Здрасте.
трабл.
Убедитесь, что на этом сервере работает служба терминалов и попробуйте подключиться к ней стандартым клиентом mstsc.exe
лог
WTware v.5.2.28
WTware v.5.2.28 supervisor.
WTC listener is active.
HTTPd listener is active.
[KERNEL] [ 0.000000] Linux version 3.14.40 (root@c8) (gcc version 4.9.2 (Ubuntu 4.9.2-10ubuntu13) ) #1 PREEMPT Wed Apr 29 21:12:25 SAMT 2015
[KERNEL] [ 0.000000] KERNEL supported cpus:
[KERNEL] [ 0.000000] Intel GenuineIntel
[KERNEL] [ 0.000000] AMD AuthenticAMD
[KERNEL] [ 0.000000] NSC Geode by NSC
[KERNEL] [ 0.000000] Cyrix CyrixInstead
[KERNEL] [ 0.000000] Centaur CentaurHauls
[KERNEL] [ 0.000000] e820: BIOS-provided physical RAM map:
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009f7ff] usable
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000000009f800-0x000000000009ffff] reserved
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003ffeffff] usable
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000003fff0000-0x000000003fff2fff] ACPI NVS
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x000000003fff3000-0x000000003fffffff] ACPI data
[KERNEL] [ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000ffffffff] reserved
[KERNEL] [ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[KERNEL] [ 0.000000] SMBIOS 2.3 present.
[KERNEL] [ 0.000000] DMI: /Springdale, BIOS 6.00 PG 09/09/2003
[KERNEL] [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[KERNEL] [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[KERNEL] [ 0.000000] e820: last_pfn = 0x3fff0 max_arch_pfn = 0x100000
[KERNEL] [ 0.000000] MTRR default type: uncachable
[KERNEL] [ 0.000000] MTRR fixed ranges enabled:
[KERNEL] [ 0.000000] 00000-9FFFF write-back
[KERNEL] [ 0.000000] A0000-DFFFF uncachable
[KERNEL] [ 0.000000] E0000-FFFFF write-protect
[KERNEL] [ 0.000000] MTRR variable ranges enabled:
[KERNEL] [ 0.000000] 0 base 000000000 mask FC0000000 write-back
[KERNEL] [ 0.000000] 1 disabled
[KERNEL] [ 0.000000] 2 disabled
[KERNEL] [ 0.000000] 3 disabled
[KERNEL] [ 0.000000] 4 disabled
[KERNEL] [ 0.000000] 5 disabled
[KERNEL] [ 0.000000] 6 disabled
[KERNEL] [ 0.000000] 7 disabled
[KERNEL] [ 0.000000] Warning only 895MB will be used.
[KERNEL] [ 0.000000] Use a HIGHMEM enabled kernel.
[KERNEL] [ 0.000000] found SMP MP-table at [mem 0x000f5cb0-0x000f5cbf] mapped at [c00f5cb0]
[KERNEL] [ 0.000000] initial memory mapped: [mem 0x00000000-0x007fffff]
[KERNEL] [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[KERNEL] [ 0.000000] [mem 0x00000000-0x000fffff] page 4k
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x37800000-0x37bfffff]
[KERNEL] [ 0.000000] [mem 0x37800000-0x37bfffff] page 2M
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x30000000-0x377fffff]
[KERNEL] [ 0.000000] [mem 0x30000000-0x377fffff] page 2M
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x00100000-0x2fffffff]
[KERNEL] [ 0.000000] [mem 0x00100000-0x003fffff] page 4k
[KERNEL] [ 0.000000] [mem 0x00400000-0x2fffffff] page 2M
[KERNEL] [ 0.000000] init_memory_mapping: [mem 0x37c00000-0x37f9ffff]
[KERNEL] [ 0.000000] [mem 0x37c00000-0x37f9ffff] page 4k
[KERNEL] [ 0.000000] BRK [0x005ad000, 0x005adfff] PGTABLE
[KERNEL] [ 0.000000] early_memtest: # of tests: 1
[KERNEL] [ 0.000000] 0000010000 - 000009b000 pattern 0000000000000000
[KERNEL] [ 0.000000] 00005b3000 - 0037fa0000 pattern 0000000000000000
[KERNEL] [ 0.000000] RAMDISK: [mem 0x3fcc6000-0x3ffcefff]
[KERNEL] [ 0.000000] Allocated new RAMDISK: [mem 0x37c97000-0x37f9fd9b]
[KERNEL] [ 0.000000] Move RAMDISK from [mem 0x3fcc6000-0x3ffced9b] to [mem 0x37c97000-0x37f9fd9b]
[KERNEL] [ 0.000000] ACPI: RSDP 000f76e0 000014 (v00 IntelR)
[KERNEL] [ 0.000000] ACPI: RSDT 3fff3000 00002C (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[KERNEL] [ 0.000000] ACPI: FACP 3fff3040 000074 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[KERNEL] [ 0.000000] ACPI: DSDT 3fff30c0 004212 (v01 INTELR AWRDACPI 00001000 MSFT 0100000E)
[KERNEL] [ 0.000000] ACPI: FACS 3fff0000 000040
[KERNEL] [ 0.000000] ACPI: APIC 3fff7300 000068 (v01 IntelR AWRDACPI 42302E31 AWRD 00000000)
[KERNEL] [ 0.000000] ACPI: Local APIC address 0xfee00000
[KERNEL] [ 0.000000] 895MB LOWMEM available.
[KERNEL] [ 0.000000] mapped low ram: 0 - 37fa0000
[KERNEL] [ 0.000000] low ram: 0 - 37fa0000
[KERNEL] [ 0.000000] Zone ranges:
[KERNEL] [ 0.000000] DMA [mem 0x00001000-0x00ffffff]
[KERNEL] [ 0.000000] Normal [mem 0x01000000-0x37f9ffff]
[KERNEL] [ 0.000000] Movable zone start for each node
[KERNEL] [ 0.000000] Early memory node ranges
[KERNEL] [ 0.000000] node 0: [mem 0x00001000-0x0009efff]
[KERNEL] [ 0.000000] node 0: [mem 0x00100000-0x3ffeffff]
[KERNEL] [ 0.000000] On node 0 totalpages: 229182
[KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat c0519600, node_mem_map f7597020
[KERNEL] [ 0.000000] DMA zone: 32 pages used for memmap
[KERNEL] [ 0.000000] DMA zone: 0 pages reserved
[KERNEL] [ 0.000000] DMA zone: 3998 pages, LIFO batch:0
[KERNEL] [ 0.000000] Normal zone: 1760 pages used for memmap
[KERNEL] [ 0.000000] Normal zone: 225184 pages, LIFO batch:31
[KERNEL] [ 0.000000] Using APIC driver default
[KERNEL] [ 0.000000] ACPI: PM-Timer IO Port: 0x408
[KERNEL] [ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[KERNEL] [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
[KERNEL] [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[KERNEL] [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[KERNEL] [ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[KERNEL] [ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[KERNEL] [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[KERNEL] [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[KERNEL] [ 0.000000] ACPI: IRQ0 used by override.
