Проблема с OpenVPN
Проблема с OpenVPN
WTWare Pro 4.6.1
Установлена на жесткий. При попытке настроить Open VPN загружаясь долго висит прогрессбар потом говорит "Open VPN failed" и всё.... Из под Винды с этими же ключами все ок. Вот лог OpenVPN - сервера:
Mon Oct 11 11:37:13 2010 MULTI: multi_create_instance called
Mon Oct 11 11:37:13 2010 94.***.***.85:10540 Re-using SSL/TLS context
Mon Oct 11 11:37:13 2010 94.***.***.85:10540 LZO compression initialized
Mon Oct 11 11:37:13 2010 94.***.***.85:10540 Control Channel MTU parms [ L:1574 D:138 EF:38 EB:0 ET:0 EL:0 ]
Mon Oct 11 11:37:13 2010 94.***.***.85:10540 Data Channel MTU parms [ L:1574 D:1450 EF:42 EB:135 ET:32 EL:0 AF:3/1 ]
Mon Oct 11 11:37:13 2010 94.***.***.85:10540 Local Options hash (VER=V4): 'f7df56b8'
Mon Oct 11 11:37:13 2010 94.***.***.85:10540 Expected Remote Options hash (VER=V4): 'd79ca330'
Mon Oct 11 11:37:13 2010 94.***.***.85:10540 TLS: Initial packet from 94.***.***.85:10540, sid=d5459bea 358d2f77
Mon Oct 11 11:37:14 2010 94.***.***.85:10540 VERIFY OK: depth=1, /C=RU/ST=AST/L=Astrakhan/O=*******/emailAddress=k_quiet@mail.ru
Mon Oct 11 11:37:14 2010 94.***.***.85:10540 VERIFY OK: depth=0, /C=RU/ST=AST/O=*******/OU=Kirova_01/CN=Kirova_01/emailAddress=k_quiet@mail.ru
Mon Oct 11 11:37:14 2010 94.***.***.85:10540 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mon Oct 11 11:37:14 2010 94.***.***.85:10540 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Oct 11 11:37:14 2010 94.***.***.85:10540 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mon Oct 11 11:37:14 2010 94.***.***.85:10540 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Oct 11 11:37:14 2010 94.***.***.85:10540 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Mon Oct 11 11:37:14 2010 94.***.***.85:10540 [Kirova_01] Peer Connection Initiated with 94.***.***.85:10540
Mon Oct 11 11:37:17 2010 Kirova_01/94.***.***.85:10540 PUSH: Received control message: 'PUSH_REQUEST'
Mon Oct 11 11:37:17 2010 Kirova_01/94.***.***.85:10540 SENT CONTROL [Kirova_01]: 'PUSH_REPLY,route 192.168.168.0 255.255.255.0 10.1.0.1,ping 10,ping-restart 120,ifconfig 10.1.0.4 255.255.255.0' (status=1)
Mon Oct 11 11:37:19 2010 read UDPv4: Connection reset by peer (WSAECONNRESET) (code=10054)
Mon Oct 11 11:37:21 2010 read UDPv4: Connection reset by peer (WSAECONNRESET) (code=10054)
Mon Oct 11 11:37:22 2010 read UDPv4: Connection reset by peer (WSAECONNRESET) (code=10054)
// и так еще примерно 30 строк ///
Mon Oct 11 11:40:40 2010 read UDPv4: Connection reset by peer (WSAECONNRESET) (code=10054)
Mon Oct 11 11:40:41 2010 read UDPv4: Connection reset by peer (WSAECONNRESET) (code=10054)
Mon Oct 11 11:40:43 2010 read UDPv4: Connection reset by peer (WSAECONNRESET) (code=10054)
Mon Oct 11 11:41:17 2010 Kirova_01/94.***.***.85:10540 [Kirova_01] Inactivity timeout (--ping-restart), restarting
Mon Oct 11 11:41:17 2010 Kirova_01/94.***.***.85:10540 SIGUSR1[soft,ping-restart] received, client-instance restarting
Судя по логу авторизация проходит успешно, в чем дело не понятно. Что делать?
Re: Проблема с OpenVPN
Разбираться. Я ничего не понимаю в OpenVPN.
