Не могу подключиться к серверу
Добавлено: Ср май 20, 2015 10:53 am
				Здрасте.
трабл.
Убедитесь, что на этом сервере работает служба терминалов и попробуйте подключиться к ней стандартым клиентом mstsc.exe
лог
WTware v.5.2.28
WTware v.5.2.28 supervisor.
WTC listener is active.
HTTPd listener is active.
[KERNEL] [ 0.000000] Linux version 3.14.40 (root@c8) (gcc version 4.9.2 (Ubuntu 4.9.2-10ubuntu13) ) #1 PREEMPT Wed Apr 29 21:12:25 SAMT 2015
[KERNEL] [ 0.000000] KERNEL supported cpus:
[KERNEL] [ 0.000000] Intel GenuineIntel
[KERNEL] [ 0.000000] AMD AuthenticAMD
[KERNEL] [ 0.000000] NSC Geode by NSC
[KERNEL] [ 0.000000] Cyrix CyrixInstead
[KERNEL] [ 0.000000] Centaur CentaurHauls
[KERNEL] [ 0.000000] e820: BIOS-provided physical RAM map:
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009f7ff] usable
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000000009f800-0x000000000009ffff] reserved
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003ffeffff] usable
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000003fff0000-0x000000003fff2fff] ACPI NVS
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000003fff3000-0x000000003fffffff] ACPI data
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000ffffffff] reserved
[KERNEL] [ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[KERNEL] [ 0.000000] SMBIOS 2.3 present.
[KERNEL] [ 0.000000] DMI: /Springdale, BIOS 6.00 PG 09/09/2003
[KERNEL] [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[KERNEL] [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[KERNEL] [ 0.000000] e820: last_pfn = 0x3fff0 max_arch_pfn = 0x100000
[KERNEL] [ 0.000000] MTRR default type: uncachable
[KERNEL] [ 0.000000] MTRR fixed ranges enabled:
[KERNEL] [ 0.000000] 00000-9FFFF write-back
[KERNEL] [ 0.000000] A0000-DFFFF uncachable
[KERNEL] [ 0.000000] E0000-FFFFF write-protect
[KERNEL] [ 0.000000] MTRR variable ranges enabled:
[KERNEL] [ 0.000000] 0 base 000000000 mask FC0000000 write-back
[KERNEL] [ 0.000000] 1 disabled
[KERNEL] [ 0.000000] 2 disabled
[KERNEL] [ 0.000000] 3 disabled
[KERNEL] [ 0.000000] 4 disabled
[KERNEL] [ 0.000000] 5 disabled
[KERNEL] [ 0.000000] 6 disabled
[KERNEL] [ 0.000000] 7 disabled
[KERNEL] [ 0.000000] Warning only 895MB will be used.
[KERNEL] [ 0.000000] Use a HIGHMEM enabled kernel.
[KERNEL] [ 0.000000] found SMP MP-table at [mem 0x000f5cb0-0x000f5cbf] mapped at [c00f5cb0]
[KERNEL] [ 0.000000] initial memory mapped: [mem 0x00000000-0x007fffff]
[KERNEL] [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[KERNEL] [ 0.000000] [mem 0x00000000-0x000fffff] page 4k
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x37800000-0x37bfffff]
[KERNEL] [ 0.000000] [mem 0x37800000-0x37bfffff] page 2M
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x30000000-0x377fffff]
[KERNEL] [ 0.000000] [mem 0x30000000-0x377fffff] page 2M
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x00100000-0x2fffffff]
[KERNEL] [ 0.000000] [mem 0x00100000-0x003fffff] page 4k
[KERNEL] [ 0.000000] [mem 0x00400000-0x2fffffff] page 2M
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x37c00000-0x37f9ffff]
[KERNEL] [ 0.000000] [mem 0x37c00000-0x37f9ffff] page 4k
[KERNEL] [ 0.000000] BRK [0x005ad000, 0x005adfff] PGTABLE
[KERNEL] [ 0.000000] early_memtest: # of tests: 1
[KERNEL] [ 0.000000] 0000010000 - 000009b000 pattern 0000000000000000
[KERNEL] [ 0.000000] 00005b3000 - 0037fa0000 pattern 0000000000000000
[KERNEL] [ 0.000000] RAMDISK: [mem 0x3fcc6000-0x3ffcefff]
[KERNEL] [ 0.000000] Allocated new RAMDISK: [mem 0x37c97000-0x37f9fd9b]
[KERNEL] [ 0.000000] Move RAMDISK from [mem 0x3fcc6000-0x3ffced9b] to [mem 0x37c97000-0x37f9fd9b]
[KERNEL] [ 0.000000] ACPI: RSDP 000f76e0 000014 (v00 IntelR)
[KERNEL] [ 0.000000] ACPI: RSDT 3fff3000 00002C (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[KERNEL] [ 0.000000] ACPI: FACP 3fff3040 000074 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[KERNEL] [ 0.000000] ACPI: DSDT 3fff30c0 004212 (v01 INTELR AWRDACPI 00001000 MSFT 0100000E)
[KERNEL] [ 0.000000] ACPI: FACS 3fff0000 000040
[KERNEL] [ 0.000000] ACPI: APIC 3fff7300 000068 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[KERNEL] [ 0.000000] ACPI: Local APIC address 0xfee00000
[KERNEL] [ 0.000000] 895MB LOWMEM available.
[KERNEL] [ 0.000000] mapped low ram: 0 - 37fa0000
[KERNEL] [ 0.000000] low ram: 0 - 37fa0000
[KERNEL] [ 0.000000] Zone ranges:
[KERNEL] [ 0.000000] DMA [mem 0x00001000-0x00ffffff]
[KERNEL] [ 0.000000] Normal [mem 0x01000000-0x37f9ffff]
[KERNEL] [ 0.000000] Movable zone start for each node
[KERNEL] [ 0.000000] Early memory node ranges
[KERNEL] [ 0.000000] node 0: [mem 0x00001000-0x0009efff]
[KERNEL] [ 0.000000] node 0: [mem 0x00100000-0x3ffeffff]
[KERNEL] [ 0.000000] On node 0 totalpages: 229182
[KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat c0519600, node_mem_map f7597020
[KERNEL] [ 0.000000] DMA zone: 32 pages used for memmap
[KERNEL] [ 0.000000] DMA zone: 0 pages reserved
[KERNEL] [ 0.000000] DMA zone: 3998 pages, LIFO batch:0
[KERNEL] [ 0.000000] Normal zone: 1760 pages used for memmap
[KERNEL] [ 0.000000] Normal zone: 225184 pages, LIFO batch:31
[KERNEL] [ 0.000000] Using APIC driver default
[KERNEL] [ 0.000000] ACPI: PM-Timer IO Port: 0x408
[KERNEL] [ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[KERNEL] [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
[KERNEL] [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[KERNEL] [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[KERNEL] [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[KERNEL] [ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[KERNEL] [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[KERNEL] [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[KERNEL] [ 0.000000] ACPI: IRQ0 used by override.
