маппинг com портов
Свойства, ошибки, замечания и проблемы сборок WTware для Rockchip. Про WTware на обычных x86 компьютерах смотрите раздел ниже.
Правила форума
маппинг com портов
Возникла проблема, при маппинге com порта на rk3188.
На x86 это же устройство ([initrd] USB: 0403:1234 Future Technology Devices International, Ltd IronLogic RFID Adapter [Z-2 USB].) маппится отлично.
Лог с x86:
[KERNEL] [ 0.000000] Linux version 4.1.13 (root@c12) (gcc version 5.2.1 20151010 (Ubuntu 5.2.1-22ubuntu2) ) #1 Wed Dec 2 22:10:29 SAMT 2015
[KERNEL] [ 0.015275] CPU: Intel(R) Celeron(R) CPU 2.53GHz (fam: 0f, model: 04, stepping: 09)
[KERNEL] [ 0.180128] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[KERNEL] [ 0.180134] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.180138] usb usb1: Product: EHCI Host Controller
[KERNEL] [ 0.180142] usb usb1: Manufacturer: Linux 4.1.13 ehci_hcd
[KERNEL] [ 0.180145] usb usb1: SerialNumber: 0000:00:1d.7
[KERNEL] [ 0.180434] hub 1-0:1.0: USB hub found
[KERNEL] [ 0.180450] hub 1-0:1.0: 8 ports detected
[KERNEL] [ 0.180812] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[KERNEL] [ 0.180826] ohci-pci: OHCI PCI platform driver
[KERNEL] [ 0.180882] uhci_hcd: USB Universal Host Controller Interface driver
[KERNEL] [ 0.181061] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[KERNEL] [ 0.181076] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[KERNEL] [ 0.181112] uhci_hcd 0000:00:1d.0: irq 20, io base 0x0000a000
[KERNEL] [ 0.181203] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.181208] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.181212] usb usb2: Product: UHCI Host Controller
[KERNEL] [ 0.181216] usb usb2: Manufacturer: Linux 4.1.13 uhci_hcd
[KERNEL] [ 0.181220] usb usb2: SerialNumber: 0000:00:1d.0
[KERNEL] [ 0.181500] hub 2-0:1.0: USB hub found
[KERNEL] [ 0.181517] hub 2-0:1.0: 2 ports detected
[KERNEL] [ 0.181837] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[KERNEL] [ 0.181853] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[KERNEL] [ 0.181924] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000a400
[KERNEL] [ 0.182017] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.182022] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.182026] usb usb3: Product: UHCI Host Controller
[KERNEL] [ 0.182029] usb usb3: Manufacturer: Linux 4.1.13 uhci_hcd
[KERNEL] [ 0.182033] usb usb3: SerialNumber: 0000:00:1d.1
[KERNEL] [ 0.182309] hub 3-0:1.0: USB hub found
[KERNEL] [ 0.182326] hub 3-0:1.0: 2 ports detected
[KERNEL] [ 0.182645] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[KERNEL] [ 0.182660] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[KERNEL] [ 0.182700] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000a800
[KERNEL] [ 0.182792] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.182797] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.182801] usb usb4: Product: UHCI Host Controller
[KERNEL] [ 0.182805] usb usb4: Manufacturer: Linux 4.1.13 uhci_hcd
[KERNEL] [ 0.182808] usb usb4: SerialNumber: 0000:00:1d.2
[KERNEL] [ 0.183090] hub 4-0:1.0: USB hub found
[KERNEL] [ 0.183108] hub 4-0:1.0: 2 ports detected
[KERNEL] [ 0.183433] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[KERNEL] [ 0.183449] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[KERNEL] [ 0.183489] uhci_hcd 0000:00:1d.3: irq 19, io base 0x0000b000
[KERNEL] [ 0.183800] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[KERNEL] [ 0.183806] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 0.183810] usb usb5: Product: UHCI Host Controller
[KERNEL] [ 0.183814] usb usb5: Manufacturer: Linux 4.1.13 uhci_hcd
[KERNEL] [ 0.183817] usb usb5: SerialNumber: 0000:00:1d.3
[KERNEL] [ 0.184145] hub 5-0:1.0: USB hub found
[KERNEL] [ 0.184162] hub 5-0:1.0: 2 ports detected
[KERNEL] [ 0.184503] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[KERNEL] [ 0.184508] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[KERNEL] [ 0.185168] serio: i8042 KBD port at 0x60,0x64 irq 1
[KERNEL] [ 0.185300] hv_vmbus: registering driver hyperv_keyboard
[KERNEL] [ 0.185421] mousedev: PS/2 mouse device common for all mice
[KERNEL] [ 0.186188] input: PC Speaker as /devices/platform/pcspkr/input/input3
[KERNEL] [ 0.186401] hidraw: raw HID events driver (C) Jiri Kosina
[KERNEL] [ 0.186731] hv_vmbus: registering driver hid_hyperv
[KERNEL] [ 0.187226] usbcore: registered new interface driver usbhid
[KERNEL] [ 0.187232] usbhid: USB HID core driver
[KERNEL] [ 0.187346] NET: Registered protocol family 17
[KERNEL] [ 0.187693] Using IPI Shortcut mode
[KERNEL] [ 0.207888] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[KERNEL] [ 0.208096] RAMDISK: xz image found at block 0
[KERNEL] [ 0.676292] usb 2-1: new full-speed USB device number 2 using uhci_hcd
[KERNEL] [ 0.808115] usb 1-8: new high-speed USB device number 4 using ehci-pci
[KERNEL] [ 0.878467] usb 2-1: New USB device found, idVendor=0403, idProduct=1234
[KERNEL] [ 0.878474] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[KERNEL] [ 0.878479] usb 2-1: Product: USB IronLogic RFID Adapter
[KERNEL] [ 0.878483] usb 2-1: Manufacturer: ILogic
[KERNEL] [ 0.878487] usb 2-1: SerialNumber: IL01R3L3
[KERNEL] [ 0.880246] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[KERNEL] [ 0.944992] usb 1-8: New USB device found, idVendor=0951, idProduct=1642
[KERNEL] [ 0.944999] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[KERNEL] [ 0.945004] usb 1-8: Product: DT 101 G2
[KERNEL] [ 0.945008] usb 1-8: Manufacturer: Kingston
[KERNEL] [ 0.945012] usb 1-8: SerialNumber: 001CC05FE930BCA189160019
[KERNEL] [ 1.025139] VFS: Mounted root (romfs filesystem) readonly on device 1:0.
[KERNEL] [ 1.025179] devtmpfs: mounted
[KERNEL] [ 1.025438] Freeing unused kernel memory: 324K (c1478000 - c14c9000)
[KERNEL] [ 1.025502] Write protecting the kernel text: 3428k
[KERNEL] [ 1.025519] Write protecting the kernel read-only data: 940k
[KERNEL] [ 1.085186] usb 3-1: New USB device found, idVendor=0458, idProduct=003a
[KERNEL] [ 1.085195] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[KERNEL] [ 1.085200] usb 3-1: Manufacturer: Genius
[KERNEL] [ 1.102638] input: Genius as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.0/0003:0458:003A.0001/input/input4
[KERNEL] [ 1.102979] hid-generic 0003:0458:003A.0001: input,hidraw0: USB HID v1.10 Mouse [Genius] on usb-0000:00:1d.1-1/input0
[KERNEL] [ 1.156032] tsc: Refined TSC clocksource calibration: 2533.251 MHz
[KERNEL] [ 1.156044] clocksource tsc: mask: 0xffffffffffffffff max_cycles: 0x2483ec817d1, max_idle_ns: 440795216948 ns
[pfac] Ok, PID 530.
[initrd] WTware shell v.5.4.8
[initrd] USB boot.
[initrd] PCI: C 06 8086:2770 Bridge Intel Corporation 82945G/GZ/P/PL Memory Controller Hub.
[initrd] PCI: C 03 8086:2772 Display controller Intel Corporation 82945G/GZ Integrated Graphics Controller.
[initrd] PCI: C 04:03 8086:27d8 Multimedia controller Audio device Intel Corporation NM10/ICH7 Family High Definition Audio Controller.
[initrd] PCI: C 06:04 8086:27d0 Bridge PCI bridge Intel Corporation NM10/ICH7 Family PCI Express Port 1.
[initrd] PCI: C 0c:03 8086:27c8 Serial bus controller USB controller Intel Corporation NM10/ICH7 Family USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:27c9 Serial bus controller USB controller Intel Corporation NM10/ICH7 Family USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:27ca Serial bus controller USB controller Intel Corporation NM10/ICH7 Family USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:27cb Serial bus controller USB controller Intel Corporation NM10/ICH7 Family USB UHCI Controller.
[initrd] PCI: C 0c:03 8086:27cc Serial bus controller USB controller Intel Corporation NM10/ICH7 Family USB2 EHCI Controller.
[initrd] PCI: C 06:04 8086:244e Bridge PCI bridge Intel Corporation 82801 PCI Bridge.
[initrd] PCI: C 06:01 8086:27b8 Bridge ISA bridge Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge.
[initrd] PCI: C 01:01 8086:27df Mass storage controller IDE interface Intel Corporation 82801G (ICH7 Family) IDE Controller.
[initrd] PCI: C 01:01 8086:27c0 Mass storage controller IDE interface Intel Corporation NM10/ICH7 Family SATA Controller [IDE mode].
[initrd] PCI: C 0c:05 8086:27da Serial bus controller SMBus Intel Corporation NM10/ICH7 Family SMBus Controller.
[initrd] PCI: C 02 11ab:4320 Network controller Marvell Technology Group Ltd. 88E8001 Gigabit Ethernet Controller.
[initrd] USB: 0951:1642 Kingston Technology DT101 G2.
[initrd] USB: 0458:003a KYE Systems Corp. (Mouse Systems) NetScroll+ Mini Traveler / Genius NetScroll 120.
[initrd] Load ISO 9660 and UDF CDROM filesystem drivers.
[initrd] modprobe udf.
[initrd] modprobe isofs.
[initrd] Load UTF8 charset.
[initrd] modprobe nls_cp437.
[initrd] modprobe nls_utf8.
[initrd] Load VFAT filesystem driver.
[initrd] modprobe fat.
[initrd] modprobe vfat.
[initrd] Load usb storage driver.
[initrd] modprobe scsi_mod.
[initrd] modprobe usb-storage.
[KERNEL] [ 1.567257] SCSI subsystem initialized
[initrd] modprobe sd_mod.
