internal error
teejee
internal error
Сообщение teejee »
есть сервер на нем TFTP\HTTP загрузка крутится
есть множество подсетей, все загружаются по http
а вот из одной сетки что не хочет
ТОНК
на dhcp подсети, впрочем как везде
сервер твтп:192.168.77.245
файл: 5.1.29\wtware.http
лог
11-22-42-0161| WTware 5.1.29 supervisor.
11-22-42-0161| WTC listener active.
11-22-42-0161| WTC broadcast listener active.
11-22-42-0161| HTTPd listener active.
11-22-42-0161| [KERNEL] Linux version 3.8.6 (root@c2) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 PREEMPT Tue Apr 9 05:46:05 MSK 2013
11-22-42-0161| [KERNEL] KERNEL supported cpus:
11-22-42-0161| [KERNEL] Intel GenuineIntel
11-22-42-0161| [KERNEL] AMD AuthenticAMD
11-22-42-0161| [KERNEL] NSC Geode by NSC
11-22-42-0161| [KERNEL] Cyrix CyrixInstead
11-22-42-0161| [KERNEL] Centaur CentaurHauls
11-22-42-0161| [KERNEL] Transmeta GenuineTMx86
11-22-42-0161| [KERNEL] Transmeta TransmetaCPU
11-22-42-0161| [KERNEL] UMC UMC UMC UMC
11-22-42-0161| [KERNEL] e820: BIOS-provided physical RAM map:
11-22-42-0161| [KERNEL] BIOS-e820: [mem 0x0000000000000000-0x000000000009e7ff] usable
11-22-42-0161| [KERNEL] BIOS-e820: [mem 0x000000000009e800-0x000000000009ffff] reserved
11-22-42-0161| [KERNEL] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
11-22-42-0161| [KERNEL] BIOS-e820: [mem 0x0000000000100000-0x000000001efaffff] usable
11-22-42-0161| [KERNEL] BIOS-e820: [mem 0x000000001efb0000-0x000000001efb2fff] ACPI NVS
11-22-42-0161| [KERNEL] BIOS-e820: [mem 0x000000001efb3000-0x000000001efbffff] ACPI data
11-22-42-0161| [KERNEL] BIOS-e820: [mem 0x00000000ffff0000-0x00000000ffffffff] reserved
11-22-42-0161| [KERNEL] Notice: NX (Execute Disable) protection missing in CPU!
11-22-42-0161| [KERNEL] SMBIOS 2.2 present.
11-22-42-0161| [KERNEL] DMI: /AMD-GX3, BIOS 6.00 PG 04/22/2008
11-22-42-0161| [KERNEL] e820: update [mem 0x00000000-0x0000ffff] usable ==> reserved
11-22-42-0161| [KERNEL] e820: remove [mem 0x000a0000-0x000fffff] usable
11-22-42-0161| [KERNEL] e820: last_pfn = 0x1efb0 max_arch_pfn = 0x100000
11-22-42-0161| [KERNEL] initial memory mapped: [mem 0x00000000-0x007fffff]
11-22-42-0161| [KERNEL] Base memory trampoline at [c008f000] 8f000 size 16384
11-22-42-0161| [KERNEL] init_memory_mapping: [mem 0x00000000-0x1efaffff]
11-22-42-0161| [KERNEL] [mem 0x00000000-0x003fffff] page 4k
11-22-42-0161| [KERNEL] [mem 0x00400000-0x1ebfffff] page 2M
11-22-42-0161| [KERNEL] [mem 0x1ec00000-0x1efaffff] page 4k
11-22-42-0161| [KERNEL] kernel direct mapping tables up to 0x1efaffff @ [mem 0x007fa000-0x007fffff]
11-22-42-0161| [KERNEL] RAMDISK: [mem 0x00800000-0x00d49fff]
11-22-42-0161| [KERNEL] ACPI: RSDP 000f60d0 00014 (v00 AMDGX3)
11-22-42-0161| [KERNEL] ACPI: RSDT 1efb3000 00028 (v01 AMDGX3 AWRDACPI 42302E31 AWRD 00000000)
11-22-42-0161| [KERNEL] ACPI: FACP 1efb3080 00074 (v01 AMDGX3 AWRDACPI 42302E31 AWRD 00000000)
11-22-42-0161| [KERNEL] ACPI BIOS Bug: Warning: Invalid length for FADT/Pm2ControlBlock: 16, using default 8 (20121018/tbfadt-648)
11-22-42-0161| [KERNEL] ACPI: DSDT 1efb3100 02CBD (v01 AMDGX3 AWRDACPI 00001000 MSFT 03000000)
11-22-42-0161| [KERNEL] ACPI: FACS 1efb0000 00040
11-22-42-0161| [KERNEL] 495MB LOWMEM available.
