Сбербанк онлайн и ключ АМИКОН VPNKey-TLS
ameelien
Сообщение ameelien »
Сегодня с радостью припёрли ключ ВПН, для сбербанка онлайн с названием "AMICON PNKEY-TLS MSC"
Не могу его заставить работать, так как "смарткарта" не пробрасывается, ибо я не могу его определить сей девайс:
[KERNEL] [25609.541163] usb 2-3: new full-speed USB device number 6 using ohci-pci
[KERNEL] [25609.727884] usb 2-3: New USB device found, idVendor=2022, idProduct=0139
[KERNEL] [25609.727909] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[KERNEL] [25609.727928] usb 2-3: Product: HWDSSL DEVICE
[KERNEL] [25609.727946] usb 2-3: Manufacturer: Infocrypt
[KERNEL] [25609.732189] usb-storage 2-3:1.0: USB Mass Storage device detected
[KERNEL] [25609.736392] scsi2 : usb-storage 2-3:1.0
[KERNEL] [25610.749051] scsi 2:0:0:0: Direct-Access AMICON PNKEY-TLS MSC 1.00 PQ: 0 ANSI: 3
[KERNEL] [25610.765028] sd 2:0:0:0: [sda] 872 512-byte logical blocks: (446 kB/436 KiB)
[KERNEL] [25610.775046] sd 2:0:0:0: [sda] Write Protect is on
[KERNEL] [25610.775078] sd 2:0:0:0: [sda] Mode Sense: 0f 00 80 00
[KERNEL] [25610.785005] sd 2:0:0:0: [sda] No Caching mode page found
[KERNEL] [25610.785032] sd 2:0:0:0: [sda] Assuming drive cache: write through
[KERNEL] [25610.825135] sd 2:0:0:0: [sda] No Caching mode page found
[KERNEL] [25610.825163] sd 2:0:0:0: [sda] Assuming drive cache: write through
[KERNEL] [25611.182015] sda:
[hpsc] Action change.
[KERNEL] [25611.228004] sd 2:0:0:0: [sda] No Caching mode page found
[KERNEL] [25611.228032] sd 2:0:0:0: [sda] Assuming drive cache: write through
[KERNEL] [25611.228054] sd 2:0:0:0: [sda] Attached SCSI removable disk
[hpsc] R/w vFAT mount ("/dev/sda", "/mnt/usb-rdp/0",..) failed, errno 30.
[hpsc] Success: USB1raw mounted VFAT r/o.
[rdpclient 480] Announce new disk named USB1 at /mnt/usb-rdp/0, r/w.
[rdpclient 480] Remote control started.
[rdpclient 480] rdpclient-rdpdr-disk.cpp ( 1104), do_IRP_MJ_DEVICE_CONTROL: -- ERROR -- IRP_MJ_DEVICE_CONTROL for disk, IoControlCode 000900eb unimplemented.
USB BUS: 2022:0139
В общем это гибрид флешки и смарткарты. Флешка пробрасывается, смарткарта нет, из-за чего софт на флешке не работает в терминальной сессии.
PS:
http://infocrypt.ru/index_supp.php?id=58
При подключении токена выдается сообщение "Ошибка! Не удается открыть Infocrypt HWDSSL Device"
Re: Сбербанк онлайн и ключ АМИКОН VPNKey-TLS
Я не нахожу линуксовый драйвер для этой штуки.
ameelien
Может имеет смысл в саппортом пообщаться ихним? Вроде там адекваты.
Ты пользователь их продукта, ты и пиши :)
Думаю, правду сказали. Гугл ничего не знает о линуксовых драйверах этой штуки, если бы они существовали, то так или иначе ушли бы в сеть.
ameelien
блин, и как быть? ((((((
1. Воткнуть ключ в сервер, физически. На сервер поставить VMware Workstation. В VMware сделать виртуальную машину с WinXP, пробросить карту на неё и разрешить на WinXP RDP доступ к консоли. Будет у юзера отдельный экран с клиент-банком, и бэкапить проще.
2. Поставить пользователю Windows.
3. Собрать стенд:
* сервер 2012R2, под ним Hyper-V, под ним VDI, на VDI виртуальную Win8.1 с клиент-банком.
* клиент Win8.1, ключ физически в клиенте, но драйвера ключа на клиента не ставить.
Вроде бы ходили слухи, что 2012R2 умеет на VDI машины пробрасывать USB. Если правда умеет, и на стенде получится увидеть ключ клиент-банком - завести на форуме тему, мол доколе втварь не понимает проброс USB.
ameelien
Не, ну се перебор. Во первых нафиг куда подальше 2012 сервер. Не перевариваю эту дрянь. Во вторых - зачем мне не нужен VDI. У меня просто сервер терминалов, и менять его на VDI - это мне нужно точно. )))
да и зачем? Это как то решит проблемы с wtware ?
Сообщение Rushmore »
aka писал(а):Вроде бы ходили слухи, что 2012R2 умеет на VDI машины пробрасывать USB.
Это не слухи. Оно действительно пробрасывает. Гостевая ОС должна быть Win7, Win8, Win81 с последними integration services.
Клиент соответственно Win81.
ameelien
Это имеет какое то отношение к решению моей проблемы с RDP win2008r2 + wtware ????
