Переподключение микрофона
Artur
Сообщение Artur »
Здравствуйте, скажите пожалуйста когда идет такое вот постоянное переподключение микрофона это нормально?
[rdpclient 1543] [57513.487941] Run 4 tile threads.
[rdpclient 1543] [57513.781596] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x000003bc.
[rdpclient 1543] [57517.393163] SessionId 0x000003bc: ORIGINAL\a.farhutdinova.
[rdpclient 1543] [57561.947337] [SOUND] AAC compressed sound 44100 frames per second.
[rdpclient 1543] [57561.947514] [ALSA] Start speaker plugin.
[rdpclient 1543] [57563.043536] Redirect microphone.
[rdpclient 1543] [57563.166139] [ALSA] Start microphone plugin.
[rdpclient 1543] [57563.166506] [ALSA MIC] Use device hw:2,0.
[rdpclient 1543] [57563.168409] [ALSA PLAY] Use device hw:2,0.
[rdpclient 1543] [57563.171374] [ALSA MIC] Hardware rate 48000Hz.
[rdpclient 1543] [57563.171480] [ALSA PLAY] Hardware rate 48000Hz.
[rdpclient 1543] [57563.178976] [ALSA MIC] Chunk size 512 frames, 1024 bytes.
[rdpclient 1543] [57563.196922] [ALSA PLAY] Chunk size 256 frames, 1024 bytes, 5 msec.
[rdpclient 1543] [58070.111155] Redirect microphone.
[rdpclient 1543] [58070.233091] [ALSA MIC] Use device hw:2,0.
[rdpclient 1543] [58070.233657] [ALSA MIC] Hardware rate 48000Hz.
[rdpclient 1543] [58070.240867] [ALSA MIC] Chunk size 512 frames, 1024 bytes.
[ RDP] [58070.240975] [aac @ 0xae90bd80] Qavg: 259.548
[ RDP] [58070.241043] [aac @ 0xae90bd80] 2 frames left in the queue on closing
[rdpclient 1543] [58222.861492] Redirect microphone.
[rdpclient 1543] [58222.983934] [ALSA MIC] Use device hw:2,0.
[rdpclient 1543] [58222.984052] [ALSA MIC] Hardware rate 48000Hz.
[rdpclient 1543] [58223.000422] [ALSA MIC] Chunk size 512 frames, 1024 bytes.
[ RDP] [58223.000515] [aac @ 0xae90c4c0] Qavg: 258.565
[ RDP] [58223.000548] [aac @ 0xae90c4c0] 2 frames left in the queue on closing
[rdpclient 1543] [58338.047795] Redirect microphone.
[rdpclient 1543] [58338.171314] [ALSA MIC] Use device hw:2,0.
[rdpclient 1543] [58338.171446] [ALSA MIC] Hardware rate 48000Hz.
[rdpclient 1543] [58338.180120] [ALSA MIC] Chunk size 512 frames, 1024 bytes.
[ RDP] [58338.180431] [aac @ 0xae94ac40] Qavg: 259.037
[ RDP] [58338.180477] [aac @ 0xae94ac40] 2 frames left in the queue on closing
[rdpclient 1543] [58497.229551] errorInfo 0x00000005.
[rdpclient 1543] [58497.229692] ERRINFO_DISCONNECTED_BY_OTHERCONNECTION: Another user connected to the server, forcing the disconnection of the current connection.
[rdpclient 1543] [58497.366948] Receive Disconnect Provider Ultimatum.
Re: Переподключение микрофона
Нормально.