11-22-42-0161| [KERNEL] mapped low ram: 0 - 1efb0000
11-22-42-0161| [KERNEL] low ram: 0 - 1efb0000
11-22-42-0161| [KERNEL] Zone ranges:
11-22-42-0161| [KERNEL] DMA [mem 0x00010000-0x00ffffff]
11-22-42-0161| [KERNEL] Normal [mem 0x01000000-0x1efaffff]
11-22-42-0161| [KERNEL] Movable zone start for each node
11-22-42-0161| [KERNEL] Early memory node ranges
11-22-42-0161| [KERNEL] node 0: [mem 0x00010000-0x0009dfff]
11-22-42-0161| [KERNEL] node 0: [mem 0x00100000-0x1efaffff]
11-22-42-0161| [KERNEL] On node 0 totalpages: 126782
11-22-42-0161| [KERNEL] free_area_init_node: node 0, pgdat c0453220, node_mem_map debd0200
11-22-42-0161| [KERNEL] DMA zone: 32 pages used for memmap
11-22-42-0161| [KERNEL] DMA zone: 0 pages reserved
11-22-42-0161| [KERNEL] DMA zone: 3950 pages, LIFO batch:0
11-22-42-0161| [KERNEL] Normal zone: 960 pages used for memmap
11-22-42-0161| [KERNEL] Normal zone: 121840 pages, LIFO batch:31
11-22-42-0161| [KERNEL] Using APIC driver default
11-22-42-0161| [KERNEL] ACPI: PM-Timer IO Port: 0x9c10
11-22-42-0161| [KERNEL] No local APIC present or hardware disabled
11-22-42-0161| [KERNEL] APIC: disable apic facility
11-22-42-0161| [KERNEL] APIC: switched to apic NOOP
11-22-42-0161| [KERNEL] nr_irqs_gsi: 16
11-22-42-0161| [KERNEL] e820: [mem 0x1efc0000-0xfffeffff] available for PCI devices
11-22-42-0161| [KERNEL] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
11-22-42-0161| [KERNEL] pcpu-alloc: [0] 0
11-22-42-0161| [KERNEL] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 125790
11-22-42-0161| [KERNEL] Kernel command line: root=/dev/ram0 quiet
11-22-42-0161| [KERNEL] PID hash table entries: 2048 (order: 1, 8192 bytes)
11-22-42-0161| [KERNEL] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
11-22-42-0161| [KERNEL] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
11-22-42-0161| [KERNEL] __ex_table already sorted, skipping sort
11-22-42-0161| [KERNEL] Initializing CPU#0
11-22-42-0161| [KERNEL] Memory: 493264k/507584k available (2553k kernel code, 13864k reserved, 863k data, 324k init, 0k highmem)
11-22-42-0161| [KERNEL] virtual kernel memory layout:
11-22-42-0161| [KERNEL] fixmap : 0xfffa2000 - 0xfffff000 ( 372 kB)
11-22-42-0161| [KERNEL] vmalloc : 0xdf7b0000 - 0xfffa0000 ( 519 MB)
11-22-42-0161| [KERNEL] lowmem : 0xc0000000 - 0xdefb0000 ( 495 MB)
11-22-42-0161| [KERNEL] .init : 0xc0457000 - 0xc04a8000 ( 324 kB)
11-22-42-0161| [KERNEL] .data : 0xc037e589 - 0xc0456500 ( 863 kB)
11-22-42-0161| [KERNEL] .text : 0xc0100000 - 0xc037e589 (2553 kB)
11-22-42-0161| [KERNEL] Checking if this processor honours the WP bit even in supervisor mode...Ok.
11-22-42-0161| [KERNEL] NR_IRQS:2304 nr_irqs:256 16
11-22-42-0161| [KERNEL] CPU 0 irqstacks, hard=de406000 soft=de408000
11-22-42-0161| [KERNEL] Console: colour VGA+ 80x25
11-22-42-0161| [KERNEL] console [tty0] enabled
11-22-42-0161| [KERNEL] tsc: Fast TSC calibration using PIT
11-22-42-0161| [KERNEL] tsc: Detected 498.619 MHz processor
11-22-42-0161| [KERNEL] Calibrating delay loop (skipped), value calculated using timer frequency.. 997.23 BogoMIPS (lpj=498619)
11-22-42-0161| [KERNEL] pid_max: default: 32768 minimum: 301
11-22-42-0161| [KERNEL] Mount-cache hash table entries: 512
11-22-42-0161| [KERNEL] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
11-22-42-0161| [KERNEL] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0
11-22-42-0161| [KERNEL] tlb_flushall_shift: -1
11-22-42-0161| [KERNEL] CPU: Geode(TM) Integrated Processor by AMD PCS (fam: 05, model: 0a, stepping: 02)
11-22-42-0161| [KERNEL] ACPI: Core revision 20121018
11-22-42-0161| [KERNEL] ACPI: setting ELCR to 0200 (from 0c20)
11-22-42-0161| [KERNEL] Performance Events: no PMU driver, software events only.