[KERNEL] [ 1.576833] usb-storage 1-8:1.0: USB Mass Storage device detected
[KERNEL] [ 1.576947] scsi host0: usb-storage 1-8:1.0
[KERNEL] [ 1.577111] usbcore: registered new interface driver usb-storage
[KERNEL] [ 2.156067] Switched to clocksource tsc
[KERNEL] [ 2.577032] scsi 0:0:0:0: Direct-Access Kingston DT 101 G2 PMAP PQ: 0 ANSI: 4
[KERNEL] [ 2.578289] sd 0:0:0:0: [sda] 15187968 512-byte logical blocks: (7.77 GB/7.24 GiB)
[KERNEL] [ 2.579545] sd 0:0:0:0: [sda] Write Protect is off
[KERNEL] [ 2.579555] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[KERNEL] [ 2.580802] sd 0:0:0:0: [sda] No Caching mode page found
[KERNEL] [ 2.580812] sd 0:0:0:0: [sda] Assuming drive cache: write through
[KERNEL] [ 2.586523] sda: sda1 sda2
[KERNEL] [ 2.590658] sd 0:0:0:0: [sda] Attached SCSI removable disk
[KERNEL] [ 2.635257] FAT-fs (sda): invalid media value (0xb9)
[KERNEL] [ 2.635263] FAT-fs (sda): Can't find a valid FAT filesystem
[initrd] Success: first USB disk mounted to /bootmedia.
[initrd] WTpassword empty.
| [BOM]
| clientIP=192.168.0.2
[initrd] Load ethernet drivers.
[initrd] modprobe skge.
[initrd] NIC module skge.ko loaded.
[KERNEL] [ 2.665854] skge: 1.14 addr 0xdfffc000 irq 20 chip Yukon-Lite rev 9
[KERNEL] [ 2.666207] skge 0000:01:04.0 eth0: addr 00:1a:92:32:d6:fc
[KERNEL] [ 2.680075] skge 0000:01:04.0 eth0: enabling interface
[KERNEL] [ 4.385352] skge 0000:01:04.0 eth0: Link is up at 100 Mbps, full duplex, flow control none
[initrd] eth0: 11ab:4320. Apply WOL configuration.
Send broadcast WTCU discover.
[initrd] Common local disk config:
| [BOM]
| server=192.168.0.1
| serial=com3(usb 0403:1234)
| clienthostname=2
| connection
| [BOM]
| server=192.168.0.1
| clienthostname=2
| connection
[initrd] Hostname: "2".
RSH: listener is active.
[gm] WTware session manager v.5.4.8.
[gm] Load agpgart driver.
[gm] modprobe agpgart.
[gm] modprobe intel-agp.
[KERNEL] [ 4.825796] Linux agpgart interface v0.103
[KERNEL] [ 4.830160] agpgart-intel 0000:00:00.0: Intel 945G Chipset
[KERNEL] [ 4.830195] agpgart-intel 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[KERNEL] [ 4.830346] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[KERNEL] [ 4.830542] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[gm] EV_REL flag found. Add mouse event4: Genius.
[gm] Add keyboard event3: AT Translated Set 2 keyboard.
[gm] Ignore event2: PC Speaker.
[gm] Add keyboard event1: Power Button.
[gm] Add keyboard event0: Power Button.
[gm] Display mode: 1366x768, 16 bit, 60 Hz, modeline "", DDC enabled, connector 0.
[gm] modprobe drm.
[gm] Run modprobe i915 modeset=1.
[KERNEL] [ 5.241937] [drm] Initialized drm 1.1.0 20060810
[gm] modprobe i915 modeset=1.
[KERNEL] [ 5.264704] [drm] Memory usable by graphics device = 256M
[KERNEL] [ 5.264715] [drm] Replacing VGA console driver
[KERNEL] [ 5.264845] Console: switching to colour dummy device 80x25
[KERNEL] [ 5.265592] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[KERNEL] [ 5.265599] [drm] Driver supports precise vblank timestamp query.
[KERNEL] [ 5.294996] [drm] initialized overlay support
[KERNEL] [ 5.295041] [drm] Initialized i915 1.6.0 20150327 for 0000:00:02.0 on minor 0
[gm] Kernel drm/kms module loaded.
[KERNEL] [ 5.367855] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[KERNEL] [ 5.367862] i915 0000:00:02.0: registered panic notifier
[gm] count_fbs 0.
[gm] count_crtcs 2.
[gm] count_connectors 1.
[gm] count_encoders 1.
[gm] min_width 0, max_width 4096, min_height 0, max_height 4096.
[gm] ======================
[gm] fb_id 0.
[gm] width 1366.
[gm] height 768.
[gm] pitch 2752.
[gm] bpp 16.
[gm] depth 16.
[gm] handle 0x00000001.
[gm] LINELENBYTES 2752, VBUF 0x0xb72c1000.
[gm] WMEMCOPY: 19530K copied in 0.016123 sec.
[gm] libc: 19530K copied in 0.015925 sec.
[gm] movs: 19530K copied in 0.015883 sec.
[gm] MMX: 19530K copied in 0.015779 sec.
[gm] SSE2: 19530K copied in 0.015897 sec.
[gm] Choose MMX memcpy.
[gm] Run serial daemon for ttyUSB0.
[pfac] Got command line /sbin/rdpdr[serial] 8.
[pfac] Ok, PID 643.
[gm] Load usb <-> serial bridges drivers.
[gm] modprobe usbserial.
[rdpdr-serial 8] RDP Serial Port Redirector, WTware v.5.4.8, device ttyUSB0.
[gm] modprobe pl2303.
[KERNEL] [ 5.653339] usbcore: registered new interface driver usbserial
[KERNEL] [ 5.653390] usbcore: registered new interface driver usbserial_generic
[KERNEL] [ 5.653432] usbserial: USB Serial support registered for generic
[gm] modprobe ftdi_sio.
[KERNEL] [ 5.661287] usbcore: registered new interface driver pl2303
[KERNEL] [ 5.661353] usbserial: USB Serial support registered for pl2303
[KERNEL] [ 5.667143] usbcore: registered new interface driver ftdi_sio
[KERNEL] [ 5.667199] usbserial: USB Serial support registered for FTDI USB Serial Device
[KERNEL] [ 5.667307] ftdi_sio 2-1:1.0: FTDI USB Serial Device converter detected
[KERNEL] [ 5.667387] usb 2-1: Detected FT232RL
[KERNEL] [ 5.669689] usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB0
[gm] modprobe cp210x.
[gm] modprobe ch341.
[KERNEL] [ 5.675118] usbcore: registered new interface driver cp210x
[KERNEL] [ 5.675173] usbserial: USB Serial support registered for cp210x
[gm] modprobe mxu11x0.
[KERNEL] [ 5.680792] usbcore: registered new interface driver ch341
[KERNEL] [ 5.680849] usbserial: USB Serial support registered for ch341-uart
[gm] modprobe metro-usb.
[KERNEL] [ 5.686580] usbcore: registered new interface driver mxu11x0
[KERNEL] [ 5.686641] usbserial: USB Serial support registered for MOXA UPort 1110
[KERNEL] [ 5.686684] usbserial: USB Serial support registered for MOXA UPort 1130
[KERNEL] [ 5.686724] usbserial: USB Serial support registered for MOXA UPort 1150
[KERNEL] [ 5.686765] usbserial: USB Serial support registered for MOXA UPort 1150I
[KERNEL] [ 5.686809] usbserial: USB Serial support registered for MOXA UPort 1130I
[KERNEL] [ 5.686819] mxu11x0: 1.3.11:MOXA UPort 11x0 USB to Serial Hub Driver
[gm] modprobe symbolserial.
[KERNEL] [ 5.696250] usbcore: registered new interface driver metro_usb
[KERNEL] [ 5.696317] usbserial: USB Serial support registered for Metrologic USB to Serial
[gm] modprobe opticon.
[KERNEL] [ 5.701340] usbcore: registered new interface driver symbolserial
[KERNEL] [ 5.701398] usbserial: USB Serial support registered for symbol
[KERNEL] [ 5.706931] usbcore: registered new interface driver opticon
[KERNEL] [ 5.706987] usbserial: USB Serial support registered for opticon
[pfac] Got command line /sbin/resolver 0x9231ca8 dns [192.168.0.1].
[pfac] Ok, PID 697.
[gm] Nobody can control terminal by VNC.
[gm] 192.168.0.1 => 192.168.0.1.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 880260 Kb.
[pfac] Ok, PID 698.
[pfac] Process pid 697 terminated, status 00000000.
[rdpclient 698] RDP Terminal Client, WTware v.5.4.8, pipe 1, pid 698.
[gm] COM3 => ttyUSB0.
[rdpclient 698] Add serial redirection, COM3 in the session = hardware ttyUSB0.
[rdpdr-serial 8] New client connection, id 1.
[rdpclient 698] Make RDP session with 192.168.0.1, port 3389.
[rdpclient 698] No PIN.
[rdpclient 698] No domain.
[rdpclient 698] No shell.
[rdpclient 698] No directory.
[rdpclient 698] Window: 1302x768@16.
[rdpclient 698] PFlags 0x0000002F.
[rdpclient 698] Keyboard 00000409:00000000.
[rdpclient 698] My hostname "2".
[rdpclient 698] TCP: connecting to 192.168.0.1:3389.
[rdpclient 698] TCP: connection with 192.168.0.1:3389 established.
[rdpclient 698] Turn keepalive on.
[rdpclient 698] Free ram after buffers allocation: 880012 KB.
[rdpclient 698] Process RDP server certificate.
[rdpclient 698] RDP5 encryption (X.509).
[KERNEL] [ 5.730368] random: rdpclient urandom read with 63 bits of entropy available
[rdpclient 698] INFOTYPE_LOGON_PLAINNOTIFY
[KERNEL] [ 74.045396] random: nonblocking pool is initialized
На rk3188 пишет:
[gm] ERROR: usb-serial device 0403:1234 not found.
[gm] Do NOT redirect COM4.
Лог с rk3188:
[init] WTware init v.5.4.8/RK3066 (c) 2003-2015 WTware http://www.wtware.com
[init] Run /sbin/loader.
[init] Ok, PID 72.
[loader] WTware/RK3066 loader v.5.4.8.
[loader] [0] partition 'misc'.
[loader] [1] partition 'kernel'.
[loader] [2] partition 'boot'.
[loader] [3] partition 'recovery'.
[loader] [4] partition 'backup'.
[loader] [5] partition 'cache'.
[loader] [6] partition 'userdata'.
[loader] [7] partition 'metadata'.
[loader] [8] partition 'kpanic'.
[loader] [9] partition 'system'. Store data here.
[loader] [10] partition 'user'.
[loader] Loader version 2.16.
[loader] Video mode looks like 1920x1080.
[loader] Keyboard not found.
[init] Run /sbin/kotenok.
[init] Ok, PID 105.
WTware v.5.4.8/RK3066 supervisor.
