Здравствуйте.
Нужно пробросить https://hard.rozetka.com.ua/ua/evromedi ... d/p169168/ , что бы получать изображение с УЗД аппаратов.
Проблема в том, что когда подключить напрямую в сервер- устройство видит и корректно работает, а когда делаю проброс через терминал - проблема, не видит. Лог прикрепляю.
Send broadcast WTCU discover.
[ initrd] [ 9.140389] Disable cache package files.
[ initrd] [ 9.140401] [TFTP] Download and unpack file 5.8.14\packages\lib6 from
[ initrd] [ 9.153557] [TFTP] WTware TFTP v.5.8.14.
[ initrd] [ 11.215919] PCI: C 04:03 8086:a170 Multimedia controller Audio device Intel Corporation Sunrise Point-H HD Audio.
[ initrd] [ 11.215939] PCI: C 06 8086:590f Bridge Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registe.
[ initrd] [ 11.215948] PCI: C 06:04 8086:a118 Bridge PCI bridge Intel Corporation Sunrise Point-H PCI Express Root Port.
[ initrd] [ 11.215957] PCI: C 03 8086:5902 Display controller Intel Corporation HD Graphics 610.
[ initrd] [ 11.215965] PCI: C 0c:03 8086:a12f Serial bus controller USB controller Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller.
[ initrd] [ 11.215973] PCI: C 0c:05 8086:a123 Serial bus controller SMBus Intel Corporation Sunrise Point-H SMBus.
[ initrd] [ 11.215981] PCI: C 01:06 8086:a102 Mass storage controller SATA controller Intel Corporation Sunrise Point-H SATA controller [AHCI mode].
[ initrd] [ 11.215990] PCI: C 05:80 8086:a121 Memory controller Memory controller Intel Corporation Sunrise Point-H PMC.
[ initrd] [ 11.215998] PCI: C 02 10ec:8168 Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller.
[ initrd] [ 11.216011] PCI: C 06:04 8086:a114 Bridge PCI bridge Intel Corporation Sunrise Point-H PCI Express Root Port.
[ initrd] [ 11.216020] PCI: C 06:01 8086:a143 Bridge ISA bridge Intel Corporation Sunrise Point-H LPC Controller.
[ initrd] [ 11.216028] PCI: C 06:04 8086:a119 Bridge PCI bridge Intel Corporation Sunrise Point-H PCI Express Root Port.
[ initrd] [ 11.216036] PCI: C 07:80 8086:a13a Communication controller Communication controller Intel Corporation Sunrise Point-H CSME HECI.
[ initrd] [ 11.222116] USB: 04f3:0235 Elan Microelectronics Corp..
[ initrd] [ 11.222133] USB: 258a:0001 .
[ initrd] [ 11.222142] USB: 1b80:d418 Afatech.
[ pfac] [ 11.222532] Run /sbin/httpd.
[ initrd] [ 11.222543] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[ pfac] [ 11.222553] Ok, PID 923.
[ initrd] [ 11.222562] [TFTP] Download config file Everyone\source.wtc from
[ httpd] [ 11.223116] HTTP Server, WTware 5.8.14
[ initrd] [ 11.225712] [TFTP] Download config file Everyone\list.wtc from
[ initrd] [ 11.227536] [TFTP] Download config file Terminals\18.31.BF.0C.CF.7D\config.wtc from
[ initrd] [ 11.229349] [TFTP] Download config file Terminals\18.31.BF.0C.CF.7D\wtware.lic from
[ initrd] [ 11.230076] [TFTP] Error code 1: File not found..
| display=1920x1080
| managed=
| usb=1b80:d418, debug
| server=
| connection
[ initrd] [ 11.230203] [TFTP] Download config file Everyone\all.wtc from
| [BOM]
| server=
| animation_speed=off
| display=
| keyswitch=alt-shift
| managed=
| onerror=5
[ initrd] [ 11.231982] [TFTP] Download config file Everyone\wtware.lic from
| [BOM]
| server=
| animation_speed=off
| display=1920x1080
| keyswitch=alt-shift
| managed=
| onerror=5
| connection
[ initrd] [ 11.234054] Hostname: "wtw1831BF0CCF7D".
[ initrd] [ 11.332152] [NTP] 42 DHCP option is not set.
can control terminal by RSH.
RSH: listener is active.
[ httpd] [ 11.332451] Reread settings.
[ httpd] [ 11.332498] Everyone can control terminal by HTTP.
[ initrd] [ 11.332889] Use 'video=i915(F)' driver.
| [BOM]
| server=
| animation_speed=off
| display=1920x1080
| keyswitch=alt-shift
| managed=
| onerror=5
| video=i915(F)
| connection
[ initrd] [ 11.333018] [TFTP] Download and unpack file 5.8.14\packages\f from
[ KERNEL] [ 12.440529] random: crng init done
[ initrd] [ 13.666501] [TFTP] Download and unpack file 5.8.14\packages\fwt6 from
[ initrd] [ 14.336625] [TFTP] Download and unpack file 5.8.14\packages\graphic from
[ gm] [ 14.386623] WTware 5.8.14 session manager.