[KERNEL] [ 0.000000] ACPI: IRQ2 used by override.
[KERNEL] [ 0.000000] ACPI: IRQ9 used by override.
[KERNEL] [ 0.000000] Using ACPI (MADT) for SMP configuration information
[KERNEL] [ 0.000000] nr_irqs_gsi: 40
[KERNEL] [ 0.000000] e820: [mem 0x40000000-0xfebfffff] available for PCI devices
[KERNEL] [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[KERNEL] [ 0.000000] pcpu-alloc: [0] 0
[KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 227390
[KERNEL] [ 0.000000] Kernel command line: root=/dev/ram0 memtest=1 quiet initrd=packages/initrd BOOT_IMAGE=packages/kernel
[KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[KERNEL] [ 0.000000] Initializing CPU#0
[KERNEL] [ 0.000000] allocated 1834232 bytes of page_cgroup
[KERNEL] [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[KERNEL] [ 0.000000] Memory: 898940K/916728K available (3167K kernel code, 211K rwdata, 828K rodata, 312K init, 248K bss, 17788K reserved)
[KERNEL] [ 0.000000] virtual kernel memory layout:
[KERNEL] [ 0.000000] fixmap : 0xfffa2000 - 0xfffff000 ( 372 kB)
[KERNEL] [ 0.000000] vmalloc : 0xf87a0000 - 0xfffa0000 ( 120 MB)
[KERNEL] [ 0.000000] lowmem : 0xc0000000 - 0xf7fa0000 ( 895 MB)
[KERNEL] [ 0.000000] .init : 0xc051e000 - 0xc056c000 ( 312 kB)
[KERNEL] [ 0.000000] .data : 0xc0418232 - 0xc051dcc0 (1046 kB)
[KERNEL] [ 0.000000] .text : 0xc0100000 - 0xc0418232 (3168 kB)
[KERNEL] [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[KERNEL] [ 0.000000] Preemptible hierarchical RCU implementation.
[KERNEL] [ 0.000000] NR_IRQS:2304 nr_irqs:256 16
[KERNEL] [ 0.000000] CPU 0 irqstacks, hard=f6c08000 soft=f6c0a000
[KERNEL] [ 0.000000] Console: colour VGA+ 80x25
[KERNEL] [ 0.000000] console [tty0] enabled
[KERNEL] [ 0.000000] tsc: Fast TSC calibration using PIT
[KERNEL] [ 0.000000] tsc: Detected 2605.669 MHz processor
[KERNEL] [ 0.002011] Calibrating delay loop (skipped), value calculated using timer frequency.. 5211.33 BogoMIPS (lpj=2605669)
[KERNEL] [ 0.002016] pid_max: default: 32768 minimum: 301
[KERNEL] [ 0.002033] ACPI: Core revision 20131218
[KERNEL] [ 0.004529] ACPI: All ACPI Tables successfully acquired
[KERNEL] [ 0.005032] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[KERNEL] [ 0.005036] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[KERNEL] [ 0.005230] Initializing cgroup subsys memory
[KERNEL] [ 0.005276] Last level iTLB entries: 4KB 64, 2MB 64, 4MB 64
[KERNEL] [ 0.005276] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 64, 1GB 0
[KERNEL] [ 0.005276] tlb_flushall_shift: 6
[KERNEL] [ 0.005280] CPU: Intel(R) Pentium(R) 4 CPU 2.60GHz (fam: 0f, model: 02, stepping: 09)
[KERNEL] [ 0.005415] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[KERNEL] [ 0.005424] ... version: 0
[KERNEL] [ 0.005426] ... bit width: 40
[KERNEL] [ 0.005428] ... generic registers: 18
[KERNEL] [ 0.005430] ... value mask: 000000ffffffffff
[KERNEL] [ 0.005432] ... max period: 0000007fffffffff
[KERNEL] [ 0.005434] ... fixed-purpose events: 0
[KERNEL] [ 0.005435] ... event mask: 000000000003ffff
[KERNEL] [ 0.005613] Enabling APIC mode: Flat. Using 1 I/O APICs
[KERNEL] [ 0.005947] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[KERNEL] [ 0.016000] devtmpfs: initialized
[KERNEL] [ 0.016000] PM: Registering ACPI NVS region [mem 0x3fff0000-0x3fff2fff] (12288 bytes)
[KERNEL] [ 0.016000] NET: Registered protocol family 16
[KERNEL] [ 0.016000] cpuidle: using governor ladder
[KERNEL] [ 0.016000] cpuidle: using governor menu
[KERNEL] [ 0.016000] ACPI: bus type PCI registered
[KERNEL] [ 0.112668] PCI: PCI BIOS revision 2.10 entry at 0xfb9e0, last bus=2
[KERNEL] [ 0.112671] PCI: Using configuration type 1 for base access
[KERNEL] [ 0.116044] bio: create slab at 0
[KERNEL] [ 0.116161] ACPI: Added _OSI(Module Device)
[KERNEL] [ 0.116165] ACPI: Added _OSI(Processor Device)
[KERNEL] [ 0.116167] ACPI: Added _OSI(3.0 _SCP Extensions)
[KERNEL] [ 0.116169] ACPI: Added _OSI(Processor Aggregator Device)
[KERNEL] [ 0.120463] ACPI: Interpreter enabled
[KERNEL] [ 0.120482] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20131218/hwxface-580)
[KERNEL] [ 0.120490] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S3_] (20131218/hwxface-580)
[KERNEL] [ 0.120503] ACPI: (supports S0 S1 S5)
[KERNEL] [ 0.120506] ACPI: Using IOAPIC for interrupt routing
[KERNEL] [ 0.120601] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[KERNEL] [ 0.128885] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[KERNEL] [ 0.128894] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments]
[KERNEL] [ 0.128905] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[KERNEL] [ 0.129039] acpi PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[KERNEL] [ 0.129043] acpi PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[KERNEL] [ 0.129047] acpi PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[KERNEL] [ 0.129050] acpi PNP0A03:00: host bridge window [mem 0x000c0000-0x000dffff] (ignored)
[KERNEL] [ 0.129054] acpi PNP0A03:00: host bridge window [mem 0x40000000-0xfebfffff] (ignored)
[KERNEL] [ 0.129058] PCI: root bus 00: using default resources
[KERNEL] [ 0.129062] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
[KERNEL] [ 0.129142] PCI host bridge to bus 0000:00
[KERNEL] [ 0.129148] pci_bus 0000:00: root bus resource [bus 00-ff]
[KERNEL] [ 0.129151] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[KERNEL] [ 0.129155] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[KERNEL] [ 0.129171] pci 0000:00:00.0: [8086:2570] type 00 class 0x060000