WTC listener is active.
HTTPd listener is active.
[KERNEL] [ 0.000000] Initializing cgroup subsys cpu
[KERNEL] [ 0.000000] Linux version 3.0.36+ (yangfeihu@xintu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #14 SMP PREEMPT Wed Jun 3 18:42:05 CST 2015
[KERNEL] [ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
[KERNEL] [ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[KERNEL] [ 0.000000] Machine: RK30board
[KERNEL] [ 0.000000] ddr size = 1024 M, set ion_reserve_size size to 125829120
[KERNEL] [ 0.000000] memory reserve: Memory(base:0x98800000 size:120M) reserved for
[KERNEL] [ 0.000000] memory reserve: Memory(base:0x97000000 size:24M) reserved for
[KERNEL] [ 0.000000] memory reserve: Memory(base:0x96800000 size:8M) reserved for
[KERNEL] [ 0.000000] memory reserve: Total reserved 152M
[KERNEL] [ 0.000000] Memory policy: ECC disabled, Data cache writeback
[KERNEL] [ 0.000000] bootconsole [earlycon0] enabled
[KERNEL] [ 0.000000] CPU SRAM: copied sram code from c0e47000 to fef00100 - fef02030
[KERNEL] [ 0.000000] CPU SRAM: copied sram data from c0e48f30 to fef02030 - fef02960
[KERNEL] [ 0.000000] sram_log: @ 0q @ P 1 / ! aB@ 2 `" 2q : 4q
[KERNEL] [ 0.000000] CLKDATA_MSG: pll_flag = 0x03
[KERNEL] [ 0.000000] cpll auto set rate error
[KERNEL] [ 0.000000] hzb test rmii clk get form clkin
[KERNEL] [ 0.000000] L310 cache controller enabled
[KERNEL] [ 0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c8, AUX_CTRL 0x76050001, Cache size: 524288 B
[KERNEL] [ 0.000000] DDR DEBUG: version 1.00 20131106
[KERNEL] [ 0.000000] DDR DEBUG: DDR3 Device
[KERNEL] [ 0.000000] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[KERNEL] [ 0.000000] DDR DEBUG: init success!!! freq=300MHz
[KERNEL] [ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=0 extra clock, DGPS=360
[KERNEL] [ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=1 extra clock, DGPS=90
[KERNEL] [ 0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[KERNEL] [ 0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb
[KERNEL] [ 0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[KERNEL] [ 0.000000] On node 0 totalpages: 223232
[KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat c0e44c40, node_mem_map c2790000
[KERNEL] [ 0.000000] Normal zone: 976 pages used for memmap
[KERNEL] [ 0.000000] Normal zone: 0 pages reserved
[KERNEL] [ 0.000000] Normal zone: 123952 pages, LIFO batch:31
[KERNEL] [ 0.000000] HighMem zone: 1072 pages used for memmap
[KERNEL] [ 0.000000] HighMem zone: 97232 pages, LIFO batch:31
[KERNEL] [ 0.000000] PERCPU: Embedded 7 pages/cpu @c2f99000 s7040 r8192 d13440 u32768
[KERNEL] [ 0.000000] pcpu-alloc: s7040 r8192 d13440 u32768 alloc=8*4096
[KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 221184
[KERNEL] [ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00790000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00006000@0x00004000(kernel),0x00006000@0x0000a000(boot),0x00010000@0x00010000(recovery),0x00020000@0x00020000(backup),0x00040000@0x00040000(cache),0x00400000@0x00080000(userdata),0x00002000@0x00480000(metadata),0x00002000@0x00482000(kpanic),0x00300000@0x00484000(system),-@0x00784000(user) bootver=2014-07-22#2.16 firmware_ver=4.4.2
[KERNEL] [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[KERNEL] [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[KERNEL] [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[KERNEL] [ 0.000000] allocated 4194304 bytes of page_cgroup
[KERNEL] [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[KERNEL] [ 0.000000] Memory: 872MB = 872MB total
[KERNEL] [ 0.000000] Memory: 850848k/850848k available, 197728k reserved, 393216K highmem
[KERNEL] [ 0.000000] Virtual kernel memory layout:
[KERNEL] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[KERNEL] [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[KERNEL] [ 0.000000] DMA : 0xff600000 - 0xffe00000 ( 8 MB)
[KERNEL] [ 0.000000] vmalloc : 0xdf000000 - 0xfe800000 ( 504 MB)
[KERNEL] [ 0.000000] lowmem : 0xc0000000 - 0xde800000 ( 488 MB)
[KERNEL] [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[KERNEL] [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[KERNEL] [ 0.000000] .init : 0xc0408000 - 0xc062f000 (2204 kB)
[KERNEL] [ 0.000000] .text : 0xc062f000 - 0xc0dbf548 (7746 kB)
[KERNEL] [ 0.000000] .data : 0xc0dc0000 - 0xc0e46aa8 ( 539 kB)
[KERNEL] [ 0.000000] .bss : 0xc0e4a024 - 0xc18facc8 (10948 kB)
[KERNEL] [ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[KERNEL] [ 0.000000] Preemptible hierarchical RCU implementation.
[KERNEL] [ 0.000000] NR_IRQS:352
[KERNEL] [ 0.000000] rk30_gpio_init: 128 gpio irqs in 4 banks
[KERNEL] [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[KERNEL] [ 0.000000] rk_timer: version 1.3
[KERNEL] [ 0.003748] Calibrating delay loop (skipped) preset value.. 1583.48 BogoMIPS (lpj=7917420)
[KERNEL] [ 0.012892] pid_max: default: 32768 minimum: 301
[KERNEL] [ 0.018159] Security Framework initialized
[KERNEL] [ 0.022731] SELinux: Initializing.
[KERNEL] [ 0.026655] SELinux: Starting in permissive mode
[KERNEL] [ 0.026721] Mount-cache hash table entries: 512
[KERNEL] [ 0.032303] Initializing cgroup subsys debug
[KERNEL] [ 0.037066] Initializing cgroup subsys cpuacct
[KERNEL] [ 0.042040] Initializing cgroup subsys memory
[KERNEL] [ 0.046920] Initializing cgroup subsys freezer
[KERNEL] [ 0.051894] CPU: Testing write buffer coherency: ok
[KERNEL] [ 0.138079] CPU1: Booted secondary processor
[KERNEL] [ 0.178069] CPU2: Booted secondary processor
[KERNEL] [ 0.218069] CPU3: Booted secondary processor
[KERNEL] [ 0.218110] Brought up 4 CPUs
[KERNEL] [ 0.235713] SMP: Total of 4 processors activated (6333.93 BogoMIPS).
[KERNEL] [ 0.243113] devtmpfs: initialized
[KERNEL] [ 0.252047] delayline: aclk_cpu 297000000 div 2 clk 99000000 start point 67
[KERNEL] [ 0.252820] NET: Registered protocol family 16
[KERNEL] [ 0.257896] last_log: 0xde100000 map to 0xdf004000 and copy to 0xc0e4e1a0 (version 2.1)
[KERNEL] [ 0.282073] DVFS MSG: AVS Value(index=0): 144 145 145 144 144 146 145 143 145 144
[KERNEL] [ 0.301087] lcdc0 is used as external display device contoller!
[KERNEL] [ 0.307717] lcdc1 is used as primary display device controller!
[KERNEL] [ 0.414511] rk29sdk_wifi_bt_gpio_control_init: init finished
[KERNEL] [ 0.422171] console [ttyFIQ0] enabled, bootconsole disabled
[KERNEL] [ 0.431339] Registered FIQ tty driver de035cc0
[KERNEL] [ 0.431966] Loaded driver for PL330 DMAC-1 rk29-pl330
[KERNEL] [ 0.432011] DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[KERNEL] [ 0.432196] Loaded driver for PL330 DMAC-2 rk29-pl330
[KERNEL] [ 0.432238] DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14
[KERNEL] [ 0.464021] bio: create slab at 0
[KERNEL] [ 0.468439] SCSI subsystem initialized
[KERNEL] [ 0.468650] usbcore: registered new interface driver usbfs
[KERNEL] [ 0.468766] usbcore: registered new interface driver hub
[KERNEL] [ 0.483016] usbcore: registered new device driver usb
[KERNEL] [ 0.483280] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter
[KERNEL] [ 0.483533] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
[KERNEL] [ 0.483718] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
[KERNEL] [ 0.483851] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter
[KERNEL] [ 0.484145] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter
[KERNEL] [ 0.514609] rk30-adc rk30-adc: rk30 adc: driver initialized
[KERNEL] [ 0.514712] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[KERNEL] [ 0.514931] rk29-wdt rk29-wdt.0: starting watchdog timer
[KERNEL] [ 0.515195] Advanced Linux Sound Architecture Driver Version 1.0.24.
[KERNEL] [ 0.515653] Bluetooth: Core ver 2.16
[KERNEL] [ 0.515727] NET: Registered protocol family 31
[KERNEL] [ 0.515764] Bluetooth: HCI device and connection manager initialized
[KERNEL] [ 0.515817] Bluetooth: HCI socket layer initialized
[KERNEL] [ 0.515856] Bluetooth: L2CAP socket layer initialized
[KERNEL] [ 0.515921] Bluetooth: SCO socket layer initialized
[KERNEL] [ 0.517021] rk fb probe ok!
[KERNEL] [ 0.521801] act8846_set_init,line=17
[KERNEL] [ 0.521833] act8846_set_init:g_pmic_type=3
[KERNEL] [ 0.523531] act8846_set_init act_dcdc1 =1200000mV end
[KERNEL] [ 0.525322] act8846_set_init vdd_core =1000000mV end
[KERNEL] [ 0.527107] act8846_set_init vdd_cpu =1000000mV end
[KERNEL] [ 0.528905] act8846_set_init act_dcdc4 =3300000mV end
[KERNEL] [ 0.530094] act8846_set_init act_ldo1 =1000000mV end
[KERNEL] [ 0.531777] act8846_set_init act_ldo2 =1200000mV end
[KERNEL] [ 0.533460] act8846_set_init act_ldo3 =1800000mV end
[KERNEL] [ 0.535143] act8846_set_init act_ldo4 =3300000mV end
[KERNEL] [ 0.536827] act8846_set_init act_ldo5 =3300000mV end
[KERNEL] [ 0.538524] act8846_set_init act_ldo6 =1800000mV end
[KERNEL] [ 0.539607] act8846_set_init act_ldo7 =1800000mV end
[KERNEL] [ 0.541290] act8846_set_init act_ldo8 =2800000mV end
[KERNEL] [ 0.541338] act8846_set_init,line=78 END
[KERNEL] [ 0.541407] i2c-core: driver [act8846] using legacy suspend method
[KERNEL] [ 0.541455] i2c-core: driver [act8846] using legacy resume method
[KERNEL] [ 0.541530] rk1000_control_probe
[KERNEL] [ 0.566434] rk1000_control_probe ok
[KERNEL] [ 0.566516] Switching to clocksource rk_timer
[KERNEL] [ 0.567504] Switched to NOHz mode on CPU #0
[KERNEL] [ 0.568107] Switched to NOHz mode on CPU #3
[KERNEL] [ 0.568126] Switched to NOHz mode on CPU #2
[KERNEL] [ 0.568138] Switched to NOHz mode on CPU #1
[KERNEL] [ 0.575370] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xdf0ac000
[KERNEL] [ 0.575461] fb0:win0
[KERNEL] [ 0.575466] fb1:win1
[KERNEL] [ 0.575471] fb2:win2
[KERNEL] [ 0.575565] rk3188 lcdc1 clk enable...
