Вебка и флешка
Act0n3
Вебка и флешка
Сообщение Act0n3 »
Как правильно пробросить вебку и флешку, со звуком довольно проосто получилось, но вебка никак не хочет.
16-55-31-613| [ rdpclient 624] [ 592.598134] Send Disconnect Provider Ultimatum.
16-55-31-629| [ gm] [ 592.598780] TSClient gracefully end.
16-55-31-629| [ rdpsnd] [ 592.604338] Link lost.
16-55-31-645| [ pfac] [ 592.605186] Process pid 624 terminated, status 00000009.
16-55-31-645| [ gm] [ 592.610233] Going to shutdown. Will not start sequent session.
16-55-41-846| [wtc.exe] Соединение закрыто.
16-55-44-719| [wtc.exe] Не удалось подключиться к 192.168.0.113:779.
16-55-47-840| WTware v.5.4.62/RPi supervisor.
16-55-47-840| WTC listener is active.
16-55-47-840| WTC broadcast listener is active.
16-55-47-840| [ KERNEL] [ 0.000000] Booting Linux on physical CPU 0xf00
16-55-47-840| [ KERNEL] [ 0.000000] Initializing cgroup subsys cpuset
16-55-47-840| [ KERNEL] [ 0.000000] Initializing cgroup subsys cpuacct
16-55-47-840| [ KERNEL] [ 0.000000] Linux version 4.4.32 (aka@c12) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #13 SMP Thu Nov 24 17:30:38 +04 2016
16-55-47-840| [ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
16-55-47-840| [ KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
16-55-47-840| [ KERNEL] [ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
16-55-47-840| [ KERNEL] [ 0.000000] cma: Reserved 8 MiB at 0x3a800000
16-55-47-840| [ KERNEL] [ 0.000000] Memory policy: Data cache writealloc
16-55-47-840| [ KERNEL] [ 0.000000] On node 0 totalpages: 241664
16-55-47-840| [ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80915640, node_mem_map b9fa6000
16-55-47-840| [ KERNEL] [ 0.000000] Normal zone: 2124 pages used for memmap
16-55-47-840| [ KERNEL] [ 0.000000] Normal zone: 0 pages reserved
16-55-47-840| [ KERNEL] [ 0.000000] Normal zone: 241664 pages, LIFO batch:31
16-55-47-840| [ KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] enter (94c0->f3003010)
16-55-47-840| [ KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] ncores=4
16-55-47-840| [ KERNEL] [ 0.000000] PERCPU: Embedded 11 pages/cpu @b9f6a000 s13324 r8192 d23540 u45056
16-55-47-840| [ KERNEL] [ 0.000000] pcpu-alloc: s13324 r8192 d23540 u45056 alloc=11*4096
16-55-47-840| [ KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
16-55-47-840| [ KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
16-55-47-840| [ KERNEL] [ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa01041 bcm2709.serial=0x6f6a5311 smsc95xx.macaddr=B8:27:EB:6A:53:11 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 console=ttyAMA0,115200 console=tty1 quiet wtboot=mmc
16-55-47-840| [ KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
16-55-47-840| [ KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
16-55-47-840| [ KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
16-55-47-840| [ KERNEL] [ 0.000000] Memory: 939208K/966656K available (3807K kernel code, 169K rwdata, 1180K rodata, 4116K init, 365K bss, 19256K reserved, 8192K cma-reserved)
16-55-47-840| [ KERNEL] [ 0.000000] Virtual kernel memory layout:
16-55-47-840| [ KERNEL] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
16-55-47-840| [ KERNEL] [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
16-55-47-840| [ KERNEL] [ 0.000000] vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
16-55-47-840| [ KERNEL] [ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
16-55-47-840| [ KERNEL] [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
16-55-47-840| [ KERNEL] [ 0.000000] .text : 0x80008000 - 0x804e6f94 (4988 kB)
16-55-47-840| [ KERNEL] [ 0.000000] .init : 0x804e7000 - 0x808ec000 (4116 kB)
16-55-47-840| [ KERNEL] [ 0.000000] .data : 0x808ec000 - 0x80916540 ( 170 kB)
16-55-47-840| [ KERNEL] [ 0.000000] .bss : 0x80919000 - 0x80974588 ( 366 kB)
16-55-47-840| [ KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
16-55-47-840| [ KERNEL] [ 0.000000] Hierarchical RCU implementation.