[KERNEL] [ 0.000000] ACPI: IRQ2 used by override.
[KERNEL] [ 0.000000] ACPI: IRQ9 used by override.
[KERNEL] [ 0.000000] Using ACPI (MADT) for SMP configuration information
[KERNEL] [ 0.000000] nr_irqs_gsi: 40
[KERNEL] [ 0.000000] e820: [mem 0x40000000-0xfebfffff] available for PCI devices
[KERNEL] [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[KERNEL] [ 0.000000] pcpu-alloc: [0] 0
[KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 227390
[KERNEL] [ 0.000000] Kernel command line: root=/dev/ram0 memtest=1 quiet initrd=packages/initrd BOOT_IMAGE=packages/kernel
[KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[KERNEL] [ 0.000000] Initializing CPU#0
[KERNEL] [ 0.000000] allocated 1834232 bytes of page_cgroup
[KERNEL] [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[KERNEL] [ 0.000000] Memory: 898940K/916728K available (3167K kernel code, 211K rwdata, 828K rodata, 312K init, 248K bss, 17788K reserved)
[KERNEL] [ 0.000000] virtual kernel memory layout:
[KERNEL] [ 0.000000] fixmap : 0xfffa2000 - 0xfffff000 ( 372 kB)
[KERNEL] [ 0.000000] vmalloc : 0xf87a0000 - 0xfffa0000 ( 120 MB)
[KERNEL] [ 0.000000] lowmem : 0xc0000000 - 0xf7fa0000 ( 895 MB)
[KERNEL] [ 0.000000] .init : 0xc051e000 - 0xc056c000 ( 312 kB)
[KERNEL] [ 0.000000] .data : 0xc0418232 - 0xc051dcc0 (1046 kB)
[KERNEL] [ 0.000000] .text : 0xc0100000 - 0xc0418232 (3168 kB)
[KERNEL] [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[KERNEL] [ 0.000000] Preemptible hierarchical RCU implementation.
[KERNEL] [ 0.000000] NR_IRQS:2304 nr_irqs:256 16
[KERNEL] [ 0.000000] CPU 0 irqstacks, hard=f6c08000 soft=f6c0a000
[KERNEL] [ 0.000000] Console: colour VGA+ 80x25
[KERNEL] [ 0.000000] console [tty0] enabled
[KERNEL] [ 0.000000] tsc: Fast TSC calibration using PIT
[KERNEL] [ 0.000000] tsc: Detected 2605.669 MHz processor
[KERNEL] [ 0.002011] Calibrating delay loop (skipped), value calculated using timer frequency.. 5211.33 BogoMIPS (lpj=2605669)
[KERNEL] [ 0.002016] pid_max: default: 32768 minimum: 301
[KERNEL] [ 0.002033] ACPI: Core revision 20131218
[KERNEL] [ 0.004529] ACPI: All ACPI Tables successfully acquired
[KERNEL] [ 0.005032] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[KERNEL] [ 0.005036] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[KERNEL] [ 0.005230] Initializing cgroup subsys memory
[KERNEL] [ 0.005276] Last level iTLB entries: 4KB 64, 2MB 64, 4MB 64
[KERNEL] [ 0.005276] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 64, 1GB 0
[KERNEL] [ 0.005276] tlb_flushall_shift: 6
[KERNEL] [ 0.005280] CPU: Intel(R) Pentium(R) 4 CPU 2.60GHz (fam: 0f, model: 02, stepping: 09)
[KERNEL] [ 0.005415] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[KERNEL] [ 0.005424] ... version: 0
[KERNEL] [ 0.005426] ... bit width: 40
[KERNEL] [ 0.005428] ... generic registers: 18
[KERNEL] [ 0.005430] ... value mask: 000000ffffffffff
[KERNEL] [ 0.005432] ... max period: 0000007fffffffff
[KERNEL] [ 0.005434] ... fixed-purpose events: 0
[KERNEL] [ 0.005435] ... event mask: 000000000003ffff
[KERNEL] [ 0.005613] Enabling APIC mode: Flat. Using 1 I/O APICs
[KERNEL] [ 0.005947] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[KERNEL] [ 0.016000] devtmpfs: initialized
[KERNEL] [ 0.016000] PM: Registering ACPI NVS region [mem 0x3fff0000-0x3fff2fff] (12288 bytes)
[KERNEL] [ 0.016000] NET: Registered protocol family 16
[KERNEL] [ 0.016000] cpuidle: using governor ladder
[KERNEL] [ 0.016000] cpuidle: using governor menu
[KERNEL] [ 0.016000] ACPI: bus type PCI registered
[KERNEL] [ 0.112668] PCI: PCI BIOS revision 2.10 entry at 0xfb9e0, last bus=2
[KERNEL] [ 0.112671] PCI: Using configuration type 1 for base access
[KERNEL] [ 0.116044] bio: create slab at 0
[KERNEL] [ 0.116161] ACPI: Added _OSI(Module Device)
[KERNEL] [ 0.116165] ACPI: Added _OSI(Processor Device)
[KERNEL] [ 0.116167] ACPI: Added _OSI(3.0 _SCP Extensions)
[KERNEL] [ 0.116169] ACPI: Added _OSI(Processor Aggregator Device)
[KERNEL] [ 0.120463] ACPI: Interpreter enabled
[KERNEL] [ 0.120482] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20131218/hwxface-580)
[KERNEL] [ 0.120490] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S3_] (20131218/hwxface-580)
[KERNEL] [ 0.120503] ACPI: (supports S0 S1 S5)
[KERNEL] [ 0.120506] ACPI: Using IOAPIC for interrupt routing
[KERNEL] [ 0.120601] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[KERNEL] [ 0.128885] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[KERNEL] [ 0.128894] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments]
[KERNEL] [ 0.128905] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[KERNEL] [ 0.129039] acpi PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[KERNEL] [ 0.129043] acpi PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[KERNEL] [ 0.129047] acpi PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[KERNEL] [ 0.129050] acpi PNP0A03:00: host bridge window [mem 0x000c0000-0x000dffff] (ignored)
[KERNEL] [ 0.129054] acpi PNP0A03:00: host bridge window [mem 0x40000000-0xfebfffff] (ignored)
[KERNEL] [ 0.129058] PCI: root bus 00: using default resources
[KERNEL] [ 0.129062] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
[KERNEL] [ 0.129142] PCI host bridge to bus 0000:00
[KERNEL] [ 0.129148] pci_bus 0000:00: root bus resource [bus 00-ff]