[ gm] [ 14.386794] Load agpgart driver.
[ gm] [ 14.386811] modprobe agpgart.
[ gm] [ 14.387734] modprobe intel-agp.
[ KERNEL] [ 14.387584] Linux agpgart interface v0.103
[ gm] [ 14.388802] Add keyboard event6: SINO WEALTH USB KEYBOARD.
[ gm] [ 14.388819] Add keyboard event5: SINO WEALTH USB KEYBOARD.
[ gm] [ 14.388828] EV_REL flag found. Add mouse event4: OM.
[ gm] [ 14.388837] Ignore event3: PC Speaker.
[ gm] [ 14.420137] Add keyboard event2: Power Button.
[ gm] [ 14.420155] Add keyboard event1: Power Button.
[ gm] [ 14.420164] Add keyboard event0: Sleep Button.
[ gm] [ 14.420174] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 14.601465] modprobe drm.
[ gm] [ 14.603029] Run modprobe i915 modeset=1.
[ gm] [ 14.603048] modprobe i915 modeset=1.
[ KERNEL] [ 14.610527] [drm] Memory usable by graphics device = 2048M
[ KERNEL] [ 14.610529] [drm] Replacing VGA console driver
[ KERNEL] [ 14.610565] Console: switching to colour dummy device 80x25
[ KERNEL] [ 14.616131] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ KERNEL] [ 14.616132] [drm] Driver supports precise vblank timestamp query.
[ KERNEL] [ 14.619556] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_01.bin (v1.1)
[ KERNEL] [ 14.620383] [drm] Initialized i915 1.6.0 20170818 for 0000:00:02.0 on minor 0
[ KERNEL] [ 14.621317] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ KERNEL] [ 14.621495] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7
[ KERNEL] [ 14.674600] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ gm] [ 14.674840] Kernel drm/kms module loaded.
[ gm] [ 14.674854] count_fbs 0.
[ gm] [ 14.674863] count_crtcs 2.
[ gm] [ 14.674872] count_connectors 3.
[ gm] [ 14.674880] count_encoders 3.
[ gm] [ 14.674889] min_width 0, max_width 8192, min_height 0, max_height 8192.
[ gm] [ 14.771608] ======================
[ gm] [ 14.771634] connector_id 48.
[ gm] [ 14.771649] encoder_id 0.
[ gm] [ 14.771663] connector_type HDMIA (11).
[ gm] [ 14.771676] connector_type_id 1.
[ gm] [ 14.771690] connection 2.
[ gm] [ 14.771704] mm_width 0, mm_height 0.
[ gm] [ 14.771717] subpixel 0.
[ gm] [ 14.771731] count_modes 0.
[ gm] [ 14.771744] count_props 6.
[ gm] [ 14.771758] count_encoders 1.
[ gm] [ 14.771771] encoders_ptr [47]
[ gm] [ 14.771784] ======================
[ gm] [ 14.793321] ======================
[ gm] [ 14.793343] connector_id 53.
[ gm] [ 14.793359] encoder_id 0.
[ gm] [ 14.793373] connector_type HDMIA (11).
[ gm] [ 14.793387] connector_type_id 2.
[ gm] [ 14.793400] connection 2.
[ gm] [ 14.793414] mm_width 0, mm_height 0.
[ gm] [ 14.793427] subpixel 0.
[ gm] [ 14.793441] count_modes 0.
[ gm] [ 14.793454] count_props 6.
[ gm] [ 14.793468] count_encoders 1.
[ gm] [ 14.793481] encoders_ptr [52]
[ gm] [ 14.793495] ======================
[ gm] [ 14.798762] ======================
[ gm] [ 14.798779] connector_id 55.
[ gm] [ 14.798793] encoder_id 54.
[ gm] [ 14.798808] connector_type DisplayPort (10).
[ gm] [ 14.798821] connector_type_id 1.
[ gm] [ 14.798835] connection 1.
[ gm] [ 14.798849] mm_width 510, mm_height 290.
[ gm] [ 14.798862] subpixel 0.
[ gm] [ 14.798876] count_modes 12.
[ gm] [ 14.798889] count_props 5.
[ gm] [ 14.798903] count_encoders 1.
[ gm] [ 14.798916] encoders_ptr [54]
[ gm] [ 14.798930] ======================
[ gm] [ 14.798945] ======================
[ gm] [ 14.798959] crtc_id 36.
[ gm] [ 14.798973] fb buffer_id 71.
[ gm] [ 14.798986] x 0, y 0.
