при подключении к wtware видим такой лог
[ gm] [1133256.374012] [VNC] Connection from 10.7.78.129.
[ gm] [1133256.381020] [VNC] Client VNC version 8 (RFB 003.008).
[ gm] [1133260.293023] [VNC] Password ok.
[ gm] [1133260.323023] [VNC] bits-per-pixel 32, depth 24, big-endian false, true-colour true.
[ gm] [1133260.323062] [VNC] red-max 0x00ff, green-max 0x00ff, blue-max 0x00ff.
[ gm] [1133260.323093] [VNC] red-shift 16, green-shift 8, blue-shift 0.
[ gm] [1133260.323124] [VNC] 16-bit server, 32-bit client.
[ gm] [1133260.324011] [VNC] 16 encodings.
[ gm] [1133260.324061] [VNC] Encoding 1.
[ gm] [1133260.324093] [VNC] Encoding 7.
[ gm] [1133260.324123] [VNC] Encoding 5.
[ gm] [1133260.324153] [VNC] Encoding 2.
[ gm] [1133260.324183] [VNC] Encoding 0.
[ gm] [1133260.324216] [VNC] Encoding -260.
[ gm] [1133260.324236] [VNC] Encoding -26.
[ gm] [1133260.324255] [VNC] Encoding -254.
[ gm] [1133260.324275] [VNC] Encoding -223.
[ gm] [1133260.324300] [VNC] Encoding -224.
[ gm] [1133260.324320] [VNC] Encoding -258.
[ gm] [1133260.324339] [VNC] Encoding -308.
[ gm] [1133260.324359] [VNC] Encoding -309.
[ gm] [1133260.324379] [VNC] Encoding -312.
[ gm] [1133260.324399] [VNC] Encoding -313.
[ gm] [1133260.324419] [VNC] Encoding -239.
[ gm] [1133260.379137] Caught signal SIGPIPE.
[ gm] [1133260.379179] Close TCP connection while sending data, errno 32.
[ gm] [1133260.379200] vncserver-updates.cpp ( 381): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.Код: Выделить всё
connecting to wss://10.10.10.10:50000/websockify
Server choose sub-protocol: binary
Server ProtocolVersion: 003.008
Screen: 1920x1080, bpp: 16, depth: 16, big_endian: 0, true_color: 1, red_max: 31, green_max: 63, blue_max: 31, red_shift: 11, green_shift: 5, blue_shift: 0
Data URI scheme cursor supported
First FBU latency: 78
Failed while connected: Unsupported encoding (encoding: 16)