[KERNEL] [ 0.129151] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[KERNEL] [ 0.129155] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[KERNEL] [ 0.129171] pci 0000:00:00.0: [8086:2570] type 00 class 0x060000
[KERNEL] [ 0.129176] pci 0000:00:00.0: Enabling MCH 'Overflow' Device
[KERNEL] [ 0.129187] pci 0000:00:00.0: reg 0x10: [mem 0xe8000000-0xefffffff pref]
[KERNEL] [ 0.129330] pci 0000:00:01.0: [8086:2571] type 01 class 0x060400
[KERNEL] [ 0.129451] pci 0000:00:06.0: [8086:2576] type 00 class 0x088000
[KERNEL] [ 0.129462] pci 0000:00:06.0: reg 0x10: [mem 0xfecf0000-0xfecf0fff]
[KERNEL] [ 0.129615] pci 0000:00:1d.0: [8086:24d2] type 00 class 0x0c0300
[KERNEL] [ 0.129658] pci 0000:00:1d.0: reg 0x20: [io 0xbc00-0xbc1f]
[KERNEL] [ 0.129724] pci 0000:00:1d.0: System wakeup disabled by ACPI
[KERNEL] [ 0.129801] pci 0000:00:1d.1: [8086:24d4] type 00 class 0x0c0300
[KERNEL] [ 0.129844] pci 0000:00:1d.1: reg 0x20: [io 0xb000-0xb01f]
[KERNEL] [ 0.129908] pci 0000:00:1d.1: System wakeup disabled by ACPI
[KERNEL] [ 0.129984] pci 0000:00:1d.2: [8086:24d7] type 00 class 0x0c0300
[KERNEL] [ 0.130032] pci 0000:00:1d.2: reg 0x20: [io 0xb400-0xb41f]
[KERNEL] [ 0.130096] pci 0000:00:1d.2: System wakeup disabled by ACPI
[KERNEL] [ 0.130171] pci 0000:00:1d.3: [8086:24de] type 00 class 0x0c0300
[KERNEL] [ 0.130214] pci 0000:00:1d.3: reg 0x20: [io 0xb800-0xb81f]
[KERNEL] [ 0.130278] pci 0000:00:1d.3: System wakeup disabled by ACPI
[KERNEL] [ 0.130361] pci 0000:00:1d.7: [8086:24dd] type 00 class 0x0c0320
[KERNEL] [ 0.130382] pci 0000:00:1d.7: reg 0x10: [mem 0xfc000000-0xfc0003ff]
[KERNEL] [ 0.130454] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[KERNEL] [ 0.130506] pci 0000:00:1d.7: System wakeup disabled by ACPI
[KERNEL] [ 0.130580] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060400
[KERNEL] [ 0.130653] pci 0000:00:1e.0: System wakeup disabled by ACPI
[KERNEL] [ 0.130729] pci 0000:00:1f.0: [8086:24d0] type 00 class 0x060100
[KERNEL] [ 0.130792] pci 0000:00:1f.0: quirk: [io 0x0400-0x047f] claimed by ICH4 ACPI/GPIO/TCO
[KERNEL] [ 0.130798] pci 0000:00:1f.0: quirk: [io 0x0480-0x04bf] claimed by ICH4 GPIO
[KERNEL] [ 0.130904] pci 0000:00:1f.1: [8086:24db] type 00 class 0x01018a
[KERNEL] [ 0.130919] pci 0000:00:1f.1: reg 0x10: [io 0x0000-0x0007]
[KERNEL] [ 0.130930] pci 0000:00:1f.1: reg 0x14: [io 0x0000-0x0003]
[KERNEL] [ 0.130941] pci 0000:00:1f.1: reg 0x18: [io 0x0000-0x0007]
[KERNEL] [ 0.130951] pci 0000:00:1f.1: reg 0x1c: [io 0x0000-0x0003]
[KERNEL] [ 0.130962] pci 0000:00:1f.1: reg 0x20: [io 0xf000-0xf00f]
[KERNEL] [ 0.130972] pci 0000:00:1f.1: reg 0x24: [mem 0x00000000-0x000003ff]
[KERNEL] [ 0.131099] pci 0000:00:1f.2: [8086:24d1] type 00 class 0x01018f
[KERNEL] [ 0.131113] pci 0000:00:1f.2: reg 0x10: [io 0xc000-0xc007]
[KERNEL] [ 0.131122] pci 0000:00:1f.2: reg 0x14: [io 0xc400-0xc403]
[KERNEL] [ 0.131131] pci 0000:00:1f.2: reg 0x18: [io 0xc800-0xc807]
[KERNEL] [ 0.131141] pci 0000:00:1f.2: reg 0x1c: [io 0xcc00-0xcc03]
[KERNEL] [ 0.131150] pci 0000:00:1f.2: reg 0x20: [io 0xd000-0xd00f]
[KERNEL] [ 0.131267] pci 0000:00:1f.3: [8086:24d3] type 00 class 0x0c0500
[KERNEL] [ 0.131310] pci 0000:00:1f.3: reg 0x20: [io 0x0500-0x051f]
[KERNEL] [ 0.131434] pci 0000:00:1f.5: [8086:24d5] type 00 class 0x040100
[KERNEL] [ 0.131451] pci 0000:00:1f.5: reg 0x10: [io 0xd800-0xd8ff]
[KERNEL] [ 0.131460] pci 0000:00:1f.5: reg 0x14: [io 0xdc00-0xdc3f]
[KERNEL] [ 0.131470] pci 0000:00:1f.5: reg 0x18: [mem 0xfc001000-0xfc0011ff]
[KERNEL] [ 0.131480] pci 0000:00:1f.5: reg 0x1c: [mem 0xfc002000-0xfc0020ff]
[KERNEL] [ 0.131517] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
[KERNEL] [ 0.131682] pci 0000:01:00.0: [10de:0181] type 00 class 0x030000
[KERNEL] [ 0.131698] pci 0000:01:00.0: reg 0x10: [mem 0xf8000000-0xf8ffffff]
[KERNEL] [ 0.131708] pci 0000:01:00.0: reg 0x14: [mem 0xf0000000-0xf7ffffff pref]
[KERNEL] [ 0.131737] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[KERNEL] [ 0.131841] pci 0000:00:01.0: PCI bridge to [bus 01]
[KERNEL] [ 0.131847] pci 0000:00:01.0: bridge window [mem 0xf8000000-0xf9ffffff]
[KERNEL] [ 0.131852] pci 0000:00:01.0: bridge window [mem 0xf0000000-0xf7ffffff pref]
[KERNEL] [ 0.131916] pci 0000:02:00.0: [10b7:9300] type 00 class 0x020000
[KERNEL] [ 0.131934] pci 0000:02:00.0: reg 0x10: [io 0xa000-0xa0ff]
[KERNEL] [ 0.131945] pci 0000:02:00.0: reg 0x14: [mem 0xfb000000-0xfb0003ff]
[KERNEL] [ 0.131982] pci 0000:02:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[KERNEL] [ 0.132037] pci 0000:02:00.0: supports D1 D2
[KERNEL] [ 0.132040] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[KERNEL] [ 0.132176] pci 0000:00:1e.0: PCI bridge to [bus 02] (subtractive decode)
[KERNEL] [ 0.132182] pci 0000:00:1e.0: bridge window [io 0xa000-0xafff]
[KERNEL] [ 0.132187] pci 0000:00:1e.0: bridge window [mem 0xfa000000-0xfbffffff]
[KERNEL] [ 0.132193] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[KERNEL] [ 0.132196] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[KERNEL] [ 0.132209] pci_bus 0000:00: on NUMA node 0
[KERNEL] [ 0.132924] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[KERNEL] [ 0.133023] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[KERNEL] [ 0.133114] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[KERNEL] [ 0.133204] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[KERNEL] [ 0.133294] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[KERNEL] [ 0.133384] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[KERNEL] [ 0.133474] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[KERNEL] [ 0.133564] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[KERNEL] [ 0.133790] ACPI: bus type USB registered
