Отключение от терминального сервера.
chekist
Сообщение chekist »
Иногда происходит самопроизвольное отключение от сервера.
вот кусок лога
17-56-26-767| [gm] modprobe fuse.
17-56-26-767| [gm] modprobe exfat.
17-56-26-767| [KERNEL] [ 32.762219] fuse init (API version 7.23)
17-56-26-767| [gm] /graphic/ppllg.png: 32x38.
17-56-26-767| [KERNEL] [ 32.764040] exFAT: Version 1.2.9
17-56-26-767| [gm] /graphic/pplsm.png: 27x30.
17-56-26-767| [gm] /graphic/offsm.png: 28x31.
17-56-26-767| [gm] Everyone can control terminal by VNC.
17-56-26-767| [gm] VNC listener at port 5900.
17-56-26-767| [gm] Add keyboard event6: Video Bus.
17-56-26-767| [rdpaudin] snd_ctl_open return -2, 'No such file or directory'.
17-56-26-767| [rdpsnd] snd_ctl_open return -2, 'No such file or directory'.
17-56-26-767| [pfac] Process pid 739 terminated, status 00000000.
17-56-26-767| [rdpaudin] Caught signal SIGSEGV.
17-56-26-767| [pfac] Process pid 738 terminated, status 00000000.
17-56-26-767| [rdpsnd] Caught signal SIGSEGV.
17-56-26-767| [pfac] Got command line /sbin/resolver 0x8233278 dns [192.168.16.28].
17-56-26-767| [pfac] Ok, PID 860.
17-56-26-767| [gm] 192.168.16.28 => 192.168.16.28.
17-56-26-767| [gm] Free ram before fork terminal client /sbin/rdpclient (session 1): 861780 Kb.
17-56-26-767| [pfac] Got command line /sbin/rdpclient 1.
17-56-26-767| [pfac] Ok, PID 861.
17-56-26-767| [pfac] Process pid 860 terminated, status 00000000.
17-56-26-767| [rdpclient 861] RDP Terminal Client, WTware v.5.3.2, pipe 1, pid 861.
17-56-26-767| [rdpclient 861] Add smartcard redirection.
17-56-26-767| [rdpdr-scard] New client connection, id 1.
17-56-26-767| [rdpclient 861] Redirect sound.
17-56-26-767| [rdpclient 861] rdpclient-rdpsnd.cpp ( 576): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 861] rdpclient-vchans.cpp ( 52): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 861] Make RDP session with 192.168.16.28, port 3389.
17-56-26-767| [rdpclient 861] Username: "chernomordin.ka".
17-56-26-767| [rdpclient 861] No password.
17-56-26-767| [rdpclient 861] No PIN.
17-56-26-767| [rdpclient 861] Domain: "tech".
17-56-26-767| [rdpclient 861] No shell.
17-56-26-767| [rdpclient 861] No directory.
17-56-26-767| [rdpclient 861] Window: 1792x1080@16.
17-56-26-767| [rdpclient 861] PFlags 0x000000AE.
17-56-26-767| [rdpclient 861] Keyboard 00000409:00000000.
17-56-26-767| [rdpclient 861] My hostname "wtwBCAEC57116B0".
17-56-26-767| [rdpclient 861] TCP: connecting to 192.168.16.28:3389.
17-56-26-767| [rdpclient 861] TCP: connection with 192.168.16.28:3389 established.
17-56-26-767| [rdpclient 861] Turn keepalive on.
17-56-26-767| [rdpclient 861] fstream.cpp ( 1020): Set TCP_USER_TIMEOUT 25000 miliseconds.
17-56-26-767| [rdpclient 861] Free ram after buffers allocation: 858600 KB.
17-56-26-767| [rdpclient 861] Process RDP server certificate.
17-56-26-767| [rdpclient 861] RDP5 encryption (X.509).
17-56-26-767| [rdpclient 861] Timezone "(UTC+03:00) Moscow, St. Petersburg, Volgograd".
17-56-26-767| [rdpdr-scard] Reset client 1.
17-56-26-767| [rdpclient 861] SessionId 0x00000008: TECH\chernomordin.ka.
17-56-26-767| [rdpclient 861] ERRINFO_RPC_INITIATED_DISCONNECT_BYUSER
17-56-26-767| [rdpclient 861] Receive Disconnect Provider Ultimatum.
