Добрый день
Терминальные серверы 2008R2, 4 штуки.
Версия wtware 4.6.11 и 4.9.28
В конфиге указываю ask_password=on, при загрузке появляется окошко ввода учетных данных,
ввожу данные, после этого все-равно запрашивается пароль на каждом сервере при переборе.
если ask_password не включать картина та же.
Session broker
Re: Session broker
Лог в студию.
Re: Session broker
[gm] New shared memory block 1024x768@32bit: id 0x00030004, address 0xb751d000.
[pfac] Got command line /sbin/resolver 0 dns [192.168.155.3].
[pfac] Ok, PID 429.
[gm] 192.168.155.3 => 192.168.155.3.
[pfac] Process pid 429 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 499908 Kb.
[pfac] Ok, PID 430.
[rdpclient 430] RDP Terminal Client, WTware v.4.9.27, pipe 1, pid 430.
[rdpclient 430] Add WTVC WTware control channel.
[rdpclient 430] Make RDP session with 192.168.155.3:3389.
[rdpclient 430] Username: "root@domain.int".
[rdpclient 430] Password: present.
[rdpclient 430] No domain.
[rdpclient 430] No shell.
[rdpclient 430] No directory.
[rdpclient 430] Window: 1024x768@24.
[rdpclient 430] PFlags 0x0000006F.
[rdpclient 430] Keyboard 00000409:00000000.
[rdpclient 430] My hostname "wtw00155D221921".
[rdpclient 430] TCP: connecting to 192.168.155.3:3389.
[rdpclient 430] TCP: connection with 192.168.155.3:3389 established.
[rdpclient 430] Free ram after buffers allocation: 493452 KB.
[rdpclient 430] RDP5 encryption (X.509).
[rdpclient 430] RC4 key 128 bit.
[rdpclient 430] 32-bit color.
[rdpclient 430] Server Redirection flags 0x0000000d.
[rdpclient 430] Server 192.168.155.9.
[rdpclient 430] User Root
[rdpclient 430] Domain DOMAIN
[rdpclient 430] LOGON_EX_LOGONERRORS
[rdpclient 430] Got PDUTYPE2_SET_ERROR_INFO_PDU with errorInfo 0x00000000.
[rdpclient 430] No additional information is available.
[rdpclient 430] Receive Disconnect Provider Ultimatum.
[gm] TSClient gracefully end.
[rdpclient 430] Caught signal SIGTERM.
[pfac] Process pid 430 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 2): 499908 Kb.
[pfac] Got command line /sbin/rdpclient 2.
[pfac] Ok, PID 431.
[rdpclient 431] RDP Terminal Client, WTware v.4.9.27, pipe 2, pid 431.
[rdpclient 431] Add WTVC WTware control channel.
[rdpclient 431] Make RDP session with 192.168.155.9:3389.
[rdpclient 431] Username: "Root".
[rdpclient 431] Password: present.
[rdpclient 431] Domain: "DOMAIN".
[rdpclient 431] No shell.
[rdpclient 431] No directory.
[rdpclient 431] Window: 1024x768@24.
[rdpclient 431] PFlags 0x0000006F.
[rdpclient 431] Keyboard 00000409:00000000.
[rdpclient 431] My hostname "wtw00155D221921".
[rdpclient 431] TCP: connecting to 192.168.155.9:3389.
[rdpclient 431] TCP: connection with 192.168.155.9:3389 established.
[rdpclient 431] Free ram after buffers allocation: 493452 KB.
[rdpclient 431] Empty Balance Info.
[rdpclient 431] RDP5 encryption (X.509).
[rdpclient 431] RC4 key 128 bit.
[rdpclient 431] 32-bit color.
[rdpclient 431] LOGON_EX_LOGONERRORS
[rdpclient 431] SessionId 0x000000de: DOMAIN\Root.
Ввел пароль в форму wtware, затем ввел в появившемся запросе от первого сервера, потом перекинуло на следующий и после ввода там - залогинился. Ввод логина пробовал и как user@domain и как domain\user. Никакой разницы.
[pfac] Ok, PID 429.
[pfac] Ok, PID 430.
[pfac] Ok, PID 431.
Re: Session broker
Если заходить этим же пользователем на этот же сервер штатным виндовым mstsc, сколько будет запросов пароля?
Оно НЕ должно спрашивать пароль ни разу. Кроме втваревой формы. В логе написано "[rdpclient 430] Password: present.", значит втварь отдает серверу пароль.
В настройках RDP-Tcp connection на серверах, в Log on Settings галка Always prompt for password случайно не установлена?
