При подключении к windows 10 TP Build 10074 выводит ошибку СredSSP connection failed.
Как это исправить?
Подключение к Windows 10 TP
Re: Подключение к Windows 10 TP
Втварь свежая? На сервере ничего не сломал? У меня подключается. Build 10074, без домена, никаких лишних действий - поставил, добавил роль Session Host, подключаюсь.
Лог покажи.
Лог покажи.
Binary
08-14-46-750| [rdpclient 758] RDP Terminal Client, WTware v.5.2.22, pipe 7, pid 758.
08-14-46-750| [rdpclient 758] Redirect sound.
08-14-46-750| [rdpclient 758] Make RDP session with 10.0.254.1, port 3389.
08-14-46-750| [rdpclient 758] Username: "User01".
08-14-46-750| [rdpclient 758] No password.
08-14-46-750| [rdpclient 758] No PIN.
08-14-46-750| [rdpclient 758] Domain: "OMF".
08-14-46-750| [rdpclient 758] No shell.
08-14-46-750| [rdpclient 758] No directory.
08-14-46-750| [rdpclient 758] Window: 1920x1080@16.
08-14-46-750| [rdpclient 758] PFlags 0x00000186.
08-14-46-750| [rdpclient 758] Keyboard 00000409:00000000.
08-14-46-750| [rdpclient 758] My hostname "Terminal_01".
08-14-46-750| [rdpclient 758] TCP: connecting to 10.0.254.1:3389.
08-14-46-750| [rdpclient 758] TCP: connection with 10.0.254.1:3389 established.
08-14-46-750| [rdpclient 758] Turn keepalive on.
08-14-46-750| [rdpclient 758] Free ram after buffers allocation: 812756 KB.
08-14-46-750| [rdpclient 758] Reconnect with TLS/SSL enabled.
08-14-46-750| [rdpclient 758] TCP: reconnecting to 10.0.254.1:3389.
08-14-46-750| [rdpclient 758] CredSSP.
08-14-46-750| [rdpclient 758] SSL_ERROR_SSL
08-14-46-750| [rdpclient 758] [SSL] error:14094419:SSL routines:SSL3_READ_BYTES:tlsv1 alert access denied
08-14-46-750| [rdpclient 758] rdpclient-credssp.cpp ( 141): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
08-14-46-750| [rdpclient 758] rdpclient-credssp.cpp ( 191): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
08-14-46-750| [rdpclient 758] rdpclient-credssp.cpp ( 319): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
08-14-46-750| [rdpclient 758] rdpclient-credssp.cpp ( 645): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
08-14-46-750| [rdpclient 758] rdpclient-tcp.cpp ( 505): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
08-14-46-750| [rdpclient 758] CredSSP connection failed.
08-14-46-750| [rdpclient 758] Caught signal SIGTERM.
08-14-46-750| [rdpsnd] Link lost.
08-14-46-750| [RDP] [06:14:32:551] [758:758] [ERROR][com.winpr.utils] - Could not open SAM file!
08-14-46-750| [pfac] Process pid 758 terminated, status 00000000.
08-14-46-750| [gm] Final message: CredSSP connection failed.
08-14-46-750| [gm] Release shared memory block: id 0x0006000a, address 0xb6f0c000.
08-14-46-750| [gm] Allocate 111104 bytes of shared memory for X imgbuf.
08-14-46-750| [gm] New shared memory block 224x248@16bit: id 0x0006800b, address 0xb6f0f000.
08-14-46-750| [gm] Release shared memory block: id 0x0006800b, address 0xb6f0f000.
08-14-46-750| [gm] Allocate 125440 bytes of shared memory for X imgbuf.
08-14-46-750| [gm] New shared memory block 224x280@16bit: id 0x0007000a, address 0xb6f0c000.
08-14-46-756| Connection from wtc.exe at 10.0.0.54.
Включи обратно NLA, которое отключил. Поможет?
Binary
Подключил. Все заработало. Только login и password не от windows 10.
Да, есть такое. То, что оно не работает с отключенным NLA - это ошибка втвари, будет исправлено в следующей версии. При отключенном NLA пароль должен запрашиваться в интерфейсе Windows.
v_poyarkov
Подключаюсь к Win server 2012 R2. Такая же ошибка. Версия wtware 5.2.32.
Написано же в описании, что в новых версиях такой проблемы не будет. Это всё-таки отключать NLA?
Такая ошибка случилась из-за отключенного NLA. Решение - включить обратно, т.е. вернуть как было изначально, после установки сервера. Если ты NLA не отключал, значит у тебя не такая ошибка, покажи лог.