[ gm] [ 14.799000] mode_valid 1.
[ gm] [ 14.799015] Mode 1920x1080: clock 148500 H 1920 2008 2052 2200 0 V 1080 1084 1089 1125 0 VR 60 flags 0x0005 type 0x0048.
[ gm] [ 14.799029] gamma_size 256.
[ gm] [ 14.799043] 0 connectors.
[ gm] [ 14.799056] ======================
[ gm] [ 14.799070] ======================
[ gm] [ 14.799084] crtc_id 46.
[ gm] [ 14.799097] fb buffer_id 0 (disconnected from fb).
[ gm] [ 14.799111] x 0, y 0.
[ gm] [ 14.799124] mode_valid 0.
[ gm] [ 14.799139] Mode : clock 0 H 0 0 0 0 0 V 0 0 0 0 0 VR 0 flags 0x0000 type 0x0000.
[ gm] [ 14.799156] gamma_size 256.
[ gm] [ 14.799169] 0 connectors.
[ gm] [ 14.799183] ======================
[ gm] [ 14.799197] ======================
[ gm] [ 14.799211] encoder_id 47.
[ gm] [ 14.799225] encoder_type TMDS (2).
[ gm] [ 14.799238] crtc_id 0.
[ gm] [ 14.799251] possible_crtcs 7.
[ gm] [ 14.799265] possible_clones 1.
[ gm] [ 14.799278] ======================
[ gm] [ 14.799293] ======================
[ gm] [ 14.799306] encoder_id 52.
[ gm] [ 14.799320] encoder_type TMDS (2).
[ gm] [ 14.799333] crtc_id 0.
[ gm] [ 14.799347] possible_crtcs 7.
[ gm] [ 14.799360] possible_clones 2.
[ gm] [ 14.799374] ======================
[ gm] [ 14.799388] ======================
[ gm] [ 14.799401] encoder_id 54.
[ gm] [ 14.799415] encoder_type TMDS (2).
[ gm] [ 14.799428] crtc_id 36.
[ gm] [ 14.799442] possible_crtcs 7.
[ gm] [ 14.799455] possible_clones 4.
[ gm] [ 14.799468] ======================
[ gm] [ 14.799483] Connector Id 55.
[ gm] [ 14.804738] Encoder Id 54.
[ gm] [ 14.804756] CRTC Id 36.
[ gm] [ 14.804770] Force 60Hz refresh.
[ gm] [ 14.804785] Mode 1920x1080: clock 148500 H 1920 2008 2052 2200 0 V 1080 1084 1089 1125 0 VR 60 flags 0x0005 type 0x0048.
[ gm] [ 14.804799] ^^^ Use this mode ^^^.
[ gm] [ 14.804814] Mode 1600x900: clock 108000 H 1600 1624 1704 1800 0 V 900 901 904 1000 0 VR 60 flags 0x0005 type 0x0040.
[ gm] [ 14.804828] Mode 1280x1024: clock 135000 H 1280 1296 1440 1688 0 V 1024 1025 1028 1066 0 VR 75 flags 0x0005 type 0x0040.
[ gm] [ 14.804842] Mode 1280x1024: clock 108000 H 1280 1328 1440 1688 0 V 1024 1025 1028 1066 0 VR 60 flags 0x0005 type 0x0040.
[ gm] [ 14.804857] Mode 1152x864: clock 108000 H 1152 1216 1344 1600 0 V 864 865 868 900 0 VR 75 flags 0x0005 type 0x0040.
[ gm] [ 14.804871] Mode 1024x768: clock 78750 H 1024 1040 1136 1312 0 V 768 769 772 800 0 VR 75 flags 0x0005 type 0x0040.
[ gm] [ 14.804885] Mode 1024x768: clock 65000 H 1024 1048 1184 1344 0 V 768 771 777 806 0 VR 60 flags 0x000a type 0x0040.
[ gm] [ 14.804899] Mode 800x600: clock 49500 H 800 816 896 1056 0 V 600 601 604 625 0 VR 75 flags 0x0005 type 0x0040.
[ gm] [ 14.804914] Mode 800x600: clock 40000 H 800 840 968 1056 0 V 600 601 605 628 0 VR 60 flags 0x0005 type 0x0040.
[ gm] [ 14.804928] Mode 640x480: clock 31500 H 640 656 720 840 0 V 480 481 484 500 0 VR 75 flags 0x000a type 0x0040.
[ gm] [ 14.804942] Mode 640x480: clock 25175 H 640 656 752 800 0 V 480 490 492 525 0 VR 60 flags 0x000a type 0x0040.
[ gm] [ 14.804956] Mode 720x400: clock 28320 H 720 738 846 900 0 V 400 412 414 449 0 VR 70 flags 0x0006 type 0x0040.
