Проблема с пробросом USB через WTWARE USBIP 2012 R2
steck
Сообщение steck »
Пытаюсь пробросить напрямую usb флэшку, usb token и получаю одну и ту же ошибку в логах usbip
Драйвер usbip на сервере 2012 r2 установлен
16-24-45-622| Action: add, ip 10.51.0.113, bus 2-1.
16-24-45-624| Device 0: path '/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1', busid '2-1', busnum 2, devnum 5, vendor 0x0529, device 0x0620, 1 interfaces.
16-24-45-627| ..\usbip.cpp ( 306): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
16-24-45-628| ..\usbip.cpp ( 402): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
16-24-45-628| Add: incorrect termination (10.51.0.113, 2-1).
16-25-02-460| Action: add, ip 10.51.0.113, bus 2-1.
16-25-02-462| Device 0: path '/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1', busid '2-1', busnum 2, devnum 6, vendor 0x0529, device 0x0620, 1 interfaces.
16-25-02-466| ..\usbip.cpp ( 306): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
16-25-02-467| ..\usbip.cpp ( 402): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
16-25-02-467| Add: incorrect termination (10.51.0.113, 2-1).
16-25-00-636| [KERNEL] [ 1200.485697] usb 2-1: USB disconnect, device number 5
16-25-00-678| [KERNEL] [ 1200.485782] usb 2-1: lock for reset
16-25-00-690| [hpsc] eToken 72K Java.
16-25-00-691| [hpsc] USBIP: remove 2-1.
16-25-00-701| [hpsc] USBIP: remove flag for bus 2-1.
16-25-02-292| [KERNEL] [ 1202.141376] usb 2-1: new full-speed USB device number 6 using uhci_hcd
16-25-02-449| [KERNEL] [ 1202.299306] usb 2-1: New USB device found, idVendor=0529, idProduct=0620
16-25-02-499| [KERNEL] [ 1202.299312] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
16-25-02-514| [KERNEL] [ 1202.299316] usb 2-1: Product: Token JC
16-25-02-515| [KERNEL] [ 1202.299320] usb 2-1: Manufacturer: Aladdin
16-25-02-524| [hpsc] USBIP: redirect "2-1".
16-25-02-525| [KERNEL] [ 1202.308505] usbip-host 2-1:1.0: usbip-host: register new device (bus 2 dev 6 ifn 0)
16-25-02-535| /--- FILE "/tmp/usbip-bind-651" -----------------------
16-25-02-536| | usbip: error: device on busid 2-1 is already bound to usbip-host
16-25-02-544| \----------------------------------------------------
16-25-02-545| [hpsc] USBIP: send "USBIP: add 2-1" to 10.51.0.254.
16-25-02-553| [SYSLOG] <14>Jun 1 16:25:01 usbipd: usbipd: info: connection from 10.51.0.254:59616
16-25-02-554| [SYSLOG] <14>Jun 1 16:25:01 usbipd: usbipd: info: received request: 0x8005(5)
16-25-02-565| [SYSLOG] <14>Jun 1 16:25:01 usbipd: usbipd: info: exportable devices: 1
16-25-02-566| [SYSLOG] <14>Jun 1 16:25:01 usbipd: usbipd: info: request 0x8005(5): complete
16-25-02-574| [SYSLOG] <14>Jun 1 16:25:01 usbipd: usbipd: info: connection from 10.51.0.254:59617
16-25-02-575| [SYSLOG] <14>Jun 1 16:25:01 usbipd: usbipd: info: received request: 0x8003(5)
16-25-02-583| [SYSLOG] <14>Jun 1 16:25:01 usbipd: usbipd: info: found requested device: 2-1
16-25-02-584| [KERNEL] [ 1202.315095] usbip-host 2-1:1.0: stub up
16-25-02-592| [SYSLOG] <14>Jun 1 16:25:01 usbipd: usbipd: info: request 0x8003(5): complete
16-25-02-595| [KERNEL] [ 1202.317853] usbip-host 2-1:1.0: recv a header, 0
16-25-02-608| [KERNEL] [ 1202.421830] usb 2-1: reset full-speed USB device number 6 using uhci_hcd
16-25-02-705| [KERNEL] [ 1202.555315] usb 2-1: device reset
Re: Проблема с пробросом USB через WTWARE USBIP 2012 R2
Оно считает, что драйвер не установлен. Попробуй использовать usbip.exe из того же архива, в котором был драйвер.
steck
Сообщение steck »
aka писал(а):Оно считает, что драйвер не установлен. Попробуй использовать usbip.exe из того же архива, в котором был драйвер.
Пробовал, все тоже самое!
Поменял терминал 2012 r2 на Windows 7 x64 sp1 ultimate все тоже самое!
C:\usbip_windows>usbip.exe -l 10.51.0.254(IP адрес где запущена служба wtusbip)
usbip err: usbip.c: 280 (show_exported_devices) - 10.51.0.254 failed
steck писал(а):C:\usbip_windows>usbip.exe -l 10.51.0.254(IP адрес где запущена служба wtusbip)
А надо IP терминала. Для shared_usb очень большой бубен надо, не у каждого такой есть...
Через некоторое время мы допишем перенаправление через RDP. Там будет проще, галку в конфиге поставил и оно должно будет работать.
steck
Сообщение steck »
Как в ручную прикрутить устройство без wtusbip?
[quote="steck"][quote="aka"][quote="steck"]C:\usbip_windows>usbip.exe -l 10.51.0.254(IP адрес где запущена служба wtusbip)[/quote]
Через некоторое время мы допишем перенаправление через RDP. Там будет проще, галку в конфиге поставил и оно должно будет работать.[/quote]
Как в ручную прикрутить устройство без wtusbip?[/quote]
В ручную usbip.exe -a 10.51.0.170 2-1.5 подключает
Как сделать чтобы автоматически подключалось???
Написать в конфиге терминала:
shared_usb=server:192.168.1.1, 1234:abcd
Вместо 192.168.1.1 подставить IP машины, на которой работает служба wtusbip из дистрибутива втвари, и на которой вручную подключает.
Вместо 1234:abcd подставить USB ID устройства.
[quote="aka"]Написать в конфиге терминала:
Вместо 1234:abcd подставить USB ID устройства.[/quote]
Написал но в итоге в логах wtusbip все та же ошибка
steck
Сообщение steck »
Может все дело в том что wtware установлен и запущен под windows server 2012 r2 ?
Зачем ты вообще перенаправляешь смарт-карту через shared_usb? Ты собираешься использовать её в консольном сеансе?
Первый абзац документации: "...и бесполезно для авторизации по смарт-карте."
