Проблема с загрузкой терминала
Andrey_B
Сообщение Andrey_B »
Здравствуйте.
Не могу загрузить один терминал.
Лог:
[DHCP] Processing DHCPDISCOVER package...
[DHCP] Determine IP...
[DHCP] IP 192.168.0.215 for MAC 00:11:5B:37:30:EB determined from terminalDHCP parameters.
[DHCP] Sending ARP to check if IP is busy...
[DHCP] Send DHCPOFFER.
[DHCP] Processing DHCPREQUEST package...
[DHCP] Stored in catalog IP 192.168.0.215 for MAC 00:11:5B:37:30:EB
[DHCP] Send DHCPACK.
[TFTP] Got RRQ, 32 bytes.
[TFTP] 00000000: 34 2e 39 2e 32 37 5c 77 74 77 61 72 65 2e 70 78
[TFTP] 00000010: 65 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00
[TFTP] Requests file "4.9.27\wtware.pxe". Tsize is requested, blksize default.
[TFTP] Sending OASK (tsize 16282).
[TFTP] Received opcode 5.
[TFTP] 00000000: 00 05 00 00 54 46 54 50 20 41 62 6f 72 74 65 64
[TFTP] 00000010: 00
[TFTP] Got RRQ, 37 bytes.
[TFTP] 00000010: 65 00 6f 63 74 65 74 00 62 6c 6b 73 69 7a 65 00
[TFTP] 00000020: 31 34 35 36 00
[TFTP] Request block size 1456, forced to 1240.
[TFTP] Requests file "4.9.27\wtware.pxe". Tsize is not requested, blksize 1240 bytes.
[TFTP] Sending OASK (blksize 1240).
[TFTP] Transfer of file "4.9.27\wtware.pxe" completed.
[TFTP] Connection closed.
[TFTP] Got RRQ, 71 bytes.
[TFTP] 00000000: 34 2e 39 2e 32 37 5c 66 66 66 66 66 66 66 66 2d
[TFTP] 00000010: 66 66 66 66 2d 66 66 66 66 2d 66 66 66 66 2d 66
[TFTP] 00000020: 66 66 66 66 66 66 66 66 66 66 66 00 6f 63 74 65
[TFTP] 00000030: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
[TFTP] 00000040: 65 00 31 34 30 38 00
[TFTP] Request block size 1408, forced to 1240.
[TFTP] Requests file "4.9.27\ffffffff-ffff-ffff-ffff-ffffffffffff". Tsize is requested, blksize 1240 bytes.
[TFTP] Requested file "C:\Program Files\WTware\TFTPDROOT\4.9.27\ffffffff-ffff-ffff-ffff-ffffffffffff" not found.
[TFTP] Got RRQ, 55 bytes.
[TFTP] 00000000: 34 2e 39 2e 32 37 5c 30 31 2d 30 30 2d 31 31 2d
[TFTP] 00000010: 35 62 2d 33 37 2d 33 30 2d 65 62 00 6f 63 74 65
[TFTP] 00000020: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
[TFTP] 00000030: 65 00 31 34 30 38 00
[TFTP] Requests file "4.9.27\01-00-11-5b-37-30-eb". Tsize is requested, blksize 1240 bytes.
[TFTP] Requested file "C:\Program Files\WTware\TFTPDROOT\4.9.27\01-00-11-5b-37-30-eb" not found.
[TFTP] Got RRQ, 43 bytes.
[TFTP] 00000000: 34 2e 39 2e 32 37 5c 43 30 41 38 30 30 44 37 00
[TFTP] 00000010: 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c
[TFTP] 00000020: 6b 73 69 7a 65 00 31 34 30 38 00
[TFTP] Requests file "4.9.27\C0A800D7". Tsize is requested, blksize 1240 bytes.
[TFTP] Requested file "C:\Program Files\WTware\TFTPDROOT\4.9.27\C0A800D7" not found.
[TFTP] Got RRQ, 42 bytes.
[TFTP] 00000000: 34 2e 39 2e 32 37 5c 43 30 41 38 30 30 44 00 6f
[TFTP] 00000010: 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b
[TFTP] 00000020: 73 69 7a 65 00 31 34 30 38 00
[TFTP] Requests file "4.9.27\C0A800D". Tsize is requested, blksize 1240 bytes.
[TFTP] Requested file "C:\Program Files\WTware\TFTPDROOT\4.9.27\C0A800D" not found.
[TFTP] Got RRQ, 41 bytes.