11-22-42-0161| [KERNEL] devtmpfs: initialized
11-22-42-0161| [KERNEL] PM: Registering ACPI NVS region [mem 0x1efb0000-0x1efb2fff] (12288 bytes)
11-22-42-0161| [KERNEL] NET: Registered protocol family 16
11-22-42-0161| [KERNEL] ACPI: bus type pci registered
11-22-42-0161| [KERNEL] PCI: PCI BIOS revision 2.10 entry at 0xfaad0, last bus=0
11-22-42-0161| [KERNEL] PCI: Using configuration type 1 for base access
11-22-42-0161| [KERNEL] bio: create slab <bio-0> at 0
11-22-42-0161| [KERNEL] ACPI: Added _OSI(Module Device)
11-22-42-0161| [KERNEL] ACPI: Added _OSI(Processor Device)
11-22-42-0161| [KERNEL] ACPI: Added _OSI(3.0 _SCP Extensions)
11-22-42-0161| [KERNEL] ACPI: Added _OSI(Processor Aggregator Device)
11-22-42-0161| [KERNEL] ACPI: EC: Look up EC in DSDT
11-22-42-0161| [KERNEL] ACPI: Interpreter enabled
11-22-42-0161| [KERNEL] ACPI: (supports S0 S1 S3 S5)
11-22-42-0161| [KERNEL] ACPI: Using PIC for interrupt routing
11-22-42-0161| [KERNEL] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
11-22-42-0161| [KERNEL] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
11-22-42-0161| [KERNEL] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
11-22-42-0161| [KERNEL] pci_root PNP0A03:00: ACPI _OSC support notification failed, disabling PCIe ASPM
11-22-42-0161| [KERNEL] pci_root PNP0A03:00: Unable to request _OSC control (_OSC support mask: 0x08)
11-22-42-0161| [KERNEL] pci_root PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
11-22-42-0161| [KERNEL] PCI host bridge to bus 0000:00
11-22-42-0161| [KERNEL] pci_bus 0000:00: root bus resource [bus 00-ff]
11-22-42-0161| [KERNEL] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
11-22-42-0161| [KERNEL] pci_bus 0000:00: root bus resource [io 0x0d00-0xac17]
11-22-42-0161| [KERNEL] pci_bus 0000:00: root bus resource [io 0xac20-0xffff]
11-22-42-0161| [KERNEL] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
11-22-42-0161| [KERNEL] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000dffff]
11-22-42-0161| [KERNEL] pci_bus 0000:00: root bus resource [mem 0x1efc0000-0xfebfffff]
11-22-42-0161| [KERNEL] pci 0000:00:01.0: [1022:2080] type 00 class 0x060000
11-22-42-0161| [KERNEL] pci 0000:00:01.0: reg 10: [io 0xac1c-0xac1f]
11-22-42-0161| [KERNEL] pci 0000:00:01.0: reg 14: [io 0x9e00-0x9e07]
11-22-42-0161| [KERNEL] pci 0000:00:01.1: [1022:2081] type 00 class 0x030000
11-22-42-0161| [KERNEL] pci 0000:00:01.1: reg 10: [mem 0xec000000-0xedffffff]
11-22-42-0161| [KERNEL] pci 0000:00:01.1: reg 14: [mem 0xefff0000-0xefff3fff]
11-22-42-0161| [KERNEL] pci 0000:00:01.1: reg 18: [mem 0xeffec000-0xeffeffff]
11-22-42-0161| [KERNEL] pci 0000:00:01.1: reg 1c: [mem 0xeffe8000-0xeffebfff]
11-22-42-0161| [KERNEL] pci 0000:00:01.1: reg 20: [mem 0xefff8000-0xefffbfff]
11-22-42-0161| [KERNEL] pci 0000:00:01.2: [1022:2082] type 00 class 0x101000
11-22-42-0161| [KERNEL] pci 0000:00:01.2: reg 10: [mem 0xefff4000-0xefff7fff]
11-22-42-0161| [KERNEL] pci 0000:00:0d.0: [10ec:8139] type 00 class 0x020000
11-22-42-0161| [KERNEL] pci 0000:00:0d.0: reg 10: [io 0xfc00-0xfcff]
11-22-42-0161| [KERNEL] pci 0000:00:0d.0: reg 14: [mem 0xeffff000-0xeffff0ff]
11-22-42-0161| [KERNEL] pci 0000:00:0d.0: reg 30: [mem 0x00000000-0x0000ffff pref]
11-22-42-0161| [KERNEL] pci 0000:00:0d.0: supports D1 D2
11-22-42-0161| [KERNEL] pci 0000:00:0d.0: PME# supported from D1 D2 D3hot D3cold
11-22-42-0161| [KERNEL] pci 0000:00:0f.0: [1022:2090] type 00 class 0x060100
11-22-42-0161| [KERNEL] pci 0000:00:0f.0: reg 10: [io 0x6000-0x6007]
11-22-42-0161| [KERNEL] pci 0000:00:0f.0: reg 14: [io 0x6100-0x61ff]
11-22-42-0161| [KERNEL] pci 0000:00:0f.0: reg 18: [io 0x6200-0x623f]
11-22-42-0161| [KERNEL] pci 0000:00:0f.0: reg 1c: [io 0x0000-0x001f]
11-22-42-0161| [KERNEL] pci 0000:00:0f.0: reg 20: [io 0x9d00-0x9d7f]
11-22-42-0161| [KERNEL] pci 0000:00:0f.0: reg 24: [io 0x9c00-0x9c3f]
11-22-42-0161| [KERNEL] pci 0000:00:0f.2: [1022:209a] type 00 class 0x010180
11-22-42-0161| [KERNEL] pci 0000:00:0f.2: reg 20: [io 0xff00-0xff0f]
11-22-42-0161| [KERNEL] pci 0000:00:0f.3: [1022:2093] type 00 class 0x040100
11-22-42-0161| [KERNEL] pci 0000:00:0f.3: reg 10: [io 0xfe00-0xfe7f]
11-22-42-0161| [KERNEL] pci 0000:00:0f.4: [1022:2094] type 00 class 0x0c0310
11-22-42-0161| [KERNEL] pci 0000:00:0f.4: reg 10: [mem 0xefffe000-0xefffefff]
11-22-42-0161| [KERNEL] pci 0000:00:0f.4: PME# supported from D0 D3hot D3cold
11-22-42-0161| [KERNEL] pci 0000:00:0f.5: [1022:2095] type 00 class 0x0c0320
11-22-42-0161| [KERNEL] pci 0000:00:0f.5: reg 10: [mem 0xefffd000-0xefffdfff]
11-22-42-0161| [KERNEL] pci 0000:00:0f.5: PME# supported from D0 D3hot D3cold
11-22-42-0161| [KERNEL] pci_bus 0000:00: on NUMA node 0
11-22-42-0161| [KERNEL] ACPI _OSC control for PCIe not granted, disabling ASPM
11-22-42-0161| [KERNEL] ACPI: PCI Interrupt Link [LNKA] (IRQs 5 *10 11)
11-22-42-0161| [KERNEL] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 10 *11)
11-22-42-0161| [KERNEL] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 10 11) *0, disabled.