WTware использует такой конфиг:
client
dev tun
proto udp
nobind
ca /etc/ca.crt
cert /etc/client.crt
key /etc/client.key
ns-cert-type server
comp-lzo
verb 1
daemon
remote 1.2.3.4 1194
Отдай этот конфиг клиенту vpn в виндовсе, который "все ок". Пути только к ключам правильные и вместо 1.2.3.4 IP сервера напиши. И смотри, что скажет сервер и что поменять в конфиге сервера, чтобы виндовс с таким конфигом подключилась. Потом расскажи
client
dev tun
proto udp
nobind
ca /etc/ca.crt
key /etc/client.key
ns-cert-type server
comp-lzo
verb 1
daemon
remote 1.2.3.4 1194
проблема понятна. разный тип DEV. а как можно поменять конфиг? т.е. отредактировать ручками?
Конфиг втвари никак не поменять. Меняй конфиг сервера.
dev - тип виртуального устройства туннеля. Может принимать значение tun или tap. Тun позволяет создавать только соединения типа точка-точка, tap виртуальные сегменты Еthernet.
дело в том, что dev=tun не поддерживает широковещательные запросы и на нем не будет нормальной ethernet сети.
как сделать чтоб работало dev=tap?
Никак не сделать. В конфиге openvpn по умолчанию написано tun. Поэтому так сложилось.
Тогда пожалуй будет честным написать в описании WtWare "поддержки OpenVPN нет и не будет", т.к. если у меня двадцать терминалов мне надо на Win-сервере создать 20 виртуальных сетевых адаптеров. А если 100 - то 100 адаптеров. Это просто бред.
P.S. Вот небольшой ликбез:
http://www.ru.kurlix.de/index.php?optio ... &Itemid=27
В описании WTware честно написано, что WTware это клиент службы терминалов Windows Terminal Services. Сейчас в планах - уменьшить задержку звука, сделать перенаправление микрофона, затем большая работа по перенаправлению USB. Это все функции клиента службы терминалов, которые никто не может заменить. Поддержка кофеварок, OpenVPN и подобного вторична и выполняется по остаточному принципу. Потому, что если клиенту нужно получить более функциональную поддержку кофеварок, OpenVPN и подобного, он всегда может поставить для этой задачи специальное устройство.
И покажи пожалуйста, где написано, что для второго tun соединения необходимо делать второй адаптер.
Продолжение истории. Вернее начало.
Заморочка с Open VPN нужна мне для того чтобы заставить работать принтер в удаленной подсети и чтобы на него могли печатать остальные клиенты этой подсети, естественно все эти киенты - WtWare. И клиент к которому подключен принтер тоже. Все это безобразие попадает на сервер терминалов через ADSL-модем с проброшенным портом 3389, что само по себе очень хреново (плохо), т.к. сервер смотрит в инет через статику на ADSL-модеме портом 3389 и любой человек с любой точки зная статику попадает на вход терм.сервера и все, немного социальной инженерии и кирдык серваку. Вариант с использование Open VPN решил бы эту проблему, а заодно и проблему принтера тоже, но увы. Кофеварки.... мать их. Заставить принтер работать через usbip не удалось, т.к. при подключении к wtware-клиенту в локальной сети сервера все замечательно. А при подключении в удаленной подсети - болт. Не видит сервер принтер через два ADSL-модема. Может нам денег каких-нибудь заплатить за персональную доработку, за изменение tun на tap.
И еще. Про создание соединения и про добавление еще адаптеров подробно написано в статьях из моего предидущего поста. Хотя из фразы "соединение точка-точка" и так все понятно.
Пожалуйста, покажи мне, где это написано явно. Статьи я прочитал, такого смысла в них не нашел. И из фразы "соединение точка-точка" мне не понятно, почему звезда не может быть множеством соединений точка-точка.k_quiet писал(а):И еще. Про создание соединения и про добавление еще адаптеров подробно написано в статьях из моего предидущего поста. Хотя из фразы "соединение точка-точка" и так все понятно.
k_quiet - в этом случае я точно за aka
Поясню - k_quiet что вам мешает поставить железяку(роутер) которая сделает нормальный закрытый туннель между сетями - это даст вам все , и защищенный туннель и не надо маяться с пробросом портов, не надо настраивать VPN на каждом терминале - да и много что еще !
VPN на терминальном клиенте имеет смысл если их 1-2шт на удаленной точке (ИМХО)
to aka:
явно это написано здесь:
Затем с помощью меню «Пуск –> Программы –> Open –> VPNAdd a new TAP-win32 virtual ethernet adapter» создаем еще один виртуальный интерфейс и переименовываем его во FreeBSD.