17-56-26-767| [gm] TSClient gracefully end.
17-56-26-767| [rdpclient 861] Caught signal SIGTERM.
17-56-26-767| [rdpdr-scard] Close client connection 0 (id 1).
17-56-26-767| [pfac] Process pid 861 terminated, status 00000000.
17-56-26-767| [pfac] Ok, PID 862.
17-56-26-767| [gm] Free ram before fork terminal client /sbin/rdpclient (session 2): 861812 Kb.
17-56-26-767| [pfac] Got command line /sbin/rdpclient 2.
17-56-26-767| [pfac] Ok, PID 863.
17-56-26-767| [pfac] Process pid 862 terminated, status 00000000.
17-56-26-767| [rdpclient 863] RDP Terminal Client, WTware v.5.3.2, pipe 2, pid 863.
17-56-26-767| [rdpclient 863] Add smartcard redirection.
17-56-26-767| [rdpdr-scard] New client connection, id 2.
17-56-26-767| [rdpclient 863] Redirect sound.
17-56-26-767| [rdpclient 863] rdpclient-rdpsnd.cpp ( 576): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 863] rdpclient-vchans.cpp ( 52): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 863] Make RDP session with 192.168.16.28, port 3389.
17-56-26-767| [rdpclient 863] Username: "Администратор".
17-56-26-767| [rdpclient 863] No password.
17-56-26-767| [rdpclient 863] No PIN.
17-56-26-767| [rdpclient 863] Domain: "tech".
17-56-26-767| [rdpclient 863] No shell.
17-56-26-767| [rdpclient 863] No directory.
17-56-26-767| [rdpclient 863] Window: 1792x1080@16.
17-56-26-767| [rdpclient 863] PFlags 0x000000AE.
17-56-26-767| [rdpclient 863] Keyboard 00000409:00000000.
17-56-26-767| [rdpclient 863] My hostname "wtwBCAEC57116B0".
17-56-26-767| [rdpclient 863] TCP: connecting to 192.168.16.28:3389.
17-56-26-767| [rdpclient 863] TCP: connection with 192.168.16.28:3389 established.
17-56-26-767| [rdpclient 863] Turn keepalive on.
17-56-26-767| [rdpclient 863] fstream.cpp ( 1020): Set TCP_USER_TIMEOUT 25000 miliseconds.
17-56-26-767| [rdpclient 863] Free ram after buffers allocation: 858648 KB.
17-56-26-767| [rdpclient 863] Process RDP server certificate.
17-56-26-767| [rdpclient 863] RDP5 encryption (X.509).
17-56-26-767| [rdpclient 863] Timezone "(UTC+03:00) Moscow, St. Petersburg, Volgograd".
17-56-26-767| [rdpdr-scard] Reset client 2.
17-56-26-767| [rdpdr-scard] Contexts left: 3, cards left: 0.
17-56-26-767| [rdpclient 863] SessionId 0x00000006: TECH\Администратор.
17-56-26-767| [rdpdr-scard] Contexts left: 2, cards left: 0.
17-56-26-767| [rdpclient 863] Sound redirection: 44100 frames per second.
17-56-26-767| [rdpclient 863] rdpclient-rdpsnd.cpp ( 424): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 863] Caught signal SIGSEGV.
17-56-26-767| [rdpdr-scard] Close client connection 0 (id 2).
17-56-26-767| [gm] ./fstream.h ( 240): -- ERROR -- Not enough data in stream in TSClientSession.cpp line 203.
17-56-26-767| [gm] ./fstream.h ( 242): -- ERROR -- Not enough data in stream in ./fstream.h line 260.
17-56-26-767| [pfac] Process pid 863 terminated, status 00000000.
17-56-26-767| [pfac] Ok, PID 864.
17-56-26-767| [gm] Free ram before fork terminal client /sbin/rdpclient (session 3): 861812 Kb.
17-56-26-767| [pfac] Got command line /sbin/rdpclient 3.
17-56-26-767| [pfac] Ok, PID 865.
17-56-26-767| [pfac] Process pid 864 terminated, status 00000000.
17-56-26-767| [rdpclient 865] RDP Terminal Client, WTware v.5.3.2, pipe 3, pid 865.
17-56-26-767| [rdpclient 865] Add smartcard redirection.
17-56-26-767| [rdpdr-scard] New client connection, id 3.
