TCP/IP connection lost. Network failure?
ashum
Сообщение ashum »
Не подключается к серверу W2012R2.
WTware 5.6.22/RPi supervisor.
[        KERNEL] [    0.000000] Booting Linux on physical CPU 0x0
[        KERNEL] [    0.000000] Linux version 4.9.65 (aka@c12) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #3 SMP Fri Dec 1 21:14:42 +04 2017
[        KERNEL] [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[        KERNEL] [    0.000000] CPU: div instructions available: patching division code
[        KERNEL] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[        KERNEL] [    0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
[        KERNEL] [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
[        KERNEL] [    0.000000] Memory policy: Data cache writealloc
[        KERNEL] [    0.000000] On node 0 totalpages: 242688
[        KERNEL] [    0.000000] free_area_init_node: node 0, pgdat 80c22b40, node_mem_map ba3a1000
[        KERNEL] [    0.000000]   Normal zone: 2133 pages used for memmap
[        KERNEL] [    0.000000]   Normal zone: 0 pages reserved
[        KERNEL] [    0.000000]   Normal zone: 242688 pages, LIFO batch:31
[        KERNEL] [    0.000000] percpu: Embedded 11 pages/cpu @ba367000 s15948 r8192 d20916 u45056
[        KERNEL] [    0.000000] pcpu-alloc: s15948 r8192 d20916 u45056 alloc=11*4096
[        KERNEL] [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[        KERNEL] [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 240555
[        KERNEL] [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  quiet wtboot=mmc
[        KERNEL] [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[        KERNEL] [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[        KERNEL] [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[        KERNEL] [    0.000000] Memory: 941160K/970752K available (5120K kernel code, 143K rwdata, 920K rodata, 5120K init, 365K bss, 21400K reserved, 8192K cma-reserved)
[        KERNEL] [    0.000000] Virtual kernel memory layout:
[        KERNEL] [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[        KERNEL] [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[        KERNEL] [    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
[        KERNEL] [    0.000000]     lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
[        KERNEL] [    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
[        KERNEL] [    0.000000]       .text : 0x80008000 - 0x80600000   (6112 kB)
[        KERNEL] [    0.000000]       .init : 0x80700000 - 0x80c00000   (5120 kB)
[        KERNEL] [    0.000000]       .data : 0x80c00000 - 0x80c23df8   ( 144 kB)
[        KERNEL] [    0.000000]        .bss : 0x80c25000 - 0x80c805a0   ( 366 kB)
[        KERNEL] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[        KERNEL] [    0.000000] Hierarchical RCU implementation.
[        KERNEL] [    0.000000] 	Build-time adjustment of leaf fanout to 32.
[        KERNEL] [    0.000000] NR_IRQS:16 nr_irqs:16 16
[        KERNEL] [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[        KERNEL] [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[        KERNEL] [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[        KERNEL] [    0.000017] Switching to timer-based delay loop, resolution 52ns
[        KERNEL] [    0.000208] Console: colour dummy device 80x30
[        KERNEL] [    0.000222] console [tty0] enabled
[        KERNEL] [    0.000238] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[        KERNEL] [    0.000251] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.000381] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.000389] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.001234] Disabling memory control group subsystem
[        KERNEL] [    0.001288] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.001620] CPU0: update cpu_capacity 1024
[        KERNEL] [    0.001629] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[        KERNEL] [    0.001652] Setting up static identity map for 0x100000 - 0x100034
[        KERNEL] [    0.003172] CPU1: update cpu_capacity 1024
[        KERNEL] [    0.003179] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[        KERNEL] [    0.003729] CPU2: update cpu_capacity 1024
[        KERNEL] [    0.003735] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[        KERNEL] [    0.004280] CPU3: update cpu_capacity 1024
[        KERNEL] [    0.004286] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[        KERNEL] [    0.004364] Brought up 4 CPUs
[        KERNEL] [    0.004373] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[        KERNEL] [    0.004377] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.004380] CPU: Virtualization extensions available.