[KERNEL] [ 0.133870] usbcore: registered new interface driver usbfs
[KERNEL] [ 0.133909] usbcore: registered new interface driver hub
[KERNEL] [ 0.133957] usbcore: registered new device driver usb
[KERNEL] [ 0.134181] wmi: Mapper loaded
[KERNEL] [ 0.134185] PCI: Using ACPI for IRQ routing
[KERNEL] [ 0.134189] PCI: pci_cache_line_size set to 64 bytes
[KERNEL] [ 0.134235] e820: reserve RAM buffer [mem 0x0009f800-0x0009ffff]
[KERNEL] [ 0.134239] e820: reserve RAM buffer [mem 0x3fff0000-0x3fffffff]
[KERNEL] [ 0.134588] cfg80211: Calling CRDA to update world regulatory domain
[KERNEL] [ 0.134675] Switched to clocksource refined-jiffies
[KERNEL] [ 0.134765] pnp: PnP ACPI init
[KERNEL] [ 0.134778] ACPI: bus type PNP registered
[KERNEL] [ 0.134942] system 00:00: [io 0x0b78-0x0b7b] has been reserved
[KERNEL] [ 0.134947] system 00:00: [io 0x0f78-0x0f7b] has been reserved
[KERNEL] [ 0.134951] system 00:00: [io 0x0a78-0x0a7b] has been reserved
[KERNEL] [ 0.134955] system 00:00: [io 0x0e78-0x0e7b] has been reserved
[KERNEL] [ 0.134958] system 00:00: [io 0x0bbc-0x0bbf] has been reserved
[KERNEL] [ 0.134961] system 00:00: [io 0x0fbc-0x0fbf] has been reserved
[KERNEL] [ 0.134965] system 00:00: [io 0x04d0-0x04d1] has been reserved
[KERNEL] [ 0.134968] system 00:00: [io 0x0294-0x0297] has been reserved
[KERNEL] [ 0.134973] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[KERNEL] [ 0.134994] pnp 00:01: [dma 4]
[KERNEL] [ 0.135099] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[KERNEL] [ 0.135173] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[KERNEL] [ 0.135232] pnp 00:03: Plug and Play ACPI device, IDs PNP0800 (active)
[KERNEL] [ 0.135297] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[KERNEL] [ 0.135461] pnp 00:05: [dma 2]
[KERNEL] [ 0.135533] pnp 00:05: Plug and Play ACPI device, IDs PNP0700 (active)
[KERNEL] [ 0.135837] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[KERNEL] [ 0.136167] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[KERNEL] [ 0.136604] pnp 00:08: [dma 3]
[KERNEL] [ 0.136698] pnp 00:08: Plug and Play ACPI device, IDs PNP0401 (active)
[KERNEL] [ 0.136811] pnp 00:09: Plug and Play ACPI device, IDs PNP0f13 (active)
[KERNEL] [ 0.136902] pnp 00:0a: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[KERNEL] [ 0.137248] pnp 00:0b: Plug and Play ACPI device, IDs PNPb02f (active)
[KERNEL] [ 0.137540] pnp 00:0c: Plug and Play ACPI device, IDs PNPb006 (active)
[KERNEL] [ 0.137635] system 00:0d: [io 0x0400-0x04bf] could not be reserved
[KERNEL] [ 0.137640] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active)
[KERNEL] [ 0.138195] system 00:0e: [mem 0x000d2000-0x000d3fff] has been reserved
[KERNEL] [ 0.138200] system 00:0e: [mem 0x000f0000-0x000f7fff] could not be reserved
[KERNEL] [ 0.138204] system 00:0e: [mem 0x000f8000-0x000fbfff] could not be reserved
[KERNEL] [ 0.138208] system 00:0e: [mem 0x000fc000-0x000fffff] could not be reserved
[KERNEL] [ 0.138211] system 00:0e: [mem 0x3fff0000-0x3fffffff] could not be reserved
[KERNEL] [ 0.138215] system 00:0e: [mem 0x00000000-0x0009ffff] could not be reserved
[KERNEL] [ 0.138219] system 00:0e: [mem 0x00100000-0x3ffeffff] could not be reserved
[KERNEL] [ 0.138223] system 00:0e: [mem 0xfec00000-0xfec00fff] could not be reserved
[KERNEL] [ 0.138226] system 00:0e: [mem 0xfec01000-0xfed8ffff] could not be reserved
[KERNEL] [ 0.138230] system 00:0e: [mem 0xfee00000-0xfee00fff] has been reserved
[KERNEL] [ 0.138233] system 00:0e: [mem 0xffb00000-0xffbfffff] has been reserved
[KERNEL] [ 0.138237] system 00:0e: [mem 0xfff00000-0xffffffff] has been reserved
[KERNEL] [ 0.138241] system 00:0e: [mem 0x000e0000-0x000effff] has been reserved
[KERNEL] [ 0.138245] system 00:0e: Plug and Play ACPI device, IDs PNP0c01 (active)
[KERNEL] [ 0.138257] pnp: PnP ACPI: found 15 devices
[KERNEL] [ 0.138260] ACPI: bus type PNP unregistered
[KERNEL] [ 0.176540] Switched to clocksource acpi_pm
[KERNEL] [ 0.176575] pci 0000:00:1e.0: BAR 9: assigned [mem 0x40000000-0x400fffff pref]
[KERNEL] [ 0.176580] pci 0000:00:1f.1: BAR 5: assigned [mem 0x40100000-0x401003ff]
[KERNEL] [ 0.176588] pci 0000:01:00.0: BAR 6: assigned [mem 0xf9000000-0xf901ffff pref]
[KERNEL] [ 0.176592] pci 0000:00:01.0: PCI bridge to [bus 01]
[KERNEL] [ 0.176598] pci 0000:00:01.0: bridge window [mem 0xf8000000-0xf9ffffff]
[KERNEL] [ 0.176603] pci 0000:00:01.0: bridge window [mem 0xf0000000-0xf7ffffff pref]
[KERNEL] [ 0.176611] pci 0000:02:00.0: BAR 6: assigned [mem 0x40000000-0x4001ffff pref]
[KERNEL] [ 0.176615] pci 0000:00:1e.0: PCI bridge to [bus 02]
[KERNEL] [ 0.176620] pci 0000:00:1e.0: bridge window [io 0xa000-0xafff]
[KERNEL] [ 0.176626] pci 0000:00:1e.0: bridge window [mem 0xfa000000-0xfbffffff]
[KERNEL] [ 0.176631] pci 0000:00:1e.0: bridge window [mem 0x40000000-0x400fffff pref]
[KERNEL] [ 0.176640] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[KERNEL] [ 0.176643] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[KERNEL] [ 0.176646] pci_bus 0000:01: resource 1 [mem 0xf8000000-0xf9ffffff]
[KERNEL] [ 0.176650] pci_bus 0000:01: resource 2 [mem 0xf0000000-0xf7ffffff pref]
