https://cloud.mail.ru/public/YYo3/TkC6362QV
Интернет работает стабильно потерь нет. Платформа скачивает образ, но потом не грузится. Платформа проверенная в другом филиале все идеально работает.
15-35-16-965| [10.78.32.29] RRQ 44 bytes:
15-35-16-965| [10.78.32.29] 00000000: 2f 36 2e 30 2e 37 32 2f 68 74 74 70 2e 65 66 69
15-35-16-965| [10.78.32.29] 00000010: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62
15-35-16-965| [10.78.32.29] 00000020: 6c 6b 73 69 7a 65 00 31 34 36 38 00
15-35-16-965| [10.78.32.29] Request block size 1468, forced to 1360.
15-35-16-965| [10.78.32.29] "6.0.72\http.efi": tsize is requested, blksize 1360 bytes.
15-35-16-965| [10.78.32.29] "6.0.72\http.efi": "C:\Program Files (x86)\WTware\TFTPDROOT\6.0.72\http.efi".
15-35-16-965| Close TCP connection while sending data, errno 0.
15-35-16-965| [10.78.32.29] Received opcode ERR.
15-35-16-965| [10.78.32.29] RRQ 36 bytes:
15-35-16-965| [10.78.32.29] 00000010: 00 6f 63 74 65 74 00 62 6c 6b 73 69 7a 65 00 31
15-35-16-965| [10.78.32.29] 00000020: 34 36 38 00
15-35-16-965| [10.78.32.29] "6.0.72\http.efi": tsize is not requested, blksize 1360 bytes.
15-35-55-068| [10.78.32.29] "6.0.72\http.efi": completed.
15-36-01-634| Connection closed.
15-36-02-253| WTware TFTP server v.6.0.72 (c) 2003-2021 WTware http://www.wtware.com
15-36-02-253| Found interface 10.148.11.20/255.255.255.0 mtu 1500 mac 00:50:56:8C:CE:D4 adapter vmxnet3 Ethernet Adapter.
15-36-02-253| No BindIP key found in registry.
15-36-02-253| Bind at 0.0.0.0:69.
15-36-05-731| [10.78.32.29] RRQ 221 bytes:
15-36-05-731| [10.78.32.29] 00000000: 57 54 77 61 72 65 20 76 2e 36 2e 30 2e 37 32 20
15-36-05-731| [10.78.32.29] 00000010: 61 74 20 31 43 3a 36 39 3a 37 41 3a 41 46 3a 44
15-36-05-731| [10.78.32.29] 00000020: 45 3a 34 37 2c 20 64 68 63 70 3d 31 30 2e 37 38
15-36-05-731| [10.78.32.29] 00000030: 2e 33 32 2e 31 2c 20 70 6c 61 74 66 6f 72 6d 3d
15-36-05-731| [10.78.32.29] 00000040: 75 65 66 69 2c 20 69 70 3d 31 30 2e 37 38 2e 33
15-36-05-731| [10.78.32.29] 00000050: 32 2e 32 39 2c 20 73 69 67 6e 3d 37 43 37 46 35
15-36-05-731| [10.78.32.29] 00000060: 35 46 34 31 39 37 31 46 42 44 31 38 32 44 43 44
15-36-05-731| [10.78.32.29] 00000070: 41 31 34 30 32 39 32 44 38 33 33 39 37 46 41 46
15-36-05-731| [10.78.32.29] 00000080: 44 44 32 38 38 38 37 42 34 43 33 33 36 39 44 31
15-36-05-731| [10.78.32.29] 00000090: 45 42 38 46 37 43 42 35 45 32 31 46 31 32 33 38
15-36-05-731| [10.78.32.29] 000000a0: 31 39 42 44 35 46 39 35 46 46 42 36 39 35 39 33
15-36-05-731| [10.78.32.29] 000000b0: 44 32 42 43 38 34 44 35 35 32 32 39 44 35 33 38
15-36-05-731| [10.78.32.29] 000000c0: 35 42 42 39 44 33 32 31 34 42 34 34 35 39 31 42
15-36-05-731| [10.78.32.29] 000000d0: 31 34 45 33 36 45 42 45 30 30 45 2e 00
15-36-05-731| [10.78.32.29] WTware v.6.0.72 found at host [], mac 1C:69:7A:AF:DE:47.
