GFX pipe closed
Александр Тюлин
GFX pipe closed
Сообщение Александр Тюлин »
У сотрудника постоянно после нескольких звонков выводится сообщение GFX pipe closed
Не могу найти где ту прикрепить весь лог, по этому скидываю часть текстом, сама ошибка в самом низу:
11-36-36-920| Media streams established with "4591" <sip:4591@10.10.60.16> for call 18 (audio).
11-36-36-920| [ gm] [ 5299.683810] linphonec state LinphoneCallConnected id 18.
11-36-36-936| [ gm] [ 5299.686136] linphonec state LinphoneCallStreamsRunning id 18.
11-36-36-936| [ gm] [ 5299.686168] ui.cpp ( 2928): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-936| [ gm] [ 5299.686190] textInputLine.cpp ( 118): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-936| [ gm] [ 5299.686206] ui.cpp ( 2928): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-936| [ gm] [ 5299.686222] textInputLine.cpp ( 130): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-936| [ gm] [ 5299.686237] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-952| [ gm] [ 5299.686253] ui.cpp ( 2943): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-952| [ gm] [ 5299.686269] imgbuf.cpp ( 298): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686302] imgbuf.cpp ( 347): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686318] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686334] ui.cpp ( 2973): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686349] textInputLine.cpp ( 198): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686364] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686379] ui.cpp ( 2993): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686395] textInputLine.cpp ( 199): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686410] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686425] ui.cpp ( 2973): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686440] textInputLine.cpp ( 200): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686455] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686477] ui.cpp ( 2993): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686493] textInputLine.cpp ( 201): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686508] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686524] ui.cpp ( 2973): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686539] textInputLine.cpp ( 202): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686554] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686569] ui.cpp ( 2993): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-36-967| [ gm] [ 5299.686585] textInputLine.cpp ( 203): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-36-40-936| [ SIP] [ 5303.715874] linphonec> Receiving command 'terminate'
11-36-40-999| [ SIP] [ 5303.723651] Call ended
11-36-40-999| [ SIP] [ 5303.734270] linphonec> Call 18 with "4591" <sip:4591@10.10.60.16> ended (No error).
11-36-40-999| [ gm] [ 5303.734343] SIP terminate: Call 18 with "4591" <sip:4591@10.10.60.16> ended (No error).
11-36-40-999| [ gm] [ 5303.735073] linphonec state LinphoneCallEnd id 18.
11-36-41-061| [ gm] [ 5303.777409] linphonec state LinphoneCallReleased id 18.
11-37-34-810| [ SIP] [ 5357.592470] linphonec> "4591" <sip:4591@10.10.60.16> is contacting you.
11-37-34-873| [ SIP] [ 5357.592493] linphonec> Receiving new incoming call from "4591" <sip:4591@10.10.60.16>, assigned id 19
11-37-34-873| [ gm] [ 5357.593348] linphonec state LinphoneCallIncomingReceived id 0.
11-37-34-873| [ gm] [ 5357.593381] SIP: incoming call from ["4591" <sip:4591@10.10.60.16>]
11-37-34-873| [ gm] [ 5357.600178] Activate SIP syspopup for "4591" <sip:4591@10.10.60.16>.
11-37-36-935| [ SIP] [ 5359.700144] Receiving command 'answer'
11-37-36-951| [ SIP] [ 5359.722940] Connected.
11-37-36-951| [ SIP] [ 5359.722956] linphonec> Call 19 with "4591" <sip:4591@10.10.60.16> connected.
11-37-36-966| [ SIP] [ 5359.724060] Media streams established with "4591" <sip:4591@10.10.60.16> for call 19 (audio).
11-37-36-966| [ gm] [ 5359.724185] SIP answer: Call 19 with "4591" <sip:4591@10.10.60.16> connected.
11-37-36-966| Media streams established with "4591" <sip:4591@10.10.60.16> for call 19 (audio).
11-37-36-966| [ gm] [ 5359.724553] linphonec state LinphoneCallConnected id 19.
11-37-36-966| [ gm] [ 5359.726794] linphonec state LinphoneCallStreamsRunning id 19.
