Помогите загрузиться через pxe
vitaminkvl
Сообщение vitaminkvl »
DHCP на микротике нужные опции прописал. Сервер WTFTP родной версии 5.6.24. Пробую загрузить клиента на VirtualBox. заткунлся вот тут.
16-02-11-947| [192.168.0.66] RRQ 45 bytes:
16-02-11-951| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 77 74 77 61 72 65 2e 70 78
16-02-11-952| [192.168.0.66] 00000010: 65 00 6f 63 74 65 74 00 62 6c 6b 73 69 7a 65 00
16-02-11-955| [192.168.0.66] 00000020: 31 34 33 32 00 74 73 69 7a 65 00 30 00
16-02-11-955| [192.168.0.66] Request block size 1432, interface MTU 1500.
16-02-11-958| [192.168.0.66] "5.6.24\wtware.pxe": tsize is requested, blksize 1432 bytes.
16-02-11-959| [192.168.0.66] "5.6.24\wtware.pxe": "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\wtware.pxe".
16-02-11-962| [192.168.0.66] "5.6.24\wtware.pxe": completed.
16-02-11-962| [192.168.0.66] RRQ 71 bytes:
16-02-11-966| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 35 35 31 35 34 66 31 37 2d
16-02-11-966| [192.168.0.66] 00000010: 62 65 30 64 2d 34 62 39 37 2d 61 38 32 30 2d 39
16-02-11-969| [192.168.0.66] 00000020: 33 62 64 32 63 36 39 39 64 37 30 00 6f 63 74 65
16-02-11-970| [192.168.0.66] 00000030: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
16-02-11-974| [192.168.0.66] 00000040: 65 00 31 34 30 38 00
16-02-11-974| [192.168.0.66] Request block size 1408, interface MTU 1500.
16-02-11-978| [192.168.0.66] "5.6.24\55154f17-be0d-4b97-a820-93bd2c699d70": tsize is requested, blksize 1408 bytes.
16-02-11-978| [192.168.0.66] "5.6.24\55154f17-be0d-4b97-a820-93bd2c699d70": file not found: "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\55154f17-be0d-4b97-a820-93bd2c699d70".
16-02-11-982| [192.168.0.66] RRQ 55 bytes:
16-02-11-982| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 30 31 2d 30 38 2d 30 30 2d
16-02-11-986| [192.168.0.66] 00000010: 32 37 2d 39 64 2d 31 31 2d 65 34 00 6f 63 74 65
16-02-11-986| [192.168.0.66] 00000020: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
16-02-11-990| [192.168.0.66] 00000030: 65 00 31 34 30 38 00
16-02-11-990| [192.168.0.66] Request block size 1408, interface MTU 1500.
16-02-11-994| [192.168.0.66] "5.6.24\01-08-00-27-9d-11-e4": tsize is requested, blksize 1408 bytes.
16-02-11-994| [192.168.0.66] "5.6.24\01-08-00-27-9d-11-e4": file not found: "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\01-08-00-27-9d-11-e4".
16-02-11-997| [192.168.0.66] RRQ 43 bytes:
16-02-11-997| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 43 30 41 38 30 30 34 32 00
16-02-12-001| [192.168.0.66] 00000010: 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c
16-02-12-002| [192.168.0.66] 00000020: 6b 73 69 7a 65 00 31 34 30 38 00
16-02-12-005| [192.168.0.66] Request block size 1408, interface MTU 1500.
16-02-12-006| [192.168.0.66] "5.6.24\C0A80042": tsize is requested, blksize 1408 bytes.
16-02-12-009| [192.168.0.66] "5.6.24\C0A80042": file not found: "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\C0A80042".
16-02-12-010| [192.168.0.66] RRQ 42 bytes:
16-02-12-014| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 43 30 41 38 30 30 34 00 6f
16-02-12-014| [192.168.0.66] 00000010: 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b
16-02-12-018| [192.168.0.66] 00000020: 73 69 7a 65 00 31 34 30 38 00
16-02-12-019| [192.168.0.66] Request block size 1408, interface MTU 1500.
16-02-12-022| [192.168.0.66] "5.6.24\C0A8004": tsize is requested, blksize 1408 bytes.
16-02-12-023| [192.168.0.66] "5.6.24\C0A8004": file not found: "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\C0A8004".
16-02-12-026| [192.168.0.66] RRQ 41 bytes:
16-02-12-027| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 43 30 41 38 30 30 00 6f 63
16-02-12-030| [192.168.0.66] 00000010: 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73
16-02-12-030| [192.168.0.66] 00000020: 69 7a 65 00 31 34 30 38 00
16-02-12-034| [192.168.0.66] Request block size 1408, interface MTU 1500.