16-55-47-840| [ KERNEL] [ 0.000000] Build-time adjustment of leaf fanout to 32.
16-55-47-840| [ KERNEL] [ 0.000000] NR_IRQS:16 nr_irqs:16 16
16-55-47-840| [ KERNEL] [ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
16-55-47-840| [ KERNEL] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
16-55-47-840| [ KERNEL] [ 0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
16-55-47-840| [ KERNEL] [ 0.000030] Switching to timer-based delay loop, resolution 52ns
16-55-47-840| [ KERNEL] [ 0.000246] Console: colour dummy device 80x30
16-55-47-840| [ KERNEL] [ 0.000449] console [tty1] enabled
16-55-47-840| [ KERNEL] [ 0.000476] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
16-55-47-840| [ KERNEL] [ 0.000498] pid_max: default: 32768 minimum: 301
16-55-47-840| [ KERNEL] [ 0.000661] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
16-55-47-840| [ KERNEL] [ 0.000680] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
16-55-47-840| [ KERNEL] [ 0.001811] Disabling cpuset control group subsystem
16-55-47-840| [ KERNEL] [ 0.001848] Initializing cgroup subsys io
16-55-47-840| [ KERNEL] [ 0.001881] Initializing cgroup subsys memory
16-55-47-840| [ KERNEL] [ 0.001929] Initializing cgroup subsys devices
16-55-47-840| [ KERNEL] [ 0.001954] Initializing cgroup subsys freezer
16-55-47-840| [ KERNEL] [ 0.002014] CPU: Testing write buffer coherency: ok
16-55-47-840| [ KERNEL] [ 0.002625] CPU0: update cpu_capacity 1024
16-55-47-840| [ KERNEL] [ 0.002645] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
16-55-47-840| [ KERNEL] [ 0.002658] [bcm2709_smp_prepare_cpus] enter
16-55-47-840| [ KERNEL] [ 0.002744] Setting up static identity map for 0x8240 - 0x8274
16-55-47-840| [ KERNEL] [ 0.004719] [bcm2709_boot_secondary] cpu:1 started (0) 18
16-55-47-840| [ KERNEL] [ 0.005014] [bcm2709_secondary_init] enter cpu:1
16-55-47-840| [ KERNEL] [ 0.005056] CPU1: update cpu_capacity 1024
16-55-47-840| [ KERNEL] [ 0.005064] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
16-55-47-840| [ KERNEL] [ 0.005566] [bcm2709_boot_secondary] cpu:2 started (0) 17
16-55-47-840| [ KERNEL] [ 0.005798] [bcm2709_secondary_init] enter cpu:2
16-55-47-840| [ KERNEL] [ 0.005828] CPU2: update cpu_capacity 1024
16-55-47-840| [ KERNEL] [ 0.005835] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
16-55-47-840| [ KERNEL] [ 0.006295] [bcm2709_boot_secondary] cpu:3 started (0) 16
16-55-47-840| [ KERNEL] [ 0.006506] [bcm2709_secondary_init] enter cpu:3
16-55-47-840| [ KERNEL] [ 0.006531] CPU3: update cpu_capacity 1024
16-55-47-840| [ KERNEL] [ 0.006538] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
16-55-47-840| [ KERNEL] [ 0.006614] Brought up 4 CPUs
16-55-47-840| [ KERNEL] [ 0.006641] SMP: Total of 4 processors activated (153.60 BogoMIPS).
16-55-47-840| [ KERNEL] [ 0.006650] CPU: All CPU(s) started in HYP mode.
16-55-47-840| [ KERNEL] [ 0.006658] CPU: Virtualization extensions available.