11-22-42-0161| [KERNEL] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 10 11) *0
11-22-42-0161| [KERNEL] ACPI: bus type usb registered
11-22-42-0161| [KERNEL] usbcore: registered new interface driver usbfs
11-22-42-0161| [KERNEL] usbcore: registered new interface driver hub
11-22-42-0161| [KERNEL] usbcore: registered new device driver usb
11-22-42-0161| [KERNEL] wmi: Mapper loaded
11-22-42-0161| [KERNEL] PCI: Using ACPI for IRQ routing
11-22-42-0161| [KERNEL] PCI: pci_cache_line_size set to 32 bytes
11-22-42-0161| [KERNEL] pci 0000:00:01.0: no compatible bridge window for [io 0xac1c-0xac1f]
11-22-42-0161| [KERNEL] e820: reserve RAM buffer [mem 0x0009e800-0x0009ffff]
11-22-42-0161| [KERNEL] e820: reserve RAM buffer [mem 0x1efb0000-0x1fffffff]
11-22-42-0161| [KERNEL] Switching to clocksource pit
11-22-42-0161| [KERNEL] pnp: PnP ACPI init
11-22-42-0161| [KERNEL] ACPI: bus type pnp registered
11-22-42-0161| [KERNEL] system 00:00: [mem 0x000f0000-0x000fffff] could not be reserved
11-22-42-0161| [KERNEL] system 00:00: [mem 0x1efb0000-0x1efbffff] could not be reserved
11-22-42-0161| [KERNEL] system 00:00: [mem 0xffff0000-0xffffffff] has been reserved
11-22-42-0161| [KERNEL] system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved
11-22-42-0161| [KERNEL] system 00:00: [mem 0x00100000-0x1efaffff] could not be reserved
11-22-42-0161| [KERNEL] system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
11-22-42-0161| [KERNEL] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
11-22-42-0161| [KERNEL] pnp 00:01: disabling [io 0x0010-0x001f] because it overlaps 0000:00:0f.0 BAR 3 [io 0x0000-0x001f]
11-22-42-0161| [KERNEL] system 00:01: [io 0x0b78-0x0b7b] has been reserved
11-22-42-0161| [KERNEL] system 00:01: [io 0x0f78-0x0f7b] has been reserved
11-22-42-0161| [KERNEL] system 00:01: [io 0x0a78-0x0a7b] has been reserved
11-22-42-0161| [KERNEL] system 00:01: [io 0x0e78-0x0e7b] has been reserved
11-22-42-0161| [KERNEL] system 00:01: [io 0x0bbc-0x0bbf] has been reserved
11-22-42-0161| [KERNEL] system 00:01: [io 0x0fbc-0x0fbf] has been reserved
11-22-42-0161| [KERNEL] system 00:01: [io 0x04d0-0x04d1] has been reserved
11-22-42-0161| [KERNEL] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
11-22-42-0161| [KERNEL] pnp 00:02: [dma 4]
11-22-42-0161| [KERNEL] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
11-22-42-0161| [KERNEL] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
11-22-42-0161| [KERNEL] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
11-22-42-0161| [KERNEL] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
11-22-42-0161| [KERNEL] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
11-22-42-0161| [KERNEL] pnp: PnP ACPI: found 7 devices
11-22-42-0161| [KERNEL] ACPI: ACPI bus type pnp unregistered
11-22-42-0161| [KERNEL] Switching to clocksource acpi_pm
11-22-42-0161| [KERNEL] pci 0000:00:0d.0: BAR 6: assigned [mem 0x1efc0000-0x1efcffff pref]
11-22-42-0161| [KERNEL] pci 0000:00:0f.0: BAR 3: assigned [io 0x1000-0x101f]
11-22-42-0161| [KERNEL] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
11-22-42-0161| [KERNEL] pci_bus 0000:00: resource 5 [io 0x0d00-0xac17]
11-22-42-0161| [KERNEL] pci_bus 0000:00: resource 6 [io 0xac20-0xffff]
11-22-42-0161| [KERNEL] pci_bus 0000:00: resource 7 [mem 0x000a0000-0x000bffff]
11-22-42-0161| [KERNEL] pci_bus 0000:00: resource 8 [mem 0x000c8000-0x000dffff]
11-22-42-0161| [KERNEL] pci_bus 0000:00: resource 9 [mem 0x1efc0000-0xfebfffff]
11-22-42-0161| [KERNEL] NET: Registered protocol family 2
11-22-42-0161| [KERNEL] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
11-22-42-0161| [KERNEL] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
11-22-42-0161| [KERNEL] TCP: Hash tables configured (established 4096 bind 4096)
11-22-42-0161| [KERNEL] TCP: reno registered
11-22-42-0161| [KERNEL] UDP hash table entries: 256 (order: 0, 4096 bytes)
11-22-42-0161| [hotplug] hotplug-main.cpp ( 446), _checkEvdev: GM evdev listener isn't running now.