[ gm] [ 14.804970] Once more, choose this mode:
[ gm] [ 14.804984] Mode 1920x1080: clock 148500 H 1920 2008 2052 2200 0 V 1080 1084 1089 1125 0 VR 60 flags 0x0005 type 0x0048.
[ gm] [ 14.805007] fb_ptr 0xa749c000
[ gm] [ 14.805022] stride 7680.
[ gm] [ 14.805035] size 8294400.
[ gm] [ 14.805049] handle 0x00000001.
[ gm] [ 14.807613] ======================
[ gm] [ 14.807638] fb_id 0.
[ gm] [ 14.807652] width 1920.
[ gm] [ 14.807665] height 1080.
[ gm] [ 14.807679] pitch 7680.
[ gm] [ 14.807693] bpp 32.
[ gm] [ 14.807706] depth 24.
[ gm] [ 14.807720] handle 0x00000001.
[ gm] [ 14.807733] ======================
[ gm] [ 14.815551] LINELENBYTES 7680, VBUF 0x0xa749c000.
[ gm] [ 14.832330] Use /lib/ui32.so.
[ gm] [ 14.864013] WMEMCOPY: 78300K copied in 0.011798 sec.
[ gm] [ 14.875126] libc: 78300K copied in 0.011053 sec.
[ gm] [ 14.886138] movs: 78300K copied in 0.010967 sec.
[ gm] [ 14.897171] MMX: 78300K copied in 0.010990 sec.
[ gm] [ 14.908124] SSE2: 78300K copied in 0.010911 sec.
[ gm] [ 14.908148] Choose SSE2 memcpy.
[ gm] [ 14.909467] Run '/sbin/rdpdr[usb] 1b80:d418 debug', log '/tmp/rdpdr[usb].out', env '', pid ''.
[ pfac] [ 14.909538] Run /sbin/rdpdr[usb] 1b80:d418 debug.
[ pfac] [ 14.909549] Ok, PID 983.
[rdpdr-usb 1b80:d418] [ 14.909971] RDP USB Redirector, WTware 5.8.14
[rdpdr-usb 1b80:d418] [ 14.909983] [DEBUG] Open listener at /tmp/rdpdr[usb]_1b80:d418. Main thread 0xa7d47700.
[rdpdr-usb 1b80:d418] [ 14.909993] [DEBUG] Init libusb.
[rdpdr-usb 1b80:d418] [ 14.910275] Device connected. USB Id 1b80:d418, bus Id 1-6, BUSNUM 1, DEVNUM 2.
[rdpdr-usb 1b80:d418] [ 14.910289] [DEBUG] Ignore 1d6b:0003.
[rdpdr-usb 1b80:d418] [ 14.910299] [DEBUG] Ignore 258a:0001.
[rdpdr-usb 1b80:d418] [ 14.910308] [DEBUG] Ignore 04f3:0235.
[rdpdr-usb 1b80:d418] [ 14.910317] [DEBUG] Ignore 1d6b:0002.
[ gm] [ 14.912980] Run '/sbin/resolver 0x904d40 dns []', log '', env '', pid ''.
[ pfac] [ 14.913047] Run /sbin/resolver 0x904d40 dns [].
[ pfac] [ 14.913058] Ok, PID 985.
[ gm] [ 14.913084] Nobody can control terminal by VNC.
[ gm] [ 14.913118] Add keyboard event7: Video Bus.
[ pfac] [ 14.913561] Process pid 985 terminated, status 00000000.
[ gm] [ 14.914554]
[ gm] [ 14.915792] Free ram before fork terminal client /sbin/rdpclient-SSE (session 1): 3081524 Kb.
[ gm] [ 14.915812] Run '/sbin/rdpclient-SSE 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 14.915868] Run /sbin/rdpclient-SSE 1.
[ pfac] [ 14.915878] Ok, PID 986.
[ rdpclient 986] [ 14.916618] RDP Terminal Client, WTware 5.8.14, pipe 1, pid 986.
[ rdpclient 986] [ 14.917996] Use /lib/ui32-SSE.so.
[ rdpclient 986] [ 14.918122] Make RDP session with, port 3389.
[ rdpclient 986] [ 14.918145] No username.
[ rdpclient 986] [ 14.918156] No password.
[ rdpclient 986] [ 14.918167] No PIN.
[ rdpclient 986] [ 14.918176] No domain.
[ rdpclient 986] [ 14.918186] No shell.
[ rdpclient 986] [ 14.918195] No directory.
[ rdpclient 986] [ 14.918205] Window: 1856x1080@24.
[ rdpclient 986] [ 14.918214] PFlags 0x0000002F.
[ rdpclient 986] [ 14.918224] Keyboard 00000409:00000000.
[ rdpclient 986] [ 14.918233] My hostname "wtw1831BF0CCF7D".