[KERNEL] [ 0.129176] pci 0000:00:00.0: Enabling MCH 'Overflow' Device
[KERNEL] [ 0.129187] pci 0000:00:00.0: reg 0x10: [mem 0xe8000000-0xefffffff pref]
[KERNEL] [ 0.129330] pci 0000:00:01.0: [8086:2571] type 01 class 0x060400
[KERNEL] [ 0.129451] pci 0000:00:06.0: [8086:2576] type 00 class 0x088000
[KERNEL] [ 0.129462] pci 0000:00:06.0: reg 0x10: [mem 0xfecf0000-0xfecf0fff]
[KERNEL] [ 0.129615] pci 0000:00:1d.0: [8086:24d2] type 00 class 0x0c0300
[KERNEL] [ 0.129658] pci 0000:00:1d.0: reg 0x20: [io 0xbc00-0xbc1f]
[KERNEL] [ 0.129724] pci 0000:00:1d.0: System wakeup disabled by ACPI
[KERNEL] [ 0.129801] pci 0000:00:1d.1: [8086:24d4] type 00 class 0x0c0300
[KERNEL] [ 0.129844] pci 0000:00:1d.1: reg 0x20: [io 0xb000-0xb01f]
[KERNEL] [ 0.129908] pci 0000:00:1d.1: System wakeup disabled by ACPI
[KERNEL] [ 0.129984] pci 0000:00:1d.2: [8086:24d7] type 00 class 0x0c0300
[KERNEL] [ 0.130032] pci 0000:00:1d.2: reg 0x20: [io 0xb400-0xb41f]
[KERNEL] [ 0.130096] pci 0000:00:1d.2: System wakeup disabled by ACPI
[KERNEL] [ 0.130171] pci 0000:00:1d.3: [8086:24de] type 00 class 0x0c0300
[KERNEL] [ 0.130214] pci 0000:00:1d.3: reg 0x20: [io 0xb800-0xb81f]
[KERNEL] [ 0.130278] pci 0000:00:1d.3: System wakeup disabled by ACPI
[KERNEL] [ 0.130361] pci 0000:00:1d.7: [8086:24dd] type 00 class 0x0c0320
[KERNEL] [ 0.130382] pci 0000:00:1d.7: reg 0x10: [mem 0xfc000000-0xfc0003ff]
[KERNEL] [ 0.130454] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[KERNEL] [ 0.130506] pci 0000:00:1d.7: System wakeup disabled by ACPI
[KERNEL] [ 0.130580] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060400
[KERNEL] [ 0.130653] pci 0000:00:1e.0: System wakeup disabled by ACPI
[KERNEL] [ 0.130729] pci 0000:00:1f.0: [8086:24d0] type 00 class 0x060100
[KERNEL] [ 0.130792] pci 0000:00:1f.0: quirk: [io 0x0400-0x047f] claimed by ICH4 ACPI/GPIO/TCO
[KERNEL] [ 0.130798] pci 0000:00:1f.0: quirk: [io 0x0480-0x04bf] claimed by ICH4 GPIO
[KERNEL] [ 0.130904] pci 0000:00:1f.1: [8086:24db] type 00 class 0x01018a
[KERNEL] [ 0.130919] pci 0000:00:1f.1: reg 0x10: [io 0x0000-0x0007]
[KERNEL] [ 0.130930] pci 0000:00:1f.1: reg 0x14: [io 0x0000-0x0003]
[KERNEL] [ 0.130941] pci 0000:00:1f.1: reg 0x18: [io 0x0000-0x0007]
[KERNEL] [ 0.130951] pci 0000:00:1f.1: reg 0x1c: [io 0x0000-0x0003]
[KERNEL] [ 0.130962] pci 0000:00:1f.1: reg 0x20: [io 0xf000-0xf00f]
[KERNEL] [ 0.130972] pci 0000:00:1f.1: reg 0x24: [mem 0x00000000-0x000003ff]
[KERNEL] [ 0.131099] pci 0000:00:1f.2: [8086:24d1] type 00 class 0x01018f
[KERNEL] [ 0.131113] pci 0000:00:1f.2: reg 0x10: [io 0xc000-0xc007]
[KERNEL] [ 0.131122] pci 0000:00:1f.2: reg 0x14: [io 0xc400-0xc403]
[KERNEL] [ 0.131131] pci 0000:00:1f.2: reg 0x18: [io 0xc800-0xc807]
[KERNEL] [ 0.131141] pci 0000:00:1f.2: reg 0x1c: [io 0xcc00-0xcc03]
[KERNEL] [ 0.131150] pci 0000:00:1f.2: reg 0x20: [io 0xd000-0xd00f]
[KERNEL] [ 0.131267] pci 0000:00:1f.3: [8086:24d3] type 00 class 0x0c0500
[KERNEL] [ 0.131310] pci 0000:00:1f.3: reg 0x20: [io 0x0500-0x051f]
[KERNEL] [ 0.131434] pci 0000:00:1f.5: [8086:24d5] type 00 class 0x040100
[KERNEL] [ 0.131451] pci 0000:00:1f.5: reg 0x10: [io 0xd800-0xd8ff]
[KERNEL] [ 0.131460] pci 0000:00:1f.5: reg 0x14: [io 0xdc00-0xdc3f]
[KERNEL] [ 0.131470] pci 0000:00:1f.5: reg 0x18: [mem 0xfc001000-0xfc0011ff]
[KERNEL] [ 0.131480] pci 0000:00:1f.5: reg 0x1c: [mem 0xfc002000-0xfc0020ff]
[KERNEL] [ 0.131517] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
[KERNEL] [ 0.131682] pci 0000:01:00.0: [10de:0181] type 00 class 0x030000
[KERNEL] [ 0.131698] pci 0000:01:00.0: reg 0x10: [mem 0xf8000000-0xf8ffffff]
[KERNEL] [ 0.131708] pci 0000:01:00.0: reg 0x14: [mem 0xf0000000-0xf7ffffff pref]
[KERNEL] [ 0.131737] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[KERNEL] [ 0.131841] pci 0000:00:01.0: PCI bridge to [bus 01]
[KERNEL] [ 0.131847] pci 0000:00:01.0: bridge window [mem 0xf8000000-0xf9ffffff]
[KERNEL] [ 0.131852] pci 0000:00:01.0: bridge window [mem 0xf0000000-0xf7ffffff pref]
[KERNEL] [ 0.131916] pci 0000:02:00.0: [10b7:9300] type 00 class 0x020000
[KERNEL] [ 0.131934] pci 0000:02:00.0: reg 0x10: [io 0xa000-0xa0ff]
[KERNEL] [ 0.131945] pci 0000:02:00.0: reg 0x14: [mem 0xfb000000-0xfb0003ff]
[KERNEL] [ 0.131982] pci 0000:02:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[KERNEL] [ 0.132037] pci 0000:02:00.0: supports D1 D2
[KERNEL] [ 0.132040] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[KERNEL] [ 0.132176] pci 0000:00:1e.0: PCI bridge to [bus 02] (subtractive decode)
[KERNEL] [ 0.132182] pci 0000:00:1e.0: bridge window [io 0xa000-0xafff]
[KERNEL] [ 0.132187] pci 0000:00:1e.0: bridge window [mem 0xfa000000-0xfbffffff]
[KERNEL] [ 0.132193] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[KERNEL] [ 0.132196] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[KERNEL] [ 0.132209] pci_bus 0000:00: on NUMA node 0
[KERNEL] [ 0.132924] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[KERNEL] [ 0.133023] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[KERNEL] [ 0.133114] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[KERNEL] [ 0.133204] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[KERNEL] [ 0.133294] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[KERNEL] [ 0.133384] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[KERNEL] [ 0.133474] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[KERNEL] [ 0.133564] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[KERNEL] [ 0.133790] ACPI: bus type USB registered
