Возникает проблема на связке server 2019 + wtware. Раз в 7 дней отваливаются пользователи с ошибкой
Сервер разорвал соединение.
UNKNOWN (0x00000010)
Помогает только перезагрузка сервера.
Из лога удаётся понять не многое.
11-02-36-959| [rdpclient 1181] [ 280.308271] RDP Terminal Client, WTware 6.0.6, pipe 1, pid 1181.
11-02-36-959| [rdpclient 1181] [ 280.309556] Use /lib/ui32-SSE.so.
11-02-36-959| [rdpclient 1181] [ 280.310419] Redirect sound.
11-02-36-959| [rdpclient 1181] [ 280.310900] Make RDP session with 192.168.1.11, port 3389.
11-02-36-959| [rdpclient 1181] [ 280.311059] No username.
11-02-36-959| [rdpclient 1181] [ 280.311200] No password.
11-02-36-959| [rdpclient 1181] [ 280.311341] No PIN.
11-02-36-959| [rdpclient 1181] [ 280.311479] No domain.
11-02-36-959| [rdpclient 1181] [ 280.311621] No shell.
11-02-36-959| [rdpclient 1181] [ 280.311770] No directory.
11-02-36-959| [rdpclient 1181] [ 280.311922] Window: 1366x768@24.
11-02-36-959| [rdpclient 1181] [ 280.312073] PFlags 0x00000182.
11-02-36-959| [rdpclient 1181] [ 280.312216] Keyboard 00000409:00000000.
11-02-36-959| [rdpclient 1181] [ 280.312359] My hostname "wtw3010B30796EF".
11-02-36-959| [rdpclient 1181] [ 280.312505] TCP: connecting to 192.168.1.11:3389.
11-02-36-959| [rdpclient 1181] [ 280.315563] TCP: connection with 192.168.1.11:3389 established.
11-02-36-959| [rdpclient 1181] [ 280.315679] Turn keepalive on.
11-02-36-959| [rdpclient 1181] [ 280.316032] Free ram after buffers allocation: 1881452 KB.
11-02-36-959| [rdpclient 1181] [ 287.613132] Reconnect with NLA enabled.
11-02-36-959| [rdpclient 1181] [ 287.613316] TCP: reconnecting to 192.168.1.11:3389.
11-02-36-959| [rdpclient 1181] [ 287.658876] TCP: connection with 192.168.1.11:3389 established.
11-02-36-959| [rdpclient 1181] [ 287.659062] Turn keepalive on.
11-02-36-959| [rdpclient 1181] [ 287.670809] Server supports GFX Pipeline.
11-02-36-959| [rdpclient 1181] [ 287.670997] NLA.
11-02-36-959| [rdpclient 1181] [ 287.671144] SSL/TLS.
11-02-36-959| [rdpclient 1181] [ 287.787616] Enable font smoothing and Desktop Composition.
11-02-36-959| [rdpclient 1181] [ 287.795460] RDP5 encryption (X.509).
11-02-36-959| [rdpclient 1181] [ 287.977663] TS_STATUS_FINDING_DESTINATION
11-02-36-959| [rdpclient 1181] [ 288.058864] TS_STATUS_LOADING_DESTINATION
11-02-36-959| [rdpclient 1181] [ 288.059330] TS_STATUS_REDIRECTING_TO_DESTINATION
11-02-36-959| [rdpclient 1181] [ 288.077466] TS_STATUS_BRINGING_SESSION_ONLINE
11-02-36-959| [rdpclient 1181] [ 288.080168] TS_STATUS_VM_LOADING
11-02-36-959| [rdpclient 1181] [ 288.262545] GFX codec.
11-02-36-959| [rdpclient 1181] [ 288.279626] Graphics output buffer 1366x768, 1 monitors.
11-02-36-959| [rdpclient 1181] [ 288.279717] Monitor 0: 0.0-1365.767 primary.
11-02-36-959| [rdpclient 1181] [ 289.143542] Run 2 tile threads.
11-02-36-959| [rdpclient 1181] [ 289.157264] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000010.
11-02-36-959| [rdpclient 1181] [ 289.608387] SessionId 0x00000010: DOMEN\User.
Что делать куда копать?
Re: UNKNOWN (0x00000010)
В этом обрывке лога даже ошибки нет. Копать в сторону снятия лога по инструкции: https://wtware.ru/logs.html
ок вот лог
- WTware_30.10.B3.07.96.EF_2020-10-30_11-02-58.txt
- (208.03 КБ) 735 скачиваний
В этом логе нет "UNKNOWN (0x00000010)". И разрыва соединения нет.
Однако это единсвенный лог с этого мака, и по поиску 0x00000010 находит в логе только
- error.jpg (72.19 КБ) 31544 просмотра
Нажми кнопку "получить лог" когда на экране нарисовано это окошко.
Так как эту ошибку искусственно не создать, напишу через неделю.
Может помочь убирание из конфига всего лишнего. "лишнее" это всё то, что не необходимо.
Например, два из этих трех надо убрать:
usb=mass_storage
shared_disk=usb
disk=usb