[        KERNEL] [    0.004917] devtmpfs: initialized
[        KERNEL] [    0.014591] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[        KERNEL] [    0.014970] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[        KERNEL] [    0.014986] futex hash table entries: 1024 (order: 4, 65536 bytes)
[        KERNEL] [    0.015469] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.015998] NET: Registered protocol family 16
[        KERNEL] [    0.017832] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.027969] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[        KERNEL] [    0.111147] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[        KERNEL] [    0.113462] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.113585] usbcore: registered new interface driver hub
[        KERNEL] [    0.113668] usbcore: registered new device driver usb
[        KERNEL] [    0.120125] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-11-17 15:19
[        KERNEL] [    0.122389] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.137435] NET: Registered protocol family 2
[        KERNEL] [    0.138009] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.138117] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.138301] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.138387] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138428] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.138600] NET: Registered protocol family 1
[        KERNEL] [    2.242713] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[        KERNEL] [    2.279207] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    2.279217] io scheduler noop registered
[        KERNEL] [    2.279222] io scheduler deadline registered (default)
[        KERNEL] [    2.287993] BCM2708FB: allocated DMA memory fad10000
[        KERNEL] [    2.288032] BCM2708FB: allocated DMA channel 0 @ bb80f000
[        KERNEL] [    2.308415] Console: switching to colour frame buffer device 160x64
[        KERNEL] [    2.321807] bcm2835-rng 3f104000.rng: hwrng registered
[        KERNEL] [    2.322010] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    2.323022] vc-sm: Videocore shared memory driver
[        KERNEL] [    2.328205] zram: Added device: zram0
[        KERNEL] [    2.328239] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    2.556308] Core Release: 2.80a
[        KERNEL] [    2.556316] Setting default values for core params
[        KERNEL] [    2.556341] Finished setting default values for core params
[        KERNEL] [    2.756694] Using Buffer DMA mode
[        KERNEL] [    2.756700] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    2.756703] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    2.756710] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    2.756740] Dedicated Tx FIFOs mode
[        KERNEL] [    2.757241] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[        KERNEL] [    2.757264] FIQ FSM acceleration enabled for :
[        KERNEL] [    2.757264] Non-periodic Split Transactions
[        KERNEL] [    2.757264] Periodic Split Transactions
[        KERNEL] [    2.757264] High-Speed Isochronous Endpoints
[        KERNEL] [    2.757264] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    2.757282] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    2.757337] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397d28
[        KERNEL] [    2.757346] WARN::hcd_init_fiq:460: FIQ ASM at 0x8039808c length 36
[        KERNEL] [    2.757355] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[        KERNEL] [    2.757410] dwc_otg 3f980000.usb: DWC OTG Controller
[        KERNEL] [    2.757443] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[        KERNEL] [    2.757473] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[        KERNEL] [    2.757518] Init: Port Power? op_state=1
[        KERNEL] [    2.757521] Init: Power Port (0)
[        KERNEL] [    2.757695] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[        KERNEL] [    2.757705] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.757712] usb usb1: Product: DWC OTG Controller
[        KERNEL] [    2.757719] usb usb1: Manufacturer: Linux 4.9.65 dwc_otg_hcd
[        KERNEL] [    2.757726] usb usb1: SerialNumber: 3f980000.usb
[        KERNEL] [    2.758437] hub 1-0:1.0: USB hub found
[        KERNEL] [    2.758472] hub 1-0:1.0: 1 port detected
[        KERNEL] [    2.759157] dwc_otg: FIQ enabled
[        KERNEL] [    2.759161] dwc_otg: NAK holdoff enabled
[        KERNEL] [    2.759165] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    2.759178] Module dwc_common_port init
[        KERNEL] [    2.759561] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    2.760926] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[        KERNEL] [    2.761383] bcm2835-cpufreq: min=600000 max=1200000
[        KERNEL] [    2.762548] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[        KERNEL] [    2.764968] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[        KERNEL] [    2.767883] ledtrig-cpu: registered to indicate activity on CPUs
[        KERNEL] [    2.768157] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    2.769705] usbcore: registered new interface driver usbhid
[        KERNEL] [    2.769712] usbhid: USB HID core driver
[        KERNEL] [    2.771880] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[        KERNEL] [    2.781851] [vc_sm_connected_init]: start
[        KERNEL] [    2.790798] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    2.791292] NET: Registered protocol family 17
[        KERNEL] [    2.791474] Registering SWP/SWPB emulation handler
[        KERNEL] [    2.792944] registered taskstats version 1
[        KERNEL] [    2.799871] sdhost: log_buf @ bad07000 (fad07000)
[        KERNEL] [    2.872429] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[        KERNEL] [    2.874729] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[        KERNEL] [    2.874736] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[        KERNEL] [    2.953608] mmc0: host does not support reading read-only switch, assuming write-enable
[        KERNEL] [    2.953685] of_cfs_init
[        KERNEL] [    2.953766] of_cfs_init: OK
[        KERNEL] [    2.972492] mmc0: Problem switching card into high-speed mode!