[KERNEL] [ 0.133870] usbcore: registered new interface driver usbfs
[KERNEL] [ 0.133909] usbcore: registered new interface driver hub
[KERNEL] [ 0.133957] usbcore: registered new device driver usb
[KERNEL] [ 0.134181] wmi: Mapper loaded
[KERNEL] [ 0.134185] PCI: Using ACPI for IRQ routing
[KERNEL] [ 0.134189] PCI: pci_cache_line_size set to 64 bytes
[KERNEL] [ 0.134235] e820: reserve RAM buffer [mem 0x0009f800-0x0009ffff]
[KERNEL] [ 0.134239] e820: reserve RAM buffer [mem 0x3fff0000-0x3fffffff]
[KERNEL] [ 0.134588] cfg80211: Calling CRDA to update world regulatory domain
[KERNEL] [ 0.134675] Switched to clocksource refined-jiffies
[KERNEL] [ 0.134765] pnp: PnP ACPI init
[KERNEL] [ 0.134778] ACPI: bus type PNP registered
[KERNEL] [ 0.134942] system 00:00: [io 0x0b78-0x0b7b] has been reserved
[KERNEL] [ 0.134947] system 00:00: [io 0x0f78-0x0f7b] has been reserved
[KERNEL] [ 0.134951] system 00:00: [io 0x0a78-0x0a7b] has been reserved
[KERNEL] [ 0.134955] system 00:00: [io 0x0e78-0x0e7b] has been reserved
[KERNEL] [ 0.134958] system 00:00: [io 0x0bbc-0x0bbf] has been reserved
[KERNEL] [ 0.134961] system 00:00: [io 0x0fbc-0x0fbf] has been reserved
[KERNEL] [ 0.134965] system 00:00: [io 0x04d0-0x04d1] has been reserved
[KERNEL] [ 0.134968] system 00:00: [io 0x0294-0x0297] has been reserved
[KERNEL] [ 0.134973] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[KERNEL] [ 0.134994] pnp 00:01: [dma 4]
[KERNEL] [ 0.135099] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[KERNEL] [ 0.135173] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[KERNEL] [ 0.135232] pnp 00:03: Plug and Play ACPI device, IDs PNP0800 (active)
[KERNEL] [ 0.135297] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[KERNEL] [ 0.135461] pnp 00:05: [dma 2]
[KERNEL] [ 0.135533] pnp 00:05: Plug and Play ACPI device, IDs PNP0700 (active)
[KERNEL] [ 0.135837] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[KERNEL] [ 0.136167] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[KERNEL] [ 0.136604] pnp 00:08: [dma 3]
[KERNEL] [ 0.136698] pnp 00:08: Plug and Play ACPI device, IDs PNP0401 (active)
[KERNEL] [ 0.136811] pnp 00:09: Plug and Play ACPI device, IDs PNP0f13 (active)
[KERNEL] [ 0.136902] pnp 00:0a: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[KERNEL] [ 0.137248] pnp 00:0b: Plug and Play ACPI device, IDs PNPb02f (active)
[KERNEL] [ 0.137540] pnp 00:0c: Plug and Play ACPI device, IDs PNPb006 (active)
[KERNEL] [ 0.137635] system 00:0d: [io 0x0400-0x04bf] could not be reserved
[KERNEL] [ 0.137640] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active)
[KERNEL] [ 0.138195] system 00:0e: [mem 0x000d2000-0x000d3fff] has been reserved
[KERNEL] [ 0.138200] system 00:0e: [mem 0x000f0000-0x000f7fff] could not be reserved
[KERNEL] [ 0.138204] system 00:0e: [mem 0x000f8000-0x000fbfff] could not be reserved
[KERNEL] [ 0.138208] system 00:0e: [mem 0x000fc000-0x000fffff] could not be reserved
[KERNEL] [ 0.138211] system 00:0e: [mem 0x3fff0000-0x3fffffff] could not be reserved
[KERNEL] [ 0.138215] system 00:0e: [mem 0x00000000-0x0009ffff] could not be reserved
[KERNEL] [ 0.138219] system 00:0e: [mem 0x00100000-0x3ffeffff] could not be reserved
[KERNEL] [ 0.138223] system 00:0e: [mem 0xfec00000-0xfec00fff] could not be reserved
[KERNEL] [ 0.138226] system 00:0e: [mem 0xfec01000-0xfed8ffff] could not be reserved
[KERNEL] [ 0.138230] system 00:0e: [mem 0xfee00000-0xfee00fff] has been reserved
[KERNEL] [ 0.138233] system 00:0e: [mem 0xffb00000-0xffbfffff] has been reserved
[KERNEL] [ 0.138237] system 00:0e: [mem 0xfff00000-0xffffffff] has been reserved
[KERNEL] [ 0.138241] system 00:0e: [mem 0x000e0000-0x000effff] has been reserved
[KERNEL] [ 0.138245] system 00:0e: Plug and Play ACPI device, IDs PNP0c01 (active)
[KERNEL] [ 0.138257] pnp: PnP ACPI: found 15 devices
[KERNEL] [ 0.138260] ACPI: bus type PNP unregistered
[KERNEL] [ 0.176540] Switched to clocksource acpi_pm
[KERNEL] [ 0.176575] pci 0000:00:1e.0: BAR 9: assigned [mem 0x40000000-0x400fffff pref]
[KERNEL] [ 0.176580] pci 0000:00:1f.1: BAR 5: assigned [mem 0x40100000-0x401003ff]
[KERNEL] [ 0.176588] pci 0000:01:00.0: BAR 6: assigned [mem 0xf9000000-0xf901ffff pref]
[KERNEL] [ 0.176592] pci 0000:00:01.0: PCI bridge to [bus 01]
[KERNEL] [ 0.176598] pci 0000:00:01.0: bridge window [mem 0xf8000000-0xf9ffffff]
[KERNEL] [ 0.176603] pci 0000:00:01.0: bridge window [mem 0xf0000000-0xf7ffffff pref]
[KERNEL] [ 0.176611] pci 0000:02:00.0: BAR 6: assigned [mem 0x40000000-0x4001ffff pref]
[KERNEL] [ 0.176615] pci 0000:00:1e.0: PCI bridge to [bus 02]
[KERNEL] [ 0.176620] pci 0000:00:1e.0: bridge window [io 0xa000-0xafff]
[KERNEL] [ 0.176626] pci 0000:00:1e.0: bridge window [mem 0xfa000000-0xfbffffff]
[KERNEL] [ 0.176631] pci 0000:00:1e.0: bridge window [mem 0x40000000-0x400fffff pref]
[KERNEL] [ 0.176640] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[KERNEL] [ 0.176643] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[KERNEL] [ 0.176646] pci_bus 0000:01: resource 1 [mem 0xf8000000-0xf9ffffff]
[KERNEL] [ 0.176650] pci_bus 0000:01: resource 2 [mem 0xf0000000-0xf7ffffff pref]
[KERNEL] [ 0.176653] pci_bus 0000:02: resource 0 [io 0xa000-0xafff]
[KERNEL] [ 0.176656] pci_bus 0000:02: resource 1 [mem 0xfa000000-0xfbffffff]
[KERNEL] [ 0.176660] pci_bus 0000:02: resource 2 [mem 0x40000000-0x400fffff pref]