[ rdpclient 986] [ 14.918243] TCP: connecting to
[ rdpclient 986] [ 14.918528] TCP: connection with established.
[ rdpclient 986] [ 14.918547] Turn keepalive on.
[ rdpclient 986] [ 14.918653] Free ram after buffers allocation: 3080764 KB.
[ rdpclient 986] [ 14.920719] Server supports GFX Pipeline.
[ rdpclient 986] [ 14.922455] Process RDP server certificate.
[ rdpclient 986] [ 14.922472] RDP5 encryption (X.509).
[ rdpclient 986] [ 14.924399] Enable font smoothing and Desktop Composition.
[ rdpclient 986] [ 14.965194] GFX codec.
[ rdpclient 986] [ 15.269733] Run 2 tile threads.
[ KERNEL] [ 15.840449] [drm] RC6 on
[ rdpclient 986] [ 22.199818] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000040.
[ rdpclient 986] [ 22.985872] SessionId 0x00000040:
[rdpdr-usb 1b80:d418] [ 22.998458] [DEBUG] Client connected.
[rdpdr-usb 1b80:d418] [ 22.998475] [DEBUG] Tell Windows device is connected.
[rdpdr-usb 1b80:d418] [ 23.000397] [DEBUG] =======================================================
[rdpdr-usb 1b80:d418] [ 23.000417] [DEBUG] RIMCALL_RELEASE.
[rdpdr-usb 1b80:d418] [ 23.000427] [DEBUG] Composite device (test 2).
[rdpdr-usb 1b80:d418] [ 23.001139] [DEBUG] Serial: '0000000000'.
[rdpdr-usb 1b80:d418] [ 23.001157] [DEBUG] bus Id '1-6'.
[rdpdr-usb 1b80:d418] [ 23.001187] [DEBUG] DeviceInstanceId raw: '\1-61B80D4180000'.
[rdpdr-usb 1b80:d418] [ 23.001199] [DEBUG] DeviceInstanceId 'af5a1c89-e770-0481-089d-a8b94846ffcf'.
[rdpdr-usb 1b80:d418] [ 23.001208] [DEBUG] HardwareIds 'USB\VID_1B80&PID_D418&REV_4001', 'USB\VID_1B80&PID_D418'.
[rdpdr-usb 1b80:d418] [ 23.001217] [DEBUG] CompatibilityIds 95 chars: 'USB\DevClass_00&SubClass_00&Prot_00', 'USB\DevClass_00&SubClass_00', 'USB\DevClass_00'.
[rdpdr-usb 1b80:d418] [ 23.001227] [DEBUG] Add 'USB\COMPOSITE'.
[rdpdr-usb 1b80:d418] [ 23.001236] [DEBUG] ContainerId: '{8f86f458-9927-0577-0ae4-7d8e95661bcc}'.
[rdpdr-usb 1b80:d418] [ 23.001245] [DEBUG] Send 514 bytes to rdpclient.
[rdpdr-usb 1b80:d418] [ 23.001255] 00000000:0100004000000000010100000100000000000000250000006100660035006100 ...@................%...a.f.5.a.
[rdpdr-usb 1b80:d418] [ 23.001264] 00000020:31006300380039002D0065003700370030002D0030003400380031002D003000 1.c.8.9.-.e.7.7.0.-.0.4.8.1.-.0.
[rdpdr-usb 1b80:d418] [ 23.001273] 00000040:3800390064002D00610038006200390034003800340036006600660063006600 8.9.d.-.a.8.b.9.4.8.4.6.f.f.c.f.
[rdpdr-usb 1b80:d418] [ 23.001282] 00000060:0000360000005500530042005C005600490044005F0031004200380030002600 ..6...U.S.B.\.V.I.D._.1.B.8.0.&.
[rdpdr-usb 1b80:d418] [ 23.001292] 00000080:5000490044005F00440034003100380026005200450056005F00340030003000 P.I.D._.D.4.1.8.&.R.E.V._.4.0.0.
[rdpdr-usb 1b80:d418] [ 23.001301] 000000a0:310000005500530042005C005600490044005F00310042003800300026005000 1...U.S.B.\.V.I.D._.1.B.8.0.&.P.
[rdpdr-usb 1b80:d418] [ 23.001311] 000000c0:490044005F004400340031003800000000005F0000005500530042005C004400 I.D._.D.4.1.8....._...U.S.B.\.D.
[rdpdr-usb 1b80:d418] [ 23.001320] 000000e0:6500760043006C006100730073005F0030003000260053007500620043006C00 e.v.C.l.a.s.s._.0.0.&.S.u.b.C.l.
[rdpdr-usb 1b80:d418] [ 23.001329] 00000100:6100730073005F00300030002600500072006F0074005F003000300000005500 a.s.s._.0.0.&.P.r.o.t._.0.0...U.