[KERNEL] [ 0.176653] pci_bus 0000:02: resource 0 [io 0xa000-0xafff]
[KERNEL] [ 0.176656] pci_bus 0000:02: resource 1 [mem 0xfa000000-0xfbffffff]
[KERNEL] [ 0.176660] pci_bus 0000:02: resource 2 [mem 0x40000000-0x400fffff pref]
[KERNEL] [ 0.176663] pci_bus 0000:02: resource 4 [io 0x0000-0xffff]
[KERNEL] [ 0.176666] pci_bus 0000:02: resource 5 [mem 0x00000000-0xffffffff]
[KERNEL] [ 0.176708] NET: Registered protocol family 2
[KERNEL] [ 0.176946] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[KERNEL] [ 0.176969] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[KERNEL] [ 0.176989] TCP: Hash tables configured (established 8192 bind 8192)
[KERNEL] [ 0.176989] TCP: reno registered
[KERNEL] [ 0.176989] UDP hash table entries: 512 (order: 1, 8192 bytes)
[KERNEL] [ 0.176989] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[KERNEL] [ 0.176989] NET: Registered protocol family 1
[KERNEL] [ 0.177196] pci 0000:01:00.0: Boot video device
[KERNEL] [ 0.177203] PCI: CLS 0 bytes, default 64
[KERNEL] [ 0.177413] Trying to unpack rootfs image as initramfs...
[KERNEL] [ 0.181404] rootfs image is not initramfs (no cpio magic); looks like an initrd
[KERNEL] [ 0.188787] Freeing initrd memory: 3108K (f7c97000 - f7fa0000)
[KERNEL] [ 0.189343] futex hash table entries: 256 (order: -1, 3072 bytes)
[KERNEL] [ 0.189687] ROMFS MTD (C) 2007 Red Hat, Inc.
[KERNEL] [ 0.189696] msgmni has been set to 1761
[KERNEL] [ 0.189856] io scheduler noop registered
[KERNEL] [ 0.189863] io scheduler cfq registered (default)
[KERNEL] [ 0.190173] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[KERNEL] [ 0.190179] ACPI: Power Button [PWRB]
[KERNEL] [ 0.190289] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[KERNEL] [ 0.190293] ACPI: Power Button [PWRF]
[KERNEL] [ 0.190396] ACPI: Fan [FAN] (on)
[KERNEL] [ 0.191432] thermal LNXTHERM:00: registered as thermal_zone0
[KERNEL] [ 0.191437] ACPI: Thermal Zone [THRM] (48 C)
[KERNEL] [ 0.191721] brd: module loaded
[KERNEL] [ 0.191877] zram: Created 1 device(s) ...
[KERNEL] [ 0.191885] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[KERNEL] [ 0.191887] ehci-pci: EHCI PCI platform driver
[KERNEL] [ 0.192007] ehci-pci 0000:00:1d.7: EHCI Host Controller
[KERNEL] [ 0.192020] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[KERNEL] [ 0.195952] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[KERNEL] [ 0.195970] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfc000000
[KERNEL] [ 0.201458] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[KERNEL] [ 0.201501] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[KERNEL] [ 0.201505] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.201508] usb usb1: Product: EHCI Host Controller
[KERNEL] [ 0.201511] usb usb1: Manufacturer: Linux 3.14.40 ehci_hcd
[KERNEL] [ 0.201514] usb usb1: SerialNumber: 0000:00:1d.7
[KERNEL] [ 0.201730] hub 1-0:1.0: USB hub found
[KERNEL] [ 0.201743] hub 1-0:1.0: 8 ports detected
[KERNEL] [ 0.201944] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[KERNEL] [ 0.201947] ohci-pci: OHCI PCI platform driver
[KERNEL] [ 0.201985] uhci_hcd: USB Universal Host Controller Interface driver
[KERNEL] [ 0.202091] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[KERNEL] [ 0.202101] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[KERNEL] [ 0.202136] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000bc00
[KERNEL] [ 0.202196] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.202201] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.202204] usb usb2: Product: UHCI Host Controller
[KERNEL] [ 0.202207] usb usb2: Manufacturer: Linux 3.14.40 uhci_hcd
[KERNEL] [ 0.202210] usb usb2: SerialNumber: 0000:00:1d.0
[KERNEL] [ 0.202412] hub 2-0:1.0: USB hub found
[KERNEL] [ 0.202422] hub 2-0:1.0: 2 ports detected
[KERNEL] [ 0.202604] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[KERNEL] [ 0.202614] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[KERNEL] [ 0.202643] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000b000
[KERNEL] [ 0.202700] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.202704] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.202708] usb usb3: Product: UHCI Host Controller
[KERNEL] [ 0.202711] usb usb3: Manufacturer: Linux 3.14.40 uhci_hcd
[KERNEL] [ 0.202714] usb usb3: SerialNumber: 0000:00:1d.1
[KERNEL] [ 0.202913] hub 3-0:1.0: USB hub found
[KERNEL] [ 0.202924] hub 3-0:1.0: 2 ports detected
[KERNEL] [ 0.203092] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[KERNEL] [ 0.203102] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[KERNEL] [ 0.203131] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000b400
[KERNEL] [ 0.203189] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.203193] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.203197] usb usb4: Product: UHCI Host Controller
[KERNEL] [ 0.203200] usb usb4: Manufacturer: Linux 3.14.40 uhci_hcd
[KERNEL] [ 0.203203] usb usb4: SerialNumber: 0000:00:1d.2
[KERNEL] [ 0.203402] hub 4-0:1.0: USB hub found
[KERNEL] [ 0.203412] hub 4-0:1.0: 2 ports detected
[KERNEL] [ 0.203596] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[KERNEL] [ 0.203605] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[KERNEL] [ 0.203629] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000b800