11-37-36-966| [ gm] [ 5359.726826] ui.cpp ( 2928): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-982| [ gm] [ 5359.726844] textInputLine.cpp ( 118): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-982| [ gm] [ 5359.726860] ui.cpp ( 2928): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-982| [ gm] [ 5359.726875] textInputLine.cpp ( 130): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-982| [ gm] [ 5359.726891] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-982| [ gm] [ 5359.726906] ui.cpp ( 2943): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-982| [ gm] [ 5359.726922] imgbuf.cpp ( 298): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-982| [ gm] [ 5359.726954] imgbuf.cpp ( 347): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-982| [ gm] [ 5359.726970] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.726986] ui.cpp ( 2973): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727001] textInputLine.cpp ( 198): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727017] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727032] ui.cpp ( 2993): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727047] textInputLine.cpp ( 199): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727062] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727078] ui.cpp ( 2973): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727093] textInputLine.cpp ( 200): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727108] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727130] ui.cpp ( 2993): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727147] textInputLine.cpp ( 201): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727162] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727178] ui.cpp ( 2973): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727193] textInputLine.cpp ( 202): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727208] imgbuf.h ( 91): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727223] ui.cpp ( 2993): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-37-36-998| [ gm] [ 5359.727239] textInputLine.cpp ( 203): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-40-10-557| [ SIP] [ 5513.345972] linphonec> warning: The echo canceller started acting funny and got slapped (reset). It swears it will behave now.
11-41-29-915| [ SIP] [ 5592.700197] Receiving command 'terminate'
11-41-29-978| [ SIP] [ 5592.718559] Call ended
11-41-29-978| [ gm] [ 5592.725908] SIP terminate: Call 19 with "4591" <sip:4591@10.10.60.16> ended (No error).
11-41-29-978| [ SIP] [ 5592.725935] linphonec> Call 19 with "4591" <sip:4591@10.10.60.16> ended (No error).
11-41-29-978| [ gm] [ 5592.726492] linphonec state LinphoneCallEnd id 19.
11-41-30-025| [ gm] [ 5592.770021] linphonec state LinphoneCallReleased id 19.
11-42-04-524| [rdpclient 1103] [ 5627.311370] Sound redirection: 44100 frames per second.
11-42-04-790| [rdpclient 1103] [ 5627.584559] rdpclient-rdpsnd.cpp ( 462): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-42-04-852| [rdpclient 1103] [ 5627.584602] Caught signal SIGSEGV.
11-42-04-852| [ gm] [ 5627.584694] TSClientSession.h ( 42): -- ERROR -- GFX pipe closed.
11-42-04-852| [ pfac] [ 5627.592144] Process pid 1103 terminated, status 00000009.
11-42-04-852| [ gm] [ 5627.595333] Final message: GFX pipe closed.
Re: GFX pipe closed
Убери sound=on из конфига.
Александр Тюлин
Re: GFX pipe closed
Одновременно linphone и звук с терминального сервера работать не могут?
Re: GFX pipe closed
Да.
Александр Тюлин
Re: GFX pipe closed
Как тогда правильно совместить linphone и звук с терминального сервера ?
Re: GFX pipe closed
Никак :(
Александр Тюлин
Re: GFX pipe closed
Возможно ли тогда подключить два звуковых устройства и отдельно прокинуть lin к примеру на hw:0 а rdp звук на hw:1?
Re: GFX pipe closed
Да. У параметра SIP= два ключика есть ring: и talk: Первый указывает, куда звонить, второй - через что разговаривать. Можно ring: и talk: зарулить на одно и то же устройство, а sound= зарулить на другое устройство, тогда конфликта локального телефона с перенаправленным с виндовса звуком не случится.
Читайте доку, она рулез: https://wtware.ru/docs5/sound.html
olmer
Re: GFX pipe closed
Сообщение olmer »
Добрый день. Если linphone не используется вообще, при этом ошибка появляется. Почему?