[        KERNEL] [    2.972636] Indeed it is in host mode hprt0 = 00021501
[        KERNEL] [    2.980068] Freeing unused kernel memory: 5120K
[        KERNEL] [    3.049419] mmc0: new SDHC card at address 0001
[        KERNEL] [    3.051345] mmcblk0: mmc0:0001 ASTC 14.7 GiB
[        KERNEL] [    3.060900] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[        KERNEL] [    3.061500]  mmcblk0: p1
[        KERNEL] [    3.063068] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.064716] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.066198] random: fast init done
[        KERNEL] [    3.067653] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[        KERNEL] [    3.158662] mmc1: new high speed SDIO card at address 0001
[        KERNEL] [    3.182443] usb 1-1: new high-speed USB device number 2 using dwc_otg
[        KERNEL] [    3.182590] Indeed it is in host mode hprt0 = 00001101
[       hotplug] [    3.229641] Block device 254:0. No action.
[       hotplug] [    3.362509] Block device 179:1. No action.
[       hotplug] [    3.362665] Block device 179:0. No action.
[          pfac] [    3.370192] Run /sbin/initrd.
[          pfac] [    3.374615] Ok, PID 608.
[        initrd] [    3.374708] WTware shell 5.6.22/RPi
[        initrd] [    3.394725] HDD/MMC/SD boot.
[        KERNEL] [    3.442658] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    3.442670] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.443442] hub 1-1:1.0: USB hub found
[        KERNEL] [    3.443569] hub 1-1:1.0: 5 ports detected
[        KERNEL] [    3.762420] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    3.892660] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    3.892671] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.992414] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[        KERNEL] [    4.140375] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c31c
[        KERNEL] [    4.140386] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.140393] usb 1-1.2: Product: USB Keyboard
[        KERNEL] [    4.140400] usb 1-1.2: Manufacturer: Logitech
[        KERNEL] [    4.160587] input: Logitech USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C31C.0001/input/input0
[        KERNEL] [    4.223820] hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-3f980000.usb-1.2/input0
[        KERNEL] [    4.252128] input: Logitech USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C31C.0002/input/input1
[        KERNEL] [    4.312866] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-3f980000.usb-1.2/input1
[        initrd] [    4.406849] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
| # http://www.raspberrypi.org/documentation/configuration/config-txt.md
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=1
| #hdmi_mode=1
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| #hdmi_group=2
| # 800x600:   hdmi_mode=9
| # 1024x768:  hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768:  hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900:  hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768:  hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| framebuffer_depth=32
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
[        initrd] [    4.414273] WTpassword empty.
[        KERNEL] [    4.412438] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[        KERNEL] [    4.547379] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c05a
[        KERNEL] [    4.547392] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.547400] usb 1-1.3: Product: USB Optical Mouse
[        KERNEL] [    4.547407] usb 1-1.3: Manufacturer: Logitech
[        KERNEL] [    4.552058] input: Logitech USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C05A.0003/input/input2
[        KERNEL] [    4.553555] hid-generic 0003:046D:C05A.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-3f980000.usb-1.3/input0
| clientIP = *
| config = local
[        initrd] [    6.416038] Load ethernet drivers.