[KERNEL] [ 0.203685] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.203689] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.203692] usb usb5: Product: UHCI Host Controller
[KERNEL] [ 0.203695] usb usb5: Manufacturer: Linux 3.14.40 uhci_hcd
[KERNEL] [ 0.203698] usb usb5: SerialNumber: 0000:00:1d.3
[KERNEL] [ 0.203900] hub 5-0:1.0: USB hub found
[KERNEL] [ 0.203910] hub 5-0:1.0: 2 ports detected
[KERNEL] [ 0.204202] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[KERNEL] [ 0.206854] serio: i8042 KBD port at 0x60,0x64 irq 1
[KERNEL] [ 0.206907] serio: i8042 AUX port at 0x60,0x64 irq 12
[KERNEL] [ 0.207015] hv_vmbus: registering driver hyperv_keyboard
[KERNEL] [ 0.207110] mousedev: PS/2 mouse device common for all mice
[KERNEL] [ 0.207436] input: PC Speaker as /devices/platform/pcspkr/input/input3
[KERNEL] [ 0.207619] hidraw: raw HID events driver (C) Jiri Kosina
[KERNEL] [ 0.207888] hv_vmbus: registering driver hid_hyperv
[KERNEL] [ 0.208327] usbcore: registered new interface driver usbhid
[KERNEL] [ 0.208330] usbhid: USB HID core driver
[KERNEL] [ 0.208401] TCP: cubic registered
[KERNEL] [ 0.208406] NET: Registered protocol family 17
[KERNEL] [ 0.208466] Using IPI Shortcut mode
[KERNEL] [ 0.232869] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[KERNEL] [ 0.649226] psmouse serio1: alps: Unknown ALPS touchpad: E7=10 00 64, EC=10 00 64
[KERNEL] [ 1.191262] tsc: Refined TSC clocksource calibration: 2605.908 MHz
[KERNEL] [ 1.191269] Switched to clocksource tsc
[KERNEL] [ 1.437895] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input5
[KERNEL] [ 1.440913] RAMDISK: xz image found at block 0
[KERNEL] [ 2.269621] VFS: Mounted root (romfs filesystem) readonly on device 1:0.
[KERNEL] [ 2.269670] devtmpfs: mounted
[KERNEL] [ 2.269965] Freeing unused kernel memory: 312K (c051e000 - c056c000)
[KERNEL] [ 2.270011] Write protecting the kernel text: 3172k
[KERNEL] [ 2.270024] Write protecting the kernel read-only data: 832k
[pfac] Ok, PID 447.
[initrd] WTware shell v.5.2.28
[initrd] PCI: C 06 8086:2570 Bridge Intel Corporation 82865G/PE/P DRAM Controller/Host-Hub Interface.
[initrd] PCI: C 06:04 8086:2571 Bridge PCI bridge Intel Corporation 82865G/PE/P AGP Bridge.
[initrd] PCI: C 08:80 8086:2576 Generic system peripheral System peripheral Intel Corporation 82865G/PE/P Processor to I/O Memory Interface.
[initrd] PCI: C 0c:03 8086:24d2 Serial bus controller USB controller Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:24d4 Serial bus controller USB controller Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:24d7 Serial bus controller USB controller Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:24de Serial bus controller USB controller Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:24dd Serial bus controller USB controller Intel Corporation 82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller.
[initrd] PCI: C 06:04 8086:244e Bridge PCI bridge Intel Corporation 82801 PCI Bridge.
[initrd] PCI: C 06:01 8086:24d0 Bridge ISA bridge Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge.
[initrd] PCI: C 01:01 8086:24db Mass storage controller IDE interface Intel Corporation 82801EB/ER (ICH5/ICH5R) IDE Controller.
[initrd] PCI: C 01:01 8086:24d1 Mass storage controller IDE interface Intel Corporation 82801EB (ICH5) SATA Controller.
[initrd] PCI: C 0c:05 8086:24d3 Serial bus controller SMBus Intel Corporation 82801EB/ER (ICH5/ICH5R) SMBus Controller.
[initrd] PCI: C 04:01 8086:24d5 Multimedia controller Multimedia audio controller Intel Corporation 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller.
[initrd] PCI: C 03 10de:0181 Display controller NVIDIA Corporation NV18 [GeForce4 MX 440 AGP 8x].
[initrd] PCI: C 02 10b7:9300 Network controller 3Com Corporation 3CSOHO100B-TX 910-A01 [tulip].
[initrd] Load ethernet drivers.
[initrd] modprobe tulip.
[KERNEL] [ 2.728894] tulip: Linux Tulip driver version 1.1.15 (Feb 27, 2007)
[KERNEL] [ 2.729176] tulip: tulip_init_one: Enabled WOL support for AN983B
[KERNEL] [ 2.729712] tulip0: MII transceiver #1 config 1000 status 786d advertising 05e1
[KERNEL] [ 2.736736] net eth0: ADMtek Comet rev 49 at Port 0xa000, 00:0a:48:0b:55:21, IRQ 20
[initrd] NIC module tulip.ko loaded.
[initrd] eth0: 10b7:9300. Apply WOL configuration.
[initrd] dhcp: 363 bytes from 192.168.20.2.
[initrd] 00000000:000001570000000000110000c0a81402ffffffff004300440157000002010600 ...W...............C.D.W......
[initrd] 00000020:67458b6b0000000000000000c0a81466c0a8140200000000000a480b55210000 gE.k..........f.........H.U!..
[initrd] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[initrd] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[initrd] dhcp: server address 192.168.20.2.
[initrd] dhcp: 192.168.20.102/255.255.255.0.
[initrd] dhcp: default gateway 192.168.20.2.
[initrd] dhcp: DNS 194.44.214.214.
[initrd] dhcp: DNS 194.44.214.40.
[initrd] dhcp: hostname wtw000A480B5521.
[initrd] dhcp: TFTP 192.168.20.2.
[initrd] dhcp: boot file (067) 5.2.28\wtware.pxe.
[initrd] TFTP binary "5.2.28\", configs prefix "", using "\" slash.
[initrd] dhcp: MTU 1500.
Send broadcast WTCU discover.
[initrd] TFTP: download and unpack file 5.2.28\packages\lib6 from 192.168.20.2.
[initrd] WTware TFTP v.5.2.28.
[initrd] TFTP: download file Everyone\list.wtc from 192.168.20.2.
| # Ïðèìåðû:
| # 02.03.04.05.06.07 file1
| # ListIncludes/file7.