[KERNEL] [ 0.176663] pci_bus 0000:02: resource 4 [io 0x0000-0xffff]
[KERNEL] [ 0.176666] pci_bus 0000:02: resource 5 [mem 0x00000000-0xffffffff]
[KERNEL] [ 0.176708] NET: Registered protocol family 2
[KERNEL] [ 0.176946] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[KERNEL] [ 0.176969] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[KERNEL] [ 0.176989] TCP: Hash tables configured (established 8192 bind 8192)
[KERNEL] [ 0.176989] TCP: reno registered
[KERNEL] [ 0.176989] UDP hash table entries: 512 (order: 1, 8192 bytes)
[KERNEL] [ 0.176989] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
[KERNEL] [ 0.176989] NET: Registered protocol family 1
[KERNEL] [ 0.177196] pci 0000:01:00.0: Boot video device
[KERNEL] [ 0.177203] PCI: CLS 0 bytes, default 64
[KERNEL] [ 0.177413] Trying to unpack rootfs image as initramfs...
[KERNEL] [ 0.181404] rootfs image is not initramfs (no cpio magic); looks like an initrd
[KERNEL] [ 0.188787] Freeing initrd memory: 3108K (f7c97000 - f7fa0000)
[KERNEL] [ 0.189343] futex hash table entries: 256 (order: -1, 3072 bytes)
[KERNEL] [ 0.189687] ROMFS MTD (C) 2007 Red Hat, Inc.
[KERNEL] [ 0.189696] msgmni has been set to 1761
[KERNEL] [ 0.189856] io scheduler noop registered
[KERNEL] [ 0.189863] io scheduler cfq registered (default)
[KERNEL] [ 0.190173] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[KERNEL] [ 0.190179] ACPI: Power Button [PWRB]
[KERNEL] [ 0.190289] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[KERNEL] [ 0.190293] ACPI: Power Button [PWRF]
[KERNEL] [ 0.190396] ACPI: Fan [FAN] (on)
[KERNEL] [ 0.191432] thermal LNXTHERM:00: registered as thermal_zone0
[KERNEL] [ 0.191437] ACPI: Thermal Zone [THRM] (48 C)
[KERNEL] [ 0.191721] brd: module loaded
[KERNEL] [ 0.191877] zram: Created 1 device(s) ...
[KERNEL] [ 0.191885] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[KERNEL] [ 0.191887] ehci-pci: EHCI PCI platform driver
[KERNEL] [ 0.192007] ehci-pci 0000:00:1d.7: EHCI Host Controller
[KERNEL] [ 0.192020] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[KERNEL] [ 0.195952] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[KERNEL] [ 0.195970] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfc000000
[KERNEL] [ 0.201458] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[KERNEL] [ 0.201501] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[KERNEL] [ 0.201505] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.201508] usb usb1: Product: EHCI Host Controller
[KERNEL] [ 0.201511] usb usb1: Manufacturer: Linux 3.14.40 ehci_hcd
[KERNEL] [ 0.201514] usb usb1: SerialNumber: 0000:00:1d.7
[KERNEL] [ 0.201730] hub 1-0:1.0: USB hub found
[KERNEL] [ 0.201743] hub 1-0:1.0: 8 ports detected
[KERNEL] [ 0.201944] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[KERNEL] [ 0.201947] ohci-pci: OHCI PCI platform driver
[KERNEL] [ 0.201985] uhci_hcd: USB Universal Host Controller Interface driver
[KERNEL] [ 0.202091] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[KERNEL] [ 0.202101] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[KERNEL] [ 0.202136] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000bc00
[KERNEL] [ 0.202196] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.202201] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.202204] usb usb2: Product: UHCI Host Controller
[KERNEL] [ 0.202207] usb usb2: Manufacturer: Linux 3.14.40 uhci_hcd
[KERNEL] [ 0.202210] usb usb2: SerialNumber: 0000:00:1d.0
[KERNEL] [ 0.202412] hub 2-0:1.0: USB hub found
[KERNEL] [ 0.202422] hub 2-0:1.0: 2 ports detected
[KERNEL] [ 0.202604] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[KERNEL] [ 0.202614] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[KERNEL] [ 0.202643] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000b000
[KERNEL] [ 0.202700] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.202704] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.202708] usb usb3: Product: UHCI Host Controller
[KERNEL] [ 0.202711] usb usb3: Manufacturer: Linux 3.14.40 uhci_hcd
[KERNEL] [ 0.202714] usb usb3: SerialNumber: 0000:00:1d.1
[KERNEL] [ 0.202913] hub 3-0:1.0: USB hub found
[KERNEL] [ 0.202924] hub 3-0:1.0: 2 ports detected
[KERNEL] [ 0.203092] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[KERNEL] [ 0.203102] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[KERNEL] [ 0.203131] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000b400
[KERNEL] [ 0.203189] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.203193] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.203197] usb usb4: Product: UHCI Host Controller
[KERNEL] [ 0.203200] usb usb4: Manufacturer: Linux 3.14.40 uhci_hcd
[KERNEL] [ 0.203203] usb usb4: SerialNumber: 0000:00:1d.2
[KERNEL] [ 0.203402] hub 4-0:1.0: USB hub found
[KERNEL] [ 0.203412] hub 4-0:1.0: 2 ports detected
[KERNEL] [ 0.203596] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[KERNEL] [ 0.203605] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[KERNEL] [ 0.203629] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000b800
[KERNEL] [ 0.203685] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.203689] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.203692] usb usb5: Product: UHCI Host Controller
[KERNEL] [ 0.203695] usb usb5: Manufacturer: Linux 3.14.40 uhci_hcd
[KERNEL] [ 0.203698] usb usb5: SerialNumber: 0000:00:1d.3
[KERNEL] [ 0.203900] hub 5-0:1.0: USB hub found