16-02-12-034| [192.168.0.66] "5.6.24\C0A800": tsize is requested, blksize 1408 bytes.
16-02-12-038| [192.168.0.66] "5.6.24\C0A800": file not found: "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\C0A800".
16-02-12-038| [192.168.0.66] RRQ 40 bytes:
16-02-12-042| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 43 30 41 38 30 00 6f 63 74
16-02-12-042| [192.168.0.66] 00000010: 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69
16-02-12-045| [192.168.0.66] 00000020: 7a 65 00 31 34 30 38 00
16-02-12-046| [192.168.0.66] Request block size 1408, interface MTU 1500.
16-02-12-049| [192.168.0.66] "5.6.24\C0A80": tsize is requested, blksize 1408 bytes.
16-02-12-049| [192.168.0.66] "5.6.24\C0A80": file not found: "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\C0A80".
16-02-12-053| [192.168.0.66] RRQ 39 bytes:
16-02-12-053| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 43 30 41 38 00 6f 63 74 65
16-02-12-057| [192.168.0.66] 00000010: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
16-02-12-057| [192.168.0.66] 00000020: 65 00 31 34 30 38 00
16-02-12-061| [192.168.0.66] Request block size 1408, interface MTU 1500.
16-02-12-062| [192.168.0.66] "5.6.24\C0A8": tsize is requested, blksize 1408 bytes.
16-02-12-065| [192.168.0.66] "5.6.24\C0A8": file not found: "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\C0A8".
16-02-12-065| [192.168.0.66] RRQ 38 bytes:
16-02-12-069| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 43 30 41 00 6f 63 74 65 74
16-02-12-069| [192.168.0.66] 00000010: 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65
16-02-12-073| [192.168.0.66] 00000020: 00 31 34 30 38 00
16-02-12-074| [192.168.0.66] Request block size 1408, interface MTU 1500.
16-02-12-077| [192.168.0.66] "5.6.24\C0A": tsize is requested, blksize 1408 bytes.
16-02-12-077| [192.168.0.66] "5.6.24\C0A": file not found: "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\C0A".
16-02-12-081| [192.168.0.66] RRQ 37 bytes:
16-02-12-081| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 43 30 00 6f 63 74 65 74 00
16-02-12-085| [192.168.0.66] 00000010: 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00
16-02-12-085| [192.168.0.66] 00000020: 31 34 30 38 00
16-02-12-089| [192.168.0.66] Request block size 1408, interface MTU 1500.
16-02-12-089| [192.168.0.66] "5.6.24\C0": tsize is requested, blksize 1408 bytes.
16-02-12-093| [192.168.0.66] "5.6.24\C0": file not found: "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\C0".
16-02-12-093| [192.168.0.66] RRQ 36 bytes:
16-02-12-097| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 43 00 6f 63 74 65 74 00 74
16-02-12-097| [192.168.0.66] 00000010: 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31
16-02-12-101| [192.168.0.66] 00000020: 34 30 38 00
16-02-12-102| [192.168.0.66] Request block size 1408, interface MTU 1500.
16-02-12-105| [192.168.0.66] "5.6.24\C": tsize is requested, blksize 1408 bytes.
16-02-12-106| [192.168.0.66] "5.6.24\C": file not found: "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\C".
16-02-12-109| [192.168.0.66] RRQ 42 bytes:
16-02-12-110| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 70 78 65 2e 63 66 67 00 6f
16-02-12-114| [192.168.0.66] 00000010: 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b
16-02-12-114| [192.168.0.66] 00000020: 73 69 7a 65 00 31 34 30 38 00
16-02-12-118| [192.168.0.66] Request block size 1408, interface MTU 1500.
16-02-12-118| [192.168.0.66] "5.6.24\pxe.cfg": tsize is requested, blksize 1408 bytes.
16-02-12-123| [192.168.0.66] "5.6.24\pxe.cfg": "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\pxe.cfg".
16-02-12-128| [192.168.0.66] "5.6.24\pxe.cfg": completed.
16-02-12-132| [192.168.0.66] RRQ 50 bytes:
16-02-12-136| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 70 61 63 6b 61 67 65 73 2f
16-02-12-137| [192.168.0.66] 00000010: 6b 65 72 6e 65 6c 00 6f 63 74 65 74 00 74 73 69
16-02-12-140| [192.168.0.66] 00000020: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
16-02-12-141| [192.168.0.66] 00000030: 38 00
16-02-12-145| [192.168.0.66] Request block size 1408, interface MTU 1500.
