5.2.26 USBIP
3JI0
5.2.26 USBIP
Сообщение 3JI0 »
В чём может быть проблема? как на 2.22 так и на 2.26.
Обычный принтер пытаюсь настроить, драйвера стоят, usbip видит
usbip.exe --list 192.168.10.50
- 192.168.10.50
     1-3: Canon, Inc. : CAPT Device (04a9:2676)
        : /sys/devices/pci0000:00/0000:00:1d.7/usb1/1-3
        : (Defined at Interface level) (00/00/00)
        :  0 - Printer / Printer / Bidirectional (07/01/02)
16-36-21-802| [gm] Load USBIP stub driver.
16-36-21-802| [gm] modprobe usbip-host.
16-36-21-802| [KERNEL] [    8.367970] usbip_core: module is from the staging directory, the quality is unknown, you have been warned.
16-36-21-802| [KERNEL] [    8.368119] usbip_core: USB/IP Core v1.0.0
16-36-21-802| [KERNEL] [    8.368145] usbip_host: module is from the staging directory, the quality is unknown, you have been warned.
16-36-21-802| [KERNEL] [    8.368550] usbip-host 1-3:1.0: 1-3 is not in match_busid table... skip!
16-36-21-802| [gm] +--- Executing "/sbin/usbipd -D -4"
16-36-21-802| [KERNEL] [    8.368818] usbcore: registered new interface driver usbip-host
16-36-21-802| [KERNEL] [    8.368820] usbip_host: USB/IP Host Driver v1.0.0
16-36-21-802| [gm] +- Errorlevel: 0, output:
16-36-21-802| File is empty.
16-36-21-802| [gm] +------------------------
16-36-21-802| [gm] WTware USBIP Initiator Server 192.168.2.250 => 192.168.2.250.
16-36-21-802| [gm] USBIP: redirect "1-3" to port 101.
16-36-21-802| [SYSLOG] <14>Mar 30 15:41:25 usbipd: usbipd: info: starting usbipd (usbip-utils 1.0.6)
16-36-21-802| [SYSLOG] <14>Mar 30 15:41:25 usbipd: usbipd: info: listening on 0.0.0.0:3240
16-36-21-802| /--- FILE "/tmp/usbip-bind-454" -----------------------
16-36-21-802| | bind device on busid 1-3: complete
16-36-21-802| \----------------------------------------------------
16-36-21-802| [KERNEL] [    8.370929] usbip-host 1-3:1.0: usbip-host: register new device (bus 1 dev 2 ifn 0)
16-36-21-802| [gm]          fstream.cpp (  494): -- ERROR -- Conection with 192.168.2.250:780 failed, errno 111.
16-36-21-802| [gm] USBIP ERROR: connection to WTware USBIP Initiator service at 192.168.2.250 port 780 failed.
WTware_00.26.18.DC.E2.D6_2015-03-30_16-36-46.txt
(248.2 КБ) 1302 скачивания
Re: 5.2.26 USBIP
3JI0 писал(а): 16-36-21-802| [gm] fstream.cpp ( 494): -- ERROR -- Conection with 192.168.2.250:780 failed, errno 111.
[/code]
На машине 192.168.2.250 не запущена или закрыта фаирволом служба WTware USBIP Initiator. Действительно .2., не .10.?
3JI0
Re: 5.2.26 USBIP
Сообщение 3JI0 »
Вы правы, мой косяк. всё заработало :)