16-55-47-840| [ KERNEL] [ 0.007231] devtmpfs: initialized
16-55-47-840| [ KERNEL] [ 0.019221] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
16-55-47-840| [ KERNEL] [ 0.019719] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
16-55-47-840| [ KERNEL] [ 0.020444] pinctrl core: initialized pinctrl subsystem
16-55-47-840| [ KERNEL] [ 0.021058] NET: Registered protocol family 16
16-55-47-840| [ KERNEL] [ 0.026624] DMA: preallocated 4096 KiB pool for atomic coherent allocations
16-55-47-840| [ KERNEL] [ 0.049945] cpuidle: using governor ladder
16-55-47-840| [ KERNEL] [ 0.079971] cpuidle: using governor menu
16-55-47-840| [ KERNEL] [ 0.087735] Serial: AMBA PL011 UART driver
16-55-47-840| [ KERNEL] [ 0.088124] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
16-55-47-840| [ KERNEL] [ 0.088511] console [ttyAMA0] enabled
16-55-47-840| [ KERNEL] [ 0.089199] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
16-55-47-840| [ KERNEL] [ 0.173663] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
16-55-47-840| [ KERNEL] [ 0.174377] usbcore: registered new interface driver usbfs
16-55-47-840| [ KERNEL] [ 0.174564] usbcore: registered new interface driver hub
16-55-47-840| [ KERNEL] [ 0.174702] usbcore: registered new device driver usb
16-55-47-840| [ KERNEL] [ 0.180281] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-11-16 12:24
16-55-47-840| [ KERNEL] [ 0.209117] clocksource: Switched to clocksource arch_sys_counter
16-55-47-840| [ KERNEL] [ 0.227131] NET: Registered protocol family 2
16-55-47-840| [ KERNEL] [ 0.227922] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
16-55-47-840| [ KERNEL] [ 0.228059] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
16-55-47-840| [ KERNEL] [ 0.228250] TCP: Hash tables configured (established 8192 bind 8192)
16-55-47-840| [ KERNEL] [ 0.228372] UDP hash table entries: 512 (order: 2, 16384 bytes)
16-55-47-840| [ KERNEL] [ 0.228435] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
16-55-47-840| [ KERNEL] [ 0.228735] NET: Registered protocol family 1
16-55-47-840| [ KERNEL] [ 2.846817] futex hash table entries: 1024 (order: 4, 65536 bytes)
16-55-47-840| [ KERNEL] [ 2.909486] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
16-55-47-840| [ KERNEL] [ 2.909526] io scheduler noop registered
16-55-47-840| [ KERNEL] [ 2.909549] io scheduler deadline registered (default)
16-55-47-840| [ KERNEL] [ 2.917410] BCM2708FB: allocated DMA memory fac00000
16-55-47-840| [ KERNEL] [ 2.917471] BCM2708FB: allocated DMA channel 0 @ f3007000
16-55-47-840| [ KERNEL] [ 2.980169] Console: switching to colour frame buffer device 240x67
16-55-47-840| [ KERNEL] [ 3.860864] bcm2835-rng 3f104000.rng: hwrng registered
16-55-47-840| [ KERNEL] [ 3.861179] vc-cma: Videocore CMA driver
16-55-47-840| [ KERNEL] [ 3.861197] vc-cma: vc_cma_base = 0x00000000
16-55-47-840| [ KERNEL] [ 3.861209] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
16-55-47-840| [ KERNEL] [ 3.861220] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
16-55-47-840| [ KERNEL] [ 3.861635] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
16-55-47-840| [ KERNEL] [ 3.864859] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
16-55-47-840| [ KERNEL] [ 3.871035] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
16-55-47-840| [ KERNEL] [ 4.071637] Core Release: 2.80a
16-55-47-840| [ KERNEL] [ 4.071664] Setting default values for core params
16-55-47-840| [ KERNEL] [ 4.071714] Finished setting default values for core params
16-55-47-840| [ KERNEL] [ 4.272146] Using Buffer DMA mode
16-55-47-840| [ KERNEL] [ 4.272172] Periodic Transfer Interrupt Enhancement - disabled
16-55-47-840| [ KERNEL] [ 4.272181] Multiprocessor Interrupt Enhancement - disabled
16-55-47-840| [ KERNEL] [ 4.272192] OTG VER PARAM: 0, OTG VER FLAG: 0
16-55-47-840| [ KERNEL] [ 4.272213] Dedicated Tx FIFOs mode
