Конфигурационный файл:
server=192.168.1.251
user=Администратор
disk=usb
vnc=on
serial=com50(com1), com51(usb 079b:0028)
video=lxfb(F)
display=1280x1024
USB Bus
067b:2303 Prolific Technology, Inc. PL2303 Serial Port
079b:0028 Sagem
093a:2510 Pixart Imaging, Inc. Optical Mouse
Log
[KERNEL] [ 12.389556] usbcore: registered new interface driver usb-storage
[gm] Load serial port driver.
[gm] modprobe parport_serial.
[KERNEL] [ 12.450478] Serial: 8250/16550 driver, 8 ports, IRQ sharing enabled
[KERNEL] [ 12.474188] 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[gm] Load usb <-> serial bridges drivers.
[gm] modprobe usbserial vendor=0x079b product=0x0028.
[KERNEL] [ 12.536365] usbcore: registered new interface driver usbserial
[KERNEL] [ 12.539308] usbcore: registered new interface driver usbserial_generic
[KERNEL] [ 12.541449] usbserial: USB Serial support registered for generic
[KERNEL] [ 12.541559] usbserial_generic 2-2:1.0: Generic device with no bulk out, not allowed.
[KERNEL] [ 12.541590] usbserial_generic: probe of 2-2:1.0 failed with error -5
[KERNEL] [ 12.541632] usbserial_generic 2-2:1.1: The "generic" usb-serial driver is only for testing and one-off prototypes.
[KERNEL] [ 12.541649] usbserial_generic 2-2:1.1: Tell linux-usb@vger.kernel.org to add your device to a proper driver.
[KERNEL] [ 12.541667] usbserial_generic 2-2:1.1: generic converter detected
[gm] modprobe pl2303.
[KERNEL] [ 12.547194] usb 2-2: generic converter now attached to ttyUSB0
[KERNEL] [ 12.563350] usbcore: registered new interface driver pl2303
[KERNEL] [ 12.565985] usbserial: USB Serial support registered for pl2303
[KERNEL] [ 12.566081] pl2303 2-1:1.0: pl2303 converter detected
[gm] modprobe ftdi_sio.
[KERNEL] [ 12.589660] usb 2-1: pl2303 converter now attached to ttyUSB1
[KERNEL] [ 12.610179] usbcore: registered new interface driver ftdi_sio
[KERNEL] [ 12.612791] usbserial: USB Serial support registered for FTDI USB Serial Device
[gm] modprobe cp210x.
[KERNEL] [ 12.629306] usbcore: registered new interface driver cp210x
[KERNEL] [ 12.631933] usbserial: USB Serial support registered for cp210x
[gm] modprobe ch341.
[KERNEL] [ 12.647331] usbcore: registered new interface driver ch341
[KERNEL] [ 12.649974] usbserial: USB Serial support registered for ch341-uart
[gm] modprobe metro-usb.
[KERNEL] [ 12.665113] usbcore: registered new interface driver metro_usb
[gm] modprobe symbolserial.
[KERNEL] [ 12.667762] usbserial: USB Serial support registered for Metrologic USB to Serial
[KERNEL] [ 12.682320] usbcore: registered new interface driver symbolserial
[gm] modprobe opticon.
[KERNEL] [ 12.684953] usbserial: USB Serial support registered for symbol
[KERNEL] [ 12.700641] usbcore: registered new interface driver opticon
[KERNEL] [ 12.703213] usbserial: USB Serial support registered for opticon
[gm] Load EXFAT filesystem driver.
[gm] modprobe fuse.
[KERNEL] [ 12.795614] fuse init (API version 7.22)
[gm] modprobe exfat.
[KERNEL] [ 12.811319] exFAT: Version 1.2.9
[pfac] Got command line /sbin/resolver 08916f68 dns [192.168.1.251].
[pfac] Ok, PID 620.
[gm] Everyone can control terminal by VNC.
[gm] VNC listener at port 5900.
[pfac] Process pid 620 terminated, status 00000000.
[gm] 192.168.1.251 => 192.168.1.251.
[gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 463964 Kb.
[pfac] Ok, PID 621.
[rdpclient 621] RDP Terminal Client, WTware v.5.2.22, pipe 1, pid 621.
[gm] COM51 => ttyUSB0.
[rdpclient 621] Add serial redirection, COM50 in the session = hardware COM1.
[rdpdr-serial 0] New client connection, id 1.
[rdpclient 621] Add serial redirection, COM51 in the session = hardware ttyUSB0.
[rdpdr-serial 8] New client connection, id 1.
Порты COM50,COM51 не появляются
Нужны ли дополнительные настройки на сервере? Windows XP Professional на это вообще способен?