[KERNEL] [ 0.600682] rk3188 lcdc1 clk disable...
[KERNEL] [ 0.660404] fb0:phy:97000000>>vir:e0000000>>len:0x1800000
[KERNEL] [ 0.660693] rk_fb_register>>>>>fb0
[KERNEL] [ 0.661028] rk_fb_register>>>>>fb1
[KERNEL] [ 0.693521] rk3188 lcdc1 probe ok!
[KERNEL] [ 0.693617] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xdf0c0000
[KERNEL] [ 0.693693] fb0:win0
[KERNEL] [ 0.693698] fb1:win1
[KERNEL] [ 0.693703] fb2:win2
[KERNEL] [ 0.693802] rk3188 lcdc0 clk enable...
[KERNEL] [ 0.718900] rk3188 lcdc0 clk disable...
[KERNEL] [ 0.718940] fb2:phy:97000000>>vir:e0000000>>len:0x1800000
[KERNEL] [ 0.719201] rk_fb_register>>>>>fb2
[KERNEL] [ 0.719543] rk_fb_register>>>>>fb3
[KERNEL] [ 0.719574] rk3188 lcdc0 probe ok!
[KERNEL] [ 0.752873] cfg80211: Calling CRDA to update world regulatory domain
[KERNEL] [ 0.780562] IT66121 probe success.
[KERNEL] [ 0.783891] emmc emmc: internal_storage is NOT emmc
[KERNEL] [ 0.784103] NET: Registered protocol family 2
[KERNEL] [ 0.784245] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
[KERNEL] [ 0.784602] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[KERNEL] [ 0.785622] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[KERNEL] [ 0.786775] TCP: Hash tables configured (established 65536 bind 65536)
[KERNEL] [ 0.786825] TCP reno registered
[KERNEL] [ 0.786857] UDP hash table entries: 256 (order: 1, 8192 bytes)
[KERNEL] [ 0.786916] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[KERNEL] [ 0.787235] NET: Registered protocol family 1
[KERNEL] [ 0.787438] Unpacking initramfs...
[KERNEL] [ 1.017573] Freeing initrd memory: 7744K
[KERNEL] [ 1.017689] PMU: registered new PMU device of type 0
[KERNEL] [ 1.017829] efuse_version_val: efuse version = 51
[KERNEL] [ 1.017870] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 33000
[KERNEL] [ 1.017926] adjust table freq=1608000 KHz, index=1350000 mV to index=1250000 mV
[KERNEL] [ 1.017984] efuse_version_val: efuse version = 51
[KERNEL] [ 1.018022] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 33000
[KERNEL] [ 1.018632] ******** Show Sink Info ********
[KERNEL] [ 1.018667] Support video mode:
[KERNEL] [ 1.018695] 1920x1080p@60Hz.
[KERNEL] [ 1.018719] 1920x1080p@50Hz.
[KERNEL] [ 1.018743] 1280x720p@60Hz.
[KERNEL] [ 1.018767] 1280x720p@50Hz.
[KERNEL] [ 1.018790] 720x576p@50Hz.
[KERNEL] [ 1.018813] 720x480p@60Hz.
[KERNEL] [ 1.018835] Support audio type: LPCM
[KERNEL] [ 1.018863] Support audio sample rate:
[KERNEL] [ 1.018893] 32000
[KERNEL] [ 1.018909] 44100
[KERNEL] [ 1.018926] 48000
[KERNEL] [ 1.018943] 88200
[KERNEL] [ 1.018960] 96000
[KERNEL] [ 1.018978] 176400
[KERNEL] [ 1.018995] 192000
[KERNEL] [ 1.019012] Support audio word lenght:
[KERNEL] [ 1.019042] 16bit
[KERNEL] [ 1.019059] 20bit
[KERNEL] [ 1.019075] 24bit
[KERNEL] [ 1.019093] ******** Show Sink Info ********
[KERNEL] [ 1.019152] rk3188 lcdc1 clk enable...
[KERNEL] [ 1.019196] lcdc1: dclk:148500000>>fps:60
[KERNEL] [ 1.019235] rk30-lcdc rk30-lcdc.1: rk3188_load_screen for lcdc1 ok!
[KERNEL] [ 1.019287] lcdc1 wakeup from standby!
[KERNEL] [ 1.019320] lcdc1 win0 open,atv layer:1
[KERNEL] [ 1.019361] lcdc1 win1 closed,atv layer:1
[KERNEL] [ 1.019712] cpufreq: delete arm freq(1608000)
[KERNEL] [ 1.148430] rk3188 cpufreq version 2.2, suspend freq 816 MHz
[KERNEL] [ 1.148937] vpu: power on
[KERNEL] [ 1.149005] VPU_SERVICE: checking hw id 4831
[KERNEL] [ 1.161345] vpu: power off...done
[KERNEL] [ 1.161406] VPU_SERVICE: init success
[KERNEL] [ 1.161695] audit: initializing netlink socket (disabled)
[KERNEL] [ 1.161769] type=2000 audit(1.090:1): initialized
[KERNEL] [ 1.164345] highmem bounce pool size: 64 pages
[KERNEL] [ 1.164529] ashmem: initialized
[KERNEL] [ 1.191454] fuse init (API version 7.16)
[KERNEL] [ 1.191730] SELinux: Registering netfilter hooks
[KERNEL] [ 1.196404] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[KERNEL] [ 1.196469] io scheduler noop registered
[KERNEL] [ 1.196510] io scheduler deadline registered
[KERNEL] [ 1.196628] io scheduler cfq registered (default)
[KERNEL] [ 1.216881] rga: Driver loaded succesfully
[KERNEL] [ 1.217014] rk3188 lcdc0 clk enable...
[KERNEL] [ 1.217058] lcdc0: dclk:148500000>>fps:60
[KERNEL] [ 1.217096] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
[KERNEL] [ 1.217585] rk1000_tv ver 2.0 probe ok
[KERNEL] [ 1.217806] rk_serial.c v1.6 2013-12-23
[KERNEL] [ 1.218095] rk_serial rk_serial.0: dma_rx_buffer 0xffdfc000
[KERNEL] [ 1.218141] rk_serial rk_serial.0: dma_rx_phy 0x7d4e6000
[KERNEL] [ 1.218193] rk_serial rk_serial.0: serial_rk_init_dma_rx sucess
[KERNEL] [ 1.218246] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0
[KERNEL] [ 1.218437] rk_serial rk_serial.0: membase 0xdf0c8000
[KERNEL] [ 1.218524] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
[KERNEL] [ 1.218709] rk_serial rk_serial.3: membase 0xdf0d0000
[KERNEL] [ 1.219000] Rockchip ion module(version: 1.0) is successfully loaded
[KERNEL] [ 1.221692] loop: module loaded
[KERNEL] [ 1.221756] Android kernel panic handler initialized (bind=kpanic)
[KERNEL] [ 1.221834] mt6622_probe.
[KERNEL] [ 1.221861] [BT-PLAT] mt_bt_power_init
[KERNEL] [ 2.436644] BTHWCTL: alloc bthwctl: 251:0
[KERNEL] [ 2.436795] BTHWCTL: Bluetooth hardware control driver initialized
[KERNEL] [ 2.437361] random_ether_addr***********:4A:F9:88:8E:7C:5
[KERNEL] [ 2.437611] rk29 vmac rk29 vmac.0: ARC VMAC at 0x10204000 irq 51 4a:f9:88:8e:7c:05
[KERNEL] [ 2.437683] PPP generic driver version 2.4.2
[KERNEL] [ 2.437811] PPP Deflate Compression module registered
[KERNEL] [ 2.437845] PPP BSD Compression module registered
[KERNEL] [ 2.447051] PPP MPPE Compression module registered
[KERNEL] [ 2.447090] NET: Registered protocol family 24
[KERNEL] [ 2.447174] usbcore: registered new interface driver asix
[KERNEL] [ 2.447232] usbcore: registered new interface driver cdc_ether
[KERNEL] [ 2.447289] usbcore: registered new interface driver dm9620
[KERNEL] [ 2.447342] usbcore: registered new interface driver SR9700_android
[KERNEL] [ 2.447408] usbcore: registered new interface driver CoreChips
[KERNEL] [ 2.447463] usbcore: registered new interface driver net1080
[KERNEL] [ 2.447517] usbcore: registered new interface driver cdc_subset
[KERNEL] [ 2.447580] usbcore: registered new interface driver zaurus
[KERNEL] [ 2.447625] cdc_ncm: 04-Aug-2011
[KERNEL] [ 2.447665] usbcore: registered new interface driver cdc_ncm
[KERNEL] [ 2.447701] Rockchip WiFi SYS interface (V1.00) ...
[KERNEL] [ 2.447758] Initializing USB Mass Storage driver...
[KERNEL] [ 2.447813] usbcore: registered new interface driver usb-storage
[KERNEL] [ 2.447852] USB Mass Storage support registered.