16-55-47-840| [ KERNEL] [ 4.272768] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
16-55-47-840| [ KERNEL] [ 4.272814] FIQ FSM acceleration enabled for :
16-55-47-840| [ KERNEL] [ 4.272814] Non-periodic Split Transactions
16-55-47-840| [ KERNEL] [ 4.272814] Periodic Split Transactions
16-55-47-840| [ KERNEL] [ 4.272814] High-Speed Isochronous Endpoints
16-55-47-840| [ KERNEL] [ 4.272814] Interrupt/Control Split Transaction hack enabled
16-55-47-840| [ KERNEL] [ 4.272840] dwc_otg: Microframe scheduler enabled
16-55-47-840| [ KERNEL] [ 4.272909] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x8025a938
16-55-47-840| [ KERNEL] [ 4.272926] WARN::hcd_init_fiq:414: FIQ ASM at 0x8025ac9c length 36
16-55-47-840| [ KERNEL] [ 4.272945] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb908000
16-55-47-840| [ KERNEL] [ 4.273027] dwc_otg 3f980000.usb: DWC OTG Controller
16-55-47-840| [ KERNEL] [ 4.273083] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
16-55-47-840| [ KERNEL] [ 4.273132] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
16-55-47-840| [ KERNEL] [ 4.273189] Init: Port Power? op_state=1
16-55-47-840| [ KERNEL] [ 4.273198] Init: Power Port (0)
16-55-47-840| [ KERNEL] [ 4.273477] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
16-55-47-840| [ KERNEL] [ 4.273497] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
16-55-47-840| [ KERNEL] [ 4.273514] usb usb1: Product: DWC OTG Controller
16-55-47-840| [ KERNEL] [ 4.273528] usb usb1: Manufacturer: Linux 4.4.32 dwc_otg_hcd
16-55-47-840| [ KERNEL] [ 4.273542] usb usb1: SerialNumber: 3f980000.usb
16-55-47-840| [ KERNEL] [ 4.274752] hub 1-0:1.0: USB hub found
16-55-47-840| [ KERNEL] [ 4.274841] hub 1-0:1.0: 1 port detected
16-55-47-840| [ KERNEL] [ 4.275520] dwc_otg: FIQ enabled
16-55-47-840| [ KERNEL] [ 4.275535] dwc_otg: NAK holdoff enabled
16-55-47-840| [ KERNEL] [ 4.275544] dwc_otg: FIQ split-transaction FSM enabled
16-55-47-840| [ KERNEL] [ 4.275713] Module dwc_common_port init
16-55-47-840| [ KERNEL] [ 4.279451] usbcore: registered new interface driver usbtouchscreen
16-55-47-840| [ KERNEL] [ 4.280571] bcm2835-cpufreq: min=600000 max=900000
16-55-47-840| [ KERNEL] [ 4.284456] sdhost: log_buf @ bac13000 (fac13000)
16-55-47-840| [ KERNEL] [ 4.339141] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
16-55-47-840| [ KERNEL] [ 4.359658] hidraw: raw HID events driver (C) Jiri Kosina
16-55-47-840| [ KERNEL] [ 4.360591] usbcore: registered new interface driver usbhid
16-55-47-840| [ KERNEL] [ 4.360608] usbhid: USB HID core driver
16-55-47-840| [ KERNEL] [ 4.361318] NET: Registered protocol family 17
16-55-47-840| [ KERNEL] [ 4.361684] Registering SWP/SWPB emulation handler
16-55-47-840| [ KERNEL] [ 4.362852] registered taskstats version 1
16-55-47-840| [ KERNEL] [ 4.363031] vc-sm: Videocore shared memory driver
16-55-47-840| [ KERNEL] [ 4.363061] [vc_sm_connected_init]: start
16-55-47-840| [ KERNEL] [ 4.364082] [vc_sm_connected_init]: end - returning 0
16-55-47-840| [ KERNEL] [ 4.381660] Freeing unused kernel memory: 4116K (804e7000 - 808ec000)
16-55-47-840| [ KERNEL] [ 4.448571] mmc0: host does not support reading read-only switch, assuming write-enable
16-55-47-840| [ KERNEL] [ 4.452093] mmc0: new high speed SDHC card at address aaaa
16-55-47-840| [ KERNEL] [ 4.452734] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
16-55-47-840| [ KERNEL] [ 4.454520] mmcblk0: p1
16-55-47-840| [ hotplug] [ 4.448406] Block device 179:0. No action.
16-55-47-840| [ hotplug] [ 4.449144] Block device 179:1. No action.
16-55-47-840| [ KERNEL] [ 4.469260] Indeed it is in host mode hprt0 = 00021501
16-55-47-840| [ KERNEL] [ 4.659172] usb 1-1: new high-speed USB device number 2 using dwc_otg
16-55-47-840| [ KERNEL] [ 4.659349] Indeed it is in host mode hprt0 = 00001101
16-55-47-840| [ pfac] [ 4.713924] Run /sbin/initrd.
16-55-47-840| [ pfac] [ 4.714271] Ok, PID 538.
