перестало заходить на сервак с windows server 2019
13-05-04-361| [            gm] [  122.827709] Run '/sbin/resolver 0x17dee70 dns [spb-trm-g.Afk.local]', log '', env '', pid ''.
13-05-04-424| [          pfac] [  122.827926] Run /sbin/resolver 0x17dee70 dns [spb-trm-g.Afk.local].
13-05-04-424| [          pfac] [  122.828143] Ok, PID 941.
13-05-04-424| [          pfac] [  122.838003] Process pid 941 terminated, status 00000000.
13-05-04-595| [            gm] [  123.052394] spb-trm-g.Afk.local => 192.168.25.49.
13-05-04-611| [            gm] [  123.060309] Free ram before fork terminal client /sbin/rdpclient (session 4): 549808 Kb.
13-05-04-627| [          pfac] [  123.060391] Run /sbin/rdpclient 4.
13-05-04-642| [            gm] [  123.060406] Run '/sbin/rdpclient 4', log '/tmp/rdpclient.out', env '', pid ''.
13-05-04-642| [          pfac] [  123.060526] Ok, PID 942.
13-05-04-642| [ rdpclient 942] [  123.067603] RDP Terminal Client, WTware 5.8.82/RPi, pipe 4, pid 942.
13-05-04-658| [ rdpclient 942] [  123.067877] Use /lib/ui32.so.
13-05-04-658| [ rdpclient 942] [  123.068441] Redirect sound.
13-05-04-673| [ rdpclient 942] [  123.068600] Make RDP session with 192.168.25.49, port 3389.
13-05-04-673| [ rdpclient 942] [  123.068632]  No username.
13-05-04-689| [ rdpclient 942] [  123.068669]  No password.
13-05-04-689| [ rdpclient 942] [  123.068702]  No PIN.
13-05-04-689| [ rdpclient 942] [  123.068728]  No domain.
13-05-04-689| [ rdpclient 942] [  123.068754]  No shell.
13-05-04-705| [ rdpclient 942] [  123.068781]  No directory.
13-05-04-705| [ rdpclient 942] [  123.068808]  Window: 1920x1080@24.
13-05-04-705| [ rdpclient 942] [  123.068872]  PFlags 0x0000002F.
13-05-04-705| [ rdpclient 942] [  123.068900]  Keyboard 00000409:00000000.
13-05-04-705| [ rdpclient 942] [  123.068926]  My hostname "zabbix".
13-05-04-705| [ rdpclient 942] [  123.068955] TCP: connecting to 192.168.25.49:3389.
13-05-04-720| [ rdpclient 942] [  123.070526] TCP: connection with 192.168.25.49:3389 established.
13-05-04-736| [ rdpclient 942] [  123.070590] Turn keepalive on.
13-05-04-736| [ rdpclient 942] [  123.071134] Free ram after buffers allocation: 549320 KB.
13-05-04-736| [ rdpclient 942] [  123.075265] Server supports GFX Pipeline.
13-05-04-736| [ rdpclient 942] [  123.078982] Process RDP server certificate.
13-05-04-736| [ rdpclient 942] [  123.079051] RDP5 encryption (X.509).
13-05-04-752| [ rdpclient 942] [  123.090975] Unsupported EncryptionMethod 0x00000010.
13-05-04-752| [ rdpclient 942] [  123.091058] Enable font smoothing and Desktop Composition.
13-05-04-752| [ rdpclient 942] [  123.101084]                ./streamInOps.h (  313): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
13-05-04-752| [ rdpclient 942] [  123.101162]            ./streamInStealer.h (   29): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
13-05-04-767| [ rdpclient 942] [  123.101199] [ERROR] totalLength 23703 large then packet 26 channelId 1003.
13-05-04-783| [ rdpclient 942] [  123.101227] 00000000:0300003602F08068000103EB3028080000001000010205463A9C995C1F491D2D  ...6...h....0(........F:..\I-
13-05-04-783| [ rdpclient 942] [  123.101256] 00000020:75A3F1DB94E405C032ADDE72798F74C1EB1E739A3BD2                      u.......2..ry.t..s.;.
13-05-04-783| [ rdpclient 942] [  123.101284]          rdpclient-connect.cpp ( 2793): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
13-05-04-783| [ rdpclient 942] [  123.101314] Close TCP connection while receiving data (recv() return -1, errno 104).
13-05-04-798| [ rdpclient 942] [  123.101341] TCP/IP connection lost. Network failure?
13-05-04-798| [            gm] [  123.221391] Final message: TCP/IP connection lost. Network failure?
13-05-04-830| [        rdpsnd] [  123.222908] Link lost.
13-05-04-830| [          pfac] [  123.223270] Process pid 942 terminated, status 00000009.