[        initrd] [    6.419785] modprobe smsc95xx.
[        KERNEL] [    6.429431] smsc95xx v1.0.5
[        KERNEL] [    6.525712] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:11:42:68
[        KERNEL] [    6.525969] usbcore: registered new interface driver smsc95xx
[        KERNEL] [    6.614580] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[        initrd] [    8.215736] WTpassword empty.
[        KERNEL] [    8.217517] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[        initrd] [    9.420177] dhcp: 367 bytes from 195.38.58.24.
[        initrd] [    9.420358] 00000000:0000015B0000000000110000C3263A18FFFFFFFF00430044015B000002010600  ...[........&:.....C.D.[......
[        initrd] [    9.420487] 00000020:67458B6B0000000000000000C3263966C3263A2200000000B827EB1142680000  gE.k.........&9f.&:".....'.Bh..
[        initrd] [    9.420614] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    9.420739] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    9.420864] 00000080:0000000000000000626F6F745C7838365C7764736E62702E636F6D0000000000  ........boot\x86\wdsnbp.com.....
[        initrd] [    9.420988] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    9.421111] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [    9.421234] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.680186] dhcp: 367 bytes from 195.38.58.24.
[        initrd] [   11.680372] 00000000:0000015B0000000000110000C3263A18FFFFFFFF00430044015B000002010600  ...[........&:.....C.D.[......
[        initrd] [   11.680502] 00000020:67458B6B0000000000000000C3263966C3263A2200000000B827EB1142680000  gE.k.........&9f.&:".....'.Bh..
[        initrd] [   11.680628] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.680752] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.680895] 00000080:0000000000000000626F6F745C7838365C7764736E62702E636F6D0000000000  ........boot\x86\wdsnbp.com.....
[        initrd] [   11.681018] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.681140] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.681262] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.720106] dhcp: server address 195.38.58.24.
[        initrd] [   11.720219] dhcp: 195.38.57.102/255.255.252.0.
[        initrd] [   11.720326] dhcp: default gateway 195.38.58.206.
[        initrd] [   11.720558] dhcp: DNS 195.38.58.22.
[        initrd] [   11.720629] dhcp: DNS 195.38.58.24.
[        initrd] [   11.720696] dhcp: domain radioc.ru.
[        initrd] [   11.720760] dhcp: TFTP from 066 195.38.58.34.
[        initrd] [   11.720825] dhcp: TFTP 195.38.58.34.
[        initrd] [   11.720889] dhcp: boot file (067) boot\x86\wdsnbp.com.
[        initrd] [   11.720954] TFTP binary "boot\x86\", configs prefix "boot\", using "\" slash.
WTC listener is active.
Send broadcast WTCU discover.
[          pfac] [   11.724041] Run /sbin/httpd.
[        initrd] [   11.724115] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   11.724232] Ok, PID 650.
[         httpd] [   11.728607] HTTP Server, WTware 5.6.22/RPi
[        initrd] [   11.836654] USB: 046d:c05a Logitech, Inc. M90/M100 Optical Mouse.
[        initrd] [   11.836787] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[        initrd] [   11.836860] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[        initrd] [   11.836931] USB: 046d:c31c Logitech, Inc. Keyboard K120.
[        initrd] [   11.837227] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[        initrd] [   11.837959] Common local disk config:
| [BOM]
| server=144.76.35.17
| [BOM]
| server=144.76.35.17
| connection
[        initrd] [   11.838708] Hostname: "wtwB827EB114268".
RSH: listener is active.
[         httpd] [   12.074941] Reread settings.
[         httpd] [   12.075105] Everyone can control terminal by HTTP.
[            gm] [   12.079309] WTware session manager 5.6.22/RPi.
[            gm] [   12.080309] EV_REL flag found. Add mouse event2: Logitech USB Optical Mouse.