16-55-47-840| [ initrd] [ 4.717282] WTware shell v.5.4.62/RPi
16-55-47-840| [ initrd] [ 4.752449] Local media boot.
16-55-47-840| [ initrd] [ 4.752611] USB boot.
16-55-47-840| [ KERNEL] [ 4.859521] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
16-55-47-840| [ KERNEL] [ 4.859552] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
16-55-47-840| [ KERNEL] [ 4.860880] hub 1-1:1.0: USB hub found
16-55-47-840| [ KERNEL] [ 4.861085] hub 1-1:1.0: 5 ports detected
16-55-47-840| [ KERNEL] [ 5.139170] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
16-55-47-840| [ KERNEL] [ 5.239447] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
16-55-47-840| [ KERNEL] [ 5.239471] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
16-55-47-840| [ KERNEL] [ 5.319161] usb 1-1.3: new low-speed USB device number 4 using dwc_otg
16-55-47-840| [ KERNEL] [ 5.564250] usb 1-1.3: New USB device found, idVendor=04d9, idProduct=1702
16-55-47-840| [ KERNEL] [ 5.564273] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
16-55-47-840| [ KERNEL] [ 5.564288] usb 1-1.3: Product: USB Keyboard
16-55-47-840| [ KERNEL] [ 5.564302] usb 1-1.3: Manufacturer:
16-55-47-840| [ KERNEL] [ 5.626084] input: USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:04D9:1702.0001/input/input0
16-55-47-840| [ KERNEL] [ 5.681018] hid-generic 0003:04D9:1702.0001: input,hidraw0: USB HID v1.10 Keyboard [ USB Keyboard] on usb-3f980000.usb-1.3/input0
16-55-47-840| [ KERNEL] [ 5.780716] input: USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:04D9:1702.0002/input/input1
16-55-47-840| [ initrd] [ 5.790555] WTpassword empty.
16-55-47-840| [ KERNEL] [ 5.839998] hid-generic 0003:04D9:1702.0002: input,hidraw1: USB HID v1.10 Device [ USB Keyboard] on usb-3f980000.usb-1.3/input1
16-55-47-840| [ KERNEL] [ 6.079150] usb 1-1.4: new high-speed USB device number 5 using dwc_otg
16-55-47-840| [ KERNEL] [ 6.205936] usb 1-1.4: New USB device found, idVendor=0ac8, idProduct=3500
16-55-47-840| [ KERNEL] [ 6.205960] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
16-55-47-840| [ KERNEL] [ 6.205975] usb 1-1.4: Product: A4 TECH HD PC Camera
16-55-47-840| [ KERNEL] [ 6.205989] usb 1-1.4: Manufacturer: A4 TECH
16-55-47-840| [ KERNEL] [ 6.206004] usb 1-1.4: SerialNumber: MI1320_SOC
16-55-47-840| [ KERNEL] [ 6.289168] usb 1-1.5: new low-speed USB device number 6 using dwc_otg
16-55-47-840| [ KERNEL] [ 6.393983] usb 1-1.5: New USB device found, idVendor=0458, idProduct=003a
16-55-47-840| [ KERNEL] [ 6.394007] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
16-55-47-840| [ KERNEL] [ 6.394022] usb 1-1.5: Product: USB Optical Mouse
16-55-47-840| [ KERNEL] [ 6.394037] usb 1-1.5: Manufacturer: Genius
16-55-47-840| [ KERNEL] [ 6.401131] input: Genius USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:0458:003A.0003/input/input2
16-55-47-840| [ KERNEL] [ 6.402142] hid-generic 0003:0458:003A.0003: input,hidraw2: USB HID v1.11 Mouse [Genius USB Optical Mouse] on usb-3f980000.usb-1.5/input0
16-55-47-840| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
16-55-47-840| | clientIP = 192.168.0.113
16-55-47-840| | netmask = 255.255.255.0
16-55-47-840| | routerIP = 192.168.0.1
16-55-47-840| | nameserverIP = 192.168.0.1
16-55-47-840| | config = local
16-55-47-840| \----------------------------------------------------
16-55-47-840| [ initrd] [ 7.824124] Load ethernet drivers.
16-55-47-840| [ initrd] [ 7.824289] modprobe smsc95xx.