и здесь:
Затем создаем конфигурационные файлы наших туннелей.
Файл windows-freebsd.ovpn:
remote 80.80.20.129
dev-node FreeBSD
dev tun
port 5001
ifconfig 10.3.0.2 10.3.0.1
secret static.txt
ping 10
verb 3
route 10.10.120.0 255.255.255.0 10.3.0.1
auth MD5
cipher DES-CBC
comp-lzo
Файл windows-linux.ovpn:
remote 80.80.20.131
dev tun
dev-node Linux
port 5002
ifconfig 10.3.0.5 10.3.0.6
secret static.txt
ping 10
verb 3
route 10.10.140.0 255.255.255.0 10.3.0.6
tun-mtu 1500
comp-lzo
Как мы видим подсеть одна, но два виртуальных адаптера и по одному конфигу для каждого, в каждом из которых прописан тунель точка-точка. Это особенность Open VPN при использовании режима tun.
to shdn777:
терминалов планируется 2-4, а самих удаленных точек 5-10. Вот такая заморочка.
и здесь:
remote 80.80.20.129
dev-node FreeBSD
dev tun
port 5001
secret static.txt
ping 10
verb 3
auth MD5
cipher DES-CBC
comp-lzo
remote 80.80.20.131
dev tun
dev-node Linux
port 5002
secret static.txt
ping 10
verb 3
tun-mtu 1500
comp-lzo
to shdn777:
k_quiet присмотрись к http://mikc.ru/product.php?id_catalog=2&id_position=193 (там и OpenVPN тоже есть) - не примите за рекламу просто у самого в эксплуатации таких штук 10 - 15 , не нарадуюсь там сетями можно крестиком вышивать !
k_quiet
Оттуда же, из второй твоей статьи:
Сейчас я по организационным обстоятельствам не могу собрать 4.6 версию. Через неделю-две выйдет наконец 4.9 со звуком (звуковой траффик уменьшится в восемь раз, еу суперкруто ), и если к тому времени не решишь задачу как-то иначе - подними еще раз эту тему. Попробуем как-нибудь выкрутиться.
Т.е. либо можно таки зарулить через один интерфейс (попробуй наконец, а?), либо "большое число" интерфейсов не представляет никаких проблем кроме субъективно-эстетических.Но если необходимо развернуть OpenVPN как VPN-концентратор для большого числа пользователей, то маршрутизация обеспечивает более высокую гибкость.
Вобщем продолжение истории:
OpenVPN заработал! В версиях OpenVPN старше 2.1 появился параметр 'topology subnet', который заставляет работать OpenVPN в режиме 'tun' как мне надо. В итоге в трех разных удаленных офисах стоит по три терминала с WtWare которые грузятся с USB Flash, подключаются к серваку по OpenVPN через ADSL-роутер D-Link 2500, в один из терминалов в каждом офисе воткнут Samsung SCX-4220 на который могут печатать пользователи с любых(!!!!) терминалов любого офиса! Статический адрес только в офисе где стоит терминальный сервер, в остальных офисах адреса динамические. Машин кроме сервака с Windows в офисах нет вообще! Но! HP P1006 так запустить и не удалось. То есть задание на него отправляется, он моргает лампочкой, жужжит, и усе. Хотя при подключении к терминалу в локальной (не удаленной) сети с сервером он печатал.
Может, таймауты и все такое? Принтер думает, что ему отвечает комп рядом. А тут пакеты ходят через Антарктиду, паузы между пакетами непонятной длины, но всегда большие...k_quiet писал(а):задание на него отправляется, он моргает лампочкой, жужжит, и усе. Хотя при подключении к терминалу в локальной (не удаленной) сети с сервером он печатал.
А Вы могли бы подробнее объяснить как у вас построено?k_quiet писал(а):Вобщем продолжение истории:
А то моему руководству понравилась новая фича в ВТВаре5 (а именно переключение между несколькими рабочими столами ), и нужно эту фичу сделать на удаленных точках. Соответственно стандартный удаленный способ подключения отпадает.
OpenVPN еще настраивать мне не доводилось.
Может какую ссылку бросите, на описание с чего начать.