11-22-42-0161| [KERNEL] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
11-22-42-0161| [KERNEL] pci 0000:00:01.1: Boot video device
11-22-42-0161| [KERNEL] ACPI: PCI Interrupt Link [LNKD] BIOS reported IRQ 0, using IRQ 11
11-22-42-0161| [KERNEL] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
11-22-42-0161| [KERNEL] PCI: setting IRQ 11 as level-triggered
11-22-42-0161| [KERNEL] PCI: CLS 32 bytes, default 32
11-22-42-0161| [KERNEL] Freeing initrd memory: 5416k freed
11-22-42-0161| [KERNEL] ROMFS MTD (C) 2007 Red Hat, Inc.
11-22-42-0161| [KERNEL] msgmni has been set to 973
11-22-42-0161| [KERNEL] io scheduler noop registered
11-22-42-0161| [KERNEL] io scheduler cfq registered (default)
11-22-42-0161| [KERNEL] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
11-22-42-0161| [KERNEL] ACPI: Power Button [PWRB]
11-22-42-0161| [KERNEL] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
11-22-42-0161| [KERNEL] ACPI: Sleep Button [SLPB]
11-22-42-0161| [KERNEL] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
11-22-42-0161| [KERNEL] ACPI: Power Button [PWRF]
11-22-42-0161| [KERNEL] brd: module loaded
11-22-42-0161| [KERNEL] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
11-22-42-0161| [KERNEL] ehci-pci: EHCI PCI platform driver
11-22-42-0161| [KERNEL] ehci-pci 0000:00:0f.5: setting latency timer to 64
11-22-42-0161| [KERNEL] ehci-pci 0000:00:0f.5: EHCI Host Controller
11-22-42-0161| [KERNEL] ehci-pci 0000:00:0f.5: new USB bus registered, assigned bus number 1
11-22-42-0161| [KERNEL] ehci-pci 0000:00:0f.5: irq 11, io mem 0xefffd000
11-22-42-0161| [KERNEL] ehci-pci 0000:00:0f.5: USB 2.0 started, EHCI 1.00
11-22-42-0161| [KERNEL] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
11-22-42-0161| [KERNEL] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
11-22-42-0161| [KERNEL] usb usb1: Product: EHCI Host Controller
11-22-42-0161| [KERNEL] usb usb1: Manufacturer: Linux 3.8.6 ehci_hcd
11-22-42-0161| [KERNEL] usb usb1: SerialNumber: 0000:00:0f.5
11-22-42-0161| [KERNEL] hub 1-0:1.0: USB hub found
11-22-42-0161| [KERNEL] hub 1-0:1.0: 4 ports detected
11-22-42-0161| [KERNEL] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
11-22-42-0161| [KERNEL] ohci_hcd 0000:00:0f.4: setting latency timer to 64
11-22-42-0161| [KERNEL] ohci_hcd 0000:00:0f.4: OHCI Host Controller
11-22-42-0161| [KERNEL] ohci_hcd 0000:00:0f.4: new USB bus registered, assigned bus number 2
11-22-42-0161| [KERNEL] ohci_hcd 0000:00:0f.4: irq 11, io mem 0xefffe000
11-22-42-0161| [KERNEL] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
11-22-42-0161| [KERNEL] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
11-22-42-0161| [KERNEL] usb usb2: Product: OHCI Host Controller
11-22-42-0161| [KERNEL] usb usb2: Manufacturer: Linux 3.8.6 ohci_hcd
11-22-42-0161| [KERNEL] usb usb2: SerialNumber: 0000:00:0f.4
11-22-42-0161| [KERNEL] hub 2-0:1.0: USB hub found
11-22-42-0161| [KERNEL] hub 2-0:1.0: 4 ports detected
11-22-42-0161| [KERNEL] uhci_hcd: USB Universal Host Controller Interface driver
11-22-42-0161| [KERNEL] i8042: PNP: No PS/2 controller found. Probing ports directly.