16-55-47-840| [ KERNEL] [ 7.843844] smsc95xx v1.0.4
16-55-47-840| [ KERNEL] [ 7.903072] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:6a:53:11
16-55-47-840| [ KERNEL] [ 7.903421] usbcore: registered new interface driver smsc95xx
16-55-47-840| [ KERNEL] [ 7.961552] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
16-55-47-840| [ KERNEL] [ 9.493498] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
16-55-47-840| [ initrd] [ 9.557128] WTpassword empty.
16-55-47-840| Send broadcast WTCU discover.
16-55-47-840| [ initrd] [ 9.561092] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
16-55-47-840| [ pfac] [ 9.561264] Run /sbin/httpd.
16-55-47-840| [ pfac] [ 9.561679] Ok, PID 580.
16-55-47-840| [ httpd] [ 9.577474] HTTP Server, WTware v.5.4.62/RPi
16-55-47-840| [ KERNEL] [ 9.602106] random: httpd: uninitialized urandom read (32 bytes read, 118 bits of entropy available)
16-55-47-840| [ initrd] [ 9.701549] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
16-55-47-840| [ initrd] [ 9.701768] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
16-55-47-840| [ initrd] [ 9.701901] USB: 04d9:1702 Holtek Semiconductor, Inc. Keyboard LKS02.
16-55-47-840| [ initrd] [ 9.702016] USB: 0ac8:3500 Z-Star Microelectronics Corp..
16-55-47-840| [ initrd] [ 9.702129] USB: 0458:003a KYE Systems Corp. (Mouse Systems) NetScroll+ Mini Traveler / Genius NetScroll 120.
16-55-47-840| [ initrd] [ 9.702254] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
16-55-47-840| [ initrd] [ 9.702891] Common local disk config:
16-55-47-840| /--- FILE "/tmp/config.wtc" -----------------------
16-55-47-840| | [BOM]
16-55-47-840| | server=192.168.0.3
16-55-47-840| | sound=on
16-55-47-840| | usb=0ac8:3500
16-55-47-840| | connection
16-55-47-840| /--- FILE "/etc/config.compiled" -----------------------
16-55-47-840| [ initrd] [ 9.716245] Hostname: "wtwB827EB6A5311".
16-55-47-840| Everyone can control terminal by RSH.
16-55-47-840| RSH: listener is active.
16-55-47-840| [ httpd] [ 9.722037] Reread settings.
16-55-47-840| [ httpd] [ 9.722225] Everyone can control terminal by HTTP.
16-55-47-840| [ gm] [ 9.727486] WTware session manager v.5.4.62/RPi.
16-55-47-840| [ gm] [ 9.780235] EV_REL flag found. Add mouse event2: Genius USB Optical Mouse.
16-55-47-840| [ gm] [ 9.780405] Add keyboard event1: USB Keyboard.
16-55-47-840| [ gm] [ 9.780529] Add keyboard event0: USB Keyboard.
16-55-47-840| [ gm] [ 9.780640] Display mode: 1920x1080, 32 bit, 0 Hz, modeline "", DDC enabled, connector 0.
16-55-47-840| [ gm] [ 9.819515] Framebuffer device found.
16-55-47-840| [ gm] [ 9.819671] LINELENBYTES 7680
16-55-47-840| [ gm] [ 9.819784] VLEN 8294400
16-55-47-840| [ gm] [ 9.860118] Use /lib/ui32.so.
16-55-47-840| [ gm] [ 9.920660] Unpack /bootmedia/packages/pi2-alsa.
16-55-47-840| [ gm] [ 10.038023] modprobe snd-bcm2835.
16-55-47-840| [ gm] [ 10.073133] modprobe snd-usb-audio.
16-55-47-840| [ KERNEL] [ 10.446807] random: nonblocking pool is initialized
16-55-47-848| Connection from wtc.exe at 192.168.0.96.
16-56-36-005| /--- FILE "/proc/asound/devices" -----------------------
16-56-36-021| | 0: [ 0] : control
16-56-36-021| | 16: [ 0- 0]: digital audio playback
16-56-36-036| | 17: [ 0- 1]: digital audio playback
16-56-36-036| | 32: [ 1] : control
16-56-36-036| | 33: : timer
16-56-36-052| | 56: [ 1- 0]: digital audio capture
16-56-36-052| \----------------------------------------------------
16-56-36-052| [ KERNEL] [ 60.111028] usbcore: registered new interface driver snd-usb-audio
16-56-36-067| [ gm] [ 60.105226] /dev/snd/pcmC1D0c character device.
16-56-36-067| [ gm] [ 60.105362] /dev/snd/controlC1 character device.
