COM 8шт
petav
COM 8шт
Сообщение petav »
WTware 5.4.92
Загрузка...
[            gm] [   11.623440] Load serial port driver.
[            gm] [   11.623453] modprobe parport_serial.
[        KERNEL] [   11.620222] Serial: 8250/16550 driver, 8 ports, IRQ sharing enabled
[        KERNEL] [   11.621799] 0000:02:00.0: ttyS4 at I/O 0xe0c0 (irq = 16, base_baud = 115200) is a XR16850
[        KERNEL] [   11.621896] 0000:02:00.0: ttyS5 at I/O 0xe0c8 (irq = 16, base_baud = 115200) is a XR16850
[        KERNEL] [   11.621984] 0000:02:00.0: ttyS6 at I/O 0xe0d0 (irq = 16, base_baud = 115200) is a XR16850
[        KERNEL] [   11.622072] 0000:02:00.0: ttyS7 at I/O 0xe0d8 (irq = 16, base_baud = 115200) is a XR16850
[        KERNEL] [   11.657261] 0000:03:00.0: ttyS0 at I/O 0xd030 (irq = 17, base_baud = 115200) is a ST16650V2
[        KERNEL] [   11.692276] 0000:03:00.1: ttyS1 at I/O 0xd020 (irq = 18, base_baud = 115200) is a ST16650V2
[        KERNEL] [   11.728170] 0000:03:00.2: ttyS2 at I/O 0xd010 (irq = 19, base_baud = 115200) is a ST16650V2
[        KERNEL] [   11.763203] 0000:03:00.3: ttyS3 at I/O 0xd000 (irq = 16, base_baud = 115200) is a ST16650V2
Конфигурация
serial=com5;com6;com7;com8
...Загрузка...
[rdpclient 1014] [   33.511973] Add serial redirection, COM5 in the session = hardware COM5 (PCI Card).
[rdpdr-serial 4] [   33.512036] New client connection, id 1.
[rdpclient 1014] [   33.512042] Add serial redirection, COM6 in the session = hardware COM6 (PCI Card).
[rdpdr-serial 7] [   33.512151] New client connection, id 1.
[rdpdr-serial 6] [   33.512163] New client connection, id 1.
[rdpdr-serial 5] [   33.512167] New client connection, id 1.
[rdpclient 1014] [   33.512171] Add serial redirection, COM7 in the session = hardware COM7 (PCI Card).
[rdpclient 1014] [   33.512180] Add serial redirection, COM8 in the session = hardware COM8 (PCI Card).
Если в serial добавить больше портов, то при загрузке сообщается о не верно сконфигурированном параметре serial. И я так и не понял где порт 8 который я пробросил, по идее надо писать так:
serial=com0;com1;com2;com3;com4;com5;com6;com7;com8
Re: COM 8шт
Втварь не умеет больше восьми портов. И порта COM0 не было.
petav
Re: COM 8шт
Сообщение petav »
Как нет? ttyS0! Какой правильной строкой все порты пробросить?
Re: COM 8шт
Эх, молодёжь...
ttyS0 - это из линуксов.
COM1 - это из DOS.
serial=com1;com2;com3;com4;com5;com6;com7;com8