11-22-42-0161| [KERNEL] serio: i8042 KBD port at 0x60,0x64 irq 1
11-22-42-0161| [KERNEL] serio: i8042 AUX port at 0x60,0x64 irq 12
11-22-42-0161| [KERNEL] mousedev: PS/2 mouse device common for all mice
11-22-42-0161| [KERNEL] input: PC Speaker as /devices/platform/pcspkr/input/input3
11-22-42-0161| [KERNEL] cpuidle: using governor ladder
11-22-42-0161| [KERNEL] hv_vmbus: registering driver hid_hyperv
11-22-42-0161| [KERNEL] usbcore: registered new interface driver usbhid
11-22-42-0161| [KERNEL] usbhid: USB HID core driver
11-22-42-0161| [KERNEL] zram: num_devices not specified. Using default: 1
11-22-42-0161| [KERNEL] zram: Creating 1 devices ...
11-22-42-0161| [KERNEL] zcache: using lzo compressor
11-22-42-0161| [KERNEL] zcache: cleancache enabled using kernel transcendent memory and compression buddies
11-22-42-0161| [KERNEL] TCP: cubic registered
11-22-42-0161| [KERNEL] NET: Registered protocol family 17
11-22-42-0161| [KERNEL] Using IPI Shortcut mode
11-22-42-0161| [KERNEL] RAMDISK: lzo image found at block 0
11-22-42-0161| [KERNEL] usb 2-1: new low-speed USB device number 2 using ohci_hcd
11-22-42-0161| [KERNEL] usb 2-1: New USB device found, idVendor=046d, idProduct=c05b
11-22-42-0161| [KERNEL] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
11-22-42-0161| [KERNEL] usb 2-1: Product: USB Optical Mouse
11-22-42-0161| [KERNEL] usb 2-1: Manufacturer: Logitech
11-22-42-0161| [KERNEL] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:0f.4/usb2/2-1/2-1:1.0/input/input4
11-22-42-0161| [KERNEL] hid-generic 0003:046D:C05B.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:0f.4-1/input0
11-22-42-0161| [KERNEL] VFS: Mounted root (romfs filesystem) readonly on device 1:0.
11-22-42-0161| [KERNEL] devtmpfs: mounted
11-22-42-0161| [KERNEL] Freeing unused kernel memory: 324k freed
11-22-42-0161| [KERNEL] Write protecting the kernel text: 2556k
11-22-42-0161| [KERNEL] Write protecting the kernel read-only data: 692k
11-22-42-0161| [KERNEL] tsc: Refined TSC clocksource calibration: 498.619 MHz
11-22-42-0161| [KERNEL] Switching to clocksource tsc
11-22-42-0161| [KERNEL] usb 2-3: new low-speed USB device number 3 using ohci_hcd
11-22-42-0161| [KERNEL] usb 2-3: New USB device found, idVendor=046d, idProduct=c31d
11-22-42-0161| [KERNEL] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
11-22-42-0161| [KERNEL] usb 2-3: Product: USB Keyboard
11-22-42-0161| [KERNEL] usb 2-3: Manufacturer: Logitech
11-22-42-0161| [KERNEL] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:0f.4/usb2/2-3/2-3:1.0/input/input5
11-22-42-0161| [KERNEL] hid-generic 0003:046D:C31D.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-0000:00:0f.4-3/input0
11-22-42-0161| [KERNEL] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:0f.4/usb2/2-3/2-3:1.1/input/input6
11-22-42-0161| [KERNEL] hid-generic 0003:046D:C31D.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-0000:00:0f.4-3/input1
11-22-42-0161| [pfac] Ok, PID 373.
11-22-42-0161| [initrd] WTware shell v.5.1.29
11-22-42-0161| [initrd] PCI: 1022:2080 Advanced Micro Devices [AMD] CS5536 [Geode companion] Host Bridge.
11-22-42-0161| [initrd] PCI: 1022:2081 Advanced Micro Devices [AMD] Geode LX Video.
11-22-42-0161| [initrd] PCI: C 10 1022:2082 Encryption controller Advanced Micro Devices [AMD] Geode LX AES Security Block.
11-22-42-0161| [initrd] PCI: 10ec:8139 Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+.
11-22-42-0161| [initrd] PCI: C 01 1022:2090 Mass storage controller Advanced Micro Devices [AMD] CS5536 [Geode companion] ISA.
11-22-42-0161| [initrd] PCI: C 01:80 1022:209a Mass storage controller Mass storage controller Advanced Micro Devices [AMD] CS5536 [Geode companion] IDE.
11-22-42-0161| [initrd] PCI: C 01 1022:2093 Mass storage controller Advanced Micro Devices [AMD] CS5536 [Geode companion] Audio.
11-22-42-0161| [initrd] PCI: C 03:10 1022:2094 Display controller Advanced Micro Devices [AMD] CS5536 [Geode companion] OHC.
11-22-42-0161| [initrd] PCI: C 03:20 1022:2095 Display controller Advanced Micro Devices [AMD] CS5536 [Geode companion] EHC.
11-22-42-0161| [initrd] USB: 046d:c05b Logitech, Inc..
