Проблема с Transcend JF V10
Проблемка в следующем - после обновления WT до последней версии перестали работать данные флешки (на старой версии данные флешки работали).
Так же есть Transcend JF V30 аналогичного размера, они работали и работают!
Флешка совместима с Linux/FreeBSD системами, форматить пробовал...
Help Please!!
ЛОГ:
KERNEL: usb 5-1: new high speed USB device using ehci_hcd and address 2
KERNEL: usb 5-1: configuration #1 chosen from 1 choice
KERNEL: scsi0 : SCSI emulation for USB Mass Storage devices
KERNEL: usb-storage: device found at 2
KERNEL: usb-storage: waiting for device to settle before scanning
KERNEL: scsi scan: INQUIRY result too short (5), using 36
KERNEL: scsi 0:0:0:0: Direct-Access PQ: 0 ANSI: 0
KERNEL: sd 0:0:0:0: [sda] Sector size 0 reported, assuming 512.
KERNEL: sd 0:0:0:0: [sda] 1 512-byte hardware sectors (0 MB)
KERNEL: sd 0:0:0:0: [sda] Write Protect is off
KERNEL: sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
KERNEL: sd 0:0:0:0: [sda] Assuming drive cache: write through
KERNEL: sda: sda1
KERNEL: sda: p1 exceeds device capacity
hotplug: R/w mount ("/dev/sda1", "/mnt/usb-hotplug/1",..) failed, errno 16.
hotplug: R/o mount ("/dev/sda1", "/mnt/usb-hotplug/1",..) failed, errno 16.
KERNEL: FAT: invalid media value (0x00)
KERNEL: VFS: Can't find a valid FAT filesystem on dev sda.
hotplug: R/w mount ("/dev/sda", "/mnt/usb-hotplug/0",..) failed, errno 22.
KERNEL: sd 0:0:0:0: [sda] Attached SCSI disk
KERNEL: usb-storage: device scan complete
hotplug: R/o mount ("/dev/sda", "/mnt/usb-hotplug/0",..) failed, errno 22.
init: Iteration, free RAM 465204 Kb
KERNEL: usb 5-1: USB disconnect, address 2
Help Please!!
ЛОГ:
KERNEL: sda: sda1
Re: Проблема с Transcend JF V10
Вот ЛОГ с Transcend JF V30 Если интересно
KERNEL: usb 5-1: new high speed USB device using ehci_hcd and address 3
KERNEL: scsi1 : SCSI emulation for USB Mass Storage devices
KERNEL: usb-storage: device found at 3
init: Iteration, free RAM 465196 Kb
KERNEL: scsi 1:0:0:0: Direct-Access JetFlash TS2GJFV30 0.00 PQ: 0 ANSI: 2
KERNEL: sd 1:0:0:0: [sda] 4096000 512-byte hardware sectors (2097 MB)
KERNEL: sd 1:0:0:0: [sda] Write Protect is off
KERNEL: sd 1:0:0:0: [sda] Mode Sense: 00 00 00 00
KERNEL: sd 1:0:0:0: [sda] Assuming drive cache: write through
KERNEL: sda: sda1
KERNEL: sd 1:0:0:0: [sda] Attached SCSI removable disk
KERNEL: FAT: invalid media value (0x01)
hotplug: R/o mount ("/dev/sda", "/mnt/usb-hotplug/0",..) failed, errno 16.
hotplug: Success: USB1p1 mounted.
KERNEL: usb 5-1: USB disconnect, address 3
hotplug: /dev/sda1 unmounted from /mnt/usb-hotplug/1.
KERNEL: sda: sda1
shdn777
+1 тоже самое случилось
при обновении на 4.5.14 такая же флешка перестала работать при откате не 4.4.15 опять заработало
4.4.15 - линуксовое ядро 2.4.36, видит флэшку корректно:
4.5.14 - линуксовое ядро 2.6.26, ругается и видит фигню:KERNEL: sd 1:0:0:0: [sda] 4096000 512-byte hardware sectors (2097 MB)
Отсюда вопросы: с каким из свежих линуксов флэшка работает? Можно ли из этих линуксов выковырять то, что скажет dmesg (на этом же компе, на котором не работает втварь) и выложить сюда?KERNEL: scsi scan: INQUIRY result too short (5), using 36
Работает с wt 4.4.15 - линуксовое ядро 2.4.36shdn777 писал(а):Отсюда вопросы: с каким из свежих линуксов флэшка работает? Можно ли из этих линуксов выковырять то, что скажет dmesg (на этом же компе, на котором не работает втварь) и выложить сюда?
У меня нет ни одного линуха, все машины терминалки, но если надо могу поставить
Это ты писал:
"Ставить" это сурово, можно какой-нибудь свежий liveCD запустить и посмотреть...
Откуда известно, что совместима?Флешка совместима с Linux
В мануале к флешке написанно что она работает Линухе.
Ладно поищу Live CD
Отпишусть по рез-там
Ладно поищу Live CD
Knoppix 5.3.1 ядро Linux 2.6.24.4
Определил и нормально заработал с флешкой
Вот dmesg
usb 1-7: new high speed USB device using ehci_hcd and address 2
usb 1-7: configuration #1 chosen from 1 choice
scsi2 : SCSI emulation for USB Mass Storage devices
scsi 2:0:0:0: Direct-Access JetFlash TS2GJFV10 8.07 PQ: 0 ANSI: 2
sd 2:0:0:0: [sda] 3969024 512-byte hardware sectors (2032 MB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Mode Sense: 03 00 00 00
sd 2:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 2:0:0:0: [sda] Attached SCSI removable disk
Вот dmesg
sda: sda1
О, теперь понял. Например, вот: http://marc.info/?l=linux-scsi&m=121665349905101&w=2
http://pxe.ru/files/testing/200810040000/
Номер версии совсем левый, поэтому папку tftpdroot/pro/8.8.7 надо будет после экспериментов удалить.
Гугл еще кучку похожих нашел. Похоже на глюк именно в 2.6.26 ядре. 2.6.27 официально еще не готова, поэтому аккуратно попробуйте вот это:I'm seeing exactly the same failure with a JetFlash 2GB
USB stick. Works fine with production Ubuntu 8.04 and
Fedora 9 (latest updates) but fails as shown above in
lk 2.6.26 .
Big Thanks!!
Настроил только у конкретных юзеров кот. пользуют данную флеш, все работает!
Будем тестить
Будем тестить