[initrd] TFTP: download file Terminals\00.0A.48.0B.55.21\config.wtc from 192.168.20.2.
| connection
| next screen
| connection
[initrd] TFTP: download file Everyone\all.wtc from 192.168.20.2.
| server=192.168.20.2
[initrd] TFTP: download file Everyone\wtware.lic from 192.168.20.2.
| [BOM]
| server=192.168.20.2
| connection
| next screen
| connection
[initrd] Hostname: "wtw000A480B5521".
RSH: listener is active.
[initrd] Use 'video=VESA(F)' driver.
| [BOM]
| server=192.168.20.2
| video=VESA(F)
| connection
| next screen
| connection
[initrd] TFTP: download and unpack file 5.2.28\packages\f from 192.168.20.2.
[KERNEL] [ 5.752129] tulip 0000:02:00.0 eth0: tulip_stop_rxtx() failed (CSR5 0xfc664010 CSR6 0xff972113)
[KERNEL] [ 5.752144] net eth0: Setting full-duplex based on MII#1 link partner capability of 45e1
[KERNEL] [ 5.784190] random: nonblocking pool is initialized
[initrd] TFTP: download and unpack file 5.2.28\packages\fwt6 from 192.168.20.2.
[initrd] TFTP: download and unpack file 5.2.28\packages\graphic from 192.168.20.2.
[gm] WTware session manager v.5.2.28.
[gm] EV_REL flag found. Add mouse event4: ImExPS/2 Generic Explorer Mouse.
[gm] Add keyboard event3: AT Translated Set 2 keyboard.
[gm] Ignore event2: PC Speaker.
[gm] Add keyboard event1: Power Button.
[gm] Add keyboard event0: Power Button.
[gm] Display mode: 1024x768, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
[gm] VBE Version 3.0.
[gm] VBE modelist at 0x00011032.
[gm] Mode 256: 640x400 (256 color palette) linelength 640 bits 8.
[gm] Mode 257: 640x480 (256 color palette) linelength 640 bits 8.
[gm] Mode 259: 800x600 (256 color palette) linelength 800 bits 8.
[gm] Mode 261: 1024x768 (256 color palette) linelength 1024 bits 8.
[gm] Mode 263: 1280x1024 (256 color palette) linelength 1280 bits 8.
[gm] Mode 270: 320x200 (5:6:5) linelength 640 bits 16.
[gm] Mode 271: 320x200 (8:8:8) linelength 1280 bits 32.
[gm] Mode 273: 640x480 (5:6:5) linelength 1280 bits 16.
[gm] Mode 274: 640x480 (8:8:8) linelength 2560 bits 32.
[gm] Mode 276: 800x600 (5:6:5) linelength 1600 bits 16.
[gm] Mode 277: 800x600 (8:8:8) linelength 3200 bits 32.
[gm] Mode 279: 1024x768 (5:6:5) linelength 2048 bits 16.
[gm] Use mode 279.
[gm] Mode 280: 1024x768 (8:8:8) linelength 4096 bits 32.
[gm] Mode 282: 1280x1024 (5:6:5) linelength 2560 bits 16.
[gm] Mode 283: 1280x1024 (8:8:8) linelength 5120 bits 32.
[gm] Mode 304: 320x200 (256 color palette) linelength 320 bits 8.
[gm] Mode 305: 320x400 (256 color palette) linelength 320 bits 8.
[gm] Mode 306: 320x400 (5:6:5) linelength 640 bits 16.
[gm] Mode 307: 320x400 (8:8:8) linelength 1280 bits 32.
[gm] Mode 308: 320x240 (256 color palette) linelength 320 bits 8.
[gm] Mode 309: 320x240 (5:6:5) linelength 640 bits 16.
[gm] Mode 310: 320x240 (8:8:8) linelength 1280 bits 32.
[gm] Mode 317: 640x400 (5:6:5) linelength 1280 bits 16.
[gm] Mode 318: 640x400 (8:8:8) linelength 2560 bits 32.
[gm] Mode 325: 1600x1200 (256 color palette) linelength 1600 bits 8.
[gm] Mode 326: 1600x1200 (5:6:5) linelength 3200 bits 16.
[gm] Mode 327: 1400x1050 (256 color palette) linelength 1400 bits 8.
[gm] Mode 328: 1400x1050 (5:6:5) linelength 2800 bits 16.
[gm] Mode 338: 2048x1536 (8:8:8) linelength 8192 bits 32.
[gm] Linear framebuffer.
[gm] mmap () return 0xb7361000. Touch video memory.
[gm] Ok.
[gm] WMEMCOPY: 14400K copied in 189367 usec.
[gm] libc: 14400K copied in 742456 usec.
[gm] movs: 14400K copied in 189332 usec.
[gm] MMX: 14400K copied in 96838 usec.
[gm] SSE2: 14400K copied in 89681 usec.
[gm] Choose SSE2 memcpy.
[pfac] Got command line /sbin/resolver 0x9b79c30 dns [192.168.20.2].
[pfac] Ok, PID 462.
[gm] Nobody can control terminal by VNC.
[pfac] Process pid 462 terminated, status 00000000.
[pfac] Got command line /sbin/resolver 0x9b7b060 dns [192.168.20.2].
[pfac] Ok, PID 463.
[gm] 192.168.20.2 => 192.168.20.2.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 884472 Kb.
[pfac] Ok, PID 464.
[rdpclient 464] RDP Terminal Client, WTware v.5.2.28, pipe 1, pid 464.
[pfac] Process pid 463 terminated, status 00000000.
[rdpclient 464] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 464] No username.
[rdpclient 464] No password.
[rdpclient 464] No PIN.
[rdpclient 464] No domain.
[rdpclient 464] No shell.
[rdpclient 464] No directory.
[rdpclient 464] Window: 960x768@16.
[rdpclient 464] PFlags 0x0000002F.
[rdpclient 464] Keyboard 00000409:00000000.
[rdpclient 464] My hostname "wtw000A480B5521".
[rdpclient 464] TCP: connecting to 192.168.20.2:3389.
[rdpclient 464] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 2): 883984 Kb.
[pfac] Got command line /sbin/rdpclient 2.
[pfac] Ok, PID 465.
[rdpclient 465] RDP Terminal Client, WTware v.5.2.28, pipe 2, pid 465.
[rdpclient 465] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 465] No username.
[rdpclient 465] No password.
[rdpclient 465] No PIN.
[rdpclient 465] No domain.
[rdpclient 465] No shell.
[rdpclient 465] No directory.
[rdpclient 465] Window: 960x768@16.
[rdpclient 465] PFlags 0x0000002F.
[rdpclient 465] Keyboard 00000409:00000000.
[rdpclient 465] My hostname "wtw000A480B5521".
[rdpclient 465] TCP: connecting to 192.168.20.2:3389.
[rdpclient 465] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[pfac] Process pid 464 terminated, status 00000000.
[rdpclient 464] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 464] Сервер 192.168.20.2, порт 3389: отказано в подключении.