16-56-36-067| [ gm] [ 60.105490] /dev/snd/pcmC0D1p character device.
16-56-36-067| [ gm] [ 60.105593] /dev/snd/pcmC0D0p character device.
16-56-36-083| [ gm] [ 60.105678] /dev/snd/controlC0 character device.
16-56-36-083| [ gm] [ 60.105776] /dev/snd/timer character device.
16-56-36-083| [ gm] [ 60.105851] Preconfigure ALSA.
16-56-36-083| [ gm] [ 60.105954] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
16-56-36-099| [ gm] [ 60.106040] Run sound daemon.
16-56-36-099| [ gm] [ 60.106163] Run '/sbin/rdpsnd 1 0 100 0 -1', log '', env '', pid ''.
16-56-36-114| [ gm] [ 60.106286] Run '/sbin/rdpdr[usb] 0ac8:3500', log '/tmp/rdpdr[usb].out', env '', pid ''.
16-56-36-114| [ pfac] [ 60.110287] Run /sbin/rdpsnd sndvol 100 100 50.
16-56-36-114| [ pfac] [ 60.110711] Ok, PID 618.
16-56-36-114| [ pfac] [ 60.110863] Run /sbin/rdpsnd 1 0 100 0 -1.
16-56-36-130| [ pfac] [ 60.111105] Ok, PID 619.
16-56-36-130| [ pfac] [ 60.111247] Run /sbin/rdpdr[usb] 0ac8:3500.
16-56-36-130| [ pfac] [ 60.111567] Ok, PID 620.
16-56-36-130| [ gm] [ 60.124466] Run '/sbin/resolver 0x15009b0 dns [192.168.0.3]', log '', env '', pid ''.
16-56-36-145| [ pfac] [ 60.124651] Run /sbin/resolver 0x15009b0 dns [192.168.0.3].
16-56-36-145| [ pfac] [ 60.125114] Ok, PID 621.
16-56-36-145| [ gm] [ 60.125287] Nobody can control terminal by VNC.
16-56-36-161| [ rdpsnd] [ 60.132359] RDP Sound Redirector, WTware v.5.4.62/RPi.
16-56-36-161| [ pfac] [ 60.134808] Process pid 621 terminated, status 00000000.
16-56-36-161| [rdpdr-usb 0ac8:3500] [ 60.139295] RDP USB Redirector, WTware v.5.4.62/RPi
16-56-36-177| [ gm] [ 60.145241] 192.168.0.3 => 192.168.0.3.
16-56-36-177| [ gm] [ 60.145412] Free ram before fork terminal client /sbin/rdpclient (session 1): 917516 Kb.
16-56-36-177| [ gm] [ 60.145512] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
16-56-36-177| [ pfac] [ 60.145601] Run /sbin/rdpclient 1.
16-56-36-192| [ pfac] [ 60.146599] Ok, PID 623.
16-56-36-192| [rdpdr-usb 0ac8:3500] [ 60.147413] Device connected.
16-56-36-192| [ rdpsnd] [ 60.153949] Card 'ALSA'/'bcm2835 ALSA'.
16-56-36-192| [ rdpsnd] [ 60.154109] Mixer name: 'Broadcom Mixer'.
16-56-36-208| [ rdpsnd] [ 60.154200] Components: ''.
16-56-36-208| [ rdpsnd] [ 60.154290] Controls: 6.
16-56-36-223| [ rdpsnd] [ 60.154378] ALSA: control 'PCM Playback Volume'.
16-56-36-223| [ rdpsnd] [ 60.154463] ALSA: control 'PCM Playback Switch'.
16-56-36-223| [ rdpsnd] [ 60.154546] ALSA: control 'PCM Playback Route'.
16-56-36-223| [ rdpsnd] [ 60.154627] ALSA: control 'IEC958 Playback Default'.
16-56-36-239| [ rdpsnd] [ 60.155001] ALSA: control 'IEC958 Playback Con Mask'.
16-56-36-239| [ rdpsnd] [ 60.155099] ALSA: control 'IEC958 Playback PCM Stream'.
16-56-36-239| [ rdpsnd] [ 60.155178] Inactive control IEC958 Playback PCM Stream'.
16-56-36-239| [ sndvol] [ 60.157102] Card 'ALSA'/'bcm2835 ALSA'.