[            gm] [   12.080396] Add keyboard event1: Logitech USB Keyboard.
[            gm] [   12.080470] Add keyboard event0: Logitech USB Keyboard.
[            gm] [   12.080581] Display mode: 1280x1024, 16 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   12.092556] Framebuffer device found.
[            gm] [   12.092635] LINELENBYTES 2560
[            gm] [   12.092708] VLEN 2621440
[            gm] [   12.105467] Use /lib/ui16.so.
[            gm] [   12.182771] Run '/sbin/resolver 0xa04ac8 dns [144.76.35.17]', log '', env '', pid ''.
[            gm] [   12.182906] Nobody can control terminal by VNC.
[          pfac] [   12.183120] Run /sbin/resolver 0xa04ac8 dns [144.76.35.17].
[          pfac] [   12.183662] Ok, PID 651.
[            gm] [   12.187271] 144.76.35.17 => 144.76.35.17.
[          pfac] [   12.187648] Process pid 651 terminated, status 00000000.
[            gm] [   12.196661] Free ram before fork terminal client /sbin/rdpclient (session 1): 932072 Kb.
[            gm] [   12.196807] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   12.196965] Run /sbin/rdpclient 1.
[          pfac] [   12.197375] Ok, PID 652.
[ rdpclient 652] [   12.204528] RDP Terminal Client, WTware 5.6.22/RPi, pipe 1, pid 652.
[ rdpclient 652] [   12.205047] Use /lib/ui16.so.
[ rdpclient 652] [   12.206383] Make RDP session with 144.76.35.17, port 3389.
[ rdpclient 652] [   12.206557]  No username.
[ rdpclient 652] [   12.206637]  No password.
[ rdpclient 652] [   12.206718]  No PIN.
[ rdpclient 652] [   12.206850]  No domain.
[ rdpclient 652] [   12.206962]  No shell.
[ rdpclient 652] [   12.207042]  No directory.
[ rdpclient 652] [   12.207120]  Window: 1280x1024@16.
[ rdpclient 652] [   12.207197]  PFlags 0x0000002F.
[ rdpclient 652] [   12.207273]  Keyboard 00000409:00000000.
[ rdpclient 652] [   12.207349]  My hostname "wtwB827EB114268".
[ rdpclient 652] [   12.207426] TCP: connecting to 144.76.35.17:3389.
[ rdpclient 652] [   12.277088] TCP: connection with 144.76.35.17:3389 established.
[ rdpclient 652] [   12.277215] Turn keepalive on.
[ rdpclient 652] [   12.277988] Free ram after buffers allocation: 931320 KB.
[ rdpclient 652] [   12.348415] Server supports GFX Pipeline.
[ rdpclient 652] [   12.418521] Process RDP server certificate.
[ rdpclient 652] [   12.418611] RDP5 encryption (X.509).
[ rdpclient 652] [   13.280797] Unsupported EncryptionMethod 0x00000010.
[ rdpclient 652] [   13.280918] Enable font smoothing and Desktop Composition.
[ rdpclient 652] [   13.352112]      ./streamInOps.h (  313): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 652] [   13.352199]  ./streamInStealer.h (   29): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 652] [   13.352279] [ERROR] totalLength 61565 large then packet 26 channelId 1003.
[ rdpclient 652] [   13.352357] 00000000:0300003602F08068000103EB302808000000100001029364BFCF7FF06ABB1F88  ...6...h....0(........d...j..
[ rdpclient 652] [   13.352436] 00000020:CD9463DCC689586F8EE80158FC32FF5BF049B97A6BF1                      ..c...Xo...X.2.[.I.zk.
[ rdpclient 652] [   13.352514] rdpclient-connect.cpp ( 2769): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 652] [   13.352592] Close TCP connection while receiving data, errno 104.
[            gm] [   13.352670] Final message: TCP/IP connection lost. Network failure?
[ rdpclient 652] [   13.352713] TCP/IP connection lost. Network failure?
