Unknown WiFi card "Archer T2U Plus"
Системный блок (210) использует "WTware 5.4.92" и загрузочную флешку WTware
This adapter has a **Realtek RTL8821AU Chipset** at its heart.
https://github.com/nlkguy/archer-t2u-plus-linux
Unknown WiFi card "Archer T2U Plus" [tid10976]
- WhatsApp Image 2022-06-09 at 09.27.53 (1).jpeg (96.05 КБ) 19579 просмотров
- WhatsApp Image 2022-06-09 at 09.21.03 (1).jpeg (72.79 КБ) 19579 просмотров
Re: Unknown WiFi card "Archer T2U Plus" [tid10976]
По проводу никак? Провод работает.
Попробуй свежую версию втвари. Если не поедет, хочу такой же экран от свежей версии втвари.
WTware v.6.0.72
Загрузка USB
Успешно!
[ KERNEL] [ 6.011363] 88XXau: loading out-of-tree module taints kernel.
[ KERNEL] [ 6.076810] usbcore: registered new interface driver rtl88xxau
[ initrd] [ 6.075259] USB Wi-Fi module 88XXau.ko loaded.
[ KERNEL] [ 6.077204] rtl88xxau 3-6:1.0 eth0: renamed from wlan0
[ initrd] [ 6.089996] Failed to disable Wi-Fi Power Management.
[ initrd] [ 6.090020] Copy /bootmedia/configs/wpa_supplicant.conf to /etc/wpa.conf.
[ initrd] [ 6.093832] /bootmedia/configs/wpa_supplicant.conf -> /etc/wpa.conf, 102 bytes copied.
Загрузка USB
Успешно!