1. Принтер HP P1006 заработал - поиск по форуму рулит - USB 2.0 Disable
2. Если нет опыта настройки OpenVPN рекомендую ссылки в данном посте выше и очень полезна оказалась ветка форума на iXBT - http://forum.ixbt.com/topic.cgi?id=14:40906
Мы работаем на версии WtWare 4.6.9 на DHCP от Microsoft, ОС - Win Server 2003, OpenVPN 2.1
WtWare 5 пока не используем. Использование OpenVPN обусловленно наличием беспроводной сети в одном из офисов, соображениями безопасности - закрыт стандартный порт 3389, и самое важное в нашем случае возможность печати на принтеры клиентов в офисах при отсутствии драйверов на них самих, т.е. все драйвера на сервере.
Последний раз редактировалось k_quiet Вс дек 26, 2010 12:42 pm, всего редактировалось 1 раз.
Спасибо за ссылку
Не работает OpenVPN
Привет всем. Есть такая проблема, никак не могу разобраться как правильно настроить OpenVPN на клиенте WTware 5.0.7. Загрузка с USB flash.
У меня работает сервак OpenVPN на статическом адресе.
Копирую файлы с ключами в каталог configs на флешке, это ясно. Но дальше где прописать адрес VPN сервера? если при загрузк нажать del, там нет такого пункта про котрый в инструкции написано.
Re: Не работает OpenVPN
В 4.6.х работал openvpn, в 5.х его так и не перенесли по причине отсутствия спроса
Сильно надо? С глюками отладоччной версии бороться будешь?
OpenVPN и мне нужен будет на 5 версии.
Но не прямо сейчас, где-то через месяц доберусь до удаленных офисов.
Ну смотрте какая ситуация. На сколько мне известно, вообще пробем с OpenVPN особенно нет. Один раз настроил и что говорится забыл. Я готов потестировать и сообщать о появляющихся глюках, если в итоге они будут устранены.
Просто у меня много компов в разных организациях. большая часть используются как клиенты серверов терминалов.
Я хочу все эти компы перевести на wtware, предварительно снять с них жесткие диски и сделав загрузку с флешки. Это значительно облегчит задачу администрироания.
Но многие работаютодновоеменно с двумя серверами терминалов. И как правило, второй сервер находится вне офиса. А для правильной работы нужно настроить печать. А сделать это можно как я понял только путем организации VPN.
Функция "rdp_printer" у меня не работает.
Проброс порта на сервер средством usbip работает крайне не стабильно.
Единственное, что достаточно стабильно пашет, это "printer=usb", с настройкой на порт RAW 9100.
Но как на него будет печатать сервер, если находится в другой сети. Только, если бдет поднят VPN!
Или есть какие то другие решения?
Да, я тоже не слышал о хронических проблемах втвари с openvpn. Просто втварь делается "по грамотному запросу". С начала 5.х версий запроса с готовностью тестировать до победы не было, вот и не прикрутили. Сделаем. Напиши мне письмо на aka@pxe.ru или на icq 89596217 чтоб быстрее контакт был.el_angelo писал(а):На сколько мне известно, вообще пробем с OpenVPN особенно нет. Один раз настроил и что говорится забыл.
...или функцией rdp_printer=.el_angelo писал(а):второй сервер находится вне офиса. А для правильной работы нужно настроить печать. А сделать это можно как я понял только путем организации VPN.
Так и пишет - "не работаю у тебя" русскими буквами? Давай ее починим, может не понадобится vpn поднимать. Загрузка по сети еще сильнее облегчает администрирование.el_angelo писал(а):Функция "rdp_printer" у меня не работает.
Механизм работы у rdp_printer= и printer= одинаковый. Если одно работает а второе не работает, то вероятно это наша ошибка. Логи давай - для начала лог после успешной отправки тестового задания на печать через printer= и лог со скриншотом проблемы с rdp_printer=.el_angelo писал(а):Единственное, что достаточно стабильно пашет, это "printer=usb", с настройкой на порт RAW 9100.
Кстате да ВПН нужная штука, если терминалы стоят вне офиса...
Плюсодин нужно ВПН, тестить смогу.
Для сканеров надо, а не только для принтеров
Товарищи плюсодины, попробуйте 5.1.14. Должна поехать openvpn. Свежие доки тоже надо посмотреть:
http://forum.wtware.ru/viewtopic.php?t=8434
http://wtware.ru/openvpn.html
