ошибка сетевой загрузки.
Добавлено: Вт сен 01, 2009 4:20 pm
Alexander4561
карточка: Realteck RTL 8169/8110 family gigabit
при загрузке появляется сообщение о том что нет ответа от dhcp сервера. лог ниже.
SUCCESS: WTware TFTP server (c) 2003-2008 WTware http://www.wtware.com
INFO : Got RRQ, 36 bytes.
INFO : 00000000: 70 72 6f 5c 34 2e 35 2e 32 39 5c 70 78 65 6c 69
INFO : 00000010: 6e 75 78 2e 30 00 6f 63 74 65 74 00 74 73 69 7a
INFO : 00000020: 65 00 30 00
INFO : 192.168.0.38 requests file "pro\4.5.29\pxelinux.0". Tsize is requested, blksize default.
INFO : Sending OASK (tsize 13340) to 192.168.0.38.
WARNING: Received opcode 5 from 192.168.0.38.
WARNING: 00000000: 00 05 00 00 54 46 54 50 20 41 62 6f 72 74 65 64
WARNING: 00000010: 00
INFO : Got RRQ, 41 bytes.
INFO : 00000010: 6e 75 78 2e 30 00 6f 63 74 65 74 00 62 6c 6b 73
INFO : 00000020: 69 7a 65 00 31 34 35 36 00
INFO : 192.168.0.38 requests file "pro\4.5.29\pxelinux.0". Tsize is not requested, blksize 1456 bytes.
INFO : Sending OASK (blksize 1456) to 192.168.0.38.
INFO : Transfer of file "pro\4.5.29\pxelinux.0" to 192.168.0.38 completed.
INFO : Connection to 192.168.0.38 closed.
INFO : Got RRQ, 72 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 30 31 2d 30 30 2d 31 61
INFO : 00000020: 2d 34 64 2d 32 36 2d 38 39 2d 38 39 00 6f 63 74
INFO : 00000030: 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69
INFO : 00000040: 7a 65 00 31 34 34 30 00
INFO : 192.168.0.38 requests file "pro\4.5.29\pxelinux.cfg\01-00-1a-4d-26-89-89". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.38 file "C:\Program Files\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\01-00-1a-4d-26-89-89" not found.
INFO : Got RRQ, 60 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 38 30 30 32 36
INFO : 00000020: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62
INFO : 00000030: 6c 6b 73 69 7a 65 00 31 34 34 30 00
INFO : 192.168.0.38 requests file "pro\4.5.29\pxelinux.cfg\C0A80026". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.38 file "C:\Program Files\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C0A80026" not found.
INFO : Got RRQ, 59 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 38 30 30 32 00
INFO : 00000020: 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c
INFO : 00000030: 6b 73 69 7a 65 00 31 34 34 30 00
INFO : 192.168.0.38 requests file "pro\4.5.29\pxelinux.cfg\C0A8002". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.38 file "C:\Program Files\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C0A8002" not found.
INFO : Got RRQ, 58 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 38 30 30 00 6f
INFO : 00000020: 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b
INFO : 00000030: 73 69 7a 65 00 31 34 34 30 00
INFO : 192.168.0.38 requests file "pro\4.5.29\pxelinux.cfg\C0A800". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.38 file "C:\Program Files\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C0A800" not found.
INFO : Got RRQ, 57 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 38 30 00 6f 63
INFO : 00000020: 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73
INFO : 00000030: 69 7a 65 00 31 34 34 30 00
INFO : 192.168.0.38 requests file "pro\4.5.29\pxelinux.cfg\C0A80". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.38 file "C:\Program Files\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C0A80" not found.
INFO : Got RRQ, 56 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 38 00 6f 63 74
INFO : 00000020: 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69
INFO : 00000030: 7a 65 00 31 34 34 30 00
INFO : 192.168.0.38 requests file "pro\4.5.29\pxelinux.cfg\C0A8". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.38 file "C:\Program Files\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C0A8" not found.
INFO : Got RRQ, 55 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 00 6f 63 74 65
INFO : 00000020: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
INFO : 00000030: 65 00 31 34 34 30 00
INFO : 192.168.0.38 requests file "pro\4.5.29\pxelinux.cfg\C0A". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.38 file "C:\Program Files\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C0A" not found.
INFO : Got RRQ, 54 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 00 6f 63 74 65 74
INFO : 00000020: 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65
INFO : 00000030: 00 31 34 34 30 00
INFO : 192.168.0.38 requests file "pro\4.5.29\pxelinux.cfg\C0". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.38 file "C:\Program Files\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C0" not found.
INFO : Got RRQ, 53 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 00 6f 63 74 65 74 00
INFO : 00000020: 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00
INFO : 00000030: 31 34 34 30 00
INFO : 192.168.0.38 requests file "pro\4.5.29\pxelinux.cfg\C". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.38 file "C:\Program Files\WTware\TFTPDROOT\pro\4.5.29\pxelinux.cfg\C" not found.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 64 65 66 61 75 6c 74 00
INFO : 192.168.0.38 requests file "pro\4.5.29\pxelinux.cfg\default". Tsize is requested, blksize 1440 bytes.
INFO : Sending OASK (tsize 222, blksize 1440) to 192.168.0.38.
INFO : Transfer of file "pro\4.5.29\pxelinux.cfg\default" to 192.168.0.38 completed.
INFO : 00000000: 70 72 6f 5c 34 2e 35 2e 32 39 5c 77 74 73 68 65
INFO : 00000010: 6c 6c 2f 62 7a 49 6d 61 67 65 00 6f 63 74 65 74
INFO : 192.168.0.38 requests file "pro\4.5.29\wtshell\bzImage". Tsize is requested, blksize 1440 bytes.
INFO : Sending OASK (tsize 1147904, blksize 1440) to 192.168.0.38.
INFO : Transfer of file "pro\4.5.29\wtshell\bzImage" to 192.168.0.38 completed.
INFO : 00000010: 6c 6c 2f 77 74 73 68 65 6c 6c 00 6f 63 74 65 74
INFO : 192.168.0.38 requests file "pro\4.5.29\wtshell\wtshell". Tsize is requested, blksize 1440 bytes.
INFO : Sending OASK (tsize 1822720, blksize 1440) to 192.168.0.38.
INFO : Transfer of file "pro\4.5.29\wtshell\wtshell" to 192.168.0.38 completed.
INFO : Timeout occured while transfer "pro\4.5.29\pxelinux.0" to 192.168.0.38.
WARNING: Client 192.168.0.38 not responding. Connection closed.
Re: ошибка сетевой загрузки.
Добавлено: Вт сен 01, 2009 4:36 pm
Свежая версия втвари называется 4.5.32.
Если не поможет - перепиши пожалуйста ВСЕ, что написано на экране в сообщении об ошибке.
Добавлено: Ср сен 02, 2009 10:19 am
Alexander4561
не помогло. на соседней машине с такойже картой все нормально. экран ошибки:
"При загрузке терминала произошла ошибка
ОШИБКА:Нет ответа от dhcp сервера
NIC1 PCIID 1106:3106
NIC2 PCIID 10ec:8167
продолжение работы не возможно пока ошибка не будет устранена.
далее указаны места где лежит документация и способы связи.
Добавлено: Ср сен 02, 2009 10:54 am
Убери вторую сетевую карту. Втварь не умеет работать с двумя сетевыми картами.