[KERNEL] [ 0.203910] hub 5-0:1.0: 2 ports detected
[KERNEL] [ 0.204202] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[KERNEL] [ 0.206854] serio: i8042 KBD port at 0x60,0x64 irq 1
[KERNEL] [ 0.206907] serio: i8042 AUX port at 0x60,0x64 irq 12
[KERNEL] [ 0.207015] hv_vmbus: registering driver hyperv_keyboard
[KERNEL] [ 0.207110] mousedev: PS/2 mouse device common for all mice
[KERNEL] [ 0.207436] input: PC Speaker as /devices/platform/pcspkr/input/input3
[KERNEL] [ 0.207619] hidraw: raw HID events driver (C) Jiri Kosina
[KERNEL] [ 0.207888] hv_vmbus: registering driver hid_hyperv
[KERNEL] [ 0.208327] usbcore: registered new interface driver usbhid
[KERNEL] [ 0.208330] usbhid: USB HID core driver
[KERNEL] [ 0.208401] TCP: cubic registered
[KERNEL] [ 0.208406] NET: Registered protocol family 17
[KERNEL] [ 0.208466] Using IPI Shortcut mode
[KERNEL] [ 0.232869] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[KERNEL] [ 0.649226] psmouse serio1: alps: Unknown ALPS touchpad: E7=10 00 64, EC=10 00 64
[KERNEL] [ 1.191262] tsc: Refined TSC clocksource calibration: 2605.908 MHz
[KERNEL] [ 1.191269] Switched to clocksource tsc
[KERNEL] [ 1.437895] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input5
[KERNEL] [ 1.440913] RAMDISK: xz image found at block 0
[KERNEL] [ 2.269621] VFS: Mounted root (romfs filesystem) readonly on device 1:0.
[KERNEL] [ 2.269670] devtmpfs: mounted
[KERNEL] [ 2.269965] Freeing unused kernel memory: 312K (c051e000 - c056c000)
[KERNEL] [ 2.270011] Write protecting the kernel text: 3172k
[KERNEL] [ 2.270024] Write protecting the kernel read-only data: 832k
[pfac] Ok, PID 447.
[initrd] WTware shell v.5.2.28
[initrd] PCI: C 06 8086:2570 Bridge Intel Corporation 82865G/PE/P DRAM Controller/Host-Hub Interface.
[initrd] PCI: C 06:04 8086:2571 Bridge PCI bridge Intel Corporation 82865G/PE/P AGP Bridge.
[initrd] PCI: C 08:80 8086:2576 Generic system peripheral System peripheral Intel Corporation 82865G/PE/P Processor to I/O Memory Interface.
[initrd] PCI: C 0c:03 8086:24d2 Serial bus controller USB controller Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:24d4 Serial bus controller USB controller Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:24d7 Serial bus controller USB controller Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:24de Serial bus controller USB controller Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:24dd Serial bus controller USB controller Intel Corporation 82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller.
[initrd] PCI: C 06:04 8086:244e Bridge PCI bridge Intel Corporation 82801 PCI Bridge.
[initrd] PCI: C 06:01 8086:24d0 Bridge ISA bridge Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge.
[initrd] PCI: C 01:01 8086:24db Mass storage controller IDE interface Intel Corporation 82801EB/ER (ICH5/ICH5R) IDE Controller.
[initrd] PCI: C 01:01 8086:24d1 Mass storage controller IDE interface Intel Corporation 82801EB (ICH5) SATA Controller.
[initrd] PCI: C 0c:05 8086:24d3 Serial bus controller SMBus Intel Corporation 82801EB/ER (ICH5/ICH5R) SMBus Controller.
[initrd] PCI: C 04:01 8086:24d5 Multimedia controller Multimedia audio controller Intel Corporation 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller.
[initrd] PCI: C 03 10de:0181 Display controller NVIDIA Corporation NV18 [GeForce4 MX 440 AGP 8x].
[initrd] PCI: C 02 10b7:9300 Network controller 3Com Corporation 3CSOHO100B-TX 910-A01 [tulip].
[initrd] Load ethernet drivers.
[initrd] modprobe tulip.
[KERNEL] [ 2.728894] tulip: Linux Tulip driver version 1.1.15 (Feb 27, 2007)
[KERNEL] [ 2.729176] tulip: tulip_init_one: Enabled WOL support for AN983B
[KERNEL] [ 2.729712] tulip0: MII transceiver #1 config 1000 status 786d advertising 05e1
[KERNEL] [ 2.736736] net eth0: ADMtek Comet rev 49 at Port 0xa000, 00:0a:48:0b:55:21, IRQ 20
[initrd] NIC module tulip.ko loaded.
[initrd] eth0: 10b7:9300. Apply WOL configuration.
[initrd] dhcp: 363 bytes from 192.168.20.2.
[initrd] 00000000:000001570000000000110000c0a81402ffffffff004300440157000002010600 ...W...............C.D.W......
[initrd] 00000020:67458b6b0000000000000000c0a81466c0a8140200000000000a480b55210000 gE.k..........f.........H.U!..
[initrd] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[initrd] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[initrd] dhcp: server address 192.168.20.2.
[initrd] dhcp: 192.168.20.102/255.255.255.0.
[initrd] dhcp: default gateway 192.168.20.2.
[initrd] dhcp: DNS 194.44.214.214.
[initrd] dhcp: DNS 194.44.214.40.
[initrd] dhcp: hostname wtw000A480B5521.
[initrd] dhcp: TFTP 192.168.20.2.
[initrd] dhcp: boot file (067) 5.2.28\wtware.pxe.
[initrd] TFTP binary "5.2.28\", configs prefix "", using "\" slash.
[initrd] dhcp: MTU 1500.
Send broadcast WTCU discover.
[initrd] TFTP: download and unpack file 5.2.28\packages\lib6 from 192.168.20.2.
[initrd] WTware TFTP v.5.2.28.
[initrd] TFTP: download file Everyone\list.wtc from 192.168.20.2.
| # Ïðèìåðû:
| # 02.03.04.05.06.07 file1
| # ListIncludes/file7.
[initrd] TFTP: download file Terminals\00.0A.48.0B.55.21\config.wtc from 192.168.20.2.
| connection
| next screen
| connection
[initrd] TFTP: download file Everyone\all.wtc from 192.168.20.2.
| server=192.168.20.2
[initrd] TFTP: download file Everyone\wtware.lic from 192.168.20.2.
| [BOM]
| server=192.168.20.2
| connection
| next screen
| connection
[initrd] Hostname: "wtw000A480B5521".