11-22-42-0161| [initrd] USB: 046d:c31d Logitech, Inc..
11-22-42-0161| [initrd] Loading ethernet drivers.
11-22-42-0161| [initrd] modprobe 8139too.
11-22-42-0161| [KERNEL] 8139too: 8139too Fast Ethernet driver 0.9.28
11-22-42-0161| [KERNEL] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
11-22-42-0161| [initrd] NIC module 8139too.ko loaded.
11-22-42-0161| [KERNEL] 8139too 0000:00:0d.0 eth0: RealTek RTL8139 at 0x0001fc00, 14:14:4b:1e:1a:57, IRQ 11
11-22-42-0161| [initrd] modprobe 8139cp.
11-22-42-0161| [KERNEL] 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
11-22-42-0161| [initrd] NIC module 8139cp.ko loaded.
11-22-42-0161| [initrd] eth0: 10ec:8139. Apply WOL configuration.
11-22-42-0161| [KERNEL] 8139too 0000:00:0d.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
11-22-42-0161| [initrd] dhcp: 328 bytes from 192.168.33.1.
11-22-42-0161| [initrd] 00000000:000001340000000000110000c0a82101c0a82110004300440134000002010600
11-22-42-0161| [initrd] 00000020:67458b6b0000000000000000c0a82110c0a84df50000000014144b1e1a570000
11-22-42-0161| [initrd] 00000040:0000000000000000000000000000000000000000000000000000000000000000
11-22-42-0161| [initrd] 00000060:0000000000000000000000000000000000000000000000000000000000000000
11-22-42-0161| [initrd] 00000080:0000000000000000352e312e32395c7774776172652e68747470000000000000
11-22-42-0161| [initrd] 000000a0:0000000000000000000000000000000000000000000000000000000000000000
11-22-42-0161| [initrd] 000000c0:0000000000000000000000000000000000000000000000000000000000000000
11-22-42-0161| [initrd] 000000e0:0000000000000000000000000000000000000000000000000000000000000000
11-22-42-0161| [initrd] 00000100:0000000000000000638253633501023604c0a8210133040003f4800104ffffff
11-22-42-0161| [initrd] 00000120:000304c0a821010608c0a84d02c0a84d030f09686f7573652e696e74ff000000
11-22-42-0161| [initrd] 00000140:0000000000000000
11-22-42-0161| [initrd] 00000100:0000000000000000638253633501053604c0a8210133040003f4800104ffffff
11-22-42-0161| [initrd] dhcp: server address 192.168.33.1.
11-22-42-0161| [initrd] dhcp: 192.168.33.16/255.255.255.0.
11-22-42-0161| [initrd] dhcp: default gateway 192.168.33.1.
11-22-42-0161| [initrd] dhcp: DNS 192.168.77.2.
11-22-42-0161| [initrd] dhcp: DNS 192.168.77.3.
11-22-42-0161| [initrd] dhcp: domain house.int.
11-22-42-0161| [initrd] dhcp: TFTP 192.168.77.245.
11-22-42-0161| [initrd] dhcp: boot file (header) 5.1.29\wtware.http.
11-22-42-0161| [initrd] Use HTTP for boot.
11-22-42-0161| [initrd] TFTP binary "wtware/5.1.29\", configs prefix "wtware/", using "\" slash.
11-22-42-0161| Send broadcast WTCU discover.
11-22-42-0161| [initrd] HTTP: download file wtware/Everyone\list.wtc from 192.168.77.245.
11-22-42-0161| /--- FILE "/tmp/list.wtc" -----------------------
11-22-42-0161| | #
11-22-42-0161| | # Ñïèñîê ïîäêëþ÷àåìûõ ôàéëîâ.
11-22-42-0161| | #
11-22-42-0161| | # Ýòîò îòäåëüíûé ìåõàíèçì íàñòðîéêè òåðìèíàëîâ ïðåäíàçíà÷åí òîëüêî
11-22-42-0161| | # äëÿ ðó÷íîãî êîíôèãóðèðîâàíèÿ òåðìèíàëîâ. Ãðàôè÷åñêèé êîíôèãóðàòîð
11-22-42-0161| | # íå ÷èòàåò list.wtc, íå ÷èòàåò è íå ïîçâîëÿåò ðåäàêòèðîâàòü ôàéëû
11-22-42-0161| | # èç êàòàëîãà ListIncludes. Ïîýòîìó íåëüçÿ ïûòàòüñÿ íàñòðàèâàòü îäèí
11-22-42-0161| | # è òîò æå òåðìèíàë è êîíôèãóðàòîðîì, è ÷åðåç list.wtc.
11-22-42-0161| | #
11-22-42-0161| | # Ôîðìàò ñòðîêè â ýòîì ôàéëå:
11-22-42-0161| | #
11-22-42-0161| | # 01.02.03.04.05.06[([èìÿïîëüçîâàòåëÿ@][èìÿòåðìèíàëà])] [ôàéë [ôàéë ...]]] [# êîììåíòàðèé]
11-22-42-0161| | #
11-22-42-0161| | # Ïðèìåðû:
11-22-42-0161| | #
11-22-42-0161| | # 02.03.04.05.06.07 file1
11-22-42-0161| | #
11-22-42-0161| | # Îçíà÷àåò, ÷òî òåðìèíàë ñ ìàê-àäðåñîì 02.03.04.05.06.07 ïðî÷èòàåò
11-22-42-0161| | # ïàðàìåòðû èç ôàéëà ListIncludes/file1.