16-56-36-255| [ rdpclient 623] [ 60.157163] RDP Terminal Client, WTware v.5.4.62/RPi, pipe 1, pid 623.
16-56-36-255| [ sndvol] [ 60.157267] Mixer name: 'Broadcom Mixer'.
16-56-36-270| [ sndvol] [ 60.157361] Components: ''.
16-56-36-270| [ sndvol] [ 60.157446] Controls: 6.
16-56-36-270| [ sndvol] [ 60.157520] ALSA: control 'PCM Playback Volume'.
16-56-36-270| [ sndvol] [ 60.157600] ALSA: control 'PCM Playback Switch'.
16-56-36-286| [ sndvol] [ 60.157677] ALSA: control 'PCM Playback Route'.
16-56-36-286| [ sndvol] [ 60.157768] ALSA: control 'IEC958 Playback Default'.
16-56-36-286| [ sndvol] [ 60.157868] ALSA: control 'IEC958 Playback Con Mask'.
16-56-36-286| [ sndvol] [ 60.157951] ALSA: control 'IEC958 Playback PCM Stream'.
16-56-36-301| [ sndvol] [ 60.158030] Inactive control IEC958 Playback PCM Stream'.
16-56-36-301| [ sndvol] [ 60.158106] Card 'Camera'/'A4 TECH A4 TECH HD PC Camera at usb-3f980000.usb-1.4, high speed'.
16-56-36-317| [ sndvol] [ 60.158329] Mixer name: 'USB Mixer'.
16-56-36-317| [ sndvol] [ 60.158500] Components: 'USB0ac8:3500'.
16-56-36-317| [ sndvol] [ 60.158591] Controls: 3.
16-56-36-317| [ rdpclient 623] [ 60.158943] Use /lib/ui32.so.
16-56-36-333| [ sndvol] [ 60.159167] ALSA: control 'Capture Channel Map'.
16-56-36-333| [ sndvol] [ 60.159295] ALSA: control 'Mic Capture Switch'.
16-56-36-333| [ sndvol] [ 60.159386] ALSA: control 'Mic Capture Volume'.
16-56-36-333| [ rdpclient 623] [ 60.161232] Redirect sound.
16-56-36-348| [ pfac] [ 60.161723] Process pid 618 terminated, status 00000000.
16-56-36-348| [ rdpclient 623] [ 60.161841] Make RDP session with 192.168.0.3, port 3389.
16-56-36-364| [ rdpclient 623] [ 60.161949] No username.
16-56-36-364| [ rdpclient 623] [ 60.162032] No password.
16-56-36-364| [ rdpclient 623] [ 60.162110] No PIN.
16-56-36-364| [ rdpclient 623] [ 60.162269] No domain.
16-56-36-379| [ rdpclient 623] [ 60.162365] No shell.
16-56-36-379| [ rdpclient 623] [ 60.162446] No directory.
16-56-36-379| [ rdpclient 623] [ 60.162563] Window: 1920x1080@24.
16-56-36-379| [ rdpclient 623] [ 60.162677] PFlags 0x0000002F.
16-56-36-395| [ rdpclient 623] [ 60.162762] Keyboard 00000409:00000000.
16-56-36-395| [ rdpclient 623] [ 60.162839] My hostname "wtwB827EB6A5311".
16-56-36-411| [ rdpclient 623] [ 60.162914] TCP: connecting to 192.168.0.3:3389.
16-56-36-411| [ rdpclient 623] [ 60.168592] TCP: connection with 192.168.0.3:3389 established.
16-56-36-411| [ rdpclient 623] [ 60.168709] Turn keepalive on.
16-56-36-411| [ rdpclient 623] [ 60.169964] Free ram after buffers allocation: 917244 KB.
16-56-36-426| [ rdpclient 623] [ 60.177974] Process RDP server certificate.
16-56-36-426| [ rdpclient 623] [ 60.178193] RDP5 encryption (X.509).
16-56-36-426| [ rdpclient 623] [ 60.209221] Enable font smoothing.
16-56-36-426| [ rdpclient 623] [ 60.281257] 32-bit color.
16-56-52-941| [ rdpclient 623] [ 77.035427] errorInfo 0x00000000.
16-56-53-159| [ rdpclient 623] [ 77.094792] SessionId 0x0000000c: TERMINAL\Администратор.
Re: Вебка и флешка
C виндовса через mstsc.exe на тот же сервер под тем же юзером эта же вебка хорошо пробросилась?