17-56-26-767| [rdpclient 865] Redirect sound.
17-56-26-767| [rdpclient 865] rdpclient-rdpsnd.cpp ( 576): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 865] rdpclient-vchans.cpp ( 52): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 865] Make RDP session with 192.168.16.28, port 3389.
17-56-26-767| [rdpclient 865] Username: "Администратор".
17-56-26-767| [rdpclient 865] No password.
17-56-26-767| [rdpclient 865] No PIN.
17-56-26-767| [rdpclient 865] Domain: "tech".
17-56-26-767| [rdpclient 865] No shell.
17-56-26-767| [rdpclient 865] No directory.
17-56-26-767| [rdpclient 865] Window: 1792x1080@16.
17-56-26-767| [rdpclient 865] PFlags 0x000000AE.
17-56-26-767| [rdpclient 865] Keyboard 00000409:00000000.
17-56-26-767| [rdpclient 865] My hostname "wtwBCAEC57116B0".
17-56-26-767| [rdpclient 865] TCP: connecting to 192.168.16.28:3389.
17-56-26-767| [rdpclient 865] TCP: connection with 192.168.16.28:3389 established.
17-56-26-767| [rdpclient 865] Turn keepalive on.
17-56-26-767| [rdpclient 865] fstream.cpp ( 1020): Set TCP_USER_TIMEOUT 25000 miliseconds.
17-56-26-767| [rdpclient 865] Free ram after buffers allocation: 858632 KB.
17-56-26-767| [rdpclient 865] Process RDP server certificate.
17-56-26-767| [rdpclient 865] RDP5 encryption (X.509).
17-56-26-767| [rdpclient 865] Timezone "(UTC+03:00) Moscow, St. Petersburg, Volgograd".
17-56-26-767| [rdpdr-scard] Reset client 3.
17-56-26-767| [rdpclient 865] SessionId 0x00000006: TECH\Администратор.
17-56-26-767| [rdpclient 865] Sound redirection: 44100 frames per second.
17-56-26-767| [rdpclient 865] rdpclient-rdpsnd.cpp ( 424): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 865] Caught signal SIGSEGV.
17-56-26-767| [rdpdr-scard] Close client connection 0 (id 3).
17-56-26-767| [rdpdr-scard] Contexts left: 1, cards left: 0.
17-56-26-767| [pfac] Process pid 865 terminated, status 00000000.
17-56-26-767| [pfac] Ok, PID 866.
17-56-26-767| [gm] Free ram before fork terminal client /sbin/rdpclient (session 4): 861812 Kb.
17-56-26-767| [pfac] Got command line /sbin/rdpclient 4.
17-56-26-767| [pfac] Ok, PID 867.
17-56-26-767| [pfac] Process pid 866 terminated, status 00000000.
17-56-26-767| [rdpclient 867] RDP Terminal Client, WTware v.5.3.2, pipe 4, pid 867.
17-56-26-767| [rdpclient 867] Add smartcard redirection.
17-56-26-767| [rdpdr-scard] New client connection, id 4.
17-56-26-767| [rdpclient 867] Redirect sound.
17-56-26-767| [rdpclient 867] rdpclient-rdpsnd.cpp ( 576): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 867] rdpclient-vchans.cpp ( 52): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 867] Make RDP session with 192.168.16.28, port 3389.
17-56-26-767| [rdpclient 867] Username: "Администратор".
17-56-26-767| [rdpclient 867] No password.
17-56-26-767| [rdpclient 867] No PIN.
17-56-26-767| [rdpclient 867] Domain: "tech".
17-56-26-767| [rdpclient 867] No shell.
17-56-26-767| [rdpclient 867] No directory.
17-56-26-767| [rdpclient 867] Window: 1792x1080@16.
17-56-26-767| [rdpclient 867] PFlags 0x000000AE.
17-56-26-767| [rdpclient 867] Keyboard 00000409:00000000.
17-56-26-767| [rdpclient 867] My hostname "wtwBCAEC57116B0".
17-56-26-767| [rdpclient 867] TCP: connecting to 192.168.16.28:3389.
17-56-26-767| [rdpclient 867] TCP: connection with 192.168.16.28:3389 established.
17-56-26-767| [rdpclient 867] Turn keepalive on.
17-56-26-767| [rdpclient 867] fstream.cpp ( 1020): Set TCP_USER_TIMEOUT 25000 miliseconds.