15-36-05-731| [10.78.32.29] Sending WTware TFTP version.
15-36-05-746| [10.78.32.29] RRQ 52 bytes:
15-36-05-746| [10.78.32.29] 00000000: 2f 36 2e 30 2e 37 32 2f 2f 77 74 77 61 72 65 2e
15-36-05-746| [10.78.32.29] 00000010: 68 74 74 70 2e 63 66 67 00 6f 63 74 65 74 00 74
15-36-05-746| [10.78.32.29] 00000020: 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31
15-36-05-746| [10.78.32.29] 00000030: 34 30 30 00
15-36-05-746| [10.78.32.29] Request block size 1400, forced to 1360.
15-36-05-746| [10.78.32.29] "6.0.72\\wtware.http.cfg": tsize is requested, blksize 1360 bytes.
15-36-05-746| [10.78.32.29] "6.0.72\\wtware.http.cfg": "C:\Program Files (x86)\WTware\TFTPDROOT\6.0.72\\wtware.http.cfg".
15-36-05-762| [10.78.32.29] "6.0.72\\wtware.http.cfg": completed.
15-40-09-235| [10.78.32.29] RRQ 44 bytes:
15-40-09-235| [10.78.32.29] 00000000: 2f 36 2e 30 2e 37 32 2f 68 74 74 70 2e 65 66 69
15-40-09-235| [10.78.32.29] 00000010: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62
15-40-09-235| [10.78.32.29] 00000020: 6c 6b 73 69 7a 65 00 31 34 36 38 00
15-40-09-235| [10.78.32.29] Request block size 1468, forced to 1360.
15-40-09-235| [10.78.32.29] "6.0.72\http.efi": tsize is requested, blksize 1360 bytes.
15-40-09-235| [10.78.32.29] "6.0.72\http.efi": "C:\Program Files (x86)\WTware\TFTPDROOT\6.0.72\http.efi".
15-40-09-250| [10.78.32.29] Received opcode ERR.
15-40-09-250| [10.78.32.29] RRQ 36 bytes:
15-40-09-250| [10.78.32.29] 00000000: 2f 36 2e 30 2e 37 32 2f 68 74 74 70 2e 65 66 69
15-40-09-250| [10.78.32.29] 00000010: 00 6f 63 74 65 74 00 62 6c 6b 73 69 7a 65 00 31
15-40-09-250| [10.78.32.29] 00000020: 34 36 38 00
15-40-09-250| [10.78.32.29] Request block size 1468, forced to 1360.
15-40-09-250| [10.78.32.29] "6.0.72\http.efi": tsize is not requested, blksize 1360 bytes.
15-40-09-250| [10.78.32.29] "6.0.72\http.efi": "C:\Program Files (x86)\WTware\TFTPDROOT\6.0.72\http.efi".
15-40-54-114| [10.78.32.29] "6.0.72\http.efi": completed.