[KERNEL] [ 2.447945] usbcore: registered new interface driver usbserial
[KERNEL] [ 2.448003] USB Serial support registered for generic
[KERNEL] [ 2.448058] usbcore: registered new interface driver usbserial_generic
[KERNEL] [ 2.448098] usbserial: USB Serial Driver core
[KERNEL] [ 2.448144] USB Serial support registered for GSM modem (1-port)
[KERNEL] [ 2.448202] usbcore: registered new interface driver option
[KERNEL] [ 2.448236] option: v0.7.2:USB Driver for GSM modems
[KERNEL] [ 2.448285] USB Serial support registered for usi-modem
[KERNEL] [ 2.448345] usbcore: registered new interface driver usi-modem
[KERNEL] [ 2.660128] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
[KERNEL] [ 2.660184] usb20_otg usb20_otg: DWC OTG Controller
[KERNEL] [ 2.660289] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
[KERNEL] [ 2.660360] usb20_otg usb20_otg: irq 48, io mem 0x00000000
[KERNEL] [ 2.660417] DWC_OTG: Init: Port Power? op_state=1
[KERNEL] [ 2.660447] DWC_OTG: Init: Power Port (0)
[KERNEL] [ 2.660512] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[KERNEL] [ 2.660555] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 2.660598] usb usb1: Product: DWC OTG Controller
[KERNEL] [ 2.660631] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd
[KERNEL] [ 2.660666] usb usb1: SerialNumber: usb20_otg
[KERNEL] [ 2.660976] hub 1-0:1.0: USB hub found
[KERNEL] [ 2.661012] hub 1-0:1.0: 1 port detected
[KERNEL] [ 2.663600] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xdf180000
[KERNEL] [ 2.874131] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
[KERNEL] [ 2.874170] usb20_host usb20_host: DWC OTG Controller
[KERNEL] [ 2.874233] usb20_host usb20_host: new USB bus registered, assigned bus number 2
[KERNEL] [ 2.874296] usb20_host usb20_host: irq 49, io mem 0x00000000
[KERNEL] [ 2.874366] DWC_OTG: Init: Port Power? op_state=1
[KERNEL] [ 2.874396] DWC_OTG: Init: Power Port (0)
[KERNEL] [ 2.874449] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[KERNEL] [ 2.874492] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 2.874538] usb usb2: Product: DWC OTG Controller
[KERNEL] [ 2.874569] usb usb2: Manufacturer: Linux 3.0.36+ host20_hcd
[KERNEL] [ 2.874604] usb usb2: SerialNumber: usb20_host
[KERNEL] [ 2.874881] hub 2-0:1.0: USB hub found
[KERNEL] [ 2.874912] hub 2-0:1.0: 1 port detected
[KERNEL] [ 2.875261] DWC_OTG: Mode Mismatch Interrupt: currently in Host mode
[KERNEL] [ 2.948517] android_usb gadget: Mass Storage Function, version: 2009/09/11
[KERNEL] [ 2.948570] android_usb gadget: Number of LUNs=2
[KERNEL] [ 2.948612] lun0: LUN: removable file: (no medium)
[KERNEL] [ 2.948651] lun1: LUN: removable file: (no medium)
[KERNEL] [ 2.948938] android_usb gadget: android_usb ready
[KERNEL] [ 2.949164] input: rk29-keypad as /devices/platform/rk29-keypad/input/input0
[KERNEL] [ 2.949436] usbcore: registered new interface driver xpad
[KERNEL] [ 2.949657] ===================================================
[KERNEL] [ 2.949699] Rockchip IR remote controller driver. Version 1.0.0
[KERNEL] [ 2.949740] ===================================================
[KERNEL] [ 2.949782] ++++++++remotectl_init
[KERNEL] [ 2.949824] ++++++++remotectl_probe
[KERNEL] [ 2.949872] remotectl probe j=0x0
[KERNEL] [ 2.949901] remotectl probe j=0x1
[KERNEL] [ 2.949927] remotectl probe j=0x2
[KERNEL] [ 2.949951] remotectl probe j=0x3
[KERNEL] [ 2.949976] remotectl probe j=0x4
[KERNEL] [ 2.950001] remotectl probe j=0x5
[KERNEL] [ 2.950028] remotectl probe j=0x6
[KERNEL] [ 2.950175] input: rkxx-remotectl as /devices/platform/rkxx-remotectl/input/input1
[KERNEL] [ 2.952431] rtc_hym8563 1-0051: clock/calendar information is no longer guaranteed
[KERNEL] [ 2.955875] using rtc device, rtc_hym8563, for alarms
[KERNEL] [ 2.955927] rtc_hym8563 1-0051: rtc core: registered rtc_hym8563 as rtc0
[KERNEL] [ 2.955997] i2c /dev entries driver
[KERNEL] [ 2.956433] lirc_dev: IR Remote Control driver registered, major 249
[KERNEL] [ 2.956477] IR NEC protocol handler initialized
[KERNEL] [ 2.956506] IR RC5(x) protocol handler initialized
[KERNEL] [ 2.956537] IR RC6 protocol handler initialized
[KERNEL] [ 2.956566] IR JVC protocol handler initialized
[KERNEL] [ 2.956625] IR Sony protocol handler initialized
[KERNEL] [ 2.956655] IR RC5 (streamzap) protocol handler initialized
[KERNEL] [ 2.956691] IR LIRC bridge handler initialized
[KERNEL] [ 2.956718] Linux video capture interface: v2.00
[KERNEL] [ 2.956906] usbcore: registered new interface driver uvcvideo
[KERNEL] [ 2.956944] USB Video Class driver (v1.1.0)
[KERNEL] [ 2.957000] def_ref_volt: 1800mV, curr_ref_volt: 1800mV
[KERNEL] [ 2.957296] device-mapper: uevent: version 1.0.3
[KERNEL] [ 2.957520] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[KERNEL] [ 2.957714] Bluetooth: HCI UART driver ver 2.2
[KERNEL] [ 2.957746] Bluetooth: HCI H4 protocol initialized
[KERNEL] [ 2.957776] Bluetooth: HCILL protocol initialized
[KERNEL] [ 2.957805] Bluetooth: Generic Bluetooth USB driver ver 0.6
[KERNEL] [ 2.957878] usbcore: registered new interface driver btusb
[KERNEL] [ 2.957948] cpuidle: using governor ladder
[KERNEL] [ 2.957976] cpuidle: using governor menu
[KERNEL] [ 3.003438]
[KERNEL] [ 3.003442] drivers/mmc/core/core.c...2019.. ===== mmc_rescan Begin....[mmc0]
[KERNEL] [ 3.003495]
[KERNEL] [ 3.003498] =================
[KERNEL] [ 3.003502] sdmmc_rescan..2026.. ====find no SDMMC host. [mmc0]
[KERNEL] [ 3.003583] .Line4018..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20. [sd_mmc]
[KERNEL] [ 3.003781]
[KERNEL] [ 3.003784] drivers/mmc/core/core.c...2019.. ===== mmc_rescan Begin....[mmc1]
[KERNEL] [ 3.003846] .Line4018..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20. [sdio]
[KERNEL] [ 3.003993] Registered led device: it66121
[KERNEL] [ 3.004038] Registered led device: cvbs
[KERNEL] [ 3.005184] usbcore: registered new interface driver usbhid
[KERNEL] [ 3.005223] usbhid: USB HID core driver
[KERNEL] [ 3.005543] logger: created 256K log 'log_main'
[KERNEL] [ 3.005638] logger: created 256K log 'log_events'
[KERNEL] [ 3.005720] logger: created 256K log 'log_radio'
[KERNEL] [ 3.005798] logger: created 256K log 'log_system'
[KERNEL] [ 3.006104] zram: Created 1 device(s) ...
[KERNEL] [ 3.006539] i2c-core: driver [RK1000_CODEC] using legacy suspend method
[KERNEL] [ 3.006609] i2c-core: driver [RK1000_CODEC] using legacy resume method
[KERNEL] [ 3.026876] rk29_sdmmc_change_clk_div..1684.. newDiv=42, newCLK=294Khz [sdio]
[KERNEL] [ 3.046664] usb 1-1: new full speed USB device number 2 using usb20_otg
[KERNEL] [ 3.161294] register rk1000 codec earlysuspend ok
[KERNEL] [ 3.161332] RK1000_CODEC 4-0060: Failed to add route Left DAC->Left Mixer
[KERNEL] [ 3.167907] asoc: rk1000_codec <-> rk29_i2s.1 mapping ok
[KERNEL] [ 3.168227] ALSA device list:
[KERNEL] [ 3.168250] #0: RK29_RK1000
[KERNEL] [ 3.168356] GACT probability NOT on
[KERNEL] [ 3.168385] Mirror/redirect action on
[KERNEL] [ 3.168410] u32 classifier
[KERNEL] [ 3.168427] Actions configured
[KERNEL] [ 3.168450] Netfilter messages via NETLINK v0.30.
[KERNEL] [ 3.168519] nf_conntrack version 0.5.0 (13415 buckets, 53660 max)
[KERNEL] [ 3.168816] ctnetlink v0.93: registering with nfnetlink.
[KERNEL] [ 3.168880] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[KERNEL] [ 3.168922] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[KERNEL] [ 3.169230] xt_time: kernel timezone is -0000
[KERNEL] [ 3.169373] ip_tables: (C) 2000-2006 Netfilter Core Team
[KERNEL] [ 3.169527] arp_tables: (C) 2002 David S. Miller
[KERNEL] [ 3.169595] TCP cubic registered
[KERNEL] [ 3.169616] Initializing XFRM netlink socket
[KERNEL] [ 3.169967] NET: Registered protocol family 10
[KERNEL] [ 3.170594] Mobile IPv6
[KERNEL] [ 3.170633] ip6_tables: (C) 2000-2006 Netfilter Core Team
[KERNEL] [ 3.170757] IPv6 over IPv4 tunneling driver
[KERNEL] [ 3.171311] NET: Registered protocol family 17
[KERNEL] [ 3.171360] NET: Registered protocol family 15
[KERNEL] [ 3.270844] usb 1-1: New USB device found, idVendor=0403, idProduct=1234
[KERNEL] [ 3.270890] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[KERNEL] [ 3.270934] usb 1-1: Product: USB IronLogic RFID Adapter
[KERNEL] [ 3.270968] usb 1-1: Manufacturer: ILogic
[KERNEL] [ 3.270996] usb 1-1: SerialNumber: IL01R3L3
[KERNEL] [ 3.412582] Bluetooth: RFCOMM TTY layer initialized
[KERNEL] [ 3.412648] Bluetooth: RFCOMM socket layer initialized
[KERNEL] [ 3.412684] Bluetooth: RFCOMM ver 1.11
[KERNEL] [ 3.412711] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[KERNEL] [ 3.412745] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[KERNEL] [ 3.412896] NET: Registered protocol family 35
[KERNEL] [ 3.413085] [BT_RFKILL]: Enter rfkill_rk_init
[KERNEL] [ 3.413192] [BT_RFKILL]: Request irq for bt wakeup host
[KERNEL] [ 3.413236] [BT_RFKILL]: ** disable irq
[KERNEL] [ 3.436594] [BT_RFKILL]: bt shut off power
[KERNEL] [ 3.456614] usb 2-1: new high speed USB device number 2 using usb20_host
[KERNEL] [ 3.466588] [BT_RFKILL]: bt_default device registered.