16-02-12-149| [192.168.0.66] "5.6.24\packages\kernel": tsize is requested, blksize 1408 bytes.
16-02-12-150| [192.168.0.66] "5.6.24\packages\kernel": "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\packages\kernel".
16-02-12-154| [192.168.0.66] "5.6.24\packages\kernel": completed.
16-02-12-155| [192.168.0.66] RRQ 50 bytes:
16-02-12-158| [192.168.0.66] 00000000: 35 2e 36 2e 32 34 5c 70 61 63 6b 61 67 65 73 2f
16-02-12-158| [192.168.0.66] 00000010: 69 6e 69 74 72 64 00 6f 63 74 65 74 00 74 73 69
16-02-12-163| [192.168.0.66] 00000020: 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31 34 30
16-02-12-163| [192.168.0.66] 00000030: 38 00
16-02-12-167| [192.168.0.66] Request block size 1408, interface MTU 1500.
16-02-12-167| [192.168.0.66] "5.6.24\packages\initrd": tsize is requested, blksize 1408 bytes.
16-02-12-171| [192.168.0.66] "5.6.24\packages\initrd": "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.24\packages\initrd".
16-02-12-319| [192.168.0.66] "5.6.24\packages\initrd": completed.
на клиенте в итоге вот такая картинка. Не понимаю что клиент скачать то не может в итоге???
Re: Помогите загрузиться через pxe
vitaminkvl писал(а): Пн фев 12, 2018 4:08 pm DHCP на микротике нужные опции прописал.
В этом месте стоило приложить скриншоты "нужных опций".
vitaminkvl писал(а): Пн фев 12, 2018 4:08 pm на клиенте в итоге вот такая картинка. Не понимаю что клиент скачать то не может в итоге???
Полезнее спрашивать не "что не может скачать", а "откуда не может скачать и зачем туда лезет". Надо понять, что терминалу отвечает DHCP.
В виртуалбоксе, после сообщения об ошибке, из командной строки:
Скриншот.
Shift-PageUp.
Скриншот.
Повторять раза три, скриншоты выложить.
vitaminkvl
в микротике next-server и option 66 указывают на сервер wtftp, в option 67 прописано '5.6.24\wtware.pxe'. Я так понимаю если чтото в dhcp указал не так то вообще до загрузки не доходило бы, а так в логах же чтото грузится с wtftp. Логи с /tmp/all.log он не весь а с места про dhcp
vitaminkvl
почемуто 3я картинка не влезает в один пост, последовательность по названию картинок
vitaminkvl писал(а): Вт фев 13, 2018 9:34 am в микротике next-server и option 66 указывают на сервер wtftp
192.168.200.125 - это правильный IP сервера с wtftp? Он другой подсети?
Пинг с этого сервера на 192.168.0.66 идет?
vitaminkvl
Спасибо все заработало, глаз замылился второй день уже смотрю в книгу вижу не то что надо ))
vitaminkvl
Тестируем WTware на 4х машинах из 5и запускается и все хорошо, но вот на одной никак не хочет . в логах сервера вот такое, на клиенте ошибка приема файлов в виде "крякозябры" Malformed RRQ.Csйцук .. . Может быть проблемы из за версий самого PXE ? Realtek GBE v 2.3 PXE -2.1 built 083.
11-50-50-252| [TFTP] 00000380: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
11-50-50-252| [TFTP] 00000390: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
11-50-50-255| [TFTP] 000003a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
11-50-50-255| [TFTP] 000003b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
11-50-50-257| [TFTP] 000003c0: ff ff ff ff ff 00 6f 63 74 65 74 00 74 73 69 7a
11-50-50-258| [TFTP] 000003d0: 65 00 30 00
11-50-50-260| [TFTP] Sending ERR 4, message "Malformed RRQ.".
11-50-50-260| [TFTP] RRQ 985 bytes:
11-50-50-263| [TFTP] 00000000: 35 2e 36 2e 32 34 2f 77 74 77 61 72 65 2e 70 78
11-50-50-263| [TFTP] 00000010: 65 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
11-50-50-266| [TFTP] 00000020: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
11-50-50-266| [TFTP] 00000030: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
11-50-50-268| [TFTP] 00000040: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
11-50-50-269| [TFTP] 00000050: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
11-50-50-346| [TFTP] 000003b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
11-50-50-348| [TFTP] 000003c0: ff ff ff ff ff 00 6f 63 74 65 74 00 62 6c 6b 73
11-50-50-348| [TFTP] 000003d0: 69 7a 65 00 31 34 35 36 00
11-50-50-351| [TFTP] Sending ERR 4, message "Malformed RRQ.".