15-41-04-568| [10.78.32.29] RRQ 221 bytes:
15-41-04-568| [10.78.32.29] 00000000: 57 54 77 61 72 65 20 76 2e 36 2e 30 2e 37 32 20
15-41-04-568| [10.78.32.29] 00000010: 61 74 20 31 43 3a 36 39 3a 37 41 3a 41 46 3a 44
15-41-04-568| [10.78.32.29] 00000020: 45 3a 34 37 2c 20 64 68 63 70 3d 31 30 2e 37 38
15-41-04-568| [10.78.32.29] 00000030: 2e 33 32 2e 31 2c 20 70 6c 61 74 66 6f 72 6d 3d
15-41-04-568| [10.78.32.29] 00000040: 75 65 66 69 2c 20 69 70 3d 31 30 2e 37 38 2e 33
15-41-04-568| [10.78.32.29] 00000050: 32 2e 32 39 2c 20 73 69 67 6e 3d 37 43 37 46 35
15-41-04-568| [10.78.32.29] 00000060: 35 46 34 31 39 37 31 46 42 44 31 38 32 44 43 44
15-41-04-568| [10.78.32.29] 00000070: 41 31 34 30 32 39 32 44 38 33 33 39 37 46 41 46
15-41-04-568| [10.78.32.29] 00000080: 44 44 32 38 38 38 37 42 34 43 33 33 36 39 44 31
15-41-04-568| [10.78.32.29] 00000090: 45 42 38 46 37 43 42 35 45 32 31 46 31 32 33 38
15-41-04-568| [10.78.32.29] 000000a0: 31 39 42 44 35 46 39 35 46 46 42 36 39 35 39 33
15-41-04-568| [10.78.32.29] 000000b0: 44 32 42 43 38 34 44 35 35 32 32 39 44 35 33 38
15-41-04-568| [10.78.32.29] 000000c0: 35 42 42 39 44 33 32 31 34 42 34 34 35 39 31 42
15-41-04-568| [10.78.32.29] 000000d0: 31 34 45 33 36 45 42 45 30 30 45 2e 00
15-41-04-568| [10.78.32.29] WTware v.6.0.72 found at host [], mac 1C:69:7A:AF:DE:47.
15-41-04-568| [10.78.32.29] Sending WTware TFTP version.
15-41-04-677| [10.78.32.29] RRQ 52 bytes:
15-41-04-677| [10.78.32.29] 00000000: 2f 36 2e 30 2e 37 32 2f 2f 77 74 77 61 72 65 2e
15-41-04-677| [10.78.32.29] 00000010: 68 74 74 70 2e 63 66 67 00 6f 63 74 65 74 00 74
15-41-04-677| [10.78.32.29] 00000020: 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00 31
15-41-04-677| [10.78.32.29] 00000030: 34 30 30 00
15-41-04-677| [10.78.32.29] Request block size 1400, forced to 1360.
15-41-04-677| [10.78.32.29] "6.0.72\\wtware.http.cfg": tsize is requested, blksize 1360 bytes.
15-41-04-677| [10.78.32.29] "6.0.72\\wtware.http.cfg": "C:\Program Files (x86)\WTware\TFTPDROOT\6.0.72\\wtware.http.cfg".
15-41-04-677| [10.78.32.29] "6.0.72\\wtware.http.cfg": completed.
15-43-13-827| Connection closed.
15-43-14-136| WTware TFTP server v.6.0.72 (c) 2003-2021 WTware http://www.wtware.com
15-43-14-136| Found interface 10.148.11.20/255.255.255.0 mtu 1500 mac 00:50:56:8C:CE:D4 adapter vmxnet3 Ethernet Adapter.
15-43-14-136| No BindIP key found in registry.
15-43-14-136| Bind at 0.0.0.0:69.
Проблема с загрузкой терминалов
Re: Проблема с загрузкой терминалов
1. На платформе,, когда она выдаёт ошибку и командную строку, сними лог терминала на флешку и покажи. Последний раздел "когда на терминале нет сети" в инструкции: https://wtware.ru/docs5/logs.html
Без лога могу предположить, что все проблемы из-за второго DHCP там, где загружается. Надо поискать второй DHCP и, если найдется, один из двоих убить.
2. Вот этот лог, который в сообщении - он как получен? Строку:
служба TFTP пишет когда запускается. Но служба должна запуститься один раз при загрузке сервера, сама никогда не перезапускается! Если бы служба падала из-за ошибки, она бы падала и не перезапускалась. Нет у нас механизма перезапуска. Её кто-то перезапускает. Кто и зачем? Предположу шибко умный антивирус. Есть что-то кроме штатного виндового дефендера?WTware TFTP server v.6.0.72 (c)...