[KERNEL] [ 3.466668] pmic set pm_suspend_volt:
[KERNEL] [ 3.482089] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[KERNEL] [ 3.482179] Registering SWP/SWPB emulation handler
[KERNEL] [ 3.482649] ddrfreq: verion 3.2 20131126
[KERNEL] [ 3.482678] ddrfreq: fix cpu pause bug
[KERNEL] [ 3.482703] ddrfreq: normal 456MHz video 0MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 198MHz reboot 300MHz
[KERNEL] [ 3.483491] ddrfreq: change freq to 445 MHz when normal
[KERNEL] [ 3.483834] Error: Driver 'generic-bluetooth' is already registered, aborting...
[KERNEL] [ 3.484387] rtc_hym8563 1-0051: setting system clock to 2011-01-01 12:00:00 UTC (1293883200)
[KERNEL] [ 3.485035] rk_cam_cif(3329):rk3066b-camera version: v0.3.21 Zoom by ipp
[KERNEL] [ 3.486439] asoc: dit-hifi <-> rk-spdif mapping ok
[KERNEL] [ 3.486889] usbcore: registered new interface driver snd-usb-audio
[KERNEL] [ 3.487198] Freeing init memory: 2204K
[KERNEL] [ 3.488663] ret: 0
[KERNEL] [ 3.516640] ret: 0
[KERNEL] [ 3.557017] ret: 0
[KERNEL] [ 3.559276] gp_rknand_info = : 0xde388600
[KERNEL] [ 3.559366] rk30_chip_set:1
[KERNEL] [ 3.559433] FtlInit!
[KERNEL] [ 3.559462] No.1 FLASH ID:ad de 14 a7 42 4a
[KERNEL] [ 3.562279] FTL version: 5.0.12 20140214
[KERNEL] [ 3.586654] camera 33-0-ov5640_back_3: Probe ov5640_back_3 failed
[KERNEL] [ 3.586763] ret: 0
[KERNEL] [ 3.616601] ret: 0
[KERNEL] [ 3.656867] min_w = 800,min_h = 600 ,max_real_w = 1600,max_real_h = 1200,max_w = 1600,max_h =1200
[KERNEL] [ 3.657318] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
[KERNEL] [ 3.657752] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1...
[KERNEL] [ 3.658182] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0...
[KERNEL] [ 3.658228] ov2659_front_4(rk_cam_sensor:163): write reg(0x103, val:0x1) failed, try to write again!
[KERNEL] [ 3.658672] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
[KERNEL] [ 3.659104] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1...
[KERNEL] [ 3.659536] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0...
[KERNEL] [ 3.659581] ov2659_front_4(rk_cam_sensor:163): write reg(0x103, val:0x1) failed, try to write again!
[KERNEL] [ 3.660024] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
[KERNEL] [ 3.660454] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1...
[KERNEL] [ 3.660885] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0...
[KERNEL] [ 3.660931] ov2659_front_4(rk_cam_sensor:163): write reg(0x103, val:0x1) failed, try to write again!
[KERNEL] [ 3.660986] ov2659_front_4(rk_cam_sensor:379): write array failed!
[KERNEL] [ 3.661020] ov2659_front_4(rk_cam_sensor:685): soft reset failed
[KERNEL] [ 3.661026]
[KERNEL] [ 3.667164] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101
[KERNEL] [ 3.667201] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[KERNEL] [ 3.667239] usb 2-1: Product: USB 2.0 Hub [MTT]
[KERNEL] [ 3.667562] hub 2-1:1.0: USB hub found
[KERNEL] [ 3.667659] hub 2-1:1.0: 4 ports detected
[KERNEL] [ 3.677102] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2...
[KERNEL] [ 3.677640] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1...
[KERNEL] [ 3.678178] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0...
[KERNEL] [ 3.678226] ov2659_front_4(rk_cam_sensor:329): read reg(0x300a val:0x0) failed, try to read again!
[KERNEL] [ 3.678281] ov2659_front_4(rk_cam_sensor:712): read chip id failed
[KERNEL] [ 3.678383] ret: 0
[KERNEL] [ 3.706618] camera 33-1-ov2659_front_4: Probe ov2659_front_4 failed
[KERNEL] [ 3.836131] gBootMedia = 1 gSdmmcFwPartOffset =0!
[KERNEL] [ 3.836158] rknand_buffer.c version: 4.40 20130830!
[KERNEL] [ 3.871644] 11 cmdlinepart partitions found on MTD device rk29xxnand
[KERNEL] [ 3.871680] Creating 11 MTD partitions on "rk29xxnand":
[KERNEL] [ 3.871717] 0x000000400000-0x000000800000 : "misc"
[KERNEL] [ 3.888259] 0x000000800000-0x000001400000 : "kernel"
[KERNEL] [ 3.893452] 0x000001400000-0x000002000000 : "boot"
[KERNEL] [ 3.898461] 0x000002000000-0x000004000000 : "recovery"
[KERNEL] [ 3.903820] 0x000004000000-0x000008000000 : "backup"
[KERNEL] [ 3.909041] 0x000008000000-0x000010000000 : "cache"
[KERNEL] [ 3.914144] 0x000010000000-0x000090000000 : "userdata"
[KERNEL] [ 3.919510] 0x000090000000-0x000090400000 : "metadata"
[KERNEL] [ 3.924879] 0x000090400000-0x000090800000 : "kpanic"
[KERNEL] [ 3.930867] apanic: Bound to mtd partition 'kpanic'
[KERNEL] [ 3.930897] apanic: No panic data available
[KERNEL] [ 3.930930] 0x000090800000-0x0000f0800000 : "system"
[KERNEL] [ 3.945100] 0x0000f0800000-0x0001d4000000 : "user"
[KERNEL] [ 3.960998] EXT4-fs (mtdblock9): mounted filesystem with ordered data mode. Opts:
[KERNEL] [ 3.968619]
[KERNEL] [ 3.968644]
[KERNEL] [ 7.552483] enter func vmac_open...
[KERNEL] [ 7.552548] !!!!!!!!!!11111111111111!!!!
[KERNEL] [ 7.552589] power on phy
[KERNEL] [ 7.698535] vmac_mii_bus: probed
[KERNEL] [ 7.699530] rk29 vmac rk29 vmac.0: PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1)
[KERNEL] [ 7.700666] ADDRCONF(NETDEV_UP): eth0: link is not ready
[KERNEL] [ 9.697047] PHY: 0:00 - Link is Down
[KERNEL] [ 10.699265] PHY: 0:00 - Link is Up - 100/Full
[KERNEL] [ 10.700294] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[KERNEL] [ 13.835473]
[KERNEL] [ 13.837054]
[KERNEL] [ 17.424515] enter func vmac_close...
[KERNEL] [ 17.428197] enter func vmac_open...
[KERNEL] [ 17.428237] !!!!!!!!!!11111111111111!!!!
[KERNEL] [ 17.428281] power on phy
[KERNEL] [ 17.576593] vmac_mii_bus: probed
[KERNEL] [ 17.577306] rk29 vmac rk29 vmac.0: PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1)
[KERNEL] [ 17.577843] ADDRCONF(NETDEV_UP): eth0: link is not ready
[KERNEL] [ 19.576991] PHY: 0:00 - Link is Down
[KERNEL] [ 20.579220] PHY: 0:00 - Link is Up - 100/Full
[KERNEL] [ 20.580208] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[init] Run /sbin/gm.
[init] Ok, PID 106.
[gm] WTware/RK3066 session manager v.5.4.8.
[gm] Common local disk config:
| [BOM]
| server=192.168.0.1
| serial=com4(usb 0403:1234)
| clienthostname=3
| connection
| [BOM]
| server=192.168.0.1
| clienthostname=3
| connection
[gm] Hostname: "3".
[gm] Add keyboard event1: rkxx-remotectl.
[gm] Add keyboard event0: rk29-keypad.
[init] Run /sbin/rdpdr[serial] 0.
[init] Ok, PID 107.
[init] Process pid 107 terminated, status 00007f00.
[init] Run /sbin/resolver 0xc7798 dns [192.168.0.1].
[init] Ok, PID 108.
[init] Process pid 108 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 812128 Kb.
[init] Run /sbin/rdpclient 1.
[init] Ok, PID 109.
[rdpclient 109] RDP Terminal Client, WTware v.5.4.8/RK3066, pipe 1, pid 109.
[gm] Failed to set keyboard leds.
[rdpclient 109] Make RDP session with 192.168.0.1, port 3389.
[rdpclient 109] Username: "sklad-suhoy".
[rdpclient 109] Password: present.
[rdpclient 109] No PIN.
[rdpclient 109] No domain.
[rdpclient 109] No shell.
[rdpclient 109] No directory.
[rdpclient 109] Window: 1856x1080@16.
[rdpclient 109] PFlags 0x0000002F.
[rdpclient 109] Keyboard 00000409:00000000.
[rdpclient 109] My hostname "3".
[rdpclient 109] TCP: connecting to 192.168.0.1:3389.
[init] Process pid 72 terminated, status 00000000.
[rdpclient 109] TCP: connection with 192.168.10.1:3389 established.
[rdpclient 109] Turn keepalive on.
[rdpclient 109] Free ram after buffers allocation: 811384 KB.
[rdpclient 109] Process RDP server certificate.
[rdpclient 109] RDP5 encryption (X.509).
[rdpclient 109] INFOTYPE_LOGON_PLAINNOTIFY
Re: маппинг com портов
В самом верху страницы, над твоим сообщением, оранжевую рамочку видишь? Вот это оно. Ядро не наше. Муторно это - подсовывать в чужое ядро, исходников которого у меня нет, новый модуль (драйвер). На Raspberry должно работать, там ядро наше. На рокчипе не едет.
Перенаправление USB через RDP для 2012R2 сервера понемногу начинает дышать, оно может помочь. В этом году надеюсь выложить первую экспериментальну сборку.
bannedspam
Сообщение bannedspam »
Понял, спасибо.
16.12.15 буду пробовать это же на Raspberry PI2 model B, результат напишу.
bannedspam
На Raspberry Pi2 model B тоже не заработало, пишет то же самое:
[gm] Do NOT redirect COM3.
вот лог Raspberry Pi2 model B:
WTware v.5.4.8
WTware v.5.4.8/Pi2 supervisor.