[rdpdr-usb 1b80:d418] [ 23.001339] 00000120:530042005C0044006500760043006C006100730073005F003000300026005300 S.B.\.D.e.v.C.l.a.s.s._.0.0.&.S.
[rdpdr-usb 1b80:d418] [ 23.001348] 00000140:7500620043006C006100730073005F003000300000005500530042005C004400 u.b.C.l.a.s.s._.0.0...U.S.B.\.D.
[rdpdr-usb 1b80:d418] [ 23.001357] 00000160:6500760043006C006100730073005F003000300000005500530042005C004300 e.v.C.l.a.s.s._.0.0...U.S.B.\.C.
[rdpdr-usb 1b80:d418] [ 23.001366] 00000180:4F004D0050004F00530049005400450000000000270000007B00380066003800 O.M.P.O.S.I.T.E.....'...{.8.f.8.
[rdpdr-usb 1b80:d418] [ 23.001376] 000001a0:360066003400350038002D0039003900320037002D0030003500370037002D00 6.f.4.5.8.-.9.9.2.7.-.0.5.7.7.-.
[rdpdr-usb 1b80:d418] [ 23.001385] 000001c0:30006100650034002D0037006400380065003900350036003600310062006300 0.a.e.4.-.7.d.8.e.9.5.6.6.1.b.c.
[rdpdr-usb 1b80:d418] [ 23.001394] 000001e0:63007D0000001C00000002000000000600000002000000000000010000005000 c.}..........................P.
[rdpdr-usb 1b80:d418] [ 23.001403] 00000200:0000 ..
[rdpdr-usb 1b80:d418] [ 23.001992] [DEBUG] =======================================================
[rdpdr-usb 1b80:d418] [ 23.002009] [DEBUG] QUERY_DEVICE_TEXT
[rdpdr-usb 1b80:d418] [ 23.002019] [DEBUG] DeviceTextDescription, LocaleId 0x00000422.
[rdpdr-usb 1b80:d418] [ 23.002028] [DEBUG] Ask string 2.
[rdpdr-usb 1b80:d418] [ 23.003070] 00000000:260350006F006C00610072006900730020004100560020004300610070007400 &.P.o.l.a.r.i.s. .A.V. .C.a.p.t.
[rdpdr-usb 1b80:d418] [ 23.003088] 00000020:750072006500 u.r.e.
[rdpdr-usb 1b80:d418] [ 23.003098] [DEBUG] Text 'Polaris AV Capture', 19 bytes.
[rdpdr-usb 1b80:d418] [ 23.003107] [DEBUG] Send 54 bytes to rdpclient.
[rdpdr-usb 1b80:d418] [ 23.003116] 00000000:00000080000000001300000050006F006C006100720069007300200041005600 ...........P.o.l.a.r.i.s. .A.V.
[rdpdr-usb 1b80:d418] [ 23.003126] 00000020:20004300610070007400750072006500000000000000 .C.a.p.t.u.r.e.......
[rdpdr-usb 1b80:d418] [ 23.003358] [DEBUG] =======================================================
[rdpdr-usb 1b80:d418] [ 23.003375] [DEBUG] QUERY_DEVICE_TEXT
[rdpdr-usb 1b80:d418] [ 23.003385] [DEBUG] DeviceTextLocationInformation
[rdpdr-usb 1b80:d418] [ 23.003395] [DEBUG] Text 'Port_#0002.Hub_#0001', 21 bytes.
[rdpdr-usb 1b80:d418] [ 23.003404] [DEBUG] Send 58 bytes to rdpclient.
[rdpdr-usb 1b80:d418] [ 23.003414] 00000000:00000080000000001500000050006F00720074005F0023003000300030003200 ...........P.o.r.t._.#.0.0.0.2.
[rdpdr-usb 1b80:d418] [ 23.003423] 00000020:2E004800750062005F0023003000300030003100000000000000 ..H.u.b._.#.0.0.0.1.......
[rdpdr-usb 1b80:d418] [ 23.005186] [DEBUG] =======================================================
[rdpdr-usb 1b80:d418] [ 23.005204] [DEBUG] REGISTER_REQUEST_CALLBACK
[rdpdr-usb 1b80:d418] [ 23.005214] [DEBUG] RequestCompletion 0.
[rdpdr-usb 1b80:d418] [ 23.005223] [DEBUG] =======================================================
[rdpdr-usb 1b80:d418] [ 23.005233] [DEBUG] INTERNAL_IO_CONTROL
[rdpdr-usb 1b80:d418] [ 23.005242] [DEBUG] IoControlCode 0x00224000, in 0 bytes, out 4 bytes, RequestId 0.
[rdpdr-usb 1b80:d418] [ 23.005251] [DEBUG] Send 32 bytes to rdpclient.