[          pfac] [   13.353531] Process pid 652 terminated, status 00000009.
[        KERNEL] [   15.914146] random: crng init done
[            gm] [   24.065935] Run '/sbin/resolver 0xa04ac8 dns [144.76.35.17]', log '', env '', pid ''.
[          pfac] [   24.066187] Run /sbin/resolver 0xa04ac8 dns [144.76.35.17].
[          pfac] [   24.066274] Ok, PID 658.
[            gm] [   24.069468] 144.76.35.17 => 144.76.35.17.
[          pfac] [   24.069891] Process pid 658 terminated, status 00000000.
[            gm] [   24.078791] Free ram before fork terminal client /sbin/rdpclient (session 2): 931436 Kb.
[          pfac] [   24.079339] Run /sbin/rdpclient 2.
[            gm] [   24.079406] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   24.079499] Ok, PID 659.
[ rdpclient 659] [   24.086203] RDP Terminal Client, WTware 5.6.22/RPi, pipe 2, pid 659.
[ rdpclient 659] [   24.086691] Use /lib/ui16.so.
[ rdpclient 659] [   24.087907] Make RDP session with 144.76.35.17, port 3389.
[ rdpclient 659] [   24.088086]  No username.
[ rdpclient 659] [   24.088166]  No password.
[ rdpclient 659] [   24.088245]  No PIN.
[ rdpclient 659] [   24.088321]  No domain.
[ rdpclient 659] [   24.088399]  No shell.
[ rdpclient 659] [   24.088475]  No directory.
[ rdpclient 659] [   24.088552]  Window: 1280x1024@16.
[ rdpclient 659] [   24.088630]  PFlags 0x0000002F.
[ rdpclient 659] [   24.088707]  Keyboard 00000409:00000000.
[ rdpclient 659] [   24.088782]  My hostname "wtwB827EB114268".
[ rdpclient 659] [   24.088859] TCP: connecting to 144.76.35.17:3389.
[ rdpclient 659] [   24.157441] TCP: connection with 144.76.35.17:3389 established.
[ rdpclient 659] [   24.157564] Turn keepalive on.
[ rdpclient 659] [   24.158287] Free ram after buffers allocation: 931328 KB.
[ rdpclient 659] [   24.228588] Server supports GFX Pipeline.
[ rdpclient 659] [   24.298920] Process RDP server certificate.
[ rdpclient 659] [   24.299006] RDP5 encryption (X.509).
[ rdpclient 659] [   24.854343] Unsupported EncryptionMethod 0x00000010.
[ rdpclient 659] [   24.854444] Enable font smoothing and Desktop Composition.
[ rdpclient 659] [   24.924163]      ./streamInOps.h (  313): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 659] [   24.924251]  ./streamInStealer.h (   29): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 659] [   24.924331] [ERROR] totalLength 54236 large then packet 26 channelId 1003.
[ rdpclient 659] [   24.924409] 00000000:0300003602F08068000103EB30280800000010000102CB0C2026DED340F58BAF  ...6...h....0(......... &..@...
[ rdpclient 659] [   24.924488] 00000020:2671B0F371FAD1011757B4D18B5A43CE78427AC573F0                      &q..q...W...ZC.xBz.s.
[ rdpclient 659] [   24.924567] rdpclient-connect.cpp ( 2769): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 659] [   24.924646] Close TCP connection while receiving data, errno 104.
[            gm] [   24.924722] Final message: TCP/IP connection lost. Network failure?
[ rdpclient 659] [   24.924768] TCP/IP connection lost. Network failure?
[          pfac] [   24.925612] Process pid 659 terminated, status 00000009.
[            gm] [   32.761853] Run '/sbin/resolver 0xa04ac8 dns [144.76.35.17]', log '', env '', pid ''.
[          pfac] [   32.762105] Run /sbin/resolver 0xa04ac8 dns [144.76.35.17].
[          pfac] [   32.762191] Ok, PID 663.
[            gm] [   32.765470] 144.76.35.17 => 144.76.35.17.