RSH: listener is active.
[initrd] Use 'video=VESA(F)' driver.
| [BOM]
| server=192.168.20.2
| video=VESA(F)
| connection
| next screen
| connection
[initrd] TFTP: download and unpack file 5.2.28\packages\f from 192.168.20.2.
[KERNEL] [ 5.752129] tulip 0000:02:00.0 eth0: tulip_stop_rxtx() failed (CSR5 0xfc664010 CSR6 0xff972113)
[KERNEL] [ 5.752144] net eth0: Setting full-duplex based on MII#1 link partner capability of 45e1
[KERNEL] [ 5.784190] random: nonblocking pool is initialized
[initrd] TFTP: download and unpack file 5.2.28\packages\fwt6 from 192.168.20.2.
[initrd] TFTP: download and unpack file 5.2.28\packages\graphic from 192.168.20.2.
[gm] WTware session manager v.5.2.28.
[gm] EV_REL flag found. Add mouse event4: ImExPS/2 Generic Explorer Mouse.
[gm] Add keyboard event3: AT Translated Set 2 keyboard.
[gm] Ignore event2: PC Speaker.
[gm] Add keyboard event1: Power Button.
[gm] Add keyboard event0: Power Button.
[gm] Display mode: 1024x768, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
[gm] VBE Version 3.0.
[gm] VBE modelist at 0x00011032.
[gm] Mode 256: 640x400 (256 color palette) linelength 640 bits 8.
[gm] Mode 257: 640x480 (256 color palette) linelength 640 bits 8.
[gm] Mode 259: 800x600 (256 color palette) linelength 800 bits 8.
[gm] Mode 261: 1024x768 (256 color palette) linelength 1024 bits 8.
[gm] Mode 263: 1280x1024 (256 color palette) linelength 1280 bits 8.
[gm] Mode 270: 320x200 (5:6:5) linelength 640 bits 16.
[gm] Mode 271: 320x200 (8:8:8) linelength 1280 bits 32.
[gm] Mode 273: 640x480 (5:6:5) linelength 1280 bits 16.
[gm] Mode 274: 640x480 (8:8:8) linelength 2560 bits 32.
[gm] Mode 276: 800x600 (5:6:5) linelength 1600 bits 16.
[gm] Mode 277: 800x600 (8:8:8) linelength 3200 bits 32.
[gm] Mode 279: 1024x768 (5:6:5) linelength 2048 bits 16.
[gm] Use mode 279.
[gm] Mode 280: 1024x768 (8:8:8) linelength 4096 bits 32.
[gm] Mode 282: 1280x1024 (5:6:5) linelength 2560 bits 16.
[gm] Mode 283: 1280x1024 (8:8:8) linelength 5120 bits 32.
[gm] Mode 304: 320x200 (256 color palette) linelength 320 bits 8.
[gm] Mode 305: 320x400 (256 color palette) linelength 320 bits 8.
[gm] Mode 306: 320x400 (5:6:5) linelength 640 bits 16.
[gm] Mode 307: 320x400 (8:8:8) linelength 1280 bits 32.
[gm] Mode 308: 320x240 (256 color palette) linelength 320 bits 8.
[gm] Mode 309: 320x240 (5:6:5) linelength 640 bits 16.
[gm] Mode 310: 320x240 (8:8:8) linelength 1280 bits 32.
[gm] Mode 317: 640x400 (5:6:5) linelength 1280 bits 16.
[gm] Mode 318: 640x400 (8:8:8) linelength 2560 bits 32.
[gm] Mode 325: 1600x1200 (256 color palette) linelength 1600 bits 8.
[gm] Mode 326: 1600x1200 (5:6:5) linelength 3200 bits 16.
[gm] Mode 327: 1400x1050 (256 color palette) linelength 1400 bits 8.
[gm] Mode 328: 1400x1050 (5:6:5) linelength 2800 bits 16.
[gm] Mode 338: 2048x1536 (8:8:8) linelength 8192 bits 32.
[gm] Linear framebuffer.
[gm] mmap () return 0xb7361000. Touch video memory.
[gm] Ok.
[gm] WMEMCOPY: 14400K copied in 189367 usec.
[gm] libc: 14400K copied in 742456 usec.
[gm] movs: 14400K copied in 189332 usec.
[gm] MMX: 14400K copied in 96838 usec.
[gm] SSE2: 14400K copied in 89681 usec.
[gm] Choose SSE2 memcpy.
[pfac] Got command line /sbin/resolver 0x9b79c30 dns [192.168.20.2].
[pfac] Ok, PID 462.
[gm] Nobody can control terminal by VNC.
[pfac] Process pid 462 terminated, status 00000000.
[pfac] Got command line /sbin/resolver 0x9b7b060 dns [192.168.20.2].
[pfac] Ok, PID 463.
[gm] 192.168.20.2 => 192.168.20.2.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 884472 Kb.
[pfac] Ok, PID 464.
[rdpclient 464] RDP Terminal Client, WTware v.5.2.28, pipe 1, pid 464.
[pfac] Process pid 463 terminated, status 00000000.
[rdpclient 464] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 464] No username.
[rdpclient 464] No password.
[rdpclient 464] No PIN.
[rdpclient 464] No domain.
[rdpclient 464] No shell.
[rdpclient 464] No directory.
[rdpclient 464] Window: 960x768@16.
[rdpclient 464] PFlags 0x0000002F.
[rdpclient 464] Keyboard 00000409:00000000.
[rdpclient 464] My hostname "wtw000A480B5521".
[rdpclient 464] TCP: connecting to 192.168.20.2:3389.
[rdpclient 464] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 2): 883984 Kb.
[pfac] Got command line /sbin/rdpclient 2.
[pfac] Ok, PID 465.
[rdpclient 465] RDP Terminal Client, WTware v.5.2.28, pipe 2, pid 465.
[rdpclient 465] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 465] No username.
[rdpclient 465] No password.
[rdpclient 465] No PIN.
[rdpclient 465] No domain.
[rdpclient 465] No shell.
[rdpclient 465] No directory.
[rdpclient 465] Window: 960x768@16.
[rdpclient 465] PFlags 0x0000002F.
[rdpclient 465] Keyboard 00000409:00000000.
[rdpclient 465] My hostname "wtw000A480B5521".
[rdpclient 465] TCP: connecting to 192.168.20.2:3389.
[rdpclient 465] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[pfac] Process pid 464 terminated, status 00000000.
[rdpclient 464] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 464] Сервер 192.168.20.2, порт 3389: отказано в подключении.
и попробуйте подключиться к ней стандартным клиентом
службы терминалов mstsc.exe.
[rdpclient 464] Caught signal SIGTERM.
[rdpclient 465] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 465] Сервер 192.168.20.2, порт 3389: отказано в подключении.
[gm] Final message: Сервер 192.168.20.2, порт 3389: отказано в подключении.