11-22-42-0161| | #
11-22-42-0161| | #
11-22-42-0161| | # 03.04.05.06.07.08(vasja@) file2
11-22-42-0161| | #
11-22-42-0161| | # Îçíà÷àåò, ÷òî òåðìèíàë ñ ìàê-àäðåñîì 03.04.05.06.07.08 ïðî÷èòàåò
11-22-42-0161| | # ïàðàìåòðû èç ôàéëà ListIncludes/file2 è â îêîøêî "Âõîä â Windows"
11-22-42-0161| | # ïîäñòàâèò èìÿ ïîëüçîâàòåëÿ "vasja".
11-22-42-0161| | #
11-22-42-0161| | #
11-22-42-0161| | # 04.05.06.07.08.09(term5) file6 file7 # Êîìï çàìãëàâáóõà.
11-22-42-0161| | #
11-22-42-0161| | # Îçíà÷àåò, ÷òî òåðìèíàëó ñ ìàê-àäðåñîì 04.05.06.07.08.09 áóäåò
11-22-42-0161| | # ïðèñâîåíî èìÿ term5, àíàëîãè÷íî óêàçàíèþ ïàðàìåòðà clienthostname,
11-22-42-0161| | # è îí ïðî÷èòàåò ïàðàìåòðû èç ôàéëîâ ListIncludes/file6 è
11-22-42-0161| | # ListIncludes/file7.
11-22-42-0161| | #
11-22-42-0161| | #
11-22-42-0161| | # ×òîáû ìîæíî áûëî óêàçûâàòü èìÿ ïîëüçîâàòåëÿ ðóññêèìè áóêâàìè, íàäî
11-22-42-0161| | # îòêðûòü ýòîò ôàéë â Notepad è ñîõðàíèòü ñ Encoding: Unicode.
11-22-42-0161| | #
11-22-42-0161| \----------------------------------------------------
11-22-42-0161| [initrd] HTTP: download file wtware/Terminals\14.14.4B.1E.1A.57\config.wtc from 192.168.77.245.
11-22-42-0161| /--- FILE "/tmp/config.wtc" -----------------------
11-22-42-0161| | [BOM]
11-22-42-0161| | server=fr-ts-farm.house.int
11-22-42-0161| | domain=house
11-22-42-0161| | keyboard=en
11-22-42-0161| | numlock=on
11-22-42-0161| | clienthostname=chelyabaTkani
11-22-42-0161| | user=
11-22-42-0161| | turnoffmenu=on
11-22-42-0161| | managed=on
11-22-42-0161| | resolution=1024x768
11-22-42-0161| | video=lxfb(F)
11-22-42-0161| | bpp=16
11-22-42-0161| | refresh=70
11-22-42-0161| | ask_password=on
11-22-42-0161| | connection
11-22-42-0161| [initrd] HTTP: download file wtware/Everyone\all.wtc from 192.168.77.245.
11-22-42-0161| /--- FILE "/tmp/all.wtc" -----------------------
11-22-42-0161| | server=192.168.77.245
11-22-42-0161| [initrd] HTTP: download file wtware/Everyone\wtware.lic from 192.168.77.245.
11-22-42-0161| /--- FILE "/etc/config.compiled" -----------------------
11-22-42-0161| [initrd] Hostname: "chelyabaTkani".
11-22-42-0161| RSHd listener active.
11-22-42-0161| Everyone can control terminal by http.
11-22-42-0161| [initrd] HTTP: download and unpack file wtware/5.1.29\packages\lib6 from 192.168.77.245.
11-22-42-0161| [initrd] Close TCP connection while receiving data, errno 104.
11-22-42-0161| [initrd] tftp.cpp ( 281), _http: -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-22-42-0161| [initrd] download.cpp ( 137), downloadPackage: -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-22-42-0161| [initrd] download.cpp ( 85), downloadPackage4CPU: -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-22-42-0161| [initrd] ERROR: INTERNAL ERROR
11-22-42-0161| WTware v.5.1.29
11-22-42-0161| File: initrd.cpp
11-22-42-0161| Line: 297
11-22-42-0161| Function: main
11-22-42-0161| Please, report this information to WTware tech support.
11-22-42-0174| Connection from wtc.exe at 192.168.77.245.
Re: internal error
"errno 104" - сервер разорвал соединение, и терминал не может определить причину. Тут на форуме полно такого, раньше это касалось RDP соединения. Что-то неправильно работает в сети, мы со стороны втвари это починить не сможем.
Причина может быть в чем угодно - от невыставленного MTU и некорректно работающего NAT до глюков драйвера сетевой карты сервера. Слышал про случай, когда такое вылечилось заменой блока питания свича - неисправный выключался затем сам же быстро включался, в результате кратковременные регулярные потери пакетов и "ошибка 104", долго причину искали...