[          pfac] [   32.765885] Process pid 663 terminated, status 00000000.
[            gm] [   32.774863] Free ram before fork terminal client /sbin/rdpclient (session 3): 931560 Kb.
[          pfac] [   32.775403] Run /sbin/rdpclient 3.
[            gm] [   32.775467] Run '/sbin/rdpclient 3', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   32.775554] Ok, PID 664.
[ rdpclient 664] [   32.782301] RDP Terminal Client, WTware 5.6.22/RPi, pipe 3, pid 664.
[ rdpclient 664] [   32.782836] Use /lib/ui16.so.
[ rdpclient 664] [   32.784073] Make RDP session with 144.76.35.17, port 3389.
[ rdpclient 664] [   32.784252]  No username.
[ rdpclient 664] [   32.784331]  No password.
[ rdpclient 664] [   32.784411]  No PIN.
[ rdpclient 664] [   32.784489]  No domain.
[ rdpclient 664] [   32.784564]  No shell.
[ rdpclient 664] [   32.784641]  No directory.
[ rdpclient 664] [   32.784718]  Window: 1280x1024@16.
[ rdpclient 664] [   32.784794]  PFlags 0x0000002F.
[ rdpclient 664] [   32.784871]  Keyboard 00000409:00000000.
[ rdpclient 664] [   32.784950]  My hostname "wtwB827EB114268".
[ rdpclient 664] [   32.785027] TCP: connecting to 144.76.35.17:3389.
[ rdpclient 664] [   32.853498] TCP: connection with 144.76.35.17:3389 established.
[ rdpclient 664] [   32.853617] Turn keepalive on.
[ rdpclient 664] [   32.854397] Free ram after buffers allocation: 931312 KB.
[ rdpclient 664] [   32.924524] Server supports GFX Pipeline.
[ rdpclient 664] [   32.994746] Process RDP server certificate.
[ rdpclient 664] [   32.994832] RDP5 encryption (X.509).
[ rdpclient 664] [   33.551789] Unsupported EncryptionMethod 0x00000010.
[ rdpclient 664] [   33.551898] Enable font smoothing and Desktop Composition.
[ rdpclient 664] [   33.620957]      ./streamInOps.h (  313): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 664] [   33.621044]  ./streamInStealer.h (   29): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 664] [   33.621124] [ERROR] totalLength 30850 large then packet 26 channelId 1003.
[ rdpclient 664] [   33.621202] 00000000:0300003602F08068000103EB3028080000001000010200201E018478B346EB4D  ...6...h....0(........ ..x.F.M
[ rdpclient 664] [   33.621286] 00000020:91E5D6861328A945C945C113071043B3B90E268EA056                      ....(.E.E..C...&..V
[ rdpclient 664] [   33.621364] rdpclient-connect.cpp ( 2769): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[            gm] [   33.621462] Final message: TCP/IP connection lost. Network failure?
[ rdpclient 664] [   33.621506] Close TCP connection while receiving data, errno 104.
[ rdpclient 664] [   33.621582] TCP/IP connection lost. Network failure?
[          pfac] [   33.622440] Process pid 664 terminated, status 00000009.
ashum
Re: TCP/IP connection lost. Network failure?
Сообщение ashum »
Обнаружил, что ошибка происходит когда на сервере в настройках RDP включено Security Layer - RDP Security Layer.
Если поменять на сервере Security Layer на SSL (TLS 1.0), то подключение устанавливается.
В обоих вариантах Encryption Level - FIPS Compliant.
RDP Security Layer (старое, встроенное в RDP шифрование) + FIPS Compliant не работает. Никогда не работало, там слишком заумный шифр для этих FIPS.
FIPS Compliant по умолчанию не установлен.
Не надо включать FIPS со старым шифрованием. Если очень хочется самое крутое шифрование - надо включать SSL и запретить TLS 1.0. Поедет TLS 1.2, это насоклько я понимаю самая круть сейчас. Тут на буржуйском: https://forum.wtware.com/viewtopic.php?t=47423
