal by VNC.
[ gm] [ 4.447689] Nobody can control terminal by WTRC.
[ pfac] [ 4.447831] Run /sbin/resolver 0x5642076b0240 dns [195.195.195.198].
[ gm] [ 4.447841] [EVDEV] Keys found. Add event10: Video Bus.
[ pfac] [ 4.447848] Ok, PID 616.
[ pfac] [ 4.449036] Process pid 616 terminated, status 00000000.
[ gm] [ 4.449666] 195.195.195.198 => 195.195.195.198.
[ gm] [ 4.450937] Free ram before fork terminal client /sbin/rdpclient (session 1): 3737452 Kb.
[ gm] [ 4.450953] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 4.450968] Run /sbin/rdpclient 1.
[ pfac] [ 4.451038] Ok, PID 618.
[ rdpclient 618] [ 4.465726] RDP Terminal Client, WTware 6.0.94/UEFI, pipe 1, pid 618.
[ rdpclient 618] [ 4.467242] Use /usr/lib/ui32.so.
[ rdpclient 618] [ 4.470310] Make RDP session with 195.195.195.198, port 3389.
[ rdpclient 618] [ 4.470330] Username: "CEH6".
[ rdpclient 618] [ 4.470338] No password.
[ rdpclient 618] [ 4.470345] No PIN.
[ rdpclient 618] [ 4.470367] Domain: "local".
[ rdpclient 618] [ 4.470375] No shell.
[ rdpclient 618] [ 4.470382] No directory.
[ rdpclient 618] [ 4.470390] Window: 1856x1080@32.
[ rdpclient 618] [ 4.470397] PFlags 0x000000AC.
[ rdpclient 618] [ 4.470420] Keyboard 00000409:00000000.
[ rdpclient 618] [ 4.470426] My hostname "wtw04421AC956AC".
[ rdpclient 618] [ 4.470433] TCP: connecting to 195.195.195.198:3389.
[ KERNEL] [ 6.781530] r8169 0000:01:00.0 eth0: Link is Up - 1Gbps/Full - flow control off
[ rdpclient 618] [ 7.546395] Connection failed with errno 113.
[ rdpclient 618] [ 8.546688] Got errno: 103.
[ rdpclient 618] [ 8.546769] rdpclient-tcp.cpp ( 480): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 618] [ 8.546801] Сервер 195.195.195.198, порт 3389: отказано в подключении.
Убедитесь, что на этом сервере работает служба терминалов
и попробуйте подключиться к ней стандартным клиентом
службы терминалов mstsc.exe.
[ gm] [ 8.547031] Session is over. Final message: Сервер 195.195.195.198, порт 3389: отказано в подключении.
[RDP] close kotopipe (n = 0, errno 2).
[ pfac] [ 8.547633] Process pid 618 terminated, status 00000009.В чем может быть причина такого поведения? Конфликта Ip адресов нет