[TFTP] 00000000: 34 2e 39 2e 32 37 5c 43 30 41 38 30 30 00 6f 63
[TFTP] 00000010: 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73
[TFTP] 00000020: 69 7a 65 00 31 34 30 38 00
[TFTP] Requests file "4.9.27\C0A800". Tsize is requested, blksize 1240 bytes.
[TFTP] Requested file "C:\Program Files\WTware\TFTPDROOT\4.9.27\C0A800" not found.
[TFTP] Got RRQ, 40 bytes.
[TFTP] 00000000: 34 2e 39 2e 32 37 5c 43 30 41 38 30 00 6f 63 74
[TFTP] 00000010: 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69
[TFTP] 00000020: 7a 65 00 31 34 30 38 00
[TFTP] Requests file "4.9.27\C0A80". Tsize is requested, blksize 1240 bytes.
[TFTP] Requested file "C:\Program Files\WTware\TFTPDROOT\4.9.27\C0A80" not found.
[TFTP] Got RRQ, 39 bytes.
[TFTP] 00000000: 34 2e 39 2e 32 37 5c 43 30 41 38 00 6f 63 74 65
[TFTP] 00000010: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
[TFTP] 00000020: 65 00 31 34 30 38 00
[TFTP] Requests file "4.9.27\C0A8". Tsize is requested, blksize 1240 bytes.
[TFTP] Requested file "C:\Program Files\WTware\TFTPDROOT\4.9.27\C0A8" not found.
[TFTP] Got RRQ, 38 bytes.
[TFTP] 00000000: 34 2e 39 2e 32 37 5c 43 30 41 00 6f 63 74 65 74
[TFTP] 00000010: 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65
[TFTP] 00000020: 00 31 34 30 38 00
[TFTP] Requests file "4.9.27\C0A". Tsize is requested, blksize 1240 bytes.
[TFTP] Requested file "C:\Program Files\WTware\TFTPDROOT\4.9.27\C0A" not found.
[TFTP] 00000000: 34 2e 39 2e 32 37 5c 43 30 00 6f 63 74 65 74 00
[TFTP] 00000010: 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00
[TFTP] 00000020: 31 34 30 38 00
[TFTP] Requests file "4.9.27\C0". Tsize is requested, blksize 1240 bytes.
[TFTP] Requested file "C:\Program Files\WTware\TFTPDROOT\4.9.27\C0" not found.
[TFTP] Got RRQ, 36 bytes.
[TFTP] 00000000: 34 2e 39 2e 32 37 5c 43 00 6f 63 74 65 74 00 74
[TFTP] 00000010: 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31
[TFTP] 00000020: 34 30 38 00
[TFTP] Requests file "4.9.27\C". Tsize is requested, blksize 1240 bytes.
[TFTP] Requested file "C:\Program Files\WTware\TFTPDROOT\4.9.27\C" not found.
[TFTP] 00000000: 34 2e 39 2e 32 37 5c 70 78 65 2e 63 66 67 00 6f
[TFTP] Requests file "4.9.27\pxe.cfg". Tsize is requested, blksize 1240 bytes.
[TFTP] Sending OASK (tsize 233, blksize 1240).
[TFTP] Transfer of file "4.9.27\pxe.cfg" completed.
[TFTP] Got RRQ, 50 bytes.
[TFTP] 00000000: 34 2e 39 2e 32 37 5c 70 61 63 6b 61 67 65 73 2f
[TFTP] 00000010: 6b 65 72 6e 65 6c 00 6f 63 74 65 74 00 74 73 69
[TFTP] 00000020: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
[TFTP] 00000030: 38 00
[TFTP] Requests file "4.9.27\packages\kernel". Tsize is requested, blksize 1240 bytes.
[TFTP] Sending OASK (tsize 1613232, blksize 1240).
[TFTP] Transfer of file "4.9.27\packages\kernel" completed.
[TFTP] 00000010: 69 6e 69 74 72 64 00 6f 63 74 65 74 00 74 73 69
[TFTP] Requests file "4.9.27\packages\initrd". Tsize is requested, blksize 1240 bytes.
[TFTP] Sending OASK (tsize 3972204, blksize 1240).
[TFTP] Transfer of file "4.9.27\packages\initrd" completed.
[TFTP] Timeout occured while transfer "4.9.27\wtware.pxe".
[TFTP] Client not responding. Connection closed.
Re: Проблема с загрузкой терминала
Хороший лог.
1. На экране что?
2. Железо какое? Мать, процессор, память.
3. Почему ты считаешь, что железо исправно?