17-56-26-767| [rdpclient 867] Free ram after buffers allocation: 858532 KB.
17-56-26-767| [rdpclient 867] Process RDP server certificate.
17-56-26-767| [rdpclient 867] RDP5 encryption (X.509).
17-56-26-767| [rdpclient 867] Timezone "(UTC+03:00) Moscow, St. Petersburg, Volgograd".
17-56-26-767| [rdpdr-scard] Reset client 4.
17-56-26-767| [rdpdr-scard] Contexts left: 4, cards left: 0.
17-56-26-767| [rdpclient 867] SessionId 0x00000006: TECH\Администратор.
17-56-26-767| [rdpclient 867] Sound redirection: 44100 frames per second.
17-56-26-767| [rdpclient 867] rdpclient-rdpsnd.cpp ( 424): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 867] Caught signal SIGSEGV.
17-56-26-767| [rdpdr-scard] Close client connection 0 (id 4).
17-56-26-767| [pfac] Process pid 867 terminated, status 00000000.
17-56-26-767| [pfac] Ok, PID 868.
17-56-26-767| [gm] Free ram before fork terminal client /sbin/rdpclient (session 5): 861812 Kb.
17-56-26-767| [pfac] Got command line /sbin/rdpclient 5.
17-56-26-767| [pfac] Ok, PID 869.
17-56-26-767| [pfac] Process pid 868 terminated, status 00000000.
17-56-26-767| [rdpclient 869] RDP Terminal Client, WTware v.5.3.2, pipe 5, pid 869.
17-56-26-767| [rdpclient 869] Add smartcard redirection.
17-56-26-767| [rdpdr-scard] New client connection, id 5.
17-56-26-767| [rdpclient 869] Redirect sound.
17-56-26-767| [rdpclient 869] rdpclient-rdpsnd.cpp ( 576): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 869] rdpclient-vchans.cpp ( 52): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
17-56-26-767| [rdpclient 869] Make RDP session with 192.168.16.28, port 3389.
17-56-26-767| [rdpclient 869] Username: "Администратор".
17-56-26-767| [rdpclient 869] No password.
17-56-26-767| [rdpclient 869] No PIN.
17-56-26-767| [rdpclient 869] Domain: "tech".
17-56-26-767| [rdpclient 869] No shell.
17-56-26-767| [rdpclient 869] No directory.
17-56-26-767| [rdpclient 869] Window: 1792x1080@16.
17-56-26-767| [rdpclient 869] PFlags 0x000000AE.
17-56-26-767| [rdpclient 869] Keyboard 00000409:00000000.
17-56-26-767| [rdpclient 869] My hostname "wtwBCAEC57116B0".
17-56-26-767| [rdpclient 869] TCP: connecting to 192.168.16.28:3389.
17-56-26-767| [rdpclient 869] TCP: connection with 192.168.16.28:3389 established.
17-56-26-767| [rdpclient 869] Turn keepalive on.
17-56-26-767| [rdpclient 869] fstream.cpp ( 1020): Set TCP_USER_TIMEOUT 25000 miliseconds.
17-56-26-767| [rdpclient 869] Free ram after buffers allocation: 858648 KB.
17-56-26-767| [rdpclient 869] Process RDP server certificate.
17-56-26-767| [rdpclient 869] RDP5 encryption (X.509).
17-56-26-767| [rdpclient 869] Timezone "(UTC+03:00) Moscow, St. Petersburg, Volgograd".
17-56-26-767| [rdpdr-scard] Reset client 5.
17-56-26-767| [rdpclient 869] SessionId 0x00000006: TECH\Администратор.
17-56-26-790| Connection from wtc.exe at 192.168.16.2.
Re: Отключение от терминального сервера.
Это из-за звука, которого нет. Падает когда пытается воспроизвести звук. Убери из конфига sound=
tyulebaev
Сообщение tyulebaev »
Постоянные отключения от сервера терминалов. То ошибка "I'm tyred!", то "TCP\IP connection lost. Network failure?" Лог прилагаю.
LOG.txt
(19.17 КБ) 1509 скачиваний
1. Свежая версия называется 5.3.10. Надо её скачать, поставить и сделать так, чтобы она загружалась.
2. Лог - это такая большая штука из целой кучи строк. Его надо выкладывать целиком, не обрывать.
