Error TFTP
Станислав
Error TFTP
Сообщение Станислав »
Вчера все прекрасно работало, а сегодня тонкие клиенты отказались грузиться. Переустановил wtware с нуля. Не помогло. Вот такой лог пишет tftp сервер.
Прошу помощи.
14-13-23-009| WTware TFTP server v.5.2.4 (c) 2003-2014 WTware http://www.wtware.com
14-13-43-617| Connection closed.
14-13-43-925| WTware TFTP server v.5.2.4 (c) 2003-2014 WTware http://www.wtware.com
14-13-43-949| Found interface 192.168.0.11/255.255.255.0 mtu 1300 mac 08:60:6E:59:8C:E2 adapter Адаптер Ethernet для виртуальной сети Hyper-V #2.
14-13-43-956| Determined DNS server 192.168.0.123
14-13-43-982| Determined DNS server 8.8.8.8
14-13-43-987| No BindIP key found in registry.
14-13-44-093| Bind at 0.0.0.0:69.
14-14-43-725| [192.168.0.33] Got RRQ, 31 bytes.
14-14-43-741| [192.168.0.33] 00000000: 35 2e 32 2e 34 5c 77 74 77 61 72 65 2e 70 78 65
14-14-43-744| [192.168.0.33] 00000010: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00
14-14-43-765| [192.168.0.33] Requests file "5.2.4\wtware.pxe". Tsize is requested, blksize default.
14-14-43-773| [192.168.0.33] Sending OASK (tsize 16282).
14-14-43-785| [192.168.0.33] Received opcode ERR.
14-14-43-787| [192.168.0.33] Got RRQ, 36 bytes.
14-14-43-838| [192.168.0.33] 00000000: 35 2e 32 2e 34 5c 77 74 77 61 72 65 2e 70 78 65
14-14-43-845| [192.168.0.33] 00000010: 00 6f 63 74 65 74 00 62 6c 6b 73 69 7a 65 00 31
14-14-43-875| [192.168.0.33] 00000020: 34 35 36 00
14-14-43-878| [192.168.0.33] Request block size 1456, forced to 1400.
14-14-43-948| [192.168.0.33] Requests file "5.2.4\wtware.pxe". Tsize is not requested, blksize 1400 bytes.
14-14-43-950| [192.168.0.33] Sending OASK (blksize 1400).
14-14-43-974| [192.168.0.33] Connection closed.
14-14-45-742| [192.168.0.33] Timeout occured while transfer "5.2.4\wtware.pxe".
14-14-45-765| [192.168.0.33] Resend block 1.
14-14-47-743| [192.168.0.33] Timeout occured while transfer "5.2.4\wtware.pxe".
14-14-47-764| [192.168.0.33] Resend block 1.
14-14-49-756| [192.168.0.33] Timeout occured while transfer "5.2.4\wtware.pxe".
14-14-49-773| [192.168.0.33] Resend block 1.
14-14-51-756| [192.168.0.33] Timeout occured while transfer "5.2.4\wtware.pxe".
14-14-51-776| [192.168.0.33] Resend block 1.
14-14-53-757| [192.168.0.33] Timeout occured while transfer "5.2.4\wtware.pxe".
14-14-53-775| [192.168.0.33] Resend block 1.
14-14-55-767| [192.168.0.33] Timeout occured while transfer "5.2.4\wtware.pxe".
14-14-55-785| [192.168.0.33] Resend block 1.
14-14-57-767| [192.168.0.33] Timeout occured while transfer "5.2.4\wtware.pxe".
14-14-57-786| [192.168.0.33] Resend block 1.
14-14-59-768| [192.168.0.33] Timeout occured while transfer "5.2.4\wtware.pxe".
14-14-59-791| [192.168.0.33] Resend block 1.
14-15-01-781| [192.168.0.33] Timeout occured while transfer "5.2.4\wtware.pxe".
14-15-01-798| [192.168.0.33] Resend block 1.
14-15-03-781| [192.168.0.33] Timeout occured while transfer "5.2.4\wtware.pxe".
14-15-03-803| [192.168.0.33] Client not responding. Connection closed.
14-15-03-806| [192.168.0.33] Connection closed.
14-15-19-738| [192.168.0.33] Received ASK, sending ERROR "Illegal TFTP operation".
14-15-19-749| [192.168.0.33] Sending ERR 4, message "Illegal TFTP operation.".
Re: Error TFTP
Почему 1300??? Надо исправить на разумное значение.