и попробуйте подключиться к ней стандартным клиентом
службы терминалов mstsc.exe.
[rdpclient 464] Caught signal SIGTERM.
[rdpclient 465] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 465] Сервер 192.168.20.2, порт 3389: отказано в подключении.
[gm] Final message: Сервер 192.168.20.2, порт 3389: отказано в подключении.
[gm] /graphic/exlm.png: 44x42.
[rdpclient 465] Caught signal SIGTERM.
[pfac] Process pid 465 terminated, status 00000000.
Send WTCU discover to 192.168.20.2.
[pfac] Ok, PID 467.
[pfac] Process pid 467 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 3): 883888 Kb.
[pfac] Got command line /sbin/rdpclient 3.
[pfac] Ok, PID 468.
[rdpclient 468] RDP Terminal Client, WTware v.5.2.28, pipe 3, pid 468.
[rdpclient 468] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 468] No username.
[rdpclient 468] No password.
[rdpclient 468] No PIN.
[rdpclient 468] No domain.
[rdpclient 468] No shell.
[rdpclient 468] No directory.
[rdpclient 468] Window: 960x768@16.
[rdpclient 468] PFlags 0x0000002F.
[rdpclient 468] Keyboard 00000409:00000000.
[rdpclient 468] My hostname "wtw000A480B5521".
[rdpclient 468] TCP: connecting to 192.168.20.2:3389.
[rdpclient 468] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[rdpclient 468] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 468] Сервер 192.168.20.2, порт 3389: отказано в подключении.
[rdpclient 468] Caught signal SIGTERM.
[RDP] close kotopipe (n = 0, errno 2).
[pfac] Process pid 468 terminated, status 00000000.
[pfac] Ok, PID 469.
[pfac] Process pid 469 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 4): 883856 Kb.
[pfac] Got command line /sbin/rdpclient 4.
[pfac] Ok, PID 470.
[rdpclient 470] RDP Terminal Client, WTware v.5.2.28, pipe 4, pid 470.
[rdpclient 470] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 470] No username.
[rdpclient 470] No password.
[rdpclient 470] No PIN.
[rdpclient 470] No domain.
[rdpclient 470] No shell.
[rdpclient 470] No directory.
[rdpclient 470] Window: 960x768@16.
[rdpclient 470] PFlags 0x0000002F.
[rdpclient 470] Keyboard 00000409:00000000.
[rdpclient 470] My hostname "wtw000A480B5521".
[rdpclient 470] TCP: connecting to 192.168.20.2:3389.
[rdpclient 470] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[rdpclient 470] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 470] Сервер 192.168.20.2, порт 3389: отказано в подключении.
[rdpclient 470] Caught signal SIGTERM.
[pfac] Process pid 470 terminated, status 00000000.
[pfac] Ok, PID 471.
[pfac] Process pid 471 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 5): 883856 Kb.
[pfac] Got command line /sbin/rdpclient 5.
[pfac] Ok, PID 472.
[rdpclient 472] RDP Terminal Client, WTware v.5.2.28, pipe 5, pid 472.
[rdpclient 472] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 472] No username.
[rdpclient 472] No password.
[rdpclient 472] No PIN.
[rdpclient 472] No domain.
[rdpclient 472] No shell.
[rdpclient 472] No directory.
[rdpclient 472] Window: 960x768@16.
[rdpclient 472] PFlags 0x0000002F.
[rdpclient 472] Keyboard 00000409:00000000.
[rdpclient 472] My hostname "wtw000A480B5521".
[rdpclient 472] TCP: connecting to 192.168.20.2:3389.
[rdpclient 472] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[rdpclient 472] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 472] Сервер 192.168.20.2, порт 3389: отказано в подключении.
[rdpclient 472] Caught signal SIGTERM.
[pfac] Process pid 472 terminated, status 00000000.
[pfac] Ok, PID 473.
[pfac] Process pid 473 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 6): 883856 Kb.
[pfac] Got command line /sbin/rdpclient 6.
[pfac] Ok, PID 474.
[rdpclient 474] RDP Terminal Client, WTware v.5.2.28, pipe 6, pid 474.
[rdpclient 474] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 474] No username.
[rdpclient 474] No password.
[rdpclient 474] No PIN.
[rdpclient 474] No domain.
[rdpclient 474] No shell.
[rdpclient 474] No directory.
[rdpclient 474] Window: 960x768@16.
[rdpclient 474] PFlags 0x0000002F.
[rdpclient 474] Keyboard 00000409:00000000.
[rdpclient 474] My hostname "wtw000A480B5521".
[rdpclient 474] TCP: connecting to 192.168.20.2:3389.
[rdpclient 474] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[rdpclient 474] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 474] Сервер 192.168.20.2, порт 3389: отказано в подключении.
[rdpclient 474] Caught signal SIGTERM.
[pfac] Process pid 474 terminated, status 00000000.
[pfac] Ok, PID 475.
[pfac] Process pid 475 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 7): 883856 Kb.
[pfac] Got command line /sbin/rdpclient 7.
[pfac] Ok, PID 476.
[rdpclient 476] RDP Terminal Client, WTware v.5.2.28, pipe 7, pid 476.
[rdpclient 476] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 476] No username.
[rdpclient 476] No password.
[rdpclient 476] No PIN.
[rdpclient 476] No domain.
[rdpclient 476] No shell.
[rdpclient 476] No directory.
[rdpclient 476] Window: 960x768@16.
[rdpclient 476] PFlags 0x0000002F.
[rdpclient 476] Keyboard 00000409:00000000.
[rdpclient 476] My hostname "wtw000A480B5521".
[rdpclient 476] TCP: connecting to 192.168.20.2:3389.
[rdpclient 476] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[rdpclient 476] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 476] Сервер 192.168.20.2, порт 3389: отказано в подключении.
[rdpclient 476] Caught signal SIGTERM.
[pfac] Process pid 476 terminated, status 00000000.
Home WTware diskless client.
			трабл.
лог
WTware v.5.2.28
[pfac] Ok, PID 447.
| # Ïðèìåðû:
| connection
| next screen
| connection
| server=192.168.20.2
| [BOM]
| server=192.168.20.2
| connection
| next screen
| connection
| [BOM]
| server=192.168.20.2
| video=VESA(F)
| connection
| next screen
| connection
[gm] Use mode 279.
[gm] Ok.
[pfac] Ok, PID 462.
[pfac] Ok, PID 463.
[pfac] Ok, PID 464.
[pfac] Ok, PID 465.
[pfac] Ok, PID 467.
[pfac] Ok, PID 468.
[pfac] Ok, PID 469.
[pfac] Ok, PID 470.
[pfac] Ok, PID 471.
[pfac] Ok, PID 472.
[pfac] Ok, PID 473.
[pfac] Ok, PID 474.
[pfac] Ok, PID 475.
[pfac] Ok, PID 476.