[KERNEL] [ 0.000000] Booting Linux on physical CPU 0xf00
[KERNEL] [ 0.000000] Linux version 4.1.11+ (aka@c12) (gcc version 5.2.1 20151010 (Ubuntu 5.2.1-22ubuntu1) ) #30 SMP PREEMPT Mon Dec 7 12:56:59 SAMT 2015
[KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[KERNEL] [ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[KERNEL] [ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[KERNEL] [ 0.000000] Memory policy: Data cache writealloc
[KERNEL] [ 0.000000] On node 0 totalpages: 241664
[KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80822240, node_mem_map ba092000
[KERNEL] [ 0.000000] Normal zone: 1888 pages used for memmap
[KERNEL] [ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] enter (93c0->f3003010)
[KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[KERNEL] [ 0.000000] PERCPU: Embedded 10 pages/cpu @ba05c000 s10688 r8192 d22080 u40960
[KERNEL] [ 0.000000] pcpu-alloc: s10688 r8192 d22080 u40960 alloc=10*4096
[KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239776
[KERNEL] [ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa21041 bcm2709.serial=0xc1ea1d60 smsc95xx.macaddr=B8:27:EB:EA:1D:60 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 console=ttyAMA0,115200 console=tty1 quiet wtboot=mmc
[KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[KERNEL] [ 0.000000] Memory: 941176K/966656K available (3339K kernel code, 259K rwdata, 1068K rodata, 3632K init, 346K bss, 17288K reserved, 8192K cma-reserved)
[KERNEL] [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[KERNEL] [ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[KERNEL] [ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
[KERNEL] [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[KERNEL] [ 0.000000] .text : 0x80008000 - 0x80455fc4 (4408 kB)
[KERNEL] [ 0.000000] .init : 0x80456000 - 0x807e2000 (3632 kB)
[KERNEL] [ 0.000000] .data : 0x807e2000 - 0x80822e78 ( 260 kB)
[KERNEL] [ 0.000000] .bss : 0x80825000 - 0x8087bba8 ( 347 kB)
[KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[KERNEL] [ 0.000000] NR_IRQS:608
[KERNEL] [ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[KERNEL] [ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[KERNEL] [ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[KERNEL] [ 0.000029] Switching to timer-based delay loop, resolution 52ns
[KERNEL] [ 0.000227] Console: colour dummy device 80x30
[KERNEL] [ 0.000430] console [tty1] enabled
[KERNEL] [ 0.000457] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[KERNEL] [ 0.000478] pid_max: default: 32768 minimum: 301
[KERNEL] [ 0.000614] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[KERNEL] [ 0.000632] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[KERNEL] [ 0.001635] CPU: Testing write buffer coherency: ok
[KERNEL] [ 0.002182] CPU0: update cpu_capacity 1024
[KERNEL] [ 0.002202] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[KERNEL] [ 0.002215] [bcm2709_smp_prepare_cpus] enter
[KERNEL] [ 0.002309] Setting up static identity map for 0x8240 - 0x8274
[KERNEL] [ 0.060287] [bcm2709_boot_secondary] cpu:1 started (0) 18
[KERNEL] [ 0.060652] [bcm2709_secondary_init] enter cpu:1
[KERNEL] [ 0.060701] CPU1: update cpu_capacity 1024
[KERNEL] [ 0.060709] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[KERNEL] [ 0.080234] [bcm2709_boot_secondary] cpu:2 started (0) 16
[KERNEL] [ 0.080515] [bcm2709_secondary_init] enter cpu:2
[KERNEL] [ 0.080543] CPU2: update cpu_capacity 1024
[KERNEL] [ 0.080551] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[KERNEL] [ 0.100274] [bcm2709_boot_secondary] cpu:3 started (0) 16
[KERNEL] [ 0.100529] [bcm2709_secondary_init] enter cpu:3
[KERNEL] [ 0.100556] CPU3: update cpu_capacity 1024
[KERNEL] [ 0.100564] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[KERNEL] [ 0.100637] Brought up 4 CPUs
[KERNEL] [ 0.100664] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[KERNEL] [ 0.100674] CPU: All CPU(s) started in HYP mode.
[KERNEL] [ 0.100683] CPU: Virtualization extensions available.
[KERNEL] [ 0.101308] devtmpfs: initialized
[KERNEL] [ 0.123286] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[KERNEL] [ 0.123873] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[KERNEL] [ 0.124379] pinctrl core: initialized pinctrl subsystem
[KERNEL] [ 0.124945] NET: Registered protocol family 16
[KERNEL] [ 0.130433] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[KERNEL] [ 0.131470] bcm2709.uart_clock = 3000000
[KERNEL] [ 0.138578] Serial: AMBA PL011 UART driver
[KERNEL] [ 0.138768] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[KERNEL] [ 0.139117] console [ttyAMA0] enabled
[KERNEL] [ 0.139781] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[KERNEL] [ 0.211776] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[KERNEL] [ 0.211824] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[KERNEL] [ 0.213012] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[KERNEL] [ 0.213033] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[KERNEL] [ 0.213696] usbcore: registered new interface driver usbfs
[KERNEL] [ 0.213874] usbcore: registered new interface driver hub
[KERNEL] [ 0.214078] usbcore: registered new device driver usb
[KERNEL] [ 0.214666] raspberrypi-firmware soc:firmware: Attached to firmware from 2015-10-23 16:24
[KERNEL] [ 0.242893] Switched to clocksource arch_sys_counter
[KERNEL] [ 0.260333] NET: Registered protocol family 2
[KERNEL] [ 0.261256] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[KERNEL] [ 0.261396] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[KERNEL] [ 0.261588] TCP: Hash tables configured (established 8192 bind 8192)
[KERNEL] [ 0.261707] UDP hash table entries: 512 (order: 2, 16384 bytes)
[KERNEL] [ 0.261772] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[KERNEL] [ 0.262070] NET: Registered protocol family 1
[KERNEL] [ 2.589439] futex hash table entries: 1024 (order: 4, 65536 bytes)
[KERNEL] [ 2.589636] audit: initializing netlink subsys (disabled)
[KERNEL] [ 2.589739] audit: type=2000 audit(2.579:1): initialized
[KERNEL] [ 2.646754] alg: No test for stdrng (krng)
[KERNEL] [ 2.647740] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[KERNEL] [ 2.647766] io scheduler noop registered
[KERNEL] [ 2.647818] io scheduler cfq registered (default)
[KERNEL] [ 2.650476] BCM2708FB: allocated DMA memory fac00000
[KERNEL] [ 2.650538] BCM2708FB: allocated DMA channel 0 @ f3007000
[KERNEL] [ 2.686158] Console: switching to colour frame buffer device 240x67
[KERNEL] [ 2.708738] bcm2708_rng_init=bb906000
[KERNEL] [ 3.598977] vc-cma: Videocore CMA driver
[KERNEL] [ 3.599003] vc-cma: vc_cma_base = 0x00000000
[KERNEL] [ 3.599017] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[KERNEL] [ 3.599028] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[KERNEL] [ 3.599380] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[KERNEL] [ 3.601233] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[KERNEL] [ 3.607431] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[KERNEL] [ 3.807795] Core Release: 2.80a
[KERNEL] [ 3.807826] Setting default values for core params
[KERNEL] [ 3.807867] Finished setting default values for core params
[KERNEL] [ 4.008340] Using Buffer DMA mode
[KERNEL] [ 4.008364] Periodic Transfer Interrupt Enhancement - disabled
[KERNEL] [ 4.008374] Multiprocessor Interrupt Enhancement - disabled
[KERNEL] [ 4.008385] OTG VER PARAM: 0, OTG VER FLAG: 0
[KERNEL] [ 4.008402] Dedicated Tx FIFOs mode
[KERNEL] [ 4.008924] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[KERNEL] [ 4.008964] FIQ FSM acceleration enabled for :
[KERNEL] [ 4.008964] Non-periodic Split Transactions
[KERNEL] [ 4.008964] Periodic Split Transactions
[KERNEL] [ 4.008964] High-Speed Isochronous Endpoints
[KERNEL] [ 4.008989] dwc_otg: Microframe scheduler enabled
[KERNEL] [ 4.009055] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80216818
[KERNEL] [ 4.009073] WARN::hcd_init_fiq:413: FIQ ASM at 0x80216b7c length 36
[KERNEL] [ 4.009091] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb908000
[KERNEL] [ 4.009136] dwc_otg 3f980000.usb: DWC OTG Controller
[KERNEL] [ 4.009188] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[KERNEL] [ 4.009234] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[KERNEL] [ 4.009286] Init: Port Power? op_state=1
[KERNEL] [ 4.009296] Init: Power Port (0)
[KERNEL] [ 4.009538] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[KERNEL] [ 4.009558] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[KERNEL] [ 4.009573] usb usb1: Product: DWC OTG Controller
[KERNEL] [ 4.009588] usb usb1: Manufacturer: Linux 4.1.11+ dwc_otg_hcd
[KERNEL] [ 4.009602] usb usb1: SerialNumber: 3f980000.usb
[KERNEL] [ 4.010707] hub 1-0:1.0: USB hub found
[KERNEL] [ 4.010799] hub 1-0:1.0: 1 port detected
[KERNEL] [ 4.011573] dwc_otg: FIQ enabled
[KERNEL] [ 4.011592] dwc_otg: NAK holdoff enabled
[KERNEL] [ 4.011602] dwc_otg: FIQ split-transaction FSM enabled
[KERNEL] [ 4.011654] Module dwc_common_port init
[KERNEL] [ 4.012815] bcm2835-cpufreq: min=600000 max=900000
[KERNEL] [ 4.015715] hidraw: raw HID events driver (C) Jiri Kosina
[KERNEL] [ 4.017528] usbcore: registered new interface driver usbhid
[KERNEL] [ 4.017545] usbhid: USB HID core driver
[KERNEL] [ 4.017792] NET: Registered protocol family 17
[KERNEL] [ 4.018086] Registering SWP/SWPB emulation handler
[KERNEL] [ 4.019176] registered taskstats version 1
[KERNEL] [ 4.019271] vc-sm: Videocore shared memory driver
[KERNEL] [ 4.019287] [vc_sm_connected_init]: start
[KERNEL] [ 4.027018] [vc_sm_connected_init]: end - returning 0
[KERNEL] [ 4.032549] Freeing unused kernel memory: 3632K (80456000 - 807e2000)
[KERNEL] [ 4.203027] Indeed it is in host mode hprt0 = 00021501
[pfac] Ok, PID 492.
[initrd] WTware shell v.5.4.8/Pi2
[initrd] Local media boot.
[KERNEL] [ 4.382952] usb 1-1: new high-speed USB device number 2 using dwc_otg
[KERNEL] [ 4.383101] Indeed it is in host mode hprt0 = 00001101
[initrd] USB boot.
