Не грузится флешка из фотоаппарата в режиме стораже кард...
Добавлено: Чт мар 11, 2010 11:55 am
Стояла версия 4,5,29, некоторые грузились.... а на одной машине не захотело.
вот лог после подключения устройства:
init: directory ""
init: video 1024x768@24
init: pflags 000000EE
init: keyboard 00000419:00000000
init: hostname "wtw001111144992"
init: ipaddr "10.1.60.52"
init: RDP5 encryption (X.509).
init: RC4 key 128 bit.
init: Iteration, free RAM 58192 Kb
init: Iteration, free RAM 58180 Kb
init: Iteration, free RAM 58168 Kb
init: Iteration, free RAM 58156 Kb
init: Iteration, free RAM 58144 Kb
init: Iteration, free RAM 58120 Kb
KERNEL: usb 1-3: new high speed USB device using ehci_hcd and address 2
KERNEL: usb 1-3: New USB device found, idVendor=054c, idProduct=0340
KERNEL: usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
KERNEL: usb 1-3: Product: DSC-W130
KERNEL: usb 1-3: Manufacturer: Sony
KERNEL: usb 1-3: SerialNumber: D34B9075F735
KERNEL: usb 1-3: configuration #1 chosen from 1 choice
KERNEL: scsi0 : SCSI emulation for USB Mass Storage devices
KERNEL: usb-storage: device found at 2
KERNEL: usb-storage: waiting for device to settle before scanning
KERNEL: scsi 0:0:0:0: Direct-Access Sony DSC 1.00 PQ: 0 ANSI: 0 CCS
KERNEL: usb-storage: device scan complete
KERNEL: sd 0:0:0:0: [sda] 1951744 512-byte logical blocks: (999 MB/953 MiB)
KERNEL: sd 0:0:0:0: [sda] Write Protect is off
KERNEL: sd 0:0:0:0: [sda] Mode Sense: 00 6a 20 00
KERNEL: sd 0:0:0:0: [sda] Assuming drive cache: write through
KERNEL: sda: sda1
KERNEL: FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
KERNEL: FAT: bogus number of reserved sectors
KERNEL: VFS: Can't find a valid FAT filesystem on dev sda.
hotplug: R/w mount ("/dev/sda", "/mnt/usb-rdp/0",..) failed, errno 22.
KERNEL: sd 0:0:0:0: [sda] Attached SCSI removable disk
hotplug: R/o mount ("/dev/sda", "/mnt/usb-rdp/0",..) failed, errno 22.
init: Iteration, free RAM 58004 Kb
init: Iteration, free RAM 57992 Kb
hotplug: Success: USB1p1 mounted.
Флэшка не видится.....
Что может быть причиной????
init: directory ""
KERNEL: sda: sda1