[gm] /graphic/exlm.png: 44x42.
[rdpclient 465] Caught signal SIGTERM.
[pfac] Process pid 465 terminated, status 00000000.
Send WTCU discover to 192.168.20.2.
[pfac] Ok, PID 467.
[pfac] Process pid 467 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 3): 883888 Kb.
[pfac] Got command line /sbin/rdpclient 3.
[pfac] Ok, PID 468.
[rdpclient 468] RDP Terminal Client, WTware v.5.2.28, pipe 3, pid 468.
[rdpclient 468] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 468] No username.
[rdpclient 468] No password.
[rdpclient 468] No PIN.
[rdpclient 468] No domain.
[rdpclient 468] No shell.
[rdpclient 468] No directory.
[rdpclient 468] Window: 960x768@16.
[rdpclient 468] PFlags 0x0000002F.
[rdpclient 468] Keyboard 00000409:00000000.
[rdpclient 468] My hostname "wtw000A480B5521".
[rdpclient 468] TCP: connecting to 192.168.20.2:3389.
[rdpclient 468] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[rdpclient 468] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 468] Сервер 192.168.20.2, порт 3389: отказано в подключении.
[rdpclient 468] Caught signal SIGTERM.
[RDP] close kotopipe (n = 0, errno 2).
[pfac] Process pid 468 terminated, status 00000000.
[pfac] Ok, PID 469.
[pfac] Process pid 469 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 4): 883856 Kb.
[pfac] Got command line /sbin/rdpclient 4.
[pfac] Ok, PID 470.
[rdpclient 470] RDP Terminal Client, WTware v.5.2.28, pipe 4, pid 470.
[rdpclient 470] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 470] No username.
[rdpclient 470] No password.
[rdpclient 470] No PIN.
[rdpclient 470] No domain.
[rdpclient 470] No shell.
[rdpclient 470] No directory.
[rdpclient 470] Window: 960x768@16.
[rdpclient 470] PFlags 0x0000002F.
[rdpclient 470] Keyboard 00000409:00000000.
[rdpclient 470] My hostname "wtw000A480B5521".
[rdpclient 470] TCP: connecting to 192.168.20.2:3389.
[rdpclient 470] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[rdpclient 470] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 470] Сервер 192.168.20.2, порт 3389: отказано в подключении.
[rdpclient 470] Caught signal SIGTERM.
[pfac] Process pid 470 terminated, status 00000000.
[pfac] Ok, PID 471.
[pfac] Process pid 471 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 5): 883856 Kb.
[pfac] Got command line /sbin/rdpclient 5.
[pfac] Ok, PID 472.
[rdpclient 472] RDP Terminal Client, WTware v.5.2.28, pipe 5, pid 472.
[rdpclient 472] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 472] No username.
[rdpclient 472] No password.
[rdpclient 472] No PIN.
[rdpclient 472] No domain.
[rdpclient 472] No shell.
[rdpclient 472] No directory.
[rdpclient 472] Window: 960x768@16.
[rdpclient 472] PFlags 0x0000002F.
[rdpclient 472] Keyboard 00000409:00000000.
[rdpclient 472] My hostname "wtw000A480B5521".
[rdpclient 472] TCP: connecting to 192.168.20.2:3389.
[rdpclient 472] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[rdpclient 472] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 472] Сервер 192.168.20.2, порт 3389: отказано в подключении.
[rdpclient 472] Caught signal SIGTERM.
[pfac] Process pid 472 terminated, status 00000000.
[pfac] Ok, PID 473.
[pfac] Process pid 473 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 6): 883856 Kb.
[pfac] Got command line /sbin/rdpclient 6.
[pfac] Ok, PID 474.
[rdpclient 474] RDP Terminal Client, WTware v.5.2.28, pipe 6, pid 474.
[rdpclient 474] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 474] No username.
[rdpclient 474] No password.
[rdpclient 474] No PIN.
[rdpclient 474] No domain.
[rdpclient 474] No shell.
[rdpclient 474] No directory.
[rdpclient 474] Window: 960x768@16.
[rdpclient 474] PFlags 0x0000002F.
[rdpclient 474] Keyboard 00000409:00000000.
[rdpclient 474] My hostname "wtw000A480B5521".
[rdpclient 474] TCP: connecting to 192.168.20.2:3389.
[rdpclient 474] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[rdpclient 474] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 474] Сервер 192.168.20.2, порт 3389: отказано в подключении.
[rdpclient 474] Caught signal SIGTERM.
[pfac] Process pid 474 terminated, status 00000000.
[pfac] Ok, PID 475.
[pfac] Process pid 475 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 7): 883856 Kb.
[pfac] Got command line /sbin/rdpclient 7.
[pfac] Ok, PID 476.
[rdpclient 476] RDP Terminal Client, WTware v.5.2.28, pipe 7, pid 476.
[rdpclient 476] Make RDP session with 192.168.20.2, port 3389.
[rdpclient 476] No username.
[rdpclient 476] No password.
[rdpclient 476] No PIN.
[rdpclient 476] No domain.
[rdpclient 476] No shell.
[rdpclient 476] No directory.
[rdpclient 476] Window: 960x768@16.
[rdpclient 476] PFlags 0x0000002F.
[rdpclient 476] Keyboard 00000409:00000000.
[rdpclient 476] My hostname "wtw000A480B5521".
[rdpclient 476] TCP: connecting to 192.168.20.2:3389.
[rdpclient 476] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.20.2:3389 failed, errno 111.
[rdpclient 476] rdpclient-tcp.cpp ( 249): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 476] Сервер 192.168.20.2, порт 3389: отказано в подключении.
[rdpclient 476] Caught signal SIGTERM.
[pfac] Process pid 476 terminated, status 00000000.
Home WTware diskless client.
Не могу подключиться к серверу
Re: Не могу подключиться к серверу
Проблема и первый шаг к её решению русским языком написаны. Что непонятно?
такая же ошибка вылезла, лог прикрепил, подключаюсь к обычному терминалу на win2008r2aka писал(а):Проблема и первый шаг к её решению русским языком написаны. Что непонятно?
проблема возникает только при подключении к терминальным серверам вне локальной сети
не подключается к 2008r2 и 2012r2
естественно терм сервера работают через обычный клиент (из той же локальной сети).. и через telnet тоже есть ответ
на серверах ошибок нет
кажется проблема на уровне сети.. куда копать?
- лог.txt
- (2.06 КБ) 1749 скачиваний
errno 110 - ETIMEDOUT. Connection timed out. Оно ждало ответа, но никто не ответил. Пакеты по дороге теряются, или фаирволом режутся. Настройки сети на терминале внимательно проверь, неверно указанные маска или шлюз могут так же проявиться.
спасибо, про шлюз я совершенно не подумал. поправил - заработало.
Я думал, что если написано Авто - то ваш DHCP сервер шлюз возьмет из настроек сетевой карты.