11-51-58-048| [TFTP] RRQ 980 bytes:
11-51-58-051| [TFTP] 00000000: 35 2e 36 2e 32 34 2f 77 74 77 61 72 65 2e 70 78
11-51-58-051| [TFTP] 00000010: 65 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
11-51-58-054| [TFTP] 00000020: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
11-51-58-054| [TFTP] 00000030: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Обновление биоса не помогает?
С каким-нибудь другим DHCP, не микротиковым, такая же проблема?
Так-то понятно, чего он хочет, можно в втваревый tftp ещё один костылик поставить, их там и так гора под такие кривые биосы...
vitaminkvl
aka писал(а): Ср фев 14, 2018 1:08 pm Так-то понятно, чего он хочет, можно в втваревый tftp ещё один костылик поставить, их там и так гора под такие кривые биосы...
Можно по подробней , какой костыль имеете ввиду ???
Мы рассуждаем. Попробуй сосредоточиться на вопросах, которые были заданы тебе.
1. Скачать, распаковать: http://wtware.com/testing/201802140610.zip
2. Запустить втваревый конфигуратор под администратором.
3. Вверху иконка с ключом, "Служба TFTP", остановить службу.
4. Удалить "C:\Program Files (x86)\WTware\Bin\wtftp.exe"
5. Вместо него записать wtftp.exe из архива.
6. В конфигураторе запустить службу.
7. Закрыть админский конфигуратор.
8. Перегрузить незагружавшийся терминал.
Поможет?
vitaminkvl
bios прошил последний , не помогло. Wtftp.exe подменил не помогло. Да пока фиг с ней с этой машиной, другую поставим если все устроит. На тех что заработали пользователи жалуются на тормознутость работы окон в 1с. Тоесть если с одной и тойже машины заходить на рдп сервер с родного клиента микрософт или с wtware то в последнем наблюдаются тормоза. Какие параметры могут влиять на скорость работы клиента wtware ??????
vitaminkvl
Победил наконец, в микротике отключил 66 и 67 опцию в DHCP, оставил только next-server=сервер_с_tftp и bootfilename= 5.6.24/wtware.pxe без ковычек .
vitaminkvl писал(а): Ср фев 14, 2018 3:54 pm Wtftp.exe подменил не помогло.
Не верю. Лог в студию.
aka писал(а): Ср фев 14, 2018 7:24 pm
Так лог на сервере wtftp не поменялся примерно тоже самое , до лога на стороне клиента не доходило вообще просто ошибка передачи с tftp и все . В общем tftp заработал стабильно, теперь надо разбираться на жалобы пользователей по тормознутому поведению окон.
Фейспалм. Не, я так не работаю.
vitaminkvl
aka писал(а): ↑
15 фев 2018, 01:04
Это к чему ??? Я уже очень готов уговорить командование выделить денег на Вашу операционку. А вы вдруг отказываетесь работать.
Смена wttft.exe не поменяла характер ошибок на той машине, все заработало при перенастройке DHCP. Логи на сервере выдавали тоже самое что и со старым wtftp.exe до командной строки на клиенте не доходило чтоб както посмотреть логи на клиенте. Могу вернуть настройки DHCP и точно скопировать лог сервера. Но он ни чем не отличается от поста номер ээээ.. (Ср фев 14, 2018 12:48 pm).
vitaminkvl
Где почитать какие версии RDP поддерживает последняя версия WTware ?????
vitaminkvl писал(а): Чт фев 15, 2018 9:38 am Это к чему ??? ... Логи на сервере выдавали тоже самое что и ...
Это к тому, что я определяю, то же самое в логах или не то же самое. Ты - выполняешь в точности мои инструкции. Или разбираешься самостоятельно, это не сложно.
vitaminkvl
Хорошо так и буду поступать, но этот вопрос уже решен. Теперь стал вопрос про скорость работы rdp клиента , сервера w2008R2 скоро перейдем на 2012r2 , с одного и тогоже рабочего места через родной rdp клиент Win7 и через клиент WTware скорость реакции окон разная , в родном быстрее. Есть ли способы повысить скорость работы окон через Ваш клиент?????
Есть способ: нанимаете системного адмиинстратора, он разбирается.