[rdpdr-usb 1b80:d418] [ 23.005261] 00000000:000000400000000000010000000000000000000004000000040000009BB96BE1 ...@..........................k.
[rdpdr-usb 1b80:d418] [ 23.005923] [DEBUG] =======================================================
[rdpdr-usb 1b80:d418] [ 23.005941] [DEBUG] TRANSFER_IN_REQUEST
[rdpdr-usb 1b80:d418] [ 23.005952] [DEBUG] Function 0x000b, RequestId 1, NoAck false, 18 bytes to receive.
[rdpdr-usb 1b80:d418] [ 23.005961] [DEBUG] URB_FUNCTION_GET_DESCRIPTOR_FROM_DEVICE
[rdpdr-usb 1b80:d418] [ 23.005971] [DEBUG] DescriptorType 1.
[rdpdr-usb 1b80:d418] [ 23.005980] [DEBUG] request_type 0x80, wValue 0x100, Index 0, DescriptorType 1, LanguageId 0.
[rdpdr-usb 1b80:d418] [ 23.005989] [DEBUG] libusb_control_transfer return 18.
[rdpdr-usb 1b80:d418] [ 23.005999] 00000000:12010002EF020140801B18D4014001020301 ......@...@....
[rdpdr-usb 1b80:d418] [ 23.006008] [DEBUG] Send 54 bytes to rdpclient.
[rdpdr-usb 1b80:d418] [ 23.006017] 00000000:0000004000000000010100000100000008000000080000000000000000000000 ...@............................
[rdpdr-usb 1b80:d418] [ 23.006026] 00000020:1200000012010002EF020140801B18D4014001020301 .........@...@....
[rdpdr-usb 1b80:d418] [ 23.006840] [DEBUG] =======================================================
[rdpdr-usb 1b80:d418] [ 23.006859] [DEBUG] TRANSFER_IN_REQUEST
[rdpdr-usb 1b80:d418] [ 23.006869] [DEBUG] Function 0x000b, RequestId 0, NoAck false, 9 bytes to receive.
[rdpdr-usb 1b80:d418] [ 23.006878] [DEBUG] URB_FUNCTION_GET_DESCRIPTOR_FROM_DEVICE
[rdpdr-usb 1b80:d418] [ 23.006888] [DEBUG] DescriptorType 2.
[rdpdr-usb 1b80:d418] [ 23.006897] [DEBUG] request_type 0x80, wValue 0x200, Index 0, DescriptorType 2, LanguageId 0.
[rdpdr-usb 1b80:d418] [ 23.006906] [DEBUG] libusb_control_transfer return 9.
[rdpdr-usb 1b80:d418] [ 23.006916] 00000000:09025801070104A0FA ..X......
[rdpdr-usb 1b80:d418] [ 23.006925] [DEBUG] Send 45 bytes to rdpclient.
[rdpdr-usb 1b80:d418] [ 23.006934] 00000000:0000004000000000010100000000000008000000080000000000000000000000 ...@............................
[rdpdr-usb 1b80:d418] [ 23.006944] 00000020:0900000009025801070104A0FA ......X......
[rdpdr-usb 1b80:d418] [ 23.007764] [DEBUG] =======================================================
[rdpdr-usb 1b80:d418] [ 23.007782] [DEBUG] TRANSFER_IN_REQUEST
[rdpdr-usb 1b80:d418] [ 23.007792] [DEBUG] Function 0x000b, RequestId 0, NoAck false, 344 bytes to receive.
[rdpdr-usb 1b80:d418] [ 23.007801] [DEBUG] URB_FUNCTION_GET_DESCRIPTOR_FROM_DEVICE
[rdpdr-usb 1b80:d418] [ 23.007810] [DEBUG] DescriptorType 2.
[rdpdr-usb 1b80:d418] [ 23.007820] [DEBUG] request_type 0x80, wValue 0x200, Index 0, DescriptorType 2, LanguageId 0.
[rdpdr-usb 1b80:d418] [ 23.007832] [DEBUG] libusb_control_transfer return 344.
[rdpdr-usb 1b80:d418] [ 23.007841] 00000000:09025801070104A0FA0904000002FFFFFF2007058E0320000407050E03200004 ..X.............. .... ...... ..
[rdpdr-usb 1b80:d418] [ 23.007851] 00000020:080B0106FFFFFF000904010001FFFFFF0707058F030800070904020001FFFFFF ................................
[rdpdr-usb 1b80:d418] [ 23.007860] 00000040:08070581020002000904020101FFFFFF09070581054000010904020201FFFFFF .....................@..........
[rdpdr-usb 1b80:d418] [ 23.007870] 00000060:0A070581058000010904020301FFFFFF0B070581053C01010904020401FFFFFF .....................<..........