Re: GFX pipe closed
Лог покажи. Лог сохраняй после ошибки. https://wtware.ru/logs.html
olmer
Re: GFX pipe closed
Сообщение olmer »
Вот лог после ошибки
GFX.rar
(40.21 КБ) 790 скачиваний
Re: GFX pipe closed
Оно в память упирается, ключевое влово в логе: "invoked oom-killer". "oom" здесь это Out Of Memory.
Новый кодек графики весьма прожорлив к памяти, а на машине всего "111MB LOWMEM available" (наверное, всего 128 мегабайт, но 16 отъедено под видеопамять).
Надо научить втварь, что если на машине 128 мегабайт, то новый модный кодек использовать нельзя...
Добавь памяти и оно должно вылечиться.
Re: GFX pipe closed
Спасибо за ответ. Добавить памяти нельзя. Можете сказать какая версия прошивки будет работать с таким объёмом памяти без нареканий?
Re: GFX pipe closed
http://pxe.ru/files/testing/201706231744.zip
Добавил проверку, чтобы без двух сотен мегабайт новая модная графика не запускалась.
olmer
Re: GFX pipe closed
Сообщение olmer »
Попробовал, пишет ошибку INTERNAL ERROR. Может быть можно поправить? Заранее спасибо...
Re: GFX pipe closed
Может быть можно показать новый лог?
olmer
Re: GFX pipe closed
Сообщение olmer »
Новый лог показать не могу т.к. не загружается тонкий клиент. На экране написано
ОШИБКА:INTERNAL ERROR
File:setup.cpp
Line:35
и все, дальше загрузка не идет
Re: GFX pipe closed
1. https://wtware.ru/logs.html
Ближе к концу меотдички раздел "Получение лога, когда нет сети, непосредственно на терминале".
2. Как втварь оказалась установленной на диске?
olmer
Re: GFX pipe closed
Сообщение olmer »
1. С самого терминала получить лог не удаётся
2. Установка с флешки
Re: GFX pipe closed
olmer писал(а):1. С самого терминала получить лог не удаётся
Мы не решим проблему с такими односложными ответами. Надо подробно описать каждое своё действие, начиная с "подключаю флешку", и до "вижу экран с ошибкой". Пунктов хотя бы на пятнадцать.
И между "cat" и "/tmp/all.log" надо поставить пробел. "cat" это команда, а "/tmp/all.log" - файл, который она распечатывает.
olmer
Re: GFX pipe closed
Сообщение olmer »
Порядок действий такой:
1. В БИОС тонкого клиента установлена загрузка с USB
2. Подключаю флешку и выбираю установить
3. Появляется предупреждение, что будут удалены все данные, нажимаю Y
4. Начинается установка с флешки, на экране появляются названия модулей, которые устанавливаются в данный момент.
5. Всё это продолжается около 2-х часов, после чего появляется эта ошибка
6. Пробел помог, прилагаю несколько фоток монитора, если не устроит качество, попробую переснять получше. Так же фотки отправил на почту.
Re: GFX pipe closed
olmer писал(а):5. Всё это продолжается около 2-х часов, после чего появляется эта ошибка
Не отключаешь флешку, не перегружаешь, не меняешь настройку БИОСа, ошибка появляется во время установке с флешки на жесткий диск?
И я должен был догадаться об этом по тексту "не загружается тонкий клиент"?
Сдаюсь. Не сможем исправить проблему. Мои способности телепатии слишком слабы.
olmer
Re: GFX pipe closed
Сообщение olmer »
1. Флешку отключал и не отключал - никак не повлияло - ошибка появляется
2. Настройки БИОСа не менял
3. С перезагрузкой так же пробовал разные варианты, перезагружал и не перезагружал, никак не повлияло, ошибка появляется
4. Ошибка появляется в процессе установки с флешки на жесткий диск.
Re: GFX pipe closed
Мне нужно описание каждого действия, начиная от "вставил флешку" до "на экране ошибка". Если текст писать тяжело - подойдут фотки экрана. Но КАЖДОГО действия, ничего не пропускать. Никаких "отключал и не отключал", никаких "пробовал разные варианты". Один вариант, приводящий к ошибке, не пропуская ни одного своего действия и ни одного экрана.