[KERNEL] [ 4.583144] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[KERNEL] [ 4.583163] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[KERNEL] [ 4.583811] hub 1-1:1.0: USB hub found
[KERNEL] [ 4.583933] hub 1-1:1.0: 5 ports detected
[KERNEL] [ 4.862933] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[KERNEL] [ 4.963247] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[KERNEL] [ 4.963271] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[KERNEL] [ 5.042949] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[KERNEL] [ 5.173195] usb 1-1.2: New USB device found, idVendor=0403, idProduct=1234
[KERNEL] [ 5.173217] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[KERNEL] [ 5.173233] usb 1-1.2: Product: USB IronLogic RFID Adapter
[KERNEL] [ 5.173248] usb 1-1.2: Manufacturer: ILogic
[KERNEL] [ 5.173264] usb 1-1.2: SerialNumber: IL01R3L3
[KERNEL] [ 5.262934] usb 1-1.4: new low-speed USB device number 5 using dwc_otg
[KERNEL] [ 5.381345] usb 1-1.4: New USB device found, idVendor=1c4f, idProduct=0026
[KERNEL] [ 5.381367] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[KERNEL] [ 5.381383] usb 1-1.4: Product: USB Keyboard
[KERNEL] [ 5.381398] usb 1-1.4: Manufacturer: SIGMACHIP
[KERNEL] [ 5.393180] input: SIGMACHIP USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:1C4F:0026.0001/input/input0
[KERNEL] [ 5.453533] hid-generic 0003:1C4F:0026.0001: input,hidraw0: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-3f980000.usb-1.4/input0
[KERNEL] [ 5.464945] input: SIGMACHIP USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:1C4F:0026.0002/input/input1
[KERNEL] [ 5.523492] hid-generic 0003:1C4F:0026.0002: input,hidraw1: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-3f980000.usb-1.4/input1
[KERNEL] [ 5.602957] usb 1-1.5: new low-speed USB device number 6 using dwc_otg
[KERNEL] [ 5.731091] usb 1-1.5: New USB device found, idVendor=0458, idProduct=003a
[KERNEL] [ 5.731148] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[KERNEL] [ 5.731171] usb 1-1.5: Manufacturer: Genius
[KERNEL] [ 5.742657] input: Genius as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:0458:003A.0003/input/input2
[KERNEL] [ 5.743240] hid-generic 0003:0458:003A.0003: input,hidraw2: USB HID v1.10 Mouse [Genius] on usb-3f980000.usb-1.5/input0
[initrd] Load MMC driver.
[initrd] modprobe mmc_block.
[initrd] modprobe bcm2835-mmc.
[KERNEL] [ 5.786942] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[KERNEL] [ 5.786972] mmc-bcm2835 3f300000.mmc: Forcing PIO mode
[KERNEL] [ 5.860346] mmc0: host does not support reading read-only switch, assuming write-enable
[KERNEL] [ 5.862491] mmc0: new high speed SDHC card at address 1234
[KERNEL] [ 5.863457] mmcblk0: mmc0:1234 SA04G 3.70 GiB
[KERNEL] [ 5.864948] mmcblk0: p1
[hotplug] Block device 179:1. No action.
[hotplug] Block device 179:0. No action.
| clientIP = 192.168.0.4
| netmask = 255.255.255.0
| routerIP = 192.168.0.1
| nameserverIP = 192.168.0.1
| config = local
[initrd] modprobe smsc95xx.
[KERNEL] [ 6.686572] smsc95xx v1.0.4
[KERNEL] [ 6.747301] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:ea:1d:60
[KERNEL] [ 6.747702] usbcore: registered new interface driver smsc95xx
[KERNEL] [ 6.805500] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[KERNEL] [ 8.248570] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
| [BOM]
| server=192.168.0.1
| connection
| [BOM]
| server=192.168.0.1
| connection
[initrd] Hostname: "wtwB827EBEA1D60".
[gm] WTware session manager v.5.4.8/Pi2.
[gm] EV_REL flag found. Add mouse event2: Genius.
[gm] Add keyboard event1: SIGMACHIP USB Keyboard.
[gm] Add keyboard event0: SIGMACHIP USB Keyboard.
[gm] Display mode: 1920x1080, 16 bit, 0 Hz, modeline "", DDC enabled, connector 0.
[gm] Framebuffer device found.
[gm] LINELENBYTES 3840
[gm] VLEN 4147200
[pfac] Got command line /sbin/rdpdr[serial] 0.
[pfac] Ok, PID 561.
[rdpdr-serial 0] RDP Serial Port Redirector, WTware v.5.4.8/Pi2, device ttyUSB0.
[KERNEL] [ 8.458701] usbcore: registered new interface driver usbserial
[KERNEL] [ 8.458807] usbcore: registered new interface driver usbserial_generic
[KERNEL] [ 8.458898] usbserial: USB Serial support registered for generic
[KERNEL] [ 8.470151] usbcore: registered new interface driver pl2303
[KERNEL] [ 8.470342] usbserial: USB Serial support registered for pl2303
[KERNEL] [ 8.483577] usbcore: registered new interface driver ftdi_sio
[KERNEL] [ 8.483783] usbserial: USB Serial support registered for FTDI USB Serial Device
[KERNEL] [ 8.494249] usbcore: registered new interface driver cp210x
[KERNEL] [ 8.494366] usbserial: USB Serial support registered for cp210x
[KERNEL] [ 8.504131] usbcore: registered new interface driver ch341
[KERNEL] [ 8.504346] usbserial: USB Serial support registered for ch341-uart
[KERNEL] [ 8.513996] usbcore: registered new interface driver metro_usb
[KERNEL] [ 8.514116] usbserial: USB Serial support registered for Metrologic USB to Serial
[KERNEL] [ 8.523952] usbcore: registered new interface driver symbolserial
[KERNEL] [ 8.524162] usbserial: USB Serial support registered for symbol
[KERNEL] [ 8.533735] usbcore: registered new interface driver opticon
[KERNEL] [ 8.533868] usbserial: USB Serial support registered for opticon
[pfac] Got command line /sbin/resolver 0x860970 dns [192.168.0.1].
[pfac] Ok, PID 604.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 927232 Kb.
[pfac] Process pid 604 terminated, status 00000000.
[pfac] Ok, PID 606.
[rdpclient 606] RDP Terminal Client, WTware v.5.4.8/Pi2, pipe 1, pid 606.
[rdpclient 606] Make RDP session with 192.168.0.1, port 3389.
[rdpclient 606] No username.
[rdpclient 606] No password.
[rdpclient 606] No PIN.
[rdpclient 606] No domain.
[rdpclient 606] No shell.
[rdpclient 606] No directory.
[rdpclient 606] Window: 1920x1080@16.
[rdpclient 606] PFlags 0x0000002F.
[rdpclient 606] Keyboard 00000409:00000000.
[rdpclient 606] My hostname "4".
[rdpclient 606] TCP: connecting to 192.168.0.1:3389.
[rdpclient 606] TCP: connection with 192.168.0.1:3389 established.
[rdpclient 606] Turn keepalive on.
[rdpclient 606] Free ram after buffers allocation: 926784 KB.
[rdpclient 606] Process RDP server certificate.
[rdpclient 606] RDP5 encryption (X.509).
[KERNEL] [ 8.617293] random: rdpclient urandom read with 119 bits of entropy available
[KERNEL] [ 9.229514] random: nonblocking pool is initialized
Загадочно.
Напиши так:
serial=com3(usb)
Что будет?
И вот это попробуй:
http://pxe.ru/files/testing/201512220322.zip
Странно. Вроде всё правильно, железку на USB видит, драйвер взлетает.
Не мапится, в конце говорит:
[rdpclient 605] RDP Terminal Client, WTware v.5.4.8/Pi2, pipe 1, pid 605.
[rdpclient 605] Add serial redirection, COM3 in the session = hardware ttyUSB0.
[rdpdr-serial 0] New client connection, id 1.
[rdpclient 605] Make RDP session with 192.168.0.1, port 3389.
[rdpclient 605] Username: "user".
[rdpclient 605] No password.
[rdpclient 605] No PIN.
[rdpclient 605] Domain: "domain".
[rdpclient 605] No shell.
[rdpclient 605] No directory.
[rdpclient 605] Window: 1360x768@16.
[rdpclient 605] PFlags 0x0000002F.
[rdpclient 605] Keyboard 00000409:00000000.
[rdpclient 605] My hostname "4".
[rdpclient 605] TCP: connecting to 192.168.0.1:3389.
[rdpclient 605] TCP: connection with 192.168.0.1:3389 established.
[rdpclient 605] Turn keepalive on.
[rdpclient 605] Free ram after buffers allocation: 928640 KB.
[rdpclient 605] Process RDP server certificate.
[rdpclient 605] RDP5 encryption (X.509).
[KERNEL] [ 8.253482] random: rdpclient urandom read with 114 bits of entropy available
[KERNEL] [ 9.393221] random: nonblocking pool is initialized
[rdpclient 605] SessionId 0x00000005: DOMAIN\user.
[rdpdr-serial 0] rdpdr[serial]-worker.cpp ( 626): -- ERROR -- Failed to open /dev/ttyUSB0, errno 2.
bannedspam
на http://pxe.ru/files/testing/201512220322.zip та же ошибка:
[rdpclient 609] [ 60.673968] RDP Terminal Client, WTware v.5.4.9/Pi2, pipe 1, pid 609.
[ gm] [ 60.674524] COM3 => ttyUSB0.
[rdpclient 609] [ 60.676191] Add serial redirection, COM3 in the session = hardware ttyUSB0.
[rdpdr-serial 0] [ 60.676715] New client connection, id 1.
[rdpclient 609] [ 60.676993] Make RDP session with 192.168.0.1, port 3389.
[rdpclient 609] [ 60.677119] No username.
[rdpclient 609] [ 60.677232] No password.
[rdpclient 609] [ 60.677341] No PIN.
[rdpclient 609] [ 60.677451] No domain.
[rdpclient 609] [ 60.677562] No shell.
[rdpclient 609] [ 60.677671] No directory.
[rdpclient 609] [ 60.677781] Window: 1920x1080@16.
[rdpclient 609] [ 60.677936] PFlags 0x0000002F.
[rdpclient 609] [ 60.678051] Keyboard 00000409:00000000.
[rdpclient 609] [ 60.678158] My hostname "4".
[rdpclient 609] [ 60.678271] TCP: connecting to 192.168.0.1:3389.
[rdpclient 609] [ 60.679196] TCP: connection with 192.168.0.1:3389 established.
[rdpclient 609] [ 60.679350] Turn keepalive on.
[rdpclient 609] [ 60.680457] Free ram after buffers allocation: 926304 KB.
[rdpclient 609] [ 60.682019] Process RDP server certificate.
[rdpclient 609] [ 60.682179] RDP5 encryption (X.509).
[rdpclient 609] [ 67. 38603] SessionId 0x00000005: DOMAIN\user.
[rdpdr-serial 0] [ 76.369087] rdpdr[serial]-worker.cpp ( 626): -- ERROR -- Failed to open /dev/ttyUSB0, errno 2.
bannedspam
http://pxe.ru/files/testing/201512230014.zip - отлично работает! ...и мапится, и данные передаются, и ошибок нет, все ок, спасибо!
Вернуться в «О версиях WTware на ARM»