[rdpdr-usb 1b80:d418] [ 23.007879] 00000080:0C07058105C802010904020501FFFFFF0D07058105C80A010904030001FFFFFF ................................
[rdpdr-usb 1b80:d418] [ 23.007889] 000000a0:14070583020002000904030101FFFFFF15070583051C00010904030201FFFFFF .............................
[rdpdr-usb 1b80:d418] [ 23.007898] 000000c0:16070583053400010904040001FFFFFF17070584020002000904040101FFFFFF ....4.........................
[rdpdr-usb 1b80:d418] [ 23.007907] 000000e0:1807058405B800010904040201FFFFFF1907058405D802010904040301FFFFFF ..............................
[rdpdr-usb 1b80:d418] [ 23.007917] 00000100:1A07058405C413010904040401FFFFFF1B07058405840B010904050001FFFFFF .............................
[rdpdr-usb 1b80:d418] [ 23.007926] 00000120:1C070585020002000904050101FFFFFF1F070505020002010904060001FFFFFF ..............................
[rdpdr-usb 1b80:d418] [ 23.007935] 00000140:1D070586020002000904060101FFFFFF1E07058605400201 ...................@..
[rdpdr-usb 1b80:d418] [ 23.007945] [DEBUG] Send 380 bytes to rdpclient.
[rdpdr-usb 1b80:d418] [ 23.007954] 00000000:0000004000000000010100000000000008000000080000000000000000000000 ...@............................
[rdpdr-usb 1b80:d418] [ 23.007964] 00000020:5801000009025801070104A0FA0904000002FFFFFF2007058E0320000407050E X.....X.............. .... .....
[rdpdr-usb 1b80:d418] [ 23.007973] 00000040:03200004080B0106FFFFFF000904010001FFFFFF0707058F0308000709040200 . ..............................
[rdpdr-usb 1b80:d418] [ 23.007982] 00000060:01FFFFFF08070581020002000904020101FFFFFF090705810540000109040202 .........................@......
[rdpdr-usb 1b80:d418] [ 23.007991] 00000080:01FFFFFF0A070581058000010904020301FFFFFF0B070581053C010109040204 .........................<......
[rdpdr-usb 1b80:d418] [ 23.008006] 000000a0:01FFFFFF0C07058105C802010904020501FFFFFF0D07058105C80A0109040300 ................................
[rdpdr-usb 1b80:d418] [ 23.008016] 000000c0:01FFFFFF14070583020002000904030101FFFFFF15070583051C000109040302 .............................
[rdpdr-usb 1b80:d418] [ 23.008025] 000000e0:01FFFFFF16070583053400010904040001FFFFFF170705840200020009040401 ........4.....................
[rdpdr-usb 1b80:d418] [ 23.008034] 00000100:01FFFFFF1807058405B800010904040201FFFFFF1907058405D8020109040403 ..............................
[rdpdr-usb 1b80:d418] [ 23.008043] 00000120:01FFFFFF1A07058405C413010904040401FFFFFF1B07058405840B0109040500 .............................
[rdpdr-usb 1b80:d418] [ 23.008053] 00000140:01FFFFFF1C070585020002000904050101FFFFFF1F0705050200020109040600 ..............................
[rdpdr-usb 1b80:d418] [ 23.008062] 00000160:01FFFFFF1D070586020002000904060101FFFFFF1E07058605400201 .......................@..
[rdpdr-usb 1b80:d418] [ 23.009206] [DEBUG] =======================================================
[rdpdr-usb 1b80:d418] [ 23.009223] [DEBUG] TRANSFER_IN_REQUEST
[rdpdr-usb 1b80:d418] [ 23.009233] [DEBUG] Function 0x0000, RequestId 0, NoAck false, 0 bytes to receive.
[rdpdr-usb 1b80:d418] [ 23.009243] [DEBUG] URB_FUNCTION_SELECT_CONFIGURATION.
[rdpdr-usb 1b80:d418] [ 23.009252] Too many (7) TS_USBD_INTERFACE_INFORMATION.
[rdpdr-usb 1b80:d418] [ 23.009262] rdpdr[usb]-main.cpp ( 275): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpdr-usb 1b80:d418] [ 23.009274] rdpdr[usb]-main.cpp ( 1458): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpdr-usb 1b80:d418] [ 28.008894] [DEBUG] =======================================================
[rdpdr-usb 1b80:d418] [ 28.008917] [DEBUG] CANCEL_REQUEST
[rdpdr-usb 1b80:d418] [ 28.008927] Cancel non-existing request 0x00000000.
Проблема с пробросом ТВ-тюнера
Re: Проблема с пробросом ТВ-тюнера
1. Свежая версия втвари называется 5.8.22. Покажи лог от неё. Врядли оно заработает, но мне нужны свежие номера строк.
2. Через mstsc.exe это устройство на этот сервер перенаправляется и уверенно работает?
